- Jun 20, 2022
- 2
- 4
- Rochester, NY, USA
- C?ID=112929
While trying to perform the grind in procedure for the paring brake I keep getting the message Refused by Control Module and Error Code 7F2F7F. Below is the scan. I watched the video and made sure to follow all the steps. I have mechanically adjusted the air gaps before calibration to 2.251 and 2.253. The Air Gap Left is 1.975 and right is 1.851. Those do not change when I adjust mechanically. An help would be appreciated.
I have been trying to get the VCDS to start the grind in procedure for a 2011 VW Touareg VR6. I keep getting an error code Refused by Control Module 7F 2F 7F. Posted below is m most recent scan.
Thursday,23,June,2022,14:01:37:62606
VCDS Version: 22.3.1.4 (x64)
VIN: WVGFF9BP9BD003509 License Plate:
Mileage: 215104km-133659mi Repair Order:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56 5F
62 65 6C 6D 72
VIN: WVGFF9BP9BD003509 Mileage: 215104km-133659miles
Address 01: Engine (J623-CGRA) Labels:. 03H-907-309-V1.clb
Part No SW: 03H 906 023 B HW: 03H 907 309
Component: 3,6 FSI ULEV2 H15 8643
Revision: M7H15--- CVN: A886D4C9
Coding: 002A0012432600000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM36FSI01103H906023B 002005
ROD: EV_ECM36FSI01103H906023B.rod
VCID: 2149D68D303D6487E0-8074
VINID: 9E65D65894A025250000314024348B23AD
10203 - Random/Multiple Cylinder Misfire Detected
P0300 00 [096] - -
Mileage: 215013 km
Date: 2022.06.20
Time: 09:41:12
Engine RPM: 677.00 /min
Normed load value: 34.1 %
Coolant temperature: 47 °C
Intake air temperature: 29 °C
Voltage terminal 30: 13.900 V
Unlearning counter according OBD: 36
Misfires per 1000 revolutions of cylinder 1: 4
Mean injection time: 1.547 ms
Leakage air: -1.7 kg/h
Long-term fuel trim bank 1 at idle: 0.00 %
Leakage recognition from oxygen sensor control: 0.9978
10591 - Cylinder 1
P0301 00 [096] - Misfire Detected
Mileage: 215013 km
Date: 2022.06.20
Time: 09:41:13
Engine RPM: 721.00 /min
Normed load value: 33.7 %
Voltage terminal 30: 14.017 V
Misfires per 1000 revolutions of cylinder 1: 5
Mean injection time: 1.567 ms
10595 - Cylinder 5
P0305 00 [096] - Misfire Detected
Mileage: 215013 km
Date: 2022.06.20
Time: 09:41:13
10593 - Cylinder 3
P0303 00 [096] - Misfire Detected
Mileage: 215013 km
Date: 2022.06.20
Time: 09:41:13
10594 - Cylinder 4
P0304 00 [096] - Misfire Detected
Mileage: 215013 km
Date: 2022.06.20
Time: 09:41:13
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 A HW: 0C8 927 750 A
Component: AL1000 AISIN 001 1824
Serial number: CVN: DB98ADE3
Coding: 001168
Shop #: WSC 38241 123 104857
ASAM Dataset: EV_TCMAL991031 001001
ROD: EV_TCMAL991031_001_VW52.rod
VCID: 2A5B31A14D0BA7DFB1-807E
Address 03: ABS Brakes (J104) Labels:* 7P0-907-379.clb
Part No SW: 7P0 907 379 E HW: 7P0 907 379 A
Component: MK25A H33 0416
Revision: -------- Serial number: 432800010EC010
Coding: 5B7613C349242556DAF9C89392DBA4407700
ASAM Dataset: EV_MK25AXT 007001
ROD: EV_ESPMK25A00700.rod
VCID: 3F8D70F5A6893277F6-806A
Part No SW: 4H0 907 064 AK HW: 4H0 907 064 AK
Component: BCM2 2.0 H23 0208
Coding: 0D860000000000000000
VCID: 72EBE9C1AD5BAF1FC9-8026
Subsystem 1 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Serial number: 2310000048589005
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 AG HW: 7P6 907 040 AG
