Golf 1,6 tdi 2011 model boost pressure failure
rgrodem
Norway
C?ID=296363
Hopefully some of you could assist me identify what the problem here can be
Driving the car uphill it lost power. Needed to go down to 2. gear and 40km/h to get up the hill. (Normally in 4-5. gear and 90km/h)
Do you think it is a leak or do you think i need to replace the turbo? Any suggestion fur any testing i can do?
I dont mind the fault codes regarding ABS and aircondition. Only what i need to get the car driving ok.
VCDS Version: 22.3.1.4 (x64) HEX-V2 CB: 0.4615.4
VIN: WVWZZZ1KZBW137160 License Plate:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 61 62 69 72
VIN: WVWZZZ1KZBW137160 Mileage: 256730km-159524miles
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 HM HW: 03L 906 023 A
Component: R4 1.6l TDI H23 9978
Revision: --H23--- Serial number: 00000000000000 CVN: FF5B2EAD
Coding: 00114036030401080000
ASAM Dataset: EV_ECM16TDI02103L906023HM 003014
ROD: EV_ECM16TDI02103L997557Q.rod
VCID: 78AAE2491259C8BBF7F-802C
VINID: 9E69EAAAA05BA929C10C70460001B00FEB
7384 - Boost Pressure Regulation
P0299 00 [167] - Control Range Not Reached
Mileage: 256717 km
Date: 2022.06.18
Time: 17:18:22
Engine RPM: 2213.75 /min
Normed load value: 77.6 %
Vehicle speed: 94 km/h
Coolant temperature: 95 °C
Intake air temperature: 17 °C
Voltage terminal 30: 14.456 V
Charge air pressure: specified value-MAP_SP_MMV: 2276.17 hPa
Charge air pressure: actual value-MAP_MMV: 1828.91 hPa
Air mass: actual value (mg/stroke)-MAF_MES: 781.112 mg/stroke
EGR Solen.val.: actual value-ANG_EGRV[0]: 31.018 %
Throttle valve adapter: actual value-ANG_THR[0]: 95.868 %
Charge air pressure actuator: acknowledgment-ANG_BPA[0]: 52.185 %
Engine torque-TQI_SP: 215.03 Nm
7196 - Function Restriction due to Faults in Other Modules
U1113 00 [101] - -
Fault Frequency: 18
Mileage: 256684 km
Date: 2022.06.18
Time: 21:56:53
Engine RPM: 783.25 /min
Normed load value: 12.9 %
Coolant temperature: 92 °C
Intake air temperature: 31 °C
Voltage terminal 30: 14.231 V
Engine RPM: 972 /min
Accelerator position: normalized-Accelerator position: 0.00 %
Battery voltage: 11.9 V
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 113B200D09250001880C04EA90190051310000
VCID: 76B6EC7118CDBECBE53-8022
Fault Status: 01101000
Reset counter: 0
Mileage: 256319 km
Date: 2016.11.08
Time: 19:03:05
Count: 3
Count: 20992
Count: 209
Count: 43008
Part No SW: 5K0 907 044 BT HW: 5K0 907 044 BT
Component: Climatronic H15 0709
Revision: 00003001
Coding: 0000000003
VCID: 7EA6F451307DF68BBD3-802A
B10AB F0 [009] - Too Low
Reset counter: 0
Mileage: 256684 km
Date: 2022.06.18
Time: 21:56:52
Part No SW: 1K0 937 084 D HW: 1K0 937 084 D
Component: BCM PQ35 B 103 0615
Revision: 00103 AD
Coding: 40180A3A88251AC040080080500000E443010088624D8560648087200041
VCID: 2F381915A717CF03665-807A
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 15101 26 0512
Coding: 009795
02391 - Terminal 30 Reference
Reset counter: 0
Mileage: 256684 km
Date: 2016.11.08
Time: 21:56:51
Voltage: 14.35 V
Term 50 On
Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
Part No SW: 5K0 919 475 C HW: 5K0 919 475
Component: PARKHILFE 8K H07 0008
Revision: -------- Serial number: 12941025010478
Coding: 110001
Shop #: WSC 00230 218 182915
VCID: 36362C71584DFECB253-8062
Part No SW: 5K0 959 655 D HW: 5K0 959 655 D
Component: AirbagVW10 037 0606
Serial number: 003FKRAELHRP
Coding: 00003132
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3B203D4563EF23A3DAD-806E
Serial number: 3572MSME2A496258ZZZ$
Serial number: 3582MSME6D731359ZZZ+
Serial number: 3512QSME36436D0EZZZ/
Serial number: 3522QSME28547026ZZZQ
Part No SW: 5K0 953 507 AS HW: 5K0 953 549 C
Component: Lenks.Modul 007 0080
Revision: -------- Serial number: 90440JJL00112
Coding: 5080040000
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 015C8FAD41838973C01-8054
Part No SW: 5K0 920 871 A HW: 5K0 920 871 A
