Hello. It's my first post here but i have hope not last. And hello to everyone. I'll be grateful if someone can helps me to calculate ABS coding Vagscan , i have label from trunk jpg but haven'i idea how to attach.
In best Regards
Type 8TA 06Y
A5 quattro sportback 166Kw A7S
Enginr Trans CDNC JKR LZK
In best Regards
Type 8TA 06Y
VCDS Version: Beta 15.6.1
Data version: 20150612
Monday,15,June,2015,19:48:35:42516
Chassis Type: 8T (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 20 2E 42 46 47 52 53 55 56
62 69 72 77
VIN: WAUZZZ8T5AA025355 Mileage: 23440km-14564miles
Address 01: Engine (CL0MA-CDNC) Labels: 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 P HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H15 0008
Revision: E1H15---
Coding: 0114000C240F0960
Shop #: WSC 46396 133 63149
ASAM Dataset: EV_ECM20TFS8K2907115P A01010
ROD: EV_ECM20TFS0118K2907115AJ.rod
VCID: 3C7CDA7CB7CDB3DFE5-8068
U1113 00 [039] - -
U1113 00 [039] - -
Readiness: 1110 0101
Address 02: Auto Trans (J217) Labels: 0B5-927-156.clb
Part No SW: 8K0 927 156 F HW: 0B5 927 156 E
Component: 0B5 20TFSIRdW H03 0013
Revision: --H03--- Serial number: 0000001343
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMDL501 A02088
ROD: EV_TCMDL501.rod
VCID: 3776C5508EEB908708-8062
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 CA HW: 8K0 907 379 CA
Component: ESP8 quattro H04 0010
Coding: 090D08
Shop #: WSC 06335 123 12345
VCID: 7AF01C64F5794DEFB7-802E
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP
Component: BCM2 1.1 H02 0326
Coding: 010400
VCID: 01026B8898AF1E37F6-8054
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
Component: KLIMA 3 ZONEN H08 0171
Revision: C1000000 Serial number: 01061020091220
Coding: 64000000
Shop #: WSC 06342 000 00000
VCID: 00046E8C93A5173FF9-8054
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H25 0380
Revision: 10025001 Serial number: 00000000357446
Coding: 260050914074AF010009000300005D5D0F1C630800010141000000
VCID: 3C7CDA7CBFCDB3DFE5-8068
Subsystem 1 - Part No SW: 8T1 955 119 D HW: 8J1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 250909 H14 0070
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 02532C
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 J HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0050
Revision: 11001001 Serial number: 39840927914276
Coding: 110107
VCID: 4084AE8CD325D73FB9-8014
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 G HW: 8K0 959 655 G
Component: AirbagVW-AU10 H39 0560
Serial number: 003EFD064SHE
Coding: 30353438363030303030554A304C38543053
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 4182AB88D02FDE37B6-8014
Serial number: 6334MSME4B6042729
Serial number: 6344MSME4C331670A
Serial number: 6352QSME203D0F04E
Serial number: 6362QSME343C0228C
Serial number: 63732SME073E4E3AB
Serial number: 63832SME5A3D33262
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90315IJ1000LG
Coding: 000036
VCID: 3D7AD778A4D7BAD7D2-8068
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8T0 920 900 P HW: 8T0 920 900 P
Component: KOMBIINSTR. H33 0255
Revision: 00000000 Serial number: CHS12GE99
Coding: 0F07310003000008000000
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 S HW: 8T0 907 468 J
Component: GW-BEM 6CAN H06 0105
Revision: HB600050 Serial number: 5000H09906844B
Coding: 00C303
VCID: 51A29BC8084F2EB726-8004
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H06 0170
Address 20: High Beam Assist. (J844) Labels: 8K0-857-511.clb
Part No SW: 8K0 857 511 E HW: 8K0 857 511 A
Component: FLA H04 0004
Revision: AA001002
Coding: 02019864747464545425363E
VCID: 336EF14092937CA734-8066
Address 2E: Media Player 3 (R199) Labels: 8T0-035-785.clb
Part No SW: 8T0 035 785 A HW: 8T0 035 785
Component: SG ext.Player H08 0280
Revision: 00000000
Coding: 020202
VCID: 3972C368B0FF86F7FE-806C
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8T0 959 793 D HW: 8T0 959 793 A
Component: TSG FA H07 1101
Coding: 011C02624000450005
VCID: 4A908CA4E5191D6F67-801E
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0121986841
Coding: 01000620203904000130040000000000
Address 47: Sound System (J525) Labels: 8T0-035-223-ASC.clb
Part No SW: 8R0 035 223 F HW: 8R0 035 223 E
Component: DSP STD H11 0440
Revision: 00000000 Serial number: 00000000000001
Coding: 0203010102
VCID: 2F66FD307EBB584750-807A
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8T0 959 792 J HW: 8T0 959 792 D
Component: TSG BF H07 1201
Coding: 011C02224000450005
VCID: 4FA69DB01E7B384730-801A
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 10000000329765
VCID: 346CF25C979D7B9F2D-8060
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357
Component: Dynamische LWR H01 0010
Coding: 0000002
Shop #: WSC 06324 000 00000
VCID: 77F60550066B5087C8-8022
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 P HW: 8T1 035 186 P
Component: Concert3 H04 0310
Revision: 00000007 Serial number: AUZ5Z6I1279914
Coding: 0402008201048500435B070800
VCID: 448CA29CC73DCB1F9D-8010
Subsystem 1 - Part No SW: 8T0 919 603 E HW: 8T0 919 603 E
Component: Display
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8T0 959 795 J HW: 8T0 959 795 B
Component: TSG HL H05 1201
Coding: 010C02224000450005
VCID: 52A094C40D4955AF1F-8006
Address 69: Trailer (J345) Labels: 8K0-907-383.clb
Part No SW: 8K0 907 383 B HW: 8K0 907 383 B
Component: Anhaenger H08 0080
Revision: 1A002002 Serial number: 00000122499354
Coding: 0100000000000000
Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
Component: TSG HR H05 1201
Part No SW: 8T0 862 335 D HW: 8T0 862 335 D
Component: FSE_256x BT H37 0600
Revision: 00000000 Serial number: 00000005111070
Coding: 0010310
VCID: 3B7ED9607AC3B4E7EC-806E
End-------------------------(Elapsed Time: 03:35)--------------------------
