No comms with ecu since replacing ABS module
rushacregarages
Pembrokeshire, Wales
C?ID=150205
Hi guys/girls,
We have lost all comms with the engine control unit on our Seat Ibiza.
It all started with an internal fault in the ABS module. The fault was 01201 - ABS pump supply voltage. we ran diagnostics and checked the loom and all was fine there, including supply voltages, so it was clear that there as a problem with the ABS module. We then sent the module away for repair which we had done many times without many issues. When the module came back we plugged it in and the fault was still present. However, this time we have no communication with the ECU at all. The battery was disconnected every time a module was unplugged/plugged in. We have checked the loom at the ECU, ABS module and between the two and everything looks as it should be.
We contacted the company who done the repair and we sent the pump back. They then said the pump wasn't repairable so we had to have a new one. We explained that there was no issues with ECU comms before the pump repair and after a few conversations with them, they supplied another recon pump free of charge.
The recon unit has been fitted and coded this morning as we would usually do but we still aren't able to communicate with the ECU. Is it possible that a faulty repair on the last unit has killed the ECU?
Below is a log from this mornings scan. The ABS supply voltage fault is now gone but the comms issue is there
Any help would be appreciated
Many thanks
Chassis Type: 6J-SE25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 4B 56 77
VIN: VSSZZZ6JZ9R020932   Mileage: 153420km-95330miles
Address 01: Engine
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ABS82.clb
   Part No SW: 6R0 907 379     HW: 6R0 907 379
   Component: ABS8.2 front  H03 0004
   Revision: --------
   Coding: 100224DB016F00B2082E24E580D300000000
   Shop #: WSC 04941 123 12345
   VCID: 7BA898E873A5CC539AD-802E
                    Fault Status: 00101101
                    Mileage: 153421 km
                    Date: 2016.11.13
                    Time: 01:50:47
                    Hex Value: 0x0005
                    Hex Value: 0x0000
                    Hex Value: 0x3112
                    Hex Value: 0x1397
                    Hex Value: 0x00FF
                    Hex Value: 0x007F
                    Hex Value: 0x7F00
                    Hex Value: 0x0000
Address 08: Auto HVAC        Labels: 6J0-820-045.clb
   Part No SW: 6J0 820 045     HW: 6J0 820 045
   Component: J301  Klimaanlage   0280
   Revision: 00 23 08    Serial number: 0000000014278-
   VCID: 6398C088E7551493B2D-8036
16372 - Control Module; Unspecified Internal Error
            014 - Defective
                    Fault Status: 01101110
                    Mileage: 153421 km
                    Date: 2016.11.13
                    Time: 00:00:03
   Part No SW: 6R0 937 087     HW: 6R0 937 087
   Component: PQ25 BCM      H06 0011
   Revision: BF006001    Serial number: 9425A154080611
   Coding: 7C882BA88861010000300000660B1CC80040400F608C00002000
   Shop #: WSC 64564 324 38760
   VCID: 7AA69DEC7CDFF55B81B-802E
   Subsystem 1 - Part No SW: 6R0 959 802 A    HW: 6R0 959 802 A  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  001 0222
   Coding: 030000
   Subsystem 2 - Part No SW: 6R0 959 801 B    HW: 6R0 959 801 B  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  001 0225
   Coding: 020000
   Subsystem 3 - Part No SW: 6R0 959 811     HW: 6R0 959 811
   Component: J388__TSG_HL  001 0227
   Subsystem 4 - Part No SW: 6R0 959 812     HW: 6R0 959 812
   Component: J389__TSG_HR  001 0228
   Part No SW: 6R0 959 655     HW: 6R0 959 655
   Component: VW10AirbagA05 H07 0013
   Revision: --------    Serial number: 003000000000
   Coding: 003035
   Shop #: WSC 06402 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 7F506CF8677DD073B65-802A
   Serial number: 3492ERB40235G3471JIN
