Maps 2022 Taos 1.5 DNKA maps
Maps
Jef
HQ
AutoScan: 3VV2X7B28NM061887
Saturday,18,June,2022,12:42:12:14741
VCDS Version: 22.4.0.1 (x64)  HEX-NET2 CB: 0.4615.4
Data version: 20220407 DS338.0
VIN: 3VV2X7B28NM061887   License Plate:
Chassis Type: B2-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 22 3C 42 44 47 4B 52 5F 6C
          75 A5 BB BC CA D6 D7
VIN: 3VV2X7B28NM061887   Mileage: 156km-96miles
BB-Door Rear Drv -- Status: Cannot be reached 0100
BC-Door Rear Pass -- Status: Cannot be reached 0100
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DNKA)       Labels: None
   Part No SW: 05E 906 013 C    HW: 05E 907 309 BB
   Component: R4 1.5l TFS   H20 1936
   Revision: KEH20000    CVN: 8C880010
   Coding: 4125003223661108B0000000000000000000000000000000
   Shop #: WSC 00066 790 00082
   ASAM Dataset: EV_ECM15TFS01105E906013C 001006
   ROD: EV_ECM15TFS01105E906013B.rod
   VCID: A0120BCA6A40FA5B732-80F4
   VINID: 0E6982A0748221E7401812081C707E0F0C
40592 - Fuel Quality
          P30C0 00 {039} - Inadequate
                    Mileage: 156 km
                    Date: 2022.06.18
                    Time: 10:27:58
                    Engine RPM: 0.00 /min
                    Coolant temperature: 26 °C
                    Intake air temperature: 34 °C
                    Voltage terminal 30: 12.220 V
                    Outside temperature: 30 °C
                    Absolute intake pressure: 97 kPa abs
                    Engine torque: 0.0 Nm
                    Fuel: tank fill level: 36.0 l
                    Oxygen sensor B1: sensor 1: specified value: 15.9998
                    Engine operating condition: Idle
Readiness: 1110 0101
   Part No SW: 0GC 300 018 E    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2803
   Revision: 00H06V13    CVN: 3DD0C142
   ASAM Dataset: EV_TCMDQ381061 001001
   ROD: EV_TCMDQ381061.rod
   VCID: AB08ECE613862903D60-80FE
   No subsystems:
   Part No SW: 5Q0 614 517 GB    HW: 5Q0 614 517 BP
   Component: ESC           H35 0114
   Revision: 00000000    Serial number: 50132000000138
   Coding: 86FB6A7EA026246D857F0308A2CA2961560524A1C045947C38215558D2AA4A0B00402F641A1B13111452653B484E7CFC
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 049015
   ROD: EV_Brake1UDSContiMK100IPB_049_VW27.rod
   VCID: F7A000969F4E5DE3628-80A2
   Part No SW: 3Q0 959 435 Q    HW: 3Q0 959 435 Q
   Component: VWKESSYMQB    037 1400
   Revision: 00037000    Serial number: 0586834275
   Coding: 132C0C0723
   ASAM Dataset: EV_KessyHellaMQBAB 004055
   ROD: EV_KessyHellaMQBAB.rod
   VCID: C8C2B36AA230E21BDB2-809C
   Part No SW: 5GM 907 044 AM    HW: 5GM 907 044 AM
   Component: Climatronic   H05 2601
   Revision: 00001K04
   Coding: 0902002420211C001104010C1211D014
   Shop #: WSC 00066 790 00221
   ASAM Dataset: EV_ACClimaBHBVW37X 006151
   VCID: 8F70587687DE7523DA8-80DA
   Part No SW: 5Q0 937 085 CK    HW: 5Q0 937 085 CK
   Component: BCM MQBAB HNA H44 0511
   Serial number: 2053094401ÿÿÿÿ
   Shop #: WSC 00066 790 00075
   ASAM Dataset: EV_BCMMQB 022001
   ROD: EV_BCMBOSCH_022_VW27.rod
   VCID: 845A675ADE98067B77A-80D0
   Subsystem 1 - Part No SW: 5Q0 955 555 A    HW: 5Q0 955 555 A
   Component: RLHSS  054 0207
   Serial number: S7Y21M12D06H13M00S20
   Coding: 0018DD
   Steering Column Switch:
   Subsystem 2 - Part No SW: 5Q1 953 521 KS    HW: 5Q1 953 569 K
   Component: Lenks.Modul  H24 0190
   Serial number: 0300050320220C200608
   Subsystem 3 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Component: SysNameFanLin  014 0102
   Serial number: ESE2828880
   Subsystem 4 - Part No SW: 3G0 963 345 A    HW: 3G0 963 345 A
   Component: SysNameFanLin  015 0102
   Serial number: ESE2888942
   Subsystem 5 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE2827435
   Subsystem 6 - Part No SW: 3G0 963 345 A    HW: 3G0 963 345 A
   Serial number: ESE2888948
   Part No SW: 5QA 919 283 H    HW: 5QA 919 283
   Component: PDC 4 Kanal   H08 0073
   Serial number: 000460601421326
   Coding: 0601554011
   ASAM Dataset: EV_EPHVA14AU3700000 009050
   ROD: EV_EPHVA14AU3700000_009_VW37.rod
   VCID: CFF09876475E35239A8-809A
   Part No SW: 2Q0 907 572 AA    HW: 2Q0 907 572 D
   Component: ACCCONTIMQB   H09 0396
   Coding: 300007C15CFF8748949C810580409700000000000000000034
   ASAM Dataset: EV_ACCMRRCONTIVW376 003018
   ROD: EV_ACCMRRCONTIVW376_003.rod
   VCID: F3B834868B3631C35E0-80A6
   Part No SW: 5Q0 959 655 CB    HW: 5Q0 959 655 CB
   Component: AirbagVW21    008 0421
   Serial number: 003J4M07DLRU
   Coding: 8CCCFC00000000005000001FC24800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002166
   VCID: 82566142C48C084B456-80D6
   Component: BF-Gewichtss.  H16 0022
   Serial number: IBH00000000000HGI01C
   Coding: 303555
   Subsystem 2 - Part No SW: -----------    HW: 480 001 311 21
   Serial number: 3570000000077DE42C5-
   Subsystem 3 - Part No SW: -----------    HW: 480 001 311 21
   Serial number: 35800000000DDB6DC95C
   Subsystem 4 - Part No SW: -----------    HW: 480 400 110 21
   Component: SideSensor_Dr  005 6149
   Serial number: 3510001C0C64186452F%
   Subsystem 5 - Part No SW: -----------    HW: 480 400 810 21
   Component: SideSensor_Pr  005 6149
   Serial number: 3520001C8C64187122E2
   Subsystem 6 - Part No SW: -----------    HW: 480 020 301 22
   Component: FrontSensor_D  005 0189
   Serial number: 3550001BAC618F06293B
   Subsystem 7 - Part No SW: -----------    HW: 480 020 301 22
   Component: FrontSensor_P  005 0189
   Serial number: 3560001BAC618F03B92H
   Part No SW: 17A 920 420 B    HW: 17A 920 420 B
   Component: KOMBI         524 6170
   Coding: 08A44808EF8CCF050288624B500000082060070D
   ASAM Dataset: EV_DashBoardVDDMQBA0 001046
   ROD: EV_DashBoardVDDMQBA0_VW37.rod
   VCID: 9C6A3F3A4628DEBBAFA-80C8
   Part No SW: 3Q0 907 530 AL    HW: 3Q0 907 530 E
   Component: GW MQB High   524 5463
   Serial number: 19022200840304
   Coding: 030D00047F085700FB0722DA1E0F00010001070000000000000000000000
   GVL: 01C63C000000040040CC80008082C80010000000000200000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: F9A406AEA95A4B9314C-80AC
   Generator:
   Component: 5-00-14-00-04
   Subsystem 2 - Part No SW: 3G0 959 442 AF    HW: 3G0 959 442 AF  Labels: 3C8-959-537.CLB
   Component: E221__MFL-YLG  H07 0120
   Serial number: YLG-0700084347210854
   Coding: 2E2B00
   Component: J367-BDMHella  H11 9070
   Serial number: 9012238600
Address 22: AWD (-----)       Labels:* None
   Part No SW: 5WA 907 554 P    HW: 5WA 525 130
   Component: 4Motion       H65 0724
   Serial number: HA1-00031.07.21
   Coding: 0101
   ASAM Dataset: EV_AllWheelContrHA1VW37X 005001
   ROD: EV_AllWheelContrHA1VW37X_005.rod
   VCID: DBE87C2603A69983660-808E
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H07 0150
   Serial number: 11230042582758
   Coding: 52954620
   ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
   ROD: EV_HREntryHellaGen3Kl15_002_VW27.rod
   VCID: B924C6AEE9DA8B9354C-80EC
   Subsystem 1 - Part No SW: 2Q0 907 685 B    HW: 2Q0 907 685 B
   Component: HRE3_Kl15_Slv  H07 0150
   Serial number: 11230041907747
   Part No SW: 5Q4 959 593 P    HW: 5Q4 959 593 P
   Component: TSG FS        011 0912
   Serial number: 83018204602773
   Coding: 003E17200000028008000000
   VCID: D2F69102546C58CBB56-8086
   Subsystem 1 - Part No SW: 5Q4 959 811 G    HW: 5Q4 959 811 G
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000011570631
   Coding: 011000
   Part No SW: 5QM 909 144 C    HW: 5QM 909 144 B
   Component: EPS_MQB_ZFLS  173 1082
   Coding: 951F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: D1F49E0E516A23D38CC-8084
   Part No SW: 2G0 035 456     HW: 2G0 035 456
   Component: AMPeth8C      H04 3131
   Serial number: A1128A00071606
   Coding: 22000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_AMPEthMQB 001005
   ROD: EV_AMPEthMQB_VW27.rod
   VCID: E0924BCA2AC0BA5B332-80B4
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0367
   Serial number: 26082100840492
   Coding: 0000000709000B5202110301000000000000000000000000000000000000
   ROD: EV_MultiModulContiVW48X_003.rod
   VCID: B720C096DFCE9DE3A28-80E2
   Part No SW: 5Q4 959 592 P    HW: 5Q4 959 592 P
   Component: TSG BFS       011 0912
   Serial number: 84018202501343
   Coding: 003E13200000028000000000
   Subsystem 1 - Part No SW: 5Q4 959 812 G    HW: 5Q4 959 812 G
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000011584869
   Coding: 091000
   Part No SW: 3G5 035 842 D    HW: 3G5 035 842
   Component: MU-O-NS-US    H56 0813
   Serial number: WG8LGM071021000
   Coding: 23165000002000000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB 001002
   ROD: EV_MUOIMQB_VW27.rod
   VCID: A90416EE197A3B1324C-80FC
   Subsystem 1 - Part No SW: 5NN 919 605 D    HW: 5NN 919 605 D
   Component: ABT_Std-2_Nav  280 8304
   Serial number: VWZ6ZMA0695337
   Subsystem 2 - Part No SW: V03 959 809 CR    HW: -----------
   Component: NAR 2021       --- 5041
   Coding: 01135602A2002017300040
Address 75: Telematics        Labels: None
   Part No SW: 5WA 035 285     HW: 5WA 035 285
   Component: OCUGen3High   H12 0316
   Coding: 023160201968AC209005460160102607
   ASAM Dataset: EV_OCUGen3High 003005
   ROD: EV_OCUGen3High_003_VW37.rod
   Part No SW: 2Q0 980 653 C    HW: 2Q0 980 653
   Component: MQB MFK 3.0   H16 1302
   Serial number: E80320004213430
   Coding: 00000A9011CE4020089F10001030002000418000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007042
   VCID: B53CCA9EC5C26FF3B04-80E0
Address BB: Door Rear Drv
Address BC: Door Rear Pass
   Coding: 00804073163C
   ROD: EV_SunRoofCONTIAU736_009_VW37.rod
   VCID: F5BC0A9E85422FF3704-80A0
   Part No SW: 992 941 572 AE    HW: 992 941 572 A
   Component: LED1L         H08 9202
   ROD: EV_LLPGen3LKEBODPO68X_VW27.rod
   VCID: E69E5DD2C8E4D46BC9E-80B2
   Component: LED1R         H08 9202
End----------(Elapsed Time: 12:50, VBatt start/end: 12.6V/12.6V)-----------
blockmap-01-05E-906-013-C_3VV2X7B28NM061887-20220618-1231.CSV
;SW:05E-906-013-C   HW:05E-907-309-BB ---  Engine
;Component:R4 1.5l TFS   H20 1936, Coding:4125003223661108B0000000000000000000000000000000
;EV_ECM15TFS01105E906013C,001006,EV_ECM15TFS01105E906013B.rod
;Saturday,18,June,2022,12:31:17:14741
;VCDS Version: Beta 22.4.0 (x64)  Data version: 20220407 DS338.0
;VCID: A0120BCA6A40FA5B732-80F4
Group,Description,Actual,
IDE00011,Vehicle Identification Number (VIN),3VV2X7B28NM061887,
IDE00019,Voltage terminal 30,12.620, V
IDE00020-ENG188621,Terminal 15 status-Bits 0-7,1,
IDE00021,Engine RPM,834, /min
IDE00025,Coolant temperature,46, °C
IDE00078,Time since engine start,136, s
IDE00083,Throttle valve position (absolute),11.8, %
IDE00084,Absolute load value,19, %
IDE00085,Normed load value,25.5, %
IDE00086,Accelerator pedal position,14.1, %
IDE00090-ENG188621,selected gear-Bits 0-7,0,
IDE00097,OBD - requirements for which this vehicle is designed,OBD + OBD II,
IDE00100,Engine torque,21.1, Nm
IDE00102,Control Module temperature,37.6, °C
IDE00148,Mean injection time,0.7236, ms
IDE00151,Oil fill level,52.120, mm
IDE00155,Ignition timing angle retard cylinder 1,0.0, °
IDE00156,Ignition timing angle retard cylinder 2,0.0, °
IDE00157,Ignition timing angle retard cylinder 3,0.0, °
IDE00158,Ignition timing angle retard cylinder 4,0.0, °
IDE00167,Exhaust temperature 1 bank 1,405.9, °C
IDE00172,A/C compressor torque,20.0, Nm
IDE00174,Camshaft adjustment: exhaust: bank 1: specified value,-23.41, °
IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,-23.58, °
IDE00178,Camshaft adjustment intake bank 1: specified value,22.00, °
IDE00179,Camshaft adjustment intake bank 1: actual value,22.05, °
IDE00182,Camshaft adaptation intake bank 1: phase position,0.00, °
IDE00184,Camshaft adaptation exhaust bank 1: phase position,0.00, °
IDE00187,Coolant temperature at engine start,26.9, °C
IDE00188,Fuel high-pressure: actual value,16.990, MPa
IDE00190,Charge air pressure: specified value,255.00, hPa
IDE00191,Charge air pressure: actual value,989.14, hPa
IDE00192,Coolant temperature at radiator outlet: actual value,28.9, °C
IDE00194,Coolant temperature at radiator output: specified value,95.0, °C
IDE00196,Engine oil temperature,29.3, °C
IDE00201,High fuel pressure: specified value,17.000, MPa
IDE00202,Low fuel pressure: specified value,415.0, kPa
IDE00304,Fuel level,36.00, l
IDE00349,Throttle valve position: normed,1.2, %
IDE00350,Air mass: specified value,8.4, kg/h
IDE00354,Engine start: start synchronization,EPM_MODE_OK,
IDE00354-ENG127291,Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE,48,
IDE00355-ENG188621,Cruise Control System (CCS): status-Bits 0-7,2,
IDE00357,Fuel temperature,30.8, °C
IDE00358,Limitation: torque,1000.0, Nm
IDE00360,Limitation: accelerator pedal,0.0, Nm
IDE00371,Fuel consumption,0.77, l/h
IDE00375,Generator: load signal,35.46, %
IDE00380,Coolant fan 1: activation,10.15, %
IDE00392,Accelerator pedal: sensor voltage 1,719.0, mV
IDE00393,Accelerator pedal: sensor voltage 2,358.8, mV
IDE00394,Camshaft position: start of phase window,39.88, °
IDE00405,Crankshaft speed (RPM),838.0, /min
IDE00406,Camshaft RPM,418.8, /min
IDE00412-ENG188621,Starter control: terminal 50-Bits 0-7,0,
IDE00413-ENG188621,Starter control: Interlock- or P/N-signal-Bits 0-7,17,
IDE00414-ENG188621,Starter control: relay 1-Bits 0-7,0,
IDE00416-ENG188621,Starter control: terminal 50 feedback-Bits 0-7,4,
IDE00417-ENG188621,Starter control: shut-off conditions 1-Bits 0-7,1,
IDE00417-ENG188621,Starter control: shut-off conditions 1-Bits 0-7,0,
IDE00443-ENG188621,Accelerator pedal: switch positions-Bits 0-7,8,
IDE00451,Currently running routine,Unknown (0),
IDE00474,Ambient air pressure,98, kPa abs
IDE00477,Torque request: sum of auxiliary aggregate,4.9, Nm
IDE00496-ENG188621,Oil pressure switch valve activation-Bits 0-7,1,
IDE00541,Acceleration,0.000, m/s²
IDE00554,Absolute vapor pressure in tank ventilation system,98100, kPa abs
IDE00556,Outside temperature,30, °C
IDE00559,Current of oxygen sensor bank 1 sensor 1 (broadband sensor),0.998 Lambda / -0.023 mA,
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,0.845, V
IDE00582,Specified value of equivalence ratio,1.000, Lambda
IDE00583,Throttle valve specified value,1.6, %
IDE00584,Distance driven since erasing DTC memory,0, km
IDE00587,Vapor pressure in tank ventilation system,2590, Pa
IDE00588,Fuel tank fill level,65.9, %
IDE00592,Status of oxygen sensor control,Closed loop,  / using O2 sensors
IDE00593,Ignition timing adjustment cylinder 1,1.5, Degrees
IDE00594,Absolute intake pressure,25, kPa abs
IDE00597,Long term adaptation of mixture formation bank 1,0.0, %
IDE00601,Monitoring status since erasing DTC memory,,
IDE00602,Monitoring status in current driving cycle,,
IDE00603,Number of driving cycles since erasing DTC memory,0,
IDE00604,Short term adaptation of mixture formation bank 1,0.8, %
IDE00608,Fuel type,Gasoline,
IDE00612,Target position of EVAP canister valve,3.1, %
IDE00738,Oxygen sensor test: bank 1: delta lambda,0.00006,
IDE00773,Terminal 15 status via CAN,1,
IDE00949-ENG188621,Hide cylinder-Bits 0-7,0,
IDE00950-ENG188621,A/C compressor status-Bits 0-7,0,
IDE01378,Fuel high pressure: control deviation,0.0060, MPa
IDE01385-ENG188621,Wear index-Bits 0-7,0,
IDE01386-ENG188621,Soot index-Bits 0-7,0,
IDE01405-ENG188621,Starter activation: status-Bits 0-7,2,
IDE01644,Oxygen sensor voltage B1 downstream CAT,0.844, V
IDE01650,Throttle valve position 2,12, %
IDE01774,Status misfire recognition,False result,
IDE01774-ENG127289,Status misfire recognition-Test_Program_B TRUE UBYTE,0,
IDE01775-ENG188621,Misfires per 1000 revolutions of cylinder 1-Bits 0-7,0,
IDE01776-ENG188621,Misfires per 1000 revolutions of cylinder 2-Bits 0-7,0,
IDE01777-ENG188621,Misfires per 1000 revolutions of cylinder 3-Bits 0-7,0,
IDE01778-ENG188621,Misfires per 1000 revolutions of cylinder 4-Bits 0-7,0,
IDE01834,Battery voltage,12620, mV
IDE01869,Long-term fuel trim bank 1 at idle,0.00, %
IDE01873,Test of catalytic converter: measured value,5.0000,
IDE01876,Adaptation of loss torque,0.0, Nm
IDE01879,Adaptation of throttle valve: result,ADP is OK,
IDE01879-ENG127324,Adaptation of throttle valve: result-Test_Program_Channel 698,2,
IDE01880,Accelerator pedal position 2,14.1, %
IDE01881,Adaptation of kick-down shifting point,4125.2, mV
IDE01888,Cold start enrichment: adaptation area 1,1.000,
IDE01889,Cold start enrichment: adaptation area 2,1.000,
IDE01890,Cold start enrichment: adaptation area 3,1.000,
IDE01891,Cold start enrichment: adaptation area 4,1.000,
IDE01892,Cold start enrichment: adaptation area 5,1.000,
IDE01893,Fuel pump: specified value,52.501, %
IDE01899,Load value: corrected specified value,67.50, %
IDE01901,Lost torque adaptation: idle,0.0, Nm
IDE01902,Lost torque adaptation A/C compressor,0.0, Nm
IDE01903,Lost torque adaptation driving mode,0.0, Nm
IDE01904,Lost torque adaptation A/C compressor and driving mode,0.0, Nm
IDE01912,Oxygen sensor B1: sensor 1: specified value,1.0000,
IDE01922,Vehicle distance driven,156, km
IDE01923,Control module distance driven,155791, m
IDE01928,Close cam shaft angle at quantity control valve,37.5, °
IDE01929,Open cam shaft angle at quantity control valve,-4.0, °
IDE01930,High pressure regulation: adaptation value,0.050, MPa
IDE01932,High pressure pump injection volume,-2.78, mm³
IDE01975-ENG188621,Numb.of misfir.: cylinder 1-Bits 0-7,0,
IDE01975-ENG188621,Numb.of misfir.: cylinder 1-Bits 0-7,27,
IDE01976-ENG188621,Numb.of misfir.: cylinder 2-Bits 0-7,21,
IDE01976-ENG188621,Numb.of misfir.: cylinder 2-Bits 0-7,0,
IDE01977-ENG188621,Numb.of misfir.: cylinder 3-Bits 0-7,0,
IDE01977-ENG188621,Numb.of misfir.: cylinder 3-Bits 0-7,38,
IDE01978-ENG188621,Numb.of misfir.: cylinder 4-Bits 0-7,0,
IDE01978-ENG188621,Numb.of misfir.: cylinder 4-Bits 0-7,39,
IDE02117,Relative load value,17.20, %
IDE02119,Long term adaptation of oxygen sensor control: bank 1,0.0, %
IDE02211,Brake pressure,3.30, MPa
IDE02540-ENG188621,Longitudinal acceleration sensor: status-Bits 0-7,0,
IDE02742,Oil pressure actual value,237.9, kPa
IDE02756,Number of manual engine starts,95,
IDE02757,Number of automatic engine starts,14,
IDE03008-MAS04415,Stop process prevented-Ambient air pressure,not active,
IDE03008-MAS04416,Stop process prevented-Sporadic function prevention,not active,
IDE03008-MAS04417,Stop process prevented-Poor start detection,not active,
IDE03008-MAS04590,Stop process prevented-Mixture adaptation,not active,
IDE03008-MAS06602,Stop process prevented-Engine temperature,not active,
IDE03008-MAS06604,Stop process prevented-Start/stop sensors:,not active,
IDE03008-MAS06605,Stop process prevented-Regeneration Mode,not active,
IDE03008-MAS06606,Stop process prevented-Brake under pressure too low,not active,
IDE03010-IDE00924,Number of prevented stop processes-Steering angle,6,
IDE03010-MAS01627,Number of prevented stop processes-Steering,14,
IDE03010-MAS02040,Number of prevented stop processes-Anti-play protection,0,
IDE03010-MAS04415,Number of prevented stop processes-Ambient air pressure,0,
IDE03010-MAS04416,Number of prevented stop processes-Sporadic function prevention,0,
IDE03010-MAS04417,Number of prevented stop processes-Poor start detection,0,
IDE03010-MAS04589,Number of prevented stop processes-Diagnosis of exhaust system,0,
IDE03010-MAS04590,Number of prevented stop processes-Mixture adaptation,0,
IDE03010-MAS04591,Number of prevented stop processes-Air system diagnosis,0,
IDE03010-MAS04592,Number of prevented stop processes-Hybrid battery performance too low,0,
IDE03010-MAS04593,Number of prevented stop processes-Auxiliary equipment power consumption too high,0,
IDE03010-MAS04595,Number of prevented stop processes-Deceleration takeover active,0,
IDE03010-MAS04805,Number of prevented stop processes-Clutch protection K0,0,
IDE03010-MAS04870,Number of prevented stop processes-Thermostat testing not completed,0,
IDE03010-MAS05758,Number of prevented stop processes-Driving situation,18,
IDE03010-MAS06602,Number of prevented stop processes-Engine temperature,5,
IDE03010-MAS06605,Number of prevented stop processes-Regeneration Mode,0,
IDE03010-MAS06606,Number of prevented stop processes-Brake under pressure too low,0,
IDE03010-MAS08032,Number of prevented stop processes-DTC memory entry in engine control module,0,
IDE03010-MAS09416,Number of prevented stop processes-Learning function active,0,
IDE03010-MAS11563,Number of prevented stop processes-hood open,1,
IDE03010-MAS11835,Number of prevented stop processes-Function locked due to frequent stalling,0,
IDE03010-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,4,
IDE03010-MAS12864,Number of prevented stop processes-Slow traffic detected,0,
IDE03010-MAS13643,Number of prevented stop processes-E machine output too low,0,
IDE03010-MAS13644,Number of prevented stop processes-Engine protection active,0,
IDE03010-MAS13645,Number of prevented stop processes-Fuel gelling protection active,0,
IDE03010-MAS13661,Number of prevented stop processes-Exhaust treatment diagnosis,0,
IDE03010-MAS16918,Number of prevented stop processes-Restriction in start system,0,
IDE03011-MAS01627,Number of requested start processes-Steering,0,
IDE03011-MAS04369,Number of requested start processes-Engine temperature too high,0,
IDE03011-MAS04370,Number of requested start processes-Engine temperature too low,0,
IDE03011-MAS04416,Number of requested start processes-Sporadic function prevention,0,
IDE03011-MAS04592,Number of requested start processes-Hybrid battery performance too low,0,
IDE03011-MAS04593,Number of requested start processes-Auxiliary equipment power consumption too high,0,
IDE03011-MAS04595,Number of requested start processes-Deceleration takeover active,0,
IDE03011-MAS06606,Number of requested start processes-Brake under pressure too low,0,
IDE03011-MAS06607,Number of requested start processes-SCR System requires restart,0,
IDE03011-MAS09730,Number of requested start processes-CAT heating,0,
IDE03011-MAS11563,Number of requested start processes-hood open,0,
IDE03011-MAS11834,Number of requested start processes-Rolling vehicle,0,
IDE03011-MAS13644,Number of requested start processes-Engine protection active,0,
IDE03011-MAS13645,Number of requested start processes-Fuel gelling protection active,0,
IDE03011-MAS16918,Number of requested start processes-Restriction in start system,0,
IDE03262,Adapt of angle sensor 1 f throttle valve,0.513, V
IDE03263,Adapt of angle sensor 2 f throttle valve,4.473, V
IDE03362,Requested transmission torque,1000.0, Nm
IDE03377,Coolant temp at radiator output: unconditioned voltage,3192.8, mV
IDE03393-ENG188621,Selector lever position-Bits 0-7,8,
IDE03493-ENG121091,Driver's door status-Dsplb Drv Door Act Opn,1,
IDE03584-ENG188621,Engine starting requirements-Bits 0-7,0,
IDE03585,System status for the start/stop function master,No release by coordinator,
IDE03586-ENG188621,Starting requirements for active participants-Bits 0-7,0,
IDE03587-IDE02697,Stopping requirements for active participants-Multifunction unit control module,not active,
IDE03587-MAS00124,Stopping requirements for active participants-Air Conditioning,not active,
IDE03587-MAS00127,Stopping requirements for active participants-brakes,not active,
IDE03587-MAS00506,Stopping requirements for active participants-Adaptive Cruise Control,not active,
IDE03587-MAS00832,Stopping requirements for active participants-Convertible top control module,not active,
IDE03587-MAS01090,Stopping requirements for active participants-Transmission,not active,
IDE03587-MAS01106,Stopping requirements for active participants-Level control system,not active,
IDE03587-MAS01490,Stopping requirements for active participants-Energy management,not active,
IDE03587-MAS01627,Stopping requirements for active participants-Steering,not active,
IDE03587-MAS02237,Stopping requirements for active participants-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03587-MAS02569,Stopping requirements for active participants-All-wheel drive electronics,not active,
IDE03587-MAS03757,Stopping requirements for active participants-Quattro Sport,not active,
IDE03587-MAS05129,Stopping requirements for active participants-Motor,not active,
IDE03587-MAS06709,Stopping requirements for active participants-Keyless operation,not active,
IDE03587-MAS08785,Stopping requirements for active participants-Parking aid,not active,
IDE03587-MAS13018,Stopping requirements for active participants-Front sensor for drivers assistant systems,not active,
IDE03588-IDE02697,System malfunctions for active participants start/stop-Multifunction unit control module,not active,
IDE03588-MAS00124,System malfunctions for active participants start/stop-Air Conditioning,not active,
IDE03588-MAS00127,System malfunctions for active participants start/stop-brakes,not active,
IDE03588-MAS00506,System malfunctions for active participants start/stop-Adaptive Cruise Control,not active,
IDE03588-MAS00832,System malfunctions for active participants start/stop-Convertible top control module,not active,
IDE03588-MAS01090,System malfunctions for active participants start/stop-Transmission,not active,
IDE03588-MAS01106,System malfunctions for active participants start/stop-Level control system,not active,
IDE03588-MAS01490,System malfunctions for active participants start/stop-Energy management,not active,
IDE03588-MAS01627,System malfunctions for active participants start/stop-Steering,not active,
IDE03588-MAS02237,System malfunctions for active participants start/stop-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03588-MAS02569,System malfunctions for active participants start/stop-All-wheel drive electronics,not active,
IDE03588-MAS03757,System malfunctions for active participants start/stop-Quattro Sport,not active,
IDE03588-MAS05129,System malfunctions for active participants start/stop-Motor,not active,
IDE03588-MAS06709,System malfunctions for active participants start/stop-Keyless operation,not active,
IDE03588-MAS08785,System malfunctions for active participants start/stop-Parking aid,not active,
IDE03588-MAS13018,System malfunctions for active participants start/stop-Front sensor for drivers assistant systems,not active,
IDE03589-MAS01161,Error status for start-stop related sensors-Communication malfunction,not active,
IDE03589-MAS11563,Error status for start-stop related sensors-hood open,not active,
IDE03589-MAS11868,Error status for start-stop related sensors-Driver door status,active,
IDE03589-MAS12097,Error status for start-stop related sensors-driver door open,active,
IDE03589-MAS12098,Error status for start-stop related sensors-Start/Stop deactivated with button,not active,
IDE03589-MAS12099,Error status for start-stop related sensors-Clutch signal error,not active,
IDE03589-MAS12100,Error status for start-stop related sensors-Brake or speed signal error,not active,
IDE03589-MAS12101,Error status for start-stop related sensors-Steering signal error,not active,
IDE03660,Longitudinal acceleration,0.118, m/s²
IDE03711,Mass flow through throttle valve,8.0, kg/h
IDE03767,Engine status,COENG_RUNNING,
IDE03767-ENG127290,Engine status-Test_Program_Co Eng st COMPU VERB UBYTE,3,
IDE03795,Camshaft adjustment: exhaust: bank 1: activation,6.543, %
IDE03806-ENG188621,Oxygen sensor bank 1 sensor 1: status-Bits 0-7,1,
IDE03807-ENG188621,O2 Sensor B1-S2: Status-Bits 0-7,2,
IDE03818-ENG99405,Heated oxygen sensor bank 1: sensor 2: resistance-R uw q2 UWORD Chann 120,326.000, Ohm
IDE03818-ENG127296,Heated oxygen sensor bank 1: sensor 2: resistance-Test_Program_Bitregister,1,
IDE03932,Charge pressure actuator: specified position,80.00, %
IDE03934,Charge pressure actuator: adaptation for lower stop,950.0, mV
IDE03951-ENG114937,Intake manifold pressure adjustment recovery conditions-Bhedp sr,0,
IDE03953,Oxygen control: adaptation value at partial load: bank 1,1.00000,
IDE04000,Intake air temperature sensor,IAT 11:29 °C / IAT 12:32 °C,
IDE04002,Charge air pressure control,BP_A act:98.9, kPa
IDE04010,Engine torque: normalized,7.0, %
IDE04011,Nominal torque,280, Nm
IDE04016,Fuel Pressure Regulation,FRP CMD:---/--- kPa / FRP ACT:16840/--- kPa,
IDE04045,Exhaust gas pressure,EP1:99.84, kPa
IDE04083,Coolant temperatures,ECT 1:47 °C / ECT 2:54 °C,
IDE04086,Turbocharger guide vane adjustment,VGT_A cmd/act:80.0/79.6 % / VGT_B cmd/act:---/--- %,
IDE04110,Additional inputs and outputs,GEAR_RCMD: N,
IDE04256,Temp sensor for engine coolant: unconditioned voltage,2349.0, mV
IDE04278,Bypass valve f high press turboch turbine inlet: target value,80.00, %
IDE04279,Bypass valve f high press turboch turbine inlet: actual value,79.99, %
IDE04301,Bypass valve for high press turboch turbine inlet: activation,-1.88, %
IDE04302-ENG188621,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,0,
IDE04302-ENG188621,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,7,
IDE04302-ENG188621,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,64,
IDE04303,Bypass valve for high press turboch turbine inlet: uncond volt,1460.8, mV
IDE04410,Intake manifold pressure: specified value,258.75, hPa
IDE04420,Secondary air system activation,Atmosphere/off,
IDE04604,Accelerator pedal travel,0.00, %
IDE04651,Torque request: A/C compressor,0.0, Nm
IDE04670,Crankshaft signal evaluation: status,EPMHCRS_GAPFOUND,
IDE04670-ENG127292,Crankshaft signal evaluation: status-Test_Program_Epm H Cr S st Sig Mode State t UBYTE,8,
IDE04693,Increasing desired torque intervention of ESP,-55324.8, Nm
IDE04695-ENG137752,Immobilizer snapshot A-Sia Error Snap,00 00 00,
IDE04696-ENG137752,Immobilizer snapshot B-Sia Error Snap,00 00 00,
IDE04820,Fuel content due to degassing of engine oil,0.00, %
IDE04887,Powertrain target torque,19.0, Nm
IDE04889,Target torque for combustion engine crankshaft level,5.6, Nm
IDE04937,Sensor for engine block temperature: raw value,47.6, °C
IDE05135,Status of compressor release,False result,
IDE05135-ENG127289,Status of compressor release-Test_Program_B TRUE UBYTE,0,
IDE05138,Shut-off timer: last engine shut-off time,88397, s
IDE05213,Activation pulse duty factor for tank vent valve for diag,0.000, %
IDE05214,EVAP valve diagnosis ratio of pressure difference,0.00,
IDE05215,EVAP valve diagnosis result correlation factor,0.00,
IDE05240-ENG188621,Request for A/C compressor power reduction-Bits 0-7,0,
IDE05241-ENG188621,A/C compressor release status-Bits 0-7,1,
IDE05332-ENG188621,Heat request from heater to thermal management-Bits 0-7,3,
IDE05436,Engine operating condition,Idle,
IDE05436-ENG127326,Engine operating condition-Test_Program_Channel 87,5,
IDE05442,Roadway slope angle acceleration interface: calculated,0.0125, rad
IDE05444,Air filling: specified value,17.37, %
IDE05449,O2 sensor 2: B1: internal resistance limit,8400, Ohm
IDE05462,Oxy sensor 1 bank 1 char curve offset,0.00000,
IDE05474,Main cat converter OSC age correction factor,0.79688,
IDE05479,Misfire recognition reference moment,5.424, %
IDE05482,Tank venting adaptation factor,0.178,
IDE05484,Servo pump desired actual torque for idle control,0.0, Nm
IDE05485-ENG188621,Irregular shutdown of the counter control mod-Bits 0-7,0,
IDE05486,Current system status,SYC_DRIVE,
IDE05486-ENG127293,Current system status-Test_Program_Exe Con State 02 UBYTE,4,
IDE05497,Adaptation value of the charge pressure control,0.00, hPa
IDE05512,Adaptation val cyl 1 with fast diagnosis,1.00000,
IDE05513,Adaptation val cyl 3 with fast diagnosis,1.00000,
IDE05514,Adaptation val cyl 4 with fast diagnosis,1.00000,
IDE05515,Adaptation val cyl 2 with fast diagnosis,1.00000,
IDE05593,Secondary air injection sensor 1,983.13, hPa
IDE05622,Status of tank leak diagnosis with electrical diagnostic pump,34,
IDE05928,Fuel consumption since DTC memory last erased,99.998, l/100km
IDE05941-ENG112665,Enable condition: camshaft control-Bnws,1,
IDE05950,Charge pressure control adaptation value 1,-16.875, hPa
IDE05951,Charge pressure control adaptation value 2,0, hPa
IDE05952,Charge pressure control adaptation value 3,0, hPa
IDE06014,Charge pressure control adaptation value 0,-61.875, hPa
IDE06020,Intake air temperature in intake manifold bank raw value,32.3, °C
IDE06021,Intake air temperature before throttle valve: raw value,29.5, °C
IDE06039,Required RPM at idle speed,835.0, /min
IDE06040,High fuel pressure: regulator output value,-0.0680, MPa
IDE06041-ENG188621,PDTC drive cycle conditions status-Bits 0-7,36,
IDE06043,Cylinder head temperature: actual value,47.9, °C
IDE06045-ENG188621,Output diagnostic test status-Bits 0-7,0,
IDE06049,Pressure in brake booster: raw value,39, hPa
IDE06198-ENG188621,Tank vent valve: diagnostic status-Bits 0-7,32,
IDE06255,Vehicle lateral acceleration,0.00, g
IDE06256,Vehicle lateral acceleration: raw value,0.00, g
IDE06307,Stop prevention history data,|Year,Month
IDE06308,Start request history data,|Year,Month
IDE06435,A/C compressor: refrigerant pressure,51000, hPa
IDE06445,Longitudinal acceleration: raw value,0.125, m/s²
IDE06567,Frequency counter deactivate start/stop function,50,
IDE06568,Stop prevention by driver frequency counter,164,
IDE06569,Frequency counter vehicle standstill,314,
IDE06570,Oil level and oil temp. sensor: oil temperature in oil pan,30.2, °C
IDE06610,Frequency counter vehicle standstill with stop,25,
IDE06703-ENG188621,Drivetrain coordinator: ACC fault status-Bits 0-7,0,
IDE06705-ENG188621,Drivetrain coordinator: brake function status-Bits 0-7,0,
IDE06705-ENG188621,Drivetrain coordinator: brake function status-Bits 0-7,1,
IDE06706-ENG188621,ACC variants-Bits 0-7,2,
IDE06707-ENG188621,CCS Switch-Bits 0-7,2,
IDE06708-ENG188621,Cruise control switch actuation-Bits 0-7,32,
IDE06708-ENG188621,Cruise control switch actuation-Bits 0-7,1,
IDE06709-ENG188621,ACC variants (coding)-Bits 0-7,3,
IDE06710-ENG188621,Cruise control system: permanent deactivation-Bits 0-7,0,
IDE06711-ENG188621,Cruise control system: temporary deactivation-Bits 0-7,0,
IDE06758,Air mass since engine start,0.6709, kg
IDE06800,A/C main switch status,Correct result,
IDE06800-ENG127289,A/C main switch status-Test_Program_B TRUE UBYTE,1,
IDE06828,Coolant recirc. pump 2: spec. value,44.54, %
IDE06946-ENG188621,Brake actuated status-Bits 0-7,3,
IDE06956-ENG188621,Driver-side belt buckle status-Bits 0-7,2,
IDE07049,Gasoline tank pressure sensor: offset corrected,25.66, hPa
IDE07050-ENG188621,Starter control: release conditions-Bits 0-7,0,
IDE07050-ENG188621,Starter control: release conditions-Bits 0-7,92,
IDE07050-ENG188621,Starter control: release conditions-Bits 0-7,4,
IDE07051-ENG188621,Engaged gear: raw signal-Bits 0-7,0,
IDE07164,Number injections,5234,
IDE07224-ENG188621,Overrun cut-off-Bits 0-7,0,
IDE07238,Status of power transfer,0.00,
IDE07240-ENG188621,Status transition of engine control module sequencing-Bits 0-7,0,
IDE07257,Tank pressure from leakage diagnosis: calculated,0.000, hPa
IDE07548,Engine temp. mangmt. actuator: specified value of angle,0.00, %
IDE07549,Engine temp. mangmt. actuator: actual value of angle,0.16, %
IDE07550,Engine temp. management actuator: raw value,656.2, mV
IDE07571,Engine torque,5.6, Nm
IDE07620-ENG188621,Status momentary default during stability intervention-Bits 0-7,0,
IDE07693,Maximum supply pressure low-pressure fuel pump,0.0, kPa
IDE07697,System test status of fuel supply,32,
IDE07724,Coolant temperature at engine outlet: calculated,48.2, °C
IDE07796-ENG188621,Turboch. 1 turb.byp.v. 1 bank 1: pos.feedback -Breakaw.attempts-Bits 0-7,0,
IDE07904-ENG188621,Brake test switch status-Bits 0-7,1,
IDE07905-ENG188621,Brake light switch status-Bits 0-7,1,
IDE07906-ENG188621,Upper clutch switch: status-Bits 0-7,0,
IDE07908,Coolant fan activation requested by A/C,0.00, %
IDE08071-ENG188621,Remote start cancellation reason store 1-Bits 0-7,1,
IDE08072-ENG188621,Remote start cancellation reason store 2-Bits 0-7,1,
IDE08073-ENG188621,Remote start cancellation reason store 3-Bits 0-7,1,
IDE08074-ENG188621,Remote start cancellation reason store 4-Bits 0-7,0,
IDE08074-ENG188621,Remote start cancellation reason store 4-Bits 0-7,64,
IDE08075-ENG188621,Remote start cancellation reason store 5-Bits 0-7,0,
IDE08075-ENG188621,Remote start cancellation reason store 5-Bits 0-7,64,
IDE08353-ENG188621,Bypass valve turbocharger: adaptation status-Bits 0-7,0,
IDE08353-ENG188621,Bypass valve turbocharger: adaptation status-Bits 0-7,7,
IDE08353-ENG188621,Bypass valve turbocharger: adaptation status-Bits 0-7,64,
IDE09307-ENG188621,Pre-ignition counter cylinder 1-Bits 0-7,1,
IDE09307-ENG188621,Pre-ignition counter cylinder 1-Bits 0-7,0,
IDE09308-ENG188621,Pre-ignition counter cylinder 2-Bits 0-7,0,
IDE09308-ENG188621,Pre-ignition counter cylinder 2-Bits 0-7,4,
IDE09309-ENG188621,Pre-ignition counter cylinder 3-Bits 0-7,0,
IDE09309-ENG188621,Pre-ignition counter cylinder 3-Bits 0-7,7,
IDE09310-ENG188621,Pre-ignition counter cylinder 4-Bits 0-7,0,
IDE09310-ENG188621,Pre-ignition counter cylinder 4-Bits 0-7,1,
IDE09313-ENG188621,Pre-ignition counter over serv.life cylinder 1-Bits 0-7,0,
IDE09313-ENG188621,Pre-ignition counter over serv.life cylinder 1-Bits 0-7,1,
IDE09314-ENG188621,Pre-ignition counter over serv.life cylinder 2-Bits 0-7,4,
IDE09314-ENG188621,Pre-ignition counter over serv.life cylinder 2-Bits 0-7,0,
IDE09315-ENG188621,Pre-ignition counter over serv.life cylinder 3-Bits 0-7,7,
IDE09315-ENG188621,Pre-ignition counter over serv.life cylinder 3-Bits 0-7,0,
IDE09316-ENG188621,Pre-ignition counter over serv.life cylinder 4-Bits 0-7,0,
IDE09316-ENG188621,Pre-ignition counter over serv.life cylinder 4-Bits 0-7,1,
IDE09319-ENG188621,Pre-ignition action counter injection cut-off-Bits 0-7,0,
IDE09320-ENG188621,Pre-ignition action counter fill level limit-Bits 0-7,2,
IDE09529,Fuel mass flow rate due to degassing of eng. oil,0.0, mg/s
IDE09531,Total mass of gasoline and alcohol in oil,0.51, g
IDE09574,O2 sens. dwnstrm. of cat.: gradient transf. rich -> lean,0.00, s
IDE09880,O2 sens. 1 bank 1 upstrm oxi cat: raw value,0.9949,
IDE09925-ENG188621,Intake camshaft bank 1: adaption error cause-Bits 0-7,0,
IDE09926-ENG188621,Outlet camshaft bank 1: adaption error cause-Bits 0-7,0,
IDE09927,Intake camshaft bank 1: adaption hardware offset active,False result,
IDE09927-ENG127289,Intake camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,0,
IDE09928,Outlet camshaft bank 1: adaption hardware offset active,False result,
IDE09928-ENG127289,Outlet camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,0,
IDE09929,Intake camshaft bank 1: adaption value hardware offset active,1.74, °
IDE09930,Outlet camshaft bank 1: adaption value hardware offset active,1.69, °
IDE09931,Outlet camshaft bank 1: adaption value sensor tolerance,-2.37, °
IDE09932,Intake camshaft B1: adaptation value sensor tolerance,-2.02, °
IDE10042,Outlet camshaft bank 1 status adaption,EPMCAS_STFULLADAP,
IDE10042-ENG127372,Outlet camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
IDE10043,intake camshaft bank 1 status adaption,EPMCAS_STFULLADAP,
IDE10043-ENG127372,intake camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
IDE10063-MAS00666,Engine oil level: current value-Warning,0,
IDE10063-MAS00900,Engine oil level: current value-Oil level,0.0, %
IDE10063-MAS09802,Engine oil level: current value-Odometer reading at entry,0, km
IDE10063-MAS09803,Engine oil level: current value-Odometer reading when determining oil level,0, km
IDE10063-MAS09807,Engine oil level: current value-Qualification,0,
IDE10063-ENG137751,Engine oil level: current value-OilLvlDisp_stTstPrcd_VW,0,
IDE10064-MAS00666,Engine oil level: history 1-Warning,0,
IDE10064-MAS00900,Engine oil level: history 1-Oil level,0.0, %
IDE10064-MAS09802,Engine oil level: history 1-Odometer reading at entry,0, km
IDE10064-MAS09803,Engine oil level: history 1-Odometer reading when determining oil level,0, km
IDE10064-MAS09807,Engine oil level: history 1-Qualification,0,
IDE10064-ENG137751,Engine oil level: history 1-OilLvlDisp_stTstPrcd_VW,0,
IDE10065-MAS00666,Engine oil level: history 2-Warning,0,
IDE10065-MAS00900,Engine oil level: history 2-Oil level,0.0, %
IDE10065-MAS09802,Engine oil level: history 2-Odometer reading at entry,0, km
IDE10065-MAS09803,Engine oil level: history 2-Odometer reading when determining oil level,0, km
IDE10065-MAS09807,Engine oil level: history 2-Qualification,0,
IDE10065-ENG137751,Engine oil level: history 2-OilLvlDisp_stTstPrcd_VW,0,
IDE10066-MAS00666,Engine oil level: history 3-Warning,0,
IDE10066-MAS00900,Engine oil level: history 3-Oil level,0.0, %
IDE10066-MAS09802,Engine oil level: history 3-Odometer reading at entry,0, km
IDE10066-MAS09803,Engine oil level: history 3-Odometer reading when determining oil level,0, km
IDE10066-MAS09807,Engine oil level: history 3-Qualification,0,
IDE10066-ENG137751,Engine oil level: history 3-OilLvlDisp_stTstPrcd_VW,0,
IDE10067-MAS00666,Engine oil level: history 4-Warning,0,
IDE10067-MAS00900,Engine oil level: history 4-Oil level,0.0, %
IDE10067-MAS09802,Engine oil level: history 4-Odometer reading at entry,0, km
IDE10067-MAS09803,Engine oil level: history 4-Odometer reading when determining oil level,0, km
IDE10067-MAS09807,Engine oil level: history 4-Qualification,0,
IDE10067-ENG137751,Engine oil level: history 4-OilLvlDisp_stTstPrcd_VW,0,
IDE10068-MAS00666,Engine oil level: history 5-Warning,0,
IDE10068-MAS00900,Engine oil level: history 5-Oil level,0.0, %
IDE10068-MAS09802,Engine oil level: history 5-Odometer reading at entry,0, km
IDE10068-MAS09803,Engine oil level: history 5-Odometer reading when determining oil level,0, km
IDE10068-MAS09807,Engine oil level: history 5-Qualification,0,
IDE10068-ENG137751,Engine oil level: history 5-OilLvlDisp_stTstPrcd_VW,0,
IDE10069-MAS00666,Engine oil level: history 6-Warning,0,
IDE10069-MAS00900,Engine oil level: history 6-Oil level,0.0, %
IDE10069-MAS09802,Engine oil level: history 6-Odometer reading at entry,0, km
IDE10069-MAS09803,Engine oil level: history 6-Odometer reading when determining oil level,0, km
IDE10069-MAS09807,Engine oil level: history 6-Qualification,0,
IDE10069-ENG137751,Engine oil level: history 6-OilLvlDisp_stTstPrcd_VW,0,
IDE10070-MAS00666,Engine oil level: history 7-Warning,0,
IDE10070-MAS00900,Engine oil level: history 7-Oil level,0.0, %
IDE10070-MAS09802,Engine oil level: history 7-Odometer reading at entry,0, km
IDE10070-MAS09803,Engine oil level: history 7-Odometer reading when determining oil level,0, km
IDE10070-MAS09807,Engine oil level: history 7-Qualification,0,
IDE10070-ENG137751,Engine oil level: history 7-OilLvlDisp_stTstPrcd_VW,0,
IDE10071-MAS00666,Engine oil level: history 8-Warning,0,
IDE10071-MAS00900,Engine oil level: history 8-Oil level,0.0, %
IDE10071-MAS09802,Engine oil level: history 8-Odometer reading at entry,0, km
IDE10071-MAS09803,Engine oil level: history 8-Odometer reading when determining oil level,0, km
IDE10071-MAS09807,Engine oil level: history 8-Qualification,0,
IDE10071-ENG137751,Engine oil level: history 8-OilLvlDisp_stTstPrcd_VW,0,
IDE10072-MAS00666,Engine oil level: history 9-Warning,0,
IDE10072-MAS00900,Engine oil level: history 9-Oil level,0.0, %
IDE10072-MAS09802,Engine oil level: history 9-Odometer reading at entry,0, km
IDE10072-MAS09803,Engine oil level: history 9-Odometer reading when determining oil level,0, km
IDE10072-MAS09807,Engine oil level: history 9-Qualification,0,
IDE10072-ENG137751,Engine oil level: history 9-OilLvlDisp_stTstPrcd_VW,0,
IDE10302,Time since engine start,173.8, s
IDE10303,Integrated air masse at first engine start,0.6916, kg
IDE10580,Engine oil level: test method 1,99.4, %
IDE10581,Engine oil level: test method 2,87.3, %
IDE10582,Engine oil level: test method 3,0.0, %
IDE10633,Clutch protection function: reduced torque,3267.7, Nm
IDE10634,Clutch protection function: slip speed of the clutch,0.0, 1/min/s
IDE10641,Low fuel pressure adaptation value for EFP: modeled,120.0, kPa
IDE10670,O2 sensor befor CAT: filter time constant changeover rich -> lean,0.00, s
IDE10710-ENG125936,Exhaust warning light: triggering contr. module-Blinking_MIL_due_to_misfire_is_causing_catalyst_damage,No,
IDE10710-ENG130107,Exhaust warning light: triggering contr. module-MIL Request from Transmission Control Module,No,
IDE10710-ENG125937,Exhaust warning light: triggering contr. module-MIL_request_register_ident,0,
IDE10710-ENG130099,Exhaust warning light: triggering contr. module-MIL-Request from All Wheel Drive Control Module,No,
IDE10710-ENG130102,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module,No,
IDE10710-ENG137566,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module 48V,No,
IDE10710-ENG130110,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module,No,
IDE10710-ENG130100,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module 2,No,
IDE10710-ENG130103,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module,No,
IDE10710-ENG130109,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 2,No,
IDE10710-ENG137567,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 48V,No,
IDE10710-ENG130105,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module,No,
IDE10710-ENG130106,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module 2,No,
IDE10710-ENG130111,Exhaust warning light: triggering contr. module-MIL-Request from HVAC Control Module,No,
IDE10710-ENG130108,Exhaust warning light: triggering contr. module-MIL-Request from Transmission Control Module 2,No,
IDE10732,Engine oil level: factor volume,46, ml/mm
IDE10970-MAS11563,Number of prevented stop processes-hood open,0,
IDE10970-MAS11835,Number of prevented stop processes-Function locked due to frequent stalling,0,
IDE10970-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,0,
IDE10989,Immobilizer: historic data,|Year,Month
IDE10994,Poor start counter at start-stop,0,
IDE11115,Start/stop driver request: counter restart by starter,1,
IDE11116,Start/stop driver request: counter internal-motor restart,1,
IDE11203,Oil pressure setpoint,238.3, kPa
IDE11267,Oil level: max. value: relative,-3276.8, %
IDE11268,Oil level: min. value: relative,3276.7, %
IDE11293,Fuel consumption difference: injectors/sensors,0.000, l
IDE11294,Fuel level difference: fuel level sensor vs. actual consumption,0.066, l
IDE11302-ENG188621,Engine oil level: test method 1 qualification-Bits 0-7,1,
IDE11303-ENG188621,Engine oil level: test method 3 qualification-Bits 0-7,0,
IDE11329-ENG188621,Oil press. sensor: raw value-Bits 0-7,186,
IDE11329-ENG188621,Oil press. sensor: raw value-Bits 0-7,2,
IDE11330,Oil press. control valve: activation pulse duty factor,44.06, %
IDE11331-MAS03057,Torque reduction: clutch protection history 1-Kilometers,0, km
IDE11331-MAS10499,Torque reduction: clutch protection history 1-Torque,0, Nm
IDE11332-MAS03057,Torque reduction: clutch protection history 2-Kilometers,0, km
IDE11332-MAS10499,Torque reduction: clutch protection history 2-Torque,0, Nm
IDE11333-MAS03057,Torque reduction: clutch protection history 3-Kilometers,0, km
IDE11333-MAS10499,Torque reduction: clutch protection history 3-Torque,0, Nm
IDE11334-MAS03057,Torque reduction: clutch protection history 4-Kilometers,0, km
IDE11334-MAS10499,Torque reduction: clutch protection history 4-Torque,0, Nm
IDE11335-MAS03057,Torque reduction: clutch protection history 5-Kilometers,0, km
IDE11335-MAS10499,Torque reduction: clutch protection history 5-Torque,0, Nm
IDE11336-MAS03057,Torque reduction: clutch protection history 6-Kilometers,0, km
IDE11336-MAS10499,Torque reduction: clutch protection history 6-Torque,0, Nm
IDE11337-MAS03057,Torque reduction: clutch protection history 7-Kilometers,0, km
IDE11337-MAS10499,Torque reduction: clutch protection history 7-Torque,0, Nm
IDE11338-MAS03057,Torque reduction: clutch protection history 8-Kilometers,0, km
IDE11338-MAS10499,Torque reduction: clutch protection history 8-Torque,0, Nm
IDE11339-MAS03057,Torque reduction: clutch protection history 9-Kilometers,0, km
IDE11339-MAS10499,Torque reduction: clutch protection history 9-Torque,0, Nm
IDE11340-MAS03057,Torque reduction: clutch protection history 10-Kilometers,0, km
IDE11340-MAS10499,Torque reduction: clutch protection history 10-Torque,0, Nm
IDE11372,Camshaft angle adaptation: inlet deviation,0.000, °
IDE11523,State of shut-off valve to the gasoline pressure tank,false,
IDE11523-ENG127289,State of shut-off valve to the gasoline pressure tank-Test_Program_B TRUE UBYTE,0,
IDE11929,I share of PID control of fully variable oil pump,-6.18, %
IDE11931,Heated oxygen sensor bank 1 sensor 1: positioning intervention rear cat controller,0.00006,
IDE12044-ENG188621,Crankshaft Position adapt.: write attempt counter-Bits 0-7,1,
IDE12074-ENG188621,Position adapt. of intake camshaft bank 1: counter-Bits 0-7,1,
IDE12077-ENG188621,Position adapt. of outlet camshaft bank 1: counter-Bits 0-7,1,
IDE12078-ENG188621,Position adapt. of camshafts cyl: individual bank 1: counter-Bits 0-7,1,
IDE12105,Temperature sensor for cylinder block: uncond. voltage value,2007.2, mV
IDE12106,Temperature sensor for cylinder block,56.3, °C
IDE12197,High-pressure fuel injection valve adapted value: cylinder 1,9.72, %
IDE12199,High-pressure fuel injection valve adapted value: cylinder 2,3.08, %
IDE12200,High-pressure fuel injection valve adapted value: cylinder 3,-1.82, %
IDE12201,High-pressure fuel injection valve adapted value: cylinder 4,-9.88, %
IDE12355,ESI: consumption equivalent of the engine control module,0.00000034,
IDE12460,Low pressure procedure: pressure regulation valve open,0.00, kPa
IDE12461,Pressure regulator valve pulse duty factor,0.00, %
IDE12462,Pressure regulator valve opening pressure,0.0, kPa
