hi i hew that faults in abs ewrything its orginal in car any idires
Thursday,23,June,2022,16:28:50:42918
VCDS Version: 22.3.1.4 (x64)
VIN: WVWZZZAUZEP034460 License Plate:
Mileage: 245488km-152539mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 13 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZEP034460 Mileage: 245488km-152539miles
Address 01: Engine (J623-CLHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 M HW: 04L 907 309 B
Component: R4 1,6L EDC H22 5517
Revision: 84H22--- CVN: B53D877B
Coding: 01110012034505092000
Shop #: WSC 00028 028 00072
ASAM Dataset: EV_ECM16TDI01104L906021M 002009
ROD: EV_ECM16TDI01104L906021P.rod
VCID: AF30F86A5797B613E65-80FA
VINID: 9E69EAAAA465A958000C410600C0344A76
10065 - Mass Air Flow Sensor (G70)
P0104 00 [167] - Intermittent
Mileage: 245488 km
Date: 2022.06.16
Time: 00:00:22
Engine RPM: 0.00 /min
Coolant temperature: 21 °C
Intake air temperature: 22 °C
Voltage terminal 30: 12.460 V
Mass airflow sensor 1 bank 1 airflow: raw value: 0.0 mg/stroke
Standardized airflow ratio: filtered: 3.9999
Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: 0.00 %
Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 0.00 %
Charge air pressure: specified value: 0 hPa
Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 1003.0 hPa
Mean injection quantity: 0.00 mg/stroke
25195 - Intake Air Temp. Sensor (G42)
P0113 00 [039] - Signal too High
Mileage: 245488 km
Date: 2022.06.16
Time: 00:00:23
4987 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 00 [237] - Electrical Fault
Mileage: 245488 km
Date: 2022.06.02
Time: 18:52:22
Engine RPM: 1017.50 /min
Normed load value: 61.2 %
Vehicle speed: 3 km/h
Coolant temperature: 28 °C
Intake air temperature: 29 °C
Voltage terminal 30: 12.580 V
Electric auxiliary heater: shut-off conditions-Bits 0-7: 130
Electric auxiliary heater: shut-off conditions-Bits 0-7: 148
Electric auxiliary heater: relay activation-Bits 0-7: 0
Pre-glow time: 0 ms
Glow status-Bits 0-7: 0
Glow status-Bits 0-7: 240
Glow cycles above temperature threshold-Bits 0-7: 0
Glow cycles above temperature threshold-Bits 0-7: 9
Glow cycles below temperature threshold-Bits 0-7: 2
Glow cycles below temperature threshold-Bits 0-7: 185
Outside temperature sensor 1: B1: raw value: 19.0 °C
U0428 00 [039] - -
Mileage: 245488 km
Date: 2022.06.16
Time: 00:00:23
17158 - Databus
U1123 00 [047] - Received Error Message
Fault Frequency: 11
Mileage: 245488 km
Date: 2022.06.02
Time: 14:15:03
Coolant temperature: 55 °C
Intake air temperature: 47 °C
Voltage terminal 30: 12.680 V
Drivetrain coordinator: brake fault status-Bits 0-7: 5
Acceleration: 0.000 m/s˛
4708 - No Communications with HVAC Control Module (J301)
U0164 00 [036] - -
Mileage: 245488 km
Date: 2022.06.16
Time: 00:00:24
Voltage terminal 30: 12.440 V
Limitation: accelerator pedal: 110.9 Nm
Cruise Control System (CCS): status-Bits 0-7: 7
selected gear-Bits 0-7: 0
Readiness: 1 1 0 0 1
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 6244300000036B
Coding: 01FA8AA124230970037B060641C32580512490C06082A4F3F440F074C002
Shop #: WSC 00028 028 00023
VCID: FBA81C3AD36F9AB31AD-80AE
10 Faults Found:
0071 - Rear Left Wheel Speed Sensor
C101C 4A [137] - Incorrect Component(s) Installed
Reset counter: 222
Date: 2022.06.16
Time: 00:11:25
0088 - Rear Right Wheel Speed Sensor
C101D 01 [137] - Electrical Failure
Reset counter: 222
Date: 2022.06.16
Time: 00:11:25
0297 - Steering angle sensor
B1168 16 [137] - Voltage Too Low
Reset counter: 222
Date: 2022.06.16
Time: 00:11:25
4410 - Indicator Lamp in Auto-Hold Switch
C1156 14 [009] - Open or Short to Ground
Reset counter: 222
Date: 2022.06.16
Time: 00:21:53
8356 - Databus
[FCAN: Klima_11_alt veraltet bit is set]
Reset counter: 7