Component: Klima 2 Zonen H18 0613
Coding: 4686200A80
VCID: 79F9DEEDF82DDC4788-802C
Part No SW: 4H0 907 063 L HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0092
Revision: 15012002 Serial number: 00000000873348
Coding: 26001012973C5D010020180300005D0C431C460882010261000000020000
VCID: 316926CD68DDD40770-8064
Subsystem 1 - Part No SW: 7P0 955 119 HW: 7P0 955 119 Labels: 1KX-955-119.CLB
Component: WWS 101123 31 0020
Serial number: 90243400101124204236
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 D HW: 7P0 955 559 D Labels: 8K0-955-559.CLB
Component: RLFS H09 0011
Serial number: 10093727
Coding: 035223
Subsystem 3 - Part No SW: 7P6 941 431 E HW: 7P6 941 431 E
Component: E1 - LDS H04 0031
Serial number: 00000000002810100329
Subsystem 4 - Part No SW: 4H0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0020
Serial number: 0000001805569R04XC06
Address 10: Park/Steer Assist (J446) Labels:| 7P6-919-475.clb
Part No SW: 7P6 919 475 HW: 7P6 919 475
Component: PARKHILFE 8K H03 0016
Revision: -------- Serial number: 38931031402514
Coding: 308501
ASAM Dataset: EV_VW526ParkiAssis2 001008
ROD: EV_VW526ParkiAssis2.rod
VCID: 55A1B25D34F5D827CC-8000
Address 15: Airbags (J234) Labels:| 7P0-959-655.clb
Part No SW: 7P0 959 655 B HW: 7P0 959 655 B
Component: VW10Airbag02D H05 0023
Revision: -------- Serial number: 003JX000W3LP
Coding: 000000000000000000000000000000003244
ROD: EV_AirbaVW10BPAVW526_001.rod
VCID: 408F7309DB774D8F8F-8014
Subsystem 1 - Part No SW: 7P6 959 339 HW: 7P6 959 339
Component: BF-Gewichtss. 003 0005
Serial number: 5850000R1072100TXW
Serial number: 3575LRB406307OTS70V3
Serial number: 3585LRB406107OTS8GI6
Serial number: 3515RRB405907S8S8P0T
Serial number: 3525RRB405B07S8SE13H
Serial number: 3555NRB404P04QROGGBL
Serial number: 3565NRB404R04QROH10%
Part No SW: 4H0 953 568 B HW: 7P6 953 507 A
Component: Lenks.Modul H08 0007
Revision: -------- Serial number: 90815JKI0003B
Coding: 000C35
VCID: 326B29C16DDBEF1F09-8066
Subsystem 1 - Part No SW: 7P6 959 542 A HW: 7P6 959 542 A
Component: E221__MFL-TAS H04 0028
Serial number: 0041892 TRW 20140306
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb-SRI1
Part No SW: 7P6 920 980 M HW: 7P6 920 980 M
Component: Kombi H12 0235
Revision: 10240060 Serial number: 658231110593024
Coding: 837732022B00CF05020004
ASAM Dataset: EV_KombiUDSRBVW526 001013
ROD: EV_KombiUDSRBVW526.rod
VCID: 46836511F95363BFB5-8012
Part No SW: 7P6 907 530 C HW: 7P6 907 530 A
Component: GW-CAN-L-MOST H08 5202
Revision: -------- Serial number: 00000000066278
Coding: 0021032600
GVL: FB4F40455D77000000
ASAM Dataset: EV_GatewVW526UDS 001006
ROD: EV_GatewUDS_VW52.rod
VCID: 387F1BE983A7054F37-806C
Subsystem 1 - Part No SW: 7P0 915 181 A HW: 7P0 915 181
Component: Batt_Sensor H07 0140
Serial number: 00000000005659362714
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00001002195075
Coding: 00581B0000004001000001010101202020202121202020
VCID: 34672FD997CFE12F1B-8060
Part No SW: 4H0 959 793 F HW: 4H0 959 793 F
Component: TSG FA H07 0162
Revision: -------- Serial number: 0000110310418
Coding: 011D17205E00453005080000
VCID: 3C7707F9BF9F296FD3-8068
Revision: 00002001 Serial number: 0136182526
Coding: 0106163A28B9509780B00620010000000000000000000000000000000000
Subsystem 1 - Part No SW: 7P6 959 719 HW: 7P6 959 719