IDE12463,Pressure regulator valve minimum pulse duty factor,False result,
IDE12463-ENG127289,Pressure regulator valve minimum pulse duty factor-Test_Program_B TRUE UBYTE,0,
IDE12464,Rail pressure at end of test,0.000, MPa
IDE12468-ENG188621,Login counter of the simulation interface-Bits 0-7,0,
IDE12748,Oil level: amount added MIN to MAX,1000, ml
IDE13301,Drivetrain coordinator: brake fault status,0,
IDE13336,Drive train coordinator reversible switch off conditions,2048,
IDE13337,Drive train coordinator irreversible switch off conditions,0,
IDE13945,Mixture variations without lambda controller interference,0.00000,
IDE14152,Oil level: maximum value: compensated,21.980, mm
IDE14153,Oil level: minimum value: compensated,35.352, mm
IDE14534,Knock control: error status,2147614720,
IDE15129,Camshaft angle correction outlet: based on ambient air pressure,0.000, °
IDE15270-ENG188621,Crankcase ventilation disk separator: target speed-Bits 0-7,26,
IDE15271-ENG188621,Crankcase ventilation disk separator: actual speed-Bits 0-7,25,
IDE15272,Crankcase ventilation disk separator: supply voltage,12.5, V
IDE15273,Crankcase ventilation disk separator: current consumption,25.6, A
IDE16075,Engine oil: calculated water quantity,0.00, g
IDE16246,Heated Oxygen Sensor: leakage current,-0.00003253, A
IDE16582,Inlet camshaft: pressure-based adaptation status,0,
IDE16583,Exhaust camshaft: pressure-based adaptation status,0,
IDE16593,Camshaft adaptation: pressure-based: inlet and outlet side,0,
MAS15845,Fuel: tank fill level,36.0, l
MAS15866,High pressure buildup gradient during pressure limitation valve opening test,0.000, MPa/revolution
MAS15883,Maximum fuel high-pressure with extended value range,0.000, MPa
MAS16066,Exhaust gas temperature at the probe before PreCat bank 1: model value,248.8, °C
MAS16222,Heated oxygen sensor bank 1 probe 1: status 2G,Correct result,
MAS16222-ENG127289,Heated oxygen sensor bank 1 probe 1: status 2G-Test_Program_B TRUE UBYTE,1,
MAS16223,Heated oxygen sensor bank 1 probe 2: status 2G,Correct result,
MAS16223-ENG127289,Heated oxygen sensor bank 1 probe 2: status 2G-Test_Program_B TRUE UBYTE,1,
MAS16287,High pressure buildup process with engine of: extended range,0.000, MPa/s
MAS16299,Heated oxygen sensor 1 probe 1: status dew point end,Correct result,
MAS16299-ENG127289,Heated oxygen sensor 1 probe 1: status dew point end-Test_Program_B TRUE UBYTE,1,
MAS16300,Heated oxygen sensor 1 probe 2: status dew point end,Correct result,
MAS16300-ENG127289,Heated oxygen sensor 1 probe 2: status dew point end-Test_Program_B TRUE UBYTE,1,
MAS16534-ENG188621,A/C compressor info: switch-off status-Bits 0-7,0,
MAS16534-ENG188621,A/C compressor info: switch-off status-Bits 0-7,2,
MAS16688,Throttle 1: bank 1: diagnostic value normed: leak detection,0.0264,
MAS17030,Engine control module hardware timer: self-diagnosis status,1,
MAS17060,Characteristics cooling module 1: end stage activation,0.00, %
MAS17189,Exhaust pressure sensor 1: raw value,996.7, hPa
MAS17191,Characteristics cooling module: target position,0.00, %
MAS17192,Characteristics cooling module: upper mechanical stop,4509.4, mV
MAS17193,Characteristics cooling module: lower mechanical stop,487.6, mV
ENG252358,Active Powertrain Warm-up Features Off-cycle Credit Vehicle Data,|Active Engine Warm-up Timer (Recent),Active Engine Warm-up Timer (Lifetime)
ENG119898,Actual_section_of_standard_test,0,
ENG105310,Batt U u Raw,2240.4, mV
ENG112670-ENG112664,Brake_booster_start_request_combustion_engine-Bbkvs ta,0,
ENG101413,Calibration Identification,05E013C 1936EXAK,
ENG99697,Calibration Verification Number,8C 88 00 10,
ENG252361,Certification Test Group/Engine Family Number,|Certification Test Group/Engine Family Number|NVGAV01.5V3|Q|,
ENG126402-ENG188621,Cruise_control_shutoff_conditions_irreversible-Bits 0-7,0,
ENG275645,Distance Traveled Since Evap Monitoring Decision,|Distance Traveled Since Evap Monitoring Decision|511|65280|, km
ENG168741,DTEV r p In Mnf Mes Estim,0.00,
ENG100152-ENG104003,ECUNAME-ECU,ECM,
ENG100152,ECUNAME,EngineControl,
ENG247045,Engine Exhaust Flow Rate,9.0, kg/h
ENG151174,Engine Friction - Percent Torque,5.0, %
ENG157850,Evap_purge_system_bank_1_cross_correlation_maximum_engine_load_gradient,0.00, hPa
ENG157851,Evap_purge_system_bank_1_cross_correlation_maximum_engine_speed_gradient,0.0, /min
ENG157852,Evap_purge_system_bank_1_cross_correlation_measured_mean_amplitude,0.0, hPa
ENG247046-ENG186450,Fuel Rate-Engine Fuel Rate,0.16, g/s
ENG247046-ENG247209,Fuel Rate-Vehicle Fuel Rate,0.16, g/s
ENG111608,Fuel_consumption_actual_driving_cycle,0.07, l
ENG100634,In-use Per Tr: 16 or 20 cou sec O2 Sens Mon Com Enc Cou B 2,00 07 00 5C 00 05 00 07 00 00 00 00 00 04 00 07 00 00 00 00 00 08 00 07 00 16 00 03 00 01 00 01 00 02 00 07 00 00 00 00 00 04 00 07 00 00 00 00 00 00 00 00 00 00 00 00,
ENG127734,Life_cycle_data_start_requirement_development,|Year,Month
ENG127735,Life_cycle_data_stop_prohibition_development,|Year,Month
ENG127733,Life_cycle_data_system_failure,|Year,Month
ENG276460-ENG188621,Mo CEMM Adr-Bits 0-7,0,
ENG276461-ENG188621,Mo XEMM Rst Idn-Bits 0-7,0,
ENG276461-ENG188621,Mo XEMM Rst Idn-Bits 0-7,15,
ENG158050-ENG188621,Mo XEMM st EMM Alrms Idx0-Bits 0-7,0,
ENG158051-ENG188621,Mo XEMM st EMM Alrms Idx1-Bits 0-7,0,
ENG289647-ENG188621,Mo XEMM st EMM Alrms Idx10-Bits 0-7,0,
ENG289648-ENG188621,Mo XEMM st EMM Alrms Idx11-Bits 0-7,0,
ENG158052-ENG188621,Mo XEMM st EMM Alrms Idx2-Bits 0-7,0,
ENG289649-ENG188621,Mo XEMM st EMM Alrms Idx20-Bits 0-7,0,
ENG289650-ENG188621,Mo XEMM st EMM Alrms Idx21-Bits 0-7,0,
ENG186217-ENG188621,Mo XEMM st EMM Alrms Idx3-Bits 0-7,0,
ENG276463-ENG188621,Mo XEMM st EMM Alrms Idx6-Bits 0-7,0,
ENG289651-ENG188621,Mo XEMM st EMM Alrms Idx7-Bits 0-7,0,
ENG289652-ENG188621,Mo XEMM st EMM Alrms Idx8-Bits 0-7,0,
ENG289653-ENG188621,Mo XEMM st EMM Alrms Idx9-Bits 0-7,0,
ENG289654-ENG188621,Mo XEMM st EMM Hw LT-Bits 0-7,0,
ENG252416,Run Time for Stop-Start and Coasting Off-cycle Credit Vehicle Data,|Idle Stop-Start Timer (Recent),Idle Stop-Start Timer (Lifetime)
ENG139760,Thr Vlv u Sens1 B1,0.574, V
ENG139761,Thr Vlv u Sens2 B1,4.412, V
ENG247047-ENG247196,Transmission Actual Gear-Transmission Actual Gear Ratio,0.000,
ENG247047-ENG247180,Transmission Actual Gear-Transmission Actual Gear Ratio Supported,Not available,
ENG247047-ENG247177,Transmission Actual Gear-Transmission Actual Gear Status,NEUT,
ENG247047-ENG247188,Transmission Actual Gear-Transmission Actual Gear Status Supported,available.,
ENG247048,Vehicle Odometer,156.3, km
ENG252424,Vehicle Operation Data - Distance/Fuel Used,|Total Distance Traveled (Recent),Total Distance Traveled (Lifetime)
ENG252425,Vehicle Operation Data - Engine Run/Idle Time,|Ignition Counter (Recent),Ignition Counter (Lifetime)
ENG252426,Vehicle Operation Data - PKE/EOE,|Positive Kinetic Energy (Recent),Positive Kinetic Energy (Lifetime)
ENG252427,Vehicle Operation Data - PSA,|Total Propulsion System Active Time (Recent),Total Propulsion System Active Time (Lifetime)
ENG158334,Virtual_SigXSet_SyC_tiPostDrv,0, s
ENG158335,Virtual_SigXSet_TiEngOff_tiDiagRef,487, s
ENG158336,Virtual_SigXSet_TiEngOff_tiStopCnt_Dif,88291, s
ENG158337,Virtual_SigXSet_TiEngOff_tiStopCnt_Raw,8300316, s
ENG158338,Virtual_SigXSet_TiOff_tiStrtEnd_Off,22100, s
Elapsed Time: 00:52,,,
blockmap-01-05E-906-013-C_3VV2X7B28NM061887-20220618-1242.CSV
;Saturday,18,June,2022,12:42:58:14741
IDE00021,Engine RPM,830, /min
IDE00025,Coolant temperature,88, °C
IDE00078,Time since engine start,840, s
IDE00083,Throttle valve position (absolute),11.0, %
IDE00084,Absolute load value,16, %
IDE00085,Normed load value,21.6, %
IDE00100,Engine torque,18.7, Nm
IDE00102,Control Module temperature,46.7, °C
IDE00148,Mean injection time,0.6596, ms
IDE00151,Oil fill level,54.620, mm
IDE00167,Exhaust temperature 1 bank 1,436.7, °C
IDE00174,Camshaft adjustment: exhaust: bank 1: specified value,-23.91, °
IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,-24.44, °
IDE00179,Camshaft adjustment intake bank 1: actual value,21.97, °
IDE00182,Camshaft adaptation intake bank 1: phase position,0.07, °
IDE00184,Camshaft adaptation exhaust bank 1: phase position,0.57, °
IDE00188,Fuel high-pressure: actual value,16.940, MPa
IDE00190,Charge air pressure: specified value,256.02, hPa
IDE00191,Charge air pressure: actual value,991.25, hPa
IDE00192,Coolant temperature at radiator outlet: actual value,33.3, °C
IDE00196,Engine oil temperature,71.5, °C
IDE00201,High fuel pressure: specified value,16.954, MPa
IDE00304,Fuel level,35.00, l
IDE00349,Throttle valve position: normed,0.8, %
IDE00350,Air mass: specified value,7.5, kg/h
IDE00357,Fuel temperature,62.3, °C
IDE00371,Fuel consumption,0.69, l/h
IDE00392,Accelerator pedal: sensor voltage 1,721.4, mV
IDE00393,Accelerator pedal: sensor voltage 2,360.0, mV
IDE00394,Camshaft position: start of phase window,39.99, °
IDE00405,Crankshaft speed (RPM),833.5, /min
IDE00406,Camshaft RPM,417.0, /min
IDE00477,Torque request: sum of auxiliary aggregate,5.1, Nm
IDE00554,Absolute vapor pressure in tank ventilation system,96785, kPa abs
IDE00556,Outside temperature,31, °C
IDE00559,Current of oxygen sensor bank 1 sensor 1 (broadband sensor),0.969 Lambda / -0.074 mA,
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,0.735, V
IDE00582,Specified value of equivalence ratio,0.970, Lambda
IDE00583,Throttle valve specified value,1.2, %
IDE00587,Vapor pressure in tank ventilation system,2937, Pa
IDE00593,Ignition timing adjustment cylinder 1,-2.5, Degrees
IDE00603,Number of driving cycles since erasing DTC memory,1,
IDE00612,Target position of EVAP canister valve,12.9, %
IDE00738,Oxygen sensor test: bank 1: delta lambda,0.00003,
IDE01378,Fuel high pressure: control deviation,0.0160, MPa
IDE01644,Oxygen sensor voltage B1 downstream CAT,0.740, V
IDE01834,Battery voltage,12640, mV
IDE01869,Long-term fuel trim bank 1 at idle,0.09, %
IDE01876,Adaptation of loss torque,-0.4, Nm
IDE01893,Fuel pump: specified value,52.242, %
IDE01899,Load value: corrected specified value,67.38, %
IDE01901,Lost torque adaptation: idle,-0.4, Nm
IDE01912,Oxygen sensor B1: sensor 1: specified value,0.9700,
IDE01928,Close cam shaft angle at quantity control valve,39.8, °
IDE01930,High pressure regulation: adaptation value,0.046, MPa
IDE01932,High pressure pump injection volume,-0.69, mm³
IDE02117,Relative load value,15.68, %
IDE02211,Brake pressure,2.55, MPa
IDE02742,Oil pressure actual value,236.3, kPa
IDE03377,Coolant temp at radiator output: unconditioned voltage,2999.8, mV
IDE03660,Longitudinal acceleration,0.121, m/s²
IDE03711,Mass flow through throttle valve,6.5, kg/h
IDE03818-ENG99405,Heated oxygen sensor bank 1: sensor 2: resistance-R uw q2 UWORD Chann 120,200.000, Ohm
IDE04000,Intake air temperature sensor,IAT 11:42 °C / IAT 12:39 °C,
IDE04002,Charge air pressure control,BP_A act:99.0, kPa
IDE04010,Engine torque: normalized,6.0, %
IDE04016,Fuel Pressure Regulation,FRP CMD:---/--- kPa / FRP ACT:16800/--- kPa,
IDE04045,Exhaust gas pressure,EP1:99.95, kPa
IDE04083,Coolant temperatures,ECT 1:88 °C / ECT 2:92 °C,
IDE04086,Turbocharger guide vane adjustment,VGT_A cmd/act:80.0/80.0 % / VGT_B cmd/act:---/--- %,
IDE04256,Temp sensor for engine coolant: unconditioned voltage,1012.0, mV
IDE04279,Bypass valve f high press turboch turbine inlet: actual value,79.98, %
IDE04301,Bypass valve for high press turboch turbine inlet: activation,-1.12, %
IDE04303,Bypass valve for high press turboch turbine inlet: uncond volt,1461.4, mV
IDE04410,Intake manifold pressure: specified value,255.63, hPa
IDE04693,Increasing desired torque intervention of ESP,-55392.8, Nm
IDE04887,Powertrain target torque,15.0, Nm
IDE04889,Target torque for combustion engine crankshaft level,6.0, Nm
IDE04937,Sensor for engine block temperature: raw value,88.6, °C
IDE05442,Roadway slope angle acceleration interface: calculated,0.0124, rad
IDE05444,Air filling: specified value,15.66, %
IDE05449,O2 sensor 2: B1: internal resistance limit,8570, Ohm
IDE05479,Misfire recognition reference moment,4.700, %
IDE05482,Tank venting adaptation factor,0.000,
IDE06020,Intake air temperature in intake manifold bank raw value,40.2, °C
IDE06021,Intake air temperature before throttle valve: raw value,42.2, °C
IDE06040,High fuel pressure: regulator output value,-0.0060, MPa
IDE06041-ENG188621,PDTC drive cycle conditions status-Bits 0-7,37,
IDE06043,Cylinder head temperature: actual value,88.7, °C
IDE06049,Pressure in brake booster: raw value,40, hPa
IDE06445,Longitudinal acceleration: raw value,0.094, m/s²
IDE06570,Oil level and oil temp. sensor: oil temperature in oil pan,72.4, °C
IDE06758,Air mass since engine start,2.7125, kg
IDE06828,Coolant recirc. pump 2: spec. value,65.79, %
IDE07049,Gasoline tank pressure sensor: offset corrected,29.64, hPa
IDE07164,Number injections,31698,
IDE07548,Engine temp. mangmt. actuator: specified value of angle,53.44, %
IDE07549,Engine temp. mangmt. actuator: actual value of angle,53.19, %
IDE07550,Engine temp. management actuator: raw value,2618.2, mV
IDE07571,Engine torque,7.3, Nm
IDE07724,Coolant temperature at engine outlet: calculated,88.8, °C
IDE09531,Total mass of gasoline and alcohol in oil,0.38, g
IDE09880,O2 sens. 1 bank 1 upstrm oxi cat: raw value,0.9929,
IDE09929,Intake camshaft bank 1: adaption value hardware offset active,1.27, °
IDE09930,Outlet camshaft bank 1: adaption value hardware offset active,1.19, °
IDE10302,Time since engine start,878.1, s
IDE10303,Integrated air masse at first engine start,2.7307, kg
IDE11294,Fuel level difference: fuel level sensor vs. actual consumption,0.250, l
IDE11329-ENG188621,Oil press. sensor: raw value-Bits 0-7,196,
IDE11330,Oil press. control valve: activation pulse duty factor,39.16, %
IDE11929,I share of PID control of fully variable oil pump,-7.76, %
IDE11931,Heated oxygen sensor bank 1 sensor 1: positioning intervention rear cat controller,0.00003,
IDE12105,Temperature sensor for cylinder block: uncond. voltage value,930.2, mV
IDE12106,Temperature sensor for cylinder block,92.6, °C
IDE12197,High-pressure fuel injection valve adapted value: cylinder 1,9.68, %
IDE12199,High-pressure fuel injection valve adapted value: cylinder 2,2.94, %
IDE12200,High-pressure fuel injection valve adapted value: cylinder 3,-1.84, %
IDE12201,High-pressure fuel injection valve adapted value: cylinder 4,-9.70, %
IDE12355,ESI: consumption equivalent of the engine control module,0.00000016,
IDE14152,Oil level: maximum value: compensated,21.976, mm
IDE14153,Oil level: minimum value: compensated,36.864, mm
IDE15271-ENG188621,Crankcase ventilation disk separator: actual speed-Bits 0-7,26,
IDE15273,Crankcase ventilation disk separator: current consumption,25.4, A
MAS15845,Fuel: tank fill level,35.8, l
MAS16066,Exhaust gas temperature at the probe before PreCat bank 1: model value,323.5, °C
MAS16688,Throttle 1: bank 1: diagnostic value normed: leak detection,-0.0322,
MAS17189,Exhaust pressure sensor 1: raw value,998.9, hPa
MAS17191,Characteristics cooling module: target position,53.44, %
ENG105310,Batt U u Raw,2239.2, mV
ENG247045,Engine Exhaust Flow Rate,8.0, kg/h
ENG151174,Engine Friction - Percent Torque,4.0, %
ENG247046-ENG186450,Fuel Rate-Engine Fuel Rate,0.14, g/s
ENG247046-ENG247209,Fuel Rate-Vehicle Fuel Rate,0.14, g/s
ENG111608,Fuel_consumption_actual_driving_cycle,0.25, l
ENG139760,Thr Vlv u Sens1 B1,0.569, V
Elapsed Time: 00:55,,,
blockmap-02-0GC-300-018-E_3VV2X7B28NM061887-20220618-1232.CSV
;SW:0GC-300-018-E   HW:0GC-927-711-H ---  Auto Trans
;Component:GSG DQ381     H06 2803, Coding:0014
;EV_TCMDQ381061,001001,EV_TCMDQ381061.rod
;Saturday,18,June,2022,12:32:13:14741
;VCID: AB08ECE613862903D60-80FE
IDE00018,Voltage terminal 15,12.7, V
IDE00019,Voltage terminal 30,12.4, V
IDE00021,Engine RPM,838, /min
IDE00022-ENG103074,Transmission input speed-Transmission Input Speed Sensor,836, /min
IDE00023,Transmission output speed,0, /min
IDE00024-ENG98981,ATF temperature-Transmission fluid temperature,30, °C
IDE00075-ENG99967,Vehicle speed-Vehicle Speed Sensor,0.00, km/h
IDE00086,Accelerator pedal position,0.0, %
IDE00091-ENG101172,Status of starter lock-Status Engine Starter Lock,Activating,
IDE00094,Kick-down status,OFF,
IDE00095-ENG101643,Status of selector lever lock-Status Shift Lock,not active,
IDE00096-ENG100569,Selector lever position-Shift Position,Position P Stop,
IDE00101-ENG103259,Engine specified torque during transmission intervention-Calculated engine preset torque,1042.0, Nm
IDE00102-ENG102028,Control Module temperature-Control modul temperature,29, °C
IDE00130-ENG103124,Transmission specified idle RPM-Idle Speed Commanded Value,0, /min
IDE00322-ENG100540,Status of basic setting-Basic Settings Status,0,
IDE00451-ENG103018,Currently running routine-Current Test Routine,0,
IDE00872-ENG102188,Current of main pressure valve-Oil Pressure Actual Current,1073.0, mA
IDE00970-ENG114816,Coolant fan activation: actual value-Radiator fan activation actual value,10.0, %
IDE00972,Idle speed increase,OFF,
IDE01588-ENG101855,Driving direction-M015 SvnNAbRichtung,not known,
IDE01716-ENG103234,Terminal 50 status-Status terminal 50,OFF,
IDE02211,Brake pressure,30.90, bar
IDE02221,Engine torque: qualification,valid,
IDE02713-ENG98471,Brake lamp switch-Brake Light Switch,operated,
IDE02714,Brake test switch,operated,
IDE02715-ENG103190,Validity of brake pressure-Brake Pressure State,valid,
IDE02716,Tiptronic source,via CAN,
IDE02717-ENG102076,Tiptronic upshift-Tiptronic Up,OFF,
IDE02718-ENG101063,Tiptronic downshift-Tiptronic Down,OFF,
IDE02719-ENG99606,Selector lever position made plausible-Shift Position Plausible,P,
IDE02720-ENG103810,Transmission input speed (RPM) shaft 1-Transmission Input Speed Shaft 1,0, /min
IDE02721-ENG100916,Transmission input speed (RPM) shaft 2-Transmission Input Speed Shaft 2,0, /min
IDE02722-ENG101964,Transmission output speed (RPM) shaft 1-Transmission Output Speed Shaft 1,0, /min
IDE02723-ENG100382,Transmission output speed (RPM) shaft 2-Transmission Output Speed Shaft 2,0, /min
IDE02724,Direction of rotation shaft 1,not known,
IDE02725,Direction of rotation shaft 2,not known,
IDE02726-ENG100799,E-Pump: power supply-Voltage Supply Electric Motor,12.4, V
IDE02727-ENG99192,Shift Lock Solenoid Specified Status-Shift Lock Desired State,not active,
IDE02728-ENG101668,Shift lock indicator lamp-Indicator Light Shift Lock,Indicator lamp off,
IDE02735-ENG100209,Display of driving mode in instrument panel-Display Driving Position,P,
IDE02736-ENG100252,Display of gear in instrument panel-Display Driving Gear,no gear engaged,
IDE02738-ENG100412,Selector lever illumination-Display Shift Lighting,P,
IDE02740-ENG99750,Temperature of friction lining for clutch 1-Temperatur_Friction_Lining_Clutch_1,29, °C
IDE02741-ENG102724,Temperature of friction lining for clutch 2-Temperatur_Friction_Lining_Clutch_2,29, °C
IDE02742,Oil pressure actual value,1.23, bar
IDE02775-ENG101304,Status of basic setting data-State Of Basic Adjustmentdata,valid,
IDE02776-ENG102757,Pressure of partial transmission 1 specified value-Pressure Transmission Part 1 Commanded Value,2.50, bar
IDE02777-ENG101539,Pressure of partial transmission 1 actual value-Pressure Transmission Part 1 Actual Value,1.23, bar
IDE02779-ENG100646,Pressure of partial transmission 2 specified value-Pressure Transmission Part 2 Commanded Value,2.50, bar
IDE02780-ENG103741,Pressure of partial transmission 2 actual value-Pressure Transmission Part 2 Actual Value,1.23, bar
IDE02782-ENG103418,Current of valve for partial transmission 1 specified value-Current Valve Transmission Part 1 Commanded Value,364.4, mA
IDE02783-ENG99260,Current of valve for partial transmission 1 actual value-Current Valve Transmission Part 1 Actual Value,364.0, mA
IDE02786-ENG101222,Current of valve for partial transmission 2 specified value-Current Valve Transmission Part 2 Commanded Value,372.7, mA
IDE02787-ENG101614,Current of valve for partial transmission 2 actual value-Current Valve Transmission Part 2 Actual Value,373.0, mA
IDE02790-ENG104124,Specified torque clutch 1-Clutch 1 Commanded Torque,-100.00, Nm
IDE02791-ENG101742,Actual torque clutch 1-Clutch 1 Actual Torque,-100.00, Nm
IDE02792-ENG101464,Specified position clutch 1-Clutch 1 Commanded Position,0.00, bar
IDE02793-ENG102450,Actual position clutch 1-Clutch 1 Actual Position,0.02, bar
IDE02796-ENG103463,Current of valve for clutch 1 specified value-Current Valve Clutch 1 Commanded Value,50.0, mA
IDE02797-ENG100730,Current of valve for clutch 1 actual value-Current Valve Clutch 1 Actual Value,50.0, mA
IDE02800-ENG100171,Specified torque clutch 2-Clutch 2 Commanded Torque,-100.00, Nm
IDE02802-ENG102780,Actual position clutch 2-Clutch 2 Actual Position,0.00, bar
IDE02805-ENG99237,Current of valve for clutch 2 specified value-Current Valve Clutch 2 Commanded Value,50.0, mA
IDE02806-ENG103118,Current of valve for clutch 2 actual value-Current Valve Clutch 2 Actual Value,51.0, mA
IDE02820,Transmission mileage,154.8, km
IDE02821-ENG101653,Pressure Supply Specified Pressure/Threshold 1-Pressure Supply Commanded Value Threshold 1,1.23, bar
IDE02823-ENG100173,Identification of selector lever-Identification Selector Lever,5QM713023D  0007,
IDE02824-ENG99279,Main status of abort code basic setting-Basic Settings Main Status,0,
IDE02825-ENG100313,Substatus of abort code basic setting-Basic Settings Sub Status,0,
IDE02827-ENG103491,Installation information steering wheel paddles-Application Info Steering Paddels,59,
IDE02828-ENG103640,Installation information brakes-Application Info Breaksystem,59,
IDE02829-ENG103127,Installation information steering column module-Application Info Steering Modul,59,
IDE02830-ENG100103,Installation information gateway-Application Info Gateway,59,
IDE02858-ENG100590,Status of basic setting data: gear selector-State Of Basic Adjustmentdata Gearpositioner,Valid basic calibration,
IDE02859-ENG99797,Status of basic setting data for clutch-State Of Basic Adjustmentdata Clutch,Valid EOL,
IDE02861-ENG103083,Mechatronic identification-Baudatum,220121,
IDE02861-ENG98675,Mechatronic identification-Construction version,N5,
IDE02861-ENG99175,Mechatronic identification-Kassel,K,
IDE02861-ENG104192,Mechatronic identification-Kennung der Mechatronik-Montagelinie,D15,
IDE02861-ENG103830,Mechatronic identification-Lfd.-Nr,6647,
IDE02861-ENG103525,Mechatronic identification-Teilenummer (3 letzten + Index),0GCE_,
IDE02862-ENG103213,Production data transmission-Aggregatekennzeichnung (Getriebe),006,
IDE02862-ENG103083,Production data transmission-Baudatum,220121,
IDE02862-ENG104019,Production data transmission-Getriebekennbuchstabe,UWQ,
IDE02862-ENG99175,Production data transmission-Kassel,K,
IDE02862-ENG101707,Production data transmission-Kennung der Montagelinie,D07,
IDE02862-ENG103830,Production data transmission-Lfd.-Nr,1486,
IDE02864-ENG99505,Actual position of gear positioner A-Gearpositioner A Actual Position,-10.23, mm
IDE02865-ENG104121,AD value 1 of actual position of gear actuator A-Gearpositioner A Actual Position AD Value 1,2932,
IDE02867-ENG103746,Specified current of gear Solen.val. A-Gearpositioner A Valve Commanded Current,0.0, mA
IDE02868-ENG102455,Actual current of gear Solen.val. A-Gearpositioner A Valve Actual Current,0.0, mA
IDE02872-ENG102218,Actual position of gear adjuster B-Gearpositioner B Actual Position,-0.02, mm
IDE02873-ENG101728,AD value 1 of actual position of gear actuator B-Gearpositioner B Actual Position AD Value 1,2035,
IDE02875-ENG101174,Specified current of gear Solen.val. B-Gearpositioner B Valve Commanded Current,0.0, mA
IDE02876-ENG99266,Actual current of gear Solen.val. B-Gearpositioner B Valve Actual Current,0.0, mA
IDE02880-ENG103036,Actual position of gear positioner C-Gearpositioner C Actual Position,-0.14, mm
IDE02881-ENG99453,AD value 1 of actual position of gear actuator C-Gearpositioner C Actual Position AD Value 1,2055,
IDE02883-ENG103740,Specified current of gear Solen.val. C-Gearpositioner C Valve Commanded Current,0.0, mA
IDE02884-ENG99821,Actual current of gear Solen.val. C-Gearpositioner C Valve Actual Current,0.0, mA
IDE02888-ENG103826,Actual position of gear positioner D-Gearpositioner D Actual Position,-9.45, mm
IDE02889-ENG100525,AD value 1 of actual position of gear actuator D-Gearpositioner D Actual Position AD Value 1,1171,
IDE02891-ENG101968,Specified current of gear Solen.val. D-Gearpositioner D Valve Commanded Current,812.0, mA
IDE02892-ENG99541,Actual current of gear Solen.val. D-Gearpositioner D Valve Actual Current,810.0, mA
IDE02989-ENG100843,Status of torque requirements on engine-State Of Torque Demand Engine,OFF,
IDE03107-ENG126246,Kilometers at last basic setting-Kilometer At Last Basic Adjustment,655350, km
IDE03152-ENG104154,Neutral due to driver registr. proced. cond.: cause-Driver Registration Procedure Condition Cause,00 00,
IDE03153-ENG102498,Driver logon procedure: number of activations-Driver Registration Procedure Activation Counter,3,
IDE03155-ENG99516,GE clutch data: Status-GE Clutch Data Status,Test stand data valid,
IDE03156-ENG102903,Last change to GE clutch data: odometer reading-Last Changing GE Clutch Data Km,655350, km
IDE03160-ENG100046,Remaining Clutch Quick Adaptations Kiss Point-Remaining Clutch Fastadaption Kisspoint,0,
IDE03163-ENG103608,Protect. function temp. clutch 1 warn. level 1 number-Protective Function Temperature Clutch 1 Warning 1 Numbers,0,
IDE03164-ENG101576,Protect. function temp. clutch 1 warn. level 2 number-Protective Function Temperature Clutch 1 Warning 2 Numbers,0,
IDE03165-ENG102133,Protective function temp. clutch 1 protect. level 1 number-Protective Function Temperature Clutch 1 Protection 1 Numbers,0,
IDE03167-ENG102425,Protect. function temp. clutch 2 warn. level 1 number-Protective Function Temperature Clutch 2 Warning 1 Numbers,0,
IDE03168-ENG100182,Protect. function temp. clutch 2 warn. level 2 number-Protective Function Temperature Clutch 2 Warning 2 Numbers,0,
IDE03169-ENG104175,Protective function temp. clutch 2 protect. level 1 number-Protective Function Temperature Clutch 2 Protection 1 Numbers,0,
IDE03171-ENG102987,Driving strategy transmission mileage-Q002 Total Driving Time,165.2, km
IDE03172-ENG100789,Driving Strategy Percentage Driving in D or S w/Cruise-Q003 Driving Time Ecological,87, %
IDE03173-ENG103567,Driving Strategy Percentage Driving in S w/o cruise-Q004 Driving Time Sporty,10, %
IDE03174-ENG100415,Driving strategy driving portions in Tiptronic-Q005 Driving Time Manual,3, %
IDE03180-ENG103176,Number of standard trips-General Denominator,7,
IDE03181-ENG102823,Number of ignition cycles-Ignition Cycle Counter,1,
IDE04612-ENG101246,Clutch temperature air / splash oil-Centrifugal oil temperature,0, °C
IDE05303-ENG99893,Actual torque clutch 2-Clutch 2 Actual Torque,-100.00, Nm
IDE05987-ENG110524,Engine stop prohibitions-Basic setting,not active,
IDE05987-ENG159578,Engine stop prohibitions-Demontagestellung,not active,
IDE05987-ENG159577,Engine stop prohibitions-Drucksensorausfall,not active,
IDE05987-ENG159579,Engine stop prohibitions-Eingeschränkte Fahrfunktion / Notlauf / Liegenbleiber,not active,
IDE05987-ENG110508,Engine stop prohibitions-km-Stand des letzten Stoppverbots,0.0, km
IDE05987-ENG159710,Engine stop prohibitions-Motorstoppverbote Anzahl Stoppverbote,0,
IDE05987-ENG110525,Engine stop prohibitions-Stop prohibition via application,not active,
IDE05987-ENG159576,Engine stop prohibitions-Temperaturbedingung,not active,
IDE05987-ENG122385,Engine stop prohibitions-unsortierte Gangsteller im Stand,not active,
IDE05988-ENG110505,Pressure of clutch 2: actual value-Clutch_2_actual_value,-0.01, bar
IDE05989-ENG110503,Pressure of clutch 1: actual value-Clutch_1_actual_value,0.02, bar
IDE05990-ENG110506,Pressure of clutch 2: specified value-Clutch_2_commanded_value,0.00, bar
IDE05991-ENG110504,Pressure of clutch 1: specified value-Clutch_1_commanded_value,0.00, bar
IDE06241-ENG120892,Uneven road surface recognition: total driving portion-Drivingpart_of_roug_road_detection_total,655.3, %
IDE06243-ENG120894,Longest active distance with uneven road surface recognition-Longest_active_mileage_of_rough_road_detection,65535, km
IDE06425,Dynamometer mode: functional,not activated,
IDE11135-ENG127823,Capacity protection function: clutch 2 number-Protective_Function_Capacity_Clutch_2_Numbers,0,
IDE11136-ENG127822,Capacity protection function: clutch 1 number-Protective_Function_Capacity_Clutch_1_Numbers,0,
IDE12712-ENG167245,Mileage at last initialization clutch friction coefficient model-Mileage of setting resetting gearbox mileage,0.0, km
IDE12713-ENG167207,Clutch friction coefficient model mileage-Gearbox mileage,154.8, km
IDE13738-ENG167750,Function test auxiliary hydraulic pump for transmission oil status-Abbruchgrund,Do not cancel,
IDE13738-ENG167870,Function test auxiliary hydraulic pump for transmission oil status-Hauptdruck,0.00, bar
IDE13738-ENG101241,Function test auxiliary hydraulic pump for transmission oil status-Speed,0, /min
IDE13947-ENG167877,Mileage since last activation: uneven road surface recognition-Kilometer_at_last_ activation_rough_road_detection,655340, km
IDE14615-MAS18568,Adapted loaded position: standardized (gear 1-R)-Adapted loaded position: standardized gear 1,-10.44, mm
IDE14615-MAS18569,Adapted loaded position: standardized (gear 1-R)-Adapted loaded position: standardized gear 2,-10.37, mm
IDE14615-MAS18570,Adapted loaded position: standardized (gear 1-R)-Adapted loaded position: standardized gear 3,10.73, mm
IDE14615-MAS18571,Adapted loaded position: standardized (gear 1-R)-Adapted loaded position: standardized gear 4,9.41, mm
IDE14615-MAS18572,Adapted loaded position: standardized (gear 1-R)-Adapted loaded position: standardized gear 5,9.07, mm
IDE14615-MAS18573,Adapted loaded position: standardized (gear 1-R)-Adapted loaded position: standardized gear 6,8.68, mm
IDE14615-MAS18574,Adapted loaded position: standardized (gear 1-R)-Adapted loaded position: standardized gear 7,-9.09, mm
IDE14615-MAS18575,Adapted loaded position: standardized (gear 1-R)-Adapted loaded position: standardized gear R,-9.70, mm
IDE14616-MAS18576,Adapted synchronized position: standardized (gear 1-R)-Adapted synchronized position: standardized gear 1,-3.03, mm
IDE14616-MAS18577,Adapted synchronized position: standardized (gear 1-R)-Adapted synchronized position: standardized gear 2,-2.31, mm
IDE14616-MAS18578,Adapted synchronized position: standardized (gear 1-R)-Adapted synchronized position: standardized gear 3,2.31, mm
IDE14616-MAS18579,Adapted synchronized position: standardized (gear 1-R)-Adapted synchronized position: standardized gear 4,1.88, mm
IDE14616-MAS18580,Adapted synchronized position: standardized (gear 1-R)-Adapted synchronized position: standardized gear 5,1.23, mm
IDE14616-MAS18581,Adapted synchronized position: standardized (gear 1-R)-Adapted synchronized position: standardized gear 6,1.69, mm
IDE14616-MAS18582,Adapted synchronized position: standardized (gear 1-R)-Adapted synchronized position: standardized gear 7,-1.40, mm
IDE14616-MAS18583,Adapted synchronized position: standardized (gear 1-R)-Adapted synchronized position: standardized gear R,-2.01, mm
IDE14617-MAS18584,Adapted neutral position: standardized (gear actuator A-D)-Adapted neutral position: standardized for gear actuator A,-0.55, mm
IDE14617-MAS18585,Adapted neutral position: standardized (gear actuator A-D)-Adapted neutral position: standardized for gear actuator B,-0.08, mm
IDE14617-MAS18586,Adapted neutral position: standardized (gear actuator A-D)-Adapted neutral position: standardized for gear actuator C,0.12, mm
IDE14617-MAS18587,Adapted neutral position: standardized (gear actuator A-D)-Adapted neutral position: standardized for gear actuator D,-0.16, mm
IDE80001-ENG100467,Analysis 1-Snapshot 1 Failure ID,65535,
IDE80002-ENG102386,Analysis 2-Snapshot 1 Mileage,0, km
IDE80003-ENG101467,Analysis 3-Snapshot 1 Counter,0,
IDE80004-ENG110548,Analysis 4-Snapshot 1 Oil Pressure Actual Value,-10.0, bar
IDE80005-ENG103330,Analysis 5-Snapshot 1 Shift Position Plausible,P,
IDE80006-ENG99650,Analysis 6-Snapshot 1 Main Status Vehicle Clutch Fahrzeugzustand,New,
IDE80006-ENG102000,Analysis 6-Snapshot 1 Main Status Vehicle Clutch Kupplungshauptzustand,New,
IDE80007-ENG101090,Analysis 7-Snapshot 1  Commanded Gear,GANG N,
IDE80008-ENG100048,Analysis 8-Snapshot 1 Preselection Gear,GANG N,
IDE80009-ENG102100,Analysis 9-Snapshot 1 Transmission Input Speed,0, /min
IDE80010-ENG101565,Analysis 10-Snapshot 1 Transmission Output Speed Shaft 1,0, /min
IDE80011-ENG100379,Analysis 11-Snapshot 1 Transmission Speed Shaft 1,0, /min
IDE80012-ENG103459,Analysis 12-Snapshot 1 Transmission Speed Shaft 2,0, /min
IDE80013-ENG99331,Analysis 13-Snapshot 1 Gearpositioner A Actual Value,-20.48, mm
IDE80014-ENG99512,Analysis 14-Snapshot 1 Gearpositioner B Actual Value,-20.48, mm
IDE80015-ENG100338,Analysis 15-Snapshot 1 Gearpositioner C Actual Value,-20.48, mm
IDE80016-ENG100656,Analysis 16-Snapshot 1 Gearpositioner D Actual Value,-20.48, mm
IDE80017-ENG99158,Analysis 17-Snapshot 1 Gearpositioner A Valve Actual Current,0, mA
IDE80018-ENG101917,Analysis 18-Snapshot 1 Gearpositioner B Valve Actual Current,0, mA
IDE80019-ENG102153,Analysis 19-Snapshot 1 Gearpositioner C Valve Actual Current,0, mA
IDE80020-ENG100002,Analysis 20-Snapshot 1 Gearpositioner D Valve Actual Current,0, mA
IDE80021-ENG102762,Analysis 21-Snapshot 1 Clutch 1 Actual Pressure,0.0, bar
IDE80022-ENG100347,Analysis 22-Snapshot 1 Clutch 2 Actual Pressure,0.0, bar
IDE80023-ENG99119,Analysis 23-Snapshot 1 Current Valve Clutch 1 Actual Value,0, mA
IDE80024-ENG101123,Analysis 24-Snapshot 1 Current Valve Clutch 2 Actual Value,0, mA
IDE80025-ENG103611,Analysis 25-Snapshot 1 Accelerator Pedal Position,0.0, %
IDE80026-ENG101503,Analysis 26-Snapshot 1 Engine torque,-50, Nm
IDE80027-ENG101521,Analysis 27-Snapshot 1 Current Valve Transmission Part 1 Actual Value,0, mA
IDE80028-ENG103949,Analysis 28-Snapshot 1 Current Valve Transmission Part 2 Actual Value,0, mA
IDE80029-ENG103070,Analysis 29-Snapshot 1 Voltage Terminal 15,0.0, V
IDE80030-ENG101050,Analysis 30-Snapshot 1 Voltage Supply Electric Motor,0.0, V
IDE80031-ENG102899,Analysis 31-Snapshot 1 Transmission Fluid Temperature,-60, °C
IDE80032-ENG99872,Analysis 32-Snapshot 1 Maximum Temperature Clutch 1 Clutch 2,-60, °C
IDE80033-ENG103098,Analysis 33-Snapshot 2 Failure ID,65535,
IDE80034-ENG101047,Analysis 34-Snapshot 2 Mileage,0, km
IDE80035-ENG99915,Analysis 35-Snapshot 2 Counter,0,
IDE80036-ENG110549,Analysis 36-Snapshot 2 Oil Pressure Actual Value,-10.0, bar
IDE80037-ENG99369,Analysis 37-Snapshot 2 Shift Position Plausible,P,
IDE80038-ENG99350,Analysis 38-Snapshot 2 Main Status Vehicle Clutch Fahrzeugzustand,New,
IDE80038-ENG102372,Analysis 38-Snapshot 2 Main Status Vehicle Clutch Kupplungshauptzustand,New,
IDE80039-ENG101369,Analysis 39-Snapshot 2  Commanded Gear,GANG N,
IDE80040-ENG103638,Analysis 40-Snapshot 2 Preselection Gear,GANG N,
IDE80041-ENG103367,Analysis 41-Snapshot 2 Transmission Input Speed,0, /min
IDE80042-ENG102476,Analysis 42-Snapshot 2 Transmission Output Speed Shaft 1,0, /min
IDE80043-ENG102699,Analysis 43-Snapshot 2 Transmission Speed Shaft 1,0, /min
IDE80044-ENG101900,Analysis 44-Snapshot 2 Transmission Speed Shaft 2,0, /min
IDE80045-ENG100935,Analysis 45-Snapshot 2 Gearpositioner A Actual Position,-20.48, mm
IDE80046-ENG102046,Analysis 46-Snapshot 2 Gearpositioner B Actual Position,-20.48, mm
IDE80047-ENG100712,Analysis 47-Snapshot 2 Gearpositioner C Actual Position,-20.48, mm
IDE80048-ENG101670,Analysis 48-Snapshot 2 Gearpositioner D Actual Position,-20.48, mm
IDE80049-ENG102288,Analysis 49-Snapshot 2 Gearpositioner A Valve Actual Current,0, mA
IDE80050-ENG103952,Analysis 50-Snapshot 2 Gearpositioner B Valve Actual Current,0, mA
IDE80051-ENG99664,Analysis 51-Snapshot 2 Gearpositioner C Valve Actual Current,0, mA
IDE80052-ENG100255,Analysis 52-Snapshot 2 Gearpositioner D Valve Actual Current,0, mA
IDE80053-ENG102973,Analysis 53-Snapshot 2 Clutch 1 Actual Pressure,0.0, bar
IDE80054-ENG100122,Analysis 54-Snapshot 2 Clutch 2 Actual Pressure,0.0, bar
IDE80055-ENG103189,Analysis 55-Snapshot 2 Current Valve Clutch 1 Actual Value,0, mA
IDE80056-ENG103616,Analysis 56-Snapshot 2 Current Valve Clutch 2 Actual Value,0, mA
IDE80057-ENG102447,Analysis 57-Snapshot 2 Accelerator Pedal Position,0.0, %
IDE80058-ENG103198,Analysis 58-Snapshot 2 Engine torque,-50, Nm
IDE80059-ENG100322,Analysis 59-Snapshot 2 Current Valve Transmission Part 1 Actual Value,0, mA
IDE80060-ENG99335,Analysis 60-Snapshot 2 Current Valve Transmission Part 2 Actual Value,0, mA
IDE80061-ENG101449,Analysis 61-Snapshot 2 Voltage Terminal 15,0.0, V
IDE80062-ENG99916,Analysis 62-Snapshot 2 Voltage Supply Electric Motor,0.0, V
IDE80063-ENG104157,Analysis 63-Snapshot 2 Transmission Fluid Temperature,-60, °C
IDE80064-ENG101948,Analysis 64-Snapshot 2 Maximum Temperature Clutch 1 Clutch 2,-60, °C
IDE80071-ENG127839,Analysis 71-FID event memory entry 1,FF FF,
IDE80071-ENG127848,Analysis 71-FID event memory entry 10,FF FF,
IDE80071-ENG127849,Analysis 71-FID event memory entry 11,FF FF,
IDE80071-ENG127850,Analysis 71-FID event memory entry 12,FF FF,
IDE80071-ENG127840,Analysis 71-FID event memory entry 2,FF FF,
IDE80071-ENG127841,Analysis 71-FID event memory entry 3,FF FF,
IDE80071-ENG127842,Analysis 71-FID event memory entry 4,FF FF,
IDE80071-ENG127843,Analysis 71-FID event memory entry 5,FF FF,
IDE80071-ENG127844,Analysis 71-FID event memory entry 6,FF FF,
IDE80071-ENG127845,Analysis 71-FID event memory entry 7,FF FF,
IDE80071-ENG127846,Analysis 71-FID event memory entry 8,FF FF,
IDE80071-ENG127847,Analysis 71-FID event memory entry 9,FF FF,
IDE80072-ENG127830,Analysis 72-Temperature hybrid time in range 0,0.0, s
IDE80073-ENG127869,Analysis 73-Temperature hybrid time in range 1,25391.7, s
IDE80074-ENG127870,Analysis 74-Temperature hybrid time in range 2,14863.5, s
IDE80075-ENG127871,Analysis 75-Temperature hybrid time in range 3,65.4, s
IDE80076-ENG127872,Analysis 76-Temperature hybrid time in range 4,0.0, s
IDE80077-ENG127873,Analysis 77-Temperature hybrid time in range 5,0.0, s
IDE80080-ENG127878,Analysis 80-Temperature hybrid maximum,100, °C
IDE80081-ENG114824,Analysis 81-Clutch 1 temperature time in range 0,25500.3, s
IDE80082-ENG114820,Analysis 82-Clutch 1 temperature time in range 1,14199.8, s
IDE80083-ENG114814,Analysis 83-Clutch 1 temperature time in range 2,590.4, s
IDE80084-ENG114813,Analysis 84-Clutch 1 temperature time in range 3,30.7, s
IDE80088-ENG111618,Analysis 88-Clutch 1 temperature maximum,176, °C
IDE80089-ENG114807,Analysis 89-Clutch 2 temperature time in range 0,27985.8, s
IDE80090-ENG114811,Analysis 90-Clutch 2 temperature time in range 1,12174.6, s
IDE80091-ENG114805,Analysis 91-Clutch 2 temperature time in range 2,155.8, s
IDE80092-ENG114817,Analysis 92-Clutch 2 temperature time in range 3,5.4, s
IDE80096-ENG111619,Analysis 96-Clutch 2 temperature maximum,162, °C
IDE80101-ENG102219,Analysis 101-Betriebszeit Motor (Drehzahlbereich 1),3.6, H
IDE80101-ENG103682,Analysis 101-Betriebszeit Motor (Drehzahlbereich 2),0.7, H
IDE80101-ENG101200,Analysis 101-Betriebszeit Motor (Drehzahlbereich 3),0.0, H
IDE80101-ENG100226,Analysis 101-Betriebszeit Motor (Drehzahlbereich 4),0.0, H
IDE80101-ENG102223,Analysis 101-Betriebszeit Motor (Drehzahlbereich 5),0.0, H
IDE80102-ENG102381,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 1-Gang,198,
IDE80102-ENG99964,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 2-Gang,301,
IDE80102-ENG100231,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 3-Gang,403,
IDE80102-ENG104160,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 4-Gang,298,
IDE80102-ENG102663,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 5-Gang,242,
IDE80102-ENG99465,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 6-Gang,160,
IDE80102-ENG103205,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 7-Gang,64,
IDE80102-ENG103678,Analysis 102-Anzahl erfolgreiche Einlegevorgänge R-Gang,102,
IDE80103-ENG103574,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 1-Gang,0,
IDE80103-ENG103754,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 2-Gang,0,
IDE80103-ENG99560,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 3-Gang,0,
IDE80103-ENG101116,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 4-Gang,2,
IDE80103-ENG99083,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 5-Gang,0,
IDE80103-ENG99508,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 6-Gang,0,
IDE80103-ENG101966,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 7-Gang,0,
IDE80103-ENG103519,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge R-Gang,0,
IDE80104-ENG100464,Analysis 104-Anzahl Gangspringer 1-Gang,0,
IDE80104-ENG103518,Analysis 104-Anzahl Gangspringer 2-Gang,0,
IDE80104-ENG101484,Analysis 104-Anzahl Gangspringer 3-Gang,0,
IDE80104-ENG102434,Analysis 104-Anzahl Gangspringer 4-Gang,0,
IDE80104-ENG100828,Analysis 104-Anzahl Gangspringer 5-Gang,0,
IDE80104-ENG99747,Analysis 104-Anzahl Gangspringer 6-Gang,0,
IDE80104-ENG102967,Analysis 104-Anzahl Gangspringer 7-Gang,0,
IDE80104-ENG100893,Analysis 104-Anzahl Gangspringer R-Gang,0,
IDE80105-ENG100707,Analysis 105-Betriebszeit Kupplung 1 (Temperaturbereich 1),7.1, H
IDE80105-ENG101697,Analysis 105-Betriebszeit Kupplung 1 (Temperaturbereich 2),3.9, H
IDE80105-ENG100556,Analysis 105-Betriebszeit Kupplung 1 (Temperaturbereich 3),0.2, H
IDE80105-ENG100205,Analysis 105-Betriebszeit Kupplung 1 (Temperaturbereich 4),0.0, H
IDE80106-ENG103428,Analysis 106-Betriebszeit Kupplung 2 (Temperaturbereich 1),7.8, H
IDE80106-ENG101321,Analysis 106-Betriebszeit Kupplung 2 (Temperaturbereich 2),3.4, H
IDE80106-ENG100639,Analysis 106-Betriebszeit Kupplung 2 (Temperaturbereich 3),0.0, H
IDE80106-ENG103433,Analysis 106-Betriebszeit Kupplung 2 (Temperaturbereich 4),0.0, H
IDE80107-ENG101291,Analysis 107-Betriebszeit Kupplung 1 (Momentenbereich 1),0.8, H
IDE80107-ENG104169,Analysis 107-Betriebszeit Kupplung 1 (Momentenbereich 2),0.3, H
IDE80107-ENG100021,Analysis 107-Betriebszeit Kupplung 1 (Momentenbereich 3),0.1, H
IDE80107-ENG101292,Analysis 107-Betriebszeit Kupplung 1 (Momentenbereich 4),0.0, H
IDE80107-ENG99418,Analysis 107-Betriebszeit Kupplung 1 (Momentenbereich 5),0.0, H
IDE80108-ENG99240,Analysis 108-Betriebszeit Kupplung 2 (Momentenbereich 1),0.4, H
IDE80108-ENG99973,Analysis 108-Betriebszeit Kupplung 2 (Momentenbereich 2),0.2, H
IDE80108-ENG103238,Analysis 108-Betriebszeit Kupplung 2 (Momentenbereich 3),0.0, H
IDE80108-ENG101007,Analysis 108-Betriebszeit Kupplung 2 (Momentenbereich 4),0.0, H
IDE80108-ENG101190,Analysis 108-Betriebszeit Kupplung 2 (Momentenbereich 5),0.0, H
IDE80117-MAS02330,Analysis 117-SPECIFIED condition,OFF,
IDE80117-MAS02331,Analysis 117-ACTUAL condition,OFF,
IDE80118-ENG167269,Analysis 118-Snapshot 1 auxiliary transmission fluid pump motor actual speed,0, /min
IDE80119-ENG167272,Analysis 119-Snapshot 1 auxiliary transmission fluid pump motor electronics temperature,-40, °C
IDE80120-ENG167271,Analysis 120-Snapshot 1 auxiliary transmission fluid pump motor current,0, mA
IDE80121-ENG161275,Analysis 121-GOP current limitation failure status,OFF,
IDE80121-ENG161276,Analysis 121-GOP rotor position sensor failure status,OFF,
IDE80122-ENG167275,Analysis 122-Snapshot 1 auxiliary transmission fluid pump motor voltage terminal 30,0.0, V
IDE80123-ENG167270,Analysis 123-Snapshot 1 auxiliary transmission fluid pump motor commanded speed demand estimation,0, /min
IDE80124-ENG167273,Analysis 124-Snapshot 1 auxiliary transmission fluid pump motor oil pressure,0.00, bar
IDE80125-MAS02330,Analysis 125-SPECIFIED condition,OFF,
IDE80125-MAS02331,Analysis 125-ACTUAL condition,OFF,
IDE80126-ENG167276,Analysis 126-Snapshot 2 auxiliary transmission fluid pump motor actual speed,0, /min
IDE80127-ENG167278,Analysis 127-Snapshot 2 auxiliary transmission fluid pump motor electronics temperature,-40, °C
IDE80128-ENG167277,Analysis 128-Snapshot 2 auxiliary transmission fluid pump motor current,0, mA
IDE80129-ENG161275,Analysis 129-GOP current limitation failure status,OFF,
IDE80129-ENG161276,Analysis 129-GOP rotor position sensor failure status,OFF,
IDE80130-ENG167280,Analysis 130-Snapshot 2 auxiliary transmission fluid pump motor voltage terminal 30,0.0, V
IDE80131-ENG167276,Analysis 131-Snapshot 2 auxiliary transmission fluid pump motor actual speed,0, /min
IDE80132-ENG167279,Analysis 132-Snapshot 2 auxiliary transmission fluid pump motor oil pressure,0.00, bar
IDE80133-ENG167274,Analysis 133-Snapshot 1 auxiliary transmission fluid pump motor valve actual current,0, mA
IDE80134-ENG167274,Analysis 134-Snapshot 1 auxiliary transmission fluid pump motor valve actual current,0, mA
IDE80137-ENG167891,Analysis 137-Mode A FID event memory entry 1,FF FF,
IDE80137-ENG167892,Analysis 137-Mode A FID event memory entry 2,FF FF,
IDE80137-ENG167893,Analysis 137-Mode A FID event memory entry 3,FF FF,
IDE80137-ENG167894,Analysis 137-Mode A FID event memory entry 4,FF FF,
IDE80276-ENG127854,Current vehicle odometer reading-Current vehicle mileage,156, km
IDE80277-ENG127828,Neutral due to driver's workplace oper: veh odom.read.-Driver registration procedure condition vehicle mileage,0, km
IDE80278-ENG127882,Driver logon procedure: vehicle odometer reading-Driver registration procedure vehicle mileage,110, km
IDE80279-ENG127826,Driver logon procedure: cause-Driver registration procedure cause,2048,
IDE80280-ENG127827,Driver logon procedure: wave-Driver registration procedure shaft,0,
IDE80282-ENG114823,Clutch 1 Adaption basic charac. point 0 moment-Clutch 1 adaption basic characteristic point 0 torque,0.0, Nm
IDE80283-ENG114819,Clutch 1 Adaption basic charac. point 1 moment-Clutch 1 adaption basic characteristic point 1 torque,100.0, Nm
IDE80284-ENG114822,Clutch 1 Adaption basic charac. point 2 moment-Clutch 1 adaption basic characteristic point 2 torque,420.0, Nm
IDE80285-ENG114815,Clutch 1 Adaption basic charac. point 3 moment-Clutch 1 adaption basic characteristic point 3 torque,500.0, Nm
IDE80287-ENG127832,Clutch 1 Friction value correction factor-Clutch 1 frictional correction factor,100.0, %
IDE80288-ENG114818,Clutch 1 Characteristic line shift-Clutch 1 characteristic shift,0.00, mm
IDE80289-ENG114806,Clutch 2 Adaption basic charac. point 0 moment-Clutch 2 adaption basic characteristic point 0 torque,0.0, Nm
IDE80290-ENG114810,Clutch 2 Adaption basic charac. point 1 moment-Clutch 2 adaption basic characteristic point 1 torque,100.0, Nm
IDE80291-ENG114821,Clutch 2 Adaption basic charac. point 2 moment-Clutch 2 adaption basic characteristic point 2 torque,420.0, Nm
IDE80292-ENG114809,Clutch 2 Adaption basic charac. point 3 moment-Clutch 2 adaption basic characteristic point 3 torque,500.0, Nm
IDE80294-ENG127876,Clutch 2 Friction value correction factor-Clutch 2 frictional correction factor,100.0, %
IDE80295-ENG114808,Clutch 2 Characteristic line shift-Clutch 2 characteristic shift,0.00, mm
IDE80296-ENG127853,Clutch 1 adaption kiss point part 1 success counter-Clutch 1 adaption part 1 positive case counter,0,
IDE80297-ENG127883,Clutch 1 Adaption kiss point part 1: vehicle odometer reading-Clutch 1 adaption part 1 vehicle mileage,655350, km
IDE80298-ENG127880,Clutch 2 adaption kiss point part 1 success counter-Clutch 2 adaption part 1 positive case counter,4,
IDE80299-ENG127884,Clutch 2 Adaption kiss point part 1: vehicle odometer reading-Clutch 2 adaption part 1 vehicle mileage,130, km
IDE80303-ENG127833,Overall software description-Software full name,K28,
IDE80305-ENG125922,Parameter set description-Data set name,FL_0GC300018E_2803_LJLN.par,
IDE80307-ENG127879,Clutch 1 Adaption kiss point part 1: remaining fast adaptations-Clutch 1 adaption part 1 remaining fastadaptions,0,
IDE80308-ENG127881,Clutch 2 Adaption kiss point part 1: remaining fast adaptations-Clutch 2 adaption part 1 remaining fastadaptions,0,
ENG98625-ENG103724,Accelerator position: qualification-Accelerator pedal position: qualification,OK,
ENG100091,Ambient temperature,30, °C
ENG157549,Anzahl Launch Control Anfahrt,0,
ENG157501-ENG130284,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Call-Stack-Element 0,00 00 00 00,
ENG157501-ENG130285,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Call-Stack-Element 1,00 00 00 00,
ENG157501-ENG130286,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Call-Stack-Element 2,00 00 00 00,
ENG157501-ENG130287,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Call-Stack-Element 3,00 00 00 00,
ENG157501-ENG161272,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 1,00 00 00 00,
ENG157501-ENG167224,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 2,0,
ENG157501-ENG167225,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 3,0,
ENG157501-ENG161273,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 4,0,
ENG157501-ENG161274,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 5,0,
ENG157501-ENG167226,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 6,0,
ENG157501-ENG130283,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Gesamt-Software-Version,,
ENG157501-ENG160009,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Häufigkeit,0,
ENG157501-ENG130295,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Klemme 15-Spannung,51.0, V
ENG157501-ENG130296,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Klemme 30-Spannung,51.0, V
