- Apr 26, 2022
- 17
- 4
- Switzerland
- C?ID=516731
Hi Everyone
I got an RS6 C7 that has been to a German body shop for installation of an extreme kit. This kit includes widening the rear axle with distancers / spacers and a number of other fancy looking bodywork parts that make it look like a shark. Its quite nice to look at. The vehicle was previously tuned both motor and gearbox and ran without faults before the installation of the body kit. When I went to the fuse boxes I had to replace a number of missing fuses and re-arrange them to the correct amperage.
Some physical facts that impact the problem:
1. The front radar senders are not installed - there is no space for them. Retrofitting the newer smaller ones is being considered as a possibility - but I dont have the expertise - yet.
2. Instrument panel displays gearbox error.
3. Parking brake error, although it functions correctly.
4. Paddle shift problem, already tested both sides - the down one does not work, mechanic swears its installed correctly VCDS Adv measures disagrees :-)
5. Gearbox functions correctly - car drives like a wild horse.
Heres the complete print out from VCDS scan. Any help to fix all this is greatly appreciate and if someone wants to remote in and sort it Im willing to pay as well - of course.
Thankyou in advance and please ask whatever questions you need to be able to help.
Tuesday,21,June,2022,11:27:01:32392
VCDS Version: 22.3.1.4 (x64) HEX-NET2 CB: 0.4615.4
Workshop Code: 210 01369 040505
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 1B 20 22 28 36 3B 3C
42 44 46 47 52 53 55 56 5F 62 65 6C 6D 72 81 82 85 8E 8F 90
BA
VIN: WUAZZZ4G5EN901130 Mileage: 129335km-80365miles
13-Auto Dist. Reg -- Status: Cannot be reached 0100
65-Tire Pressure -- Status: Not registered 0011
81-Gear Shift -- Status: Cannot be reached 0100
82-Head Up Display -- Status: Malfunction 0010
85-On Board Cam. -- Status: Malfunction 0010
8F-Pretens. Frt Left -- Status: Malfunction 0010
90-Pretens. Frt Right -- Status: Malfunction 0010
Address 01: Engine (------CRDB) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 906 560 HW: 4H0 906 014
Component: 4.0l V8TFSI / X62 0009
Revision: NCX62--- CVN: B23CF558
Coding: 122A003265460B0A1000
Shop #: WSC 92521 052 12345
ASAM Dataset: EV_ECM40TFS0114G0906560 001010
ROD: EV_ECM40TFS0114G0906560.rod
VCID: 659CDEF325E62EA35C9-8030
VINID: 9E546AAAA117155789001043006BC65448
4709 - No Communications with Cruise Control (Front) Distance Sensor
U0235 00 [039] - -
[Lost Communication WithCruise Control Front Distance Range Sensor]
Mileage: 129335 km
Date: 2022.06.21
Time: 10:44:31
Engine RPM: 0.00 /min
Coolant temperature: 33 °C
Intake air temperature: 34 °C
Ambient air pressure: 940 mbar
Voltage terminal 30: 11.685 V
selected gear-Bits 0-7: 0
Cruise control switch actuation-Bits 0-7: 0
Readiness: 0110 1001
Part No SW: 4G0 927 158 BD HW: 0BK 927 156 AM
Component: 0BK 40TFSIRdW H16 1006
Revision: --H16--- CVN: 94DF419B
VCID: 71B4BAA3E12EF203301-8024
18126 - Controls in Steering Wheel
U108F 00 [039] - Implausible Signal
[Control unit in steering wheelImplausible signal]
Mileage: 129335 km
Date: 2022.06.21
Time: 10:44:32
Voltage terminal 30: 11.781 V
Engine RPM: 0 /min
Status data bus communication diagnostic interface-State Deashboard received: not received
Status data bus communication diagnostic interface-State ECM received: not received
Status data bus communication diagnostic interface-State ESP received: not received
