G’day all,
Long story: Stop-start is enabled automatically unless you disable it manually near the gear shift. I understand you can disable it permanently via coding but I want it disabled every time I start the car and can manually activate when I feel the need to. Example, I’ll be at a roundabout and stop-start will activate at the most inconvenient moment! I also understand stop-start can activate as you depress the brake further to lower the RPM. I can habitually activate the stop-start when I know I’ll be situated for long periods of time. Unfortunately, the car doesn’t have the technology to read moments like this. I am not putting down this feature as a negative but I am happy to act alongside with it
Simple story: I want the stop-start to be deactivated and manually activated after each time the car is started instead of it being automatically activated every time the car is started. Does permanently disabling stop-start allow the user to activate stop-start manually?
Thanks for reading!
Edit: Grammar correction
Thanks for reading!
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F
VIN: WVWZZZAUZFP567409 Mileage: 45772km-28441miles
Address 01: Engine (J623-CRBC) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 DT HW: 04L 907 309 D
Component: R4 2,0L EDC H22 8127
Revision: 83H22--- CVN: 0DE255AC
Coding: 111D0012042505082000
Shop #: WSC 00028 028 00073
ASAM Dataset: EV_ECM20TDI01104L906021DT 002008
ROD: EV_ECM20TDI01104L906021DT_002.rod
VCID: FAA61892FC53652B01B-80AE
VINID: 9E69EAAAA465A968051871002487131FDD
Part No SW: 0D9 300 041 P HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4507
Revision: 05853104 Serial number: TFK01409250651 CVN: 000092A8
Shop #: WSC 00028 028 00067
ROD: EV_TCMDQ250021.rod
VCID: A51C1BEE256D3AD31C9-80F0
Part No SW: 3Q0 907 379 F HW: 3Q0 907 379 F
Component: ESC H42 0609
Revision: 00000000 Serial number: 63004000000599
Coding: 04FA8AA124260973077B060041CC2920512490E0608294F300620038C202
Shop #: WSC 00028 028 00244
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034027
ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
VCID: BD2CD38EADFD9213649-80E8
Part No SW: 5G0 907 044 BD HW: 5G0 907 044 BD
Component: Climatronic H03 1001
Revision: 00001K08
Coding: 02120124200100001005000012101400
VCID: EA8628D28CF3D5ABF1B-80BE
Air quality sensor:
Part No SW: 5Q0 937 086 AE HW: 5Q0 937 086 AE
Revision: -------- Serial number: 86582810140755
Coding: 03501A46C24122FB4BE44000000C07081000000000000000000000000000
ROD: EV_BCMBOSCH_014.rod
VCID: FDAC138EED7D5213249-80A8
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 141015 042 0551
Serial number: 141017171040
Coding: 0E4DFD
Component: RLHS 037 0059
Serial number: S4Y14M10D30H06M29S17
Coding: 06A8DD
Sunroof control module:
Subsystem 3 - Part No SW: 5G0 959 591 HW: 7P0 959 591 C
Component: J245 PS22.018 H01 0008
Serial number: WOO3332235
Coding: 191800
Roof shade control module:
Subsystem 4 - Part No SW: 5G0 959 591 HW: 7P0 959 591 C
Component: J394 PS22.018 H01 0008
Serial number: WOO3332183/
Coding: 191800
Humidity sensor: interior:
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 E HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0048
Revision: -------- Serial number: 39331429805178
Coding: 0031111011
Part No SW: 5Q0 959 655 D HW: 5Q0 959 655 D
Component: AirbagVW20 014 0385
Serial number: 003F6R0CHZM8
Coding: 98CCC000000000005C00000000C800000065
Shop #: WSC 00028 028 00059
VCID: C1D4AF7ED105F6F3001-8094
Subsystem 1 - Part No SW: ----------- HW: 480 002 510 14
Serial number: 35767000000F8214711O
Subsystem 2 - Part No SW: ----------- HW: 480 002 510 14
Serial number: 3586700000071524711E
Subsystem 3 - Part No SW: ----------- HW: 480 402 210 14
Serial number: 3516502C51811BA2220Y
Subsystem 4 - Part No SW: ----------- HW: 480 402 310 14
Serial number: 3526502B71860BA4E2AL
Subsystem 5 - Part No SW: ----------- HW: 480 402 210 14
Serial number: 3556502A5169752271A5
Part No SW: 5Q0 953 521 P HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20141029400068
Coding: 0410
ROD: EV_SMLSVALEOMQB.rod
VCID: BFD0A986A7F18003765-80EA
617752 - Selector Lever Park Position Lock Switch
B1162 29 [008] - Signal Implausible
Reset counter: 150
Mileage: 44623 km
Date: 2022.05.03
Time: 17:41:08
Ubat 30 Voltage: 14.50 V
Ignition State: On
Terminal 15: 13.70 V
A/D #1: 0.00 %
A/D #2: 0.00 %
A/D #3: 0.00 %
Part No SW: 5G1 920 741 HW: 5G1 920 741
Component: KOMBI 204 4270
Coding: 27A511082B80000800087A001400000000000000
VCID: E49A46EA6ED783DBCB7-80B0
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 M
Component: GW MQB High 212 2203
Revision: -------- Serial number: 17101410801090
Coding: 030100340F087300EF00024A1C0F00010001050000000000000000000000
GVL: 01543C0000000000400C10000000C80000000000000000000000000000000000
ROD: EV_GatewConti_011.rod
VCID: F2B630B2A4231D6B49B-80A6
Generator:
Subsystem 2 - Part No SW: 5G0 959 442 J HW: 5G0 959 442 J Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H16 0038
Serial number: 29140002377360094441
Coding: 28FFFF
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 9676244703
Part No SW: 5Q4 959 593 C HW: 5Q4 959 593 B
Component: TSG FS 009 0015
Serial number: 0000122900733
Coding: 003A03208001020000000000
VCID: C5DCBB6EC52DDAD33C9-8090
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000006960022
Coding: 0D0000
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 125 1061
Coding: 0102
VCID: C3D8A576CB19E4E312D-8096
Part No SW: 5Q4 959 592 C HW: 5Q4 959 592 B
Component: TSG BFS 009 0015
Serial number: 0000122828332
Coding: 003A03208E01020000800000
VCID: C4DAA66ACE17E3DB2B7-8090
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000006893668
Coding: 050000
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 069E00000B000200
VCID: C0D2AA7ADA0FFFFB0FF-8094
Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 2E0000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 846 A HW: 5G0 035 846 A
Component: MU-S-N-ER 041 0430
Serial number: V1F02610144153
Coding: 02730208FF00000011510001000900001F0102960100010045
ROD: EV_MUStd4CPASE_VW37.rod
VCID: A70011E65F6128C32E5-80F2
Subsystem 1 - Part No SW: 5G0 919 605 D HW: 5G0 919 605 D
Component: ABT_Std_Nav H60 0030
Serial number: VWZ8Z9PS403VP7
Subsystem 2 - Part No SW: 5G0 919 866 R HW: -----------
Component: ROW 2015 --- 0031
6922 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Park assist OPS (0x0A) - function restriction due to communication error - BapErr_timeout: heartbeat]
Reset counter: 110
Mileage: 44801 km
Date: 2022.05.05
Time: 14:38:58
Voltage terminal 30: 11.9 V
7178 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Park assist OPS (0x0A) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 110
Mileage: 44801 km
Date: 2022.05.05
Time: 14:39:01
BAP-BAP_Function_ID: 02
End----(Elapsed Time: 01:35, VBatt start/end: 11.8V/11.9V. VIgn 11.7V)-----