Date: 2022.06.16
Time: 00:11:25
C1146 02 [137] - Signal Failure
Reset counter: 222
Mileage: 245488 km
Date: 2022.06.16
Time: 00:11:33
32833 - Switch for Electric Parking Brake
C100C 01 [137] - Electrical Failure
Reset counter: 222
Date: 2022.06.16
Time: 00:21:53
32837 - Lamp in Switch for Electronic Parking Brake
C1145 13 [137] - Open Circuit
Reset counter: 222
Date: 2022.06.16
Time: 00:21:53
32992 - Control Module for Electric Parking Brake
C10E2 F0 [137] - RPM Sensor Implausble Signal
Reset counter: 222
Date: 2022.06.16
Time: 00:11:25
32994 - Control Module for Electric Parking Brake
C10E2 F0 [009] - RPM Sensor Implausble Signal
Reset counter: 222
Date: 2022.06.16
Time: 00:21:53
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5G0 907 426 M HW: 5G0 907 426 M
Component: AC Manuell H01 0705
Revision: 00001K06
Coding: 00120104202100001000000000000000
VCID: B53CCA02B5CB8CC3AC9-80E0
262658 - High Pressure Sensor
B10AE 31 [009] - No Signal
Reset counter: 222
Mileage: 245488 km
Date: 2022.06.02
Time: 13:58:15
Outside temperature: 18.0 °C
Engine RPM: 700 /min
Temperature downstream of evaporator: 20.7 °C
System run time-Engine running time: 255 s
System run time-Terminal 15 on: 255 s
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 S HW: 5Q0 937 084 S
Component: BCM MQBAB M H14 0112
Serial number: 00011323900240
Coding: 03000842C24102730BA44080B10403281000000000000000000000000000
ROD: EV_BCMBOSCH_011.rod
VCID: C8C2B3F6D239012BC7F-809C
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 130804 042 0551
Serial number: 130823043651
Subsystem 2 - Part No SW: 5Q0 955 559 HW: 5Q0 955 559 Labels: 5Q0-955-547.CLB
Component: RLS 024 0042
Serial number: Y13M09D02H03M26S36S1
Coding: 00A8DD
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY131830B5Z
Serial number: 00000000000057443404
264968 - Sensor 2 for interior monitoring
B1332 29 [008] - Signal Implausible
Fault Frequency: 13
Reset counter: 7
Mileage: 245488 km
Date: 2022.06.02
Time: 18:52:58
Terminal 15 status: OFF
Terminal 50 status: OFF
CAN-Bus_aktiv: On
OFF: operated
Position lamps: Not operated
Low beam: Not operated
Voltage: 12.6 V
Outside temperature: 19.0 °C
539157 - Databus
[Klima_12 Datenbus fehlende Botschaft]
Reset counter: 7
Mileage: 245488 km
Date: 2022.06.16
Time: 00:00:25
Terminal 15 status: On
CAN-Bus_aktiv: On
OFF: operated
Voltage: 12.3 V
Outside temperature: 20.0 °C
558100 - Databus
[Airbag_02 Datenbus empfangener Fehlerwert]
Reset counter: 222
Mileage: 245488 km
Date: 2022.06.16
Time: 00:00:25
CAN-Bus_aktiv: On
OFF: operated
Voltage: 12.3 V
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 A HW: 5Q0 907 572 A
Component: ACC Bosch MQB H04 0150
Serial number: 29081376510062
Coding: 00000300FE0339
ASAM Dataset: EV_ACCMRRBoschVW372 001013
9 Faults Found:
1067 - Brake Temperature
C10DF 00 [009] - -
Reset counter: 222
Mileage: 245488 km
Date: 2022.06.02
Time: 13:58:16
Control Module temperature: 36 °C
Voltage terminal 15: 13.3 V
Vehicle speed: 0.00 m/s
Acceleration: -0.00 m/s˛
1056 - Databus
[FAULT_CIS_ECD_FAIL]
Reset counter: 222
Mileage: 245488 km
Date: 2022.06.02
Time: 13:58:16
1058 - Databus
[FAULT_CIS_ECD_NOTAVAILABLE]
Reset counter: 222
Mileage: 245488 km
Date: 2022.06.02
Time: 13:58:16
1062 - Databus
[FAULT_CIS_EPB_SWITCH_FAIL]
Reset counter: 222
Mileage: 245488 km
Date: 2022.06.16
Time: 00:00:24
Control Module temperature: 23 °C
Voltage terminal 15: 12.3 V
Acceleration: 0.00 m/s˛
1059 - Databus
[FAULT_CIS_ESP_FAIL]
Reset counter: 222
Mileage: 245488 km
Date: 2022.06.02
Time: 13:58:16
1078 - Databus
[FAULT_CIS_SAS_INIT]
Reset counter: 222
Mileage: 245488 km
Date: 2022.06.16
Time: 00:00:25
1043 - Automatic Distance Control
B10E7 F0 [009] - Disconnected
[FAULT_CIS_TSK_IRREV_FAIL]
