Very Sick RS6 Xtreme
09: Cent. Elect.
Supply Voltage faults
If you clear them, under what circumstances do they come back?
19-CAN Gateway:
Control Module Incorrectly Coded
This is because 65-Tire Pressure is "Not Registered" in the Gateway.
Mats@MFT
C?ID=56967
Hi Everyone, so Ive made some significant progress and the car now runs without errors on the dash. Ive had to deprogram the paddle shifters out for the moment since one of them is clearly malfunctioning and needs replacing. I think Ive taken it as far as I can with my knowledge level and ask for a little bit of guidance to get the rest of the way. One strange problem has appeared - its not possible to lock the car with the key FOB anymore. Pulling the blade key out locks it no problem and inside the car the central locking system is functional.
Theres a few lingering errors on the Autoscan but I really dont know how to overcome them. Any help would be greatly appreciated.
Tuesday,28,June,2022,09:32:47:32392
VCDS Version: 22.3.1.4 (x64)  HEX-NET2 CB: 0.4615.4
Workshop Code: 210 01369 040505
VIN: WUAZZZ4G5EN901130   License Plate:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 1B 20 22 28 36 3B 3C 42
          44 46 47 52 53 55 56 5F 62 65 6C 6D 72 82 85 8E 8F 90 BA
VIN: WUAZZZ4G5EN901130   Mileage: 129373km-80388miles
3C-Lane Change -- Status: Not registered 0001
8F-Pretens. Frt Left -- Status: Malfunction 0010
90-Pretens. Frt Right -- Status: Malfunction 0010
Address 01: Engine (------CRDB)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 906 560     HW: 4H0 906 014
   Component: 4.0l V8TFSI / X62 0009
   Revision: NCX62---    CVN: B23CF558
   Coding: 122A003265260B0A1000
   Shop #: WSC 01369 210 40505
   ASAM Dataset: EV_ECM40TFS0114G0906560 001010
   ROD: EV_ECM40TFS0114G0906560.rod
   VCID: 659CDEF325E62EA35C9-8030
   VINID: 9E546AAAA117155789001043006BC65448
Readiness: 0110 1001
   Part No SW: 4G0 927 158 BD    HW: 0BK 927 156 AM
   Component: 0BK 40TFSIRdW H16 1006
   Revision: --H16---    CVN: 94DF419B
   VCID: 71B4BAA3E12EF203301-8024
   Part No SW: 4G0 907 379 P    HW: 4G0 907 379 P
   Component: ESP PREMIUM   H09 0100
   Coding: 64BF990126FD9980CB00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 004036
   VCID: 3E2E519FE0F05D7BFD3-806A
   Part No SW: 4H0 907 064 DP    HW: 4H0 907 064 DP
   Component: BCM2 2.0      H35 0510
   Coding: 05A92F07000000000000
   VCID: 7AA69D8FBCD8B15B81B-802E
   Part No SW: 4G0 820 043 AE    HW: 4G0 820 043 AE
   Component: KLIMA 4 ZONEN H13 0088
   Serial number: 31081300040451
   Coding: 680200B815
   ASAM Dataset: EV_AirCondiComfoUDS 002043
   VCID: 6296C5EF34C8599BB9B-8036
   Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
   Revision: 11012002    Serial number: 00000001624116
   Coding: 0987201059749FF0BF8100C7A0001800CF9CC708AE080201800108546F01
   VCID: 6FB0BCDBF79AE4F3265-803A
   Component: WWS57X 130724  H36 0080
   Serial number:         130826102722
   Coding: 0045F7
   Serial number: 21685071
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 AA    HW: 4G0 941 531 AA
   Component: E1 - LDS  H07 0044
   Serial number: 29 08 2013  00000743
   Subsystem 4 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A31 LED Mod1L  H03 0006
   Serial number: 00000030071300010644
   Coding: 110000
   Subsystem 5 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A27 LED Mod1R  H03 0006
   Serial number: 00000029071300010411
   Coding: 110000
   Subsystem 6 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA106232000004385214
   Coding: 020300
   Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: B43905C6000000000001
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
                    Fault Status: 00101100
                    Fault Frequency: 45
                    Reset counter: 34
                    Mileage: 129373 km
                    Date: 2022.06.28
                    Time: 08:42:00
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
                    Fault Frequency: 20
                    Reset counter: 34
                    Mileage: 129373 km
                    Date: 2022.06.28
                    Time: 08:42:00
   Part No SW: 4H0 919 475 AC    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0091
   Revision: 11001001    Serial number: 61031319500013
   Coding: A8E31B
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000_004.rod
   VCID: 73B8B0AB9B32C013C2D-8026