Status data bus communication diagnostic interface-State Gateway received: not received
Status data bus communication diagnostic interface-State Parking Brake received: not received
Status data bus communication diagnostic interface-State Steering Angle received: not received
Status data bus communication diagnostic interface-State Steering Assist received: not received
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 P HW: 4G0 907 379 P
Component: ESP PREMIUM H09 0100
Coding: 64BF990126FD9980CB00
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremiAU57X 004036
VCID: 3E2E519FE0F05D7BFD3-806A
0040 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[ComScl_PDU_ACC_05_Timeout]
Reset counter: 247
Mileage: 129335 km
Date: 2022.06.21
Time: 10:44:29
VzRef: 00
Bit Info 1: 00
Bit Info 2: 00
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 00
F-Type: 9E
Uz: 97
0042 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[ComScl_PDU_ACC_10_Timeout]
Reset counter: 247
Mileage: 129335 km
Date: 2022.06.21
Time: 10:44:29
VzRef: 00
Bit Info 1: 00
Bit Info 2: 00
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 00
F-Type: A4
Uz: 97
Part No SW: 4H0 907 064 DP HW: 4H0 907 064 DP
Component: BCM2 2.0 H35 0510
Coding: 05A92F07000000000000
VCID: 7AA69D8FBCD8B15B81B-802E
Part No SW: 4G0 820 043 AE HW: 4G0 820 043 AE
Component: KLIMA 4 ZONEN H13 0088
Serial number: 31081300040451
Coding: 680200B815
ASAM Dataset: EV_AirCondiComfoUDS 002043
VCID: 6296C5EF34C8599BB9B-8036
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002 Serial number: 00000001624116
Coding: 0987201059749FF2BF8100C7A0001800CF9CC708AE080201800108546F01
Shop #: WSC 01369 210 40505
VCID: 6FB0BCDBF79AE4F3265-803A
Component: WWS57X 130724 H36 0080
Serial number: 130826102722
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 21685071
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 AA HW: 4G0 941 531 AA
Component: E1 - LDS H07 0044
Serial number: 29 08 2013 00000743
Subsystem 4 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A31 LED Mod1L H03 0006
Serial number: 00000030071300010644
Coding: 110000
Subsystem 5 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A27 LED Mod1R H03 0006
Serial number: 00000029071300010411
Coding: 110000
Subsystem 6 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA106232000004385214
Coding: 020300
Subsystem 7 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: B43905C6000000000001
01319 - Control Module for Distance Control (J428)
Reset counter: 247
Mileage: 129335 km
Date: 2022.06.21
Time: 10:44:00
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AC HW: 4H0 919 475 AG
Component: PARKHILFE ACC H01 0091
Revision: 11001001 Serial number: 61031319500013
Coding: A8EB1B
ASAM Dataset: EV_EPHVA18AU57X0000 004009
ROD: EV_EPHVA18AU57X0000_004.rod
VCID: 73B8B0AB9B32C013C2D-8026
12727552 - Databus
[Steuergerät für Abstandsdistanzregelung - ACC_02_FR - kein Signal/keine Kommunikation]
Reset counter: 247
Mileage: 129335 km
Date: 2022.06.21
Time: 10:44:29
Address 13: Auto Dist. Reg
Address 14: Susp. Elect. Labels: None
Part No SW: 4G0 907 376 HW: 4G0 907 376 A
Component: J250 DRC FahrwerH01 0040
Revision: 00000000 Serial number: 00894015103700
Coding: 0000000
Shop #: WSC 12041 002 1048576
VCID: 6B88A8CBCF8218D30AD-803E
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG00EKCJH
Coding: 3032343631334E303438554A304C34473053