Component: GTO BT H19 0059
Serial number: 284103711
Subsystem 3 - Part No SW: 7P0 959 591 HW: 7P0 959 591
Component: J245 PS30.050 H05 0006
Serial number: WOO10846643
Coding: 191100
Subsystem 4 - Part No SW: 7P0 959 591 A HW: 4H0 959 591
Component: J394 PS30.050 H06 0006
Serial number: WOO10883240
Coding: 191100
03622 - Control Module 2 for Roof Shade
Reset counter: 251
Mileage: 215103 km
Date: 2022.06.23
Time: 11:51:41
Part No SW: 7P6 035 466 HW: 7P6 035 466
Component: DSP Prem H01 0090
Revision: 00001001 Serial number: 10811000203401
VCID: 75E1D2DDDC35B827EC-8020
Part No SW: 4H0 959 792 F HW: 4H0 959 792 F
Component: TSG BF H07 0162
Revision: -------- Serial number: 0000110353918
VCID: 3B7504E5BA912E57DA-806E
Address 53: Parking Brake (J540-) Labels:| 7P0-907-801.clb
Part No SW: 7P0 907 801 E HW: 7P0 907 801 E
Component: EPB H51 1100
Revision: 00000000 Serial number: A10A160013B
Coding: 01040000
ROD: EV_ParkbA7.rod
VCID: 356112DD94B5F8272C-8060
Slave 1:
Slave 3:
0025 - No Calibration
B2010 F0 [008] - Deviation from Expected Range
Reset counter: 252
Mileage: 215104 km
Date: 2022.06.23
Time: 12:18:02
Voltage: 12.2 V
0024 - No Basic Setting
B2010 00 [009] - -
Reset counter: 252
Mileage: 215104 km
Date: 2022.06.23
Time: 12:06:42
Voltage: 12.4 V
Address 55: Headlight Range (J745) Labels:. 7P6-907-357.clb
Part No SW: 7P6 907 357 HW: 7L6 907 357 C
Component: AFS-ECU H04 0110
Coding: 010A00010F000400
ASAM Dataset: EV_HeadlRegulVWAFS 005006
ROD: EV_HeadlRegulVWAFS_VW52.rod
VCID: 7CF7C7F9F71FE96F93-8028
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0001
Coding: 130000
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0001
Coding: 130000
Part No SW: 4G0 035 082 HW: 4G0 035 082
Component: Radio U SIRIU H51 0052
Revision: AB001007 Serial number: 471K10A7543809
Coding: 020007010000000001
VCID: 5DB1AA7D44C5006784-8008
Part No SW: 7P6 035 664 HW: 7P6 035 664
Component: H-BN-NA H43 0170
Revision: -------- Serial number: 445J50A7507759
Coding: 020200050040E1EF41020B0E00000003F0080101
Subsystem 1 - Part No: 8R0 060 884 P
Component: NAR 2010 0407
Subsystem 2 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Component: DU8 SV Touch H23 0045
Serial number: VWZ8Z9K29001UX
Subsystem 3 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Component: CD-Database 1886
Part No SW: 4H0 959 795 B HW: 4H0 959 795 B
Component: TSG HL H09 0162
Revision: -------- Serial number: 0000110343395
Coding: 011C17200000253005080000
VCID: 3A7B01E1B5AB175FC1-806E
Address 65: Tire Pressure (J502) Labels: 3Y0-907-273.clb
Part No SW: 7P6 907 273 F HW: 7P6 907 273 F
Component: RDKBERU25 H09 0008
Serial number: 10000000017076
ASAM Dataset: EV_RDKBERU25 003006
ROD: EV_RDKBERU25_VW52.rod
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 7P6 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0020
Revision: 00H03000 Serial number: 525 PA8J0X0709
Coding: 0120001
VCID: 377D18D546B90A373E-8062
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7P6 959 107 HW: 7P6 959 107
Component: HDSG-Modul H10 0611
Revision: 09145444 Serial number: 316000027
Coding: 0533314002
ASAM Dataset: EV_HeckkTouar 202135
ROD: EV_HeckkTouar.rod
Component: TSG HR H09 0162
Revision: -------- Serial number: 0000110333630
End-------------------------(Elapsed Time: 05:07)--------------------------