Address 14: Susp. Elect.        Labels: None
   Part No SW: 4G0 907 376     HW: 4G0 907 376 A
   Component: J250 DRC FahrwerH01 0040
   Revision: 00000000    Serial number: 00894015103700
   Coding: 0000000
   Shop #: WSC 12041 002 1048576
   VCID: 6B88A8CBCF8218D30AD-803E
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H43 0040
   Revision: --------    Serial number: 003JG00EKCJH
   Coding: 3032343631334E303438554A304C34473053
   VCID: 363E49BFC8C0953B253-8062
   Serial number: 3575HRB401850JEEJHHL
   Serial number: 3585HRB401G50JEA8I43
   Serial number: 3515JRB406125REQ58KH
   Serial number: 3525JRB400U50LAKKH5W
   Serial number: 3554VRB405J25RESD9B8
   Serial number: 3564VRB405L25RESKG7L
1050368 - Databus
          [CAN: 0x323 PCF_01 Timeout]
                    Reset counter: 247
                    Mileage: 129335 km
                    Date: 2022.06.24
                    Time: 18:26:24
   Revision: --------    Serial number: 90372MHU000E2
   Coding: 000015
   VCID: 372044BBCF4A6C333E5-8062
   Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
   Serial number: 20 07 2013  C0307543
                    Reset counter: 249
                    Mileage: 129373 km
                    Date: 2022.06.28
                    Time: 08:52:20
   Part No SW: 4G0 920 931 B    HW: 4G0 920 931 B
   Component: TBenRdwAccNv  H80 0618
   Revision: 30460232    Serial number: 658290813596005
   Coding: 138F110BABC50008000400
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K_AU57.rod
   VCID: 251C9EF36566EEA39C9-8070
   Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
   Component: J533--Gateway H13 0050
   Revision: --------    Serial number: 00000001082365
   Coding: 00ED030000
   GVL: FDA1EDC8FEEB680D4180
   ASAM Dataset: EV_GatewPkoUDS 001019
   VCID: 72B6B5AFE428C91BC9B-8026
   Serial number: 0386281203
0021 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [Steuergerät falsch codiert (CAN)]
                    Reset counter: 249
                    Mileage: 129373 km
                    Date: 2022.06.28
                    Time: 09:25:28
                    Voltage terminal 30: 11.9 V
                    Voltage terminal 15: 12.0 V
                    Control Module temperature: 38 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
   Part No SW: 8K0 907 144 L    HW: 8K0 907 144 L
   Component: DYNAMIKLENK.  H06 0720
   Revision: 52001005    Serial number: --------------
   Coding: 010100
   VCID: 38224787C254634B37F-806C
   Part No SW: 8T0 857 511 AD    HW: 8T0 857 511 AD
   Component: FLA           H04 0012
   Revision: AA001002
   VCID: 7CAA9B97B6EC8F6B937-8028
   Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H16 0200
   Serial number: 002108130001208
   VCID: 280297C71274F3CBA7F-807C
   Part No SW: 4G0 919 158 K    HW: 4G0 919 158 K
   Component: KLIMA FOND    H07 0088
   Serial number: 06091300041480
   Coding: 20
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002021
   VCID: 372044BBCFCA6C333E5-8062
   Component: MEM-FS        H03 0154
   Revision: AA000000    Serial number: 00000072836046
   VCID: 77A084BB8FCAAC33FE5-8022
   Component: SARA 6D red   H03 0056
   Revision: --------    Serial number: EJ1BPA7E00M4YW
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   Part No SW: 4G0 907 566 K    HW: 4G0 907 566
   Component: J769  SWA MasterH04 0010
   Revision: 00H04000    Serial number: 6PZ 010 287-09
   Coding: 0000105
   VCID: 372044BBC34A6C333E5-8062
   Subsystem 1 - Part No: 4G0 907 568 K
   Component: J770  SWA Slave H04 0020
   Subsystem 2 - Serial number: 6PZ 010 287-29
   Subsystem 3 - Serial number: 5F30.08.1300H04000AMS16227ÿ
   Subsystem 4 - Serial number: S16227ÿ
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0507
   Coding: 011F16015E00628002080013
   VCID: 45DC3E7385A60EA3BC9-8010
   Component: RCEPS         H38 0010
   Revision: 00001000    Serial number: 0017773802
   Coding: 011001010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 323675AF24A8891B09B-8066
   Revision: 00002001    Serial number: 0313676887
   Coding: 013E1E22A0BD3081A3300984080312470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
   Subsystem 3 - Part No SW: 4G0 947 135 C    HW: 4G0 947 135
   Serial number: 0000000AP00004205967
   Subsystem 4 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 66100517
   Revision: CJ007001    Serial number: 00000000027946
   Coding: 030000
   VCID: 1D6CB6134DB62663C49-8048