   Serial number: 3502ERB402T5EOKV8CFB
   Part No SW: 6J0 920 900 K    HW: 6J0 920 900 K
   Component: KOMBI         016 0016
   Coding: 410A00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
   VCID: 2F307CB8F79DE0F3665-807A
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 0011
   Coding: 022300
   VCID: 70B2BFC42AA3BF0B3FF-8024
   Component: IMMO          016 0016
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
   Part No: 6R0 423 156
   Component: LenkhilfeTRW        V272
   Coding: 10121
   Shop #: WSC 06402
   VCID: 6D8CA6B034D152E3149-8038
Address 4B: Multifunc. Module        Labels: 6J0-959-441.clb
   Part No: 6J0 959 441 A
   Component: MF-Modul       0007 0001
   Coding: 0000002
   Shop #: WSC 77005 000 00000
   VCID: 31347AC0ED29F603701-8064
Address 56: Radio (J503)       Labels:. 6J0-035-153.clb
   Part No SW: 6J0 035 153 B    HW: 6J0 035 153 B
   Component: Radio G3 UL   H55 0033
   Revision: 0H001001    Serial number: SEZ1Z2H5663717
   Coding: 0503040002
   Shop #: WSC 04941 000 00000
   VCID: 23188088ABD55493F2D-8076
Address 77: Telephone        Labels: 5P0-862-335.lbl
   Part No SW: 5P0 862 335 D    HW: 5P0 862 335 D
   Component: FSE_2P7x        H31 0120
   Revision: 00000001    Serial number: 00000005001981
   Coding: 0000720
   VCID: 343A73D4123BC32B1B7-8060
Eric
HC800000
Do you have the autoscan of when the ECU was communicating?
rushacregarages
C?ID=150205
Yes i do. Here it is:
Address 01: Engine        Labels: 03C-906-024-BXW.lbl
   Part No SW: 03C 906 024 BK    HW: 03C 906 024 BH
   Component:             MM4HV   3052
   Revision: --H05---    Serial number:
   Coding: 0000071
   VCID: 68D5A4E258D0A1C9E9-5122
   VINID: 9A38EAAAA19AA898800802430818FCF9D7
   Revision: --------
   VCID: 7BFFEBAEFE461A5114-802E
01201 - ABS Pump Supply Voltage
                    Fault Status: 11100000
                    Reset counter: 246
                    Mileage: 153419 km
                    Date: 2016.07.09
                    Time: 00:12:56
                    Hex Value: 0x4005
                    Hex Value: 0x0000
                    Hex Value: 0x30A0
                    Hex Value: 0x0597
                    Hex Value: 0x00FF
                    Hex Value: 0x007F
                    Hex Value: 0x7E00
                    Hex Value: 0x0000
   VCID: 63CFB3CEA2F6C2913C-8036
                    Mileage: 152503 km
                    Date: 2016.07.09
                    Time: 00:01:24
   VCID: 7AF1EEAAF57C23590F-802E
   Coding: 030000
   Coding: 020000
14 Faults Found:
00968 - Right Turn Signals
            006 - Short to Plus - Intermittent
                    Fault Status: 00100110
                    Reset counter: 24
                    Mileage: 153413 km
                    Date: 2016.07.09
                    Time: 01:08:02
01758 - Bulbs for Brake Lamps
                    Fault Frequency: 35
                    Reset counter: 24
                    Mileage: 153413 km
                    Date: 2016.07.09
                    Time: 01:03:08
                    Fault Status: 00101011
                    Reset counter: 24
                    Mileage: 153413 km
                    Date: 2016.07.09
                    Time: 04:29:54
00329 - Control Circuit for Unlocking Rear Lid
                    Reset counter: 22
03297 - Switch in Lock Cylinder; Driver Side
                    Reset counter: 23
03301 - Response Closing Status of Drivers Door
                    Reset counter: 22
03302 - Response Closing Status of Passenger's Door
                    Reset counter: 22
03303 - Response Closing Status of Rear Left Door
                    Reset counter: 30
                    Mileage: 143922 km
                    Date: 2016.07.09
                    Time: 22:54:40
03304 - Response Closing Status of Rear Right Door
                    Reset counter: 22
03224 - Play Protection Active
                    Reset counter: 21