VCID: 363E49BFC8C0953B253-8062
Serial number: 3575HRB401850JEEJHHL
Serial number: 3585HRB401G50JEA8I43
Serial number: 3515JRB406125REQ58KH
Serial number: 3525JRB400U50LAKKH5W
Serial number: 3554VRB405J25RESD9B8
Serial number: 3564VRB405L25RESKG7L
1050368 - Databus
[CAN: 0x323 PCF_01 Timeout]
Reset counter: 247
Mileage: 129335 km
Date: 2022.06.21
Time: 10:44:30
Revision: -------- Serial number: 90372MHU000E2
Coding: 00003D
VCID: 372044BBCF4A6C333E5-8062
Subsystem 1 - Part No SW: 8U0 951 528 H HW: 8U0 951 528 H
Serial number: 20 07 2013 C0307543
01749 - Switch for Tiptronic in Steering Wheel (E439); Down
Fault Status: 01101100
Reset counter: 247
Mileage: 129335 km
Date: 2022.06.21
Time: 10:44:27
Part No SW: 4G0 920 931 B HW: 4G0 920 931 B
Component: TBenRdwAccNv H80 0618
Revision: 30460232 Serial number: 658290813596005
Coding: 138F110BAEC50008000400
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K_AU57.rod
VCID: 251C9EF36566EEA39C9-8070
U1014 00 [009] - -
Reset counter: 247
Mileage: 129335 km
Date: 2022.06.21
Time: 10:44:29
16776960 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[ACC_02_FR keine Kommunikation]
Reset counter: 247
Mileage: 129335 km
Date: 2022.06.21
Time: 10:44:29
16776961 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[ACC_04_FR keine Kommunikation]
Reset counter: 247
Mileage: 129335 km
Date: 2022.06.21
Time: 10:44:29
Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb
Part No SW: 4G0 907 468 AD HW: 4G0 907 468 AC
Component: J533--Gateway H13 0050
Revision: -------- Serial number: 00000001082365
Coding: 00ED074800
GVL: FDA9EDCCFEE3680DC180
ASAM Dataset: EV_GatewPkoUDS 001019
VCID: 72B6B5AFE428C91BC9B-8026
Serial number: 0386281203
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 130619000000000001FB
5510 - No Communication with Gear Selector Module
U0103 00 [009] - -
Reset counter: 247
Mileage: 129335 km
Date: 2022.06.21
Time: 10:44:29
Voltage terminal 30: 11.6 V
Voltage terminal 15: 11.7 V
Control Module temperature: 38 °C
System status: Terminal 15 on
Engine running: OFF
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 0
4365 - No Communications with Cruise Control (Front) Distance Sensor
U0235 00 [009] - -
Reset counter: 247
Mileage: 129335 km
Date: 2022.06.21
Time: 10:44:29
Engine running: OFF
IN ZAS_Te_X: On
Datenfeld: 0
0021 - Control Module Incorrectly Coded
U1014 00 [009] - -
[Steuergerät falsch codiert (CAN)]
Reset counter: 247
Mileage: 129335 km
Date: 2022.06.21
Time: 10:44:32
Engine running: OFF
IN ZAS_Te_X: On
Datenfeld: 0
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 L HW: 8K0 907 144 L
Component: DYNAMIKLENK. H06 0720
Revision: 52001005 Serial number: --------------
Coding: 010100
VCID: 38224787C254634B37F-806C
Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD
Component: FLA H04 0012
Revision: AA001002
VCID: 7CAA9B97B6EC8F6B937-8028
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 B HW: 4H0 907 163 A
Component: 4 Wheel Drive H16 0200
Serial number: 002108130001208
VCID: 280297C71274F3CBA7F-807C
Part No SW: 4G0 919 158 K HW: 4G0 919 158 K
Component: KLIMA FOND H07 0088
Serial number: 06091300041480
Coding: 20
ASAM Dataset: EV_ClimaContrUnitRearUDS 002021
VCID: 372044BBCFCA6C333E5-8062
Component: MEM-FS H03 0154
Revision: AA000000 Serial number: 00000072836046
VCID: 77A084BB8FCAAC33FE5-8022
Part No SW: 4G0 907 637 L HW: 4G0 907 637 G
Component: SARA 6D red H03 0056
Revision: -------- Serial number: EJ1BPA7E00M4YW