   Component: TSG BF        H03 0507
   Coding: 011F16015E00628002080002
   VCID: 46DE397FB8A005BBB53-8012
   Part No SW: 4H0 907 801 G    HW: 4H0 907 801 A
   Component: EPB-4         H03 0014
   Revision: --------    Serial number: 00000000805062
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2C0A6BD7068CDFEB437-8078
   Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
   Component: ....LWR12.... H02 0010
   Serial number: 130903-0002-114
   Coding: 1122A6601002B300
   ROD: EV_HeadlRegulBasic_AU21.rod
   VCID: 2D0C66D33D96D6E3549-8078
   Part No SW: 4G0 035 061 L    HW: 4G0 035 061
   Component: Radio U DAB   H60 0133
   Revision: AB001007    Serial number: 109I$0D7704841
   Coding: 010103010000000001
   VCID: 261E99FF18E0E5BB953-8072
   Part No SW: 4G0 035 670 K    HW: 4G0 035 670 H
   Component: H-BNT-EU      H51 0732
   Revision: --------    Serial number: 190I50D7548367
   Coding: 070100010302E5FF65B0CF3E00000003080001000000000000
   VCID: 2B0868CB0302D8D34AD-807E
   Subsystem 1 - Part No: 8R0 060 884 BC
   Component: EUR 2013/2014  1603
   Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
   Component: DU8 C7 SV  H43 0021
   Serial number: AUZ8ZDDD00296HJ
   Subsystem 3 - Part No SW: 4G1 919 612 Q    HW: 4G1 919 612 Q
   Component: E380 BDT C7  H11 0204
   Serial number: 90349MI3000D8
   Component: CD-Database  5298
                    Reset counter: 249
                    Mileage: 129373 km
                    Date: 2022.06.28
                    Time: 09:29:14
                    Bin. Bits: 00000000 00000000
                    Bin. Bits: 10001000 00000000
   Component: TSG HL        H03 0507
   Coding: 010F14004000628002080002
   VCID: 49C43243A9BEEAC3581-801C
Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
   Part No SW: 4H0 907 273     HW: 4H0 907 273
   Component: RDKBERU25     H09 0700
   Serial number: 10000000003709
   ASAM Dataset: EV_RDKBERU25 003014
   ROD: EV_RDKBERU25_AU57.rod
   VCID: 6882D7C7D2F433CB67F-803C
   Part No SW: 4H0 907 428 B    HW: 7P6 907 441 D
   Component: TopView       H05 0220
   Revision: 11001001    Serial number: 82330JF0102694
   Coding: 0203000101010000000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 007026
   ROD: EV_CamerSysteTopViewAUDI_007.rod
   Part No SW: 4G9 959 107 B    HW: 4G9 959 107 A
   Component: HDSG-Modul    H03 0143
   Revision: 14003001    Serial number: 240300884
   Coding: 097205C010
   ROD: EV_HDSGAu571.rod
   VCID: 353C4EB3D5C69E232C9-8060
   Component: TSG HR        H03 0507
Address 82: Head Up Display (J898)       Labels:| 4G0-919-604.clb
   Part No SW: 4G0 919 604 K    HW: 4G0 919 604 K
   Component: HeadUpDisplay 004 0201
   Coding: 870000
   ASAM Dataset: EV_HUDContiC7 001023
   ROD: EV_HUDContiC7.rod
   VCID: 333870ABDBB2801302D-8066
   Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
   Component: DPC-SG        H26 0038
   Coding: 62040000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 261E99FF1860E5BB953-8072
   Part No SW: 4G0 907 107 E    HW: 4H0 907 107
   Component: BV-SG         H32 0041
   Serial number: 005000122608137
   Coding: 0400A91B1111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Coding: 0066E608031F0376070308014240C0010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 31347AA321AEB203701-8064
12583680 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 249
                    Mileage: 129373 km
                    Date: 2022.06.28
                    Time: 09:18:25
12583693 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 249
                    Mileage: 129373 km
                    Date: 2022.06.28
                    Time: 09:18:25
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
          U1111 00 [009] - -
                    Reset counter: 247
                    Mileage: 129335 km
                    Date: 2022.06.24
                    Time: 18:26:23
          U1111 00 [009] - -
                    Reset counter: 247
                    Mileage: 129335 km
                    Date: 2022.06.24
                    Time: 18:26:23
   Part No SW: 4H0 907 145     HW: 4H0 907 145
   Component: AEM - LEAR    H07 0006
   Revision: 00001001    Serial number: 97809002405800
   ASAM Dataset: EV_AEMLearAU64X 002014
   ROD: EV_AEMLearAU64X.rod
   VCID: 669ED9FFD8E025BB553-8032
End----(Elapsed Time: 02:50, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
The fob battery is still fine?