                    Mileage: 145723 km
                    Date: 2016.07.09
                    Time: 22:58:54
                    Reset counter: 23
                    Mileage: 153413 km
                    Date: 2016.07.09
                    Time: 00:47:56
                    Reset counter: 22
                    Reset counter: 22
                    Mileage: 115509 km
                    Date: 2014.09.09
                    Time: 00:00:03
   Coding: 003035
   VCID: 7F071FBEE65E067138-802A
   Coding: 410A00
   VCID: 2F670FFE76BE36F1E8-807A
   Coding: 022300
   VCID: 70E5CC82A3006909B1-8024
9456128 - Engine Control Module (ECM) not authorized
          B104A 00 [008] - -
                    Mileage: 124389 km
                    Date: 2021.04.10
                    Time: 21:35:55
   Coding: 10121
   Shop #: WSC 06402
   VCID: 6DDBD5F6203284E19A-8038
   Coding: 0000002
   VCID: 31630986A88A2001FE-8064
   Coding: 0503040002
   VCID: 234FF3CE227682917C-8076
   Coding: 0000720
   VCID: 346D00925798152995-8060
Eric
HC800000
ok, hat tip to @NEtech , there is probably nothing wrong with your engine controller, other than having fault codes that you can't read at the moment. The working scan was done with a HEX+CAN, and the non-working scan with a HEX-NET which apparently still has issues connecting to those half-length marelli ECUs. I've ordered one off eBay, but in the meantime, try "Bypass CAN" in the options, and if that does not work, try removing battery power for a minutes, then bypass CAN. Let us know if that improves things as far as engine communication. The rest of the controllers, being on the CAN bus, will not answer with the "bypass CAN" option checked.
rushacregarages
C?ID=150205
Ah ok. We upgraded our machine a couple of months ago, that's why the two scans are different.
So I tried everything that you suggested but I still have no comms with the ECU. What step would you suggest next?
I'm very grateful for your response :) Thank you
Eric
HC800000
I just tried our problematic marelli here (03C 906 014 G) and it works with both HEX-USB+CAN and HEX-NET. I'm afraid until we get the 03C 906 024 BK from ebay, I don't have a solution for you other than use another interface...
NEtech
Denmark
C?ID=56995
Probably not helping, but it does not cost much to test.
Try and enable "Bypass DoIP" option.
JMR
Romania , EU
C?ID=432218
did you recheck fuses ? Perhaps a short circuit happened when you replugged the repaired module back in ? Did you try and unplug abs unit and see if ECU communicate ? And please take each fuse out and check it visually :thumbs:
rushacregarages
C?ID=150205
Thanks for your replies. I will try your suggestions today. I did check all the fuses again but I will do that again just to be 100% sure. I have tried communicating with it with the ABS module unplugged with no joy.
I will also try to use several other machines and change the options and see what happens today.
I will update the thread once I've tried the above but if there are anymore suggestions in the meantime, write them down and I'll add them to this to do list.
Thanks again for the replies :)
Reactions: JMR
Trowbridge, UK
If you were able to communicate with the ECU before replacing the ABS module and now cannot communicate even with the new ABS module unplugged then that suggests either a fuse has blown or maybe some wiring to the ECU has been disturbed.
rushacregarages
C?ID=150205
All fuses were checked again and are ok. The only difference between when we initially done the first scan and the scan after the unit was replaced was that we were using a new genuine VCDS interface. The previous scan was done using an older genuine VCDS interface.
Understood, which is why we're trying to get a hold of such an ECU to see if there might be some incompatibility between it and the newer interfaces.
JMR
Romania , EU
C?ID=432218
So you don t have the older interface around ??
