Perfcent
I believe the coding should be: 00254014030500080000
Thursday,23,June,2022,12:44:00:42627
VCDS Version: 22.3.1.4 (x64)
Workshop Code: 210 01369 040505
VIN: WV1ZZZ2KZCX014174 License Plate:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56
VIN: WV1ZZZ2KZCX014174 Mileage: 104780km-65107miles
Address 01: Engine (J623-CAYD) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 PC HW: 03L 907 425 C
Component: 1,6l R4 CR td H43 8013
Revision: --H43--- Serial number: 00000000000000 CVN: 563A1DB3
Coding: 00000000000000000000
Shop #: WSC 35110 790 50316
ASAM Dataset: EV_ECM16TDI02103L906023PC 003009
ROD: EV_ECM16TDI02103L906023B_003_VW36.rod
VCID: 76E782C4C961BE3FE5-8022
VINID: 9E606AAAA09BA93A0004404710F6AF15D6
6548 - Engine Control Module Incorrectly Coded
P1612 00 [165] - -
Mileage: 104786 km
Date: 2022.06.23
Time: 12:17:46
Engine RPM: 780.25 /min
Normed load value: 27.8 %
Coolant temperature: 43 °C
Intake air temperature: 23 °C
Voltage terminal 30: 14.231 V
Coding in the engine control module-FRF_VARCOD: 4
Number of resets of main unit-CTR_RST_MC: 0
Control Module temperature-TECU: 46 °C
Accelerator position: normalized-Accelerator position: 0.00 %
6549 - Software Incompatibility with Transmission Control Module
U0302 00 [165] - -
Mileage: 104786 km
Date: 2022.06.23
Time: 12:17:46
Sensor for engine block temperature: raw value-Coolant temperature: 48 °C
Engine torque-TQI_SP: 0.00 Nm
selected gear-DRI: 0
11844 - Engine Control Unit Incorrectly Coded
P0610 00 [165] - -
Mileage: 104786 km
Date: 2022.06.23
Time: 12:17:46
Readiness: 0110 1000
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 052 H HW: 0AM 927 769 D
Component: GSG DSG AG7 421 2710
Revision: 00042014 Serial number: CU501106095500
Shop #: WSC 35110 377 00155
VCID: 306B74DCA385D00F7F-8064
006227 - Powertrain Data Bus
P1853 - 000 - Implausible Message from ABS Controller - Intermittent
Reset counter: 10
Mileage: 104786 km
Date: 2016.11.13
Time: 12:06:08
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 433C400D092303FEC20C02EB901DC081310000
VCID: 7BF193F0FA43E3579A-802E
18020 - Engine Control Module Incorrectly Coded
P1612 - 000 -
Reset counter: 239
Mileage: 104786 km
Date: 2016.11.13
Time: 11:19:31
Count: 2
Count: 20992
Count: 8197
Count: 43520
Count: 1
Count: 65280
Part No SW: 7N0 907 426 AM HW: 7N0 907 426 AM
Component: AC Manuell H19 0304
Revision: 00001015
Coding: 0000004002
VCID: 7F0967E0E65BFF77B6-802A
Part No SW: 2K5 937 086 B HW: 2K5 937 086 B
Component: BCM PQ35 M+ 011 1044
Revision: BD011001
Coding: 411A583A8025186A088000829000816403017288524F8160648000000040
VCID: 356545C89CE7F5272C-8060
Subsystem 1 - Part No: 1T2 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer 18051 26 0512
Coding: 009795
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag00U H06 0013
Revision: -------- Serial number: 003HL0062ADT
Coding: 000000000000000000000000000000003055
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 356545C894E7F5272C-8060
Part No SW: 5K0 953 507 AB HW: 5K0 953 549
Revision: -------- Serial number: 90440KER000Y2
Coding: 1880060000
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 70EBB4DCAB05900F3F-8024
Part No SW: 2K0 920 965 E HW: 2K0 920 965 E
Component: KOMBI H03 0606
Coding: 480001
VCID: 316D71D8608FD90770-8064
Part No SW: 7N0 907 530 H HW: 1K0 907 951
Component: J533 Gateway H42 1620
Revision: H42 Serial number: 130611F1000074
Coding: 357401
Component: IMMO H03 0606
VCID: 6ADFA6B48DD96ADF71-803E
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2110
Coding: 0000560
VCID: 489B3C3C3B1578CF47-801C
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 140 3201
Revision: 00H20000
VCID: 346378CC579DEC2F1B-8060
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0000560
VCID: 47993F00360B77B74E-8012
Address 56: Radio
End-------------------------(Elapsed Time: 02:00)--------------------------