   #23
fastlanetuningschweiz
Switzerland
C?ID=516731
as far as I can tell yes. It unlocks and opens the truck without problems. All 3 keys exhibit the same problem. I think I screwed something on the coding somewhere.
   #24
Morski
Cheshire, UK
C?ID=90186
Copy your old coding from the first scan you posted back into module 46 and recheck. If it works then great. Re-enter coding changes incrementally whilst checking that the remote works.
If it fails to re-enable it then do the same for other modules ie 5F,19
Switzerland
C?ID=516731
Modules 46, 5F and 19 coded back to original condition. No success. Still cannot lock with the Key fob - all 3 of them. Recoded back to current specifications because it has the least amount of errors.
Any ideas lads Im completely stumped.
   #26
Westbury, UK
You mention coded back to original condition, what about adaptation channels?
   #27
Morski
Cheshire, UK
C?ID=90186
I think you need to take a deep breath and go through all coding changes that you have made by going through debug folder and check if anything has been changed at the time when you realised the fobs stopped working.
If not then 1 option is to recode every module- not easy and easy to miss things and make things worse. 2nd option is to get it reverted back to factory settings with ODIS online and then start again with individual coding changes.
Also make sure the car has a battery support unit attached when the ign is on for long periods of time.
Have you locked the car and left it overnight ie let it sleep and then see if any changes have taken affect.
   #28
Switzerland
C?ID=516731
Battery maintainer is available and used for longer sessions. Car has slept. Unfortunately I dont have ODIS so I will have to do it the hard way. I think Im going to use the current basis and work from that. The number of problems the car had at the start after the body work modification was massive and I dont particularly want to have to back through all that again. The biggest problem here is the simple fact that because the car is in a show room that is lockable, it was not locked and by the time I noticed the lack of locking capability we were well into version 7 of changes. First ever version should have resolved the problem but it didnt.
   #29
Switzerland
C?ID=516731
09: Cent. Elect.
19-CAN Gateway:
Hi Uwe, these errors seemed to have disappeared entirely and have not come back since. Im grateful they are gone.
   #30
Switzerland
C?ID=516731
A quick update. Since looking into adaptations things have gone sideways big time. I screwed up and things are going backwards. Ive attempted to retrace my steps but now unlocking with the FOB is gone as well. Physically it all functions with buttons and I had some challenges with the rear trunk as well that Im working through. Will get back at it next week and update. Thanks everyone for your help and support its been great. I wont post a scan for now, suffice to say it has issues in 5F and 6D.
   #31
EuroX
Northern NJ USA
C?ID=208579
Look in your Debug sub-folder. There should be a file there called AdpLog.csv that you may find useful.
I suspect this file is created to help unfuck a problem??
  • Agree
Switzerland
C?ID=516731
Going back through adaptations helped a lot. So did going back through coding logs. Nearly there. Unfortunately no locking capable yet. Key fob functionality is nearly perfect - but it wont lock the car. The central locking button works, unlocking all doors is possible and it will even close the windows with the key fob. Rear trunk can be opened with the keyfob as well and the closing assistant works with the rear trunk door button.
Got almost all of it sorted, but for some fucking annoying reason I now have a coding error on the engine and the EPC light is on. Im about ready to drive this thing off a bridge lol. I can feel Im close though.
When the bonnet is down and the car is off - attempting to lock the car with the key results in a slight clicking noise on the drivers side pillar near the relais. Its very faint.
