09 VW Beetle
pebjr
North Carolina, USA
C?ID=194904
I'm working on this vehicle and I have several issues that I'm hoping to get some help.
The vehicle seems to run ok and I have fixed some issues already. The car was just recently purchased from a used car dealer.
Had a coolant leak which was the coolant flange and seal.
The passenger side window wont roll down and door lock not working. The driver side door harness has some broken wires which I assume will fix the issues once I repair or replace the harness.
The airbag light is on.
CEL is on
The idle seems to be somewhat off when first started, just cant put my finger on it
any help would be appreciated in steering me in the right direction.
VIN: 3VWPW31C19M515202   License Plate: EMILEE
Mileage: 266590km-165651mi   Repair Order:
Chassis Type: 1C (9C - VW New Beetle (1999 > 2010))
Scan: 01 02 03 08 15 17 19 25 29 35 37 39 46 54 56 65 75
VIN: 3VWPW31C19M515202   Mileage: 266590km-165651miles
Address 01: Engine (BPS)       Labels: 06A-906-032-BGP.lbl
   Part No SW: 07K 906 032 CH    HW: 07K 906 032 AA
   Component: NB R5 AT        G   2783
   Revision: 1SH04---    Serial number: VWX5Z0I1278050
   Coding: 0000003
   Shop #: WSC 00066 000 00000
   VCID: 71BFD8EF7DA3F2E3301-8024
   VINID: 0E69E09C305304974504508008EAE8E4DF
001109 - EVAP System
               P0455 - 001 - Large Leak Detected - MIL ON
                    Fault Status: 11100001
                    Mileage: 266276 km
                    RPM: 1448 /min
                    Load: 31.8 %
                    Speed: 57.0 km/h
                    Temperature: 63.0°C
                    Temperature: 33.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.970 V
012408 - Throttle Control
               P3078 - 002 - Airflow at Idle too Low
                    Fault Status: 01100010
                    Mileage: 266281 km
                    RPM: 674 /min
                    Load: 24.7 %
                    Temperature: 81.0°C
                    Temperature: 34.0°C
                    Voltage: 13.462 V
   Part No SW: 09G 927 750 JT    HW: 09G 927 750 JT
   Component: AQ 250 6F           1380
   Revision: 00H77000    Serial number:
   Coding: 0000008
   VCID: 0C41A91B7A51BF0BA37-513C
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
   Part No: 1C0 907 379 Q
   Coding: 0019978
   VCID: 382925CB5E4963AB37F-5160
Address 15: Airbags        Labels: 1T0-909-605.lbl
   Part No: 6Q0 909 605 AK
   Component: 01 AIRBAG VW71      0911
   Coding: 0012337
   VCID: 00598D2B4649EB6BCFF-8054
   Subsystem 1 - Component: BF-Gewichtsens.
00472 - Control Module for Brake Boost (J539)
Address 17: Instruments        Labels: None
   Part No: 1C0 920 801 L
   Component: KOMBI+WEGFAHRS. M73 V05
   Coding: 11234
   Shop #: WSC 00066
   VCID: 2411E1BBF7C1174B8B7-4B1E
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    V052
   Coding: 00006
   Shop #: WSC 00066
   VCID: 70B9DDEB73B9FBEB3FF-4B1E
Address 25: Immobilizer        Labels: 1C0-920-xxx-25.clb
   Part No SW: 1C0 920 801 L    HW: 1C0 920 801 L
   Component: IMMO                X007
   Revision: xxxxxxxx    Serial number: VWX5Z0I1278050
   VCID: 2411E1BBF2C1174B8B7-5160
Address 35: Centr. Locks        Labels: 1C0-962-258-III.lbl
   Part No: 1C0 962 258 AC
   Component: 4G Zentr.Verriegel. 0004
   Coding: 00016
   Shop #: WSC 00066
   VCID: 6889B58B4B69332B67F-4B00
Address 56: Radio        Labels: 1J0-035-18x-56.clb
   Part No: 1C0 035 196 CS
   Component:  RADIO DE2         0006
   Coding: 00403
   Shop #: WSC 01814
   VCID: 72BDD7E37DB5C9FBC9B-51CE
Address 65: Tire Pressure        Labels: None
   Part No SW: 1C0 907 273     HW: 1C0 907 273
   Component:    RDK          H02 0220
   Revision: --H02-D0    Serial number: 12830790003554
   Coding: 0100101
   VCID: 6099ADABA6494B6BAFF-8034
02214 - Tire Pressure Warning
                    Reset counter: 49
                    Mileage: 266375 km
                    Date: 2064.00.00
                    Time: 00:00:14
                    Text: 3443652357
                    Pressure: 1.90 bar
                    Pressure: 2.30 bar
                    Temperature: 31.2°C
                    Text: 00
                    Speed: 64.0 km/h
End----------(Elapsed Time: 03:11, VBatt start/end: 12.1V/12.1V)-----------
I would focus on the EVAP System Leak. That's what's got your Check Engine light on.
Have you tried clearing the Airbag fault? It is flagged "Intermittent", meaning the fault condition that set the DTC did not exist (or could not be detected) at the time the scan was performed.
pebjr
North Carolina, USA
C?ID=194904
I've cleared the CEL, but did not think about going into the airbag system and clearing its code.
I think the CEL may be the N80 valve from what I've been reading, but have not check yet.
I'm heading out of town this afternoon and wont be back till Friday to work on the car.
In the meantime any other suggestion would be greatly appreciated...