ENG157501-ENG130297,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Mechatroniktemperatur,215, °C
ENG157501-ENG98689,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Odometer reading,655350, km
ENG157501-ENG130291,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Reset Quelle,0,
ENG157501-ENG112343,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Reset Status,0,
ENG157501-ENG130293,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Reset Typ,0,
ENG157501-ENG130300,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Status des Eintrags,FF,
ENG157501-ENG130299,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Uds-Lesestatus des Eintrages,1,
ENG157502-ENG130284,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Call-Stack-Element 0,00 00 00 00,
ENG157502-ENG130285,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Call-Stack-Element 1,00 00 00 00,
ENG157502-ENG130286,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Call-Stack-Element 2,00 00 00 00,
ENG157502-ENG130287,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Call-Stack-Element 3,00 00 00 00,
ENG157502-ENG161272,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 1,00 00 00 00,
ENG157502-ENG167224,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 2,0,
ENG157502-ENG167225,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 3,0,
ENG157502-ENG161273,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 4,0,
ENG157502-ENG161274,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 5,0,
ENG157502-ENG167226,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 6,0,
ENG157502-ENG130283,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Gesamt-Software-Version,,
ENG157502-ENG160009,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Häufigkeit,0,
ENG157502-ENG130295,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Klemme 15-Spannung,51.0, V
ENG157502-ENG130296,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Klemme 30-Spannung,51.0, V
ENG157502-ENG130297,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Mechatroniktemperatur,215, °C
ENG157502-ENG98689,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Odometer reading,655350, km
ENG157502-ENG130291,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Reset Quelle,0,
ENG157502-ENG112343,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Reset Status,0,
ENG157502-ENG130293,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Reset Typ,0,
ENG157502-ENG130300,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Status des Eintrags,FF,
ENG157502-ENG130299,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Uds-Lesestatus des Eintrages,1,
ENG157503-ENG130284,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Call-Stack-Element 0,00 00 00 00,
ENG157503-ENG130285,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Call-Stack-Element 1,00 00 00 00,
ENG157503-ENG130286,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Call-Stack-Element 2,00 00 00 00,
ENG157503-ENG130287,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Call-Stack-Element 3,00 00 00 00,
ENG157503-ENG161272,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 1,00 00 00 00,
ENG157503-ENG167224,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 2,0,
ENG157503-ENG167225,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 3,0,
ENG157503-ENG161273,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 4,0,
ENG157503-ENG161274,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 5,0,
ENG157503-ENG167226,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 6,0,
ENG157503-ENG130283,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Gesamt-Software-Version,,
ENG157503-ENG160009,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Häufigkeit,0,
ENG157503-ENG130295,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Klemme 15-Spannung,51.0, V
ENG157503-ENG130296,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Klemme 30-Spannung,51.0, V
ENG157503-ENG130297,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Mechatroniktemperatur,215, °C
ENG157503-ENG98689,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Odometer reading,655350, km
ENG157503-ENG130291,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Reset Quelle,0,
ENG157503-ENG112343,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Reset Status,0,
ENG157503-ENG130293,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Reset Typ,0,
ENG157503-ENG130300,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Status des Eintrags,FF,
ENG157503-ENG130299,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Uds-Lesestatus des Eintrages,1,
ENG157504-ENG130284,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Call-Stack-Element 0,00 00 00 00,
ENG157504-ENG130285,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Call-Stack-Element 1,00 00 00 00,
ENG157504-ENG130286,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Call-Stack-Element 2,00 00 00 00,
ENG157504-ENG130287,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Call-Stack-Element 3,00 00 00 00,
ENG157504-ENG161272,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 1,00 00 00 00,
ENG157504-ENG167224,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 2,0,
ENG157504-ENG167225,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 3,0,
ENG157504-ENG161273,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 4,0,
ENG157504-ENG161274,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 5,0,
ENG157504-ENG167226,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 6,0,
ENG157504-ENG130283,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Gesamt-Software-Version,,
ENG157504-ENG160009,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Häufigkeit,0,
ENG157504-ENG130295,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Klemme 15-Spannung,51.0, V
ENG157504-ENG130296,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Klemme 30-Spannung,51.0, V
ENG157504-ENG130297,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Mechatroniktemperatur,215, °C
ENG157504-ENG98689,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Odometer reading,655350, km
ENG157504-ENG130291,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Reset Quelle,0,
ENG157504-ENG112343,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Reset Status,0,
ENG157504-ENG130293,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Reset Typ,0,
ENG157504-ENG130300,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Status des Eintrags,FF,
ENG157504-ENG130299,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Uds-Lesestatus des Eintrages,1,
ENG157505-ENG130284,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Call-Stack-Element 0,00 00 00 00,
ENG157505-ENG130285,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Call-Stack-Element 1,00 00 00 00,
ENG157505-ENG130286,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Call-Stack-Element 2,00 00 00 00,
ENG157505-ENG130287,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Call-Stack-Element 3,00 00 00 00,
ENG157505-ENG161272,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 1,00 00 00 00,
ENG157505-ENG167224,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 2,0,
ENG157505-ENG167225,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 3,0,
ENG157505-ENG161273,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 4,0,
ENG157505-ENG161274,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 5,0,
ENG157505-ENG167226,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 6,0,
ENG157505-ENG130283,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Gesamt-Software-Version,,
ENG157505-ENG160009,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Häufigkeit,0,
ENG157505-ENG130295,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Klemme 15-Spannung,51.0, V
ENG157505-ENG130296,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Klemme 30-Spannung,51.0, V
ENG157505-ENG130297,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Mechatroniktemperatur,215, °C
ENG157505-ENG98689,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Odometer reading,655350, km
ENG157505-ENG130291,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Reset Quelle,0,
ENG157505-ENG112343,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Reset Status,0,
ENG157505-ENG130293,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Reset Typ,0,
ENG157505-ENG130300,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Status des Eintrags,FF,
ENG157505-ENG130299,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Uds-Lesestatus des Eintrages,1,
ENG99187,CAN version,0,
ENG98482-ENG99180,Checksum of flash-Calibration Checksumme,F0 AD 90 F2,
ENG98482-ENG100495,Checksum of flash-Cboot Checksumme,F0 51 F1 13,
ENG98482-ENG100117,Checksum of flash-Checksumme ECU + CAL,3D D0 C1 42,
ENG98482-ENG102221,Checksum of flash-ECU Checksumme,4D 23 30 50,
ENG101012,Clutch 1 adaption basic characteristic point 0 position,2.31, bar
ENG102187,Clutch 1 adaption basic characteristic point 1 position,4.53, bar
ENG99501,Clutch 1 adaption basic characteristic point 2 position,11.54, bar
ENG99792,Clutch 1 adaption basic characteristic point 3 position,14.00, bar
ENG103827,Clutch 1 adaption basic characteristic range 1 quick adaptions remaining km,0, km
ENG99333,Clutch 1 adaption basic characteristic range 2 quick adaptions remaining km,0, km
ENG102537,Clutch 1 adaption basic characteristic range 3 quick adaptions remaining km,0, km
ENG110529,Clutch 1 adaption kiss point part 1 fault cause,00 00 00 00,
ENG110528,Clutch 1 adaption kiss point part 1 fault cause cumulative,00 00 00 00,
ENG110530,Clutch 1 adaption kiss point part 1 fault counter,0,
ENG104250,Clutch 2 adaption basic characteristic point 0 position,2.56, bar
ENG100941,Clutch 2 adaption basic characteristic point 1 position,4.66, bar
ENG99957,Clutch 2 adaption basic characteristic point 2 position,11.39, bar
ENG99481,Clutch 2 adaption basic characteristic point 3 position,14.00, bar
ENG102732,Clutch 2 adaption basic characteristic range 1 quick adaptions remaining km,0, km
ENG101931,Clutch 2 adaption basic characteristic range 2 quick adaptions remaining km,0, km
ENG100136,Clutch 2 adaption basic characteristic range 3 quick adaptions remaining km,0, km
ENG110535,Clutch 2 adaption kiss point part 1 fault cause,00 00 00 00,
ENG110534,Clutch 2 adaption kiss point part 1 fault cause cumulative,00 00 00 00,
ENG110536,Clutch 2 adaption kiss point part 1 fault counter,0,
ENG102882,Clutch adaptation kiss-point fast adaptation remaining km tr,0, km
ENG103186,Clutch center central plate temperature,29, °C
ENG107241-ENG103334,Coefficient vmd_k_Clutch_1C0-Koeffizient,76.995,
ENG107242-ENG103334,Coefficient vmd_k_Clutch_1C1-Koeffizient,69.729,
ENG107243-ENG103334,Coefficient vmd_k_Clutch_1C2-Koeffizient,-89.446,
ENG107244-ENG103334,Coefficient vmd_k_Clutch_1C3-Koeffizient,30.326,
ENG107245-ENG103334,Coefficient vmd_k_Clutch_2C0-Koeffizient,47.152,
ENG107246-ENG103334,Coefficient vmd_k_Clutch_2C1-Koeffizient,67.719,
ENG107247-ENG103334,Coefficient vmd_k_Clutch_2C2-Koeffizient,-69.752,
ENG107248-ENG103334,Coefficient vmd_k_Clutch_2C3-Koeffizient,42.587,
ENG107249-ENG103334,Coefficient vmd_k_Cool_C0-Koeffizient,766.130,
ENG107250-ENG103334,Coefficient vmd_k_Cool_C1-Koeffizient,352.129,
ENG107251-ENG103334,Coefficient vmd_k_Cool_C2-Koeffizient,0.369,
ENG107252-ENG103334,Coefficient vmd_k_Cool_C3-Koeffizient,-21.757,
ENG107253-ENG103334,Coefficient vmd_k_Cool_C4-Koeffizient,-1.886,
ENG107254-ENG103334,Coefficient vmd_k_Cool_Qmax-Koeffizient,24.771,
ENG107255-ENG103334,Coefficient vmd_k_CutOff_ OddC0-Koeffizient,193.141,
ENG107256-ENG103334,Coefficient vmd_k_CutOff_ OddC1-Koeffizient,-0.091,
ENG107257-ENG103334,Coefficient vmd_k_CutOff_ OddC2-Koeffizient,38.482,
ENG107258-ENG103334,Coefficient vmd_k_CutOff_Even_C0-Koeffizient,179.565,
ENG107259-ENG103334,Coefficient vmd_k_CutOff_Even_C1-Koeffizient,-0.088,
ENG107260-ENG103334,Coefficient vmd_k_CutOff_Even_C2-Koeffizient,33.807,
ENG107261-ENG103334,Coefficient vmd_k_CutOff_Even_C3-Koeffizient,0.120,
ENG107262-ENG103334,Coefficient vmd_k_CutOff_Even_C4-Koeffizient,29.749,
ENG107263-ENG103334,Coefficient vmd_k_CutOff_OddC3-Koeffizient,0.052,
ENG107264-ENG103334,Coefficient vmd_k_CutOff_OddC4-Koeffizient,9.972,
ENG107265-ENG103334,Coefficient vmd_k_FlwC0_Even_ABw-Koeffizient,720.382,
ENG107266-ENG103334,Coefficient vmd_k_FlwC0_Even_AFw-Koeffizient,911.526,
ENG107267-ENG103334,Coefficient vmd_k_FlwC0_Even_BBw-Koeffizient,717.650,
ENG107268-ENG103334,Coefficient vmd_k_FlwC0_Even_BFw-Koeffizient,899.633,
ENG107269-ENG103334,Coefficient vmd_k_FlwC0_OddABw-Koeffizient,752.505,
ENG107270-ENG103334,Coefficient vmd_k_FlwC0_OddAFw-Koeffizient,937.545,
ENG107271-ENG103334,Coefficient vmd_k_FlwC0_OddBBw-Koeffizient,753.252,
ENG107272-ENG103334,Coefficient vmd_k_FlwC0_OddBFw-Koeffizient,938.129,
ENG107273-ENG103334,Coefficient vmd_k_FlwC1_Even_ABw-Koeffizient,20.241,
ENG107274-ENG103334,Coefficient vmd_k_FlwC1_Even_AFw-Koeffizient,59.109,
ENG107275-ENG103334,Coefficient vmd_k_FlwC1_Even_BBw-Koeffizient,32.015,
ENG107276-ENG103334,Coefficient vmd_k_FlwC1_Even_BFw-Koeffizient,50.084,
ENG107277-ENG103334,Coefficient vmd_k_FlwC1_OddABw-Koeffizient,22.952,
ENG107278-ENG103334,Coefficient vmd_k_FlwC1_OddAFw-Koeffizient,63.252,
ENG107279-ENG103334,Coefficient vmd_k_FlwC1_OddBBw-Koeffizient,26.337,
ENG107280-ENG103334,Coefficient vmd_k_FlwC1_OddBFw-Koeffizient,58.481,
ENG107281-ENG103334,Coefficient vmd_k_FlwC2_Even_ABw-Koeffizient,6.412,
ENG107282-ENG103334,Coefficient vmd_k_FlwC2_Even_AFw-Koeffizient,10.801,
ENG107283-ENG103334,Coefficient vmd_k_FlwC2_Even_BBw-Koeffizient,10.792,
ENG107284-ENG103334,Coefficient vmd_k_FlwC2_Even_BFw-Koeffizient,8.984,
ENG107285-ENG103334,Coefficient vmd_k_FlwC2_OddABw-Koeffizient,7.391,
ENG107286-ENG103334,Coefficient vmd_k_FlwC2_OddAFw-Koeffizient,12.651,
ENG107287-ENG103334,Coefficient vmd_k_FlwC2_OddBBw-Koeffizient,6.992,
ENG107288-ENG103334,Coefficient vmd_k_FlwC2_OddBFw-Koeffizient,9.910,
ENG107289-ENG103334,Coefficient vmd_k_FlwC3_Even_ABw-Koeffizient,-51.068,
ENG107290-ENG103334,Coefficient vmd_k_FlwC3_Even_AFw-Koeffizient,-9.363,
ENG107291-ENG103334,Coefficient vmd_k_FlwC3_Even_BBw-Koeffizient,-26.324,
ENG107292-ENG103334,Coefficient vmd_k_FlwC3_Even_BFw-Koeffizient,28.499,
ENG107293-ENG103334,Coefficient vmd_k_FlwC3_OddABw-Koeffizient,-52.563,
ENG107294-ENG103334,Coefficient vmd_k_FlwC3_OddAFw-Koeffizient,-16.770,
ENG107295-ENG103334,Coefficient vmd_k_FlwC3_OddBBw-Koeffizient,-43.495,
ENG107296-ENG103334,Coefficient vmd_k_FlwC3_OddBFw-Koeffizient,8.294,
ENG107297-ENG103334,Coefficient vmd_k_Line_C0-Koeffizient,-5.024,
ENG107298-ENG103334,Coefficient vmd_k_Line_C1-Koeffizient,1178.752,
ENG107299-ENG103334,Coefficient vmd_k_Line_C2-Koeffizient,-41.032,
ENG107300-ENG103334,Coefficient vmd_k_Line_C3-Koeffizient,-0.007,
ENG107301-ENG103334,Coefficient vmd_k_Line_C4-Koeffizient,1.000,
ENG99212,Common highside 1 specified condition,Common Highside soll eingeschaltet werden,
ENG99878,Common highside 2 specified condition,Common Highside soll eingeschaltet werden,
ENG103403,Converter Loss Torque,2.3, Nm
ENG100625,Coolant temperature,52, °C
ENG157510-ENG167264,Daten des Lebensdauermodells der K1-Reibarbeit gewichtet,7.0, mJ
ENG157510-ENG167265,Daten des Lebensdauermodells der K1-Reibarbeit gewichtet HR,495079.1, J
ENG157510-ENG167266,Daten des Lebensdauermodells der K1-Reibarbeit ungewichtet,7.0, mJ
ENG157510-ENG167267,Daten des Lebensdauermodells der K1-Reibarbeit ungewichtet HR,495079.1, J
ENG157510-ENG161282,Daten des Lebensdauermodells der K1-Reibwertkorrekturfaktor Lebensmodell,0.0, %
ENG157511-ENG167264,Daten des Lebensdauermodells der K2-Reibarbeit gewichtet,6.5, mJ
ENG157511-ENG167265,Daten des Lebensdauermodells der K2-Reibarbeit gewichtet HR,274053.7, J
ENG157511-ENG167266,Daten des Lebensdauermodells der K2-Reibarbeit ungewichtet,6.5, mJ
ENG157511-ENG167267,Daten des Lebensdauermodells der K2-Reibarbeit ungewichtet HR,274053.7, J
ENG157511-ENG161282,Daten des Lebensdauermodells der K2-Reibwertkorrekturfaktor Lebensmodell,0.0, %
ENG104016,Designation VWDQ-Lib,K27D01,
ENG98602,Driver intention torque,2.0, Nm
ENG100746,Driving strategy: sport factor,0.0, %
ENG101251,Empty,Empty,
ENG99932,Engine coding info,74,
ENG98756,Engine torque,22.0, Nm
ENG104230,Engine torque loss,20.0, Nm
ENG106287-ENG104036,Enriched maximum temperature clutch 1-Erreichte Maximaltemperatur Kupplung 1,176, °C
ENG106287-ENG103379,Enriched maximum temperature clutch 1-Erreichte Maximaltemperatur Kupplung 2,162, °C
ENG123019-ENG99024,Fahrgeschwindigkeit vom Getriebe-Vehicle speed from transmission,0.0, km/h
ENG100414,Gangsteller A Adaption Neutralposition,-0.7, mm
ENG100089,Gangsteller B Adaption Neutralposition,-0.0, mm
ENG103055,Gangsteller C Adaption Neutralposition,-0.0, mm
ENG101354,Gangsteller D Adaption Neutralposition,0.0, mm
ENG110510,Gear actuator adaption engaged position G1,-8.6, mm
ENG110511,Gear actuator adaption engaged position G2,-9.5, mm
ENG110512,Gear actuator adaption engaged position G3,9.2, mm
ENG99484,Gear actuator adaption engaged position G4,9.8, mm
ENG110513,Gear actuator adaption engaged position G5,8.4, mm
ENG110514,Gear actuator adaption engaged position G6,9.4, mm
ENG110515,Gear actuator adaption engaged position G7,-9.1, mm
ENG110516,Gear actuator adaption engaged position GR,-9.2, mm
ENG110517,Gear actuator adaption synchro position G1,-2.7, mm
ENG110518,Gear actuator adaption synchro position G2,-2.1, mm
ENG110519,Gear actuator adaption synchro position G3,1.9, mm
ENG99198,Gear actuator adaption synchro position G4,2.1, mm
ENG110520,Gear actuator adaption synchro position G5,0.9, mm
ENG110521,Gear actuator adaption synchro position G6,1.8, mm
ENG110522,Gear actuator adaption synchro position G7,-1.5, mm
ENG110523,Gear actuator adaption synchro position GR,-1.7, mm
ENG157514-ENG161285,Gear_ratio_control-Status 1-Gang,Übersetzung i.O.,
ENG157514-ENG161286,Gear_ratio_control-Status 2-Gang,Übersetzung i.O.,
ENG157514-ENG161287,Gear_ratio_control-Status 3-Gang,Übersetzung i.O.,
ENG157514-ENG161288,Gear_ratio_control-Status 4-Gang,Übersetzung i.O.,
ENG157514-ENG161289,Gear_ratio_control-Status 5-Gang,Übersetzung i.O.,
ENG157514-ENG161290,Gear_ratio_control-Status 6-Gang,Übersetzung i.O.,
ENG157514-ENG161291,Gear_ratio_control-Status 7-Gang,Übersetzung i.O.,
ENG157514-ENG161292,Gear_ratio_control-Status R-Gang,Übersetzung noch nicht ermittelt,
ENG157514-ENG167281,Gear_ratio_control-Übersetzung 1-Gang,17.810,
ENG157514-ENG167282,Gear_ratio_control-Übersetzung 2-Gang,10.777,
ENG157514-ENG167283,Gear_ratio_control-Übersetzung 3-Gang,6.875,
ENG157514-ENG167284,Gear_ratio_control-Übersetzung 4-Gang,4.798,
ENG157514-ENG167285,Gear_ratio_control-Übersetzung 5-Gang,3.656,
ENG157514-ENG167286,Gear_ratio_control-Übersetzung 6-Gang,2.935,
ENG157514-ENG167287,Gear_ratio_control-Übersetzung 7-Gang,2.470,
ENG157514-ENG167288,Gear_ratio_control-Übersetzung R-Gang,0.000,
ENG157515-ENG167227,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-15-Endlage Seite_A,7.7, mm
ENG157515-ENG167228,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-15-Endlage Seite_B,-76.8, mm
ENG157515-ENG167229,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-15-Synchronlage Seite_A,-48.6, mm
ENG157515-ENG167230,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-15-Synchronlage Seite_B,-30.7, mm
ENG157515-ENG167231,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-26-Endlage Seite_A,7.7, mm
ENG157515-ENG167232,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-26-Endlage Seite_B,-76.8, mm
ENG157515-ENG167233,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-26-Synchronlage Seite_A,-48.6, mm
ENG157515-ENG167234,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-26-Synchronlage Seite_B,-30.7, mm
ENG157515-ENG167235,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-73-Endlage Seite_A,7.7, mm
ENG157515-ENG167236,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-73-Endlage Seite_B,-76.8, mm
ENG157515-ENG167237,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-73-Synchronlage Seite_A,-48.6, mm
ENG157515-ENG167238,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-73-Synchronlage Seite_B,-30.7, mm
ENG157515-ENG167239,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-R4-Endlage Seite_A,7.7, mm
ENG157515-ENG167240,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-R4-Endlage Seite_B,-76.8, mm
ENG157515-ENG167241,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-R4-Synchronlage Seite_A,-48.6, mm
ENG157515-ENG167242,Grenzwertvorgaben der Grundeinmessung Gangsteller-Max-Wert der GS-R4-Synchronlage Seite_B,-30.7, mm
ENG157515-ENG167246,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-15-Endlage Seite_A,79.3, mm
ENG157515-ENG167247,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-15-Endlage Seite_B,-5.1, mm
ENG157515-ENG167248,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-15-Synchronlage Seite_A,33.3, mm
ENG157515-ENG167249,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-15-Synchronlage Seite_B,51.2, mm
ENG157515-ENG167250,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-26-Endlage Seite_A,79.3, mm
ENG157515-ENG167251,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-26-Endlage Seite_B,-5.1, mm
ENG157515-ENG167252,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-26-Synchronlage Seite_A,33.3, mm
ENG157515-ENG167253,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-26-Synchronlage Seite_B,51.2, mm
ENG157515-ENG167254,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-73-Endlage Seite_A,79.3, mm
ENG157515-ENG167255,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-73-Endlage Seite_B,-5.1, mm
ENG157515-ENG167256,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-73-Synchronlage Seite_A,33.3, mm
ENG157515-ENG167257,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-73-Synchronlage Seite_B,51.2, mm
ENG157515-ENG167258,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-R4-Endlage Seite_A,79.3, mm
ENG157515-ENG167259,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-R4-Endlage Seite_B,-5.1, mm
ENG157515-ENG167260,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-R4-Synchronlage Seite_A,33.3, mm
ENG157515-ENG167261,Grenzwertvorgaben der Grundeinmessung Gangsteller-Min-Wert der GS-R4-Synchronlage Seite_B,51.2, mm
ENG157516-ENG167243,Grenzwertvorgaben der Grundeinmessung Kupplung-Max-Wert des Kisspoints Kupplung_1,240.6, bar
ENG157516-ENG167244,Grenzwertvorgaben der Grundeinmessung Kupplung-Max-Wert des Kisspoints Kupplung_2,240.6, bar
ENG157516-ENG167262,Grenzwertvorgaben der Grundeinmessung Kupplung-Min-Wert des Kisspoints Kupplung_1,307.2, bar
ENG157516-ENG167263,Grenzwertvorgaben der Grundeinmessung Kupplung-Min-Wert des Kisspoints Kupplung_2,281.6, bar
ENG99720,Height info,974, mbar
ENG98604,Hill factor driving strategy,0.0, %
ENG99596,Indicated engine torque without external interventions,21.0, Nm
ENG99582,Intake air temperature,32, °C
ENG110538,Kupplung 2 Adaption Kupplungsendlage (KEL) geschlossen,15.00, bar
ENG110539,Kupplung 2 Adaption Kupplungsendlage (KEL) offen,0.00, bar
ENG110556-ENG110541,Leak oil compensation K1-Abbruch Zähler K1 Drucküberwachung,0,
ENG110556-ENG110542,Leak oil compensation K1-Abbruch Zähler K1 Solldruckintegral zu groß,0,
ENG110556-ENG110543,Leak oil compensation K1-Abbruch Zähler K1 Solldruckintegral zu klein,0,
ENG110556-ENG120771,Leak oil compensation K1-Erfolgreiche K1 Leckölkompensationen,30,
ENG110557-ENG110545,Leak oil compensation K2-Abbruch Zähler K2 Drucküberwachung,0,
ENG110557-ENG110546,Leak oil compensation K2-Abbruch Zähler K2 Solldruckintegral zu groß,0,
ENG110557-ENG110547,Leak oil compensation K2-Abbruch Zähler K2 Solldruckintegral zu klein,4,
ENG110557-ENG110544,Leak oil compensation K2-Erfolgreiche K2 Leckölkompensationen,88,
ENG107605-ENG103083,Mechatronics-ID_Dev.-Baudatum,220121,
ENG107605-ENG98675,Mechatronics-ID_Dev.-Construction version,N5,
ENG107605-ENG99175,Mechatronics-ID_Dev.-Kassel,K,
ENG107605-ENG104192,Mechatronics-ID_Dev.-Kennung der Mechatronik-Montagelinie,D15,
ENG107605-ENG103830,Mechatronics-ID_Dev.-Lfd.-Nr,6647,
ENG107605-ENG103525,Mechatronics-ID_Dev.-Teilenummer (3 letzten + Index),0GCE_,
ENG111613-ENG101555,Motordrehmoment Begrenzung-Engine torque limitation,82.0, Nm
ENG104079,Odometer state: last chng GE clutch mov press. char. curve,4294967295, km
ENG105329-ENG101124,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 1),0.0, H
ENG105329-ENG100216,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 2),7.1, H
ENG105329-ENG103067,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 3),4.1, H
ENG105329-ENG101168,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 4),0.0, H
ENG105329-ENG104150,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 5),0.0, H
ENG105329-ENG100130,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 6),0.0, H
ENG100188,Reached maximum temperature control module,100, °C
ENG123020-ENG102793,Rollwiderstand-Road Resistance,1.3, %
ENG103000,Run time complete system,11.2078, H
ENG102748,Selector lever error flags,00 00,
ENG100909,Snapshot 1 Info current ECM3 error 0,0,
ENG100722,Snapshot 1 Info current ECM3 error 1,0,
ENG103157,Snapshot 1 Info old ECM3 error 0,0,
ENG99098,Snapshot 1 Info old ECM3 error 1,0,
ENG102200,Snapshot 2 Info current ECM3 error 0,0,
ENG101765,Snapshot 2 Info current ECM3 error 1,0,
ENG101738,Snapshot 2 Info old ECM3 error 0,0,
ENG101881,Snapshot 2 Info old ECM3 error 1,0,
ENG101057,Specified idle speed,840, /min
ENG100803,Speed: output,0, /min
ENG100141,Transmission coding info,24,
ENG106780-ENG103213,Transmission-ID_Dev.-Aggregatekennzeichnung (Getriebe),006,
ENG106780-ENG103083,Transmission-ID_Dev.-Baudatum,220121,
ENG106780-ENG104019,Transmission-ID_Dev.-Getriebekennbuchstabe,UWQ,
ENG106780-ENG99175,Transmission-ID_Dev.-Kassel,K,
ENG106780-ENG101707,Transmission-ID_Dev.-Kennung der Montagelinie,D07,
ENG106780-ENG103830,Transmission-ID_Dev.-Lfd.-Nr,1486,
ENG103964,Veh. odometer state: last change of GE gear selector data,655350, km
ENG101346,Version info driving strategy,FBJRMSHEH.039,
ENG109959-ENG101914,vmd_i_FlwVlvCurMin_mA_EvenA-vmd i FlwVlvCurMin mA EvenA,488,
ENG109960-ENG104144,vmd_i_FlwVlvCurMin_mA_EvenB-vmd i FlwVlvCurMin mA EvenB,496,
ENG109961-ENG101870,vmd_i_FlwVlvCurMin_mA_OddA-vmd i FlwVlvCurMin mA OddA,506,
ENG109962-ENG102688,vmd_i_FlwVlvCurMin_mA_OddB-vmd i FlwVlvCurMin mA OddB,511,
ENG109963-ENG103264,vmd_i_NulFlw_mA_Even_ABw-vmd i NulFlw mA Even ABw,720,
ENG109964-ENG100102,vmd_i_NulFlw_mA_Even_AFw-vmd i NulFlw mA Even AFw,877,
ENG109965-ENG103659,vmd_i_NulFlw_mA_Even_BBw-vmd i NulFlw mA Even BBw,739,
ENG109966-ENG100519,vmd_i_NulFlw_mA_Even_BFw-vmd i NulFlw mA Even BFw,885,
ENG109967-ENG99410,vmd_i_NulFlw_mA_OddABw-vmd i NulFlw mA OddABw,753,
ENG109968-ENG99443,vmd_i_NulFlw_mA_OddAFw-vmd i NulFlw mA OddAFw,896,
ENG109969-ENG100167,vmd_i_NulFlw_mA_OddBBw-vmd i NulFlw mA OddBBw,757,
ENG109970-ENG99387,vmd_i_NulFlw_mA_OddBFw-vmd i NulFlw mA OddBFw,914,
ENG109971-ENG103334,vmd_k_Line_PmaxKoeffizient vmd_k_Line_Pmax-Koeffizient,24.791,
ENG109005,Voltage Common Highside 1,12.4, V
ENG99955,Voltage Common Highside 2,12.4, V
Elapsed Time: 00:44,,,
blockmap-03-5Q0-614-517-GB_3VV2X7B28NM061887-20220618-1233.CSV
;SW:5Q0-614-517-GB   HW:5Q0-614-517-BP ---  ABS Brakes
;Component:ESC           H35 0114, Coding:86FB6A7EA026246D857F0308A2CA2961560524A1C045947C38215558D2AA4A0B00402F641A1B13111452653B484E7CFC
;EV_Brake1UDSContiMK100IPB,049015,EV_Brake1UDSContiMK100IPB_049_VW27.rod
;Saturday,18,June,2022,12:33:03:14741
;VCDS Version: Beta 22.4.0 (x64)  Data version: 20220407 DS338.0
;VCID: F7A000969F4E5DE3628-80A2
Group,Description,Actual,
IDE00609-MAS01156,Communication status of data bus 1-Communication status,|Control module,Communication status|Engine Electronics
IDE00780,Mode,running_mode,
IDE02270-IDE00086,CAN input signal(s) status-Accelerator pedal position,0, %
IDE02270-IDE02049,CAN input signal(s) status-Trailer detected,Malfunction,
IDE02270-IDE02713,CAN input signal(s) status-Brake lamp switch,operated,
IDE02270-MAS00025,CAN input signal(s) status-Driver seat belt switch,not connected,
IDE02270-MAS00218,CAN input signal(s) status-Driver door,Open,
IDE02270-MAS00314,CAN input signal(s) status-Clutch Pedal Switch,operated,
IDE02270-MAS00364,CAN input signal(s) status-Shift lever / selector lever position,Neutral,
IDE02270-MAS01281,CAN input signal(s) status-Back-up lamp,OFF,
IDE02270-MAS02357,CAN input signal(s) status-Vehicle identification,B261887,
IDE02270-MAS03992,CAN input signal(s) status-Clutch pedal switch: interlock position,active,
IDE02271-IDE03311,CAN output signal(s) status-Emergency braking display,not active,
IDE02271-IDE03660,CAN output signal(s) status-Longitudinal acceleration,0.09375, m/s²
IDE02492,Start/Stop Function: coding information,Start-stop function in control module active,
IDE02986-IDE04431,Indicator lamps-ASR and ESP indicator lamp,OFF,
IDE02986-IDE04451,Indicator lamps-Tire press monitoring display indictor lamp,OFF,
IDE02986-IDE04498,Indicator lamps--AUTO HOLD- Indicator Lamp,Not available due to specific system,
IDE02986-IDE04771,Indicator lamps-Indicator lamp for electro-mechanical parking brake malfunction,OFF,
IDE02986-MAS00253,Indicator lamps-ABS indicator lamp,OFF,
IDE02986-MAS00556,Indicator lamps-Electromechanical parking brake indicator lamp,On,
IDE02986-MAS01206,Indicator lamps-Hill descent control indicator lamp,OFF,
IDE02986-MAS02925,Indicator lamps-Brake system indicator lamp,OFF,
IDE02986-MAS03234,Indicator lamps-ESP_off indicator lamp,OFF,
IDE03008-IDE05181,Stop process prevented-Emerg.brake,not active,
IDE03008-MAS04513,Stop process prevented-ABS control module pump running,not active,
IDE03008-MAS04515,Stop process prevented-Roll back detection,not active,
IDE03009-IDE04446,Start process requested-Hill descent control,not active,
IDE03009-IDE06139,Start process requested-AUTO HOLD slippage recognition,not active,
IDE03009-MAS02515,Start process requested-System malfunction,not active,
IDE03009-MAS04485,Start process requested-ESP function deactivation,not active,
IDE03009-MAS04515,Start process requested-Roll back detection,not active,
IDE03010-IDE04446,Number of prevented stop processes-Hill descent control,2,
IDE03010-IDE05181,Number of prevented stop processes-Emerg.brake,0,
IDE03010-IDE06139,Number of prevented stop processes-AUTO HOLD slippage recognition,0,
IDE03010-MAS04485,Number of prevented stop processes-ESP function deactivation,0,
IDE03010-MAS04513,Number of prevented stop processes-ABS control module pump running,15,
IDE03010-MAS04515,Number of prevented stop processes-Roll back detection,0,
IDE03010-MAS07931,Number of prevented stop processes-Retaining function unavailable,0,
IDE03010-MAS07932,Number of prevented stop processes-Inclination limit,21,
IDE03011-IDE06139,Number of requested start processes-AUTO HOLD slippage recognition,0,
IDE03011-MAS02515,Number of requested start processes-System malfunction,0,
IDE03011-MAS04515,Number of requested start processes-Roll back detection,0,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2000,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2022,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,0,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,6,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,0,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,16,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,0,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,12,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,16,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,0,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,0,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,31,
IDE03127,Prevented stop processes (ring memory),Inclination limit,
IDE03127,Prevented stop processes (ring memory),Initial value,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2000,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,0,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,0,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,0,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,0,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,0,
IDE03128,Requested start processes (ring memory),Initial value,
IDE03207,Hardware version for suppliers,Texas_Instruments,
IDE03212,Start/stop conditions,Stop release,
IDE03213,Start/stop enable,No release by coordinator,
IDE03527-IDE02070,CAN signals-Wake-up cause,1,
IDE03527-IDE02445,CAN signals-Transmission type,24,
IDE03651,Bleed brake system (rework bleeding),0.00, s
IDE03680-IDE00018,Supply voltages-Voltage terminal 15,On,
IDE03680-IDE01232,Supply voltages-Supply voltage for external components,5.005, V
IDE03680-IDE04444,Supply voltages-Terminal 30 voltage for pump,0.014, V
IDE03680-IDE04445,Supply voltages-Terminal 30 voltage for valves,12.688, V
IDE03680-IDE04500,Supply voltages-Terminal 30 voltage for logic,On,
IDE04422-IDE04442,Brake system sensor-Vacuum sensor,-0.949, bar
IDE04422-IDE04450,Brake system sensor-Brake pressure sensor 1,31.30, bar
IDE04422-IDE04494,Brake system sensor-Brake pressure sensor 1: uncond voltage 1,Not available due to specific system,
IDE04422-IDE04495,Brake system sensor-Brake pressure sensor 1: uncond voltage 2,Not available due to specific system,
IDE04422-MAS00179,Brake system sensor-Brake lamp switch,operated,
IDE04422-MAS02152,Brake system sensor-EPB clutch pedal travel,Not available due to specific system,
IDE04425-IDE00920,Left front ABS wheel speed sensor-Front left wheel speed,0.0, km/h
IDE04425-IDE04435,Left front ABS wheel speed sensor-Air gap,65535, mm
IDE04425-MAS01466,Left front ABS wheel speed sensor-Direction of rotation,forward,
IDE04426-IDE00921,Right front ABS wheel speed sensor-Wheel speed: right front,0.0, km/h
IDE04426-IDE04435,Right front ABS wheel speed sensor-Air gap,65535, mm
IDE04426-MAS01466,Right front ABS wheel speed sensor-Direction of rotation,forward,
IDE04427-IDE00922,Left rear ABS wheel speed sensor-Left rear wheel speed,0.0, km/h
IDE04427-IDE04435,Left rear ABS wheel speed sensor-Air gap,65535, mm
IDE04427-MAS01466,Left rear ABS wheel speed sensor-Direction of rotation,forward,
IDE04428-IDE00923,Right rear ABS wheel speed sensor-Right rear wheel speed,0.0, km/h
IDE04428-IDE04435,Right rear ABS wheel speed sensor-Air gap,65535, mm
IDE04428-MAS01466,Right rear ABS wheel speed sensor-Direction of rotation,forward,
IDE04442-IDE00009,Vacuum sensor-Date of manufacture,KW 21 2021,
IDE04442-IDE00010,Vacuum sensor-Serial number,00 09 32 50 73,
IDE04442-IDE00104,Vacuum sensor-DTC,0,
IDE04442-IDE02955,Vacuum sensor-System status,available.,
IDE04442-IDE03205,Vacuum sensor-Manufacturer code,5,
IDE04442,Vacuum sensor,-0.94, bar
IDE04442-MAS12759,Vacuum sensor-Type of individual vacuum sensor,0,
IDE04443-IDE02241,Slip control system sensor-Lateral acceleration sensor 1,0.05886, m/s²
IDE04443-IDE02538,Slip control system sensor-Longitude Acceleration Sensor,0.33354, m/s²
IDE04443-IDE04429,Slip control system sensor-Lateral acceleration sensor 1: offset,-0.00000, m/s²
IDE04443-IDE04430,Slip control system sensor-Longitudinal acceleration sensor: offset,0.12500, m/s²
IDE04443-IDE04449,Slip control system sensor-Rotation rate sensor 1: Z-axis,0.172, °/s
IDE04443-IDE04460,Slip control system sensor-Steering angle sensor: offset straight line running,-4.156, °
IDE04443-MAS00815,Slip control system sensor-Steering angle sensor,-4.156, °
IDE04446-IDE01599,Hill descent control-Incline,1, %
IDE04446-IDE02955,Hill descent control-System status,available.,
IDE04446-IDE03664,Hill descent control-Button for driving program,not activated,
IDE04446-MAS03095,Hill descent control-Function status,not active,
IDE04452-IDE03662,Brake system button-ASR/ESP button,Not operated,
IDE04452-IDE03663,Brake system button--AUTO HOLD- Button,Not available due to specific system,
IDE04452-IDE03664,Brake system button-Button for driving program,Not operated,
IDE04452-IDE04432,Brake system button-Tire Pressure Monitoring Display Button,Not operated,
IDE04452-IDE04769,Brake system button-Electro-mechanical parking brake button: status,Not operated,
IDE04456-IDE02955,Brake disk drying-System status,available.,
IDE04456-IDE04775,Brake disk drying-Odometer reading of last activation,0, km
IDE04461-IDE03208,Internal measured values-Software version for suppliers,MXDRAE00027,
IDE04461-IDE03649,Internal measured values-Fill/bleed brake system,not completed successfully,
IDE04461-MAS01481,Internal measured values-Temperature in control module,33, °C
IDE04461-MAS04484,Internal measured values-Flashloader version, TSCBAF00012,
IDE04499-IDE02955,Sensor for roof rack recognition-System status,Not available due to specific system,
IDE04499-MAS03095,Sensor for roof rack recognition-Function status,not detected,
IDE04508-IDE02955,Hydraulic brake booster-System status,available.,
IDE04508-IDE04442,Hydraulic brake booster-Vacuum sensor,-949, mbar
IDE04508-IDE04450,Hydraulic brake booster-Brake pressure sensor 1,31.30, bar
IDE04508-MAS03095,Hydraulic brake booster-Function status,not active,
IDE04508-MAS04002,Hydraulic brake booster-Low intake manifold pressure,720, mbar
IDE04644-IDE02955,Roll-over protection-System status,available.,
IDE04644-IDE04775,Roll-over protection-Odometer reading of last activation,0, km
IDE04645-IDE00003,Electromechanical parking brake-Coding,will be performed.,
IDE04645-IDE00902,Electromechanical parking brake-Automatic distance control: status,activated,
IDE04645-IDE02652,Electromechanical parking brake-Start-stop status,activated,
IDE04645-IDE02955,Electromechanical parking brake-System status,available.,
IDE04645-IDE03493,Electromechanical parking brake-Driver's door status,activated,
IDE04645-IDE04871,Electromechanical parking brake-Dynamic starting assist,activated,
IDE04645-IDE04944,Electromechanical parking brake-Brake pedal evaluation,activated,
IDE04645-IDE04948,Electromechanical parking brake-Fall-back level,0,
IDE04645-IDE05711,Electromechanical parking brake-Automatic application during engine stalling,activated,
IDE04645-IDE06590,Electromechanical parking brake-Play protection counter: button for electromech. parking brake,0,
IDE04645-MAS02666,Electromechanical parking brake-Seat belt buckle scan,activated,
IDE04645-MAS03998,Electromechanical parking brake-Delay interface for electro-mechanical parking brake,6,
IDE04645-IDE02657,Electromechanical parking brake-Cut-off current: left: reached,0.00, A
IDE04645-IDE02658,Electromechanical parking brake-Cut-off current: right: reached,0.00, A
IDE04645-IDE04496,Electromechanical parking brake-Left parking brake motor: status,closed,
IDE04645-IDE04497,Electromechanical parking brake-Right parking brake motor: status,closed,
IDE04645-IDE04506,Electromechanical parking brake-Calculated left rear brake temperature,30.5, °C
IDE04645-IDE04507,Electromechanical parking brake-Calculated right rear brake temperature,30.5, °C
IDE04645-IDE04647,Electromechanical parking brake-Left parking brake motor: current,0.00, A
IDE04645-IDE04648,Electromechanical parking brake-Right parking brake motor: current,0.00, A
IDE04645-IDE05048,Electromechanical parking brake-Left parking brake motor: actuation counter,27,
IDE04645-IDE05049,Electromechanical parking brake-Right parking brake motor: actuation counter,27,
IDE04765-IDE02955,Counter steer support-System status,available.,
IDE04765-IDE04775,Counter steer support-Odometer reading of last activation,94, km
IDE04772-IDE03530,Indicator light in the button for electromech. parking brake-Monitoring status,7,
IDE04772-MAS03745,Indicator light in the button for electromech. parking brake-Function light,On,
IDE04774-IDE02955,Vehicle and trailer stabilization-System status,Not available due to specific system,
IDE04774-IDE04775,Vehicle and trailer stabilization-Odometer reading of last activation,0, km
IDE04871-IDE01599,Dynamic starting assist-Incline,1, %
IDE04871-IDE02445,Dynamic starting assist-Transmission type,automatic,
IDE04871-MAS01447,Dynamic starting assist-Act.val.,normal,
IDE04871-MAS03995,Dynamic starting assist-Clutch pedal threshold: initial value,60, %
IDE04871-MAS03996,Dynamic starting assist-Clutch pedal threshold: learned value,0, %
IDE04871-MAS04734,Dynamic starting assist-Required engine torques: current slope (TARGET),0, Nm
IDE04871-MAS04735,Dynamic starting assist-Current engine torques (ACTUAL),0, Nm
IDE04871-MAS04736,Dynamic starting assist-Expected achievable engine torques,0, Nm
IDE04939-IDE02955,Tire Pressure Monitoring System (TPMS)-System status,available.,
IDE04939-IDE04248,Tire Pressure Monitoring System (TPMS)-Left front tire pressure diffusion indicator,254,
IDE04939-IDE04249,Tire Pressure Monitoring System (TPMS)-Right front tire pressure diffusion indicator,254,
IDE04939-IDE04250,Tire Pressure Monitoring System (TPMS)-Left rear tire pressure diffusion indicator,254,
IDE04939-IDE04251,Tire Pressure Monitoring System (TPMS)-Right rear tire pressure diffusion indicator,254,
IDE04939-IDE04432,Tire Pressure Monitoring System (TPMS)-Tire Pressure Monitoring Display Button,Not operated,
IDE04939-IDE04946,Tire Pressure Monitoring System (TPMS)-Odometer reading at last adaptation,0, km
IDE04939-IDE04947,Tire Pressure Monitoring System (TPMS)-Odometer reading of last warning,0, km
IDE04939-MAS04538,Tire Pressure Monitoring System (TPMS)-Odometer reading two adaptations ago,0, km
IDE04939-MAS04539,Tire Pressure Monitoring System (TPMS)-Odometer reading three adaptations ago,0, km
IDE04939-MAS04540,Tire Pressure Monitoring System (TPMS)-Odometer reading four adaptations ago,0, km
IDE04939-MAS04541,Tire Pressure Monitoring System (TPMS)-Odometer reading of next-to-last warning,0, km
IDE04939-MAS04542,Tire Pressure Monitoring System (TPMS)-Odometer reading of third-to-last warning,0, km
IDE04939-MAS04543,Tire Pressure Monitoring System (TPMS)-Odometer reading of fourth-to-last warning,0, km
IDE04939-MAS04544,Tire Pressure Monitoring System (TPMS)-Left front flat tire indicator,255,
IDE04939-MAS04545,Tire Pressure Monitoring System (TPMS)-Right front flat tire indicator,255,
IDE04939-MAS04546,Tire Pressure Monitoring System (TPMS)-Left rear flat tire indicator,255,
IDE04939-MAS04547,Tire Pressure Monitoring System (TPMS)-Right rear flat tire indicator,255,
IDE05712-IDE02955,AUTO HOLD-System status,Not available due to specific system,
IDE05712-IDE03530,AUTO HOLD-Monitoring status,7,
IDE05712-IDE04498,AUTO HOLD--AUTO HOLD- Indicator Lamp,OFF,
IDE05712-IDE04561,AUTO HOLD-Switch-on and shut-off conditions,valid,
IDE05712-IDE05333,AUTO HOLD-Indicator light in AUTO HOLD button,OFF,
IDE05712-MAS00025,AUTO HOLD-Driver seat belt switch,not connected,
IDE05712-MAS03095,AUTO HOLD-Function status,not active,
IDE05712-MAS04006,AUTO HOLD-Operating mode,Last setting,
IDE05712-MAS04409,AUTO HOLD-Active hold,not active,
IDE05712-MAS04411,AUTO HOLD-Hydraulic pressure transfer to electro-mechanical parking brake,No,
IDE06591-ENG118150,Pump load counter-Comp_Rotatation_of_pump_motor,5733,
IDE06591-ENG118152,Pump load counter-Load_on_feeding_side_of_Pump,66344,
IDE06591-ENG118151,Pump load counter-Load_on_suction_side_of_Pump,72,
IDE06591-ENG118153,Pump load counter-Pump_motor_start_counter,129,
IDE07280-IDE04775,Multiple collision brake-Odometer reading of last activation,0, km
IDE07280-IDE06609,Multiple collision brake-Odometer reading of last deactivation,0, km
IDE07280-MAS00106,Multiple collision brake-Year,2000,
IDE07280-MAS00107,Multiple collision brake-Month,0,
IDE07280-MAS00108,Multiple collision brake-Day,0,
IDE07280-MAS00109,Multiple collision brake-Hours,0,
IDE07280-MAS00110,Multiple collision brake-Minutes,0,
IDE07280-MAS00111,Multiple collision brake-Seconds,0,
IDE07280-MAS07659,Multiple collision brake-Frequency counter for multi-collision brake active,0,
IDE07280-MAS07660,Multiple collision brake-Frequency counter for multi-collision brake deactivated,0,
IDE07280-MAS07661,Multiple collision brake-Frequency counter function deactivated by driver,0,
IDE07280-MAS07662,Multiple collision brake-Mileage reading of the last deactivation by driver,0, km
IDE80101,Analysis 101,A3 32 38 35 31 36 33 32 35 32 31 33 30 30 30 30 35 32 32 31 31 33 30 30 30 38 41 2F 02 07 3E 45 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80102-ENG122580,Analysis 102-value_1_percentaged,103.118, %
IDE80102-ENG122579,Analysis 102-value_1_quantity,0,
IDE80102-ENG122582,Analysis 102-value_2_percentaged,102.728, %
IDE80102-ENG122581,Analysis 102-value_2_quantity,0,
IDE80102-ENG122584,Analysis 102-value_3_percentaged,98.0406, %
IDE80102-ENG122583,Analysis 102-value_3_quantity,17,
IDE80102-ENG122586,Analysis 102-value_4_percentaged,103.9, %
IDE80102-ENG122585,Analysis 102-value_4_quantity,27,
IDE80102-ENG122588,Analysis 102-value_5_percentaged,98.4312, %
IDE80102-ENG122587,Analysis 102-value_5_quantity,4,
IDE80102-ENG122590,Analysis 102-value_6_percentaged,103.118, %
IDE80102-ENG122589,Analysis 102-value_6_quantity,17,
IDE80103-MAS00976,Analysis 103-Counter,0,
MAS00121-IDE02955,Electronic Differential Lock-System status,available.,
MAS00121-IDE04504,Electronic Differential Lock-Calculated left front brake temperature,30.5, °C
MAS00121-IDE04505,Electronic Differential Lock-Calculated right front brake temperature,30.5, °C
MAS00121-IDE04506,Electronic Differential Lock-Calculated left rear brake temperature,30.5, °C
MAS00121-IDE04507,Electronic Differential Lock-Calculated right rear brake temperature,30.5, °C
MAS00121-MAS00179,Electronic Differential Lock-Brake lamp switch,operated,
MAS00121-MAS01853,Electronic Differential Lock-Left front,available.,
MAS00121-MAS01854,Electronic Differential Lock-Right front,available.,
MAS00121-MAS01855,Electronic Differential Lock-Left rear,available.,
MAS00121-MAS01856,Electronic Differential Lock-Right rear,available.,
MAS00210-IDE80007,Parking Brake-Analysis 7,0, km
MAS00210-IDE80008,Parking Brake-Analysis 8,156, km
MAS00210-IDE80009,Parking Brake-Analysis 9,0, km
MAS00210-IDE80010,Parking Brake-Analysis 10,0, km
MAS00210-IDE80011,Parking Brake-Analysis 11,156, km
MAS00210-IDE80012,Parking Brake-Analysis 12,8F 0A 11 10 02 0C,
MAS00210-ENG167752,Parking Brake-ActDbg_ECR_EvCnt,0,
MAS00210-ENG167753,Parking Brake-ActDbg_ESA_EvCnt,0,
MAS00210-ENG167754,Parking Brake-ActDbg_OTH_EvCnt,0,
MAS00210-ENG167755,Parking Brake-ActDbg_SAR_EvCnt,0,
MAS00210-ENG167756,Parking Brake-ActDbg_UV_EvCnt,0,
MAS00210-ENG167757,Parking Brake-ActDbg_UVE_EvCnt,0,
MAS00911-IDE02955,All Wheel Drive (AWD)-System status,available.,
MAS00911-IDE04502,All Wheel Drive (AWD)-Haldex clutch: status,No malfunction detected,
MAS00911-IDE04943,All Wheel Drive (AWD)-Haldex clutch,Not open,
MAS00911-MAS04730,All Wheel Drive (AWD)-Degree of blockage,20.4, %
MAS02138-IDE02955,Hill-start assistant-System status,available.,
MAS02138-MAS00025,Hill-start assistant-Driver seat belt switch,not connected,
MAS02138-MAS00218,Hill-start assistant-Driver door,Open,
MAS02138-MAS03095,Hill-start assistant-Function status,Condition not met,
MAS02426-MAS00580,Text display in instrument cluster-Electromechanical parking brake text 1,0,
MAS02426-MAS03359,Text display in instrument cluster-Text,0,
MAS02672-IDE02955,Start-stop-System status,available.,
MAS02672-IDE03214,Start-stop-Engine stop using start-stop function,not active,
MAS02672-IDE03215,Start-stop-Engine start using start-stop function,not active,
MAS02672-MAS00025,Start-stop-Driver seat belt switch,not connected,
MAS08072-MAS13685,Driving profile selection-Actual value of downhill driving assistant,2,
MAS08072-MAS13686,Driving profile selection-Actual value uphill driving assistant,2,
MAS08072-MAS13687,Driving profile selection-Actual value of differential lock,2,
MAS08072-MAS13688,Driving profile selection-ESC actual value,2,
MAS08072-MAS13689,Driving profile selection-Compatibility of downhill driving assistant,Yes,
MAS08072-MAS13690,Driving profile selection-Compatibility of uphill driving assistant,Yes,
MAS08072-MAS13691,Driving profile selection-Compatibility of differential lock,Yes,
MAS08072-MAS13692,Driving profile selection-ESC compatibility,Yes,
MAS08072-MAS13693,Driving profile selection-Spec. value of downhill driving assistant,2,
MAS08072-MAS13694,Driving profile selection-Spec. value of uphill driving assistant,2,
MAS08072-MAS13695,Driving profile selection-Spec. value of differential lock,2,
MAS08072-MAS13696,Driving profile selection-ESC spec. value,2,
MAS08072-MAS13697,Driving profile selection-System status of downhill driving assistant,available.,
MAS08072-MAS13698,Driving profile selection-System status uphill driving assistant,available.,
MAS08072-MAS13699,Driving profile selection-System status of differential lock,available.,
MAS08072-MAS13700,Driving profile selection-ESC system status,available.,
MAS08072-MAS13701,Driving profile selection-Switchover status of downhill driving assistant,Shifting carried out,
MAS08072-MAS13702,Driving profile selection-Switchover status of uphill driving assistant,Shifting carried out,
MAS08072-MAS13703,Driving profile selection-ESC switchover status,Shifting carried out,
MAS08072-MAS13704,Driving profile selection-Switchover status_differential lock,Shifting carried out,
ENG157353-IDE01011,HBV_Event_Counter-Data record,0,
Elapsed Time: 00:15,,,
blockmap-05-3Q0-959-435-Q_3VV2X7B28NM061887-20220618-1233.CSV
;SW:3Q0-959-435-Q   HW:3Q0-959-435-Q ---  Acc/Start Auth.