In adaptations:
19-CAN gateway - IDE02185-IKA-key sporadic communication error. !!!!!!! Could this be my gremlin????
onday,04,July,2022,14:52:41:32392
VIN: WUAZZZ4G5EN901130   Mileage: 129498km-80466miles
4332 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [167] - -
          [Checking coding/versions ofcontrol modules in drivetrain]
                    Mileage: 129498 km
                    Date: 2022.07.04
                    Time: 14:48:59
                    Engine RPM: 0.00 /min
                    Coolant temperature: 28 °C
                    Intake air temperature: 31 °C
                    Ambient air pressure: 950 mbar
                    Voltage terminal 30: 11.638 V
                    Engine status: COENG_READY
Readiness: 0110 1101
   Coding: 05A92F06000000000000
   Coding: 680200B815
   Coding: 0045F7
   Coding: 02006D
   Coding: 110000
   Coding: 110000
   Coding: 020300
   Coding: A8E31B
   Coding: 0000000
1050368 - Databus
                    Reset counter: 253
                    Mileage: 129498 km
                    Date: 2022.07.04
                    Time: 14:48:58
   Coding: 00001D
   Coding: 00ED030000
   GVL: FDA1EDCCFEEB680D4180
   Coding: 010100
   Revision: AA001002
   Coding: 20
   ROD: EV_SARA2.rod
   Coding: 0000105
   Coding: 013A0E20A0B93081A3300984080312470000000000000000000000000000
   Coding: 030000
   Coding: 070100010302E5FF7DB0CF3E00000003080001000000000000
                    Reset counter: 253
                    Mileage: 129498 km
                    Date: 2022.07.04
                    Time: 14:49:05
                    Bin. Bits: 00001010 00000000
   Coding: 010F14001000628002080002
   Coding: 0973058010
   Coding: 870000
   Coding: 62040000
   ROD: EV_BC7.rod
   ROD: EV_RGS_L.rod
          U1111 00 [009] - -
                    Reset counter: 253
                    Mileage: 129498 km
                    Date: 2022.07.04
                    Time: 14:48:56
          U1111 00 [009] - -
                    Reset counter: 253
                    Mileage: 129498 km
                    Date: 2022.07.04
                    Time: 14:48:56
   ROD: EV_RGS_R.rod
          U1111 00 [009] - -
                    Reset counter: 253
                    Mileage: 129498 km
                    Date: 2022.07.04
                    Time: 14:48:56
          U1111 00 [009] - -
                    Reset counter: 253
                    Mileage: 129498 km
                    Date: 2022.07.04
                    Time: 14:48:56
End----------(Elapsed Time: 02:52, VBatt start/end: 11.6V/12.1V)-----------
And here below are my notes during the process, maybe a smarter brain can see what the issue is: besides operator error that is:
Address 6D channel IDE01651 status of adaptation, set at not active
attempted to change to active several times - says accepted but when
checked it reverts to not active.
5F channel 6 restored to 1 development test mode active.
Address 17    4G0 920 931 B    channel IDE02494-Automatic door locking
readapted to readout and soft reset done.
Address 09    4H0 907 063 CG    channel 63    adapted from    0    to    1
Address 09    4H0 907 063 CG    channel 64    adapted from    218    to    2
Address 09    4H0 907 063 CG    channel 65    adapted from    0    to    3
Address 09    4H0 907 063 CG    channel 66    adapted from    15    to    4
All returned to original values for channels 63-66 (0,218,0,15)
Long press on drivers door trunk button - closes the boot. Progress
trunk reopens with remote.
6D errors gone
5F remains with error
16 Steering wheel - coding 000035 with tiptronic - results in getriebe warning on dash.
Switched to multi=function steering wheel not installed. But now no music adjustment possible.
Moving back to non-tiptronic coding with ACC installed (reality minus tiptronic) 00001D
returns no errors -must clear them and rescan gateway.
01-Motor drivetrain error - recoded 16 to 000015 (CCS, MFL, lane assist not installed)
16 returns incorrectly coded error. Return to 00001D. No errors
01 - Motor electronics - changed start stop deactivation to not active, to match other modeules
That didnt do anything. Returned to active condition. Motor error remains.