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4G0 907 566 K HW: 4G0 907 566
Component: J769 SWA MasterH04 0010
Revision: 00H04000 Serial number: 6PZ 010 287-09
Coding: 0000105
VCID: 372044BBC34A6C333E5-8062
Subsystem 1 - Part No: 4G0 907 568 K
Component: J770 SWA Slave H04 0020
Subsystem 2 - Serial number: 6PZ 010 287-29
Subsystem 3 - Serial number: 5F30.08.1300H04000AMS16227ÿ
Subsystem 4 - Serial number: S16227ÿ
Component: TSG FA H04 0507
Coding: 011F16015E00628002080013
VCID: 45DC3E7385A60EA3BC9-8010
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H38 0010
Revision: 00001000 Serial number: 0017773802
Coding: 011001010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 323675AF24A8891B09B-8066
Revision: 00002001 Serial number: 0313676887
Coding: 013A0E20A0B93081A33009840C0312470000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177
Component: DWA-Sensor H01 0010
Subsystem 3 - Part No SW: 4G0 947 135 C HW: 4G0 947 135
Serial number: 0000000AP00004205967
Subsystem 4 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Serial number: 66100517
Reset counter: 247
Mileage: 129335 km
Date: 2022.06.21
Time: 10:44:27
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007001 Serial number: 00000000027946
Coding: 030000
VCID: 1D6CB6134DB62663C49-8048
Component: TSG BF H03 0507
Coding: 011F16015E00628002080002
VCID: 46DE397FB8A005BBB53-8012
Part No SW: 4H0 907 801 G HW: 4H0 907 801 A
Component: EPB-4 H03 0014
Revision: -------- Serial number: 00000000805062
ROD: EV_ParkiBrake_VW51.rod
VCID: 2C0A6BD7068CDFEB437-8078
327936 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[FC_ACC_05_MESSAGE_TIMEOUT]
Reset counter: 247
Mileage: 129335 km
Date: 2022.06.21
Time: 10:44:29
Voltage terminal 30: 11.8 V
Internal Fault ID: 86
Function light in parking brake button: On
Red operating lamp: On
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: OFF
RWU: not active
DSD: not active
HTR: not active
ECD: not active
ACC requested apply: not active
Auto Adjust: not active
Internal Parking Brake state: static
Status ParkingBrake left: applied
Status ParkingBrake right: applied
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Component: ....LWR12.... H02 0010
Serial number: 130903-0002-114
Coding: 1122A6601002B300
ROD: EV_HeadlRegulBasic_AU21.rod
VCID: 2D0C66D33D96D6E3549-8078
Part No SW: 4G0 035 061 L HW: 4G0 035 061
Component: Radio U DAB H60 0133
Revision: AB001007 Serial number: 109I$0D7704841
Coding: 010103010000000001
VCID: 261E99FF18E0E5BB953-8072
Part No SW: 4G0 035 670 K HW: 4G0 035 670 H
Component: H-BNT-EU H51 0732
Revision: -------- Serial number: 190I50D7548367
Coding: 070100010303CDEF7DB0CB3E00000003080001000000000000
VCID: 2B0868CB0302D8D34AD-807E
Subsystem 1 - Part No: 8R0 060 884 BC
Component: EUR 2013/2014 1603
Subsystem 2 - Part No SW: 4G0 919 605 C HW: 4G0 919 605 C
Component: DU8 C7 SV H43 0021
Serial number: AUZ8ZDDD00296HJ
Subsystem 3 - Part No SW: 4G1 919 612 Q HW: 4G1 919 612 Q
Component: E380 BDT C7 H11 0204
Serial number: 90349MI3000D8
Component: CD-Database 5298
Reset counter: 247
Mileage: 129335 km
Date: 2022.06.21
Time: 11:23:10
Bin. Bits: 00000000 00100000
Bin. Bits: 00001000 00000000
Bin. Bits: 00000000 00000000
Component: TSG HL H03 0507
Coding: 010F14004000628002080002
VCID: 49C43243A9BEEAC3581-801C
Address 65: Tire Pressure (J502) Labels: 3Y0-907-273.clb
Part No SW: 4H0 907 273 HW: 4H0 907 273
Component: RDKBERU25 H09 0700
