Hello. I just got my VCDS and performed an autoscan and came up with a bunch of DTC's, some of which I know the cause of (radio, navigation, park assist), and some need a bit of investigation. After the first scan, which I saved, I cleared all DTC's and went for a drive then came back and did another autoscan. So below are the results. I'm mainly concerned about the engine and ABS brakes sections. Any suggestions, comments, pointers, would be greatly appreciated.
Sunday,26,June,2022,21:31:11:21166
VCDS Version: 22.3.1.4 (x64) HEX-V2 CB: 0.4615.4
VIN: WVGAL27L89D006525 License Plate: 223025
Mileage: 228870km-142213mi Repair Order:
Chassis Type: 7L (6N0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 37 46 55 56 68 6D 76
VIN: WVGAL27L89D006525 Mileage: 228870km-142213miles
37-Navigation -- Status: Not registered 0011
68-Wiper Electr. -- Status: OK 0000
76-Park Assist -- Status: Cannot be reached 1100
Address 01: Engine (BHK) Labels: 03H-906-032-BLV.clb
Part No SW: 03H 906 032 CR HW: 03H 906 032 S
Component: T-GP 7GH G 1671
Revision: 5FH04--- Serial number: VWX3Z0H1769647
Coding: 0001175
Shop #: WSC 31414 790 00001
VCID: 74B1D1E2F2AE054BDB7-5160
VINID: 9E65D17021DC209500006142142CE8050E
008342 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 1
P2096 - 002 - Too Lean
Fault Status: 01100010
Mileage: 228868 km
RPM: 1607 /min
Load: 38.4 %
Speed: 73.0 km/h
Temperature: 87.0°C
Temperature: 45.0°C
Absolute Pres.: 990.0 mbar
Voltage: 14.224 V
008598 - Oxygen (Lambda) Sensor B1 S1
P2196 - 002 - Signal too High (Rich)
Mileage: 228870 km
RPM: 1204 /min
Load: 32.5 %
Speed: 14.0 km/h
Temperature: 87.0°C
Temperature: 48.0°C
Voltage: 14.224 V
Readiness: 0010 0001
Address 02: Auto Trans Labels: 09D-927-750.clb
Part No SW: 09D 927 750 HJ HW: 09D 927 750 HJ
Component: AL 750 6A 1406
Revision: 00H75000 Serial number:
Coding: 0004200
VCID: 7DA7F4C6C1E44403A49-5160
Address 03: ABS Brakes Labels: 7L0-907-379-MK25E1.clb
Part No SW: 7L0 907 379 P HW: 7L0 614 517 C
Component: ESP ALLRAD MK25E1 0304
Revision: 00H53001
Coding: 0010498
VCID: 46D55B2AD4B2C7DBB53-5184
03197 - StopPing Distance Reduction 2 in ADR Control Module (J428)
Reset counter: 177
Mileage: 228865 km
Date: 2022.06.26
Time: 20:40:31
Count: 128
Count: 12545
Count: 8244
Count: 3
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 139 D HW: 3D0 909 139 D
Component: Kessy 6850
Revision: 00H22070 Serial number: VWX3Z0H1769647
Coding: 0000232
VCID: 2A0D0F9A60BA03BBB1B-807E
Component: ELV XXXX
Address 08: Auto HVAC Labels: 7L6-907-040.clb
Part No: 7L6 907 040 AH
Component: CLIMAtronic R/L 4334
Coding: 0021020
VCID: 76B5EBEAE482175BE53-8022
Address 09: Cent. Elect. Labels:. 7Lx-937-049-V2.clb
Part No SW: 7L6 937 049 AF HW: 7L6 937 049 AF
Component: J519 2002
Revision: -0004--- Serial number: --------------
Coding: 600004003B061C000000000000000000
VCID: 00598D32B64629EBCFF-8054
007 - Short to Ground
Address 15: Airbags Labels: 7L0-959-655.lbl
Part No SW: 7L0 959 655 HW: 7L0 959 655
Component: J234__36 VW8T 0250
Revision: 92012025 Serial number: 0039P005CD5T
Coding: 0013110
VCID: 7AADFFDAD09A733B81B-802E
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 F
Component: J527 3601
Coding: 0010011
VCID: 42DD473AF8CAFBFB99B-8016
Address 17: Instruments Labels: 7L6-920-xxx-7L6.lbl
Part No SW: 7L6 920 875 P HW: 7L6 920 875 P
Component: J285 KOMBI-INST. 8828
Revision: KHH05V35
Coding: 0007601
Shop #: WSC 16073 002 1048576
VCID: 48C95512DEB6D1AB47F-801C
Address 19: CAN Gateway Labels:. 6N0-909-901-7L.clb
Part No SW: 6N0 909 901 HW: 7L6 920 875 P
Component: J533 GW-K-CAN TP20 8828
Coding: 77E2E79940046002
VCID: 70B9DDF286A6396B3FF-8024
Reset counter: 177
Mileage: 228865 km
Date: 2022.06.26
Time: 20:39:43
01327 - Control Module for Parking Aid (J446)
Reset counter: 177
Mileage: 228865 km
Date: 2022.06.26
Time: 20:39:47
Address 22: AWD Labels: None
Part No: 0AD 927 755 BG
Component: TRANSFERCASE 0126
VCID: 015F8836BD1C20E3C01-5160
Address 37: Navigation
Address 46: Central Conv. Labels: 7L0-959-933.lbl
Part No: 7L6 959 933 A
Component: 23 HSG 0601
Coding: 0000085
Shop #: WSC 16077 002 1048576
VCID: 40D94D32F696E9EB8FF-4B3C
Subsystem 1 - Part No: 7L0 959 701 M
Component: Tuersteuergeraet FS 6304
Subsystem 2 - Part No: 7L0 959 702 M
Component: Tuersteuergeraet BF 6304
Subsystem 3 - Part No: 7L6 959 703
Component: Tuersteuergeraet HL 0202
Subsystem 4 - Part No: 7L6 959 704
Component: Tuersteuergeraet HR 0202
Address 55: Headlight Range Labels: 7L6-907-357-A.lbl
Part No SW: 7L6 907 357 A HW: 7L6 907 357 A
Component: AFS-Steuergeraet 0001
Revision: H02 Serial number:
Coding: 1286275
VCID: 392F20D6951CB823C81-806C
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l S002
Coding: 00000019
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r S002
Coding: 00000019
Address 56: Radio
Address 68: Wiper Electr. Labels: 7L0-955-119-V2.clb
Part No: 7L6 955 119 B
Component: J400__ Front Wiper 5301
Coding: 0001397
VCID: 392F20D6955CB823C81-806C
Component: RLS 050608 054 0402
Coding: 00208941
Shop #: WSC 31414
Address 6D: Trunk Elect. Labels: 7L6-959-107.clb
Part No SW: 7L6 959 107 B HW: 7L6 959 107 B
Component: J605 HECKKLAPPE 1310
Revision: --H05--- Serial number: --------035626
Coding: 0122110
VCID: 3A2D3FDA901AB33BC1B-806E
Address 76: Park Assist
End----------(Elapsed Time: 02:33, VBatt start/end: 12.5V/12.6V)-----------