05- Acc/start Auth - shift by wire installed - removed. Byte 3 bit 0
Error in 01 remains, moved to 5F Information electronics -
5F
channel 16 telephone - deactivated - value changed from 1 to 0
Channel 17 internal bluetooth - value changed from inactive to active 0 to 1
Made no difference to 5F state - still malfunction
01 - Motor
reverted coding from:122A003265260B0A1000 to: 122A003265460B0A1000 (from 24 Jun)
same problem - 0010 malfunction. Says no communication with cruise control front distance sensor.
Monday,04,July,2022,13:34:57:32392
VCDS Version: Release 22.3.1 (x64) Running on Windows 10 x64
                Address 01: Engine       Labels: 06E-907-551-CGW.clb
Control Module Part Number: 4G0 906 560     HW: 4H0 906 014
  Component and/or Version: 4.0l V8TFSI / X62 0009
           Software Coding: 122A003265460B0A1000
            Work Shop Code: WSC 01369 210 40505
              ASAM Dataset: EV_ECM40TFS0114G0906560 001010 (AU57)
4709 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [039] - -
          [Lost Communication WithCruise Control Front Distance Range Sensor]
                    Mileage: 129498 km
                    Date: 2022.07.04
                    Time: 13:33:34
                    Intake air temperature: 30 °C
                    Voltage terminal 30: 11.897 V
                    selected gear-Bits 0-7: 0
                    Cruise control switch actuation-Bits 0-7: 0
Changed byte 5 bit 5-6 to 20 - Cruise control system isntalled CCS
results in code: 122A003265260B0A1000 which is the same as the original before this. Get same error back
Monday,04,July,2022,13:38:12:32392
           Software Coding: 122A003265260B0A1000
                      VCID: 659CDEF324662EA35C9-8030
          P1647 00 [167] - -
                    Mileage: 129498 km
                    Date: 2022.07.04
                    Time: 13:37:49
attempted adaptation - IDE07216-Deactivated partial motor operation
brings error:
Monday,04,July,2022,13:41:24:32392
Fault Codes have been Erased
19407 - Partial engine operation
          P166F 00 [167] - Deactivated
                    Mileage: 129498 km
                    Date: 2022.07.04
                    Time: 13:40:44
                    Voltage terminal 30: 11.944 V
Returned it to previous values of per defined parameters - new code gone but basic drivetrain
issue remains.
checking 19 - CAN Gateway
Adaptation - found problem IDE02185-IKA Key gives sporadic communications error
Installation list:
unticked 3C lane change since its not active - results in incorrect coding error - undone
01 Motor:
attempt old coding: current value: 122A003265260B0A1000 change to: 122A003665460B0A1000
says request out of range - no joy here.
Leaving the motor as it is, I dont think the problem is there
46- central convenience:
currently can unlock all doors, open boot with KeyFOB but cannot lock the car with key fob.
Rear door switch operation okay so is the driver door switch.. all works again except
locking capability.
attempting recode from 23 Jun - earliest recorded work undertaken at this point
current coding: 013E1622A0BD3081A3300984080312470000000000000000000000000000
proposed new / old coding: 013A0E20A0B93081A33009840C0312470000000000000000000000000000
result: functions - however no locking capability still - goal not achieved.
To remove J248 module error - I went to
byte 12 bit 2 - unticked.
Successful. Test of locking function = same result - everything works except locking.
back to gateway installation - still have 010 on motor 01
01 - motor electronics - attempted recoding
Euro 6D in byte 7 bit 0-2
byte 4 bit 0-2 04 continuously fans installed selected.
resultant code: 122A003264260B0B1000
rejected - out of range
tried just Euro 6
rejected
Attempted start - motor runs okay but EPC light is now active.
not a good result. Some improvements in functionality but now additional problems.
Reviewing adaptation log and coding log didnt help that much but has returned all most all functionality.
Im going to hit that instrument cluster with the Autel Maxisys and reset it.. see what happens as well.
   #34
Switzerland
C?ID=516731
I managed to find the EPC problem - was related to steering wheel coding. Settled on CCS 20 cruise control , multifunctional steering wheel and Lane assist NOT installed. However Lane assist 3C is still in the gateway installation list i noticed.
   #35
Switzerland
C?ID=516731
In case anyone was wondering where the key problem was hidden, resetting personalization under adaption in module 46 seemed to have fixed the problem. I want to thank everybody for their help with this and if there is interest I will post the log of the changes I made and diagnostic process I went through to get to the bottom of this conundrum. Let me know Id be happy to pass on the knowledge but it seems interest in this topic has come to its natural conclusion.
