Hello, I have this 2009 VW Golf with steering issue.
I replace the G85 at the steering column but still showing G85 not reached.
I checked fuses and all is good.
Any idea?
Any idea?
Wednesday,22,June,2022,21:29:51:46973
VCDS Version: 22.3.1.4 HEX-NET CB: 0.4615.4
Workshop Code: 000 18261 018261
VIN: WVWZZZ1KZ9P001138 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ9P001138 Mileage: 170610km-106012miles
04-Steering Angle -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Cannot be reached 1100
Address 01: Engine Labels: 03G-906-016-BKC.clb
Part No SW: 03G 906 021 PM HW: 03G 906 021 AN
Component: R4 1,9L EDC G000SG 1136
Revision: --H08--- Serial number: VWX7Z0H43N790J
Coding: 0000071
Shop #: WSC 00028 028 00001
VCID: F9BAA4B9B06EAF4708-80AC
VINID: 9E69EAAAA05BA8980000104320D41A0CA3
8 Faults Found:
005658 - Glowplug for Cylinder 1 (Q10)
P161A - 000 - Open Circuit
Mileage: 170578 km
Time: 17:18:34
RPM: 882 /min
Voltage: 11.70 V
Bin. Bits: 00001100
Temperature: 14.4°C
Bin. Bits: 10110000
005659 - Glowplug for Cylinder 2 (Q11)
P161B - 000 - Open Circuit
Mileage: 170578 km
Time: 17:18:34
RPM: 882 /min
Voltage: 11.70 V
Bin. Bits: 00001100
Temperature: 14.4°C
Bin. Bits: 10110000
005660 - Glowplug for Cylinder 3 (Q12)
P161C - 000 - Open Circuit
Mileage: 170578 km
Time: 17:18:34
RPM: 882 /min
Voltage: 11.70 V
Bin. Bits: 00001100
Temperature: 14.4°C
Bin. Bits: 10110000
005661 - Glowplug for Cylinder 4 (Q13)
P161D - 000 - Open Circuit
Mileage: 170578 km
Time: 17:18:34
RPM: 882 /min
Voltage: 11.70 V
Bin. Bits: 00001100
Temperature: 14.4°C
Bin. Bits: 10110000
005379 - Load Signal from Alternator Term. DF
P1503 - 000 - Implausible Signal - Intermittent
Fault Status: 00110000
Mileage: 170578 km
Time: 17:28:31
RPM: 945 /min
Voltage: 11.63 V
Bin. Bits: 00001100
(no units): 33.0
005785 - Powertrain Data Bus
P1699 - 000 - Missing Message from Steering Wheel Electronics - Intermittent
Mileage: 170580 km
Time: 10:12:07
Voltage: 13.07 V
Bin. Bits: 00001100
Bin. Bits: 00000000
(no units): 0.0
000275 - Intake Air Temp. Sensor (G42)
P0113 - 000 - Signal too High - Intermittent
Voltage: 12.01 V
Temperature: 133.2°C
Temperature: 13.5°C
Temperature: 14.4°C
000568 - Manifold Pressure / Boost Sensor (G31)
P0238 - 000 - Signal too High - Intermittent
Voltage: 12.01 V
Bin. Bits: 00001100
Absolute Pres.: 132.6 mbar
Absolute Pres.: 2182.8 mbar
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 CD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0120
Revision: 00H35001
Coding: 113B200D092200FB880C04E7902100813000
Shop #: WSC 18261 000 18261
VCID: F6A0AF854170C03F65-80A2
Reset counter: 92
Mileage: 170615 km
Count: 2
Count: 2
Count: 12288
Count: 166
Count: 47104
01486 - System Function Test Activated
Reset counter: 92
Mileage: 170615 km
Count: 2
Count: 2
Count: 12288
Count: 320
Count: 47104
Fault Status: 01100101
Reset counter: 92
Mileage: 170615 km
Count: 2
Count: 2
Count: 12288
Count: 295
Count: 47104
Fault Status: 01101000
Reset counter: 92
Mileage: 170615 km
Count: 2
Count: 2
Count: 12288
Count: 8212
Count: 47104
Part No SW: 1K0 820 047 HM HW: 1K0 820 047 HM
