I always do a full scan before doing any work on the car, always good to have a permanent record in case one loses the code, e.g ABS coding, then I can re-enter the code.
Life would be easier for us and many other people if everyone did that!
Wednesday,24,August,2022,14:22:30:46973
VCDS Version: 22.3.1.4 HEX-NET CB: 0.4615.4
Workshop Code: 000 18261 018261
VIN: WVWZZZ1KZ9P001138 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ9P001138 Mileage: 171150km-106347miles
72-Door, Rear Right -- Status: Cannot be reached 1100
Address 01: Engine Labels: 03G-906-016-BKC.clb
Part No SW: 03G 906 021 PM HW: 03G 906 021 AN
Component: R4 1,9L EDC G000SG 1136
Revision: --H08--- Serial number: VWX7Z0H43N790J
Coding: 0000071
Shop #: WSC 00028 028 00001
VCID: 79BA24B9306E2F4788-802C
VINID: 9E69EAAAA05BA8980000104320D41A0CA3
053273 - Control Module for Instrument Cluster
U1019 - 000 - Missing Signal for Oil Level/Temperature
Mileage: 171151 km
Time: 04:13:26
Voltage: 12.54 V
Bin. Bits: 00101100
Bin. Bits: 00000000
(no units): 0.0
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 CD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0120
Revision: 00H35001
Coding: 133B200D092200FBC80C04E7902100813000
Shop #: WSC 18261 000 18261
VCID: 76A02F85C170403FE5-8022
Part No SW: 1K0 820 047 HM HW: 1K0 820 047 HM
Component: Climatic PQ35 142 1111
Revision: 00142031 Serial number: 00000000000000
VCID: 76A02F850170403FE5-8022
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-M.lbl
Part No SW: 3C0 937 049 AH HW: 3C0 937 049 AH
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000005702297
Coding: E4890F2700041000471400001400000000087B075C000100000000000000
Shop #: WSC 00028 067 57207
VCID: 6FAE1AE17E2A71F726-803A
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 050508 021 0501
Coding: 00038805
Shop #: WSC 00028
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 200508 046 0204
Coding: 00208933
Shop #: WSC 00028
Reset counter: 103
Mileage: 171151 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 12.35 V
Component: 38 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD20BHZS
Coding: 0013112
VCID: 3D32F0A964C6D367E4-8068
Subsystem 1 - Serial number: 6332MSME29053530+
Subsystem 2 - Serial number: 6342MSME2701164F8
Subsystem 3 - Serial number: 6352QSME6830796DT
Subsystem 4 - Serial number: 6362QSME690F4C5B/
Part No SW: 1K0 953 549 BG HW: 1K0 953 549 BG
Component: J0527 752 0101
Coding: 0002022
VCID: 78BC21BD0B64364FF7-802C
Component: E0221 002 0010
Part No SW: 1K0 920 974 B HW: 1K0 920 974 B
Component: KOMBIINSTRUMENT VDD 2216
Revision: V0002000 Serial number: VWX7Z0H43N790J
Coding: 0000401
VCID: 2D12C0E9B4A643E754-8078
00003 - Control Module
014 - Defective
Fault Status: 01101110
Mileage: 158627 km
Time: 00:00:09
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H07 0062
Revision: H07 01 Serial number: 050508F2000137
Coding: E9807F060002020003
VCID: 3522E8895CF60B272C-8060
Reset counter: 103
Mileage: 171151 km
Time: 04:13:00
Component: IMMO VDD 2216
014 - Defective
Mileage: 169808 km
Time: 01:31:03
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 006 1220
Coding: 0000692
VCID: 383CE1BD4BE4F64F37-806C
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 69 3201
Revision: 00H20000
VCID: 3424D58D578C122F1B-8060
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 819002005103087F2D04840570085F0690FC00
VCID: 0346465142A26597D2-8056
Component: LIN BACKUP HORN H08 9001
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0000692
VCID: 393AE4B970EEEF47C8-806C
Address 56: Radio Labels: 1K0-035-1xx-56.clb
Part No: 1K0 035 186 AD
Component: Radio GR0 034 0033
Revision: 0003404S Serial number: VWZ2Z2H6918576
Coding: 0020200
VCID: 689C71FD5BC4A6CF67-803C
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 006 1302
Coding: 0000144
Shop #: WSC 00028 028 1012545
Address 72: Door, Rear Right
End----------(Elapsed Time: 01:01, VBatt start/end: 12.4V/12.4V)-----------