;Component:VWKESSYMQB    037 1400, Coding:132C0C0723
;EV_KessyHellaMQBAB,004055,EV_KessyHellaMQBAB.rod
;Saturday,18,June,2022,12:33:21:14741
;VCID: C8C2B36AA230E21BDB2-809C
IDE00019,Voltage terminal 30,12.667, V
IDE00021,Engine RPM,1378.0, /min
IDE00021-MAS02248,Engine RPM-Signal state,valid,
IDE00075,Vehicle speed,0.0, km/h
IDE00075-MAS02248,Vehicle speed-Signal state,valid,
IDE00096-MAS02248,Selector lever position-Signal state,Up-to-date,
IDE00096,Selector lever position,OK,
IDE00322,Status of basic setting,Basic setting ended,
IDE02406,Key number of last identified ID sensor,ID sensor 2,
IDE02407,Status of vehicle locking,Vehicle unlocked at single door,
IDE02408-MAS00218,Individual door locking: status-Driver door,Open,
IDE02408-MAS00219,Individual door locking: status-Front Passenger Door,closed,
IDE02408-MAS00220,Individual door locking: status-Left rear door,closed,
IDE02408-MAS00221,Individual door locking: status-Right rear door,closed,
IDE02409,ID-sensor 1 authentication: status,No response,
IDE02410,ID-sensor 2 authentication: status,No response,
IDE02411,ID-sensor 3 authentication: status,No response,
IDE02412,ID-sensor 4 authentication: status,No response,
IDE02413,Door handle touch sensor: last operation,Driver door,
IDE02414-MAS00080,Driver exterior door handle touch sensor-Coding information,coded,
IDE02414-MAS02176,Driver exterior door handle touch sensor-Approach to the inside,not active,
IDE02414-MAS02177,Driver exterior door handle touch sensor-Actuation to the inside,not active,
IDE02414-MAS02178,Driver exterior door handle touch sensor-Approach to the outside,not active,
IDE02414-MAS02179,Driver exterior door handle touch sensor-Actuation to the outside,not active,
IDE02414-MAS02451,Driver exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02415-MAS00080,Front passenger exterior door handle touch sensor-Coding information,coded,
IDE02415-MAS02176,Front passenger exterior door handle touch sensor-Approach to the inside,not active,
IDE02415-MAS02177,Front passenger exterior door handle touch sensor-Actuation to the inside,not active,
IDE02415-MAS02178,Front passenger exterior door handle touch sensor-Approach to the outside,not active,
IDE02415-MAS02179,Front passenger exterior door handle touch sensor-Actuation to the outside,not active,
IDE02415-MAS02451,Front passenger exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02416-MAS00080,Left rear outside door handle touch sensor-Coding information,Not coded,
IDE02416-MAS02176,Left rear outside door handle touch sensor-Approach to the inside,not active,
IDE02416-MAS02177,Left rear outside door handle touch sensor-Actuation to the inside,not active,
IDE02416-MAS02178,Left rear outside door handle touch sensor-Approach to the outside,not active,
IDE02416-MAS02179,Left rear outside door handle touch sensor-Actuation to the outside,not active,
IDE02416-MAS02451,Left rear outside door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02417-MAS00080,Right rear outside door handle touch sensor-Coding information,Not coded,
IDE02417-MAS02176,Right rear outside door handle touch sensor-Approach to the inside,not active,
IDE02417-MAS02177,Right rear outside door handle touch sensor-Actuation to the inside,not active,
IDE02417-MAS02178,Right rear outside door handle touch sensor-Approach to the outside,not active,
IDE02417-MAS02179,Right rear outside door handle touch sensor-Actuation to the outside,not active,
IDE02417-MAS02451,Right rear outside door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02418,Proximity sensor driver door: number of triggers,19,
IDE02419,Proximity sensor frt.pass. door: number of triggers,4,
IDE02420,Proximity sensor left rear door: number of triggers,0,
IDE02421,Proximity sensor right rear door: number of triggers,0,
IDE02422-MAS01482,Driver door handle: version information-Hardware version,FF,
IDE02422-MAS01483,Driver door handle: version information-Software version,FF,
IDE02422-MAS04065,Driver door handle: version information-EEPROM,FF,
IDE02423-MAS01482,ass. door handle: version information-Hardware version,FF,
IDE02423-MAS01483,ass. door handle: version information-Software version,FF,
IDE02423-MAS04065,ass. door handle: version information-EEPROM,FF,
IDE02424-MAS01482,Left rear door handle: version information-Hardware version,FF,
IDE02424-MAS01483,Left rear door handle: version information-Software version,FF,
IDE02424-MAS04065,Left rear door handle: version information-EEPROM,FF,
IDE02425-MAS01482,Right rear door handle: version information-Hardware version,FF,
IDE02425-MAS01483,Right rear door handle: version information-Software version,FF,
IDE02425-MAS04065,Right rear door handle: version information-EEPROM,FF,
IDE02426-MAS02398,Key number last identified in left exterior area-ID sensor 1,No,
IDE02426-MAS02399,Key number last identified in left exterior area-ID sensor 2,Yes,
IDE02426-MAS02400,Key number last identified in left exterior area-ID sensor 3,No,
IDE02426-MAS02401,Key number last identified in left exterior area-ID sensor 4,No,
IDE02427-MAS02398,Key number last identified in right exterior area-ID sensor 1,Yes,
IDE02427-MAS02399,Key number last identified in right exterior area-ID sensor 2,Yes,
IDE02427-MAS02400,Key number last identified in right exterior area-ID sensor 3,No,
IDE02427-MAS02401,Key number last identified in right exterior area-ID sensor 4,No,
IDE02428-MAS02398,Key number last identified in rear exterior area-ID sensor 1,No,
IDE02428-MAS02399,Key number last identified in rear exterior area-ID sensor 2,Yes,
IDE02428-MAS02400,Key number last identified in rear exterior area-ID sensor 3,No,
IDE02428-MAS02401,Key number last identified in rear exterior area-ID sensor 4,No,
IDE02429-MAS02398,Key number last identified in interior area-ID sensor 1,No,
IDE02429-MAS02399,Key number last identified in interior area-ID sensor 2,No,
IDE02429-MAS02400,Key number last identified in interior area-ID sensor 3,No,
IDE02429-MAS02401,Key number last identified in interior area-ID sensor 4,No,
IDE02430-MAS02398,Key number last identified in luggage compartment area-ID sensor 1,Yes,
IDE02430-MAS02399,Key number last identified in luggage compartment area-ID sensor 2,Yes,
IDE02430-MAS02400,Key number last identified in luggage compartment area-ID sensor 3,No,
IDE02430-MAS02401,Key number last identified in luggage compartment area-ID sensor 4,No,
IDE02466,Play protection activation counter driver door,0,
IDE02467,Play protection activation counter frt.pass. door,0,
IDE02468,Play protection activation counter left rear door,0,
IDE02469,Play protection activation counter right rear door,0,
IDE02482,72h-Signaling counter driver door,0,
IDE02483,72-hour signaling counter frt.pass. door,0,
IDE02484,72h-Signaling counter left rear door,0,
IDE02485,72h-Signaling counter right rear door,0,
IDE02495,Service-Key: Number of activations,28,
IDE02496,Service-Key: Number of Timeouts,0,
IDE02497,Service-Key: Number of incomplete messages,0,
IDE02569-MAS02240,Terminal S: line status-Steering column lock specified value,On,
IDE02569-MAS02241,Terminal S: line status-Steering column lock actual value,On,
IDE02569-MAS02242,Terminal S: line status-Electronic central electric actual value,On,
IDE02570-MAS02240,Terminal 15: line status-Steering column lock specified value,On,
IDE02570-MAS02241,Terminal 15: line status-Steering column lock actual value,On,
IDE02570-MAS02242,Terminal 15: line status-Electronic central electric actual value,On,
IDE02571-MAS02240,Terminal 50: line status-Steering column lock specified value,OFF,
IDE02571-MAS02241,Terminal 50: line status-Steering column lock actual value,OFF,
IDE02572-MAS02350,Starter button: status-Switch contact 1,Not operated,
IDE02572-MAS02351,Starter button: status-Switch contact 2,Not operated,
IDE02579,Park selector lever position,Engaged and locked,
IDE02581,Drive train uncoupling,decoupled,
IDE02582-MAS00179,Brake activation: switch status-Brake lamp switch,On,
IDE02582-MAS02248,Brake activation: switch status-Signal state,valid,
IDE02582-MAS02253,Brake activation: switch status-Brake test switch,On,
IDE02589,Rotary latch status,For,
IDE02590-MAS02256,External vehicle locking: SPECIFIED condition-SPECIFIED condition of lock per remote/key,unlocked,
IDE02590-MAS02257,External vehicle locking: SPECIFIED condition-SPECIFIED condition of fuse per remote/key,Vehicle not secured,
IDE02760-MAS02240,Terminal 15 redundancy: line status-Steering column lock specified value,On,
IDE02760-MAS02241,Terminal 15 redundancy: line status-Steering column lock actual value,On,
IDE02760-MAS02242,Terminal 15 redundancy: line status-Electronic central electric actual value,On,
IDE03008-MAS05971,Stop process prevented-Missing from ECM,not active,
IDE03008-MAS06116,Stop process prevented-Antenna malfunction of a go-relevant antenna,not active,
IDE03008-MAS06118,Stop process prevented-ID sensor not found,not active,
IDE03008-MAS06119,Stop process prevented-CAN Signal: read coil operation is set,not active,
IDE03009-MAS12704,Start process requested-System error if motor stops,not active,
IDE03010-MAS05971,Number of prevented stop processes-Missing from ECM,3,
IDE03010-MAS06116,Number of prevented stop processes-Antenna malfunction of a go-relevant antenna,0,
IDE03010-MAS06118,Number of prevented stop processes-ID sensor not found,5,
IDE03010-MAS06119,Number of prevented stop processes-CAN Signal: read coil operation is set,0,
IDE03011-MAS12704,Number of requested start processes-System error if motor stops,0,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,3,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,19,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,4,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,22,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,37,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,7,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,15,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,52,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,1,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,45,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,36,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,29,
IDE03127-MAS02886,Prevented stop processes (ring memory)-Last prohibited stop,Missing from ECM,
IDE03127-MAS02888,Prevented stop processes (ring memory)-Penultimate prohibited stop,ID sensor not found,
IDE03127-MAS02890,Prevented stop processes (ring memory)-Third-last prohibited stop,ID sensor not found,
IDE03127-MAS02892,Prevented stop processes (ring memory)-Fourth last prohibited stop,Missing from ECM,
IDE03127-MAS02894,Prevented stop processes (ring memory)-Fifth-last prohibited stop,ID sensor not found,
IDE03128,Requested start processes (ring memory),Empty,
IDE03527-MAS04444,CAN signals-Wake-up,not active,
IDE03527-MAS05102,CAN signals-Driver information: emergency shutdown,not active,
IDE03527-MAS05103,CAN signals-Driver information: roll warning,not active,
IDE03527-MAS08112,CAN signals-Drive readiness,not active,
IDE03527-MAS09771,CAN signals-Driver information comfort switching,not active,
IDE03527-MAS10894,CAN signals-Hybrid error,not active,
IDE03527-MAS10895,CAN signals-Driver information key position copy workshop,not active,
IDE04042-ENG123041,ID sensor history data-Scan 1: Scan_origin_en,PASSIVE_GO,
IDE04042-ENG123040,ID sensor history data-Scan 1: Scan_trigger_en,GO_AUTHENTIFICATION_REQUEST,
IDE04042-ENG123042,ID sensor history data-Scan 1: Single_scan_en,INTERIOR_WITH_TRUNK,
IDE04042-ENG123043,ID sensor history data-Scan 1: Trigger_Information_u8,62,
IDE04042-ENG123045,ID sensor history data-Scan 2: Scan_origin_en,PASSIVE_GO,
IDE04042-ENG123044,ID sensor history data-Scan 2: Scan_trigger_en,GO_ID_REQUEST,
IDE04042-ENG123046,ID sensor history data-Scan 2: Single_scan_en,INTERIOR_WITH_TRUNK,
IDE04042-ENG123047,ID sensor history data-Scan 2: Trigger_Information_u8,52,
IDE04042-ENG123049,ID sensor history data-Scan 3: Scan_origin_en,PASSIVE_GO,
IDE04042-ENG123048,ID sensor history data-Scan 3: Scan_trigger_en,GO_AUTHENTIFICATION_REQUEST,
IDE04042-ENG123050,ID sensor history data-Scan 3: Single_scan_en,INTERIOR_WITH_TRUNK,
IDE04042-ENG123051,ID sensor history data-Scan 3: Trigger_Information_u8,62,
IDE05204,Manufacturer production data door handle drivers door,FF FF FF FF FF,
IDE05205,Manufacturer production data door handle front pass.door,FF FF FF FF FF,
IDE05206,Manufacturer production data door handle left rear,FF FF FF FF FF,
IDE05207,Manufacturer production data door handle right rear,FF FF FF FF FF,
IDE07028,Time until shut-off terminal S,1800, s
IDE07290-MAS08119,Conditions for turning on the ignition-Request active,Condition not met,
IDE07290-MAS08136,Conditions for turning on the ignition-Enabling Steering Column Lock,Condition met,
IDE07290-MAS08137,Conditions for turning on the ignition-Enabling immobilizer,Condition not met,
IDE07290-MAS08138,Conditions for turning on the ignition-No active error mode,Condition met,
IDE07290-MAS08139,Conditions for turning on the ignition-Key signature validity,Condition met,
IDE07359,Dimming of starter button lighting,100,
IDE08440,Recommendation energy management,no restriction,
IDE14837-MAS19401,Outer door handle switch: status-Driver Side Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19402,Outer door handle switch: status-Front Passenger Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19403,Outer door handle switch: status-Rear Passenger Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19404,Outer door handle switch: status-Rear Driver Side Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19405,Outer door handle switch: status-Driver Side Exterior Door Handle Switch: locked,not active,
IDE14837-MAS19406,Outer door handle switch: status-Front Passenger Exterior Door Handle Switch: locked,not active,
IDE14837-MAS19407,Outer door handle switch: status-Rear Passenger Exterior Door Handle Switch: locked,not active,
IDE14837-MAS19408,Outer door handle switch: status-Rear Driver Side Exterior Door Handle Switch: locked,not active,
IDE80258,Immobilizer status,Electronic steering locking device not installed,
IDE80258-MAS00106,Immobilizer status-Year,2022,
IDE80258-MAS00107,Immobilizer status-Month,3,
IDE80258-MAS00108,Immobilizer status-Day,16,
IDE80258-MAS00109,Immobilizer status-Hours,4,
IDE80258-MAS00110,Immobilizer status-Minutes,36,
IDE80258-MAS00111,Immobilizer status-Seconds,4,
IDE80258-MAS02349,Immobilizer status-Learn mode,Adapted,
IDE80258-MAS06793,Immobilizer status-Number of adapted keys,02,
MAS00025,Driver seat belt switch,not connected,
MAS00464-MAS00106,Standard - ambient data 1-Year,2022,
MAS00464-MAS00107,Standard - ambient data 1-Month,6,
MAS00464-MAS00108,Standard - ambient data 1-Day,18,
MAS00464-MAS00109,Standard - ambient data 1-Hours,10,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,33,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,5,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,19,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,156, km
MAS01493,Engine running,active,
MAS03554,Clutch pedal operation,Yes,
MAS03607,Engine stop active in Start/Stop mode,active,
MAS04004,Transmission code,OK,
MAS05104,Driver request: start engine,not active,
MAS08076,Exiting the vehicle,Condition not met,
MAS08788,Driving Cycle,Condition not met,
MAS08790,Driver absence,Condition not met,
MAS09771,Driver information comfort switching,No switch-off,
ENG125217,Active_requirement_light_lag,not activated,
ENG129039-ENG129149,Car_keys_RSSI_measurements-Abort_counter,0,
ENG129039-ENG129148,Car_keys_RSSI_measurements-Easy_close_function_counter,0,
ENG129039-ENG129150,Car_keys_RSSI_measurements-Last_abort_reason,none,
ENG129039-ENG160891,Car_keys_RSSI_measurements-RSSI_Value_1,0,
ENG129039-ENG160890,Car_keys_RSSI_measurements-RSSI_Value_2,0,
ENG129039-ENG160889,Car_keys_RSSI_measurements-RSSI_Value_3,0,
ENG129039-ENG160888,Car_keys_RSSI_measurements-RSSI_Value_4,0,
ENG102274,Control Module Voltage,12.661, V
ENG139762,Easy_open_unavailable_reason,Kl15_is_active,
ENG129032,ELV_Status,ELV_Entriegelt,
ENG245551,Enginestart_variant_coded,---,
ENG125220-MAS00106,History last automatic terminal switch off-Year,2000,
ENG125220-MAS00107,History last automatic terminal switch off-Month,0,
ENG125220-MAS00108,History last automatic terminal switch off-Day,0,
ENG125220-MAS00109,History last automatic terminal switch off-Hours,0,
ENG125220-MAS00110,History last automatic terminal switch off-Minutes,0,
ENG125220-MAS00111,History last automatic terminal switch off-Seconds,0,
ENG125220-ENG125227,History last automatic terminal switch off-Mileage_shutoff_reason_n,0, km
ENG125220-ENG125230,History last automatic terminal switch off-Mileage_shutoff_reason_n-1,0, km
ENG125220-ENG125233,History last automatic terminal switch off-Mileage_shutoff_reason_n-2,0, km
ENG125220-ENG125236,History last automatic terminal switch off-Mileage_shutoff_reason_n-3,0, km
ENG125220-ENG125239,History last automatic terminal switch off-Mileage_shutoff_reason_n-4,0, km
ENG125220-ENG125225,History last automatic terminal switch off-shutoff_reason_n,Leaving the car,
ENG125220-ENG125228,History last automatic terminal switch off-shutoff_reason_n-1,Leaving the car,
ENG125220-ENG125231,History last automatic terminal switch off-shutoff_reason_n-2,Leaving the car,
ENG125220-ENG125234,History last automatic terminal switch off-shutoff_reason_n-3,Leaving the car,
ENG125220-ENG125237,History last automatic terminal switch off-shutoff_reason_n-4,Leaving the car,
ENG249150-MAS00111,History_low_voltage-Seconds,0, s
ENG249150-ENG249469,History_low_voltage-Function_restriction_n,No_function_restriction,
ENG249150-ENG249453,History_low_voltage-Function_restriction_n-1,No_function_restriction,
ENG249150-ENG249295,History_low_voltage-Function_restriction_n-2,No_function_restriction,
ENG249150-ENG249381,History_low_voltage-Function_restriction_n-3,No_function_restriction,
ENG249150-ENG249352,History_low_voltage-Function_restriction_n-4,No_function_restriction,
ENG249150-ENG249461,History_low_voltage-Function_restriction_n-5,No_function_restriction,
ENG249150-ENG249401,History_low_voltage-Function_restriction_n-6,No_function_restriction,
ENG249150-ENG249354,History_low_voltage-Function_restriction_n-7,No_function_restriction,
ENG249150-ENG249339,History_low_voltage-Function_restriction_n-8,No_function_restriction,
ENG249150-ENG249350,History_low_voltage-Function_restriction_n-9,No_function_restriction,
ENG129040-ENG129151,History_of_last _reset_reason-Last_1_reset_reason,ECUEXT_RR_WDGM_TEST_EARLY,
ENG129040-ENG129152,History_of_last _reset_reason-Last_2_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG129153,History_of_last _reset_reason-Last_3_reset_reason,ECUEXT_RR_WDGM_TEST_LATE,
ENG129040-ENG129154,History_of_last _reset_reason-Last_4_reset_reason,ECUEXT_RR_WDGM_TEST_EARLY,
ENG129040-ENG129155,History_of_last _reset_reason-Last_5_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG129156,History_of_last _reset_reason-Last_6_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG129157,History_of_last _reset_reason-Last_7_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG129158,History_of_last _reset_reason-Last_8_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG129159,History_of_last _reset_reason-Last_9_reset_reason,SBC_UNDERVOLTAGE_RESET,
ENG129040-ENG124545,History_of_last _reset_reason-Last_reset_reason,ECUEXT_RR_WDGM_TEST_LATE,
ENG247070-ENG247201,History_toggle-Last_Action,Entry,
ENG247070-ENG247195,History_toggle-Last_Action_n-1,Entry,
ENG247070-ENG247181,History_toggle-Last_Action_n-2,Entry,
ENG247070-ENG247159,History_toggle-Last_Action_n-3,Entry,
ENG247070-ENG247168,History_toggle-Last_Action_n-4,Entry,
ENG247070-ENG247164,History_toggle-Last_Action_n-5,Entry,
ENG247070-ENG247158,History_toggle-Last_Action_n-6,Entry,
ENG247070-ENG247166,History_toggle-Last_Action_n-7,Entry,
ENG247070-ENG247179,History_toggle-Last_control_section,ft,
ENG247070-ENG247171,History_toggle-Last_control_section_n-1,ft,
ENG247070-ENG247176,History_toggle-Last_control_section_n-2,ft,
ENG247070-ENG247202,History_toggle-Last_control_section_n-3,ft,
ENG247070-ENG247169,History_toggle-Last_control_section_n-4,ft,
ENG247070-ENG247198,History_toggle-Last_control_section_n-5,ft,
ENG247070-ENG247210,History_toggle-Last_control_section_n-6,ft,
ENG247070-ENG247160,History_toggle-Last_control_section_n-7,ft,
ENG157998-MAS00106,lf_shutdowns-Year,2000,
ENG157998-MAS00107,lf_shutdowns-Month,0,
ENG157998-MAS00108,lf_shutdowns-Day,0,
ENG157998-MAS00109,lf_shutdowns-Hours,0,
ENG157998-MAS00110,lf_shutdowns-Minutes,0,
ENG157998-MAS00111,lf_shutdowns-Seconds,0,
ENG157998-ENG163142,lf_shutdowns-Mileage_lf_shutdown_n,0, km
ENG157998-ENG163143,lf_shutdowns-Mileage_lf_shutdown_n-1,0, km
ENG157998-ENG163144,lf_shutdowns-Mileage_lf_shutdown_n-2,0, km
ENG157998-ENG163145,lf_shutdowns-Mileage_lf_shutdown_n-3,0, km
ENG247087,Next_toggle_activity,Entry,
ENG120048,Overtemperaturecounter for ADRIMA,0,
ENG129034-ENG129128,power_state_door_handle-power_state_bt,active,
ENG129034-ENG129127,power_state_door_handle-power_state_ft,active,
ENG129034-ENG129129,power_state_door_handle-power_state_hl,not active,
ENG129034-ENG129130,power_state_door_handle-power_state_hr,not active,
ENG129030,Request_steering_column_lock_terminal_approval,not requested,
ENG108452,Reset_counter,12,
ENG129033,s_anf_klemmenfreigabe_wfs,not requested,
ENG126972,s_klemmenfreigabe_wfs,No enabling,
ENG157420-ENG129140,Scan_cycle_data-Car_key_1,0,
ENG157420-ENG129141,Scan_cycle_data-Car_key_2,0,
ENG157420-ENG129141,Scan_cycle_data-Car_key_2,1,
ENG157420-ENG129142,Scan_cycle_data-Car_key_3,0,
ENG157420-ENG129143,Scan_cycle_data-Car_key_4,0,
ENG157420-ENG161108,Scan_cycle_data-Mileage_n,52, km
ENG157420-ENG161109,Scan_cycle_data-Mileage_n-1,52, km
ENG157420-ENG161110,Scan_cycle_data-Mileage_n-10,0, km
ENG157420-ENG161111,Scan_cycle_data-Mileage_n-11,0, km
ENG157420-ENG161112,Scan_cycle_data-Mileage_n-12,0, km
ENG157420-ENG161113,Scan_cycle_data-Mileage_n-13,0, km
ENG157420-ENG161114,Scan_cycle_data-Mileage_n-14,0, km
ENG157420-ENG161115,Scan_cycle_data-Mileage_n-15,0, km
ENG157420-ENG161116,Scan_cycle_data-Mileage_n-16,0, km
ENG157420-ENG161117,Scan_cycle_data-Mileage_n-17,0, km
ENG157420-ENG161118,Scan_cycle_data-Mileage_n-18,0, km
ENG157420-ENG161119,Scan_cycle_data-Mileage_n-19,0, km
ENG157420-ENG161120,Scan_cycle_data-Mileage_n-2,52, km
ENG157420-ENG161121,Scan_cycle_data-Mileage_n-3,43, km
ENG157420-ENG161122,Scan_cycle_data-Mileage_n-4,43, km
ENG157420-ENG161123,Scan_cycle_data-Mileage_n-5,17, km
ENG157420-ENG161124,Scan_cycle_data-Mileage_n-6,17, km
ENG157420-ENG161125,Scan_cycle_data-Mileage_n-7,0, km
ENG157420-ENG161126,Scan_cycle_data-Mileage_n-8,0, km
ENG157420-ENG161127,Scan_cycle_data-Mileage_n-9,0, km
ENG157420-ENG161148,Scan_cycle_data-Retry_count_n,9,
ENG157420-ENG161149,Scan_cycle_data-Retry_count_n -6,9,
ENG157420-ENG161150,Scan_cycle_data-Retry_count_n-1,10,
ENG157420-ENG161151,Scan_cycle_data-Retry_count_n-10,1,
ENG157420-ENG161152,Scan_cycle_data-Retry_count_n-11,0,
ENG157420-ENG161153,Scan_cycle_data-Retry_count_n-12,0,
ENG157420-ENG161154,Scan_cycle_data-Retry_count_n-13,0,
ENG157420-ENG161155,Scan_cycle_data-Retry_count_n-14,0,
ENG157420-ENG161156,Scan_cycle_data-Retry_count_n-15,0,
ENG157420-ENG161157,Scan_cycle_data-Retry_count_n-16,0,
ENG157420-ENG161158,Scan_cycle_data-Retry_count_n-17,0,
ENG157420-ENG161159,Scan_cycle_data-Retry_count_n-18,0,
ENG157420-ENG161160,Scan_cycle_data-Retry_count_n-19,0,
ENG157420-ENG161161,Scan_cycle_data-Retry_count_n-2,9,
ENG157420-ENG161162,Scan_cycle_data-Retry_count_n-3,9,
ENG157420-ENG161163,Scan_cycle_data-Retry_count_n-4,9,
ENG157420-ENG161164,Scan_cycle_data-Retry_count_n-5,10,
ENG157420-ENG161165,Scan_cycle_data-Retry_count_n-7,1,
ENG157420-ENG161166,Scan_cycle_data-Retry_count_n-8,1,
ENG157420-ENG161167,Scan_cycle_data-Retry_count_n-9,9,
ENG157420-ENG161186,Scan_cycle_data-Scan_reason_n,trunk,
ENG157420-ENG161187,Scan_cycle_data-Scan_reason_n-1,Passenger_door,
ENG157420-ENG161188,Scan_cycle_data-Scan_reason_n-10,trunk,
ENG157420-ENG161189,Scan_cycle_data-Scan_reason_n-11,Initial,
ENG157420-ENG161190,Scan_cycle_data-Scan_reason_n-12,Initial,
ENG157420-ENG161191,Scan_cycle_data-Scan_reason_n-13,Initial,
ENG157420-ENG161192,Scan_cycle_data-Scan_reason_n-14,Initial,
ENG157420-ENG161193,Scan_cycle_data-Scan_reason_n-15,Initial,
ENG157420-ENG161194,Scan_cycle_data-Scan_reason_n-16,Initial,
ENG157420-ENG161195,Scan_cycle_data-Scan_reason_n-17,Initial,
ENG157420-ENG161196,Scan_cycle_data-Scan_reason_n-18,Initial,
ENG157420-ENG161197,Scan_cycle_data-Scan_reason_n-19,Initial,
ENG157420-ENG161198,Scan_cycle_data-Scan_reason_n-2,rear_left_door,
ENG157420-ENG161199,Scan_cycle_data-Scan_reason_n-3,rear_right_door,
ENG157420-ENG161200,Scan_cycle_data-Scan_reason_n-4,rear_left_door,
ENG157420-ENG161201,Scan_cycle_data-Scan_reason_n-5,rear_left_door,
ENG157420-ENG161202,Scan_cycle_data-Scan_reason_n-6,rear_right_door,
ENG157420-ENG161203,Scan_cycle_data-Scan_reason_n-7,trunk,
ENG157420-ENG161204,Scan_cycle_data-Scan_reason_n-8,trunk,
ENG157420-ENG161205,Scan_cycle_data-Scan_reason_n-9,trunk,
ENG157420-ENG161206,Scan_cycle_data-Scan_trigger_n,Reset_stop_car,
ENG157420-ENG161207,Scan_cycle_data-Scan_trigger_n-1,Reset_stop_car,
ENG157420-ENG161208,Scan_cycle_data-Scan_trigger_n-10,Set_stop_car,
ENG157420-ENG161209,Scan_cycle_data-Scan_trigger_n-11,Set_stop_car,
ENG157420-ENG161210,Scan_cycle_data-Scan_trigger_n-12,Set_stop_car,
ENG157420-ENG161211,Scan_cycle_data-Scan_trigger_n-13,Set_stop_car,
ENG157420-ENG161212,Scan_cycle_data-Scan_trigger_n-14,Set_stop_car,
ENG157420-ENG161213,Scan_cycle_data-Scan_trigger_n-15,Set_stop_car,
ENG157420-ENG161214,Scan_cycle_data-Scan_trigger_n-16,Set_stop_car,
ENG157420-ENG161215,Scan_cycle_data-Scan_trigger_n-17,Set_stop_car,
ENG157420-ENG161216,Scan_cycle_data-Scan_trigger_n-18,Set_stop_car,
ENG157420-ENG161217,Scan_cycle_data-Scan_trigger_n-19,Set_stop_car,
ENG157420-ENG161218,Scan_cycle_data-Scan_trigger_n-2,Set_stop_car,
ENG157420-ENG161219,Scan_cycle_data-Scan_trigger_n-3,Set_stop_car,
ENG157420-ENG161220,Scan_cycle_data-Scan_trigger_n-4,Set_stop_car,
ENG157420-ENG161221,Scan_cycle_data-Scan_trigger_n-5,Reset_stop_car,
ENG157420-ENG161222,Scan_cycle_data-Scan_trigger_n-6,Set_stop_car,
ENG157420-ENG161223,Scan_cycle_data-Scan_trigger_n-7,Set_stop_car,
ENG157420-ENG161224,Scan_cycle_data-Scan_trigger_n-8,Set_stop_car,
ENG157420-ENG161225,Scan_cycle_data-Scan_trigger_n-9,Set_stop_car,
ENG125222-ENG129124,Selective_catalytic_reduction-Possible_Engine_Start,OK,
ENG125222-ENG129123,Selective_catalytic_reduction-SCR_install_state,not installed,
ENG129035-MAS00106,service_key_internal_status-Year,2022,
ENG129035-MAS00106,service_key_internal_status-Year,2000,
ENG129035-MAS00107,service_key_internal_status-Month,0,
ENG129035-MAS00107,service_key_internal_status-Month,6,
ENG129035-MAS00108,service_key_internal_status-Day,0,
ENG129035-MAS00108,service_key_internal_status-Day,17,
ENG129035-MAS00109,service_key_internal_status-Hours,10,
ENG129035-MAS00109,service_key_internal_status-Hours,0,
ENG129035-MAS00110,service_key_internal_status-Minutes,13,
ENG129035-MAS00110,service_key_internal_status-Minutes,0,
ENG129035-MAS00111,service_key_internal_status-Seconds,20,
ENG129035-MAS00111,service_key_internal_status-Seconds,0,
ENG129035-ENG129135,service_key_internal_status-checksum_comparison_service_key1,OK,
ENG129035-ENG129136,service_key_internal_status-checksum_comparison_service_key2,not OK.,
ENG129031,Steering_column_lock_terminal_approval,No enabling,
ENG125218,Suppression_ignition_message,not activated,
ENG129036,To_block_terminal_upshift,not active,
ENG129037,Trigger_terminal_deactivation_central_locking,not activated,
ENG129038,Valid_time_control_section_diagnostics,0, s
ENG139702-ENG140253,WFS_key_signature-clap_15_activateing_signature,02,
ENG139702-ENG140248,WFS_key_signature-signature_key_1,05 DA,
ENG139702-ENG140249,WFS_key_signature-signature_key_2,05 E9,
ENG139702-ENG140250,WFS_key_signature-signature_key_3,00 00,
ENG139702-ENG140251,WFS_key_signature-signature_key_4,00 00,
ENG139702-ENG140252,WFS_key_signature-signature_key_5,00 00,
Elapsed Time: 00:20,,,
blockmap-08-5GM-907-044-AM_3VV2X7B28NM061887-20220618-1234.CSV
;SW:5GM-907-044-AM   HW:5GM-907-044-AM ---  Auto HVAC
;Component:Climatronic   H05 2601, Coding:0902002420211C001104010C1211D014
;EV_ACClimaBHBVW37X,006151,EV_ACClimaBHBVW37X_006_VW37.rod
;Saturday,18,June,2022,12:34:06:14741
;VCID: 8F70587687DE7523DA8-80DA
IDE00019,Voltage terminal 30,12.7, V
IDE00021,Engine RPM,1400, /min
IDE00025,Coolant temperature,56, °C
IDE00198,Refrigerant pressure,7.8, bar
IDE00767,No. of unscheduled ECU resets,3,
IDE00965,Compressor shut-off condition,A/C off or fan control switch in 0 position,
IDE00966,Compressor current: actual value,0.000, A
IDE00967,Compressor current: specified value,0.000, A
IDE00968,Compressor speed,1600, /min
IDE00969,Compressor load,0.0, Nm
IDE00970,Coolant fan activation: actual value,10.0, %
IDE00971,Coolant fan activation: specified value,0.0, %
IDE00973,Outside temperature,30.5, °C
IDE00974,Outside air temperature internally calculated,30.5, °C
IDE00976,Left front vent temperature,43.0, °C
IDE00977,Right front vent temperature,44.3, °C
IDE00981,Footwell vent temperature,34.3, °C
IDE00982,Temperature downstream of evaporator,28.7, °C
IDE00983,Inside temperature,39.5, °C
IDE00984,Sun intensity left,380, W/m²
IDE00985,Sun intensity right,290, W/m²
IDE00987,Blower voltage: specified value,0.0, V
IDE00989,Blower status,not active,
IDE00994,Actual value for fresh air/recirculation air flow flap,0.0, %
IDE00994,Actual value for fresh air/recirculation air flow flap,77,
IDE00995,Fresh air/recirculating air/back pressure door specified value,72,
IDE00996,Fresh air stop for fresh air/recirculation air flow flap,164,
IDE00997,Recirculated air stop for fresh air/recirc air flow flap,77,
IDE00998,Left temperature flap - actual value,0.0, %
IDE00998,Left temperature flap - actual value,25,
IDE00999,Temperature door left - Specified value,24,
IDE01040,Left Temperature Control Door - cold stop,29,
IDE01041,Left temperature flap: warm stop,232,
IDE01042,Right temperature flap: actual value,0.0, %
IDE01042,Right temperature flap: actual value,21,
IDE01043,Temperature door right - Specified value,20,
IDE01044,Right temperature flap: cold stop,25,
IDE01045,Right temperature flap: warm stop,230,
IDE01050,Front air distribution flap: actual value,21,
IDE01050,Front air distribution flap: actual value,0.0, %
IDE01051,Air distribution door front - Specified value,20,
IDE01052,Front air distribution flap: air outlet stop,235,
IDE01053,Front air distribution flap: footwell air outlet stop,25,
IDE01054,Defroster flap: actual value,232,
IDE01054,Defroster flap: actual value,100.0, %
IDE01055,Defrost door - Specified value,233,
IDE01056,Defroster flap: stop open,228,
IDE01057,Defroster flap: stop closed,18,
IDE01063,Status of recirculation air,Fresh air,
IDE01066,Convertible top status,to,
IDE01076,Time since ignition off,240, min
IDE01088,Rear temperature flap: actual value,20,
IDE01088,Rear temperature flap: actual value,0.0, %
IDE01089,Rear temperature flap: specified value,20,
IDE01090,Rear temperature flap: cold stop,0,
IDE01091,Rear temperature flap: warm stop,0,
IDE01217-MAS01447,Left heated seat stage-Act.val.,0,
IDE01217-MAS01448,Left heated seat stage-Target value,0,
IDE01218-MAS01447,Right heated seat stage-Act.val.,0,
IDE01218-MAS01448,Right heated seat stage-Target value,0,
IDE01226,Blower voltage: actual value,0.0, V
IDE01227,Blower current,0.00, A
IDE01232,Supply voltage for external components,5.0, V
IDE01264,Remaining time of parking heater/ventilation operation,0, min
IDE01287-MAS01260,Counter of compressor switch-offs-Shut-off from Engine Control Module (ECM) via CAN,67,
IDE01287-MAS01265,Counter of compressor switch-offs-Speed shut-off,0,
IDE01419,Compressor shut-off condition: last,Low pressure event,
IDE01420,Compressor shut-off requirement: penultimate,Low pressure event,
IDE01421,Compressor shut-off requirement: antepenultimate,Low pressure event,
IDE01433,Air quality status,not installed,
IDE01442-MAS01533,Pressing a button-Defrost,Not operated,
IDE01442-MAS01534,Pressing a button-Recirculating air,Not operated,
IDE01442-MAS01535,Pressing a button-Rear window defogger,Not operated,
IDE01442-MAS01550,Pressing a button-AC,Not operated,
IDE01442-MAS01554,Pressing a button-Left heated seat,Not operated,
IDE01442-MAS01556,Pressing a button-Right heated seat,Not operated,
IDE01442-MAS01560,Pressing a button-OFF,Not operated,
IDE01442-MAS01577,Pressing a button-Parking heater,Not operated,
IDE01442-MAS02015,Pressing a button-AUTO,Not operated,
IDE01442-MAS02192,Pressing a button-SYNC,Not operated,
IDE01442-MAS03196,Pressing a button-Menu,Not operated,
IDE01442-MAS03830,Pressing a button-Footwell air distribution,Not operated,
IDE01442-MAS03831,Pressing a button-Upper body vent air distribution,Not operated,
IDE01442-MAS03832,Pressing a button-Air distribution up,Not operated,
IDE01442-MAS04605,Pressing a button-AC MAX,Not operated,
IDE01443,Left push-and-rotary knob counter,0,
IDE01444,Right push-and-rotary knob counter,0,
IDE02270-IDE01268,CAN input signal(s) status-Windshield wiper,OFF,
IDE02270-IDE01457,CAN input signal(s) status-Energy management deactivation stage,Deactivation stage 0,
IDE02270-MAS01283,CAN input signal(s) status-Actual value of windshield heater,OFF,
IDE02271-IDE00972,CAN output signal(s) status-Idle speed increase,not active,
IDE02271-MAS00130,CAN output signal(s) status-Compressor on,OFF,
IDE03008-MAS01564,Stop process prevented-Front windshield heater,not active,
IDE03008-MAS02802,Stop process prevented-Interior temperature difference to specifications,not active,
IDE03008-MAS02803,Stop process prevented-Blowout temperature difference to specifications,not active,
IDE03008-MAS02804,Stop process prevented-Manual fan speed increase,not active,
IDE03008-MAS05009,Stop process prevented-A/C request: auxil. heat mode,not active,
IDE03008-MAS06551,Stop process prevented-Seat ventilation,not active,
IDE03008-MAS09538,Stop process prevented-max A/C,not active,
IDE03009-MAS01517,Start process requested-Defrost active,not active,
IDE03009-MAS01564,Start process requested-Front windshield heater,not active,
IDE03009-MAS02802,Start process requested-Interior temperature difference to specifications,not active,
IDE03009-MAS02803,Start process requested-Blowout temperature difference to specifications,not active,
IDE03009-MAS02804,Start process requested-Manual fan speed increase,not active,
IDE03009-MAS04353,Start process requested-Fogging hazard (humidity sensor),not active,
IDE03009-MAS04354,Start process requested-Interior comfort humidity too high (humidity sensor),not active,
IDE03009-MAS05009,Start process requested-A/C request: auxil. heat mode,not active,
IDE03009-MAS05047,Start process requested-Maximum cooling and heating set,not active,
IDE03009-MAS06551,Start process requested-Seat ventilation,not active,
IDE03009-MAS09538,Start process requested-max A/C,not active,
IDE03010-MAS00478,Number of prevented stop processes-Reserved,0,
IDE03010-MAS01517,Number of prevented stop processes-Defrost active,0,
IDE03010-MAS01564,Number of prevented stop processes-Front windshield heater,0,
IDE03010-MAS02802,Number of prevented stop processes-Interior temperature difference to specifications,4,
IDE03010-MAS02803,Number of prevented stop processes-Blowout temperature difference to specifications,2,
IDE03010-MAS02804,Number of prevented stop processes-Manual fan speed increase,0,
IDE03010-MAS04353,Number of prevented stop processes-Fogging hazard (humidity sensor),0,
IDE03010-MAS04354,Number of prevented stop processes-Interior comfort humidity too high (humidity sensor),1,
IDE03010-MAS05009,Number of prevented stop processes-A/C request: auxil. heat mode,0,
IDE03010-MAS05047,Number of prevented stop processes-Maximum cooling and heating set,0,
IDE03010-MAS06551,Number of prevented stop processes-Seat ventilation,0,
IDE03010-MAS09538,Number of prevented stop processes-max A/C,1,
IDE03011-MAS00478,Number of requested start processes-Reserved,0,
IDE03011-MAS01517,Number of requested start processes-Defrost active,0,
IDE03011-MAS01564,Number of requested start processes-Front windshield heater,0,
IDE03011-MAS02802,Number of requested start processes-Interior temperature difference to specifications,0,
IDE03011-MAS02803,Number of requested start processes-Blowout temperature difference to specifications,3,
IDE03011-MAS02804,Number of requested start processes-Manual fan speed increase,0,
IDE03011-MAS04353,Number of requested start processes-Fogging hazard (humidity sensor),0,
IDE03011-MAS04354,Number of requested start processes-Interior comfort humidity too high (humidity sensor),0,
IDE03011-MAS05009,Number of requested start processes-A/C request: auxil. heat mode,0,
IDE03011-MAS05047,Number of requested start processes-Maximum cooling and heating set,0,
IDE03011-MAS06551,Number of requested start processes-Seat ventilation,0,
IDE03011-MAS09538,Number of requested start processes-max A/C,0,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,9,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,11,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,33,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,56,
IDE03127,Prevented stop processes (ring memory),Blowout temperature difference to specifications,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2022,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,6,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,9,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,11,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,20,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,28,
IDE03128,Requested start processes (ring memory),Blowout temperature difference to specifications,
IDE03214,Engine stop using start-stop function,not active,
IDE03215,Engine start using start-stop function,not active,
IDE03488,Driving time remaining for basic setting of compressor run in,0, s
IDE04312-IDE04095,System run time-Engine running time,255, s
IDE04312-MAS00084,System run time-Terminal 15 on,255, s
IDE04797,Center push-and-rotary knob counter,0,
IDE04805-IDE02955,Driving profile selection-System status,Not available,
IDE04805-MAS01447,Driving profile selection-Act.val.,0,
IDE04805-MAS01448,Driving profile selection-Target value,2,
IDE04805-MAS05058,Driving profile selection-Compatibility,Yes,
IDE05725,Dimmer terminal 58xs,0, %
IDE05726,Dimmer terminal 58xd,253,
IDE06091-IDE01440,Humidity sensor: interior-Front windshield temperature,60.4, °C
IDE06091-MAS04629,Humidity sensor: interior-Sensor temperature,61.0, °C
IDE06091-MAS04630,Humidity sensor: interior-Relative humidity,8.5, %
IDE06091-MAS04647,Humidity sensor: interior-Dew point,15.4, °C
IDE06234-IDE01270,Auxiliary heater: in stages-Enabling for auxiliary heater operation,Enabling stage 3,
IDE06234-MAS01447,Auxiliary heater: in stages-Act.val.,0,
IDE06234-MAS01448,Auxiliary heater: in stages-Target value,0,
IDE06234-MAS04992,Auxiliary heater: in stages-Specified value for control,0,
IDE06235,Potentiometer for rear vent temperature,255,
IDE07991-MAS04446,A/C clutch-Relay activation status,not active,
IDE12141-MAS00106,History memory: parking heater-Year,2127,
IDE12141-MAS00107,History memory: parking heater-Month,15,
IDE12141-MAS00108,History memory: parking heater-Day,31,
IDE12141-MAS00109,History memory: parking heater-Hours,31,
IDE12141-MAS00110,History memory: parking heater-Minutes,63,
IDE12141-MAS00111,History memory: parking heater-Seconds,63,
IDE12141-MAS02526,History memory: parking heater-Activation,Measuring value not available,
IDE12141-MAS04390,History memory: parking heater-Active source,Measuring value not available,
IDE12499-IDE08704,A/C compressor initial running in: start prevention-Load management,not active,
IDE12499-MAS01250,A/C compressor initial running in: start prevention-Malfunction on fresh air blower,not active,
IDE12499-MAS01493,A/C compressor initial running in: start prevention-Engine running,Yes,
IDE12499-MAS10030,A/C compressor initial running in: start prevention-Adapt. of run-in time: compressor initial operation: written,Yes,
IDE12499-MAS14625,A/C compressor initial running in: start prevention-High-voltage vehicle electrical system,active,
IDE12499-MAS14626,A/C compressor initial running in: start prevention-High-voltage current limitations,not active,
IDE12499-MAS14891,A/C compressor initial running in: start prevention-Flaps not calibrated,not active,
IDE12500-MAS01250,A/C compressor initial running in: interruption conditions-Malfunction on fresh air blower,not active,
IDE12500-MAS01254,A/C compressor initial running in: interruption conditions-AC button off,not active,
IDE12500-MAS01256,A/C compressor initial running in: interruption conditions-Outside air temperature too low,not active,
IDE12500-MAS01261,A/C compressor initial running in: interruption conditions-Evaporator temperature ice-up danger,not active,
IDE12500-MAS01263,A/C compressor initial running in: interruption conditions-Compressor activation: malfunction in activation path,not active,
IDE12500-MAS01264,A/C compressor initial running in: interruption conditions-Malfunction at refrigerant pressure sensor,not active,
IDE12500-MAS01265,A/C compressor initial running in: interruption conditions-Speed shut-off,not active,
IDE12500-MAS01504,A/C compressor initial running in: interruption conditions-Supply voltage too high,not active,
IDE12500-MAS01508,A/C compressor initial running in: interruption conditions-High pressure event,not active,
IDE12500-MAS01509,A/C compressor initial running in: interruption conditions-Low pressure event,not active,
IDE12500-MAS14892,A/C compressor initial running in: interruption conditions-Pressure test not successful,not active,
IDE12500-MAS14893,A/C compressor initial running in: interruption conditions-Fault on the evaporator temperature sensor,not active,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,55,
Elapsed Time: 00:14,,,
blockmap-09-5Q0-937-085-CK_3VV2X7B28NM061887-20220618-1234.CSV
;SW:5Q0-937-085-CK   HW:5Q0-937-085-CK ---  Cent. Elect.
