2020 AUDI Q7 45 TDI fuel tank indicator malfunction with yellow engine light
MRARC
New Zealand
C?ID=445236
Greeting from NZ.
Hello everyone, I am new to the forum.
We purchase the Q7 from UK. About 900 miles on the clock and having few issues so far. First was the NoX sensor that had been fixed thanks to VCDS.
The current problem is the tank indicator malfunction that come with some other faults. They may be related.
There is no warranty come with the car in NZ since this is a UK import. Not even the 2 years manufacturer warranty because the local AUDI dealer here just does not want to deal with it. (unlike the local BMW here that has a different attitude).
I attached the vcds scan below. Hope someone can help us to pin-point the problem.
Cheers.
Sunday,12,June,2022,16:00:00:21199
VCDS Version: 21.9.0.2 (x64)  HEX-NET2 CB: 0.4555.4
VIN: WAUZZZ4MXLD011547   License Plate: NSH678
Mileage: 9426km-5857mi   Repair Order:
Chassis Type: 4M-AU73 (4N1)
Scan: 01 02 03 09 15 16 17 19 2B 36 42 44 46 50 52 5F 61 69 6C 6D
          74 81 A5 AC BB BC C4 CC D6 D7 DE
VIN: WAUZZZ4MXLD011547   Mileage: 9426km-5857miles
50-Seat Adj. 3rd row -- Status: OK 0000
74-Chassis Control -- Status: Malfunction 0010
C4-DC/DC Converter -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
Address 01: Engine (J623-DHXC)       Labels: None
   Part No SW: 4M0 907 401 AJ    HW: 059 907 309 L
   Component: 3.0l V6 TDI   H26 0002
   Revision: CAH26---    CVN: 527AAEE00406833F8947E11D8947E11DD6C3ECFE
   Coding: 2A2A4032053E050334086000000000000000000000000000
   Shop #: WSC 32482 003 1048576
   ASAM Dataset: EV_ECM30TDI0114M0907401AJ 001002
   ROD: EV_ECM30TDI0114M0907401AJ.rod
   VCID: 71B4BCF0F15C367358F-8124
   VINID: 9D196AAAA11DA1C5000411441C277080C3
23734 - Implausible Data Received from Instrument Panel Control Module
          U0423 00 [175] - -
          [Invalid Data Received FromInstrument Panel Cluster Control Module]
                    Mileage: 9399 km
                    Date: 2022.06.11
                    Time: 16:17:10
                    Engine RPM: 0.00 /min
                    Coolant temperature: 33 °C
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 11.660 V
                    Com st X Set2 Val1-Bits 0-7: 0
                    Com st X Set2 Val2-Bits 0-7: 0
                    Com st X Set2 Val3-Bits 0-7: 0
                    Com st X Set2 Val4-Bits 0-7: 0
                    Com st X Set2 Val5-Bits 0-7: 0
                    Com st X Set2 Val6-Bits 0-7: 0
                    Com st X Set2 Val7-Bits 0-7: 0
                    Com st X Set2 Val7-Bits 0-7: 1
Readiness: 1 1 0 0 0
   Part No SW: 4M0 927 158 DN    HW: 0D5 927 156 P
   Component: 0D5 30TDIRdW  H05 0001
   Revision: --H05---    CVN: 47A00D8300005592
   Coding: 100000
   Shop #: WSC 31414 033 00001
   ASAM Dataset: EV_TCMALX52011 002016
   ROD: EV_TCMALX52011.rod
   VCID: 0358E638DBE034E3BA3-8156
   ATF pump:
   Subsystem 1 - Part No SW: 4M0 927 154 AA    HW: 0D7 321 281 A
   Component: V552 ATFP  H02 0810
   Serial number: 1911271482
Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-PRE-V1.clb
   Part No SW: 4M6 907 379 AE    HW: 4M6 907 379 B
   Component: ESP9 Premium  H06 0857
   CVN: E9DB63B6
   Coding: 24982CB231A30A97D3A358951884D2D2F5BAE024348C50CB1A184B4BAF5D07
   ROD: EV_ESP9BOSCHCMP_004_AU49.rod