   #36
EuroX
Northern NJ USA
C?ID=208579
Yes such logs would be appreciated.
   #37
Switzerland
C?ID=516731
Okay so here is the scan after everything works properly.
Tuesday,05,July,2022,16:35:56:32392
   Coding: 0987201059749FF0BF8100C7A0001800CF9CC708AA080201800108546F01
   Coding: 0045F7
   Coding: 02006D
   Coding: 110000
   Coding: 110000
   Coding: 020300
   Coding: A8E31B
   Coding: 0000000
1050368 - Databus
                    Reset counter: 253
                    Mileage: 129498 km
                    Date: 2022.07.05
                    Time: 15:57:53
   Coding: 000015
                    Reset counter: 253
                    Mileage: 129498 km
                    Date: 2022.07.05
                    Time: 15:57:50
   Coding: 138F110BEBC50008000400
   Coding: 00ED030000
   Coding: 010100
   Revision: AA001002
   Coding: 20
   ROD: EV_SARA2.rod
   Coding: 0000105
   Coding: 011F16015E00628002080012
   Coding: 013E0E20A0BD308183300984080312470000000000000000000000000000
   Coding: 030000
                    Reset counter: 253
                    Mileage: 129498 km
                    Date: 2022.07.05
                    Time: 15:58:00
   Coding: 097205C010
   Coding: 870000
   Coding: 62040000
   ROD: EV_BC7.rod
   ROD: EV_RGS_L.rod
          U1111 00 [009] - -
                    Reset counter: 253
                    Mileage: 129498 km
                    Date: 2022.07.05
                    Time: 15:57:52
          U1111 00 [009] - -
                    Reset counter: 253
                    Mileage: 129498 km
                    Date: 2022.07.05
                    Time: 15:57:52
   ROD: EV_RGS_R.rod
          U1111 00 [009] - -
                    Reset counter: 253
                    Mileage: 129498 km
                    Date: 2022.07.05
                    Time: 15:57:52
          U1111 00 [009] - -
                    Reset counter: 253
                    Mileage: 129498 km
                    Date: 2022.07.05
                    Time: 15:57:52
End----(Elapsed Time: 03:08, VBatt start/end: 11.8V/11.7V. VIgn 11.6V)-----
Heres the notes taken during this process - some my find this amusing - I bet its like watching a monkey figure something out :0)
17 - instruments - ori; 138F110BABC50008000400
added byte 4, bit 6 lane assist
brings up malfunction in engine and transmission, reverting back
reverted back same malfunctions -cleared codes - attempting again.
Accepted.
CAN Gateway 19 accepted it.
Just
15
16
5F
8F
90
show errors
Back into 16 - attempting to reactivate lane assist old coding: 000015
new coding: 000055 - out of range - rejected. Quitting.
5F: current coding (with 010 Malfunction)
Analysis: byte 5 was originally coded as A7 going to try that as new coding.
First attempting to inject coding from 24 June 22
proposed new coding: 070100010303C5EF7DB0CB3E00000003080001000000000000
CODING ACCEPTED
CLEARING DTCS
same error codes on 5F present. Testing locking mechanisms.
Same click with the bonnet as before. Instinct is telling me look at the bonnet.
Reverting back to previous coding then will attempt byte 5 change alone.
Changinge byte 5 did nothing to resolve the key issue.
Returned code to 070100010302E5FF7DB0CF3E00000003080001000000000000
46: central convenience
Looking at central convenience 46 now to compare current to old code:
Observations: only change was byte 12 bit 2 ACC flashing brakes on braking
Left current coding as is since its functional.
byte 3 bit 3 currently unselected - safe function operation inactive
Setting to active (nothing to lose by trying)
013A0E28A0B93081A3300984080312470000000000000000000000000000 - proposed code
coding accepted no fault codes
Cleared all DTCs, same 5 suspects on gateway 15-16-5F-8F-90
Testing doors: same result - will not lock
baseline code (removed byte 3 bit 3) 013A0E20A0B93081A3300984080312470000000000000000000000000000
attempting byte 3 bit 1 central locking slective single door locking active
resultant code: 013A0E22A0B93081A3300984080312470000000000000000000000000000
no fault codes - same result - no locking.
noted: pressing the locking button closes the MMI screen and shutsdown the electronics,
so its receiving the signal just not locking
Trying byte 2 bit 1 comfort operation door lock active - that didnt do shit
returned to baseline coding: 013A0C20A0B93081A3300984080312470000000000000000000000000000
Maybe it is to do with the motor room.