;Component:BCM MQBAB HNA H44 0511, Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BCMMQB,022001,EV_BCMBOSCH_022_VW27.rod
;Saturday,18,June,2022,12:34:28:14741
;VCDS Version: Beta 22.4.0 (x64)  Data version: 20220407 DS338.0
;VCID: 845A675ADE98067B77A-80D0
Group,Description,Actual,
IDE00356-IDE00355,Cruise Control System (CCS): switch position-Cruise Control System (CCS): status,No communication,
IDE00356-MAS00125,Cruise Control System (CCS): switch position-Cruise control system,No communication,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,No communication,
IDE00356-MAS00320,Cruise Control System (CCS): switch position-Main switch,No communication,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Tap delay,No communication,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Set,No communication,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Resume,No communication,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,NOT-DEFINED,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,No communication,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not assigned,No communication,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,No communication,
IDE00374-MAS05377,Electric auxiliary heater: relay activation-Low heat output relay,not active,
IDE00374-MAS05378,Electric auxiliary heater: relay activation-High heat output relay,not active,
IDE00844-MAS07314,Switch for engine hood-Status engine hood contact,closed,
IDE00844-ENG122175,Switch for engine hood-Bonnet_Magnetic_Lock,Measuring value not available,
IDE00973,Outside temperature,30.50, °C
IDE01066-IDE02092,Convertible top status-Tailgate condition,not coded/not installed,
IDE01066,Convertible top status,not coded/not installed,
IDE01464-IDE04741,Rear window defogger-Rear window defogger button,Not operated,
IDE01464-IDE04744,Rear window defogger-Rear window defogger indicator lamp,OFF,
IDE01537-IDE04742,Front windshield heater-Windshield defogger button,not coded/not installed,
IDE01537-IDE04743,Front windshield heater-Windshield defogger indicator lamp,not coded/not installed,
IDE01537-MAS01580,Front windshield heater-Activation,not coded/not installed,
IDE01943,Turn signal lamp,|Connector number,Connector terminal number
IDE02092-IDE02093,Tailgate condition-Status of rear lid lock,not coded/not installed,
IDE02092-IDE02133,Tailgate condition-Activation using rear lid unlocking button,OFF,
IDE02092-MAS01872,Tailgate condition-Rear lid remote control lock switch,Not operated,
IDE02092-MAS02405,Tailgate condition-Pre-engagement contact for rotary latch,to,
IDE02092-MAS02447,Tailgate condition-Release,not enabled,
IDE02092-MAS06265,Tailgate condition-Release button in rear lid handle,Not operated,
IDE02092-MAS06430,Tailgate condition-Main notch contact of rotary latch,to,
IDE02488-MAS01632,Anti-theft system interior monitoring-Status,not coded/not installed,
IDE02488-MAS04508,Anti-theft system interior monitoring-Alarm detected,not coded/not installed,
IDE02515,Low beam,|Connector number,Connector terminal number
IDE02588-IDE00020,Terminal signals and start release-Terminal 15 status,active,
IDE02588-IDE00773,Terminal signals and start release-Terminal 15 status via CAN,active,
IDE02588-IDE01351,Terminal signals and start release-Terminal 75 status,On,
IDE02588-IDE01715,Terminal signals and start release-Status terminal S,active,
IDE02588-IDE01716,Terminal signals and start release-Terminal 50 status,OFF,
IDE02588-IDE06027,Terminal signals and start release-Terminal S status via CAN,active,
IDE02588-MAS12787,Terminal signals and start release-Terminal 15 ignition switch signal 1,active,
IDE02588-MAS12788,Terminal signals and start release-Terminal 15 ignition switch signal 2,active,
IDE02614-MAS02788,Reversing light switch-CAN,not active,
IDE02614-MAS05360,Reversing light switch-Discreet wire,not coded/not installed,
IDE02711,Rear wiper,not active,
IDE02743,High Beam,|Connector number,Connector terminal number
IDE02744-MAS01632,Steering wheel heating-Status,switched off,
IDE02744-MAS02311,Steering wheel heating-Steering wheel heating button,Not operated,
IDE02744-MAS09758,Steering wheel heating-Temperature sensor,89,
IDE02857-IDE03111,Activation current-Interior lighting,0, mA
IDE02857-IDE05533,Activation current-Heater for nozzles,0, mA
IDE02857-IDE06012,Activation current-Background lighting,0, mA
IDE02857-MAS01554,Activation current-Left heated seat,0, mA
IDE02857-MAS01556,Activation current-Right heated seat,0, mA
IDE02857-ENG128454,Activation current-Cockpittaster_1,No malfunction,
IDE02857-ENG128455,Activation current-Cockpittaster_2,No malfunction,
IDE02857-ENG128456,Activation current-Cockpittaster_3,No malfunction,
IDE02857-ENG128457,Activation current-Cockpittaster_4,No malfunction,
IDE02857-ENG128458,Activation current-DWA_Einfachhorn,0, mV
IDE02857-ENG126436,Activation current-signal_horn,65533, mV
IDE02957,Ambient lighting,|Channel,Connector number
IDE03111,Interior lighting,|Connector number,Connector terminal number
IDE03195-IDE03854,High values for automatic vertical headlight aim-Left front level control system sensor: height value current,0.0,
IDE03195-IDE04144,High values for automatic vertical headlight aim-Left rear level control system sensor: height value current,0.0,
IDE03195-IDE07143,High values for automatic vertical headlight aim-Vehicle level sensor: supply voltage,16.2, V
IDE03195-MAS13964,High values for automatic vertical headlight aim-Spec. value: activation vehicle level sensor,127.5,
IDE03195-MAS13965,High values for automatic vertical headlight aim-Vehicle level sensor: control voltage,12.7, V
IDE03310,Brake lamp,|Connector number,Connector terminal number
IDE03388-IDE01217,Left front heated seat: status-Left heated seat stage,OFF,
IDE03388-MAS02201,Left front heated seat: status-Temperature,23.50, °C
IDE03389-IDE01218,Right front heated seat: status-Right heated seat stage,OFF,
IDE03389-MAS02201,Right front heated seat: status-Temperature,22.50, °C
IDE03504,Personalized settings,|profile,Comfort opening
IDE03638,Stationary cornering lamp,|Connector number,Connector terminal number
IDE04213,Central locking button,not coded/not installed,
IDE04213-IDE07357,Central locking button-Indicator lamp for central locking,not coded/not installed,
IDE04254-MAS06517,Play protection for central locking-Rear spoiler counter,not active,
IDE04347-IDE00104,Expanded freeze frame conditions-DTC,08 0E 00,
IDE04347-IDE07836,Expanded freeze frame conditions-Log data,00 00 00 03 00 11 0C 00 11 0C 00 0C 00 0F 62 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90 00 03 00 06 4F B4 00 00 07 15 00 00 00 03 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 00 00 02 00 20 00 00 10 06 0B 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1F 01 00 00 00 00 00 50 64 09 12 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 00 01 00 01 0C 81 04 13 00 00 00 00 04 4C 20 64 00 20 00 00 00 00 00 00 00 00 00 00 00 0F 01 56 00 3B 00 00 00 00 00 00 00 00 00 00 00 00 08 01 00 00 00 00 02 00 00 00 03 00 00 00 00 8F,
IDE04925,Daytime running lights,|Connector number,Connector terminal number
IDE05042-MAS03873,Emergency flasher button-Duty cycle,21.00, %
IDE05045-IDE05183,Front wiper module-Malfunction left,not coded/not installed,
IDE05045-IDE05184,Front wiper module-Malfunction right,not coded/not installed,
IDE05045-MAS03638,Front wiper module-Wipe speed,0, /min
IDE05045-MAS05057,Front wiper module-Number of wiper cycles,300,
IDE05045-MAS05878,Front wiper module-Stage,Stage 1,
IDE05323,Fog lamp,|Connector number,Connector terminal number
IDE05434,Rear entry light,|Connector number,Side
IDE05533,Heater for nozzles,not active,
IDE05719-IDE05534,Window washer system-Headlamp washer system,not coded/not installed,
IDE05719-MAS02341,Window washer system-Rear window washer system,not active,
IDE05720-IDE02589,Front driver side door status-Rotary latch status,Open,
IDE05720-IDE04213,Front driver side door status-Central locking button,Not operated,
IDE05722-IDE02589,Door status: driver side rear-Rotary latch status,closed,
IDE05722-IDE04213,Door status: driver side rear-Central locking button,not coded/not installed,
IDE05722-MAS06256,Door status: driver side rear-Status door lock,Signal from door lock: engaged,
IDE05727-IDE04213,Front passenger side door status-Central locking button,Not operated,
IDE05727-IDE04214,Front passenger side door status-Key switch in door lock,Not operated,
IDE05727-MAS06256,Front passenger side door status-Status door lock,Signal from door lock: engaged,
IDE05729-IDE02589,Door status: frt. pass. side rear-Rotary latch status,closed,
IDE05729-IDE04213,Door status: frt. pass. side rear-Central locking button,not coded/not installed,
IDE05729-MAS06256,Door status: frt. pass. side rear-Status door lock,Signal from door lock: engaged,
IDE05730,Luggage compartment light,|Connector number,Connector terminal number
IDE05739,Footwell lamp,|Connector number,Connector terminal number
IDE05742-IDE02515,Light switch position-Low beam,Not operated,
IDE05742-IDE05323,Light switch position-Fog lamp,not coded/not installed,
IDE05742-IDE07956,Light switch position-redundant signal line,OFF,
IDE05742-MAS00063,Light switch position-OFF,operated,
IDE05742-MAS02462,Light switch position-Automatic high beam assist,Not operated,
IDE05742-MAS03835,Light switch position-Position lamps,Not operated,
IDE05742-MAS03836,Light switch position-Rear fog lamp,not coded/not installed,
IDE05822-MAS01632,Anti-theft alarm system vehicle inclination sensor-Status,not coded/not installed,
IDE05822-MAS04508,Anti-theft alarm system vehicle inclination sensor-Alarm detected,not coded/not installed,
IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch,not coded/not installed,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,not coded/not installed,
IDE05826-MAS01632,DWA Sirens / alarm horn for anti-theft warning system-Status,not coded/not installed,
IDE05826-MAS04508,DWA Sirens / alarm horn for anti-theft warning system-Alarm detected,No,
IDE05826-MAS04509,DWA Sirens / alarm horn for anti-theft warning system-Alarm activated,No,
IDE05827,Horn for anti-theft warning system,not coded/not installed,
IDE05829,Rear spoiler history data,|Spoiler_Activation_Trigger,Spoiler_Activation_Trigger_Date
IDE05830-MAS02282,Rear Spoiler-Position,not coded/not installed,
IDE05830-ENG115793,Rear Spoiler-Spoiler_Button,not coded/not installed,
IDE05830-ENG115792,Rear Spoiler-Spoiler_Cycle_Protection,not coded/not installed,
IDE05830-ENG115794,Rear Spoiler-Spoiler_Indication_Light,not coded/not installed,
IDE05830-ENG115791,Rear Spoiler-Spoiler_Position,not coded/not installed,
IDE05833,Anti-theft warning system: history data,|Cause for alarm activation,Odometer reading
IDE05834-IDE01718,Driver info-Crash signal,not active,
IDE05834-MAS00212,Driver info-Insufficient washer fluid,not active,
IDE05834-MAS00214,Driver info-Brake pad wear,not coded/not installed,
IDE05836-MAS03637,Rain recognition sensor-Rain quantity,0,
IDE05838-MAS02248,Light recognition sensor-Signal state,active,
IDE05838-MAS02475,Light recognition sensor-Brightness infrared,75200, lx
IDE05838-MAS02851,Light recognition sensor-Brightness,6126, lx
IDE05838-MAS04809,Light recognition sensor-Darkness,OFF,
IDE05838-MAS04810,Light recognition sensor-Request for light activation,OFF,
IDE05839,Parking lamps,|Connector number,Connector terminal number
IDE05841,Central locking history data,|Control-section / cause,command_direction_locking
IDE05842,Comfort function history data,|Control-section / cause,Operating command
IDE06012,Background lighting,|Connector number,terminal
IDE06091-IDE01440,Humidity sensor: interior-Front windshield temperature,-38.1, °C
IDE06091-MAS04629,Humidity sensor: interior-Sensor temperature,61.5, °C
IDE06091-MAS04630,Humidity sensor: interior-Relative humidity,9.0, %
IDE06091-MAS04647,Humidity sensor: interior-Dew point,-38.8, °C
IDE06096-IDE03111,Interior lights-Interior lighting,100, %
IDE06096-IDE05724,Interior lights-Dimmer terminal 58xt,100.0, %
IDE06096-IDE05725,Interior lights-Dimmer terminal 58xs,0.0, %
IDE06096-IDE05726,Interior lights-Dimmer terminal 58xd,125.0, %
IDE06096-MAS01634,Interior lights-Supply voltage,100.0, %
IDE06096-MAS04528,Interior lights-Instrument panel and switch illumination dimmer switch,100, %
IDE06324-IDE04217,Tank cap lock-Fuel filler door release button,Not operated,
IDE06324-MAS01580,Tank cap lock-Activation,not active,
IDE06324-MAS06251,Tank cap lock-Contact switch,Open,
IDE06470,Periphery lighting,|Connector number,Connector terminal number
IDE06507-MAS13127,Button in center console-Status of button 1,Not operated,
IDE06507-MAS13128,Button in center console-Indicator lamp button 1,OFF,
IDE06507-MAS13130,Button in center console-Status of button 2,not coded/not installed,
IDE06507-MAS13131,Button in center console-Indicator lamp button 2,not coded/not installed,
IDE06507-MAS13133,Button in center console-Status of button 3,not coded/not installed,
IDE06507-MAS13134,Button in center console-Indicator lamp button 3,not coded/not installed,
IDE06507-MAS13136,Button in center console-Indicator lamp button 4,not coded/not installed,
IDE06507-MAS13137,Button in center console-Status of button 4,not coded/not installed,
IDE06644-IDE06864,Vehicle positioning system-Daytime running lamps,not coded/not installed,
IDE06644-MAS01288,Vehicle positioning system-Horn,not coded/not installed,
IDE06644-MAS03834,Vehicle positioning system-Emergency signal flashing,not coded/not installed,
IDE06644-MAS03835,Vehicle positioning system-Position lamps,not coded/not installed,
IDE06649-MAS05016,Wireless transmitter-Receiver status,not installed,
IDE06649-MAS05048,Wireless transmitter-Number of transmitters adapted,0,
IDE06649-ENG247157,Wireless transmitter-Kom.Schlüssel eFFB Handsender 1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE06649-ENG247187,Wireless transmitter-Kom.Schlüssel eFFB Handsender 2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE06695,Energy management: last critical state,|Energy management heat output control status,Maximum switch-off priority while driving
IDE06864,Daytime running lamps,|Connector number,Connector terminal number
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,04,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,00,
IDE07187-MAS06538,Level control system sensor-Left Front Level Control System Sensor: PWM signal,30.40, %
IDE07187-MAS06539,Level control system sensor-Left Rear Level Control System Sensor: PWM signal,50.00, %
IDE07187-MAS06540,Level control system sensor-Left front level control system sensor: frequency,791.7, Hz
IDE07187-MAS06541,Level control system sensor-Left Rear Left Control System Sensor: frequency,783.6, Hz
IDE07187-MAS06542,Level control system sensor-Vehicle level sensor: supply voltage,5.000, V
IDE07344-IDE00542,Sunroof shade-Excessive temperature protection,not active,
IDE07344-IDE03114,Sunroof shade-Comfort function,not active,
IDE07344-MAS01979,Sunroof shade-Adapting,Not adapted,
IDE07344-MAS02282,Sunroof shade-Position,126, %
IDE07344-MAS02447,Sunroof shade-Release,not active,
IDE07344-MAS03656,Sunroof shade-Reverse,not active,
IDE07344-MAS05563,Sunroof shade-Norming,not normed,
IDE07345-MAS07997,Sunroof front closed position switch-Rotary switch activation,Not operated,
IDE07345,Sunroof front closed position switch,Not operated,
IDE07345-ENG122183,Sunroof front closed position switch-rotary_switch_position,to,
IDE07346,Sunroof shade switches,Not operated,
IDE08125-MAS01458,Left head area heater-Operating condition,not coded/not installed,
IDE08125-MAS06651,Left head area heater-PTC heater element: current consumption,not coded/not installed,
IDE08125-MAS06652,Left head area heater-Blower motor: speed,not coded/not installed,
IDE08125-MAS06653,Left head area heater-Indicator light for head area heater,not coded/not installed,
IDE08126-MAS01458,Right head area heater-Operating condition,not coded/not installed,
IDE08126-MAS06651,Right head area heater-PTC heater element: current consumption,not coded/not installed,
IDE08126-MAS06652,Right head area heater-Blower motor: speed,not coded/not installed,
IDE08126-MAS06653,Right head area heater-Indicator light for head area heater,not coded/not installed,
IDE08177-MAS06456,Central locking system-Auto lock,not active,
IDE08177-MAS06740,Central locking system-Release button in rear lid handle locked,not active,
IDE08177-MAS09894,Central locking system-Status exterior skin,Open,
IDE08177-MAS09896,Central locking system-Act. condition: Status central locking internal locked,not active,
IDE08177-MAS09897,Central locking system-Act. condition: Status central locking external locked,not active,
IDE08177-MAS09898,Central locking system-Act. condition: Status central locking safe,not active,
IDE08177-MAS09900,Central locking system-Spec. condition: Status central lock,Vehicle unlocked at single door,
IDE08177-MAS13126,Central locking system-Luggage hold closure,not coded/not installed,
IDE08211-MAS03129,History data control module reset-Reset counter,7,
IDE08211,History data control module reset,|last cause of reset,Year
IDE08343,Immobilizer Challenge,3C AB BD D7,
IDE08356-IDE00102,Left seat backrest fan 1-Control Module temperature,41, °C
IDE08356-MAS01447,Left seat backrest fan 1-Act.val.,0, /min
IDE08356-MAS01634,Left seat backrest fan 1-Supply voltage,13, V
IDE08356-MAS09948,Left seat backrest fan 1-Pin coding. spec. value,7,
IDE08356-MAS09949,Left seat backrest fan 1-Pin coding. act. value,7,
IDE08356-MAS10342,Left seat backrest fan 1-No. of start-up attempts after blocking error,0,
IDE08358-IDE00102,Left seat cushion fan 1-Control Module temperature,34, °C
IDE08358-MAS01447,Left seat cushion fan 1-Act.val.,0, /min
IDE08358-MAS01634,Left seat cushion fan 1-Supply voltage,12, V
IDE08358-MAS09948,Left seat cushion fan 1-Pin coding. spec. value,6,
IDE08358-MAS09949,Left seat cushion fan 1-Pin coding. act. value,6,
IDE08358-MAS10342,Left seat cushion fan 1-No. of start-up attempts after blocking error,0,
IDE08360-IDE00102,Right seat backrest fan 1-Control Module temperature,39, °C
IDE08360-MAS01447,Right seat backrest fan 1-Act.val.,0, /min
IDE08360-MAS01634,Right seat backrest fan 1-Supply voltage,13, V
IDE08360-MAS09948,Right seat backrest fan 1-Pin coding. spec. value,3,
IDE08360-MAS09949,Right seat backrest fan 1-Pin coding. act. value,3,
IDE08360-MAS10342,Right seat backrest fan 1-No. of start-up attempts after blocking error,0,
IDE08362-IDE00102,Right seat cushion fan 1-Control Module temperature,34, °C
IDE08362-MAS01447,Right seat cushion fan 1-Act.val.,0, /min
IDE08362-MAS01634,Right seat cushion fan 1-Supply voltage,13, V
IDE08362-MAS09948,Right seat cushion fan 1-Pin coding. spec. value,2,
IDE08362-MAS09949,Right seat cushion fan 1-Pin coding. act. value,2,
IDE08362-MAS10342,Right seat cushion fan 1-No. of start-up attempts after blocking error,0,
IDE08949-MAS07869,Operating current: light driver-Conn. pin 2,0, mA
IDE08949-MAS07870,Operating current: light driver-Conn. pin 3,0, mA
IDE08949-MAS07871,Operating current: light driver-Conn. pin 4,0, mA
IDE08949-MAS07872,Operating current: light driver-Conn. pin 5,0, mA
IDE08949-MAS07873,Operating current: light driver-Conn. pin 6,0, mA
IDE08949-MAS07874,Operating current: light driver-Conn. pin 7,0, mA
IDE08949-MAS07875,Operating current: light driver-Conn. pin 8,0, mA
IDE08949-MAS07876,Operating current: light driver-Conn. pin 9,0, mA
IDE08949-MAS07877,Operating current: light driver-Conn. pin 10,0, mA
IDE08949-MAS07878,Operating current: light driver-Conn. pin 11,0, mA
IDE08949-MAS07879,Operating current: light driver-Conn. pin 12,0, mA
IDE08949-MAS07880,Operating current: light driver-Conn. pin 13,0, mA
IDE08949-MAS07887,Operating current: light driver-Conn. pin 20,228, mA
IDE08949-MAS07888,Operating current: light driver-Conn. pin 21,204, mA
IDE08949-MAS07889,Operating current: light driver-Conn. pin 22,144, mA
IDE08949-MAS07890,Operating current: light driver-Conn. pin 23,114, mA
IDE08949-MAS07891,Operating current: light driver-Conn. pin 24,144, mA
IDE08949-MAS07892,Operating current: light driver-Conn. pin 25,0, mA
IDE08949-MAS07897,Operating current: light driver-Conn. pin 30,0, mA
IDE09065-MAS07964,Status: remote start-Engine run time after remote start,0, s
IDE09065-MAS16464,Status: remote start-Number of RemoteStarts carried out,2,
IDE09850-MAS07146,Garage door opener control head-Button 1,not coded/not installed,
IDE09850-MAS07147,Garage door opener control head-Button 2,not coded/not installed,
IDE09850-MAS07148,Garage door opener control head-Button 3,not coded/not installed,
IDE11134-IDE01943,Light sequence HU test result-Turn signal lamp,not installed / not active,
IDE11134-IDE02515,Light sequence HU test result-Low beam,not installed / not active,
IDE11134-IDE02614,Light sequence HU test result-Reversing light switch,not installed / not active,
IDE11134-IDE02743,Light sequence HU test result-High Beam,not installed / not active,
IDE11134-IDE03310,Light sequence HU test result-Brake lamp,not installed / not active,
IDE11134-IDE03638,Light sequence HU test result-Stationary cornering lamp,not installed / not active,
IDE11134-IDE05323,Light sequence HU test result-Fog lamp,not installed / not active,
IDE11134-IDE05839,Light sequence HU test result-Parking lamps,not installed / not active,
IDE11134-IDE06470,Light sequence HU test result-Periphery lighting,not installed / not active,
IDE11134-IDE06864,Light sequence HU test result-Daytime running lamps,not installed / not active,
IDE11134-MAS02354,Light sequence HU test result-Headlamp flasher,not installed / not active,
IDE11134-MAS03835,Light sequence HU test result-Position lamps,not installed / not active,
IDE11134-MAS03836,Light sequence HU test result-Rear fog lamp,not installed / not active,
IDE11134-MAS11025,Light sequence HU test result-Status,no restriction,
IDE11350-MAS12597,Sunlight photo sensor-Sun intensity left,385, W/m²
IDE11350-MAS12598,Sunlight photo sensor-Sun intensity right,290, W/m²
IDE11668-MAS06256,Driver side rear sliding door: central locking signals-Status door lock,not coded/not installed,
IDE11668-MAS06431,Driver side rear sliding door: central locking signals-Door contact switch,not coded/not installed,
IDE11668-MAS06433,Driver side rear sliding door: central locking signals-Door lock: safe status,not coded/not installed,
IDE11669-MAS06256,Passenger side rear sliding door: central locking signals-Status door lock,not coded/not installed,
IDE11669-MAS06431,Passenger side rear sliding door: central locking signals-Door contact switch,not coded/not installed,
IDE11669-MAS06433,Passenger side rear sliding door: central locking signals-Door lock: safe status,not coded/not installed,
IDE11670-MAS06256,Rear wing door: central locking signals-Status door lock,not coded/not installed,
IDE11670-MAS06431,Rear wing door: central locking signals-Door contact switch,not coded/not installed,
IDE11670-MAS06433,Rear wing door: central locking signals-Door lock: safe status,not coded/not installed,
IDE11727-IDE04806,Function of the central console button-Driving profile selection button,LED not installed,
IDE11727-MAS13125,Function of the central console button-Function of button 1,Start-stop,
IDE11727-MAS13129,Function of the central console button-Function of button 2,not coded/not installed,
IDE11727-MAS13132,Function of the central console button-Function of button 3,not coded/not installed,
IDE11727-MAS13135,Function of the central console button-Function of button 4,not coded/not installed,
IDE11943,Signature lamp,|Connector number,Connector terminal number
IDE11999-IDE03853,High values of headlight range adjustment: basic setting-Left front level control system sensor: height value adapted,-100.0,
IDE11999-IDE04143,High values of headlight range adjustment: basic setting-Left rear level control system sensor: height value adapted,-100.0,
IDE12060,Headlight range adjustment counter,00 00 00 00,
IDE12212,Cause control module incorrectly coded,not installed,
IDE12940-IDE01268,Lever functions of the steering column electronics-Windshield wiper,Not operated,
IDE12940-IDE02335,Lever functions of the steering column electronics-Signal light switch position,Not operated,
IDE12940-IDE02711,Lever functions of the steering column electronics-Rear wiper,Not operated,
IDE12940-MAS00232,Lever functions of the steering column electronics-MFI button UP,Not operated,
IDE12940-MAS00233,Lever functions of the steering column electronics-MFI button DOWN,Not operated,
IDE12940-MAS00234,Lever functions of the steering column electronics-MFI button RESET / OK,Not operated,
IDE12940-MAS00242,Lever functions of the steering column electronics-Driver assistance systems button,Not operated,
IDE12940-MAS00243,Lever functions of the steering column electronics-Buttons for driver assistance systems: status,No malfunction detected,
IDE12940-MAS01288,Lever functions of the steering column electronics-Horn,Not operated,
IDE12940-MAS02338,Lever functions of the steering column electronics-Windshield wiper: intermittent stage,Stage 4,
IDE12940-MAS02339,Lever functions of the steering column electronics-Windshield washer system,Not operated,
IDE12940-MAS02341,Lever functions of the steering column electronics-Rear window washer system,Not operated,
IDE12940,Lever functions of the steering column electronics,Not operated,
IDE14095-MAS17564,Wiper park position heater-Relay actuation,not coded/not installed,
IDE14110-MAS17842,Digital Key-NFC control section,not coded/not installed,
IDE14110-MAS17843,Digital Key-Bluetooth control section,not coded/not installed,
IDE14172-MAS03692,Remote key movement information-Key 1,Movement sensor faulty,
IDE14172-MAS03693,Remote key movement information-Key 2,not inoperative,
IDE14172-MAS03694,Remote key movement information-Key 3,Movement sensor faulty,
IDE14172-MAS03695,Remote key movement information-Key 4,Movement sensor faulty,
IDE14963-MAS19705,Remote start: current operating parameters-Captcha List,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE14963-MAS19706,Remote start: current operating parameters-Communication key,00 00 00 00 00 00 00 00,
IDE80251-MAS06439,Head area heater-Crash status,not coded/not installed,
IDE80251-MAS06646,Head area heater-Head area heater left: specified level,not coded/not installed,
IDE80251-MAS06647,Head area heater-Head area heater right: specified level,not coded/not installed,
IDE80251-MAS06648,Head area heater-Continuation at terminal 15 on,not coded/not installed,
IDE80251-MAS06649,Head area heater-Left front seat occupation status,not coded/not installed,
IDE80251-MAS06650,Head area heater-Right front occupation status,not coded/not installed,
MAS00043-IDE00019,Terminal 30 power supply-Voltage terminal 30,12.65, V
MAS00043-IDE05835,Terminal 30 power supply-Supply voltage for central locking,12.65, V
MAS00043-IDE05967,Terminal 30 power supply-Voltage terminal 30 left,12.70, V
MAS00043-IDE05968,Terminal 30 power supply-Voltage terminal 30 right,12.65, V
MAS00043-IDE08734,Terminal 30 power supply-Supply voltage for anti-theft alarm system,5.00, V
MAS00043-IDE08735,Terminal 30 power supply-Supply voltage for seat heater,12.65, V
MAS00043-MAS00362,Terminal 30 power supply-Battery voltage,5.00, V
MAS00043-MAS07472,Terminal 30 power supply-Battery voltage BEM,12.65, V
MAS00043-MAS07473,Terminal 30 power supply-Test voltage rear window defogger,0.00, V
MAS00043-MAS07474,Terminal 30 power supply-Test voltage windshield defogger,0.00, V
MAS00043-MAS21998,Terminal 30 power supply-Test voltage for wiper tray heater,0.00, V
MAS00179-MAS04422,Brake lamp switch-Brake light signal via CAN,On,
MAS00179-MAS07313,Brake lamp switch-Brake light signal via HW,On,
MAS00464-MAS00106,Standard - ambient data 1-Year,2022,
MAS00464-MAS00107,Standard - ambient data 1-Month,6,
MAS00464-MAS00108,Standard - ambient data 1-Day,18,
MAS00464-MAS00109,Standard - ambient data 1-Hours,10,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,34,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,52,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,20,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,156, km
MAS00829-MAS00244,Access/start authorization-Prompt wire,operated,
MAS00829-MAS01763,Access/start authorization-Signal Strength,-48,
MAS00829-MAS07866,Access/start authorization-Duration: last awakening wire actua.,4, ms
MAS01281,Back-up lamp,|Connector number,Connector terminal number
MAS01431-IDE01442,Vehicle key with remote control-Pressing a button,Not operated,
MAS01431-IDE01839,Vehicle key with remote control-Battery charge level,Not available,
MAS01431-MAS00077,Vehicle key with remote control-Immobilizer,NOT-DEFINED,
MAS01431-MAS01551,Vehicle key with remote control-Key number,255,
MAS01431-MAS05048,Vehicle key with remote control-Number of transmitters adapted,2,
MAS01431-MAS06362,Vehicle key with remote control-Code in catch area,Not available,
MAS01490-IDE02744,Energy management-Steering wheel heating,Enabled,
MAS01490-IDE04216,Energy management-Mirror heater,Enabled,
MAS01490-IDE80251,Energy management-Head area heater,Enabling stage 3,
MAS01490-MAS01535,Energy management-Rear window defogger,Enabled,
MAS01490-MAS01563,Energy management-Auxiliary Air Heater,Enabling stage 3,
MAS01490-MAS01564,Energy management-Front windshield heater,Enabled,
MAS01490-MAS01632,Energy management-Status,not active,
MAS01490-MAS02390,Energy management-Shutoff,42,
MAS01490-MAS05795,Energy management-Rear seat heater,Enabled,
MAS01490-MAS05796,Energy management-Emergency shut-down,0,
MAS01490-MAS05887,Energy management-Battery cut out relay 2,not enabled,
MAS01490-MAS06551,Energy management-Seat ventilation,Enabled,
MAS01490-MAS06552,Energy management-Front seat heating,Enabling stage 3,
MAS01490-MAS06553,Energy management-Display consumer switch-off,not active,
MAS01490-MAS06554,Energy management-Switch-off priority while driving,0,
MAS01490-MAS06555,Energy management-Maximum switch-off priority while driving,3,
MAS01490-MAS06556,Energy management-Switch-off with voltage drops,0,
MAS01490-MAS06557,Energy management-Switch-off priority with vehicle crash,0,
MAS01490-MAS06558,Energy management-Current negative charge balance,0, %
MAS01490-MAS06559,Energy management-Switch-off priority with engine off,0,
MAS01490-MAS06560,Energy management-Short distance driving,0,
MAS01597-IDE00542,Sunroof-Excessive temperature protection,not active,
MAS01597-IDE03114,Sunroof-Comfort function,not active,
MAS01597-MAS01979,Sunroof-Adapting,Not adapted,
MAS01597-MAS02282,Sunroof-Position,126, %
MAS01597-MAS02447,Sunroof-Release,not active,
MAS01597-MAS03656,Sunroof-Reverse,not active,
MAS01597-MAS05563,Sunroof-Norming,not normed,
MAS01597-MAS05737,Sunroof-Position,Tilt out posi.,
MAS03835,Position lamps,|Connector number,Connector terminal number
MAS03836,Rear fog lamp,|Connector number,Connector terminal number
MAS07959,Remote start history data,|Stop or cancel cause,Cause for cancellation
MAS08202-MAS09607,CAN p locked-Switch p locked,Engaged and locked,
MAS08202-MAS09608,CAN p locked-SMLS p locked plausibility,Implausible,
MAS08228-MAS01632,Light sensor-Status,not coded/not installed,
MAS08228-MAS02851,Light sensor-Brightness,22860, lx
MAS08228-MAS04121,Light sensor-Voltage,25.4, V
MAS13141,Test voltage,0, V
MAS18843,SE references from last used digital key devices,|Secure_element_reference_state,Secure_element_reference
ENG116910,Control unit internal measured value (supplier),00 00 00 03 0D 0C 00 0D 00 1A 00 1A 0D 00 63 00 00 1C 4F 00 00 00 00 00 00 00 00 00 00 00 00 02 00 06 00 04 AB D8 00 00 07 15 00 00 00 03 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 00 00 02 00 20 00 00 10 06 0C 00 00 00 00 00 00 05 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 34 00 00 00 00 00 00 53 64 09 12 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 04 00 00 01 00 01 0C 81 14 53 00 00 10 00 04 4C 20 64 00 20 00 00 40 02 00 02 7B 1F 00 00 00 79 67 90 00 3B 00 00 00 00 00 00 00 00 00 00 00 00 06 02 00 00 00 00 02 00 00 00 03 00 00 00 00 81,
ENG117285-ENG115840,Cycle_Protection_Counter-general_cycle_protection_counter,2,
ENG117285-ENG124947,Cycle_Protection_Counter-last_wake_up,gueltiges Funktelegramm,
ENG116908-ENG115779,Ecu_Intern_Meas._Values_2-Betriebsstunden_Abblendlicht_an,0, H
ENG116908-ENG115778,Ecu_Intern_Meas._Values_2-Hours_of_operation,0, H
ENG116908-ENG115775,Ecu_Intern_Meas._Values_2-Hours_of_operation_front_window_wiper,0,
ENG116908-ENG115776,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_front_window_wiper,3,
ENG116908-ENG115777,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_rear_window_wiper,0,
ENG116813,Entwicklermesswerte_CONTI,|KurzSchlussZaehler|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|,
ENG247080-IDE10662,light_swich_module-Light switch (button module),not coded/not installed,
ENG247080-MAS17838,light_swich_module-Exterior lighting: global shutoff,not coded/not installed,
ENG116909-ENG107391,LIN activity-LIN 1,active,
ENG116909-ENG107392,LIN activity-LIN 2,not coded/not installed,
ENG116909-ENG114948,LIN activity-LIN 3,not coded/not installed,
ENG116909-ENG114949,LIN activity-LIN 4,active,
ENG116909-ENG114950,LIN activity-LIN 5,active,
ENG116909-ENG114951,LIN activity-LIN 6,active,
ENG128380,Parametermonitor_0,82 14 64 64 A0 78 00 00 00 00 00 00 00 00 00 00 50 50 32 32 00 50 50 50 50 50 50 50 50 00 00 50 50 01 1C 1C 0A 00 00 00 1E 0A 1C 1C 03 07 00 00 06 06 28 00 3C 03 1E 22 00 04 19 05 00 01 01 28 00 02 00 02 1E 64 05 B4 1E 32 00 00 00 00 26 1D 5A 96 02 05 0A 6E 96 05 00 00 00 00 00 00 00 00 0A 1E 3C 42 0F 00 00 00 00 00 00 00 00 00 00 00 64 0A 01 00 00 00 00 00 00 00 00 00 00 00 00 00 63 0A 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 5A 19 E1 32 0A 0A 00 00 00 00 00 A0 00 00 00 A0 00 00 00 A0 06 0C 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116806,Parametermonitor_1,00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 64 64 64 64 64 00 64 64 64 64 64 64 64 64 3C 00 60 7E 7F 60 60 7E 60 60 60 7F 60 60 60 60 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 3C 00 60 7E 7F 60 60 7E 60 60 60 7F 60 60 60 60 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 01 01 00 00 00 14 00 00 04 10 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116807,Parametermonitor_2,0F 04 0A 00 16 00 00 14 28 14 00 14 32 5A 32 0A 1E 12 00 4B 0A 01 1E 5A 0F 3C 3C 05 0A 01 0A 78 00 FA 01 1C 00 0F 00 05 0A 14 03 02 00 19 64 00 64 1E 32 18 18 7D 28 05 28 28 7D 3C 3C 7D 7D 0A 19 3C 7D 2B 00 00 02 00 00 01 28 0A 28 19 0A 23 04 C8 FA 17 16 88 00 1E 05 00 01 C8 32 C8 14 00 5A 03 00 03 03 00 00 04 01 05 32 32 32 64 03 00 00 00 00 00 22 00 00 14 00 00 00 00 00 00 00 00 0F 14 50 78 32 3C 02 58 00 00 0A 6E 05 64 28 00 0A 06 19 0A 0A 28 00 00 00 00 00 00 00 00 00 00 14 14 14 00 32 00 00 00 00 28 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 28 14 14 C8 32 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116808-ENG115827,Parametermonitor_3-parameter_monitor_3_climatic,FF 02 32 00 3C FF 80 05 05 00 00 00 00 00 00 00 80 FF 02 32 3C 00 05 00 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 FF 02 05 00 00 00 00 00 00 00 00 00 00 00 00 02 0A 28 0F 1E 06 32 0A 34 0B 01 64 64 03 0A 05 01 0A 46 00 1E 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 18 14 14 1E 14 06 00 00 00 00,
ENG116808-ENG115828,Parametermonitor_3-parameter_monitor_3_wiper,0A 00 00 19 19 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 50 46 00 58 8B FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116809,Parametermonitor_4,04 04 14 1E 03 B4 00 0A 05 05 0A 4B 00 32 0A 00 00 1E 32 05 14 00 00 00 00 00 00 00 00 00 00 00 01 02 02 01 0A 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 04 0C 78 04 04 0C 01 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2A 3E 00 00 00 00 00 00 00 00 00 00 00 05 03 00 00 00 00 00 00 00 00 00 00 00 00 00 0A FF 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 03 0A 00 00 00 00 00 04 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 32 28 00 00 00 00 00 05 05 3C 04 01 01 01 01 96 01 01 C8 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00 3C 14 37 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116810,Parametermonitor_5,0A 00 0C 08 09 0A 05 0A 0A 14 08 0A 03 00 0A 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 04 00 00 1E 0A 05 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 46 00 03 09 01 05 00 00 00 00 00 00 0A 0F 0F 00 00 60 06 16 06 19 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116811,Parametermonitor_6,00 46 32 FA 3C 00 1E 32 05 04 3C 00 08 05 01 00 01 00 00 00 05 0A 50 0F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116911,Parametermonitor_7,00 0A 00 0A 00 0A FF FF 00 0A 00 0A FF FF FF FF 0F A0 00 32 00 32 00 32 00 32 00 32 00 0A 00 0A 00 32 FF FE 00 0A 00 32 00 32 00 00 00 0A 00 0A 00 00 FF FF 00 00 00 00 FF FF FF FF 00 00 00 00 00 00 00 0A 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116812,Parametermonitor_FF,00 00 05 30 30 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG126653,Personalized_Account_Key_History,|Account,Key number
ENG126652-MAS03692,Personalized_key__Setting-Key 1,0,
ENG126652-MAS03693,Personalized_key__Setting-Key 2,1,
ENG126652-MAS03694,Personalized_key__Setting-Key 3,0,
ENG126652-MAS03695,Personalized_key__Setting-Key 4,0,
ENG126652-MAS03696,Personalized_key__Setting-Key 5,0,
ENG126652-MAS03697,Personalized_key__Setting-Key 6,0,
ENG126652-MAS03698,Personalized_key__Setting-Key 7,0,
ENG126654,Personalized_Signals,|Perso_Konto,Perso_Steuerung
ENG116792-ENG115817,Power up history-Funktionsanforderung,|Funktionsanforderung|10|9|0|10|0|19|0|19|10|0|,
ENG130589-MAS16304,Remotestart_Monitor-Number of driver takeovers from RemoteStart,2,
ENG130589-MAS16305,Remotestart_Monitor-Number of duplicate activations,2,
ENG130589-MAS16306,Remotestart_Monitor-Number of incorrect takeovers,0,
ENG130589-MAS16307,Remotestart_Monitor-Average running time: group 1,4,
ENG130589-MAS16308,Remotestart_Monitor-Average running time: group 2,2,
ENG130589-MAS16309,Remotestart_Monitor-Average running time: group 3,3,
ENG130589-MAS16333,Remotestart_Monitor-Number of RemoteStarts,9,
ENG130589-MAS16334,Remotestart_Monitor-RemoteStart cancellations counter,7,
ENG116790-MAS00711,Supply voltage history-Odometer reading,28, km
ENG116790-ENG115814,Supply voltage history-highest voltage ever measured,14.9, V
ENG116790-ENG115815,Supply voltage history-hoechste im letzten Fahrzyklus gemessen Batteriespannung,12.9, V
ENG116790-ENG115816,Supply voltage history-voltage measurement: intern,12.6, V
ENG116791,Temperatures,30.50, °C
ENG127111-ENG127149,Valeo_Entwickler_MWB-Batterie_Spannung_KL_15,0.0, V
ENG127111-ENG127148,Valeo_Entwickler_MWB-Batterie_Spannung_KL_30,0.0, V
ENG127111-ENG127156,Valeo_Entwickler_MWB-GRA leitung,0,
ENG127111-ENG161085,Valeo_Entwickler_MWB-Historienspeicher im Fehlerfall,00 00 00 00 7E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG127111-ENG98652,Valeo_Entwickler_MWB-Horn,OFF,
ENG127111-ENG161099,Valeo_Entwickler_MWB-Lenkrad Heizung,0,
ENG127111-ENG161147,Valeo_Entwickler_MWB-Resetmonitor,0,
ENG127111-ENG127158,Valeo_Entwickler_MWB-U12V_SW2,0,
ENG127111-ENG161254,Valeo_Entwickler_MWB-WakeUp2,OFF,
ENG116907-IDE00020,Zusaetzliche Umgebungsdaten-Terminal 15 status,On,
ENG116907-IDE01716,Zusaetzliche Umgebungsdaten-Terminal 50 status,OFF,
ENG116907-IDE02515,Zusaetzliche Umgebungsdaten-Low beam,Not operated,
ENG116907-IDE04639,Zusaetzliche Umgebungsdaten-Last wake-up cause,Radio telegram: valid,
ENG116907-IDE07956,Zusaetzliche Umgebungsdaten-redundant signal line,infinite,
ENG116907-MAS01957,Zusaetzliche Umgebungsdaten-Outside temperature,30.5, °C
ENG116907-MAS02462,Zusaetzliche Umgebungsdaten-Automatic high beam assist,Not operated,
ENG116907-MAS02788,Zusaetzliche Umgebungsdaten-CAN,On,
ENG116907-MAS03835,Zusaetzliche Umgebungsdaten-Position lamps,Not operated,
ENG116907-MAS04121,Zusaetzliche Umgebungsdaten-Voltage,12.6, V
ENG116907-MAS06466,Zusaetzliche Umgebungsdaten-Parking light left,Not operated,
ENG116907-MAS06467,Zusaetzliche Umgebungsdaten-Parking light right,Not operated,
ENG116907-MAS14232,Zusaetzliche Umgebungsdaten-Light switch: zero setting,operated,
ENG116907-MAS19766,Zusaetzliche Umgebungsdaten-Status of brake lamp switch: discrete,On,
ENG116907-MAS19768,Zusaetzliche Umgebungsdaten-Brake lamp switch via CAN: status,On,
Elapsed Time: 01:23,,,
blockmap-10-5QA-919-283-H_3VV2X7B28NM061887-20220618-1235.CSV
;SW:5QA-919-283-H   HW:5QA-919-283 ---  Park/Steer Assist
;Component:PDC 4 Kanal   H08 0073, Coding:0601554011
;EV_EPHVA14AU3700000,009050,EV_EPHVA14AU3700000_009_VW37.rod
;Saturday,18,June,2022,12:35:54:14741
;VCID: CFF09876475E35239A8-809A
IDE00018,Voltage terminal 15,12.3, V
IDE00325,Diagnostic mode,VW - diagnostic mode,
IDE00958-MAS01632,Resulting distance of rear sensors-Status,infinite,
IDE00974,Outside air temperature internally calculated,30.50, °
IDE01122-MAS00988,Parking aid input signal-Reverse gear,No,
IDE01122-MAS01374,Parking aid input signal-Trailer,not installed,
IDE01123-MAS01632,Distance of left rear park assist sensor-Status,infinite,
IDE01124-MAS01632,Distance of left rear center park assist sensors-Status,infinite,
IDE01125-MAS01632,Distance of right rear center park assist sensors-Status,infinite,
IDE01126-MAS01632,Distance of right rear park assist sensor-Status,infinite,
IDE01131-MAS01632,Oscillating time of left rear park assist sensors-Status,Malfunction,
IDE01132-MAS01632,Oscillating time of left rear center park assist sensors-Status,Malfunction,
IDE01133-MAS01632,Oscillating time of right rear center park assist sensors-Status,Malfunction,
IDE01134-MAS01632,Oscillating time of right rear park assist sensors-Status,Malfunction,
IDE01162-MAS01426,Factory setting for park assist volume/frequencies-Rear parking aid buzzer: volume,Stage 4,
IDE01162-MAS01427,Factory setting for park assist volume/frequencies-Speaker frequency for rear park assist,Stage 1,
IDE01162-MAS01428,Factory setting for park assist volume/frequencies-Front parking aid buzzer: volume,ERROR,
IDE01162-MAS01429,Factory setting for park assist volume/frequencies-Speaker frequency for front park assist,ERROR,
IDE01163,Sound output for park assist in selector lever position P,OFF,
IDE01165,Park assist activation tone,On,
IDE01166,Supply voltage for park assist sensor,12.3, V
IDE01167,Convertible offset for volume level 1,not installed,
IDE01168,Increment for convertible volume levels,not installed,
IDE01169,Audio lowering request,Yes,
IDE01171,Convertible factory setting offset for volume level 1,not installed,
IDE01172,Factory setting for increment for convertible volume levels,not installed,
IDE01173,Factory setting: audio lowering,Yes,
IDE01411-IDE11215,Personalization 1 for park assist-Automatic Activation,activated,
IDE01411-IDE11217,Personalization 1 for park assist-Show parking space,not activated,
IDE01411-MAS01426,Personalization 1 for park assist-Rear parking aid buzzer: volume,Stage 4,
IDE01411-MAS01427,Personalization 1 for park assist-Speaker frequency for rear park assist,Stage 1,
IDE01411-MAS01428,Personalization 1 for park assist-Front parking aid buzzer: volume,Stage 4,
IDE01411-MAS01429,Personalization 1 for park assist-Speaker frequency for front park assist,Stage 7,
IDE01411-MAS06193,Personalization 1 for park assist-Profile 1,Parking aid active,
IDE01411-MAS12843,Personalization 1 for park assist-Maneuvering brake function,activated,
IDE01412-IDE11215,Personalization 2 for park assist-Automatic Activation,activated,
IDE01412-IDE11217,Personalization 2 for park assist-Show parking space,not activated,
IDE01412-MAS01426,Personalization 2 for park assist-Rear parking aid buzzer: volume,Stage 4,
IDE01412-MAS01427,Personalization 2 for park assist-Speaker frequency for rear park assist,Stage 1,
IDE01412-MAS01428,Personalization 2 for park assist-Front parking aid buzzer: volume,Stage 4,
IDE01412-MAS01429,Personalization 2 for park assist-Speaker frequency for front park assist,Stage 7,
IDE01412-MAS06194,Personalization 2 for park assist-Profile 2,not active,
IDE01412-MAS12843,Personalization 2 for park assist-Maneuvering brake function,activated,
IDE01413-IDE11215,Personalization 3 for park assist-Automatic Activation,activated,
IDE01413-IDE11217,Personalization 3 for park assist-Show parking space,not activated,
IDE01413-MAS01426,Personalization 3 for park assist-Rear parking aid buzzer: volume,Stage 4,
IDE01413-MAS01427,Personalization 3 for park assist-Speaker frequency for rear park assist,Stage 1,
IDE01413-MAS01428,Personalization 3 for park assist-Front parking aid buzzer: volume,Stage 4,
IDE01413-MAS01429,Personalization 3 for park assist-Speaker frequency for front park assist,Stage 7,
IDE01413-MAS06195,Personalization 3 for park assist-Profile 3,not active,
IDE01413-MAS12843,Personalization 3 for park assist-Maneuvering brake function,activated,
IDE01414-IDE11215,Personalization 4 for park assist-Automatic Activation,activated,
IDE01414-IDE11217,Personalization 4 for park assist-Show parking space,not activated,
IDE01414-MAS01426,Personalization 4 for park assist-Rear parking aid buzzer: volume,Stage 4,
IDE01414-MAS01427,Personalization 4 for park assist-Speaker frequency for rear park assist,Stage 1,
IDE01414-MAS01428,Personalization 4 for park assist-Front parking aid buzzer: volume,Stage 4,
IDE01414-MAS01429,Personalization 4 for park assist-Speaker frequency for front park assist,Stage 7,
IDE01414-MAS06196,Personalization 4 for park assist-Profile 4,not active,
IDE01414-MAS12843,Personalization 4 for park assist-Maneuvering brake function,activated,
IDE01632,System status of parking aid,not active,
IDE01633,Cause for parking aid shut-off,No shut-off requirement,
IDE01943,Turn signal lamp,Not operated,
IDE03782,Switch-off speed for parking assist,15, km/h
IDE03784,Temporary function limitation due to environmental influences,No,
IDE11152-MAS12261,Wheel circumferences-Right front wheel circumference,08 5E,
IDE11152-MAS12262,Wheel circumferences-Left front wheel circumference,08 5C,
IDE11152-MAS12263,Wheel circumferences-Right rear wheel circumference,08 60,
IDE11152-MAS12264,Wheel circumferences-Left rear wheel circumference,08 61,
IDE12038-IDE00086,Brake requirements (ring buffer)-Accelerator pedal position,255, %/s
IDE12038-IDE02211,Brake requirements (ring buffer)-Brake pressure,255, bar
IDE12038-IDE16238,Brake requirements (ring buffer)-Escape request: event list,1,
IDE12038-MAS00106,Brake requirements (ring buffer)-Year,2127,
IDE12038-MAS00107,Brake requirements (ring buffer)-Month,15,
IDE12038-MAS00108,Brake requirements (ring buffer)-Day,31,
IDE12038-MAS00109,Brake requirements (ring buffer)-Hours,31,
IDE12038-MAS00110,Brake requirements (ring buffer)-Minutes,63,
IDE12038-MAS00111,Brake requirements (ring buffer)-Seconds,63,
IDE12038-MAS00370,Brake requirements (ring buffer)-Vehicle speed,0.0, km/h
IDE12038-MAS11940,Brake requirements (ring buffer)-Brake electronics fault,Parking aid active,
IDE12038-MAS13914,Brake requirements (ring buffer)-Object horizontal position,0.0, m
IDE12038-MAS13915,Brake requirements (ring buffer)-Object vertical position,0.0, m
MAS00464-MAS00110,Standard - ambient data 1-Minutes,35,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,41,
MAS01426,Rear parking aid buzzer: volume,Stage 4,
MAS01427,Speaker frequency for rear park assist,Stage 1,
MAS10122,ARA operating condition,Initialization,
MAS10122-MAS11700,ARA operating condition-ARA function request door control module,no request,
MAS16451-IDE11215,Personalization 5-Automatic Activation,activated,
MAS16451-IDE11217,Personalization 5-Show parking space,not activated,
MAS16451-MAS01426,Personalization 5-Rear parking aid buzzer: volume,Stage 4,
MAS16451-MAS01427,Personalization 5-Speaker frequency for rear park assist,Stage 1,
MAS16451-MAS01428,Personalization 5-Front parking aid buzzer: volume,Stage 4,
MAS16451-MAS01429,Personalization 5-Speaker frequency for front park assist,Stage 7,
