U1123 P050A Crank no start
EuroMasterTek
Las Vegas, USA
C?ID=104263
Hi guys, fighting with this weird case, crank no start, charger is connected, verified timing is ok, compressions 100-110psi all, spark is present, fuel pressure, low-5bars, high 80bars, still no fire up. any ideas??
Thank you for your support!!!
Here's the full scan:
Friday,24,June,2022,08:56:04:27081
VCDS Version: 22.3.1.4 (x64)  HEX-NET CB: 0.4615.4
VIN: 1VWAT7A32FC0107xx   License Plate: HURTADO
Mileage: 179340km-111436mi   Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 4F 52 56 62 72 77
VIN: 1VWAT7A32FC0107xx   Mileage: 179340km-111436miles
Address 01: Engine (J623-CPRA)       Labels:. 06K-907-425-V2.clb
   Part No SW: 06K 997 071 G    HW: 06K 907 425 C
   Component: R4 1.8l TFS   H13 9372
   Revision: --H13---    CVN: 0B000D33
   Coding: 001A0012242400170000
   Shop #: WSC 35039 005 1048576
   ASAM Dataset: EV_ECM18TFS02006K997071G 001005
   ROD: EV_ECM18TFS02006K906071K.rod
   VCID: 393ADB1DB8305B47C8-806C
   VINID: 0669D19074430964C00401C81C7687CD8A
17178 - Databus
          U1123 00 [039] - Received Error Message
                    Fault Frequency: 22
                    Mileage: 179349 km
                    Date: 2022.06.24
                    Time: 04:22:06
                    Engine RPM: 0.00 /min
                    Coolant temperature: 27 °C
                    Intake air temperature: 29 °C
                    Ambient air pressure: 930 mbar
                    Voltage terminal 30: 12.167 V
                    Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                    Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                    Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                    Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                    Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                    Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                    Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                    Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
                    Drivetrain coordinator: brake fault status-ESP system error: No
15080 - Cold Start Idle Air Control System
          P050A 00 [039] - Malfunction
                    Mileage: 179349 km
                    Date: 2022.06.24
                    Time: 04:31:29
                    Engine RPM: 382.75 /min
                    Normed load value: 40.0 %
                    Voltage terminal 30: 10.683 V
                    Engine: operating status: IS
                    STATE_LS_SAE[1]: OL_CDN
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 91 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
                    FAC_TPS_1_SAE: 30.859375 %
                    FUP_H_SAE: 3060.0 kPa
Readiness: 1110 1101
Address 02: Auto Trans (J217)       Labels:* 09G-927-749-V1.clb
   Part No SW: 09G 927 749 B    HW: 09G 927 749 B
   Component: AISIN AG6 G3  109 2855
   CVN: E39A1153
   Coding: 000348
   Shop #: WSC 09003 957 00200
   ASAM Dataset: EV_TCMAQ250031 001004
   ROD: EV_TCMAQ250031_001.rod
   VCID: 383CDE19833A424F37-806C
   Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
   Component: ESP MK60EC1   H46 0164
   Revision: 00H46001
   Coding: C54BC0F5492300FAA31203EC92200041A1100012
   VCID: 7EB00801E99EBC7FBD-802A
7 Faults Found:
                    Fault Status: 00100001
                    Reset counter: 103
                    Mileage: 179349 km
                    Count: 16391
                    Count: 12
                    Count: 12288
                    Count: 129
                    Count: 65280
                    Count: 256
                    Count: 512
                    Reset counter: 103
                    Mileage: 179349 km
                    Date: 2016.10.19
                    Time: 00:00:27
                    Count: 12
                    Count: 20480
                    Count: 8208
                    Count: 43008
                    Count: 512
                    Count: 509
                    Fault Status: 00101101
                    Reset counter: 103
                    Mileage: 179349 km
                    Date: 2016.07.17
                    Time: 04:21:58
                    Count: 7
                    Count: 12
                    Count: 28928
                    Count: 8269
                    Count: 41472
                    Count: 511
                    Reset counter: 103
                    Mileage: 179349 km
                    Date: 2016.07.17
                    Time: 00:57:14
                    Count: 7
                    Count: 13
                    Count: 28672
                    Count: 128
                    Count: 29696
                    Count: 511
                    Reset counter: 103
                    Mileage: 179349 km
                    Date: 2016.07.17
                    Time: 00:05:60
                    Count: 2
                    Count: 12
                    Count: 20480
                    Count: 16390
                    Count: 43520
                    Count: 511
                    Reset counter: 103
                    Mileage: 179349 km
                    Date: 2016.10.19
                    Time: 00:00:59
                    Count: 16386
                    Count: 12
                    Count: 20480
                    Count: 166
                    Count: 41984
                    Count: 253
                    Count: 3072
02214 - Tire Pressure Warning
                    Fault Status: 01100010
                    Reset counter: 103
                    Mileage: 179349 km
                    Date: 2016.07.17
                    Time: 00:05:51
                    Count: 3
                    Count: 12
                    Count: 20480
                    Count: 16401
                    Count: 43264
                    Count: 511
   Part No SW: 561 907 426 D    HW: 561 907 426 D
   Component: AC Manuell    H02 0303
   Revision: 00001K02
   Coding: 0010001002
   ROD: EV_ACManuaElectGen2BHTC_VW36.rod
   VCID: 1C74228917C20E6F33-8048
   Part No SW: 5K0 937 085 AB    HW: 5K0 937 085 AB
   Component: BCM PQ35 B+   122 0174
   Revision: BH122001
   Coding: EF200E18902B08D4088000010600044800F1A08640801920648060000C70
   VCID: 73A62935D2DCE117C2-8026
7 Faults Found:
                    Reset counter: 143
                    Mileage: 179349 km
                    Date: 2016.11.11
                    Time: 04:20:50
                    Voltage: 8.25 V
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 103
                    Mileage: 179349 km
                    Date: 2016.11.14
                    Time: 00:35:29
                    Voltage: 12.55 V
                    Reset counter: 103
                    Mileage: 179349 km
                    Date: 2016.11.14
                    Time: 00:35:29
                    Voltage: 12.60 V
                    Reset counter: 103
                    Mileage: 179349 km
                    Date: 2016.11.14
                    Time: 00:35:29
                    Voltage: 12.60 V
                    Reset counter: 103
                    Mileage: 179349 km
                    Date: 2016.10.22
                    Time: 01:00:54
                    Voltage: 10.25 V
                    Reset counter: 103
                    Mileage: 179349 km
                    Date: 2016.11.14
                    Time: 00:12:43
                    Voltage: 12.55 V
03189 - Bulb for Side Marker Light; Front Right
                    Reset counter: 103
                    Mileage: 179349 km
                    Date: 2016.11.14
                    Time: 00:35:28
                    Voltage: 12.55 V
   Part No SW: 5C0 959 655 AB    HW: 5C0 959 655 AB
   Component: AirbagVW10    500 0975
   Serial number: 003LZD01GMUC
   Coding: 00004D4E
   Shop #: WSC 33169 002 1048576
   ASAM Dataset: EV_AirbaVW10SMEVW360 001030
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 72A82C31A5C6E81FC9-8026
   Serial number: 6940000Y1400015ZZW0.