   VCID: 0052E934CAF62FFBA71-8154
Address 09: Cent. Elect. (J519)       Labels:* 4N0-907-063-V2.clb
   Part No SW: 4N0 907 063 KG    HW: 4N0 907 063 AG
   Component: BCM1 MLBevo   H10 0691
   Coding: 07000143E13900CD070C87089FBE8C78130B33100006009701000800393216810A45093202560508000001000001001B1000000000010100000000000000000000
   Shop #: WSC 31414 049 00001
   ASAM Dataset: EV_BCM1BOSCHAU651 016011
   ROD: EV_BCM1BOSCHAU651_016.rod
   VCID: 7DAC90C0BD044213CC7-8128
   Subsystem 1 - Part No SW: 4M8 955 119 A    HW: 4M8 955 119 A  Labels: 1KX-955-119.CLB
   Component: J400FRWISCH  052 0997
   Serial number: 904853F0401908101228
   Coding: 7DC727
   Serial number: 23986040X81A955555A0
   Coding: 02005E
   Subsystem 3 - Part No SW: 4K2 941 501 R    HW: 4K2 941 501 R
   Component: E1 - LTM  H06 0060
   Serial number: 17S06.12.1900302650
   Serial number: GX1CE105091923610933
   Coding: 210000
   Interior Light Module:
   Subsystem 5 - Part No SW: 4M0 947 135 DQ    HW: 4M0 947 135 DQ
   Component: Dachmodul  H42 0416
   Serial number: Q00832197
   Coding: 0D0106
   Part No SW: 4KE 959 655     HW: 4KE 959 655
   Component: AirbagVW32    H42 3122
   Serial number: 003XPM019EM0
   Coding: AACCF0D80CC0000098F650FFF08D400000C5
   Shop #: WSC 31414 027 00001
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001034
   ROD: EV_AirbaVW31SMEAU65x.rod
   VCID: 0B48CE18F3B07CA3C23-815E
   Subsystem 1 - Part No SW: -----------    HW: 480 000 412 19
   Serial number: 3570000000070371C248
   Subsystem 2 - Part No SW: -----------    HW: 480 000 412 19
   Serial number: 3580000000010171C241
   Subsystem 3 - Part No SW: -----------    HW: 480 030 512 19
   Serial number: 351002C004DD75401F21
   Subsystem 4 - Part No SW: -----------    HW: 480 030 912 19
   Serial number: 352002C0053D308139D$
   Subsystem 5 - Part No SW: -----------    HW: 480 032 011 19
   Component: FrontSensor_D  002 014A
   Serial number: 355002C00E83D90078AD
   Subsystem 6 - Part No SW: -----------    HW: 480 032 011 19
   Component: FrontSensor_P  002 014A
   Serial number: 356002C00E889A10DE2L
   Subsystem 7 - Part No SW: -----------    HW: 480 030 612 19
   Component: PedP_Sensor_C  002 0149
   Serial number: 230002C0053A7990DD13
   Subsystem 8 - Part No SW: -----------    HW: 480 000 511 19
   Serial number: I0M000000006CB8C71CN
   Subsystem 9 - Part No SW: -----------    HW: 480 000 511 19
   Serial number: I0N000000009BB8C71CQ
   Part No SW: 4N0 907 129 AH    HW: 4N0 907 129 AH
   VCID: 77A082E89F38684396B-8122
   Part No SW: 4K0 920 790 B    HW: 4K0 920 790 B
   Component: FBenRDWACC--- H12 0212
   Coding: A4A480D4788006000123E160B0806B0008003800
   ROD: EV_DashBoardAU65X_001_AU73.rod
   VCID: 2C0A6D8416FE1B9B2B9-8178
13639428 - Databus
          [ECU for body control module 2 error value received]
                    Reset counter: 69
                    Mileage: 9426 km
                    Date: 2022.06.12
                    Time: 15:32:20
   Part No SW: 4N1 907 468 BL    HW: 4N1 907 468 AB
   Component: Gateway       H16 0063
   Revision: CL010002    Serial number: 028CL505719C03
   Coding: 020100010004864073960000005B0132489A0000180000000975078E10000000
   Shop #: WSC 31414 147 00001
   GVL: 01503C0008040200829C08000002C80001082010000000000000000000000000
   ASAM Dataset: EV_CGateCONTIAU491 004190
   ROD: EV_CGateCONTIAU491_004_VW53.rod