MAS16451-MAS06197,Personalization 5-Profile 5,not active,
MAS16451-MAS12843,Personalization 5-Maneuvering brake function,activated,
MAS16452-IDE11215,Personalization 6-Automatic Activation,activated,
MAS16452-IDE11217,Personalization 6-Show parking space,not activated,
MAS16452-MAS01426,Personalization 6-Rear parking aid buzzer: volume,Stage 4,
MAS16452-MAS01427,Personalization 6-Speaker frequency for rear park assist,Stage 1,
MAS16452-MAS01428,Personalization 6-Front parking aid buzzer: volume,Stage 4,
MAS16452-MAS01429,Personalization 6-Speaker frequency for front park assist,Stage 7,
MAS16452-MAS06198,Personalization 6-Profile 6,not active,
MAS16452-MAS12843,Personalization 6-Maneuvering brake function,activated,
MAS16453-IDE11215,Personalization 7-Automatic Activation,activated,
MAS16453-IDE11217,Personalization 7-Show parking space,not activated,
MAS16453-MAS01426,Personalization 7-Rear parking aid buzzer: volume,Stage 4,
MAS16453-MAS01427,Personalization 7-Speaker frequency for rear park assist,Stage 1,
MAS16453-MAS01428,Personalization 7-Front parking aid buzzer: volume,Stage 4,
MAS16453-MAS01429,Personalization 7-Speaker frequency for front park assist,Stage 7,
MAS16453-MAS06199,Personalization 7-Profile 7,not active,
MAS16453-MAS12843,Personalization 7-Maneuvering brake function,activated,
ENG113995,Dimming_Signal_Terminal_58xd_pdc_pla,80, %
blockmap-13-2Q0-907-572-AA_3VV2X7B28NM061887-20220618-1236.CSV
;SW:2Q0-907-572-AA   HW:2Q0-907-572-D ---  Auto Dist. Reg
;Component:ACCCONTIMQB   H09 0396, Coding:300007C15CFF8748949C810580409700000000000000000034
;EV_ACCMRRCONTIVW376,003018,EV_ACCMRRCONTIVW376_003.rod
;Saturday,18,June,2022,12:36:12:14741
;VCID: F3B834868B3631C35E0-80A6
IDE00002,Transport mode,OFF,
IDE00018,Voltage terminal 15,12.5, V
IDE00075,Vehicle speed,0.00, m/s
IDE00102,Control Module temperature,55, °C
IDE00391,Adaptive distance regulation: status,ACC_StandBy,
IDE01794-ENG161032,ACC operating lever signal-ACC_main_switch,Not operated,
IDE01794-ENG98480,ACC operating lever signal-Cancel,Not operated,
IDE01794-ENG161043,ACC operating lever signal-Control_lever_coding,ACC,
IDE01794-ENG161044,ACC operating lever signal-Control_lever_error,No malfunction,
IDE01794-ENG161056,ACC operating lever signal-distance_control_minus,Not operated,
IDE01794-ENG161057,ACC operating lever signal-distance_control_plus,Not operated,
IDE01794-ENG161132,ACC operating lever signal-part_control_lever,VW_MFL_Gen2,
IDE01794-ENG159615,ACC operating lever signal-Resume,Not operated,
IDE01794-ENG98911,ACC operating lever signal-Set,Not operated,
IDE01794-ENG161234,ACC operating lever signal-tip_down_in_step_1,Not operated,
IDE01794-ENG161235,ACC operating lever signal-tip_down_in_step_2,Not operated,
IDE01794-ENG161236,ACC operating lever signal-tip_up_in_step_1,Not operated,
IDE01794-ENG161237,ACC operating lever signal-tip_up_in_step_2,Not operated,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,C0 1F E6 6E,
IDE03008-MAS12557,Stop process prevented-Vehicle ahead starts driving: ACC active: automatic drive-off disabled,not active,
IDE03008-MAS12559,Stop process prevented-Vehicle ahead starts driving: ACC passive,not active,
IDE03008-MAS12560,Stop process prevented-Vehicle ahead starts driving: ACC off,not active,
IDE03008-MAS16236,Stop process prevented-Vehicle ahead approaching: ECC not coded,not active,
IDE03010-MAS12557,Number of prevented stop processes-Vehicle ahead starts driving: ACC active: automatic drive-off disabled,0,
IDE03010-MAS12559,Number of prevented stop processes-Vehicle ahead starts driving: ACC passive,0,
IDE03010-MAS12560,Number of prevented stop processes-Vehicle ahead starts driving: ACC off,0,
IDE03010-MAS16236,Number of prevented stop processes-Vehicle ahead approaching: ECC not coded,0,
IDE03011-MAS12557,Number of requested start processes-Vehicle ahead starts driving: ACC active: automatic drive-off disabled,0,
IDE03011-MAS12558,Number of requested start processes-Vehicle ahead starts driving: ACC active: automatic drive-off possible,0,
IDE03011-MAS12559,Number of requested start processes-Vehicle ahead starts driving: ACC passive,0,
IDE03011-MAS12560,Number of requested start processes-Vehicle ahead starts driving: ACC off,0,
IDE03011-MAS16236,Number of requested start processes-Vehicle ahead approaching: ECC not coded,0,
IDE03660,Longitudinal acceleration,0.09, m/s²
IDE04329-ENG118721,Status of all SWaP functions-SWaP_function_state array,|ID number,Release code for a SWaP function
IDE04332-ENG117770,Release code for a SWaP function-fsc,Not available,
IDE04334-MAS02643,Public key for SWaP function-Key,83 D8 A9 C6 A2 5F 95 2F 9A C7 07 19 CE 81 32 39 60 7F 0F D0 B2 94 86 3E 82 8C 6E 19 B5 2D 10 04 55 7F E1 1D 37 CC AA 45 46 81 1C 27 FC 2B F2 07 70 6D DB 7B B4 F2 A4 92 00 FF C0 96 82 48 8D E2 81 FD 83 D6 B5 E3 F7 E4 67 2E D3 F9 9D 81 9C E5 C9 71 C8 76 21 BE 13 C4 26 06 D9 15 EE 1A 8D A0 DF 31 66 C3 AA 82 99 AD 2B 38 92 4F BD C5 D6 3C C2 2A 6C 5C AB 63 ED 39 D2 0E B5 FA 98 58 37 EF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04805-IDE02955,Driving profile selection-System status,available.,
IDE04805-MAS01447,Driving profile selection-Act.val.,3,
IDE04805-MAS01448,Driving profile selection-Target value,3,
IDE05228,Operating hour counter,360, min
IDE05814,Individualization characteristic,21 4B 02 A4 76,
IDE06307-MAS00106,Stop prevention history data-Year,2127,
IDE06307-MAS00107,Stop prevention history data-Month,15,
IDE06307-MAS00108,Stop prevention history data-Day,31,
IDE06307-MAS00109,Stop prevention history data-Hours,31,
IDE06307-MAS00110,Stop prevention history data-Minutes,63,
IDE06307-MAS00111,Stop prevention history data-Seconds,63,
IDE06307-MAS16236,Stop prevention history data-Vehicle ahead approaching: ECC not coded,Vehicle ahead approaching: ECC not coded,
IDE06307,Stop prevention history data,Vehicle ahead starts driving: ACC passive,
IDE06307,Stop prevention history data,Vehicle ahead starts driving: ACC off,
IDE06307,Stop prevention history data,Vehicle ahead starts driving: ACC active: automatic drive-off disabled,
IDE06308-MAS00106,Start request history data-Year,2127,
IDE06308-MAS00107,Start request history data-Month,15,
IDE06308-MAS00108,Start request history data-Day,31,
IDE06308-MAS00109,Start request history data-Hours,31,
IDE06308-MAS00110,Start request history data-Minutes,63,
IDE06308-MAS00111,Start request history data-Seconds,63,
IDE06308-MAS16236,Start request history data-Vehicle ahead approaching: ECC not coded,Vehicle ahead approaching: ECC not coded,
IDE06308,Start request history data,Vehicle ahead starts driving: ACC passive,
IDE06308,Start request history data,Vehicle ahead starts driving: ACC off,
IDE06308,Start request history data,Vehicle ahead starts driving: ACC active: automatic drive-off disabled,
IDE06308,Start request history data,Vehicle ahead starts driving: ACC active: automatic drive-off possible,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,00,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,00,
IDE08936,Misalignment angle: horiz,0.214, °
IDE09380-IDE01784,Performed adjustment-Misalignment angle,0.00, °
IDE09380-MAS00106,Performed adjustment-Year,2022,
IDE09380-MAS00107,Performed adjustment-Month,3,
IDE09380-MAS00108,Performed adjustment-Day,16,
IDE09380-MAS05610,Performed adjustment-Calibration,static,
IDE09380-MAS08804,Performed adjustment-Horizontal offset angle,0.21, °
IDE09380-MAS08805,Performed adjustment-Vertical offset angle,0.41, °
IDE09906,Vertical deadjustment,-0.103, °
IDE11923-MAS13423,Number of calibration procedures-Counter for statistical calibration procedures started,1,
IDE11923-MAS13424,Number of calibration procedures-Counter for statistical calibration procedures successful,1,
IDE11923-MAS13425,Number of calibration procedures-Counter for dynamical calibration procedures started,0,
IDE11923-MAS13426,Number of calibration procedures-Counter for dynamical calibration procedures successful,0,
IDE11924-MAS13427,Correction angle-Horizontal correction angle: dynamic,0.000, °
IDE11924-MAS13428,Correction angle-Vertical correction angle: dynamic,0.000, °
IDE11924-MAS13429,Correction angle-Horizontal correction angle: currently,0.210, °
IDE11924-MAS13430,Correction angle-Vertical correction angle: currently,-0.100, °
IDE11924-MAS13887,Correction angle-Horizontal correction angle static,0.210, °
IDE11924-MAS13888,Correction angle-Vertical correction angle static,0.410, °
IDE12062,Counter for terminal 15 reset,130,
ENG254667,Freeze_Frame_Dataset_Sensor_01,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254668,Freeze_Frame_Dataset_Sensor_02,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254669,Freeze_Frame_Dataset_Sensor_03,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254670,Freeze_Frame_Dataset_Sensor_04,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254671,Freeze_Frame_Dataset_Sensor_05,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254672,Freeze_Frame_Dataset_Sensor_06,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254673,Freeze_Frame_Dataset_Sensor_07,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254674,Freeze_Frame_Dataset_Sensor_08,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254675,Freeze_Frame_Dataset_Sensor_09,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254676,Freeze_Frame_Dataset_Sensor_10,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254677,Freeze_Frame_Dataset_Sensor_11,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254678,Freeze_Frame_Dataset_Sensor_12,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254679,Freeze_Frame_Dataset_Sensor_13,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254680,Freeze_Frame_Dataset_Sensor_14,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254681,Freeze_Frame_Dataset_Sensor_15,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG131998,Number_of_boost_function_active,0,
ENG131999,Number_of_deactivation_ASR_active,0,
ENG132000,Number_of_deactivation_ESC_active,0,
ENG107928,Operating_time_ACC,1, min
ENG131991,Operating_time_ACC_active_driving_programm_auto,1, min
ENG131990,Operating_time_ACC_active_driving_programm_comfort,0, min
ENG131989,Operating_time_ACC_active_driving_programm_dynamic,0, min
ENG131992,Operating_time_ACC_active_driving_programm_efficiency,0, min
ENG131993,Operating_time_ACC_active_timegap_1,0, min
ENG131994,Operating_time_ACC_active_timegap_2,0, min
ENG131995,Operating_time_ACC_active_timegap_3,1, min
ENG131996,Operating_time_ACC_active_timegap_4,0, min
ENG131997,Operating_time_ACC_active_timegap_5,0, min
ENG132001,Operating_time_ACC_active_v-delta_0,1, min
ENG132004,Operating_time_ACC_active_v-delta_large,0, min
ENG132003,Operating_time_ACC_active_v-delta_medium,0, min
ENG132002,Operating_time_ACC_active_v-delta_small,0, min
Elapsed Time: 00:17,,,
blockmap-15-5Q0-959-655-CB_3VV2X7B28NM061887-20220618-1236.CSV
;SW:5Q0-959-655-CB   HW:5Q0-959-655-CB ---  Airbags
;Component:AirbagVW21    008 0421, Coding:8CCCFC00000000005000001FC24800000065
;EV_AirbaVW20SMEVW37X,002166,EV_AirbaVW20SMEVW37X_VW37.rod
;Saturday,18,June,2022,12:36:35:14741
;VCDS Version: Beta 22.4.0 (x64)  Data version: 20220407 DS338.0
;VCID: 82566142C48C084B456-80D6
Group,Description,Actual,
IDE00821,Seat belt switch 2nd row driver's side,not installed,
IDE00822,Safety belt switch 2nd row frt.passenger side,not installed,
IDE00823,Seat belt switch 2nd row center,not installed,
IDE00824,Seat belt switch 3rd row driver's side,not installed,
IDE00825,Passenger side 3rd row seat belt switch,not installed,
IDE00919,Driver side airbag igniter ohm value,3.0, Ohm
IDE00956,Occupation status: frt.passenger seat,Empty or child or child safety seat,
IDE01100,Passenger side airbag igniter ohm value,2.3, Ohm
IDE01101,Passenger side airbag igniter 2 ohm value,2.2, Ohm
IDE01102,Driver thorax airbag igniter ohm value,2.5, Ohm
IDE01103,Passenger side side airbag igniter ohm value,2.5, Ohm
IDE01104,driver side rear airbag igniter ohm value,no measured value present,
IDE01105,Ft. pass.side rear airbag igniter ohm value,no measured value present,
IDE01106,Driver side head curtain airbag igniter ohm value,2.4, Ohm
IDE01107,Frt.pass. side head curtain airbag igniter ohm value,2.4, Ohm
IDE01108,Driver side knee airbag igniter ohm value,no measured value present,
IDE01109,Frt.pass. side knee airbag igniter ohm value,no measured value present,
IDE01110,Driver side belt tensioner igniter ohm value,2.4, Ohm
IDE01111,Frt.pass. side belt tensioner igniter ohm value,2.3, Ohm
IDE01112,Driver side belt tensioner igniter 2 ohm value,2.5, Ohm
IDE01113,Frt.pass. side belt tensioner igniter 2 ohm value,2.4, Ohm
IDE01114,Driver side belt force limiter igniter ohm value,2.4, Ohm
IDE01115,side belt force limiter igniter ohm value,2.3, Ohm
IDE01116,driver side rear belt tensioner igniter ohm value,no measured value present,
IDE01117,Passenger side rear belt tensioner igniter ohm value,no measured value present,
IDE01119,Battery open circuit igniter ohm value,no measured value present,
IDE01193,Driver belt tensioner ohm value,Too Small,
IDE01194,Frt.pass. belt tensioner ohm value,Too Small,
IDE01195,Front passenger side seat occupancy detection: Ohm value,no measured value present,
IDE01197,Key switch contact 1 ohm value,too large,
IDE01198,Key switch contact 2 ohm value,too large,
IDE01200,Driver seat position sensor current value,5.8, mA
IDE01201,Frt.pass. seat position sensor current value,5.8, mA
IDE01205,Safety belt switch 2nd row driver side ohm value,no measured value present,
IDE01206,Safety belt switch 2nd row frt.pass. side ohm value,no measured value present,
IDE01207,Safety belt switch center 2nd row ohm value,no measured value present,
IDE01208,Seat belt switch 3rd row driver side ohm value,no measured value present,
IDE01209,Seat belt switch 3rd row frt.pass. side ohm value,no measured value present,
IDE01271,Number of rollover bar deployments,0,
IDE01555,Number of frontal crashes,0,
IDE02852,Battery Interrupt Igniter High-Voltage Battery,not installed,
IDE02853,Igniter for batt. interrupt: high volt. batt. ohm value,no measured value present,
IDE03870,Seat occupied recognition malfunction status,0,
IDE03870,Seat occupied recognition malfunction status,|,
IDE06959,Seat occupant detection: diagnosis signal,31.5, %
IDE06960,Seat occupant detection: msmt. signal,1.5, %
IDE06961,Seat occupant detection: ref. signal,1.0, %
IDE13284-MAS01632,Seat-occupied recognition: 3rd row driver side-Status,not installed,
IDE13284-MAS05030,Seat-occupied recognition: 3rd row driver side-Resistance,0.0, Ohm
IDE13586-MAS01632,Seat-occupied recognition: 3rd row front passenger side-Status,not installed,
IDE13586-MAS05030,Seat-occupied recognition: 3rd row front passenger side-Resistance,0.0, Ohm
MAS00001,Driver airbag igniter,correct,
MAS00003,Front passenger airbag igniter,correct,
MAS00004,Front passenger airbag igniter 2,correct,
MAS00005,Driver thorax airbag igniter,correct,
MAS00006,Front passenger side airbag igniter,correct,
MAS00007,Driver side rear thorax airbag igniter,cannot be measured currently,
MAS00008,Passenger side rear thorax airbag igniter,cannot be measured currently,
MAS00009,Driver head curtain airbag igniter,correct,
MAS00010,Front passenger head curtain airbag igniter,correct,
MAS00011,Driver knee airbag igniter,cannot be measured currently,
MAS00012,Front passenger knee airbag igniter,cannot be measured currently,
MAS00013,Driver side seat belt tension igniter,correct,
MAS00014,Front passenger side seat belt tension igniter,correct,
MAS00015,Driver's Safety Belt Tensioner Igniter 2,correct,
MAS00016,Front passenger seat belt tensioner igniter 2,correct,
MAS00017,Driver's Belt Force Limiter,correct,
MAS00018,Front passenger side belt force limiter igniter,correct,
MAS00019,Driver side rear safety belt tension igniter,cannot be measured currently,
MAS00020,Passenger side rear seat belt tensioner igniter,cannot be measured currently,
MAS00022,Battery Interrupt Igniter,cannot be measured currently,
MAS00025,Driver seat belt switch,not connected,
MAS00026,Front passenger side safety belt switch,not connected,
MAS00030,Seat occupied recognition,Not assigned,
MAS00031,Airbag deactivation status,OFF,
MAS00032,Key switch terminal 1,not installed,
MAS00033,Key switch terminal 2,not installed,
MAS00035,Seat position sensor: driver side,Rear,
MAS00036,Seat position sensor: front passenger side,Rear,
MAS00037,Calibration status,0,
MAS00038,Seat occupied recognition: driver side: rear,not installed,
MAS00039,Seat occupied recognition: passenger side: rear,not installed,
MAS00040,Seat occupied recognition: center: rear,not installed,
MAS00044,Terminal 15 power supply,12.7, V
MAS01634,Supply voltage,correct,
Elapsed Time: 00:13,,,
blockmap-17-17A-920-420-B_3VV2X7B28NM061887-20220618-1229.CSV
;SW:17A-920-420-B   HW:17A-920-420-B ---  Instruments
;Component:KOMBI         524 6170, Coding:08A44808EF8CCF050288624B500000082060070D
;EV_DashBoardVDDMQBA0,001046,EV_DashBoardVDDMQBA0_VW37.rod
;Saturday,18,June,2022,12:29:29:14741
;VCID: 9C6A3F3A4628DEBBAFA-80C8
IDE00019,Voltage terminal 30,12.5, V
IDE00021,Engine RPM,1224.00, /min
IDE00025,Coolant temperature,30.00, °C
IDE00191,Charge air pressure: actual value,11.60, %
IDE00196,Engine oil temperature,26, °C
IDE00301,Mileage,156, km
IDE00310,Outside temperature,30.5, °C
IDE00316-IDE00500,Time-Hour,10, H
IDE00316-IDE00501,Time-Minute,29, min
IDE00316-MAS00111,Time-Seconds,6, s
IDE00317-IDE00502,Date-Year,2022, yr
IDE00317-IDE00503,Date-Month,6, Months
IDE00317-IDE00504,Date-Day,18, d
IDE00510,ESI: distance driven from inspection,141, km
IDE00511,ESI: time from inspection,18, d
IDE00512,ESI: minimum value km-driving distance/inspection,15000, km
IDE00513,ESI: maximum value km-driving distance/inspection,30000, km
IDE00514,ESI: maximum value of time between inspections,730, d
IDE00515,ESI: oil quality,poor oil quality,
IDE00517,ESI: soot entry,0, km
IDE00518,ESI: thermal load,300, km
IDE00520,Photo transistor,253,
IDE00695,ESI: service exceedance in km,0, km
IDE00696,ESI: service exceedance in days,0, d
IDE00697,ESI: remaining distance,15960, km
IDE00698,ESI: remaining running time,347, d
IDE00787-IDE02689,Cause for cancellation-Complete tank calibration,not performed,
IDE00787-IDE02690,Cause for cancellation-Wet dry tank calibration,not performed,
IDE00819,Day counter,93, d
IDE00827,ESI: minimum value of time between inspections,365, d
IDE00843,Starting impulse recognized,No,
IDE00845-MAS03213,Wheel circumference-Average wheel circumference for trip distance,2069, mm
IDE00845-MAS03214,Wheel circumference-Maximum wheel circumference for speed,2069, mm
IDE00935,ESI: Theoretical service interval,15000, km
IDE01076,Time since ignition off,86808, s
IDE01153,SIA: maximum value of distance to service,16100, km
IDE01154,SIA: maximum value of time to service,365, d
IDE02307,Parking brake status,Not operated,
IDE02642,Outside temp.: displayed value,30.5, °C
IDE03193-MAS02352,Terminal 58 status-Display dimming terminal 58d,FD,
IDE03193-MAS02353,Terminal 58 status-Switch dimming terminal 58s,00,
IDE03193-MAS02916,Terminal 58 status-Dimmer: duty cycle terminal 58st,64,
IDE03193-MAS02917,Terminal 58 status-Sensor for detecting light in the instrument panel insert,571,
IDE03349,FIX:Max. distance driven until next mileage-related inspection,32200, km
IDE03350,FIX: Maximum time until next time-dependent inspection,730, d
IDE03351,FIX: Distance covered since last mileage-dependent inspection,100, km
IDE03352,FIX: Time since last time-dependent inspection,18, d
IDE03471-IDE02383,Vehicle configuration-Dynamic steering,Correct coding,
IDE03471-IDE04525,Vehicle configuration-Wheel Damping Electronics,Correct coding,
IDE03471-IDE04939,Vehicle configuration-Tire Pressure Monitoring System (TPMS),Correct coding,
IDE03471-IDE05830,Vehicle configuration-Rear Spoiler,Correct coding,
IDE03471-IDE07016,Vehicle configuration-Tire Pressure Monitoring System (TPMS),Correct coding,
IDE03471-IDE07944,Vehicle configuration-electronic brake booster,Correct coding,
IDE03471-MAS01374,Vehicle configuration-Trailer,Correct coding,
IDE03471-MAS01891,Vehicle configuration-Lane assist,Correct coding,
IDE03471-MAS01938,Vehicle configuration-Traffic sign detection,Correct coding,
IDE03471-MAS02570,Vehicle configuration-Differential lock electronics,Correct coding,
IDE03471-MAS02725,Vehicle configuration-Customer-specific function control module,Correct coding,
IDE03471-MAS06008,Vehicle configuration-Internal noise sound actuator,Correct coding,
IDE03471-MAS08201,Vehicle configuration-Trailer maneuvering assistant,Correct coding,
IDE03471-MAS08940,Vehicle configuration-Collision warning,Correct coding,
IDE03471-MAS09196,Vehicle configuration-Rear Axle Steering,Correct coding,
IDE03471-MAS12422,Vehicle configuration-intelligent parking assistant,Correct coding,
IDE03472-MAS03806,Volume after refueling-Last displayed quantity before refueling,4.0, l
IDE03472-MAS03807,Volume after refueling-Last displayed quantity after refueling,54.0, l
IDE03472-MAS03808,Volume after refueling-Last sensor final value at end of refueling,54.6, l
IDE03472-MAS03809,Volume after refueling-Last reference quantity,3.7, l
IDE03472-MAS03810,Volume after refueling-Penultimate displayed quantity before refueling,0.0, l
IDE03472-MAS03811,Volume after refueling-Penultimate displayed quantity after refueling,0.0, l
IDE03472-MAS03812,Volume after refueling-Penultimate sensor final value at end of refueling,0.0, l
IDE03472-MAS03813,Volume after refueling-Penultimate reference quantity,0.0, l
IDE03472-MAS03814,Volume after refueling-Third-last displayed volume before refueling,0.0, l
IDE03472-MAS03815,Volume after refueling-Third-last displayed volume after refueling,0.0, l
IDE03472-MAS03816,Volume after refueling-Third-last sensor final value at end of refueling,0.0, l
IDE03472-MAS03817,Volume after refueling-Third-last reference quantity,0.0, l
IDE03472-MAS03818,Volume after refueling-Fourth-last displayed volume before refueling,0.0, l
IDE03472-MAS03819,Volume after refueling-Fourth-last displayed volume after refueling,0.0, l
IDE03472-MAS03820,Volume after refueling-Fourth-last sensor final value at end of refueling,0.0, l
IDE03472-MAS03821,Volume after refueling-Fourth-last reference quantity,0.0, l
IDE03472-MAS03822,Volume after refueling-Last error status,0,
IDE03472-MAS03823,Volume after refueling-Penultimate error status,0,
IDE03472-MAS03824,Volume after refueling-Third-last error status,0,
IDE03472-MAS03825,Volume after refueling-Fourth-last error status,0,
IDE03472-MAS06153,Volume after refueling-Last distance,0,
IDE03472-MAS06154,Volume after refueling-Penultimate distance,0,
IDE03472-MAS06155,Volume after refueling-Third to last distance,0,
IDE03472-MAS06156,Volume after refueling-Fourth to last distance,0,
IDE03473-IDE00730,tank sensor-Fuel level sensor 1 including soiling resistance,89, Ohm
IDE03473-IDE00731,tank sensor-Fuel level sensor 2 including soiling resistance,185, Ohm
IDE03473-IDE00732,tank sensor-Fuel level sensor 1 soiling resistance,-3, Ohm
IDE03473-IDE00733,tank sensor-Fuel level sensor 2 soiling resistance,-1, Ohm
IDE03473-IDE03494,tank sensor-Fuel level sensor 3 including soiling resistance,65535, Ohm
IDE03473-IDE03495,tank sensor-Fuel level sensor 3 soiling resistance,-32768, Ohm
IDE03473-IDE03496,tank sensor-Fuel level sensor 4 including soiling resistance,65535, Ohm
IDE03473-IDE03497,tank sensor-Fuel level sensor 4 soiling resistance,-32768, Ohm
IDE03473-MAS03798,tank sensor-Raw value sensor 1 resistor 1,1280,
IDE03473-MAS03799,tank sensor-Raw value sensor 1 resistor 2,2320,
IDE03473-MAS03800,tank sensor-Raw value sensor 2 resistor 1,1984,
IDE03473-MAS03801,tank sensor-Raw value sensor 2 resistor 2,1812,
IDE03473-MAS03802,tank sensor-Raw value sensor 3 resistor 1,65535,
IDE03473-MAS03803,tank sensor-Raw value sensor 3 resistor 2,65535,
IDE03473-MAS03804,tank sensor-Raw value sensor 4 resistor 1,65535,
IDE03473-MAS03805,tank sensor-Raw value sensor 4 resistor 2,65535,
IDE03474-IDE00304,Calculated volume-Fuel level,36.0, l
IDE03474-IDE00306,Calculated volume-Fuel Level Sensor 1,86, Ohm
IDE03474-IDE00307,Calculated volume-Fuel Level Sensor 2,184, Ohm
IDE03474-IDE00308,Calculated volume-Fuel Level Sensor 3,65535, Ohm
IDE03474-IDE00309,Calculated volume-Fuel Level Sensor 4,65535, Ohm
IDE03474-IDE00312,Calculated volume-Fuel level from sensor 1,21.4, l
IDE03474-IDE00313,Calculated volume-Fuel level from sensor 2,13.9, l
IDE03474-IDE00314,Calculated volume-Fuel level from sensor 3,0.0, l
IDE03474-IDE00315,Calculated volume-Fuel level from sensor 4,0.0, l
IDE03474-MAS03827,Calculated volume-Quality sensor 2,10,
IDE03474-MAS10338,Calculated volume-Non-calibrated volume: sensor 1,-21.4, l
IDE03474-MAS10339,Calculated volume-Non-calibrated volume: sensor 2,-13.9, l
IDE03474-MAS10340,Calculated volume-Non-calibrated volume: sensor 3,-32768.0, l
IDE03474-MAS10341,Calculated volume-Non-calibrated volume: sensor 4,-32768.0, l
IDE03474-ENG103155,Calculated volume-accelerated_linking_x,1.0000000, m/s
IDE03474-ENG103517,Calculated volume-accelerated_linking_y,1.0000000, m/s
IDE03474-ENG102894,Calculated volume-averaged_volume,35.4, l
IDE03474-ENG99406,Calculated volume-averaged_volume_clipped,35.4, l
IDE03474-ENG101619,Calculated volume-calibrated_volume_total,35.3, l
IDE03474-ENG101669,Calculated volume-prefiltered_acceleration_x,0.12500, m/s
IDE03474-ENG102339,Calculated volume-prefiltered_acceleration_y,-0.00,
IDE03474-ENG101623,Calculated volume-reference_volume,36.0, l
IDE03474-ENG102479,Calculated volume-speed_based_linking,0.0000000, m/s
IDE03474-ENG99683,Calculated volume-version_of_application,111,
IDE03474-ENG102081,Calculated volume-volume_based_linking,0.0016661,
IDE03475-MAS00216,Control button in instrument cluster-External button for daily distance driven,not active,
IDE03475-MAS02915,Control button in instrument cluster-Button for auto check system,not active,
IDE03475-MAS03929,Control button in instrument cluster-Menu button,not active,
IDE03477-IDE00500,GPS time-Hour,4, H
IDE03477-IDE00501,GPS time-Minute,29, min
IDE03477-IDE00501,GPS time-Minute,28, min
IDE03477-IDE00502,GPS time-Year,2022, yr
IDE03477-IDE00503,GPS time-Month,6, Months
IDE03477-IDE00504,GPS time-Day,18, d
IDE03477-MAS00111,GPS time-Seconds,32, s
IDE03477-MAS00111,GPS time-Seconds,9, s
IDE03477-MAS03493,GPS time-last synchronization year,2022, yr
IDE03506,Distance: high resolution,00 02 62 E7,
IDE03911-MAS01390,Service -interval- display: history 1-Block 1,4F F0 00 4B,
IDE03911-MAS01391,Service -interval- display: history 1-Block 2,0F F0 00 0F,
IDE03911-MAS01392,Service -interval- display: history 1-Block 3,8F F0 00 0F,
IDE03911-MAS01393,Service -interval- display: history 1-Block 4,CF F0 00 4B,
IDE03911-MAS01394,Service -interval- display: history 1-Block 5,4F F0 00 4B,
IDE03911-MAS01395,Service -interval- display: history 1-Block 6,0F F0 00 0F,
IDE03911-MAS01396,Service -interval- display: history 1-Block 7,8F F0 00 0F,
IDE03911-MAS01397,Service -interval- display: history 1-Block 8,CF F0 00 4B,
IDE03911-MAS01398,Service -interval- display: history 1-Block 9,FF FF FF FF,
IDE03911-MAS01399,Service -interval- display: history 1-Block 10,FF FF FF FF,
IDE03911-MAS01400,Service -interval- display: history 1-Block 11,FF FF FF FF,
IDE03911-MAS01401,Service -interval- display: history 1-Block 12,FF FF FF FF,
IDE03911-MAS01402,Service -interval- display: history 1-Block 13,FF FF FF FF,
IDE03911-MAS01403,Service -interval- display: history 1-Block 14,FF FF FF FF,
IDE03911-MAS01404,Service -interval- display: history 1-Block 15,FF FF FF FF,
IDE03911-MAS01405,Service -interval- display: history 1-Block 16,FF FF FF FF,
IDE03912-MAS01390,Service -interval- display: history 2-Block 1,FF FF FF FF,
IDE03912-MAS01391,Service -interval- display: history 2-Block 2,FF FF FF FF,
IDE03912-MAS01392,Service -interval- display: history 2-Block 3,FF FF FF FF,
IDE03912-MAS01393,Service -interval- display: history 2-Block 4,FF FF FF FF,
IDE03912-MAS01394,Service -interval- display: history 2-Block 5,FF FF FF FF,
IDE03912-MAS01395,Service -interval- display: history 2-Block 6,FF FF FF FF,
IDE03912-MAS01396,Service -interval- display: history 2-Block 7,FF FF FF FF,
IDE03912-MAS01397,Service -interval- display: history 2-Block 8,FF FF FF FF,
IDE03912-MAS01398,Service -interval- display: history 2-Block 9,FF FF FF FF,
IDE03912-MAS01399,Service -interval- display: history 2-Block 10,FF FF FF FF,
IDE03912-MAS01400,Service -interval- display: history 2-Block 11,FF FF FF FF,
IDE03912-MAS01401,Service -interval- display: history 2-Block 12,FF FF FF FF,
IDE03912-MAS01402,Service -interval- display: history 2-Block 13,FF FF FF FF,
IDE03912-MAS01403,Service -interval- display: history 2-Block 14,FF FF FF FF,
IDE03912-MAS01404,Service -interval- display: history 2-Block 15,FF FF FF FF,
IDE03912-MAS01405,Service -interval- display: history 2-Block 16,FF FF FF FF,
IDE03913-MAS01390,Service -interval- display: history 3-Block 1,FF FF FF FF,
IDE03913-MAS01391,Service -interval- display: history 3-Block 2,FF FF FF FF,
IDE03913-MAS01392,Service -interval- display: history 3-Block 3,FF FF FF FF,
IDE03913-MAS01405,Service -interval- display: history 3-Block 16,FF FF FF FF,
IDE03914-MAS01405,Service -interval- display: history 4-Block 16,FF FF FF FF,
IDE05931,FIX: Reset value for next mileage-dependent inspection,32200, km
IDE05932,FIX: Reset value for next time-dependent inspections,730, d
IDE06592-MAS18012,Status: special functions-Vehicle locking and unlocking via mobile online service,lock,
IDE06592-MAS18013,Status: special functions-Deactivation of extended start authentication,OFF,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,06,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,08,
IDE07145-MAS06776,Component protection properties-Komponent protection role,WFS Master,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,80,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 6,
IDE08235-MAS06806,Status of immobilizer participant-Status OCU,00,
IDE08235-MAS06807,Status of immobilizer participant-Status VTS,00,
IDE08235-ENG118223,Status of immobilizer participant-ELV_State,00,
IDE08235-ENG118222,Status of immobilizer participant-GSG_State,F8,
IDE08235-ENG118217,Status of immobilizer participant-Immobilizer_State,00,
IDE08235-ENG118216,Status of immobilizer participant-key_state,1C,
IDE08235-ENG118218,Status of immobilizer participant-MSG_1_State,F8,
IDE08235-ENG118219,Status of immobilizer participant-MSG_2_State,00,
IDE08235-ENG118220,Status of immobilizer participant-MSG_3_State,00,
IDE08235-ENG118221,Status of immobilizer participant-MSG_4_State,00,
IDE08236-ENG118224,Status locking periods immobilizer-blocking_time,00 00 00 00 00 00,
IDE08237-MAS06814,Status Secure Hardware Extension-SHE counter,00 00 00 02,
IDE08237-MAS06815,Status Secure Hardware Extension-SHE key number,06,
IDE08238,Transponder ID current Key,00 00 00 00,
IDE08239,Transponder ID Key 1,A1 2C 7B E1,
IDE08240,Transponder ID Key 2,92 2C 7B E1,
IDE08251-IDE80258,Configuration immobilizer-Immobilizer status,00 00,
IDE08251-MAS01159,Configuration immobilizer-Version number,00,
IDE08251-MAS01483,Configuration immobilizer-Software version,00 00 00,
IDE08251-MAS11095,Configuration immobilizer-Cause,00 00 00,
IDE08252-MAS06854,Test sum of adapted transponder-Version,81,
IDE08252-MAS06855,Test sum of adapted transponder-Test sum,9C C8 2A 1B,
IDE08343,Immobilizer Challenge,14 5A A6 7D,
IDE10779,Ethernet signal quality,good: link available,
IDE10780,Ethernet counter connection interruptions,1,
IDE10781,Ethernet counter checksum malfunction,0,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FD 53 7C B8 03 83 00 05 00 00 00 00 00 00 00 14|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 31|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 32|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 46|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 28|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 29|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 04|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|5|,
IDE11756,IP network: counter messages with inadmissible VLANs,0,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,38,
IDE11759,IP network: counter messages with inadmissible TCP ports,0,
IDE11760,IP network: counter messages with inadmissible UDP ports,0,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|00 54 AF 86 02 F9|,
IDE11869,IP network: NDP cache,|MAC address,IPv6 address
IDE12238,I network: discarded messages counter,38,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|FD 53 7C B8 03 83 00 05 00 00 00 00 00 00 00 73
IDE12262-MAS14182,Virtual radio key: status-Master key coded,Yes,
IDE12262-MAS14183,Virtual radio key: status-Virtual radio key active,No,
IDE12262-MAS14184,Virtual radio key: status-Number of secure elements in the ticket table,00,
IDE12263,Virtual radio key: vehicle ID,D6 45 E8 86 08 6B 06 BA 1E 04 C6 8B 5A 4E D2 E0,
IDE12264-MAS14185,Virtual radio key: ticket table-Ticket 1,01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14186,Virtual radio key: ticket table-Ticket 2,02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14187,Virtual radio key: ticket table-Ticket 3,03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14188,Virtual radio key: ticket table-Ticket 4,04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14189,Virtual radio key: ticket table-Ticket 5,05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14190,Virtual radio key: ticket table-Ticket 6,06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14191,Virtual radio key: ticket table-Ticket 7,07 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14192,Virtual radio key: ticket table-Ticket 8,08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14193,Virtual radio key: ticket table-Ticket 9,09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14194,Virtual radio key: ticket table-Ticket 10,0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14195,Virtual radio key: ticket table-Ticket 11,0B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14196,Virtual radio key: ticket table-Ticket 12,0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14197,Virtual radio key: ticket table-Ticket 13,0D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14198,Virtual radio key: ticket table-Ticket 14,0E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14199,Virtual radio key: ticket table-Ticket 15,0F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14200,Virtual radio key: ticket table-Ticket 16,10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12265-MAS06854,Virtual radio key: check sum-Version,C1,
IDE12265-MAS06879,Virtual radio key: check sum-Checksum,45 3B 1F 63,
IDE14186-MAS17993,Communication transponder-Phase value,15,
IDE14186-MAS17994,Communication transponder-Compensation constant,3D,
IDE14186-MAS17995,Communication transponder-external oscillator frequency,04,
MAS00077-ENG99298,Immobilizer-State,02 01 03 63 02 00 00 00 15 00,
ENG250331-ENG250595,Condition_check_1-State_info_1,4,
ENG250331-ENG250481,Condition_check_1-State_info_2,1,
ENG250331-ENG250687,Condition_check_1-Transponder_Identification,00 00 00 00,
ENG250332-ENG250595,Condition_check_2-State_info_1,4,
ENG250332-ENG250481,Condition_check_2-State_info_2,1,
ENG250332-ENG250687,Condition_check_2-Transponder_Identification,0,
ENG105830-ENG104002,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_bar_graph_and_ACC,100, %
ENG105830-ENG119807,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial,100, %
ENG105830-ENG101889,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_gauge/finger/hand,100, %
ENG105830-ENG100477,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights,100, %
ENG105830-ENG103803,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_middle_display_main_field,71, %
ENG106303-ENG99140,ESI_active_warning-advance_warning_fixed_days,not active,
ENG106303-ENG100265,ESI_active_warning-advance_warning_fixed_km,not active,
ENG106303-ENG101600,ESI_active_warning-advance_warning_WIV_days,not active,
ENG106303-ENG102887,ESI_active_warning-advance_warning_WIV_km,not active,
ENG106303-ENG99971,ESI_active_warning-in_calculation,active,
ENG106303-ENG101015,ESI_active_warning-no_calculation_available,not active,
ENG106303-ENG101477,ESI_active_warning-service_warning_fixed_days,not active,
ENG106303-ENG101550,ESI_active_warning-service_warning_fixed_km,not active,
ENG106303-ENG101709,ESI_active_warning-service_warning_WIV_days,not active,
ENG106303-ENG102993,ESI_active_warning-service_warning_WIV_km,not active,
ENG119883,ESI_mileage_per_day,100, km
ENG99439,Instrument_recorder,06 61 70 00 46 50 4B 45 56 57 32 31 53 31 46 41 43 35 44 34 35 38 36 62 31 32 5F 00 03 00 C6 00 1E 00 00 02 8A 00 00 00 0B 00 00 00 00 00 05 DC C4 E3 2C 72 B8 00 B4 00 1F 00 00 02 97 00 00 00 01 80 00 00 01 00 05 E1 90 7F 22 8F E8 00 C6 00 1E 00 00 02 8A 00 00 00 02 00 00 00 00 00 05 E1 90 7F 22 8F E8 01 44 00 35 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 44 00 35 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 44 00 35 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 44 00 35 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 44 00 35 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 44 00 35 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 44 00 35 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 44 00 35 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 44 00 35 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 44 00 35 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 44 00 35 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 44 00 35 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 44 00 35 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 44 00 35 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 44 00 35 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 44 00 35 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 44 00 35 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 06 FF FF FF FF FF FF FF FF FF 00 00 1F 00 B4 00 97 02 00 00 01 00 00 00 90 E1 05 00 E8 8F 22 7F 1E 00 C6 00 8A 02 00 00 02 00 00 00 90 E1 05 00 E8 8F 22 7F 1E 00 C6 00 8A 02 00 00 0B 00 00 00 C4 DC 05 00 B8 72 2C E3 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 27 00 03 00 00 00 03 00 03 00 01 00 01 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG128745,Instrument_recorder_graphic,04 61 60 00 46 50 4B 45 56 57 32 31 53 31 46 47 43 5F 56 57 00 00 05 03 00 97 00 1C 00 80 00 00 00 00 00 00 00 05 DA 5C 13 02 78 7E 00 00 05 03 00 97 00 1C 00 AC 00 00 00 00 00 00 00 05 E0 50 32 3A B9 DA 00 00 02 B2 00 68 00 00 00 7B 00 00 00 00 00 03 00 05 E1 2C 59 D2 AC A7 00 00 00 FB 00 0F 00 00 01 88 00 00 00 00 00 03 00 05 E1 90 5E D7 D2 0B 00 00 02 B3 00 68 00 00 00 7B 00 00 00 00 00 00 00 05 E1 8F 70 AA A8 8A 00 00 05 3D 00 9C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 3D 00 9C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 3D 00 9C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG107920-ENG98868,onboard_computer-Range,384, km
ENG107920-ENG119788,onboard_computer-range_average_consumption,8.5, l/100km
ENG107920-ENG126296,onboard_computer-range_average_consumption_cng,6.0, kg/100 km
ENG107920-ENG126292,onboard_computer-range_average_consumption_cng_high,6.0, kg/100 km
ENG107920-ENG126294,onboard_computer-range_average_consumption_cng_low,6.0, kg/100 km
ENG107920-ENG119789,onboard_computer-range_average_consumption_high,8.6, l/100km
ENG107920-ENG119790,onboard_computer-range_average_consumption_low,8.0, l/100km
ENG107920-ENG126297,onboard_computer-range_average_consumption_lpg,10.0, kg/100 km
ENG107920-ENG126293,onboard_computer-range_average_consumption_lpg_high,10.0, kg/100 km
ENG107920-ENG126295,onboard_computer-range_average_consumption_lpg_low,10.0, kg/100 km
ENG107920-ENG126298,onboard_computer-range_cng,0, km
ENG107920-ENG126300,onboard_computer-range_cng_display_value,0, km
ENG107920-ENG119791,onboard_computer-range_display_value,384, km
ENG107920-ENG126299,onboard_computer-range_lpg,0, km
ENG107920-ENG126301,onboard_computer-range_lpg_display_value,0, km
ENG107953-ENG99788,outside_temp_algorithm_group-engine_running_detection_MSG,active,
ENG107953-ENG99520,outside_temp_algorithm_group-no_blockage_active,not active,
ENG107953-ENG99784,outside_temp_algorithm_group-outside_temperature_filtered,161,
ENG103405,read_out_measured_value_block,0,
ENG119885-ENG103300,Service_Key_current_data-Service_Data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG108927-ENG119819,Service_Key_Master_Counter-Counter_ID_Kessy,28,
ENG108927-ENG119811,Service_Key_Master_Counter-Counter_Key_ID_1,0,
ENG108927-ENG119812,Service_Key_Master_Counter-Counter_Key_ID_2,0,
ENG108927-ENG119813,Service_Key_Master_Counter-Counter_Key_ID_3,0,
ENG108927-ENG119814,Service_Key_Master_Counter-Counter_Key_ID_4,0,
ENG108927-ENG119815,Service_Key_Master_Counter-Counter_Key_ID_5,0,
ENG108927-ENG119816,Service_Key_Master_Counter-Counter_Key_ID_6,0,
ENG108927-ENG119817,Service_Key_Master_Counter-Counter_Key_ID_7,0,
ENG108927-ENG119818,Service_Key_Master_Counter-Counter_Key_ID_8,0,
ENG108927-ENG119821,Service_Key_Master_Counter-Counter_Trigger,0,
ENG108927-ENG119822,Service_Key_Master_Counter-Error_Counter,0,
ENG108927-ENG119823,Service_Key_Master_Counter-Immo_Key,2,
ENG108927-ENG119820,Service_Key_Master_Counter-Last_Key,ID_Kessy,
ENG108927-ENG99298,Service_Key_Master_Counter-State,Wait_SpeedlimitExceed,
ENG108929-ENG99961,Service_Key_Pointer-Current_Bank,key_not_readable,
ENG108929-ENG161255,Service_Key_Pointer-Write_Pointer_Adr_160,0,
ENG108929-ENG161256,Service_Key_Pointer-Write_Pointer_Adr_184,0,
ENG108929-ENG161257,Service_Key_Pointer-Write_Pointer_Adr_208,0,
Elapsed Time: 00:28,,,
blockmap-19-3Q0-907-530-AL_3VV2X7B28NM061887-20220618-1230.CSV
;SW:3Q0-907-530-AL   HW:3Q0-907-530-E ---  CAN Gateway
;Component:GW MQB High   524 5463, Coding:030D00047F085700FB0722DA1E0F00010001070000000000000000000000
;EV_GatewNF,013026,EV_GatewNF_VW37.rod
;Saturday,18,June,2022,12:30:16:14741
;VCID: F9A406AEA95A4B9314C-80AC
IDE00019,Voltage terminal 30,12.6, V
IDE00020,Terminal 15 status,Terminal 15 on,
IDE00056,History data 1,|Life Cycle Data String|2022-06-16-10:15*02.1*01*00442***,
2022-06-11-13:32*01.9*01**,,,
2022-06-11-07:48*00.0*01**,,,
IDE00057,History data 2,|Life Cycle Data String|-------------:--*---*---*--.---*-------------*-*--*-----**,
IDE00058,History data 3,|Life Cycle Data String|2022-05-31-07:53*T*0*070*055*0-0-0-0-0-0-0*0*0*00.0*00.0**,
2022-05-30-14:20*T*0*075*060*0-0-0-0-0-0-0*0*0*00.0*00.0**,,,
2022-05-30-14:14*T*0*069*056*0-0-0-0-0-0-0*0*0*00.0*00.0**,,,
2022-05-30-14:10*T*0*069*056*0-0-0-0-0-0-0*0*0*00.0*00.0**,,,
2022-05-27-10:29*T*0*068*055*0-0-0-0-0-0-0*0*0*00.0*00.0**,,,
2022-05-27-09:49*T*0*071*058*0-0-0-0-0-0-0*0*0*00.0*00.0**,,,
2022-05-26-09:11*T*0*058*046*0-0-0-0-0-0-0*0*0*00.0*00.0**,,,
2022-05-26-08:59*T*0*057*046*0-0-0-0-0-0-0*0*0*00.0*00.0**,,,
2022-05-26-08:19*T*0*066*055*0-0-0-0-0-0-0*0*0*00.0*00.0**,,,
2022-05-26-08:10*T*0*068*057*0-0-0-0-0-0-0*0*0*00.0*00.0**|, ,,
IDE00059,History data 4,|Life Cycle Data String|       0000000km*01*059*JCB*1111111111*10002*00068*000.7*000.0*000.0**,
IDE00060,History data 5,|Life Cycle Data String|-------------:--*-*--.---*--.--*---*--*---.-*-----*-----*------*-------------*-*-*-*--.-*--.-*---.-*--*--*--*--*--**,
IDE00061,History data 6,|Life Cycle Data String|2022-06-17-10:11*068*+33*+000.0*00.10*0.00*000**,
2022-06-16-13:16*064*+47*+000.2*00.00*0.00*000**,,,
2022-06-16-12:50*064*+47*+003.0*00.30*0.00*000**,,,
2022-06-16-11:58*062*+43*+001.7*00.30*0.00*002**,,,
2022-06-16-10:27*064*+33*+001.0*00.00*0.00*000**,,,
2022-06-16-10:16*063*+32*+000.2*00.10*0.00*000**,,,
2022-06-11-13:35*062*+35*+003.5*00.60*0.00*000**,,,
2022-06-11-07:48*058*+21*+000.0*00.20*0.04*003**,,,
2022-06-09-11:59*057*+33*+000.1*00.00*0.00*000**,,,
2022-06-09-11:07*059*+32*+002.7*00.40*0.02*003**|, ,,
IDE00062,History data 7,|Life Cycle Data String|2022-06-17-10:21*068*+001.6*024.1*00.0*00.0**,
2022-06-16-13:19*067*+000.8*020.8*00.0*00.0**,,,
2022-06-16-13:14*063*+000.1*000.0*00.0*00.0**,,,
2022-06-16-12:21*060*+000.4*000.4*00.0*00.0**,,,
2022-06-16-11:57*061*+000.1*000.0*00.0*00.0**,,,
2022-06-16-11:46*061*+000.2*000.1*00.0*00.0**,,,
2022-06-16-10:38*061*+000.4*000.9*00.0*00.0**,,,
2022-06-16-10:26*063*+000.1*000.0*00.0*00.0**,,,
2022-06-13-15:21*063*+000.9*067.1*00.0*00.0**,,,
2022-06-11-14:13*061*+001.0*049.1*00.0*00.0**|, ,,
IDE00063,History data 8,|Life Cycle Data String|       0000009km*1*05*00*00*04*-------------:--*01**,
2022-03-16-20:26*1*04*00*00*04*-------------:--*01**,,,
2022-03-16-19:53*4*03*00*00*04*2022-03-16-00:12*01**|, ,,
IDE00064,History data 9,|Life Cycle Data String|2022-03-16-00:00*000*000*000*000*00000*09.00*+00*00*01*00.00*00000*00000**,
2022-06-16-10:15*086*094*075*062*00063*12.50*+31*04*01*03.10*01347*00011**,,,
2022-05-18-08:50*093*100*072*063*00030*12.40*+27*04*01*03.35*00137*00000**,,,
2022-04-16-10:38*095*100*083*076*00025*12.60*+21*04*01*03.35*00137*00000**,,,
IDE00065,History data 10,|Life Cycle Data String|2022-06-17-10:04*1*000.0*0000.0*0*000.0*0000.0*00.00*0000000**,
IDE00066,History data 11,|Life Cycle Data String|2022-06-17-10:11*000*000*000*010*0003*010*00.0*00.0*079*068*079*068*01*00004*00005*00004*00030*00051**,
2022-06-16-13:16*000*000*000*002*0022*002*00.0*00.3*075*063*075*064*01**,,,
2022-06-16-12:50*000*000*000*023*0248*023*00.0*03.2*072*060*075*064*01**,,,
2022-06-16-11:58*000*000*000*022*0185*023*00.0*02.2*073*061*075*062*03**,,,
2022-06-16-10:34*000*000*000*004*0047*011*00.0*00.2*076*063*077*064*01**|, ,,
IDE00067,History data 12,|Life Cycle Data String|-------------:--*---------------**,
IDE00068,History data 13,|Life Cycle Data String|-------------:--*---------*---.-*-----**,
IDE00069,History data 14,|Life Cycle Data String|2022-06-18-10:28*1*00030*0000*0000*00.00*000008*+27*0001.1*0000.0*0000.0**,
2022-06-18-10:28*3*00000*0000*0002*00.00*000008*+27**,,,
2022-06-17-10:04*1*00382*0000*0000*00.00*000008*+32**,,,
2022-06-16-13:16*1*00013*0000*0000*00.00*000008*+47**,,,
2022-06-16-13:16*3*00000*0000*0002*00.00*000008*+47**,,,
00036*00087*00053*00000*00000**,,,
2022-06-18-10:28*000.7*12.4*12.6*0000.0**,,,
2022-06-17-10:04*000.6*12.4*12.5**,,,
2022-06-16-10:16*000.6*12.4*12.5**|, ,,
IDE00071,History data 16,|Life Cycle Data String|       0000156km**,
00047*00017*00053*00002*00000**,,,
00105*00019*00001*00001**,,,
00478*00040*00002*00001**,,,
00065*00023*00002*00005**,,,
00078*00014*00003**,,,
00000*00000*00000*00000**,,,
00013*00000*00001**,,,
00001*00000*00000**,,,
00004*00000*00001**,,,
00001*00002*00001*00002*00002*00001*00001*00000*00001*00001*00000**|, ,,
IDE00356,Cruise Control System (CCS): switch position,OFF,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,Not operated,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Tap delay,Not operated,
IDE00356-MAS00324,Cruise Control System (CCS): switch position-Tap acceleration,Not operated,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Set,Not operated,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Resume,Not operated,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,Not operated,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,5,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not assigned,Not operated,
IDE00356-MAS04522,Cruise Control System (CCS): switch position-Tap deceleration stage 2,Not operated,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,Cruise control switch with ACC,
IDE00356-MAS05812,Cruise Control System (CCS): switch position-Limit button,installed,
IDE00356-MAS06029,Cruise Control System (CCS): switch position-MFL message counter,8,
IDE00356-MAS06879,Cruise Control System (CCS): switch position-Checksum,196,
IDE00767-ENG123029,No. of unscheduled ECU resets-Counter_Watchdog_Resets,0,
IDE01459,Energy management heat output control status,Stage 1,