   Coding: 303048
   Serial number: 3572MSME32477A44ZZZY
   Serial number: 3582MSME42565B45ZZZ-
   Serial number: 3516KSME0650342EZZZN
   Subsystem 5 - Part No SW: 5K0 959 659 A    HW: 5K0 959 659 A
   Serial number: 3556LSME1F40572EZZZ%
   Serial number: 3566LSME2342572EZZZY
9443605 - Rear Side Airbag Crash Sensor (on front passenger's side)
          B1019 15 [137] - Open or Short to Plus
                    Mileage: 179349 km
                    Date: 2022.06.01
                    Time: 01:00:36
          B10B4 00 [008] - Function Restriction due to Undervoltage
                    Reset counter: 143
                    Mileage: 179349 km
                    Date: 2022.06.24
                    Time: 04:44:50
   Part No SW: 1K5 953 521 BN    HW: 5K0 953 569 AE
   Revision: FF010042    Serial number: 20140609300929
   Coding: 488A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7AB80411FDB6905F81-802E
   Subsystem 1 - Part No SW: 561 959 537     HW: 561 959 537
   Coding: 620000
   Part No SW: 561 920 960 D    HW: 561 920 960 D
   Component: KOMBI         H04 0809
   Coding: 230E01
   VCID: 1A7824911DF6705F21-804E
   Part No SW: 7N0 907 530 AR    HW: 7N0 907 530 AM
   Component: J533  Gateway H55 1653
   Revision:   H55       Serial number: 24061403000700
   Coding: 461000
   Shop #: WSC 00000 960 410406
   VCID: 004C76F9936ACA8FCF-8054
   Component: IMMO          H04 0809
   VCID: 6A9834518D1620DF71-803E
   Revision: 13110009    Serial number: 0008592901
   Coding: 040495
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 5BF66195524C4957FA-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811 B    HW: 561 959 811 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  006 5470
   Serial number: 14202630140512211209
   Coding: 800000
          B11EC 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 143
                    Mileage: 179349 km
                    Date: 2022.06.01
                    Time: 01:00:37
131584 - Motor for Rear Window Regulator
          B11EE 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 103
                    Mileage: 179349 km
                    Date: 2022.06.01
                    Time: 01:00:37
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 211    3501
   Revision: 00H22000
   VCID: 393ADB1D70305B47C8-806C
   Component: EZE_2         H55 1653
   Coding: 00000008
   VCID: 6FAE2545BEF4C5F726-803A
   Subsystem 1 - Part No SW: 561 919 204 B    HW: 561 919 204 B
   Revision: 15110009    Serial number: 0008585842
   Coding: 040494
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 5CF4628957424E6FF3-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812 B    HW: 561 959 812 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  006 5470
   Serial number: 14202631140626212341
   Coding: 800000
                    Reset counter: 143
                    Mileage: 179349 km
                    Date: 2022.06.01
                    Time: 01:00:39
                    Reset counter: 103
                    Mileage: 179349 km
                    Date: 2022.06.01
                    Time: 01:00:39
   Part No SW: 1K0 035 164 D    HW: 1K0 035 164 D
   Component: LOW NAR       H03 0006
   Revision: -----07S    Serial number: VWZ4Z6P3813080
   Coding: 0500040002000B
   VCID: 2306197522BC3197F2-8076
   Part No SW: 7P6 035 730 N    HW: 7P6 035 730 N
   Component: TELEFON       H15 4217
   Revision: 1B001001    Serial number: 00007666122497
   Coding: 0A10040000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3D32CF0DAC186767E4-8068
End----------(Elapsed Time: 01:08, VBatt start/end: 12.3V/12.3V)-----------
Jef
HQ
100 to 110 PSI compression... that doesn't sound good at all. I would expect around 180 PSI.
Is there some back story. It also appears that codes has been cleared in the ECM prior to the Auto-Scan... where there additional codes? What is your fuel rail pressure during cranking (location IDE00188)?
EuroX
Northern NJ USA
C?ID=208579
100-110psi tells me timing is either far from ok. or there is an issue with the internals of the engine or the cylinders are washed out.
In regards to your fault. If it applies to this vin there is a known software flash for this fault. However this fault will not stop you from starting the engine.