Reset counter: 222
Mileage: 245488 km
Date: 2022.06.02
Time: 13:58:16
1118 - Databus
[FAULT_CIS_WHEEL_PULSE_FAIL]
Reset counter: 222
Mileage: 245488 km
Date: 2022.06.02
Time: 13:58:16
1081 - Databus
[FAULT_CIS_WHEEL_RPM_FAIL]
Reset counter: 222
Mileage: 245488 km
Date: 2022.06.02
Time: 13:58:16
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 014 0386
Serial number: 003MLR003TS4
Shop #: WSC 00028 028 00061
VCID: FF50E82AC7778693365-80AA
Left seat belt tensioner:
Right seat belt tensioner:
Component: BeltPretRevFR H35 0341
Serial number: 34169676B23061470075
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 001 708 13
Serial number: 35767000000D07097D0Y
Subsystem 4 - Part No SW: ----------- HW: 480 001 708 13
Serial number: 3586700000065C497D0%
Subsystem 5 - Part No SW: ----------- HW: 480 402 908 13
Serial number: 3516502991088B1142C2
Subsystem 6 - Part No SW: ----------- HW: 480 402 908 13
Serial number: 3526502B91088B13205$
Subsystem 7 - Part No SW: ----------- HW: 480 403 008 13
Serial number: 3556502BB1088B10F2CK
9439771 - Front Passenger's Side Airbag Igniter
B100A 1B [137] - Resistance Too High
Mileage: 245488 km
Date: 2022.06.16
Time: 00:00:23
9447189 - Seat Occupied Sensor; Passenger's Side
B1027 15 [137] - Open or Short to Plus
Mileage: 245488 km
Date: 2022.06.16
Time: 00:00:24
12680704 - No Communication with Control Module for Seat Belt Tensioner; Front Left
U017E 00 [009] - -
[ECU for Pretensioner left no communication]
Reset counter: 222
Mileage: 245488 km
Date: 2022.06.02
Time: 13:58:19
1050117 - Databus
[NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
Reset counter: 222
Mileage: 245488 km
Date: 2022.06.16
Time: 00:00:25
Part No SW: 5Q0 953 507 AG HW: 5Q0 953 549 A
Revision: -------- Serial number: 04091304400134
Coding: 0D00
Shop #: WSC 40195 333 37120
Part No SW: 5G0 920 961 A HW: 5G0 920 961 A
Component: KOMBI 252 2210
Coding: 27A41A002780260001882A01040000
VCID: A80213767279E12B27F-FFFE
16777018 - Function Restricted due to Interrupted Communications
U1110 00 [009] - -
[BAP_Audio_0x31 keine Kommunikation]
U1110 00 [009] - -
[BAP_TEL_0x28 keine Kommunikation]
Part No SW: 5Q0 907 530 M HW: 5Q0 907 530 M
Component: GW MQB High 212 2147
Revision: -------- Serial number: 28081310801613
Coding: 030100040B087300EF00005C080F00010001000000000000000000000000
GVL: 01503C0000000000400C80000000480000000000000000000000000000000000
ASAM Dataset: EV_GatewConti 009011
ROD: EV_GatewConti_009.rod
VCID: BB28DC3A93EF5AB35AD-80EE
Generator:
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H14 0035
Serial number: 27130001319230113335
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 3200690903
131603 - No Communication with ABS Brake Control Module
U0121 00 [008] - -
[Timeout Knoten 0x13 / 03 - Steuergerät für ABS Bremse]
Fault Frequency: 11
Reset counter: 7
Mileage: 245488 km
Date: 2022.06.16
Time: 17:14:46
Terminal 30 power supply: 12.5 V
Terminal 15: OFF
131654 - No Communications with HVAC Control Module (J301)
U0164 00 [008] - -
[Timeout Knoten 0x46 / 08 - Steuergerät für Klima]
Fault Frequency: 11
Reset counter: 7
Mileage: 245488 km
Date: 2022.06.16
Time: 17:33:38
Terminal 15: OFF
131699 - Control unit for information electronics 1
U1054 00 [009] - No Communication
[Timeout Knoten 0x73 / 5F - Steuergerät für Informationselektronik 1]
Reset counter: 222
Mileage: 245488 km
Date: 2022.06.16
Time: 00:00:25
Terminal 30 power supply: 12.4 V
Terminal 15: On
Part No SW: 5Q4 959 393 HW: 5Q4 959 393
Component: TSG FS 007 0006
Serial number: 0000072074057
Coding: 003002208001028000001000
VCID: D5E82937258BACC34C9-FFFE
Subsystem 1 - Part No: 5Q4 959 812 A Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV
No Faults Found