IDE01805,History data 19,|Life Cycle Data String|-------------:--*-----*---*---*---**,
IDE01807-IDE07142,History data 21-Time since terminal 15 off,65.4, H
IDE01807-MAS00106,History data 21-Year,2022,
IDE01807-MAS00107,History data 21-Month,4,
IDE01807-MAS00108,History data 21-Day,9,
IDE01807-MAS00109,History data 21-Hours,7, H
IDE01807-MAS00110,History data 21-Minutes,31, min
IDE01807-MAS14375,History data 21-Cycle counter,62,
IDE01807-MAS14376,History data 21-ECU 1,Multifunction module on the second bus connection,
IDE01807-MAS14377,History data 21-Alert maintenance time for ECU 1,1.1, H
IDE01807-MAS14378,History data 21-Repetition counter for ECU 1,0,
IDE01807-MAS14379,History data 21-ECU 2,Node_0x-- $-- (empty entry),
IDE01807-MAS14380,History data 21-Alert maintenance time for ECU 2,0.0, H
IDE01807-MAS14381,History data 21-Repetition counter for ECU 2,0,
IDE01807-MAS14382,History data 21-ECU 3,Node_0x-- $-- (empty entry),
IDE01807-MAS14383,History data 21-Alert maintenance time for ECU 3,0.0, H
IDE01807-MAS14384,History data 21-Repetition counter for ECU 3,0,
IDE01807-MAS14385,History data 21-ECU 4,Node_0x-- $-- (empty entry),
IDE01807-MAS14386,History data 21-Alert maintenance time for ECU 4,0.0, H
IDE01807-MAS14387,History data 21-Repetition counter for ECU 4,0,
IDE01807-MAS14388,History data 21-ECU 5,Node_0x-- $-- (empty entry),
IDE01807-MAS14389,History data 21-Alert maintenance time for ECU 5,0.0, H
IDE01807-MAS14390,History data 21-Repetition counter for ECU 5,0,
IDE01808-MAS03173,History data 22-Powertrain data bus,0.0, H
IDE01808-MAS03174,History data 22-Comfort data bus,0.0, H
IDE01808-MAS03175,History data 22-Extended data bus,0.0, H
IDE01808-MAS03176,History data 22-Display and control head databus,0.0, H
IDE01808-MAS03177,History data 22-Infotainment data bus,0.0, H
IDE01808-MAS03178,History data 22-Suspension data bus,0.0, H
IDE01808-MAS03179,History data 22-Local data bus 2,0.0, H
IDE01808-MAS03180,History data 22-Local data bus,0.0, H
IDE01808-MAS05686,History data 22-Data bus diagnostics,0.0, H
IDE01808-MAS14373,History data 22-All BUS systems,0.0, H
IDE01809-IDE07142,History data 23-Time since terminal 15 off,0.0, H
IDE01809-MAS00106,History data 23-Year,2000,
IDE01809-MAS00107,History data 23-Month,1,
IDE01809-MAS00108,History data 23-Day,1,
IDE01809-MAS00109,History data 23-Hours,0, H
IDE01809-MAS00110,History data 23-Minutes,0, min
IDE01809-MAS14375,History data 23-Cycle counter,0,
IDE01809-MAS14395,History data 23-Bus with maximum number of post alarms,Unknown,
IDE01809-MAS14396,History data 23-Post alerts in current cycle,0,
IDE01809-MAS14397,History data 23-Rousing ECU 1,Node_0x-- $-- (empty entry),
IDE01809-MAS14398,History data 23-Number of post alerts for control module 1,0,
IDE01809-MAS14399,History data 23-CarWakeUp bit 1,0,
IDE01809-MAS14400,History data 23-Rousing ECU 2,Node_0x-- $-- (empty entry),
IDE01809-MAS14401,History data 23-Number of post alerts for control module 2,0,
IDE01809-MAS14402,History data 23-CarWakeUp bit 2,0,
IDE01809-MAS14403,History data 23-Rousing ECU 3,Node_0x-- $-- (empty entry),
IDE01809-MAS14404,History data 23-Number of post alerts for control module 3,0,
IDE01809-MAS14405,History data 23-CarWakeUp bit 3,0,
IDE01809-MAS14406,History data 23-Rousing ECU 4,Node_0x-- $-- (empty entry),
IDE01809-MAS14407,History data 23-Number of post alerts for control module 4,0,
IDE01809-MAS14408,History data 23-CarWakeUp bit 4,0,
IDE01809-MAS14409,History data 23-Rousing ECU 5,Node_0x-- $-- (empty entry),
IDE01809-MAS14410,History data 23-Number of post alerts for control module 5,0,
IDE01809-MAS14411,History data 23-CarWakeUp bit 5,0,
IDE01810-IDE07142,History data 24-Time since terminal 15 off,0.3, H
IDE01810-MAS00106,History data 24-Year,2022,
IDE01810-MAS00107,History data 24-Month,3,
IDE01810-MAS00108,History data 24-Day,16,
IDE01810-MAS00109,History data 24-Hours,21, H
IDE01810-MAS00110,History data 24-Minutes,11, min
IDE01810-MAS14375,History data 24-Cycle counter,32,
IDE01810-MAS14399,History data 24-CarWakeUp bit 1,0,
IDE01810-MAS14402,History data 24-CarWakeUp bit 2,0,
IDE01810-MAS14405,History data 24-CarWakeUp bit 3,0,
IDE01810-MAS14408,History data 24-CarWakeUp bit 4,0,
IDE01810-MAS14411,History data 24-CarWakeUp bit 5,0,
IDE01810-MAS14412,History data 24-Bus with maximum number of alerts,Comfort data bus,
IDE01810-MAS14413,History data 24-Alert events in current cycle,53,
IDE01810-MAS14414,History data 24-ID of the alerting message 1,17 F0 00 09,
IDE01810-MAS14415,History data 24-Counter of the alerting message 1,3,
IDE01810-MAS14416,History data 24-Bus of the alerting message 1,Extended data bus,
IDE01810-MAS14417,History data 24-ID of the alerting message 2,1B 00 00 0E,
IDE01810-MAS14418,History data 24-Counter of the alerting message 2,1,
IDE01810-MAS14419,History data 24-Bus of the alerting message 2,Comfort data bus,
IDE01810-MAS14420,History data 24-ID of the alerting message 3,00 00 05 E1,
IDE01810-MAS14421,History data 24-Counter of the alerting message 3,1,
IDE01810-MAS14422,History data 24-Bus of the alerting message 3,Comfort data bus,
IDE01810-MAS14423,History data 24-ID of the alerting message 4,1B 00 00 09,
IDE01810-MAS14424,History data 24-Counter of the alerting message 4,1,
IDE01810-MAS14425,History data 24-Bus of the alerting message 4,Extended data bus,
IDE01810-MAS14426,History data 24-ID of the alerting message 5,1B 00 00 14,
IDE01810-MAS14427,History data 24-Counter of the alerting message 5,1,
IDE01810-MAS14428,History data 24-Bus of the alerting message 5,Comfort data bus,
IDE01812-MAS01468,History data 26-Terminal 15,126,
IDE01812-MAS03173,History data 26-Powertrain data bus,1,
IDE01812-MAS03174,History data 26-Comfort data bus,416,
IDE01812-MAS03175,History data 26-Extended data bus,396,
IDE01812-MAS03177,History data 26-Infotainment data bus,0,
IDE01812-MAS03178,History data 26-Suspension data bus,4,
IDE01812-MAS03180,History data 26-Local data bus,1,
IDE01812-MAS05686,History data 26-Data bus diagnostics,0,
IDE01812-MAS14374,History data 26-Totals,818,
IDE01813-MAS03173,History data 27-Powertrain data bus,265,
IDE01813-MAS03174,History data 27-Comfort data bus,691,
IDE01813-MAS03175,History data 27-Extended data bus,93,
IDE01813-MAS03177,History data 27-Infotainment data bus,109,
IDE01813-MAS03178,History data 27-Suspension data bus,88,
IDE01813-MAS14374,History data 27-Totals,1246,
IDE01814-MAS03173,History data 28-Powertrain data bus,4,
IDE01814-MAS03174,History data 28-Comfort data bus,980,
IDE01814-MAS03175,History data 28-Extended data bus,0,
IDE01814-MAS03177,History data 28-Infotainment data bus,0,
IDE01814-MAS03178,History data 28-Suspension data bus,3,
IDE01814-MAS14374,History data 28-Totals,990,
IDE01816-IDE07142,History data 30-Time since terminal 15 off,65.4, H
IDE01816-MAS00106,History data 30-Year,2022,
IDE01816-MAS00107,History data 30-Month,4,
IDE01816-MAS00108,History data 30-Day,9,
IDE01816-MAS00109,History data 30-Hours,7, H
IDE01816-MAS00110,History data 30-Minutes,31, min
IDE01816-MAS14375,History data 30-Cycle counter,62,
IDE01816-ENG151642,History data 30-Bus_1,Extended data bus,
IDE01816-ENG151644,History data 30-Bus_2,Unknown,
IDE01816-ENG151646,History data 30-Bus_3,Unknown,
IDE01816-ENG151648,History data 30-Bus_4,Unknown,
IDE01816-ENG151650,History data 30-Bus_5,Unknown,
IDE01816-ENG151643,History data 30-Bus_Active_Time_1,1.1, H
IDE01816-ENG151645,History data 30-Bus_Active_Time_2,0.0, H
IDE01816-ENG151647,History data 30-Bus_Active_Time_3,0.0, H
IDE01816-ENG151649,History data 30-Bus_Active_Time_4,0.0, H
IDE01816-ENG151651,History data 30-Bus_Active_Time_5,0.0, H
IDE01817-IDE07142,History data 31-Time since terminal 15 off,65.4, H
IDE01817-MAS00106,History data 31-Year,2022,
IDE01817-MAS00107,History data 31-Month,4,
IDE01817-MAS00108,History data 31-Day,9,
IDE01817-MAS00109,History data 31-Hours,7, H
IDE01817-MAS00110,History data 31-Minutes,31, min
IDE01817-MAS14375,History data 31-Cycle counter,62,
IDE01817-MAS14376,History data 31-ECU 1,Multifunction module on the second bus connection,
IDE01817-MAS14377,History data 31-Alert maintenance time for ECU 1,1.1, H
IDE01817-MAS14378,History data 31-Repetition counter for ECU 1,0,
IDE01817-MAS14379,History data 31-ECU 2,Node_0x-- $-- (empty entry),
IDE01817-MAS14380,History data 31-Alert maintenance time for ECU 2,0.0, H
IDE01817-MAS14381,History data 31-Repetition counter for ECU 2,0,
IDE01817-MAS14382,History data 31-ECU 3,Node_0x-- $-- (empty entry),
IDE01817-MAS14383,History data 31-Alert maintenance time for ECU 3,0.0, H
IDE01817-MAS14384,History data 31-Repetition counter for ECU 3,0,
IDE01817-MAS14385,History data 31-ECU 4,Node_0x-- $-- (empty entry),
IDE01817-MAS14386,History data 31-Alert maintenance time for ECU 4,0.0, H
IDE01817-MAS14387,History data 31-Repetition counter for ECU 4,0,
IDE01817-MAS14388,History data 31-ECU 5,Node_0x-- $-- (empty entry),
IDE01817-MAS14389,History data 31-Alert maintenance time for ECU 5,0.0, H
IDE01817-MAS14390,History data 31-Repetition counter for ECU 5,0,
IDE01818-IDE07142,History data 32-Time since terminal 15 off,0.0, H
IDE01818-MAS00106,History data 32-Year,2000,
IDE01818-MAS00107,History data 32-Month,1,
IDE01818-MAS00108,History data 32-Day,1,
IDE01818-MAS00109,History data 32-Hours,0, H
IDE01818-MAS00110,History data 32-Minutes,0, min
IDE01818-MAS14375,History data 32-Cycle counter,0,
IDE01818-MAS14391,History data 32-Alerting ECU,Node_0x-- $-- (empty entry),
IDE01818-MAS14392,History data 32-CarWakeUp Bit,0,
IDE01819-IDE07142,History data 33-Time since terminal 15 off,0.3, H
IDE01819-MAS00106,History data 33-Year,2022,
IDE01819-MAS00107,History data 33-Month,3,
IDE01819-MAS00108,History data 33-Day,16,
IDE01819-MAS00109,History data 33-Hours,21, H
IDE01819-MAS00110,History data 33-Minutes,11, min
IDE01819-MAS14375,History data 33-Cycle counter,32,
IDE01819-MAS14393,History data 33-ID of the alerting message,1B 00 00 0E,
IDE01819-MAS14394,History data 33-Bus of the alerting message,Comfort data bus,
IDE01820-IDE07142,History data 34-Time since terminal 15 off,24.0, H
IDE01820-MAS00106,History data 34-Year,2022,
IDE01820-MAS00107,History data 34-Month,6,
IDE01820-MAS00108,History data 34-Day,18,
IDE01820-MAS00109,History data 34-Hours,10, H
IDE01820-MAS00110,History data 34-Minutes,26, min
IDE01820-MAS14375,History data 34-Cycle counter,126,
IDE01820-MAS14393,History data 34-ID of the alerting message,1B 00 00 32,
IDE01823-IDE07142,History data 37-Time since terminal 15 off,0.0, H
IDE01823-MAS00106,History data 37-Year,2011,
IDE01823-MAS00107,History data 37-Month,1,
IDE01823-MAS00108,History data 37-Day,1,
IDE01823-MAS00109,History data 37-Hours,0, H
IDE01823-MAS00110,History data 37-Minutes,0, min
IDE01823-MAS01632,History data 37-Status,activated,
IDE01823-MAS14375,History data 37-Cycle counter,127,
IDE01823-MAS14429,History data 37-Time in current cycle,0.0, H
IDE01827,Specified generator voltage,12.7, V
IDE01828,Generator DF Signal,35.500, %
IDE01829,Generator exciter current,2.000, A
IDE01830-MAS01632,Generator Status-Status,Thermal OK,
IDE01830-MAS02970,Generator Status-Status 2:,Mechanical OK,
IDE01830-MAS02971,Generator Status-Status 3:,electrically OK,
IDE01831-MAS03159,Generator variant-Manufacturer,Robert Bosch GmbH,
IDE01831-MAS06310,Generator variant-Generator identifier,82 - 140A,
IDE01832-MAS06311,Generator regulator variant-ASIC manufacturer,0,
IDE01832-MAS06312,Generator regulator variant-ASIC variant,4,
IDE01834,Battery voltage,12.672, V
IDE01836,Battery current,1.552, A
IDE01837,Temperature of battery sensor,31, °C
IDE01838,Battery temperature,27, °C
IDE01839,Battery charge level,78, %
IDE01841,Battery internal resistance,4.6, mOhm
IDE01842,Usable battery charge,67, Ah
IDE01843,Battery voltage at rest,12.5, V
IDE01844,Increase idle speed request,no request,
IDE01845,Reduce internal fan request,no request,
IDE01846,Static current shut-off stage,Deactivation stage 0,
IDE01847,Auxiliary heater activation restriction request,Permitted,
IDE01847-MAS06319,Auxiliary heater activation restriction request-Allowed parking heater runtime,60, min
IDE01848,Energy balance of last driving cycle,0.1, Ah
IDE01849,Previous journey duration,0.0, H
IDE01852,Static current measurement: result,Initialization,
IDE01853,Static current measurement: status,Cancel,
IDE01854,Energy reclamation request,active,
IDE01855,Generator current,19.7, A
IDE01948,Battery internal resistance not normed,4.6, mOhm
IDE01985-ENG101043,FAZIT identification test sum-Checksum,8D 8A 4B 80,
IDE01985-ENG99027,FAZIT identification test sum-Version,129,
IDE02578-ENG137113,Play protection status-fiddle_proofing_1,not active,
IDE02578-ENG137115,Play protection status-fiddle_proofing_2,not active,
IDE02578-ENG137116,Play protection status-fiddle_proofing_3,not active,
IDE02578-ENG137117,Play protection status-fiddle_proofing_4,not active,
IDE02578-ENG137118,Play protection status-fiddle_proofing_5,not active,
IDE02578-ENG137119,Play protection status-fiddle_proofing_6,not active,
IDE02578-ENG137120,Play protection status-fiddle_proofing_7,not active,
IDE02578-ENG137121,Play protection status-fiddle_proofing_8,not active,
IDE02578-ENG137114,Play protection status-function_calls_counter_1,0,
IDE02578-ENG137122,Play protection status-function_calls_counter_2,0,
IDE02578-ENG137123,Play protection status-function_calls_counter_3,0,
IDE02578-ENG137124,Play protection status-function_calls_counter_4,0,
IDE02578-ENG137125,Play protection status-function_calls_counter_5,0,
IDE02578-ENG137126,Play protection status-function_calls_counter_6,0,
IDE02578-ENG137127,Play protection status-function_calls_counter_7,0,
IDE02578-ENG137128,Play protection status-function_calls_counter_8,0,
IDE03008-IDE01838,Stop process prevented-Battery temperature,not active,
IDE03008-IDE01844,Stop process prevented-Increase idle speed request,not active,
IDE03008-MAS02193,Stop process prevented-Outside temperature,not active,
IDE03008-MAS04054,Stop process prevented-Consumer/component current too high,not active,
IDE03008-MAS04055,Stop process prevented-Withdrawable battery charge too low,not active,
IDE03008-MAS04056,Stop process prevented-Battery state of charge too low,not active,
IDE03008-MAS04062,Stop process prevented-Possible standing time too short,not active,
IDE03008-MAS06001,Stop process prevented-Energy management special veto,not active,
IDE03008-MAS06002,Stop process prevented-DC/DC converter Veto,not active,
IDE03008-MAS19121,Stop process prevented-Successful restart done through freight quota,not active,
IDE03009-MAS01478,Start process requested-insufficient voltage,not active,
IDE03009-MAS02885,Start process requested-Restart because of outside temperature,not active,
IDE03009-MAS04054,Start process requested-Consumer/component current too high,not active,
IDE03009-MAS04055,Start process requested-Withdrawable battery charge too low,not active,
IDE03009-MAS04056,Start process requested-Battery state of charge too low,not active,
IDE03009-MAS04058,Start process requested-Standing time timed out,not active,
IDE03009-MAS06003,Start process requested-Charge contingency,not active,
IDE03009-MAS06004,Start process requested-Special start request,not active,
IDE03010-IDE01838,Number of prevented stop processes-Battery temperature,0,
IDE03010-IDE01844,Number of prevented stop processes-Increase idle speed request,0,
IDE03010-MAS02193,Number of prevented stop processes-Outside temperature,0,
IDE03010-MAS04054,Number of prevented stop processes-Consumer/component current too high,0,
IDE03010-MAS04055,Number of prevented stop processes-Withdrawable battery charge too low,0,
IDE03010-MAS04056,Number of prevented stop processes-Battery state of charge too low,0,
IDE03010-MAS04062,Number of prevented stop processes-Possible standing time too short,0,
IDE03010-MAS05998,Number of prevented stop processes-Frequency counter DC/DC converter Veto,0,
IDE03010-MAS06350,Number of prevented stop processes-Frequency counter: energy management special veto,0,
IDE03011-MAS01478,Number of requested start processes-insufficient voltage,0,
IDE03011-MAS02885,Number of requested start processes-Restart because of outside temperature,0,
IDE03011-MAS04054,Number of requested start processes-Consumer/component current too high,0,
IDE03011-MAS04055,Number of requested start processes-Withdrawable battery charge too low,0,
IDE03011-MAS04056,Number of requested start processes-Battery state of charge too low,0,
IDE03011-MAS04058,Number of requested start processes-Standing time timed out,0,
IDE03011-MAS05999,Number of requested start processes-Frequency counter charging contingent,0,
IDE03011-MAS06000,Number of requested start processes-Frequency counter special start requirements,0,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2127,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,15,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,31,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,31,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,63,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,63,
IDE03127-ENG118156,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n,no measured value present,
IDE03127-ENG118158,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-1,no measured value present,
IDE03127-ENG118160,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-2,no measured value present,
IDE03127-ENG118162,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-3,no measured value present,
IDE03127-ENG118164,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-4,no measured value present,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2127,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,15,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,31,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,31,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,63,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,63,
IDE03128-ENG118166,Requested start processes (ring memory)-Restart_n,no measured value present,
IDE03128-ENG118168,Requested start processes (ring memory)-Restart_n-1,no measured value present,
IDE03128-ENG118170,Requested start processes (ring memory)-Restart_n-2,no measured value present,
IDE03128-ENG118172,Requested start processes (ring memory)-Restart_n-3,no measured value present,
IDE03128-ENG118174,Requested start processes (ring memory)-Restart_n-4,no measured value present,
IDE03212,Start/stop conditions,Stop release,
IDE03213,Start/stop enable,No release by coordinator,
IDE03214,Engine stop using start-stop function,not active,
IDE03215,Engine start using start-stop function,not active,
IDE03256-MAS06105,Battery adaptation-Rated battery capacity,59, Ah
IDE03256-MAS06106,Battery adaptation-Battery technology,EFB,
IDE03256-MAS06107,Battery adaptation-Battery manufacturer,JCB,
IDE03256-MAS06108,Battery adaptation-Battery Serial Number,1111111111,
IDE03588-MAS05683,System malfunctions for active participants start/stop-Battery fault,0,
IDE03588-MAS06321,System malfunctions for active participants start/stop-System malfunction generator,0,
IDE03588-MAS06322,System malfunctions for active participants start/stop-System malfunction due to battery throughput,0,
IDE03588-MAS06323,System malfunctions for active participants start/stop-Start/stop coordinator implausible,0,
IDE03588-MAS06324,System malfunctions for active participants start/stop-DCDC converter system malfunction,0,
IDE03588-MAS06326,System malfunctions for active participants start/stop-Communication malfunction battery data module,0,
IDE03588-MAS06327,System malfunctions for active participants start/stop-Battery data module defective,0,
IDE04329-ENG118721,Status of all SWaP functions-SWaP_function_state array,|ID number,Release code for a SWaP function
IDE04332,Release code for a SWaP function,2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D,
IDE04334,Public key for SWaP function,99 19 70 20 DD A9 1D 14 0A BB A4 90 B5 ED 09 97 32 66 86 77 B6 FC 36 C9 0F 44 99 7F 58 BF 1C 99 82 8C DD 35 B4 F5 BB 76 4F 28 2E 4A 4B AA 98 44 D5 65 19 9D 70 BD 6E 67 C7 B2 D6 C9 37 77 57 DD CE 12 D4 A1 15 32 59 88 5E 5C 05 4B C4 B9 D5 8F 18 83 0E BA 93 C1 43 56 0F A4 B6 B9 3C 79 66 8F D7 5B 33 70 34 84 1E 8E D7 AE CD B8 E6 0E 29 FC D5 60 B3 F6 EC FD E2 D3 2B 1A 7D 78 41 88 78 F9 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04806-ENG137100,Driving profile selection button-Driving_Profile_Selection_Button_1,Not operated,
IDE04806-ENG137101,Driving profile selection button-Driving_Profile_Selection_Button_2,Not operated,
IDE04806-ENG137102,Driving profile selection button-Driving_Profile_Selection_Button_3,Not operated,
IDE04806-ENG137103,Driving profile selection button-Driving_Profile_Selection_Button_4,Not operated,
IDE04806-ENG137104,Driving profile selection button-Driving_Profile_Selection_Button_5,Not operated,
IDE04806-ENG137105,Driving profile selection button-Driving_Profile_Selection_Button_6,Not operated,
IDE04806-ENG137106,Driving profile selection button-Driving_Profile_Selection_Button_7,Not operated,
IDE04806-ENG137107,Driving profile selection button-Driving_Profile_Selection_Button_8,Not operated,
IDE05583-IDE02766,Break recommendation-Malfunction status,Switched off: not installed,
IDE05583-MAS03095,Break recommendation-Function status,not installed,
IDE05583-MAS04622,Break recommendation-Break recommend. message,No message,
IDE05583-MAS13162,Break recommendation-Icon deactivated,Yes,
IDE05740-MAS05376,Driving profile selection: system status-Coordinator status,active,
IDE05740-ENG136079,Driving profile selection: system status-profile_state_1,engaged,
IDE05740-ENG136080,Driving profile selection: system status-profile_state_2,engaged,
IDE05740-ENG136081,Driving profile selection: system status-profile_state_3,not engaged,
IDE05740-ENG136082,Driving profile selection: system status-profile_state_4,not engaged,
IDE05740-ENG136083,Driving profile selection: system status-profile_state_5,not engaged,
IDE05740-ENG136084,Driving profile selection: system status-profile_state_6,not engaged,
IDE05740-ENG136085,Driving profile selection: system status-profile_state_7,not engaged,
IDE05740-ENG136086,Driving profile selection: system status-profile_state_8,not engaged,
IDE05814,Individualization characteristic,14 90 C4 D7 9C,
IDE06007-IDE00105,Driving profile history data 1-Malfunction type,no entry,
IDE06007-IDE04805,Driving profile history data 1-Driving profile selection,0,
IDE06007-IDE07643,Driving profile history data 1-Faulty function,no entry,
IDE06007-MAS00106,Driving profile history data 1-Year,2000,
IDE06007-MAS00107,Driving profile history data 1-Month,0,
IDE06007-MAS00108,Driving profile history data 1-Day,0,
IDE06007-MAS00109,Driving profile history data 1-Hours,0,
IDE06007-MAS00110,Driving profile history data 1-Minutes,0,
IDE06007-MAS00111,Driving profile history data 1-Seconds,0,
IDE06007-MAS00711,Driving profile history data 1-Odometer reading,0, km
IDE06007-MAS03095,Driving profile history data 1-Function status,Initialization,
IDE06008-IDE00105,Driving profile history data 2-Malfunction type,no entry,
IDE06008-IDE04805,Driving profile history data 2-Driving profile selection,0,
IDE06008-IDE07643,Driving profile history data 2-Faulty function,no entry,
IDE06008-MAS00106,Driving profile history data 2-Year,2000,
IDE06008-MAS00107,Driving profile history data 2-Month,0,
IDE06008-MAS00108,Driving profile history data 2-Day,0,
IDE06008-MAS00109,Driving profile history data 2-Hours,0,
IDE06008-MAS00110,Driving profile history data 2-Minutes,0,
IDE06008-MAS00111,Driving profile history data 2-Seconds,0,
IDE06008-MAS00711,Driving profile history data 2-Odometer reading,0, km
IDE06008-MAS03095,Driving profile history data 2-Function status,Initialization,
IDE06009-IDE00105,Driving profile history data 3-Malfunction type,no entry,
IDE06009-IDE04805,Driving profile history data 3-Driving profile selection,0,
IDE06009-IDE07643,Driving profile history data 3-Faulty function,Transmission Control Module (TCM),
IDE06009-MAS00106,Driving profile history data 3-Year,2000,
IDE06009-MAS00107,Driving profile history data 3-Month,0,
IDE06009-MAS00108,Driving profile history data 3-Day,0,
IDE06009-MAS00109,Driving profile history data 3-Hours,0,
IDE06009-MAS00110,Driving profile history data 3-Minutes,0,
IDE06009-MAS00111,Driving profile history data 3-Seconds,0,
IDE06009-MAS00711,Driving profile history data 3-Odometer reading,0, km
IDE06009-MAS03095,Driving profile history data 3-Function status,Initialization,
IDE06010-IDE00105,Driving profile history data 4-Malfunction type,no entry,
IDE06010-IDE04805,Driving profile history data 4-Driving profile selection,0,
IDE06010-IDE07643,Driving profile history data 4-Faulty function,Engine Control Module,
IDE06010-MAS00106,Driving profile history data 4-Year,2000,
IDE06010-MAS00107,Driving profile history data 4-Month,0,
IDE06010-MAS00108,Driving profile history data 4-Day,0,
IDE06010-MAS00109,Driving profile history data 4-Hours,0,
IDE06010-MAS00110,Driving profile history data 4-Minutes,0,
IDE06010-MAS00111,Driving profile history data 4-Seconds,0,
IDE06010-MAS00711,Driving profile history data 4-Odometer reading,0, km
IDE06010-MAS03095,Driving profile history data 4-Function status,Initialization,
IDE06011-ENG136071,Selected driving profile-driving_profile_1,Dynamic,
IDE06011-ENG136072,Selected driving profile-driving_profile_2,no function,
IDE06011-ENG136073,Selected driving profile-driving_profile_3,no function,
IDE06011-ENG136074,Selected driving profile-driving_profile_4,no function,
IDE06011-ENG136075,Selected driving profile-driving_profile_5,no function,
IDE06011-ENG136076,Selected driving profile-driving_profile_6,no function,
IDE06011-ENG136077,Selected driving profile-driving_profile_7,no function,
IDE06011-ENG136078,Selected driving profile-driving_profile_8,no function,
IDE06165-MAS06193,Driving profile selection statistics-Profile 1,0,
IDE06165-MAS06194,Driving profile selection statistics-Profile 2,397,
IDE06165-MAS06195,Driving profile selection statistics-Profile 3,88,
IDE06165-MAS06196,Driving profile selection statistics-Profile 4,0,
IDE06165-MAS06197,Driving profile selection statistics-Profile 5,14,
IDE06165-MAS06198,Driving profile selection statistics-Profile 6,0,
IDE06165-MAS06199,Driving profile selection statistics-Profile 7,17,
IDE06165-MAS06200,Driving profile selection statistics-Profile 8,0,
IDE06165-MAS08875,Driving profile selection statistics-Profile 9,0,
IDE06165-MAS08876,Driving profile selection statistics-Profile 10,0,
IDE06165-MAS08877,Driving profile selection statistics-Profile 11,0,
IDE06165-MAS08878,Driving profile selection statistics-Profile 12,0,
IDE06230-MAS00106,Break recommend.: last message-Year,2000,
IDE06230-MAS00107,Break recommend.: last message-Month,0,
IDE06230-MAS00108,Break recommend.: last message-Day,0,
IDE06230-MAS00109,Break recommend.: last message-Hours,0,
IDE06230-MAS00110,Break recommend.: last message-Minutes,0,
IDE06230-MAS00111,Break recommend.: last message-Seconds,0,
IDE06230-MAS03095,Break recommend.: last message-Function status,Initialization,
IDE06230-MAS04622,Break recommend.: last message-Break recommend. message,No message,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,05,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,03,
IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Master,
IDE07184-MAS06023,MFL button for freely assignable function-Parameter actuation of Joker FPA button,Not operated,
IDE07184-MAS06024,MFL button for freely assignable function-Parameter programming of Joker FPA button,not active,
IDE07424-IDE04447,Status: driving profile selection for engine-Function status,not engaged,
IDE07424-IDE06260,Status: driving profile selection for engine-ID number,76,
IDE07424-MAS01156,Status: driving profile selection for engine-Communication status,OK,
IDE07424-MAS01447,Status: driving profile selection for engine-Act.val.,2,
IDE07425-IDE04447,Status: driving profile selection for start-stop function-Function status,not engaged,
IDE07425-IDE06260,Status: driving profile selection for start-stop function-ID number,23,
IDE07425-MAS01156,Status: driving profile selection for start-stop function-Communication status,OK,
IDE07425-MAS01447,Status: driving profile selection for start-stop function-Act.val.,0,
IDE07426-IDE04447,Status: driving profile selection for transmission-Function status,not engaged,
IDE07426-IDE06260,Status: driving profile selection for transmission-ID number,5,
IDE07426-MAS01156,Status: driving profile selection for transmission-Communication status,OK,
IDE07426-MAS01447,Status: driving profile selection for transmission-Act.val.,2,
IDE07473-MAS06303,Generator limitation-Status overvoltage limitation,not active,
IDE07473-MAS06304,Generator limitation-Status overvoltage diagnosis,not active,
IDE07473-MAS06305,Generator limitation-Status of diagnosis for energy balance,not active,
IDE07473-MAS06306,Generator limitation-Status generator release by engine,Request by Engine Control Module,
IDE07473-MAS06307,Generator limitation-Status of battery charging function,not active,
IDE07473-MAS06308,Generator limitation-Power steering support active,not active,
IDE07473-MAS06309,Generator limitation-Coolant fan activation request by BEM,not active,
IDE07474-MAS06313,Adapting for energy management-Adaptation static current management,not active,
IDE07474-MAS06314,Adapting for energy management-Battery coding active,not active,
IDE07616,Battery degradation for start/stop mode,Phase 1,
IDE07619-IDE07621,Start/stop starting voltage prediction-Permitted engine stop time,max.value,
IDE07619-IDE07622,Start/stop starting voltage prediction-Power consumption during idle phase,25, A
IDE07623-MAS06328,Open-circuit voltage gateway-Battery voltage last wakeup,12.6, V
IDE07623-MAS06329,Open-circuit voltage gateway-Batter voltage penultimate wakeup,15.0, V
IDE07623-MAS06330,Open-circuit voltage gateway-Open-circuit voltage valid,invalid,
IDE07628-IDE07629,Status power receptacle-Function release power receptacle,locked,
IDE07628-IDE07630,Status power receptacle-Pre-warning power receptacle,not active,
IDE07628-MAS01581,Status power receptacle-Power consumption,0, W
IDE07628-MAS06331,Status power receptacle-Enabling self-contained operation,locked,
IDE07628-MAS06332,Status power receptacle-Status function readiness,locked,
IDE07628-MAS06333,Status power receptacle-Status function,OFF,
IDE07628-MAS06334,Status power receptacle-Status overtemperature,in correct range,
IDE07638-MAS06339,Status condition determin. ready for idle-Sleep readiness BEM,ended,
IDE07638-MAS06340,Status condition determin. ready for idle-Busstat readiness BEM,Run busstat,
IDE07638-MAS06341,Status condition determin. ready for idle-After-run for power receptacle,not active,
IDE07640-MAS06344,Analysis of start voltage behavior-Minimum voltage at last engine start,9.20,
IDE07640-MAS06345,Analysis of start voltage behavior-Minimum voltage at last engine start recognized,not detected,
IDE07640-MAS06346,Analysis of start voltage behavior-Voltage drop through engine start recognized,not detected,
IDE07640-MAS06347,Analysis of start voltage behavior-Current voltage drop last start,3.00, V
IDE07640-MAS06348,Analysis of start voltage behavior-Normed voltage drop,3.00, V
IDE07640-MAS11064,Analysis of start voltage behavior-Current last engine start,832, A
IDE07640-MAS11065,Analysis of start voltage behavior-Current delta last engine start,816, A
IDE07681-MAS06086,Battery total charging throughput-Total re-charge,71.4, Ah
IDE07681-MAS06087,Battery total charging throughput-Entire energy throughput,68.4, Ah
IDE07873-MAS06193,Driving mode selection activated profiles-Profile 1,Not Used,
IDE07873-MAS06194,Driving mode selection activated profiles-Profile 2,AUTO,
IDE07873-MAS06195,Driving mode selection activated profiles-Profile 3,Dynamic,
IDE07873-MAS06196,Driving mode selection activated profiles-Profile 4,Offroad,
IDE07873-MAS06197,Driving mode selection activated profiles-Profile 5,ECONOMY,
IDE07873-MAS06198,Driving mode selection activated profiles-Profile 6,Not Used,
IDE07873-MAS06199,Driving mode selection activated profiles-Profile 7,INDIVIDUAL,
IDE07873-MAS06200,Driving mode selection activated profiles-Profile 8,EV_On,
IDE07873-MAS08875,Driving mode selection activated profiles-Profile 9,hybrid_auto,
IDE07873-MAS08876,Driving mode selection activated profiles-Profile 10,Not Used,
IDE07873-MAS08877,Driving mode selection activated profiles-Profile 11,Not Used,
IDE07873-MAS08878,Driving mode selection activated profiles-Profile 12,Not Used,
IDE07907,Bus communication,active,
IDE08343,Immobilizer Challenge,C4 22 E9 28,
IDE08346-MAS06117,Generator Analysis-Specified voltage,16.0, V
IDE08346-MAS06864,Generator Analysis-Generator actual voltage,12.6, V
IDE08346-MAS06865,Generator Analysis-Voltage difference generator battery,0.0, V
IDE08346-MAS06866,Generator Analysis-Generator speed,2057, /min
IDE08346-MAS06867,Generator Analysis-Generator chip temperature,32, °C
IDE08347,adapted battery capacity,111, Ah
IDE08680-MAS03173,Allocation data bus identifier-Powertrain data bus,11,
IDE08680-MAS03174,Allocation data bus identifier-Comfort data bus,12,
IDE08680-MAS03175,Allocation data bus identifier-Extended data bus,15,
IDE08680-MAS03177,Allocation data bus identifier-Infotainment data bus,13,
IDE08680-MAS03178,Allocation data bus identifier-Suspension data bus,14,
IDE08680-MAS03179,Allocation data bus identifier-Local data bus 2,52,
IDE08680-MAS03180,Allocation data bus identifier-Local data bus,51,
IDE08680-MAS05686,Allocation data bus identifier-Data bus diagnostics,10,
IDE08680-MAS05972,Allocation data bus identifier-Local data bus 3,53,
IDE08681-MAS03173,Data bus defect error-Powertrain data bus,OK,
IDE08681-MAS03174,Data bus defect error-Comfort data bus,OK,
IDE08681-MAS03175,Data bus defect error-Extended data bus,OK,
IDE08681-MAS03177,Data bus defect error-Infotainment data bus,OK,
IDE08681-MAS03178,Data bus defect error-Suspension data bus,OK,
IDE08681-MAS03179,Data bus defect error-Local data bus 2,OK,
IDE08681-MAS03180,Data bus defect error-Local data bus,OK,
IDE08681-MAS05686,Data bus defect error-Data bus diagnostics,OK,
IDE08681-MAS05972,Data bus defect error-Local data bus 3,not installed,
IDE08682-MAS03173,Data bus single wire err.-Powertrain data bus,OK,
IDE08682-MAS03174,Data bus single wire err.-Comfort data bus,OK,
IDE08682-MAS03175,Data bus single wire err.-Extended data bus,OK,
IDE08682-MAS03177,Data bus single wire err.-Infotainment data bus,OK,
IDE08682-MAS03178,Data bus single wire err.-Suspension data bus,OK,
IDE08682-MAS03179,Data bus single wire err.-Local data bus 2,Not coded,
IDE08682-MAS03180,Data bus single wire err.-Local data bus,Not coded,
IDE08682-MAS05686,Data bus single wire err.-Data bus diagnostics,Not coded,
IDE08682-MAS05972,Data bus single wire err.-Local data bus 3,not installed,
IDE08683-MAS03173,Data bus TimeOut error-Powertrain data bus,OK,
IDE08683-MAS03174,Data bus TimeOut error-Comfort data bus,OK,
IDE08683-MAS03175,Data bus TimeOut error-Extended data bus,OK,
IDE08683-MAS03177,Data bus TimeOut error-Infotainment data bus,OK,
IDE08683-MAS03178,Data bus TimeOut error-Suspension data bus,OK,
IDE08683-MAS03179,Data bus TimeOut error-Local data bus 2,Not coded,
IDE08683-MAS03180,Data bus TimeOut error-Local data bus,Not coded,
IDE08683-MAS05686,Data bus TimeOut error-Data bus diagnostics,Not coded,
IDE08683-MAS05972,Data bus TimeOut error-Local data bus 3,not installed,
IDE08684-SFT271901,Allocation LIN system number-Generator,00 1D,
IDE08684-SFT271921,Allocation LIN system number-Multifunction steering wheel control module,00 31,
IDE08684-SFT271927,Allocation LIN system number-Battery Monitoring Control Module,00 37,
IDE08684-SFT271977,Allocation LIN system number-Inverter for electrical outlet,00 69,
IDE08684-SFT271986,Allocation LIN system number-Analog clock,00 72,
IDE08684-SFT272175,Allocation LIN system number-Control head driving profile,01 2F,
IDE08684-SFT272190,Allocation LIN system number-Steering Wheel Touch Recognition Control Module,01 3E,
IDE08685-SFT271901,Status LIN user-Generator,not active,
IDE08685-SFT271921,Status LIN user-Multifunction steering wheel control module,active,
IDE08685-SFT271927,Status LIN user-Battery Monitoring Control Module,active,
IDE08685-SFT271977,Status LIN user-Inverter for electrical outlet,not active,
IDE08685-SFT271986,Status LIN user-Analog clock,not active,
IDE08685-SFT272175,Status LIN user-Control head driving profile,active,
IDE08685-SFT272190,Status LIN user-Steering Wheel Touch Recognition Control Module,active,
IDE08794-MAS06106,Battery cell analysis-Battery technology,Unknown,
IDE08794-MAS07703,Battery cell analysis-Cell voltage,0.0000, V
IDE08794-MAS07704,Battery cell analysis-Cell temp.,-40, °C
IDE08794-MAS07705,Battery cell analysis-Cell limit voltage (binary coded),0,
IDE08794-MAS07706,Battery cell analysis-Can be analyzed,Initialization,
IDE08794-MAS07707,Battery cell analysis-Health condition acc. to calendar,126, %
IDE08794-MAS07708,Battery cell analysis-Cut-off element,closed,
IDE09561,Static current last LIN sleep phase,-1.531, A
IDE09562,Range extension counter: stage 2,0,
IDE10674-MAS11055,Extended battery diagnosis-Pulse interior resistance,2.2, mOhm
IDE10674-MAS11056,Extended battery diagnosis-Counter battery warning,0,
IDE10674-MAS11059,Extended battery diagnosis-Power state LV battery singular operation,OK,
IDE10674-MAS11060,Extended battery diagnosis-Status Handshake HVK,OK,
IDE10739-IDE04447,Status: driving profile selection for oper. mode selection-Function status,not engaged,
IDE10739-IDE06260,Status: driving profile selection for oper. mode selection-ID number,8,
IDE10739-MAS01156,Status: driving profile selection for oper. mode selection-Communication status,OK,
IDE10739-MAS01447,Status: driving profile selection for oper. mode selection-Act.val.,0,
IDE11573,Energy management in heating power allocation,1000, W
IDE11673-MAS02246,Battery Management 2: prohibition on turning-on 48V-Timeout,not active,
IDE11673-MAS03123,Battery Management 2: prohibition on turning-on 48V-Reduced performance,not active,
IDE11673-MAS09519,Battery Management 2: prohibition on turning-on 48V-Message error,not active,
IDE11673-MAS09541,Battery Management 2: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11673-MAS09542,Battery Management 2: prohibition on turning-on 48V-Error status init. error,not active,
IDE11673-MAS09543,Battery Management 2: prohibition on turning-on 48V-Operating mode error,not active,
IDE11673-MAS09544,Battery Management 2: prohibition on turning-on 48V-No component function,not active,
IDE11673-MAS09545,Battery Management 2: prohibition on turning-on 48V-Sequence error,not active,
IDE11674-MAS02246,Voltage transformer: prohibition on turning-on 48V-Timeout,not active,
IDE11674-MAS09519,Voltage transformer: prohibition on turning-on 48V-Message error,not active,
IDE11674-MAS09541,Voltage transformer: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11674-MAS09542,Voltage transformer: prohibition on turning-on 48V-Error status init. error,not active,
IDE11674-MAS09543,Voltage transformer: prohibition on turning-on 48V-Operating mode error,not active,
IDE11674-MAS09544,Voltage transformer: prohibition on turning-on 48V-No component function,not active,
IDE11674-MAS09545,Voltage transformer: prohibition on turning-on 48V-Sequence error,not active,
IDE11676-MAS00799,Airbag: prohibition on turning-on 48V-Airbag control module,not active,
IDE11676-MAS02246,Airbag: prohibition on turning-on 48V-Timeout,not active,
IDE11676-MAS09519,Airbag: prohibition on turning-on 48V-Message error,not active,
IDE11676-MAS09521,Airbag: prohibition on turning-on 48V-Light accident detected,not active,
IDE11676-MAS09522,Airbag: prohibition on turning-on 48V-Severe accident detected,not active,
IDE11678-MAS02246,Engine electronics: prohibition on turning-on 48V-Timeout,not active,
IDE11678-MAS09519,Engine electronics: prohibition on turning-on 48V-Message error,not active,
IDE11678-MAS09541,Engine electronics: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11678-MAS09545,Engine electronics: prohibition on turning-on 48V-Sequence error,not active,
IDE11678-MAS09547,Engine electronics: prohibition on turning-on 48V-Error status drive motor: init. error,not active,
IDE11678-MAS09548,Engine electronics: prohibition on turning-on 48V-Error status drive: init. error,not active,
IDE11678-MAS09549,Engine electronics: prohibition on turning-on 48V-Drive condition: init. error,not active,
IDE11678-MAS09554,Engine electronics: prohibition on turning-on 48V-no component function drive,not active,
IDE11678-MAS13413,Engine electronics: prohibition on turning-on 48V-No component function of starter generator,not active,
IDE11678-MAS13415,Engine electronics: prohibition on turning-on 48V-48 V shut-down due to operating strategy,not active,
IDE11679-MAS02246,Electrical compressor: prohibition on turning-on 48V-Timeout,not active,
IDE11679-MAS09519,Electrical compressor: prohibition on turning-on 48V-Message error,not active,
IDE11679-MAS09541,Electrical compressor: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11679-MAS09542,Electrical compressor: prohibition on turning-on 48V-Error status init. error,not active,
IDE11679-MAS09544,Electrical compressor: prohibition on turning-on 48V-No component function,not active,
IDE11679-MAS09545,Electrical compressor: prohibition on turning-on 48V-Sequence error,not active,
IDE11679-MAS13455,Electrical compressor: prohibition on turning-on 48V-48 V voltage measurement error,not active,
IDE11681-MAS03182,Monitoring line disconnection: prohibition on turning-on 48V-Branch 1,not active,
IDE11681-MAS03183,Monitoring line disconnection: prohibition on turning-on 48V-Branch 2,not active,
IDE11684-MAS02832,Battery management 2: status for 48V power-Malfunction status,Initialization,
IDE11684-MAS03001,Battery management 2: status for 48V power-Mode,Initialization,
IDE11685-MAS02832,Voltage converter: status for 48V power-Malfunction status,Initialization,
IDE11685-MAS03001,Voltage converter: status for 48V power-Mode,Initialization,
IDE11911-MAS00799,48V activation restriction-Airbag control module,not active,
IDE11911-MAS09516,48V activation restriction-Engine Electronics,not active,
IDE11911-MAS10933,48V activation restriction-Roll stabilization,not active,
IDE11911-MAS13411,48V activation restriction-48 V activation restriction due to open circuit,not active,
IDE11911-MAS13412,48V activation restriction-48 V activation restriction due to deactivation,not active,
IDE11911-SFT00033,48V activation restriction-Battery management 2,not active,
IDE11911-SFT00196,48V activation restriction-Voltage converter,not active,
IDE11911-SFT271913,48V activation restriction-Auxiliary Air Heater Control Module/PTC,not active,
IDE11911-SFT272141,48V activation restriction-Electrical compressor,not active,
IDE12084,Component protection participant status,00 14 1B 00 00 00 0E 13 00 00 00 57 13 00 00 00 15 11 00 00 00 6F 13 00 00 00 6D 20 00 00 00 73 13 00 00 00 4E 20 00 00 00 8A 20 00 00 00 2C 20 00 00 00 4F 13 00 00 00 7B 20 00 00,
IDE12133-MAS01896,Freewheel - energy-Free run,25, A
IDE12133-MAS14352,Freewheel - energy-Auxiliary store current,0, A
IDE12133-MAS14353,Freewheel - energy-Loading release for additional memory,Maximum charge DC/DC converter,
IDE12133-MAS14357,Freewheel - energy-Generator start mode,First start,
IDE12133-MAS14362,Freewheel - energy-Voltage limit boost mode,6.0, V
IDE12134-MAS14344,Freewheel - condition-Status of coasting release,Release,
IDE12134-MAS14348,Freewheel - condition-Status of freewheel engine off release,Release,
IDE12134-MAS14349,Freewheel - condition-Freewheel engine off block,0,
IDE12134-MAS14350,Freewheel - condition-Store request,no request,
IDE12134-MAS14351,Freewheel - condition-Freewheel engine off restart,0,
IDE12135-MAS14363,Belt driven starter generator 12V-Specified voltage: lower limit,10.60, V
IDE12135-MAS14364,Belt driven starter generator 12V-Specified voltage limit,10.60, V
IDE12135-MAS14365,Belt driven starter generator 12V-Recommended specified voltage,10.6, V
IDE12135-MAS14366,Belt driven starter generator 12V-Maximum ramp time,0, s
IDE12135-MAS14367,Belt driven starter generator 12V-Minimum voltage for start,7.0, V
IDE12135-MAS14368,Belt driven starter generator 12V-Specified voltage of the belt driven starter generator,9.0, V
IDE12135-MAS14369,Belt driven starter generator 12V-Actual mode belt driven starter generator,Unknown (14),
IDE12609-MAS02832,Steering wheel touch recognition: status-Malfunction status,No malfunction detected,
IDE12609-MAS14836,Steering wheel touch recognition: status-Touch intensity sensor 1,32,
IDE12609-MAS14837,Steering wheel touch recognition: status-Touch intensity sensor 2,40,
IDE12609-MAS14838,Steering wheel touch recognition: status-Touch intensity sensor 3,47,
IDE12609-MAS14839,Steering wheel touch recognition: status-Touch status,not touching,
IDE13754-IDE04447,Diagnosis filter: status-Function status,Function active,
IDE13754-MAS16866,Diagnosis filter: status-Odometer,44, km
IDE13754-MAS16867,Diagnosis filter: status-Reason for deactivation,production,
IDE13754-MAS16875,Diagnosis filter: status-Filter status,Filter is not active,
IDE13755-IDE00056,Diagnosis filter: history data-History data 1,0000000*2011-01-01-00-00-34*6**,
IDE13755-IDE00057,Diagnosis filter: history data-History data 2,0000000*0000-01-01-00-00-00*0**,
IDE13755-IDE00058,Diagnosis filter: history data-History data 3,0000000*0000-01-01-00-00-00*0**,
IDE13755-IDE00059,Diagnosis filter: history data-History data 4,0000000*0000-01-01-00-00-00*0**,
IDE13755-IDE00060,Diagnosis filter: history data-History data 5,0000000*0000-01-01-00-00-00*0**,
IDE14424,Historical data info status,00000110 ,
MAS00464-MAS00106,Standard - ambient data 1-Year,2022,
MAS00464-MAS00107,Standard - ambient data 1-Month,6,
MAS00464-MAS00108,Standard - ambient data 1-Day,18,
MAS00464-MAS00109,Standard - ambient data 1-Hours,10,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,30,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,34,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,19,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,156, km
MAS00769-IDE02717,Multifunction steering wheel control module-Tiptronic upshift,Not operated,
MAS00769-IDE02718,Multifunction steering wheel control module-Tiptronic downshift,Not operated,
MAS00769-IDE07668,Multifunction steering wheel control module-MFL Variant code,10,
MAS00769-MAS01065,Multifunction steering wheel control module-Brand,VW,
MAS00769-MAS01288,Multifunction steering wheel control module-Horn,Not operated,
MAS00769-MAS02317,Multifunction steering wheel control module-Button code 1,Not operated,
MAS00769-MAS02318,Multifunction steering wheel control module-Button code 2,Not operated,
MAS00769-MAS02319,Multifunction steering wheel control module-Event code 1,No result,
MAS00769-MAS02320,Multifunction steering wheel control module-Event code 2,No result,
MAS00769-MAS06029,Multifunction steering wheel control module-MFL message counter,7,
MAS00769-MAS06030,Multifunction steering wheel control module-MFL Toggle Bit,1,
MAS00769-MAS06034,Multifunction steering wheel control module-MFL Local active,not active,
MAS00769-MAS06035,Multifunction steering wheel control module-MFL M button,Not operated,
MAS04447-IDE06339,Engine running status-Hybrid readiness: status,not active,
MAS04447-MAS01493,Engine running status-Engine running,Engine running,
MAS04447-MAS03023,Engine running status-Driving mode,Driving mode,
MAS04447-MAS06320,Engine running status-Status rolling mode,not active,
SFT271901,Generator,-,
SFT271901-ENG250861,Generator-alternator_family,35,
SFT271901-ENG245985,Generator-asic_manufacturer,30 30,
SFT271901-ENG250451,Generator-asic_variant,30 34,
SFT271901-ENG171470,Generator-Manufacturer,30 30,