   Subsystem 1 - Part No SW: 4M8 951 523     HW: 4M8 951 523
   Component: J453 MFL  H07 0004
   Serial number: 20191118122105 31133
   Serial number: 1279453305
8913154 - Databus
          [Signal_Error_Tank_Level_High_Resolution]
                    Fault Frequency: 24
                    Reset counter: 69
                    Mileage: 9399 km
                    Date: 2022.06.11
                    Time: 16:18:01
   Part No SW: 3Q0 905 861 C    HW: 3Q0 905 861 C
   Component: ELV-MLBevo    H05 0020
   Serial number: 19000320008010
   Coding: 8800000000000000
   ROD: EV_ELVMarqMQBA0_AU49.rod
   VCID: 343A75E4CECE435B739-8160
   Serial number: 00000398684777
   Coding: 007812000000B0010003010101010000000000000000000000000000004000
   ROD: EV_SCMDriveSideCONTIAU736_AU37.rod
   VCID: 79A484D0A92C7E33E0F-812C
   Part No SW: 4M0 959 593 M    HW: 4M0 959 593 J
   Component: TSG FS        010 0384
   Serial number: 0000397120003
   Coding: 001F8A005201000000013002
   ROD: EV_DCU2DriveSideMAXHCONT_AU37.rod
   VCID: 46DE3F2CA852C1CBDDD-8112
   Coding: 90000101010000
   ROD: EV_EPSVWBSAU426_010.rod
   VCID: 323673FC34DA4D6B615-8166
   Part No SW: 8W1 907 064 AM    HW: 8W1 907 064 M
   Component: BCM2 MLBevo   044 0542
   Coding: 01351E002FB100406309A0000400D80203000000804306502F04000000040030001F0181000011
   ASAM Dataset: EV_BCM2HellaAU736 017017
   ROD: EV_BCM2HellaAU736_017_AU49.rod
   VCID: 0842F114E2C617BBEF1-815C
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY193202UAF
   Subsystem 2 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004 0007
   Serial number: 00000000000000783832
65694 - Fuel Level Sensor 1
          B103E 1B [009] - Resistance Too High
                    Reset counter: 69
                    Mileage: 9426 km
                    Date: 2022.06.12
                    Time: 15:30:07
                    Supply voltages-Terminal 30 power supply: 12.201 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.215 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.201 V
                    general_additional_freeze_frame-terminal_control_intern_status: 1B 01 0A 10 04 E0
                    fuel_sender_freeze_frame: 11111111 11111111 11111111 11111111
65698 - Fuel Level Sensor 2
          B1058 1B [009] - Resistance Too High
                    Reset counter: 69
                    Mileage: 9426 km
                    Date: 2022.06.12
                    Time: 15:30:07
Address 50: Seat Adj. 3rd row (J857)       Labels:* None
   Part No SW: 4M1 959 760 G    HW: 4M1 959 760 G
   Component: MEM-SR3       008 0016
   Serial number: 00000398660682
   Coding: FF201020F1000000000F000000000900000021210900000000000000440000
   Shop #: WSC 31414 055 00001
   ASAM Dataset: EV_SCM3rdRowCONTIAU736 005007
   ROD: EV_SCM3rdRowCONTIAU736_AU73.rod
   VCID: 3D2C50C0FD8482138C7-8168
   Part No SW: 4M0 959 592 M    HW: 4M0 959 592 J
   Component: TSG BFS       010 0384
   Serial number: 0000397123791
   Coding: 001F8A005E01000000013000
   ROD: EV_DCU2PasseSideMAXHCONT_AU37.rod
   VCID: 45DC38209554CAD3D47-8110
Address 5F: Information Electr. (J794)       Labels:| 4G1-035-MIB-HGH2.clb
   Part No SW: 4K0 035 063 D    HW: 4K0 035 063 A
   Component: MU-H-LND-EU   056 2711
   Coding: 01370601FF0A000043111101C00800302F0001E603F008008E
   ROD: EV_MUHigGen2pALPI_AU37.rod