Component: KOMBI H20 0420
Coding: 170F00
VCID: 2C020E199681B41B437-8078
Address 19: CAN Gateway Labels:. 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 A HW: 1K0 907 951
Component: J533 Gateway H25 5603
Revision: H25 Serial number: 231010F1003083
Coding: E9A07F4600020204000002
VCID: 2E060411AC1DC60B6D3-807A
Component: IMMO H20 0420
VCID: 6A8EC8015CF56A2B71B-803E
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2119
Coding: 0131252
VCID: 313C1F6DBD23D9F3701-8064
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 69 3001
Revision: 00H17000
Part No SW: 5K0 959 702 E HW: 5K0 959 702 E
Component: Tuer-SG 009 2151
Coding: 0131508
VCID: 35342B7D494BF5D32C9-8060
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 3C8 035 195 HW: 3C8 035 195
Component: Radio RCD510 041 0166
Revision: 00000001 Serial number: VWZ1Z3I4228353
Coding: 0500040004
Shop #: WSC 00230 218 182837
VCID: 6594BB3DB56B45535C9-8030
03138 - Input AUX IN
Reset counter: 0
Mileage: 256684 km
Date: 2016.11.08
Time: 21:56:57
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H25 5603
Coding: 030B185A
VCID: 71BCDF6D71A399F3301-8024
00458 - Control Module for Battery Monitoring (J367)
Reset counter: 0
Mileage: 256684 km
Date: 2016.11.08
Time: 21:57:52
Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
Component: Tuer-SG 007 2101
Coding: 0131216
Shop #: WSC 01357 011 1012552
Component: Anhaenger H07 0100
Revision: 3A001001 Serial number: 00000134222051
Coding: 0100000100000000
VCID: 303A1A69BA29D0FB7FF-8064
Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
Coding: 0131216
VCID: 36362C71544DFECB253-8062
End----------(Elapsed Time: 01:10, VBatt start/end: 14.2V/14.4V)-----------
rgrodem
Norway
C?ID=296363
The scan above is after a 1 hour drive in the montains. Tha scan below is the scan i did before i cleared all errors and did the test drive in the mountains. I see that not all the errors has returned.
VIN: WVWZZZ1KZBW137160 Mileage: 256680km-159493miles
7286 - Turbocharger Boost Control Position Sensor Circuit
P2563 00 [237] - Implausible Signal
Mileage: 256358 km
Date: 2022.06.16
Time: 08:01:02
Engine RPM: 901.00 /min
Normed load value: 19.6 %
Vehicle speed: 14 km/h
Coolant temperature: 31 °C
Intake air temperature: 12 °C
Charge air pressure actuator: acknowledgment-ANG_BPA[0]: 49.866 %
Charge Pressure Actuator: activation-ANG_SP_BPA[0]: 85.001 %
High press turbocharger actuator: activation-CTL_LIM_BPA[0]: 84.998 %
High press turbocharger actuator: actual uncond volt value-V_BPA[0]: 2.388 V
Turbocharger boost control: offset open-V_BPA_BOL[0]: 0.498 V
Turbocharger boost control: offset closed-V_BPA_TOL[0]: 3.643 V
High press turbocharger actuator: status-LF_STATE_BPA_DISP[0]: 76
P0299 00 [096] - Control Range Not Reached
Mileage: 256677 km
Date: 2022.06.16
Time: 21:33:08
Engine RPM: 2081.00 /min
Normed load value: 83.5 %
Vehicle speed: 88 km/h
Coolant temperature: 89 °C
Intake air temperature: 18 °C
Voltage terminal 30: 14.344 V
Charge air pressure: specified value-MAP_SP_MMV: 2310.08 hPa
Charge air pressure: actual value-MAP_MMV: 1806.19 hPa
Air mass: actual value (mg/stroke)-MAF_MES: 753.517 mg/stroke
EGR Solen.val.: actual value-ANG_EGRV[0]: 25.940 %
Throttle valve adapter: actual value-ANG_THR[0]: 95.996 %
Charge air pressure actuator: acknowledgment-ANG_BPA[0]: 53.827 %
Engine torque-TQI_SP: 230.44 Nm
U1113 00 [101] - -
Fault Frequency: 60
Mileage: 256210 km
Date: 2022.06.16
Time: 12:58:49
Engine RPM: 779.50 /min
Normed load value: 20.8 %
Coolant temperature: 48 °C
Intake air temperature: 26 °C
Engine RPM: 768 /min
Battery voltage: 12.0 V
Readiness: 1 1 0 0 0
JMR
Romania , EU
C?ID=432218
your car puts out about 1800 mbars of pressure while required value was 2300 mbars, i d say you have a bad turbo hose /bad intercooler or vacuum leak , need to check those and then the other culprits ( turbo solenoid or bad turbo)
