- May 6, 2021
- 15
- 10
- Pembrokeshire, Wales
- C?ID=150205
Hi guys/girls,
We have lost all comms with the engine control unit on our Seat Ibiza.
It all started with an internal fault in the ABS module. The fault was 01201 - ABS pump supply voltage. we ran diagnostics and checked the loom and all was fine there, including supply voltages, so it was clear that there as a problem with the ABS module. We then sent the module away for repair which we had done many times without many issues. When the module came back we plugged it in and the fault was still present. However, this time we have no communication with the ECU at all. The battery was disconnected every time a module was unplugged/plugged in. We have checked the loom at the ECU, ABS module and between the two and everything looks as it should be.
We contacted the company who done the repair and we sent the pump back. They then said the pump wasn't repairable so we had to have a new one. We explained that there was no issues with ECU comms before the pump repair and after a few conversations with them, they supplied another recon pump free of charge.
The recon unit has been fitted and coded this morning as we would usually do but we still aren't able to communicate with the ECU. Is it possible that a faulty repair on the last unit has killed the ECU?
Below is a log from this mornings scan. The ABS supply voltage fault is now gone but the comms issue is there
Any help would be appreciated
Many thanks
Many thanks
Chassis Type: 6J-SE25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 4B 56 77
VIN: VSSZZZ6JZ9R020932 Mileage: 153420km-95330miles
Address 01: Engine
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ABS82.clb
Part No SW: 6R0 907 379 HW: 6R0 907 379
Component: ABS8.2 front H03 0004
Revision: --------
Coding: 100224DB016F00B2082E24E580D300000000
Shop #: WSC 04941 123 12345
VCID: 7BA898E873A5CC539AD-802E
Fault Status: 00101101
Mileage: 153421 km
Date: 2016.11.13
Time: 01:50:47
Hex Value: 0x0005
Hex Value: 0x0000
Hex Value: 0x3112
Hex Value: 0x1397
Hex Value: 0x00FF
Hex Value: 0x007F
Hex Value: 0x7F00
Hex Value: 0x0000
Address 08: Auto HVAC Labels: 6J0-820-045.clb
Part No SW: 6J0 820 045 HW: 6J0 820 045
Component: J301 Klimaanlage 0280
Revision: 00 23 08 Serial number: 0000000014278-
VCID: 6398C088E7551493B2D-8036
16372 - Control Module; Unspecified Internal Error
014 - Defective
Fault Status: 01101110
Mileage: 153421 km
Date: 2016.11.13
Time: 00:00:03
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 HW: 6R0 937 087
Component: PQ25 BCM H06 0011
Revision: BF006001 Serial number: 9425A154080611
Coding: 7C882BA88861010000300000660B1CC80040400F608C00002000
Shop #: WSC 64564 324 38760
VCID: 7AA69DEC7CDFF55B81B-802E
Subsystem 1 - Part No SW: 6R0 959 802 A HW: 6R0 959 802 A Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 001 0222
Coding: 030000
Subsystem 2 - Part No SW: 6R0 959 801 B HW: 6R0 959 801 B Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 001 0225
Coding: 020000
Subsystem 3 - Part No SW: 6R0 959 811 HW: 6R0 959 811
Component: J388__TSG_HL 001 0227
Subsystem 4 - Part No SW: 6R0 959 812 HW: 6R0 959 812
Component: J389__TSG_HR 001 0228
Part No SW: 6R0 959 655 HW: 6R0 959 655
Component: VW10AirbagA05 H07 0013
Revision: -------- Serial number: 003000000000
Coding: 003035
Shop #: WSC 06402 785 00200
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 7F506CF8677DD073B65-802A
Serial number: 3492ERB40235G3471JIN
Serial number: 3502ERB402T5EOKV8CFB
Part No SW: 6J0 920 900 K HW: 6J0 920 900 K
Component: KOMBI 016 0016
Coding: 410A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
VCID: 2F307CB8F79DE0F3665-807A
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 0011
Coding: 022300
VCID: 70B2BFC42AA3BF0B3FF-8024
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO 016 0016
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156
Component: LenkhilfeTRW V272
Coding: 10121
Shop #: WSC 06402
VCID: 6D8CA6B034D152E3149-8038
Address 4B: Multifunc. Module Labels: 6J0-959-441.clb
Part No: 6J0 959 441 A
Component: MF-Modul 0007 0001
Coding: 0000002
Shop #: WSC 77005 000 00000
VCID: 31347AC0ED29F603701-8064
Address 56: Radio (J503) Labels:. 6J0-035-153.clb
Part No SW: 6J0 035 153 B HW: 6J0 035 153 B
Component: Radio G3 UL H55 0033
Revision: 0H001001 Serial number: SEZ1Z2H5663717
Coding: 0503040002
Shop #: WSC 04941 000 00000
VCID: 23188088ABD55493F2D-8076
Address 77: Telephone Labels: 5P0-862-335.lbl
Part No SW: 5P0 862 335 D HW: 5P0 862 335 D
Component: FSE_2P7x H31 0120
Revision: 00000001 Serial number: 00000005001981
Coding: 0000720
VCID: 343A73D4123BC32B1B7-8060
