Seat Ibiza abs pump long coding
Chrishendy
Wakefield, UK
C?ID=231476 (NRRT)
Hi everyone I’m new to the forum. Ive got a 2009 59 seat Ibiza in we replaced the abs pump with a used on. due to it constantly buzzing even with the ignition turned off. Customer was having to disconnect the battery to stop it draining and the abs light was on. The abs light now is flashing and the fault is saying it needs coding. When I go into it there’s just zero00000’s where the code should be. Any ideas or advice to get the correct would be much appreciated. The chassis Num is VSSZZZ6JZAR038199 it’s just a standard petrol 1.4 I think front discs and rear drums the abs no is 6RO 907 379 AD. Thanks Chris
Please see:
The most important thing there is: Please post an Auto-Scan for complete context.
iichel
Netherlands, Operation Market Garden
C?ID=284912
120200E3007000BA482600EB00DA00000000
or
120200E3007000BA482600EB00DA00010000
or
120200E3017000BA482600EB80DA00000000
or
120200E3017000BA482600EB80DA00010000
Chrishendy
Wakefield, UK
C?ID=231476 (NRRT)
Hi again thanks for the response. the long codes you provided iichel didn’t work. Here’s the data from the auto scan if this can help. Thanks again
Saturday,25,June,2022,16:46:24:58068
VCDS Version: 22.3.1.4
VIN: VSSZZZ6JZAR038199   License Plate:
Mileage: 164130km-101985mi   Repair Order:
Chassis Type: 6J-SE25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 4B 56
VIN: VSSZZZ6JZAR038199   Mileage: 164130km-101985miles
Address 01: Engine        Labels: 03C-906-024-BXW.lbl
   Part No SW: 03C 906 024 BK    HW: 03C 906 024 BK
   Component:       BXW   MM4HV G 4119
   Revision: --H11---    Serial number:
   Coding: 0000071
   Shop #: WSC 06402 785 00200
   VCID: 68D8320758910FCF67-5164
   VINID: 9A38EAAAA19AA918800C804924256600F1
18049 - Please check DTC Memory of A/C Controller
            P1641 - 000 -
                    Reset counter: 170
                    Mileage: 164135 km
                    Date: 2016.11.15
                    Time: 22:12:56
                    Bin. Bits: 00000000
                    Lambda: 0.0 %
                    Temperature: 26.0°C
                    Absolute Pres.: 989.4 mbar
Readiness: 0010 0101
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ABS82.clb
   Part No SW: 6R0 907 379 AD    HW: 6R0 907 379 AB
   Component: ABS8.2 front  H03 0001
   Revision: --------
   Coding: 000000000000000000000000000000000000
   Shop #: WSC 04941 000 00000
   VCID: 00080AA797E1D78FCF-8054
03306 - Coding Not Valid
                    Fault Frequency: 13
                    Reset counter: 210
                    Mileage: 164135 km
                    Date: 2016.11.15
                    Time: 15:48:15
                    Hex Value: 0x0001
                    Hex Value: 0x0000
                    Hex Value: 0x3027
                    Hex Value: 0x149A
                    Hex Value: 0x00FF
                    Hex Value: 0x007F
                    Hex Value: 0x7E00
                    Hex Value: 0x0000
                    Fault Frequency: 14
                    Reset counter: 170
                    Mileage: 164135 km
                    Date: 2016.11.15
                    Time: 19:44:08
                    Hex Value: 0x0005
                    Hex Value: 0x0000
                    Hex Value: 0x3013
                    Hex Value: 0x149B
                    Hex Value: 0x00FF
                    Hex Value: 0x007F
                    Hex Value: 0x7F00
                    Hex Value: 0x0000
Address 08: Auto HVAC        Labels: 6J0-820-045.clb
   Part No SW: 6J0 820 045     HW: 6J0 820 045
   Component: J301  Klimaanlage   0280
   Revision: 00 23 08    Serial number: 0000000193655-
   VCID: 63C2252BA2B76C97B2-8036
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 169
                    Mileage: 164135 km
                    Date: 2016.11.15
                    Time: 00:04:13
   Part No SW: 6R0 937 087 B    HW: 6R0 937 087 B
   Component: PQ25 BCM      H08 0025
   Revision: BF008001    Serial number: 9955A180090923
   Coding: 24882BE888610100003000007E0B1CC800C0400F608C00002000
   Shop #: WSC 64564 324 38760
   VCID: 3C70BE57BF89736FD3-8068
   Subsystem 1 - Part No SW: 6R0 959 802     HW: 6R0 959 802   Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  001 0239
   Coding: 030000
   Subsystem 2 - Part No SW: 6R0 959 801 B    HW: 6R0 959 801 B  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  001 0243
   Coding: 020000
   Subsystem 3 - Part No SW: 6R0 959 811     HW: 6R0 959 811
   Component: J388__TSG_HL  001 0245
   Subsystem 4 - Part No SW: 6R0 959 812     HW: 6R0 959 812
   Component: J389__TSG_HR  001 0246
   Part No SW: 6R0 959 655 C    HW: 6R0 959 655 C
   Component: VW10AirbagA0D H09 0018
   Revision: --------    Serial number: 003DW0049GUL
   Coding: 003044
   Shop #: WSC 06401 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 428CC0AFD56D059F99-8016
   Serial number: 3496GRB402V9CK5T8S2B
   Serial number: 3506GRB40358UK5J24KG
   Part No SW: 6J0 920 901     HW: 6J0 920 901
   Component: KOMBI         H07 0110
   Coding: 410A00
   VCID: 65C63B33648312A75C-8030
   Part No SW: 6N0 909 901     HW: 6R0 937 087 B
   Component: GW-K-CAN TP20 0025
   Coding: 022300
   VCID: 70E85A67A341C70F3F-8024
   Component: IMMO          H07 0110
   Part No: 6R0 423 156 A
   Component: LenkhilfeTRW        V275
   Coding: 10111
   Shop #: WSC 06402
   VCID: 2E54841FEDF591FF6D-807A
Address 4B: Multifunc. Module        Labels: 6J0-959-441.clb
   Part No: 6J0 959 441
   Component: MF-Modul       0007 0001
   Coding: 0000001
   Shop #: WSC 77005 000 00000
   VCID: 70E85A676341C70F3F-8024
Address 56: Radio (J503)       Labels:. 6J0-035-153.clb
   Part No SW: 6J0 035 153 B    HW: 6J0 035 153 B
   Component: Radio G3 UL   H56 0034
   Revision: 0H001001    Serial number: SEZ1Z2I6317280
   Coding: 0503040002
   VCID: 2342652B22372C97F2-8076
End-------------------------(Elapsed Time: 02:22)--------------------------
JMR
Romania
C?ID=432218
vis4vag comes with about 10-12 combinations of coding for this car...so ....@Dana @etz2k might help you faster
Chrishendy
Wakefield, UK
C?ID=231476 (NRRT)
Please see:
a guess at any reason why the coding might be lost? what happened?
The original pump was constantly buzzing even with ignition off and it was draining the battery. I’ve replaced the abs pump with a second hand unit. So can only imagine it has been wiped prior to sale. Thanks
Westbury, UK
When an ABS is fitted into a different vehicle it detects the VIN mismatch and deletes its coding - wrong coding COULD be a safety risk so VAG have included this into their firmware.
  • Agree
Chrishendy
Wakefield, UK
C?ID=231476 (NRRT)
So the coding from the old pump would be the same??
etz2k
C?ID=69430
It's possible, but it doesn't have to be, because the ABS can't check if all things (for example the size of the brake parts) of your coding are correct for your car.