42 Drivers door electrics
Base coding: 011F16015E00628002080013
byte 11 bit 0 removed - Adaptive cruise control ACC door contact monitoring active
byte 11 bit 4 SWA/LCA lane change assistant... kept in place.
new code: 011F16015E00628002080012
no errors
no change on the gateway still the 5 horsemen - 15,16,5F,8f,90
central locking still unable to lock car with key
Trunk electronics maybe? Motorraum connected to it?
09 Central electrics - had byte 20 bit 2
baseline: 0987201059749FF0BF8100C7A0001800CF9CC708AE080201800108546F01
with removed 0987201059749FF0BF8100C7A0001800CF9CC708AA080201800108546F01
no errors, no CAN gateway faults.
attempting locking - no change
Leaving it how it is
6D trunk electronics
Cant find anything in adaptations that would change behaviour
Current coding: 0973058010
older coding (to be tried again): 097205C010 - only code it had was load space cover error
attempting to code older shit
difference was byte 1 bit 0 interface - direct or spindle
transport mode was also enabled on byte 3 bit 6 - thats not making any sense.
Will test this: 097205C010
Also found byte 4 bit 1 currently unselected saying 1 sided, not two sided but I noticed it
has two sensors on the bonnet - so maybe this is the fucking gremlin
testing: 097205C010 - no error codes - CAN gateway - no change - locking?
trying with byte 4 bit 1 selected - 2 sided: 097205C012 request out of range - answers that.
19 CAN GATEWAY
no errors - current direct coding is; FDA1EDCCFEEB680D4180
removed 8F, 90 from installation list.
recoded -  new coding: FDA1EDCCFEEB68014180 gives incorrect coding error
reverting back no more gateway errors.
Still not locking.
Not motorroom
Not trunk 6D electronics
not the gateway, has to be central electrics adaptations
46 - central convience again
what about selecting beep on lock byte 1 bit 2 anti-theft system horn active
Adaptations: channel 63 - default value was 168 this doesnt calculate out with all the available
options which comes to 04,08,16,32,64 = 124 - or remove 08 terminal 87 USA logic you get 116
proposed calculated new number from 168 to 116
testing 116@+: no change - attempting 124: no change
removing +64 selective lockingn via KESSY inactive..... hope this works.
new value is 60 no change
selected 04 - central locking confirmation, 16 comfort op confirmation, test value 20
no change - does not lock.
Attempting recode of module 46 central convenience -
current coding: 013A0C20A0B93081A3300984080312470000000000000000000000000000
selected byte 2 bit 1 comfort operation door lock active, bit 2 remote control activ
byte 4 bit 5 two-latch lock installed? was already selected
byte 5 bit 2 central locking via Advance Key Terminal S on Active =--- shit!
new proposed coding: 013E0E20A0BD3081A3300984080312470000000000000000000000000000 / with channel 63 adaptation value of 20
no fault codes
didnt work, same shit - going to adaptation back to 168 and see what we get.
Switching to 168 removes the opening chime - still does not lock.
going for 116
116 restores the chirps.
testing 124 - 08- Terminal 87 USA logic
testing 04 = no locking
back to original value of 168 -
added 04 confirmation of central locking opening 172
nothing works - returned it to 168 which was what it had at teh start
tried 28
Attempting to reset all adaptations to factory default:
stored current values:
Channnel 01 value 36960
Channel 02 value 36960
Channel 03 value 36960
Channel 04 value 36960
Channel 14 - 200
Channel 15 - 200
Channel 21 - 21
Channel 60 - 15
Channel 61 - 12287
Channel 62 - 65535
Channel 63 - 168
Channel 64 - 490
Channel 65 - 63
channel 66 - error not available.
Resetting back to defaults simply removes the chime when opening, closing problem remains.
Everythign else works except locking.
Module 46 - coding error found byte 8 bit 5 shift by wire - removed.  Original code:
new code:
013E0E20A0BD308183300984080312470000000000000000000000000000 - value 8 changed.
accepted without errors
Slept car went and had coffee and some food - came back and the bastard car works properly now.!!!!
Im taking the win and quitting right here.
I honestly dont know what I did here, but it seems resetting all adapations to factory default did it.