   VCID: 241A85A47E2ED3DBE39-8170
   Subsystem 1 - Part No: V03 959 807 SD
   Component: MIB2P_EU_Q320  0480
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4M8 919 605 L    HW: 4M8 919 605 F
   Component: DU AU536 Top  H32 0053
   Serial number: INX00126091900150229
   Compact disc data bank:
   Component: Gracenote2  1010
   Volume Control 1:
   Subsystem 4 - Part No SW: 4N1 919 616 B    HW: 4N1 919 616
   Serial number: 00004419000131245037
   Multimedia System 5:
   Subsystem 5 - Part No SW: 4N0 919 603 L    HW: 4N0 919 603 F
   Component: DU AU651 Bot  H32 0053
   Serial number: INX00113091900170165
   Media socket:
   Subsystem 6 - Part No SW: 4N0 035 736 A    HW: 4N0 035 736
   Component: MediaConnectH  014 0133
   Serial number: 051900729408013
          B201A 00 [009] - -
                    Reset counter: 69
                    Mileage: 9426 km
                    Date: 2022.06.12
                    Time: 15:28:54
                    Voltage terminal 30: 11.9 V
                    Status_Software_Version_Management-module_name: PChargeF.wtcA.bo
Address 61: Battery Regul. (J1120)       Labels: None
   Part No SW: 4N0 915 105 B    HW: 4N0 915 105 B
   Component: BMS_48V_LiIon H06 0108
   ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
   ROD: EV_BMS48VLiIonLGAU536_AU37.rod
   VCID: 29049490190C0EB3D0F-817C
Address 69: Trailer (J345)       Labels:| 5H0-907-383.clb
   Part No SW: 8W1 907 383 A    HW: 8W1 907 383
   Component: Anhaenger     H07 0039
   Serial number: 000000000005338
   Coding: 0100000202001100
   ASAM Dataset: EV_TrailFunctGener3Hella 001009
   ROD: EV_TrailFunctGener3Hella_VW27.rod
   VCID: 3FD02AC8F78890039EB-816A
   Component: RVC Compact   H18 0250
   Coding: 0235060103002005C20040
   ROD: EV_CamSysRVRVCPANAMLBEv_005.rod
   VCID: 333876F8CBC044636A3-8166
   Part No SW: 8W8 959 107 D    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0171
   Revision: --------    Serial number: A2-C744-8781-2
   Coding: 0090
   VCID: 4AC60B1CBC4A25AB395-811E
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 4M8 907 777 CA    HW: 4M8 907 777 C
   Component: Fahrwerk-SG   H52 2135
   Serial number: 0212191314
   Coding: 98505048F842
   ASAM Dataset: EV_ChassContrContiAU651 002016
   ROD: EV_ChassContrContiAU651_002.rod
   VCID: 0256E33CC4FA3DEBB15-8156
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004130818978
   Coding: 303030
196611 - Quantity of Fuel Added to Tank
          C123D 29 [009] - Signal Implausible
          [Function limitation through implausible Signal KBI_Inhalt_Tank]
                    Reset counter: 69
                    Mileage: 9426 km
                    Date: 2022.06.12
                    Time: 15:27:02
                    Internal DTC: 839
   Part No SW: 4M8 713 041 A    HW: 4N2 713 041 C
   Component: GSM-LL        H10 0081
   Revision: 0L0D5012    Serial number: 19101255849504
   ASAM Dataset: EV_GSMWaehlZFAU736 001018
   ROD: EV_GSMWaehlZFAU736.rod
   VCID: 2A066B9C1C0A05ABD95-817E
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
   Part No SW: 4KE 907 107 AP    HW: 4N0 907 107 F
   Component: zFAS Var A    H08 0295
   Coding: 04C1040000000000000006000040462C189D56000000000000000000000000000019000000000000000000000000000000000000000000000000400000000000000018D80080009000000000000000000080400000B0
   ASAM Dataset: EV_ZFASAU516 001007