Serial number: 10000000003709
ASAM Dataset: EV_RDKBERU25 003014
ROD: EV_RDKBERU25_AU57.rod
VCID: 6882D7C7D2F433CB67F-803C
12652551 - Tire Pressure Monitoring
C10DC 54 [009] - Missing Calibration / Basic Setting
Reset counter: 247
Mileage: 129335 km
Date: 2022.06.21
Time: 10:44:29
Part No SW: 4H0 907 428 B HW: 7P6 907 441 D
Component: TopView H05 0220
Revision: 11001001 Serial number: 82330JF0102694
Coding: 0203000101010000000102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 007026
ROD: EV_CamerSysteTopViewAUDI_007.rod
Part No SW: 4G9 959 107 B HW: 4G9 959 107 A
Component: HDSG-Modul H03 0143
Revision: 14003001 Serial number: 240300884
Coding: 097205C010
ROD: EV_HDSGAu571.rod
VCID: 353C4EB3D5C69E232C9-8060
0114 - Load Space Cover
B12EF 54 [137] - Missing Calibration / Basic Setting
Reset counter: 247
Mileage: 129335 km
Date: 2022.06.21
Time: 10:44:29
Voltage terminal 30: 11.68 V
Component: TSG HR H03 0507
Address 81: Gear Shift
Address 82: Head Up Display (J898) Labels:| 4G0-919-604.clb
Part No SW: 4G0 919 604 K HW: 4G0 919 604 K
Component: HeadUpDisplay 004 0201
Coding: C70000
ASAM Dataset: EV_HUDContiC7 001023
ROD: EV_HUDContiC7.rod
VCID: 333870ABDBB2801302D-8066
U1111 00 [009] - -
Reset counter: 247
Mileage: 129335 km
Date: 2022.06.21
Time: 10:44:29
U1111 00 [009] - -
[ACC_04 keine Kommunikation]
Reset counter: 247
Mileage: 129335 km
Date: 2022.06.21
Time: 10:44:29
Part No SW: 4G0 907 217 A HW: 4H0 907 217 A
Component: DPC-SG H26 0038
Coding: 6A060000
ROD: EV_OnBoardCamerDPC.rod
VCID: 261E99FF1860E5BB953-8072
0724 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[ACC_timeout]
Reset counter: 247
Mileage: 129335 km
Date: 2022.06.21
Time: 10:44:29
Outside temperature: -36.5 °C
Voltage terminal 15: 11.5 V
Control Module temperature: 39.0 °C
Part No SW: 4G0 907 107 E HW: 4H0 907 107
Component: BV-SG H32 0041
Serial number: 005000122608137
Coding: 04C0BB1B1111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
0030 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[Kombi_Kombi_01_Signal_Error]
Reset counter: 247
Mileage: 129335 km
Date: 2022.06.21
Time: 10:44:30
Outside temperature: 27.0 °C
Control Module temperature: 36.0 °C
0046 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[ACC_timeout]
Reset counter: 247
Mileage: 129335 km
Date: 2022.06.21
Time: 10:44:30
0173 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[APS_Signal_Error_Master]
Reset counter: 247
Mileage: 129335 km
Date: 2022.06.21
Time: 10:44:30
Component: RGS-VL H13 0080
Coding: 0066E608031F0376070308014240C0010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 31347AA321AEB203701-8064
12583680 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 247
Mileage: 129335 km
Date: 2022.06.21
Time: 10:44:29
12583693 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 247
Mileage: 129335 km
Date: 2022.06.21
Time: 10:44:29
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
U1111 00 [009] - -
Reset counter: 247
Mileage: 129335 km
Date: 2022.06.21
Time: 10:44:29
U1111 00 [009] - -
Reset counter: 247
Mileage: 129335 km
Date: 2022.06.21
Time: 10:44:29
Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
Part No SW: 4H0 907 145 HW: 4H0 907 145
Component: AEM - LEAR H07 0006
Revision: 00001001 Serial number: 97809002405800
ASAM Dataset: EV_AEMLearAU64X 002014
ROD: EV_AEMLearAU64X.rod
VCID: 669ED9FFD8E025BB553-8032
End----(Elapsed Time: 03:05, VBatt start/end: 11.4V/11.7V. VIgn 11.6V)-----
