Mk5 VW Golf Dashboard replacement
PaulSergio
New Zealand
HI,
have a MK5 golf that needs new dashboard due to something is wrong with CAN Bus. Two Garages and
Local factory dealer says that it needs new dashboard. and apparently VW Germany is not supplying new ones .
The Dealer said you cannot transfer immobiliser between secondhand dashboards as VW have locked them
Can anyone supply a solution ?
Regards
Paul Cotogni
Sergio & Son Automotive
Lower Hutt
New Zealand
2kaa52
C?ID=319193
Swapping a used dash into a golf mk5 is no Problem,if you have the correct tools and the knowlegde what exactly is to do.
Vcds cant do it.
Vw dealership can do this job with his odis Software also.
siLc
Tallinn, Estonia
C?ID=330192
Vcds cant do it.
Yep, but you might find that the dealership doesn't want to touch used parts.
Just find someone with the correct tools and knowledge.
PaulSergio
New Zealand
Thankyou for your replies
Dealer says that secondhand dash cannot be recoded due to VW software is locked on this model. Can only code in a new virgin dash which they cannot supply as VW is not supplying them any more. In New Zealand and not too many knowledgeable Techs here.
Seems like a waste of a car as it has only done 40,000k's
2kaa52
C?ID=319193
What your dealer says is not true. If you cant find help in NZ,contact me.
Westbury, UK
I strongly suspect that what the dealer actually means is that they cannot do it using only official VW tools.
siLc
Tallinn, Estonia
C?ID=330192
When they say they can't provide new clusters, then they're right - new Golf Mk5 clusters were dropped in 2019.
NZDubNurd
New Zealand
C?ID=230482
I can do early MK5, but I'm in Northland... about 8 hours drive north!
What model year is the car (not the rego year, the VIN year). with this info, I may be able to find someone nearer to you.
I'm struggling to think of anybody based in your area. Sutherland Performance are in Wellington, and may have the tools required?
My suggestion would be to post on the VASK facebook page, or maybe forum.
My concern is that some people know what they are doing and some may not...
You'll need the new unit Immo matched, coded and kms matched. You also need to make sure you get a compatible part number.
PaulSergio
New Zealand
Thankyou for all your help
According to the VIN the car is a 2007 FSI
Might have found someone local that can do it hopefully
Mark at Capital Auto Electrics
JMR
EU
C?ID=432218
hmmm..you never posted an auto scan so we all see them problems in the CAN area...i 'm curios what the problem is ..?