   ROD: EV_ZFASAU516_001.rod
   VCID: 0D4CC0008DA47293DC7-8158
Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
   Part No SW: 4M0 907 355 D    HW: 4M0 907 355 B
   Component: SCR-Stg-G3H05 0006
   ASAM Dataset: EV_RDCMINERGAU736 005012
   ROD: EV_RDCMINERGAU736_AU49.rod
   Part No SW: 4M0 959 595 M    HW: 4M0 959 595 J
   Component: TSG HFS       010 0384
   Serial number: 0000397880212
   Coding: 000F88000001000000003000
   ROD: EV_DCU2RearDriveMAXHCONT_AU37.rod
   VCID: 48C23114A246D7BB2F1-811C
   Component: TSG HBFS      010 0384
   Serial number: 0000397880168
   ROD: EV_DCU2RearPasseMAXHCONT_AU37.rod
Address C4: DC/DC Converter (A7)       Labels: None
   Part No SW: 4K0 959 663     HW: 4K0 959 663
   Component: DCDC_GEN_2 H20 0307
   Serial number: DC19485000111
   ASAM Dataset: EV_DCDC48VFLEXAU581 004001
   ROD: EV_DCDC48VFLEXAU581_AU37.rod
   VCID: 75BC88E085341A53847-8120
Address CC: Starter-Generator (----)       Labels:* None
   Part No SW: 4N0 903 028 M    HW: 4N0 903 028 M
   Component: BSG-HP1-65    H17 0523
   Serial number: 23111900020025
   Coding: 28000000000000
   ASAM Dataset: EV_Start48VAU651 001006
   ROD: EV_Start48VAU651_001.rod
   VCID: 353C48E0C5B45A53447-8160
Address D6: Light Ctrl Left 2 (A31)       Labels: None
   Part No SW: 4K0 941 591 BD    HW: 4K0 941 591 B
   Component: LMS_MLBevo    H11 0040
   ASAM Dataset: EV_LMSLeftHELLAAU58X 001015
   ROD: EV_LMSLeftHELLAAU58X.rod
   VCID: 72B6B3FCF45A0D6BA15-8126
Address D7: Light Ctrl Right 2 (A27)       Labels: None
   ASAM Dataset: EV_LMSRightHELLAAU58X 001015
Address DE: Charger 1 for mobile dev (J1146)       Labels:* 4N0-035-502.clb
   Part No SW: 4N0 035 502 B    HW: 4N0 035 502 B
   Component: WLC Front     H14 0061
   Coding: 400000
   VCID: 231886B87B20D4E39A3-8176
End----(Elapsed Time: 02:38, VBatt start/end: 11.7V/11.7V. VIgn 11.6V)-----
JMR
Romania
C?ID=432218
well, if this car has a split tank ( i am not sure ) if one of the fuel sensors has a problem , it'll bog down the other one too. Why don't you check and see if you have a stuck fuel level sensor problem? Perhaps the car sat a while without fuel and it got stuck? Also , if the tank has a visitation hole , take a little hammer and clank it few times on the edge of the plastic screws that secures the pumps in the tank..
Wow. Looks like the fuel level sensors in this vehicle are connected to BCM2 rather than the instrument cluster. What other indirection will Audi think of next? (For the last ~10 years or so, they've made some cars with the A/C pressure sensor connected to BCM1 rather than the HVAC module, so I guess this shouldn't come as too much of a shock).
Go to 46-Cent. Conv. -> Adv. Meas. Values and type 'Fuel' in the search/filter box. You'll find a bunch of data from as many as four fuel level sensors.
  • Wow
Reactions: JMR
JMR
Romania
C?ID=432218
yeap ,there is my conational in the other thread fighting this crap :banghead:
MRARC
New Zealand
C?ID=445236
Thanks for the quick reply. The fuel tank is underneath the second row seats and there is no cut out on the floor to quickly check the sensor. I am thinking of looking at some other problem that may cause the malfunction before having to probably take the fuel tank out ( I have no idea on how to access the fuel sensor. There is very little info on the net).