Component: Climatic PQ35 142 1111
Revision: 00142031 Serial number: 00000000000000
VCID: F6A0AF858170C03F65-80A2
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-M.lbl
Part No SW: 3C0 937 049 AH HW: 3C0 937 049 AH
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000005702297
Coding: E4890F2700041000471400001400000000087B075C000100000000000000
Shop #: WSC 00028 067 57207
VCID: EFAE9AE1FE2AF1F7A6-80BA
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 050508 021 0501
Coding: 00038805
Shop #: WSC 00028
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 200508 046 0204
Coding: 00208933
Shop #: WSC 00028
Reset counter: 92
Mileage: 170615 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 13.00 V
Component: 38 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD20BHZS
Coding: 0013112
VCID: BD3270A9E4C6536764-80E8
Subsystem 1 - Serial number: 6332MSME29053530+
Subsystem 2 - Serial number: 6342MSME2701164F8
Subsystem 3 - Serial number: 6352QSME6830796DT
Subsystem 4 - Serial number: 6362QSME690F4C5B/
Part No SW: 1K0 953 549 BG HW: 1K0 953 549 BG
Component: J0527 752 0101
Coding: 0002022
VCID: F8BCA1BD8B64B64F77-80AC
01426 - Controls in Steering Wheel (E221)
Part No SW: 1K0 920 974 B HW: 1K0 920 974 B
Component: KOMBIINSTRUMENT VDD 2216
Revision: V0002000 Serial number: VWX7Z0H43N790J
Coding: 0000401
Shop #: WSC 00999 444 64523
VCID: AD1240E934A6C3E7D4-80F8
00003 - Control Module
014 - Defective
Fault Status: 01101110
Mileage: 158627 km
Time: 00:00:09
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H07 0062
Revision: H07 01 Serial number: 050508F2000137
Coding: E9807F064002020003
VCID: B5226889DCF68B27AC-80E0
Reset counter: 92
Mileage: 170615 km
Time: 09:11:22
Reset counter: 92
Mileage: 170615 km
Time: 09:11:22
Component: IMMO VDD 2216
014 - Defective
Mileage: 169808 km
Time: 01:31:03
Address 37: Navigation Labels: 1T0-919-887.lbl
Part No: 5P0 919 887 A
Component: Navigation 0311
Coding: 0000002
Shop #: WSC 06402 785 00200
VCID: C0CC095D93343E8F0F-8094
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 006 1220
Coding: 0000692
VCID: B83C61BDCBE4764FB7-80EC
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.069 H07 1806
Shop #: WSC 00000 028 00001
02546 - Steering Limit Stop
Mileage: 170600 km
Temperature: 17.0°C
Voltage: 13.00 V
Voltage: 12.80 V
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 819002005103087F2D04840570085FC690FC00
VCID: 8346C651C2A2E59752-80D6
Component: LIN BACKUP HORN H08 9001
Subsystem 2 - Component: NGS No Answer
Subsystem 3 - Component: IRUE No Answer
Reset counter: 92
Mileage: 170615 km
Time: 09:13:14
00323 - Vehicle Inclination Sensor (G384)
Reset counter: 92
Mileage: 170615 km
Time: 09:13:14
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0000692
VCID: B93A64B9F0EE6F4748-80EC
Address 56: Radio Labels: 1T0-035-095.lbl
Part No: 1T0 035 095
Component: Radio 0311
Coding: 0004400
VCID: EB968EF1CA320DD78A-80BE
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 006 1302
Coding: 0000144
Shop #: WSC 00028 028 1012545
Address 72: Door, Rear Right
End----------(Elapsed Time: 01:32, VBatt start/end: 13.2V/13.2V)-----------