MRARC
New Zealand
C?ID=445236
Thanks Uwe. I ll do that soon and post the value.
JMR
Romania
C?ID=432218
i've had varying degrees of success before by beating few times with a bit bigger hammer right into the tank from underneath
MRARC
New Zealand
C?ID=445236
Please find the fuel sensor reading below. Cheers.
Friday,24,June,2022,10:24:07:21199
Address 46: Central Conv. (8W1 907 064 AM)
10:23:58
IDE00306-MAS02227 Fuel Level Sensor 1-Quality Malfunction
IDE00306-MAS06614 Fuel Level Sensor 1-Variant Two-wire sensor
IDE00306-MAS06615 Fuel Level Sensor 1-Soiling resistance 0
IDE00306-MAS06621 Fuel Level Sensor 1-Raw value 1 03 FF
IDE00306-MAS06622 Fuel Level Sensor 1-Raw value 2 00 00
IDE00306-MAS06623 Fuel Level Sensor 1-Sensor including soiling resistance 0
IDE00306-MAS06624 Fuel Level Sensor 1-Sensor without soiling resistance 4095
IDE00306-MAS06643 Fuel Level Sensor 1-Resistance 1: measurable value 32767
IDE00306-MAS06644 Fuel Level Sensor 1-Resistance 2: measurable value 0
IDE00307-MAS06614 Fuel Level Sensor 2-Variant Two-wire sensor
IDE00307-MAS06615 Fuel Level Sensor 2-Soiling resistance 0
10:25:46
IDE00307-MAS02227 Fuel Level Sensor 2-Quality Malfunction
IDE00307-MAS06621 Fuel Level Sensor 2-Raw value 1 00 0F
IDE00307-MAS06622 Fuel Level Sensor 2-Raw value 2 00 00
IDE00307-MAS06623 Fuel Level Sensor 2-Sensor including soiling resistance 0
IDE00307-MAS06624 Fuel Level Sensor 2-Sensor without soiling resistance 4095
IDE00307-MAS06643 Fuel Level Sensor 2-Resistance 1: measurable value 1
IDE00307-MAS06644 Fuel Level Sensor 2-Resistance 2: measurable value 0
Reactions: JMR
I'm not sure what to make of those. I think one would need to compare them to a similar vehicle in which the gauge functions properly.
Reactions: JMR
MRARC
New Zealand
C?ID=445236
Hi Uwe,
Reading from my 2019 A6 50 TDI. both car are full tank.
IDE00306-MAS02227 Fuel Level Sensor 1-Quality 10
IDE00306-MAS06615 Fuel Level Sensor 1-Soiling resistance not coded/not installed
IDE00306-MAS06621 Fuel Level Sensor 1-Raw value 1 03 61
IDE00306-MAS06622 Fuel Level Sensor 1-Raw value 2 not coded/not installed
IDE00306-MAS06623 Fuel Level Sensor 1-Sensor including soiling resistance not coded/not installed
IDE00306-MAS06624 Fuel Level Sensor 1-Sensor without soiling resistance 67
IDE00306-MAS06643 Fuel Level Sensor 1-Resistance 1: measurable value 67
IDE00306-MAS06644 Fuel Level Sensor 1-Resistance 2: measurable value not coded/not installed
Address 46: Central Conv. (4N0 907 064 BD)
17:20:14
IDE00307-MAS02227 Fuel Level Sensor 2-Quality 10
IDE00307-MAS06615 Fuel Level Sensor 2-Soiling resistance not coded/not installed
IDE00307-MAS06621 Fuel Level Sensor 2-Raw value 1 03 67
IDE00307-MAS06622 Fuel Level Sensor 2-Raw value 2 not coded/not installed
IDE00307-MAS06623 Fuel Level Sensor 2-Sensor including soiling resistance not coded/not installed
IDE00307-MAS06624 Fuel Level Sensor 2-Sensor without soiling resistance 67
IDE00307-MAS06643 Fuel Level Sensor 2-Resistance 1: measurable value 68
IDE00307-MAS06644 Fuel Level Sensor 2-Resistance 2: measurable value not coded/not installed