SFT271901-ENG99001,Generator-Variant,31 34,
ENG118784-ENG124497,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Actuator_Exterior_Noise,not active,
ENG118784-ENG118736,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Adaptive_Cruise_Control,not active,
ENG118784-ENG137111,Driv._Prof._Sel._Coord._Retry_State-Retry_State_AGK,not active,
ENG118784-ENG124493,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Air_Condition,not active,
ENG118784-ENG118739,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Ambient_Illumination,not active,
ENG118784-ENG124501,Driv._Prof._Sel._Coord._Retry_State-Retry_State_area_view,not active,
ENG118784-ENG124495,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Belt_Pretensioner,not active,
ENG118784-ENG124499,Driv._Prof._Sel._Coord._Retry_State-Retry_State_brake_control_system,not active,
ENG118784-ENG124503,Driv._Prof._Sel._Coord._Retry_State-Retry_State_central_differential,not active,
ENG118784-ENG118734,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Damper_Control,not active,
ENG118784-ENG137112,Driv._Prof._Sel._Coord._Retry_State-Retry_State_EDS,not active,
ENG118784-ENG126254,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Electronic_Brake_Booster,not active,
ENG118784-ENG118730,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Engine_Control,not active,
ENG118784-ENG152042,Driv._Prof._Sel._Coord._Retry_State-Retry_State_FMA,not active,
ENG118784-ENG124498,Driv._Prof._Sel._Coord._Retry_State-Retry_State_front_axle_differential_lock,not active,
ENG118784-ENG124500,Driv._Prof._Sel._Coord._Retry_State-Retry_State_hill_descent_control,not active,
ENG118784-ENG137110,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Hill_Distence_Control,not active,
ENG118784-ENG124494,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Lighting_Control,not active,
ENG118784-ENG126252,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Operation_Mode,not active,
ENG118784-ENG124496,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Overrunning_Clutch,not active,
ENG118784-ENG137108,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Park_Distence_Control,not active,
ENG118784-ENG126251,Driv._Prof._Sel._Coord._Retry_State-Retry_State_range_Calculation,not active,
ENG118784-ENG124502,Driv._Prof._Sel._Coord._Retry_State-Retry_State_rear_spoiler,not active,
ENG118784-ENG126253,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Seat_Sidebolster_Adjustment,not active,
ENG118784-ENG118737,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Sound_Actuator,not active,
ENG118784-ENG124492,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Start_/_Stop,not active,
ENG118784-ENG118733,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Steering_Support,not active,
ENG118784-ENG118732,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Transmission_Control,not active,
ENG118786-ENG137129,Driv._Prof._Sel._Dr._Op.-Drehsteller_Ist_Modus,2,
ENG118786-ENG137130,Driv._Prof._Sel._Dr._Op.-Drehsteller_Modus,2,
ENG118786-ENG137133,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_HVEM,0,
ENG118786-ENG137135,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Mo_BZS,0,
ENG118786-ENG137134,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Step_Reduction,0,
ENG118786-ENG137132,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Trailer,0,
ENG118786-ENG137131,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Modus,not detected,
ENG118786-ENG118748,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Profile,not detected,
ENG118783-ENG118728,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Coordinator_Sub_State_Value,5,
ENG118783-ENG118729,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Startup_State,active,
ENG118766,eASS_operation_status,active,
ENG137076-ENG118763,EM_battery_analog_monitoring-actual_difference_voltage,0.000, V
ENG137076-ENG118760,EM_battery_analog_monitoring-battery_analog_voltage,0.0, V
ENG137076-ENG118765,EM_battery_analog_monitoring-battery_off_counter,0,
ENG137076-ENG118764,EM_battery_analog_monitoring-battery_off_status_intern,connected,
ENG137076-ENG118761,EM_battery_analog_monitoring-battery_voltage_filtered,13.5, V
ENG137076-ENG118762,EM_battery_analog_monitoring-voltage_difference,0.00, V
ENG106123,EM_blAlternator On,On,
ENG106124,EM_blAlternator Valid,Yes,
ENG106140,EM_Current_Control_Recu,active,
ENG151180,EM_electrical_system_current,18.579, A
ENG118437,EM_IAlternatorReserve,144.5, A
ENG118434,EM_LoadResponse Time,3, s
ENG106154,EM_PAltMechanical,350, W
ENG106155-ENG118436,EM_prcSoh-SOH_P,96, %
ENG106155-ENG118435,EM_prcSoh-SOH_Q,89, %
ENG106157,EM_RecuMode_Engine,Neutral,
ENG118780-ENG246261,EM_Recuperation_Precondition-48V_emergency_run,0,
ENG118780-ENG118443,EM_Recuperation_Precondition-acid_lamination,1,
ENG118780-ENG118438,EM_Recuperation_Precondition-available_charge,1,
ENG118780-ENG118442,EM_Recuperation_Precondition-battery_aging_charge,1,
ENG118780-ENG118441,EM_Recuperation_Precondition-battery_aging_power,1,
ENG118780-ENG118440,EM_Recuperation_Precondition-battery_charging_state,1,
ENG118780-ENG118447,EM_Recuperation_Precondition-battery_regeneration,1,
ENG118780-ENG103388,EM_Recuperation_Precondition-battery_temperature,1,
ENG118780-ENG112320,EM_Recuperation_Precondition-Battery_Voltage,1,
ENG118780-ENG167301,EM_Recuperation_Precondition-climate_electronics_enable,1,
ENG118780-ENG118448,EM_Recuperation_Precondition-energy_net,1,
ENG118780-ENG118445,EM_Recuperation_Precondition-generator_diagnosis,1,
ENG118780-ENG118449,EM_Recuperation_Precondition-idle_increase,1,
ENG118780-ENG167323,EM_Recuperation_Precondition-kfg_enable,1,
ENG118780-ENG118439,EM_Recuperation_Precondition-LIN_communication,1,
ENG118780-ENG118450,EM_Recuperation_Precondition-special_veto,1,
ENG118781-ENG118673,EM_Recuperation_Restriction-component_protection_engine,0,
ENG118781-ENG118675,EM_Recuperation_Restriction-component_protection_EPS,0,
ENG118781-ENG118674,EM_Recuperation_Restriction-component_protection_ESP,0,
ENG118781-ENG118672,EM_Recuperation_Restriction-component_protection_high_beam_light,0,
ENG118781-ENG118668,EM_Recuperation_Restriction-inside_light_active,0,
ENG118781-ENG118670,EM_Recuperation_Restriction-left_turn_signal_active,0,
ENG118781-ENG252593,EM_Recuperation_Restriction-limited_by_48V_consumer,0,
ENG118781-ENG107413,EM_Recuperation_Restriction-low_beam_light_active,0,
ENG118781-ENG110583,EM_Recuperation_Restriction-PLA,0,
ENG118781-ENG113826,EM_Recuperation_Restriction-RekuLight,0,
ENG118781-ENG118669,EM_Recuperation_Restriction-right_turn_signal_active,0,
ENG118781-ENG167381,EM_Recuperation_Restriction-voltage_requirement_bcm,0,
ENG118781-ENG167382,EM_Recuperation_Restriction-voltage_Requirement_kfg,0,
ENG118781-ENG118667,EM_Recuperation_Restriction-workload_inside_blaster,0,
ENG118782-ENG118462,Gateway app. software identification-software_version_BCmE,1035,
ENG118782-ENG118457,Gateway app. software identification-software_version_eASS,2015,
ENG118782-ENG137098,Gateway app. software identification-software_version_ehr,----,
ENG118782-ENG118454,Gateway app. software identification-software_version_em,7144,
ENG118782-ENG118453,Gateway app. software identification-software_version_fpa,-020,
ENG118782-ENG118455,Gateway app. software identification-software_version_history_data,0700,
ENG118782-ENG125888,Gateway app. software identification-software_version_hv-em,----,
ENG118782-ENG118456,Gateway app. software identification-software_version_ks,----,
ENG118782-ENG118458,Gateway app. software identification-software_version_mfl,0200,
ENG118782-ENG118463,Gateway app. software identification-software_version_mke,3178,
ENG118782-ENG163716,Gateway app. software identification-software_version_mv-em,0505,
ENG118782-ENG163717,Gateway app. software identification-software_version_rtm,----,
ENG118782-ENG122591,Gateway app. software identification-software_version_rwb,----,
ENG118782-ENG118459,Gateway app. software identification-software_version_service_key_1a,0100,
ENG118782-ENG118460,Gateway app. software identification-software_version_SWaP,0630,
ENG118782-ENG118461,Gateway app. software identification-software_version_wakeup_monitor,0100,
ENG118782-ENG118452,Gateway app. software identification-version_routing_gateway,7230,
ENG118666,MKE_HFC_filtrated,1.0,
ENG126247-ENG126257,MKE_TTNR-TTNR_DS,60021,
ENG126247-ENG126256,MKE_TTNR-TTNR_SW,60039,
ENG151185-ENG140447,MV-EM_48V_electrical_system_components-48V_Ptc_installed,not installed,
ENG151185-ENG140446,MV-EM_48V_electrical_system_components-48V_Rsg_installed,not installed,
ENG151185-ENG140442,MV-EM_48V_electrical_system_components-DcDc_installed,not installed,
ENG151185-ENG140444,MV-EM_48V_electrical_system_components-eAbc_installed,not installed,
ENG151185-ENG140445,MV-EM_48V_electrical_system_components-eAv_installed,not installed,
ENG151185-ENG140443,MV-EM_48V_electrical_system_components-eAws_installed,not installed,
ENG151185-ENG140441,MV-EM_48V_electrical_system_components-LiIon_battery_installed,not installed,
ENG151185-ENG140440,MV-EM_48V_electrical_system_components-sCap_installed,not installed,
ENG151186-MAS01867,MV-EM_48V_electrical_system_diagnosis_typ_1-Measurement,not OK.,
ENG151186-ENG140420,MV-EM_48V_electrical_system_diagnosis_typ_1-48V_electrical_system_diagnosis_request,not requested,
ENG151186-ENG140421,MV-EM_48V_electrical_system_diagnosis_typ_1-Bms_48V_actual_current,0, A
ENG151187-MAS01867,MV-EM_48V_electrical_system_diagnosis_typ_2-Measurement,not OK.,
ENG151187-ENG140423,MV-EM_48V_electrical_system_diagnosis_typ_2-48V_electrical_system_active,not active,
ENG151187-ENG140416,MV-EM_48V_electrical_system_diagnosis_typ_2-Bms_48V_actual_voltage,0.00, V
ENG151187-ENG140424,MV-EM_48V_electrical_system_diagnosis_typ_2-DcDc_48V_actual_voltage,Initialization,
ENG151187-ENG140428,MV-EM_48V_electrical_system_diagnosis_typ_2-eAbc_back_48V_actual_voltage,0.00, V
ENG151187-ENG140427,MV-EM_48V_electrical_system_diagnosis_typ_2-eAbc_front_48V_actual_voltage,0.00, V
ENG151187-ENG140429,MV-EM_48V_electrical_system_diagnosis_typ_2-eAv_48V_actual_voltage,0.00, V
ENG151187-ENG140426,MV-EM_48V_electrical_system_diagnosis_typ_2-eAws_back_48V_actual_voltage,0.00, V
ENG151187-ENG140425,MV-EM_48V_electrical_system_diagnosis_typ_2-eAws_front_48V_actual_voltage,0.00, V
ENG151187-ENG140430,MV-EM_48V_electrical_system_diagnosis_typ_2-Rsg_48V_actual_voltag,Initialization,
ENG151188-MAS01867,MV-EM_48V_overvoltage_check-Measurement,not OK.,
ENG151188-ENG140416,MV-EM_48V_overvoltage_check-Bms_48V_actual_voltage,0.00, V
ENG151188-ENG140417,MV-EM_48V_overvoltage_check-Bms_48V_Soc,0.00, %
ENG151189-MAS11874,MV-EM_48V_Zero_potential_status-Overall status,Initialization,
ENG151190-ENG140438,MV-EM_coldstart_requirement_engine-requirement_12V_start,not active,
ENG151190-ENG140439,MV-EM_coldstart_requirement_engine-requirement_48V_start,not active,
ENG151191,MV-EM_dc_current_Mv,-204.0, A
ENG151192,MV-EM_dc_power_desired,-6325, W
ENG151193,MV-EM_DC_voltage_desired,0.00, V
ENG151194,MV-EM_dc_voltage_Mv,0.00, V
ENG151195-ENG140270,MV-EM_Derating_voltage-Derating_group_A,0.00, V
ENG151195-ENG140271,MV-EM_Derating_voltage-Derating_group_B,0.00, V
ENG151195-ENG140272,MV-EM_Derating_voltage-Derating_group_C,0.00, V
ENG151195-ENG140409,MV-EM_Derating_voltage-Derating_Umax_feedback,0.00, V
ENG151196,MV-EM_EMG_level_of_capacity,0.025, %
ENG151197,MV-EM_Mv_current,-511, A
ENG151198-ENG140414,MV-EM_recommendation_Dcdc-Dcdc_boost_mode,not active,
ENG151198-ENG140415,MV-EM_recommendation_Dcdc-Dcdc_buck_mode,not active,
ENG151199-ENG140410,MV-EM_release-12V_coldstart_release,No enabling,
ENG151199-ENG140411,MV-EM_release-12V_warmstart_release,No enabling,
ENG151199-ENG140412,MV-EM_release-48V_coldstart_release,No enabling,
ENG151199-ENG140413,MV-EM_release-start_stopp_support_release,No enabling,
ENG151200,MV-EM_RSG_maximal_current,0, A
ENG151201,MV-EM_RSG_maximal_voltage,0.00, V
ENG250370-ENG250534,NVEM_Grund_BEM_falsch_codiert-Grund_BEM_falsch_codiert,0,
Elapsed Time: 00:53,,,
blockmap-22-5WA-907-554-P_3VV2X7B28NM061887-20220618-1236.CSV
;SW:5WA-907-554-P   HW:5WA-525-130 ---  AWD
;Component:4Motion       H65 0724, Coding:0101
;EV_AllWheelContrHA1VW37X,005001,EV_AllWheelContrHA1VW37X_005.rod
;Saturday,18,June,2022,12:36:52:14741
;VCDS Version: Beta 22.4.0 (x64)  Data version: 20220407 DS338.0
;VCID: DBE87C2603A69983660-808E
Group,Description,Actual,
IDE00019,Voltage terminal 30,12.3, V
IDE00102,Control Module temperature,39, °C
IDE00323,Security Access: Number of invalid keys,255,
IDE00920,Front left wheel speed,0.0, km/h
IDE00921,Wheel speed: right front,0.0, km/h
IDE00922,Left rear wheel speed,0.0, km/h
IDE00923,Right rear wheel speed,0.0, km/h
IDE01617,Clutch temperature,-152.45, °C
IDE02271-IDE02384,CAN output signal(s) status-Status of event memory,not active,
IDE02271-MAS01464,CAN output signal(s) status-Emergency running mode,not active,
IDE02271-MAS01480,CAN output signal(s) status-excessive temperature,not active,
IDE02404,Checksum calculation,CC AD 00 38,
IDE04502-MAS04730,Haldex clutch: status-Degree of blockage,34.65, %
IDE05609,Cooling fin temperature,323.70, °C
IDE05610,Duration of overtemperature,0, min
IDE05707,Haldex clutch pump: current,5.273, A
IDE05708,Haldex clutch pump: PWM signal,53, %
IDE05710,Haldex clutch pump: voltage,4.2, V
IDE06111,Axle speed deltas,0.0, km/h
IDE80003-ENG119372,Analysis 3-Exeedance_Intergral_1_traction_slip_controller,53,
IDE80003-ENG119373,Analysis 3-Exeedance_Intergral_2_extreme_slip_event,87,
IDE80003-ENG119374,Analysis 3-Undercut_Integral_3_differential_lock_too_far_closed,65,
IDE80004-ENG119372,Analysis 4-Exeedance_Intergral_1_traction_slip_controller,53,
IDE80004-ENG119373,Analysis 4-Exeedance_Intergral_2_extreme_slip_event,87,
IDE80004-ENG119374,Analysis 4-Undercut_Integral_3_differential_lock_too_far_closed,65,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,36,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,29,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,20,
MAS03129,Reset counter,1,
ENG119394-ENG119379,Pump_Calibration_Values-Calibration_Value_at_1_Bar_Current_EEPROM,3018,
ENG119394-ENG119380,Pump_Calibration_Values-Calibration_Value_at_1_Bar_Current_Last_Measurement,1155,
ENG119394-ENG119378,Pump_Calibration_Values-Calibration_Value_at_1_Bar_Pressure_EEPROM,190,
ENG119394-ENG119381,Pump_Calibration_Values-Calibration_Value_at_1_Bar_Voltage_EEPROM,789,
ENG119394-ENG119382,Pump_Calibration_Values-Calibration_Value_at_1_Bar_Voltage_Last_Measurement,2934,
ENG119394-ENG119384,Pump_Calibration_Values-Calibration_Value_at_15_Bar_Current_EEPROM,2441,
ENG119394-ENG119385,Pump_Calibration_Values-Calibration_Value_at_15_Bar_Current_Interpolation,3157,
ENG119394-ENG119383,Pump_Calibration_Values-Calibration_Value_at_15_Bar_Pressure_EEPROM,7137,
ENG119394-ENG119386,Pump_Calibration_Values-Calibration_Value_at_15_Bar_Voltage_EEPROM,6848,
ENG119394-ENG119387,Pump_Calibration_Values-Calibration_Value_at_15_Bar_Voltage_Interpolation,10518,
ENG119394-ENG119389,Pump_Calibration_Values-Calibration_Value_at_42_Bar_Current_EEPROM,6299,
ENG119394-ENG119390,Pump_Calibration_Values-Calibration_Value_at_42_Bar_Current_Last_Measurement,19532,
ENG119394-ENG119388,Pump_Calibration_Values-Calibration_Value_at_42_Bar_Pressure_EEPROM,4126,
ENG119394-ENG119391,Pump_Calibration_Values-Calibration_Value_at_42_Bar_Voltage_EEPROM,5460,
ENG119394-ENG119392,Pump_Calibration_Values-Calibration_Value_at_42_Bar_Voltage_Last_Measurement,32,
ENG119394-ENG119377,Pump_Calibration_Values-Series_Number_Pump,³,
ENG119394-ENG119376,Pump_Calibration_Values-Temperature_Value_at_Calibration,8722, °C
ENG119375,Upper Limit of Temperature Duration,0, min
Elapsed Time: 00:03,,,
blockmap-3C-2Q0-907-686-B_3VV2X7B28NM061887-20220618-1236.CSV
;SW:2Q0-907-686-B   HW:2Q0-907-686-B ---  Lane Change
;Component:HRE3_Kl15_Mst H07 0150, Coding:52954620
;EV_HREntryHellaGen3Kl15,002001,EV_HREntryHellaGen3Kl15_002_VW27.rod
;Saturday,18,June,2022,12:36:58:14741
;VCID: B924C6AEE9DA8B9354C-80EC
IDE00018,Voltage terminal 15,12.48, V
IDE00102,Control Module temperature,53.0, °C
IDE00925,Yaw rate,0.09, °/s
IDE01441,Back-up lamp,OFF,
IDE01766-MAS01853,Distance impulses-Left front,0,
IDE01766-MAS01854,Distance impulses-Right front,0,
IDE01766-MAS01855,Distance impulses-Left rear,0,
IDE01766-MAS01856,Distance impulses-Right rear,0,
IDE02049,Trailer detected,not detected,
IDE02057-MAS10062,Dynamic calibration: status-Auto. calibration: distance travelled,63.00, km
IDE02057-MAS10063,Dynamic calibration: status-Auto. calibration: percent. progress Master,100, %
IDE02057-MAS10064,Dynamic calibration: status-Auto. calibration: percent. progress Slave,100, %
IDE02057,Dynamic calibration: status,OFF,
IDE02219-MAS02471,Steering wheel angle: sign-Sign,Negative,
IDE02219,Steering wheel angle: sign,3.20,
IDE02486,Data logger triggering,not initialize,
IDE03619,System condition,On,
IDE05064,lane change assist. 2: supply voltage,12.48, V
IDE05065,lane change assist. 2: temperature,53.0, °C
IDE05067-MAS08213,Functional status of lane change assist.-Blind spot detection,passive,
IDE05067-MAS10332,Functional status of lane change assist.-Rear Cross Traffic Alert,passive,
IDE05067-SFT00060,Functional status of lane change assist.-Lane change assistance,OFF,
IDE05070,Curve radius,19328, m
IDE05077-MAS02475,Rain/light recognition sensor via data bus-Brightness infrared,5,
IDE05077-MAS02477,Rain/light recognition sensor via data bus-Front brightness,1021,
IDE05077,Rain/light recognition sensor via data bus,installed,
IDE05087,Dynamic angle offset lane change assist. 1,1.10, °
IDE05088,Dynamic angle offset lane change assist. 2,0.10, °
IDE05090,Measured receiving power lane change assist. 1,0, %
IDE05091,Measured receiving power lane change assist. 2,0, %
IDE05092,Measured angle lane change assist. 1,-20.48, °
IDE05093,Measured angle lane change assist. 2,-20.48, °
IDE05094,Static angle offset lane change assist. 1,10.24, °
IDE05095,Static angle offset lane change assist. 2,10.24, °
IDE06199-MAS01167,Indicator light for lane change assist. in instrument cluster-Actuation time,no control,
IDE06199-ENG170421,Indicator light for lane change assist. in instrument cluster-IoReached Status,Output diagnostic test not active,
IDE10102,Right warning light flashing cycle,OFF,
IDE10103,Left warning light flashing cycle,OFF,
IDE10104,Left warning light status,OFF,
IDE10106,Right warning light status,OFF,
IDE10107,Dimming value of left warning light: warning algorithm,0, %
IDE10108,Status of left warning light: warning algorithm,---,
IDE10109,Dimming value of right warning light: warning algorithm,0, %
IDE10110,Status of right warning light: warning algorithm,---,
IDE10229-IDE10101,Warning light for blind spot assistant in left exterior mirror-Dimming value of left warning light,0, %
IDE10229-MAS01167,Warning light for blind spot assistant in left exterior mirror-Actuation time,no control,
IDE10229-ENG170421,Warning light for blind spot assistant in left exterior mirror-IoReached Status,Output diagnostic test not active,
IDE10230-IDE10105,Warning light for blind spot assistant in right exterior mirror-Dimming value of right warning light,0, %
IDE10230-MAS01167,Warning light for blind spot assistant in right exterior mirror-Actuation time,no control,
IDE10230-ENG170421,Warning light for blind spot assistant in right exterior mirror-IoReached Status,Output diagnostic test not active,
IDE10235-IDE10233,Status night design-Night design,not activated,
IDE10235-IDE10234,Status night design-Day design,activated,
IDE10235,Status night design,OFF,
IDE10236-MAS01487,Lane keeping warning system-LED,yellow,
IDE10236-MAS10041,Lane keeping warning system-Distance to lane,0.55, m
IDE10236-MAS10042,Lane keeping warning system-Time to lane crossing,3.0, s
IDE10236-MAS10043,Lane keeping warning system-Vehicle side,Left,
IDE11133-MAS01167,Output of parking assistant warning-Actuation time,no control,
IDE11133-ENG170421,Output of parking assistant warning-IoReached Status,Output diagnostic test not active,
IDE13096,Rear cross traffic assistant: left warning level,RCTA_hat_links_nichts_erkannt,
IDE13107,Rear cross traffic assistant: right warning level,RCTA_hat_rechts_nichts_erkannt,
IDE80001,Analysis 1,No display,
IDE80002,Analysis 2,keine_Anzeige,
IDE80004,Analysis 4,keine_Anzeige,
MAS05108-MAS10050,ESP-Delay regulation,Feedback: delay regulation is available,
MAS05108-MAS10059,ESP-Blind spot warning: message,consistent,
MAS05108-MAS10669,ESP-Delay regulation: brake jolt,Not available,
MAS08785-IDE02679,Parking aid-Tone sensor,Not available,
MAS08785-IDE03619,Parking aid-System condition,System off,
MAS12659-IDE00007,VW/Audi part numbers of sub-bus users-VW/Audi part number,2Q0907685B ,
MAS12659-MAS01170,VW/Audi part numbers of sub-bus users-Subsystem designation,Lane change assistance control module 2,
MAS12659-ENG170217,VW/Audi part numbers of sub-bus users-Number Of Expected SubSystem Identification,1,
MAS12659-ENG170218,VW/Audi part numbers of sub-bus users-Number Of Retrieved SubSystem Identification,1,
MAS12659-ENG170221,VW/Audi part numbers of sub-bus users-SubSystem Node Address,00 3B,
MAS12660-IDE00016,Hardware version number of sub-bus users-Hardware version,H07,
MAS12660-MAS01170,Hardware version number of sub-bus users-Subsystem designation,Lane change assistance control module 2,
MAS12660-ENG170217,Hardware version number of sub-bus users-Number Of Expected SubSystem Identification,1,
MAS12660-ENG170218,Hardware version number of sub-bus users-Number Of Retrieved SubSystem Identification,1,
MAS12660-ENG170221,Hardware version number of sub-bus users-SubSystem Node Address,00 3B,
MAS12661-IDE00008,Software version number of sub-bus users-Software version,0150,
MAS12661-MAS01170,Software version number of sub-bus users-Subsystem designation,Lane change assistance control module 2,
MAS12661-ENG170217,Software version number of sub-bus users-Number Of Expected SubSystem Identification,1,
MAS12661-ENG170218,Software version number of sub-bus users-Number Of Retrieved SubSystem Identification,1,
MAS12661-ENG170221,Software version number of sub-bus users-SubSystem Node Address,00 3B,
MAS12662-IDE00012,Hardware part number of sub-bus users-Hardware part number,2Q0907685B ,
MAS12662-MAS01170,Hardware part number of sub-bus users-Subsystem designation,Lane change assistance control module 2,
MAS12662-ENG170217,Hardware part number of sub-bus users-Number Of Expected SubSystem Identification,1,
MAS12662-ENG170218,Hardware part number of sub-bus users-Number Of Retrieved SubSystem Identification,1,
MAS12662-ENG170221,Hardware part number of sub-bus users-SubSystem Node Address,00 3B,
MAS12663-IDE00010,Series number of sub-bus users-Serial number,11230041907747      ,
MAS12663-MAS01170,Series number of sub-bus users-Subsystem designation,Lane change assistance control module 2,
MAS12663-ENG170217,Series number of sub-bus users-Number Of Expected SubSystem Identification,1,
MAS12663-ENG170218,Series number of sub-bus users-Number Of Retrieved SubSystem Identification,1,
MAS12663-ENG170221,Series number of sub-bus users-SubSystem Node Address,00 3B,
MAS12665-MAS00966,FAZIT identifications of sub-bus users-Manufacturer index location,YRK-HEC,
MAS12665-MAS00968,FAZIT identifications of sub-bus users-Day of manufacture,26.01.22,
MAS12665-MAS00969,FAZIT identifications of sub-bus users-Manufacturer- test stand number,6CC6,
MAS12665-MAS00970,FAZIT identifications of sub-bus users-Running manufacturer number,217D,
MAS12665-MAS01170,FAZIT identifications of sub-bus users-Subsystem designation,Lane change assistance control module 2,
MAS12665-ENG170217,FAZIT identifications of sub-bus users-Number Of Expected SubSystem Identification,1,
MAS12665-ENG170218,FAZIT identifications of sub-bus users-Number Of Retrieved SubSystem Identification,1,
MAS12665-ENG170221,FAZIT identifications of sub-bus users-SubSystem Node Address,00 3B,
MAS12666-ENG299104,SubSystemNodeAddress of sub bus participant-SubSystem Node Addresses,|SubSystem Node Address,Subsystem designation|00 3B
MAS12667-ENG299102,Specified installation of sub-bus users-SubSystems coded,|SubSystem coded Bit 0,SubSystem coded Bit 1
MAS12668-ENG299105,Actual installation of sub-bus users-SubSystems present,|SubSystem present Bit 0,SubSystem present Bit 1
MAS12669-ENG299103,Bus identification of sub-bus users-SubSystem Bus IDs,|Bus ID|1|,
MAS13422-IDE00013,System description of sub bus participant-System designation,HRE3_Kl15_Slv,
MAS13422-MAS01170,System description of sub bus participant-Subsystem designation,Lane change assistance control module 2,
MAS13422-ENG170217,System description of sub bus participant-Number Of Expected SubSystem Identification,1,
MAS13422-ENG170218,System description of sub bus participant-Number Of Retrieved SubSystem Identification,1,
MAS13422-ENG170221,System description of sub bus participant-SubSystem Node Address,00 3B,
MAS18838,Auto-calibration: adaptive angle correction characteristic curve (slave),0, %
MAS18839,Auto-calibration: adaptive angle correction characteristic curve,0, %
Elapsed Time: 00:10,,,
blockmap-42-5Q4-959-593-P_3VV2X7B28NM061887-20220618-1237.CSV
;SW:5Q4-959-593-P   HW:5Q4-959-593-P ---  Door Elect, Driver
;Component:TSG FS        011 0912, Coding:003E17200000028008000000
;EV_DCU2DriveSideMAXHCONT,001005,EV_DCU2DriveSideMAXHCONT_VW37.rod
;Saturday,18,June,2022,12:37:13:14741
;VCID: D2F69102546C58CBB56-8086
IDE00310,Outside temperature,30.50, °C
IDE01992-MAS12276,Installation list: current installations-Front door control module,can be reached,
IDE01992-MAS12277,Installation list: current installations-Rear door control module,not attainable,
IDE01993-MAS12276,Control module reference number-Front door control module,Driver door control module,
IDE01993-MAS12277,Control module reference number-Rear door control module,Rear Driver Side Door Control Module,
IDE02260-IDE00773,Supply voltage for door control module: rear: left-Terminal 15 status via CAN,active,
IDE02260-IDE01715,Supply voltage for door control module: rear: left-Status terminal S,active,
IDE02260-IDE05835,Supply voltage for door control module: rear: left-Supply voltage for central locking,12.20, V
IDE02262,synchronous mirror adjustment,not active,
IDE02267-IDE05835,Supply voltage for door control module: front: driver side-Supply voltage for central locking,12.60, V
IDE02384-MAS12276,Status of event memory-Front door control module,No malfunctions in DTC memory,
IDE02384-MAS12277,Status of event memory-Rear door control module,No malfunctions in DTC memory,
IDE03150-MAS12276,Readiness for bus sleep mode-Front door control module,active,
IDE03150-MAS12277,Readiness for bus sleep mode-Rear door control module,active,
IDE04215-MAS02428,Mirror adjustment switch-Switch positions,Neutral,
IDE04216-MAS01458,Mirror heater-Operating condition,not active,
IDE04216-MAS02965,Mirror heater-Performance percentage,0, %
IDE04216-MAS04247,Mirror heater-Button,Not operated,
IDE04217,Fuel filler door release button,Not operated,
IDE04218,Turn signal in exterior rear-view mirror,not active,
IDE04219-IDE02266,Window regulator control unit: driver side-Passenger side rear power window button,Not operated,
IDE04219-IDE04220,Window regulator control unit: driver side-Driver power window button,Not operated,
IDE04219-IDE06621,Window regulator control unit: driver side-Driver side rear power window button,Not operated,
IDE04219-IDE06872,Window regulator control unit: driver side-Front passenger power window button,Not operated,
IDE04220,Driver power window button,Not operated,
IDE04343-MAS03180,Bus identification-Local data bus,assigned,
IDE04343-MAS12276,Bus identification-Front door control module,Bus master,
IDE04411,Child safety button,Not operated,
IDE04539-MAS01634,Mirror memory-Supply voltage,not active,
IDE04539-MAS02228,Mirror memory-X coordinate,Not available,
IDE04539-MAS02229,Mirror memory-Y coordinate,Not available,
IDE04539-MAS02476,Mirror memory-installed,not installed,
IDE04540,Mirror adjustment (X/Y direction),Position center,
IDE04580,Dimming of inside door handle lighting,100, %
IDE04581,Dimming for interior ambient lighting,Not available,
IDE04586,Mirror fold-in activation,not installed,
IDE05071-MAS02594,Lane change assistance button-Indicator light in switch,not installed,
IDE05071-MAS07693,Lane change assistance button-Button Status,not installed,
IDE05720-IDE02589,Front driver side door status-Rotary latch status,Open,
IDE05720-IDE04213,Front driver side door status-Central locking button,Not operated,
IDE05720-IDE04214,Front driver side door status-Key switch in door lock,not installed,
IDE05725,Dimmer terminal 58xs,0, %
IDE05726,Dimmer terminal 58xd,100, %
IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch,not coded/not installed,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,not coded/not installed,
IDE06206-MAS01453,Front window regulator status: driver side-Blocking detection,not active,
IDE06206-MAS02097,Front window regulator status: driver side-Window position,0.00, %
IDE06206-MAS02098,Front window regulator status: driver side-Window regulator standardized,Yes,
IDE06206-MAS04642,Front window regulator status: driver side-Before upper stop,active,
IDE06206-MAS05370,Front window regulator status: driver side-Direction of movement,Position top,
IDE06208-MAS01453,Rear window regulator status: driver side-Blocking detection,active,
IDE06208-MAS02039,Rear window regulator status: driver side-Force limitation,not active,
IDE06208-MAS02097,Rear window regulator status: driver side-Window position,0.00, %
IDE06208-MAS02098,Rear window regulator status: driver side-Window regulator standardized,Yes,
IDE06208-MAS03548,Rear window regulator status: driver side-Motor current,Not available,
IDE06208-MAS04642,Rear window regulator status: driver side-Before upper stop,active,
IDE06208-MAS05370,Rear window regulator status: driver side-Direction of movement,Position top,
IDE06469,Ambient illumination for speaker,Not available,
IDE06614-IDE06842,Memory seat adjustment control head-Status - Button 1,not installed,
IDE06614-IDE06843,Memory seat adjustment control head-Status - Button 2,not installed,
IDE06614-IDE06844,Memory seat adjustment control head-Status - Button 3,not installed,
IDE06614-IDE06845,Memory seat adjustment control head-Status - Button 4,not installed,
IDE06621,Driver side rear power window button,Not operated,
IDE06931-MAS01159,Ident. of rear window regulator programming: driver side-Version number,4Q01,
IDE06935,Rear window regulator relay: driver side,Open,
IDE06937-MAS02545,Front window regulator reversing position: driver side-Last,127.50, %
IDE06937-MAS02546,Front window regulator reversing position: driver side-Second to last,127.50, %
IDE06937-MAS02547,Front window regulator reversing position: driver side-Third to last,127.50, %
IDE06937-MAS02548,Front window regulator reversing position: driver side-Fourth to last,127.50, %
IDE06937-MAS05380,Front window regulator reversing position: driver side-fifth to last,127.50, %
IDE06939-MAS02545,Rear window regulator reversing position: driver side-Last,53.50, %
IDE06939-MAS02546,Rear window regulator reversing position: driver side-Second to last,74.00, %
IDE06939-MAS02547,Rear window regulator reversing position: driver side-Third to last,14.00, %
IDE06939-MAS02548,Rear window regulator reversing position: driver side-Fourth to last,127.50, %
IDE06939-MAS05380,Rear window regulator reversing position: driver side-fifth to last,127.50, %
IDE06940,Rear window regulator child lock: driver side,not active,
IDE07405-MAS02447,Enable driver front window regulator relay-Release,Yes,
IDE07407-IDE03114,Enable driver-side rear window regulator-Comfort function,No,
IDE07407-MAS02447,Enable driver-side rear window regulator-Release,Yes,
IDE07409-MAS02955,Excessive temper. disconnect: front window regulator: driv.side-Engine temperature,42, °C
IDE07411-MAS01632,Excess.temp.disconnect: rear window regulator: driver side-Status,not active,
IDE07411-MAS02955,Excess.temp.disconnect: rear window regulator: driver side-Engine temperature,47, °C
IDE07415,Comfort function for rear window regulator: driver side,not active,
IDE07543,Vehicle speed,0.00, km/h
IDE08697-MAS07302,Number of driving cycles without opening door-Max. number of driving cycles without opening door,0,
IDE09335,Mirror fold-in: current consumption,Not available,
IDE10158,Window lift: switch-over from front to rear,not installed,
IDE10164-MAS01632,Automatically dimming exterior mirrors-Status,not installed,
IDE10164-MAS03691,Automatically dimming exterior mirrors-Dimming,255, %
IDE13865-MAS02099,Exterior door handle actuator-Switch for inside door handle,not installed,
IDE13865-MAS02100,Exterior door handle actuator-Switch for outside door handle,not installed,
IDE13865-MAS09598,Exterior door handle actuator-Request on CAN,Not available,
IDE13865-MAS11741,Exterior door handle actuator-CAN Status,Not available,
IDE13865-MAS17088,Exterior door handle actuator-Contact: exterior door handle retracted,not installed,
IDE13865-MAS17089,Exterior door handle actuator-Contact: exterior door handle extended,not installed,
IDE13865-MAS17090,Exterior door handle actuator-Actuator activation status,not installed,
IDE15336,Light output 1 pin D8 target brightness on front driver side,0, %
IDE15338,Light output 3 pin C1/B3 target brightness on front driver side,Not available,
IDE15339,Light output 4 pin D16 target brightness on front driver side,0, %
IDE15636,Light output 2 pin D3 target brightness on front driver side,0, %
IDE16389-MAS25781,Front ambient Lighting configuration - light output 1-Malfunction location:,Unknown (255),
IDE16390-MAS25781,Front ambient Lighting configuration - light output 2-Malfunction location:,Unknown (255),
IDE16391-MAS25781,Front ambient Lighting configuration - light output 3-Malfunction location:,Unknown (255),
IDE16392-MAS25781,Front ambient Lighting configuration - light output 4-Malfunction location:,Unknown (255),
MAS01872,Rear lid remote control lock switch,not installed,
MAS02101,Child safety lock,not active,
MAS06010,Ambient light,96, %
ENG117315-ENG163906,Window_Regulator_Driver_Side_Rear_VW_Workshop_System_Name-System_short_sign,J926 ,
blockmap-44-5QM-909-144-C_3VV2X7B28NM061887-20220618-1237.CSV
;SW:5QM-909-144-C   HW:5QM-909-144-B ---  Steering Assist
;Component:EPS_MQB_ZFLS  173 1082, Coding:951F0000
;EV_SteerAssisMQB,015157,EV_SteerAssisMQB_015.rod
;Saturday,18,June,2022,12:37:26:14741
;VCID: D1F49E0E516A23D38CC-8084
IDE00018,Voltage terminal 15,12.67, V
IDE00019,Voltage terminal 30,12.56, V
IDE00020,Terminal 15 status,Terminal 15 on,
IDE00021,Engine RPM,1422, /min
IDE00102,Control Module temperature,40.0, °C
IDE00550-IDE03737,Identification of parameterization-Index characteristic curve,04,
IDE00550-MAS01078,Identification of parameterization-Vehicle model,06,
IDE00550-MAS05566,Identification of parameterization-Version of system parameters,21,
IDE00550-MAS05567,Identification of parameterization-Version of characteristic curves,05,
IDE00550-MAS05568,Identification of parameterization-Version of memory map,A1,
IDE02006-IDE02955,Lane assist-System status,operational,
IDE02006-IDE04227,Lane assist-Directional stab. asst w/ pwr steering asst: steering status,0.000, Nm
IDE02006-MAS03095,Lane assist-Function status,activated,
IDE02006-MAS03368,Lane assist-Steering wheel vibration,not active,
IDE02202,End stage temperature,31.0, °C
IDE02216-IDE05795,Steering angle sensor: basic setting-End basic setting,Not permitted,
IDE02216-IDE06673,Steering angle sensor: basic setting-Initialization status,initialized,
IDE02216-MAS01632,Steering angle sensor: basic setting-Status,calibrated,
IDE02216-MAS03161,Steering angle sensor: basic setting-Start,Not permitted,
IDE02955,System status,Driving mode,
IDE03682-IDE04457,motor position sensor-Electric motor speed,14, /min
IDE03682-MAS02961,motor position sensor-Engine angle,109.7, °
IDE03682-MAS03083,motor position sensor-Cosine signal,1.578, V
IDE03682-MAS03211,motor position sensor-Sine signal,2.750, V
IDE03682-MAS05053,motor position sensor-Reference value,Condition met,
IDE03725-IDE03734,Steering Assistance-Support power,-100, %
IDE03725-MAS03001,Steering Assistance-Mode,automatic,
IDE03725-MAS03095,Steering Assistance-Function status,activated,
IDE03726-IDE02955,Parallel Parking Assistance-System status,not active,
IDE03726-IDE05159,Parallel Parking Assistance-Steering angle: target value,-5.3, °
IDE03726-IDE05160,Parallel Parking Assistance-Steering angle: target-actual deviation,0.0, °
IDE03726-MAS03095,Parallel Parking Assistance-Function status,not activated,
IDE03735,Steering torque,0.069, Nm
IDE03735-MAS01632,Steering torque-Status,OK,
IDE03736,Steering torque 2,0.069, Nm
IDE03736-MAS01632,Steering torque 2-Status,OK,
IDE04118-IDE05157,Straight line running correction-Long term learning condition,Condition not met,
IDE04118-IDE05158,Straight line running correction-Short term learning condition,Condition not met,
IDE04118-MAS02998,Straight line running correction-Angle value offset,-0.6, °
IDE04118-MAS03095,Straight line running correction-Function status,activated,
IDE04118-MAS03528,Straight line running correction-Long term adaptation value,-0.6, °
IDE04118-MAS03529,Straight line running correction-Short term adaptation value,0.0, °
IDE04119-MAS03738,Active default-Restoring force: setpoint,0, N
IDE04183,Steering assistance: target engine torque,0.006, Nm
IDE04184,Steering assistance: engine output,100.000, %
IDE04185,Terminal 30 voltage filtered,12.64, V
IDE04187,Steering torque: raw value 1,-48.535, %
IDE04187-MAS01632,Steering torque: raw value 1-Status,OK,
IDE04188,Steering torque: raw value 2,-68.164, %
IDE04188-MAS01632,Steering torque: raw value 2-Status,OK,
IDE04189,Steering torque: raw value 3,-48.535, %
IDE04189-MAS01632,Steering torque: raw value 3-Status,OK,
IDE04190,Steering torque: raw value 4,-68.164, %
IDE04190-MAS01632,Steering torque: raw value 4-Status,OK,
IDE04191-MAS03084,Steering assistance: PWM signal for motor-Phase 1,2.38, %
IDE04191-MAS03085,Steering assistance: PWM signal for motor-Phase 2,2.40, %
IDE04191-MAS03086,Steering assistance: PWM signal for motor-Phase 3,2.40, %
IDE04192-MAS03084,Steering assistance: motor current-Phase 1,-0.1, A
IDE04192-MAS03085,Steering assistance: motor current-Phase 2,0.3, A
IDE04192-MAS03086,Steering assistance: motor current-Phase 3,-0.1, A
IDE04194,Steering assistance: electromotor power,-0.79, W
IDE04448-IDE00924,Steering angle sensor: angle-Steering angle,-4.2, °
IDE04448-MAS01632,Steering angle sensor: angle-Status,valid,
IDE04454-MAS01632,Steering angle sensor: angle speed-Status,valid,
IDE04454-MAS02984,Steering angle sensor: angle speed-Steering angle speed,0.6, °
IDE04458-MAS02996,Steering angle sensor: mechanical steering stroke-Steering stroke measured,160.99, mm
IDE04458-MAS03731,Steering angle sensor: mechanical steering stroke-Mechanical center position determined,Yes,
IDE04459,Steering angle sensor: offset index mark mechanical middle,0.01, mm
IDE04460,Steering angle sensor: offset straight line running,-0.2, °
IDE04510-MAS03732,Steering angle sensor: slope detection index-Steering angle speed negative dropping slope on curve,not detected,
IDE04510-MAS03733,Steering angle sensor: slope detection index-Steering angle speed negative rising slope on curve,not detected,
IDE04510-MAS03734,Steering angle sensor: slope detection index-Steering angle speed positive dropping slope on curve,not detected,
IDE04510-MAS03735,Steering angle sensor: slope detection index-Steering angle speed positive rising slope on curve,not detected,
IDE04510-MAS03736,Steering angle sensor: slope detection index-Index mark,1,
IDE04511,Steering angle sensor external via CAN: angle,Measuring value not available,
IDE04512,Steering angle sensor external via CAN: angular velocity,Measuring value not available,
IDE04513,Steering angle sensor external via CAN: status,not active,
IDE04514,Steering angle sensor external via CAN: basic setting,Calibration not possible,
IDE04765-IDE02955,Counter steer support-System status,operational,
IDE04765-MAS03095,Counter steer support-Function status,activated,
IDE04765-MAS03739,Counter steer support-Steering torque request: brake electronics,0.000, Nm
IDE04766-IDE04116,Replacement values-Vehicle speed replacement value,No,
IDE04766-MAS00371,Replacement values-Engine RPM,No,
IDE04787,Hybrid status,not active,
IDE04805-IDE02955,Driving profile selection-System status,operational,
IDE04805-MAS01447,Driving profile selection-Act.val.,3,
IDE04805-MAS01448,Driving profile selection-Target value,3,
IDE04805-MAS05058,Driving profile selection-Compatibility,Yes,
IDE05155,Power steering current consumption,-0.06, A
IDE05162-IDE03723,Software end stop-End stops for steering,Adapted,
IDE05162-MAS01849,Software end stop-Left,80.50, mm
IDE05162-MAS01850,Software end stop-Right,-80.48, mm
IDE05162-MAS03095,Software end stop-Function status,active,
IDE05713-IDE01864,Network diagnosis-Status of current bus communication,active,
IDE05713-MAS00102,Network diagnosis-valid,Yes,
IDE05713-MAS02447,Network diagnosis-Release,Yes,
IDE05993-ENG120753,Steering wheel angle load-0_to_50_degrees,2343,
IDE05993-ENG120755,Steering wheel angle load-100_to_150_degrees,0,
IDE05993-ENG120751,Steering wheel angle load--100_to_-50_degrees,0,
IDE05993-ENG120750,Steering wheel angle load--150_to_-100_degrees,0,
IDE05993-ENG120756,Steering wheel angle load-150_to_200_degrees,0,
IDE05993-ENG120749,Steering wheel angle load--200_to_-150_degrees,0,
IDE05993-ENG120757,Steering wheel angle load-200_to_250_degrees,0,
IDE05993-ENG120748,Steering wheel angle load--250_to_-200_degrees,0,
IDE05993-ENG120758,Steering wheel angle load-250_to_300_degrees,0,
IDE05993-ENG120747,Steering wheel angle load--300_to_-250_degrees,0,
IDE05993-ENG120759,Steering wheel angle load-300_to_350_degrees,0,
IDE05993-ENG120746,Steering wheel angle load--350_to_-300_degrees,0,
IDE05993-ENG120760,Steering wheel angle load-350_to_400_degrees,0,
IDE05993-ENG120745,Steering wheel angle load--400_to_-350_degrees,0,
IDE05993-ENG120761,Steering wheel angle load-400_to_450_degrees,0,
IDE05993-ENG120744,Steering wheel angle load--450_to_-400_degrees,0,
IDE05993-ENG120762,Steering wheel angle load-450_to_500_degrees,0,
IDE05993-ENG120752,Steering wheel angle load--50_to_0_degrees,2372,
IDE05993-ENG120754,Steering wheel angle load-50_to_100_degrees,0,
IDE05993-ENG120743,Steering wheel angle load--500_to_-450_degrees,0,
IDE05993-ENG120763,Steering wheel angle load-500_to_550_degrees,0,
IDE05993-ENG120742,Steering wheel angle load--550_to_500_degrees,0,
IDE05993-ENG120764,Steering wheel angle load-above_550_degrees,0,
IDE05993-ENG120741,Steering wheel angle load-below_-550_degrees,0,
IDE05994-ENG120729,Engine specified torque load-0_to_1_kilo_newton,0,
IDE05994-ENG120728,Engine specified torque load--1_to_0_kilo_newton,0,
IDE05994-ENG120730,Engine specified torque load-1_to_2_kilo_newton,0,
IDE05994-ENG139218,Engine specified torque load-10_to_11_kilo_newton,0,
IDE05994-ENG120719,Engine specified torque load--10_to_-9_kilo_newton,0,
IDE05994-ENG139219,Engine specified torque load--11_to_-10_kilo_newton,0,
IDE05994-ENG120727,Engine specified torque load--2_to_-1_kilo_newton,0,
IDE05994-ENG120731,Engine specified torque load-2_to_3_kilo_newton,0,
IDE05994-ENG120726,Engine specified torque load--3_to_-2_kilo_newton,0,
IDE05994-ENG120732,Engine specified torque load-3_to_4_kilo_newton,0,
IDE05994-ENG120725,Engine specified torque load--4_to_-3_kilo_newton,0,
IDE05994-ENG120733,Engine specified torque load-4_to_5_kilo_newton,0,
IDE05994-ENG120724,Engine specified torque load--5_to_-4_kilo_newton,0,
IDE05994-ENG120734,Engine specified torque load-5_to_6_kilo_newton,0,
IDE05994-ENG120723,Engine specified torque load--6_to_-5_kilo_newton,0,
IDE05994-ENG120735,Engine specified torque load-6_to_7_kilo_newton,0,
IDE05994-ENG120722,Engine specified torque load--7_to_-6_kilo_newton,0,
IDE05994-ENG120736,Engine specified torque load-7_to_8_kilo_newton,0,
IDE05994-ENG120721,Engine specified torque load--8_to_-7_kilo_newton,0,
IDE05994-ENG120737,Engine specified torque load-8_to_9_kilo_newton,0,
IDE05994-ENG120738,Engine specified torque load-9_to_10_kilo_newton,0,
IDE05994-ENG120720,Engine specified torque load--9_to_-8_kilo_newton,0,
IDE05994-ENG161314,Engine specified torque load-above_11_kilo_newton,462,
IDE05994-ENG161479,Engine specified torque load-below_-11_kilo_newton,462,
IDE05995-ENG120703,ECU temperature load-0_to_10_degrees_celsius,0,
IDE05995-ENG120702,ECU temperature load--10_to_0_degrees_celsius,42034,
IDE05995-ENG120704,ECU temperature load-10_to_20_degrees_celsius,0,
IDE05995-ENG120713,ECU temperature load-100_to_110_degrees_celsius,0,
IDE05995-ENG120714,ECU temperature load-110_to_120_degrees_celsius,0,
IDE05995-ENG120701,ECU temperature load--20_to_-10_degrees_celsius,0,
IDE05995-ENG120705,ECU temperature load-20_to_30_degrees_celsius,0,
IDE05995-ENG120700,ECU temperature load--30_to_-20_degrees_celsius,0,
IDE05995-ENG120706,ECU temperature load-30_to_40_degrees_celsius,0,
IDE05995-ENG120699,ECU temperature load--40_to_-30_degrees_celsius,0,
IDE05995-ENG120707,ECU temperature load-40_to_50_degrees_celsius,0,
IDE05995-ENG120708,ECU temperature load-50_to_60_degrees_celsius,0,
IDE05995-ENG120709,ECU temperature load-60_to_70_degrees_celsius,0,
IDE05995-ENG120710,ECU temperature load-70_to_80_degrees_celsius,0,
IDE05995-ENG120711,ECU temperature load-80_to_90_degrees_celsius,0,
IDE05995-ENG120712,ECU temperature load-90_to_100_degrees_celsius,0,
IDE05995-ENG120715,ECU temperature load-above_120_degrees_celsius,0,
IDE05995-ENG120698,ECU temperature load-below_-40_degrees_celsius,0,
IDE05996-ENG120766,Steering wheel angle speed load-360_to_600_degrees_per_second,2,
IDE05996-ENG120765,Steering wheel angle speed load-50_to_360_degrees_per_second,4,
IDE05996-ENG120767,Steering wheel angle speed load-600_to_800_degrees_per_second,5,
IDE05996-ENG120768,Steering wheel angle speed load-above_800_degrees_per_second,318,
IDE06678-IDE03458,Pull compensation-Steering torque offset,0.000, Nm
IDE06678-MAS03000,Pull compensation-Adaptation value,0.041, Nm
IDE06678-MAS03095,Pull compensation-Function status,activated,
IDE07399,Engine type,0,
IDE07400-MAS03084,Phase disconnect: status-Phase 1,closed,
IDE07400-MAS03085,Phase disconnect: status-Phase 2,closed,
IDE07400-MAS03086,Phase disconnect: status-Phase 3,closed,
IDE07542-MAS00370,Prerequisites: basic setting-Vehicle speed,Condition met,
IDE07542-MAS01468,Prerequisites: basic setting-Terminal 15,Condition met,
IDE07542-MAS01634,Prerequisites: basic setting-Supply voltage,Condition met,
IDE07542-MAS01746,Prerequisites: basic setting-Control active,Condition met,
IDE07542-MAS02980,Prerequisites: basic setting-Manual steering torque,Condition met,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,37,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,8,
MAS00976-IDE80003,Counter-Analysis 3,1346715695,
MAS00976-IDE80004,Counter-Analysis 4,90864,
MAS01172-MAS01156,Development messages-Communication status,active,
MAS01172-MAS03095,Development messages-Function status,not active,
MAS02126-MAS01632,Steering angle sensor: status-Status,active,
MAS02126-MAS02247,Steering angle sensor: status-CAN message,valid,
ENG120769-MAS00973,identification_add-on_parts_steering_assistance-Construction version,Series,
ENG120769-ENG120622,identification_add-on_parts_steering_assistance-moment_sensor,magnetoresistiv,
ENG120769-ENG120621,identification_add-on_parts_steering_assistance-system_supplier,ZFO,
ENG168891-ENG169036,Strain_detection-Calculated_worm_gear_temperature,40.0, °C
ENG168891-ENG169118,Strain_detection-High_count_worm_gear_alt,90864,
ENG168891-ENG169133,Strain_detection-KlimaSensor02_alt,0,
ENG168891-ENG169169,Strain_detection-Low_count_worm_gear_alt,1346715695,
ENG168891-ENG169177,Strain_detection-Mileage_counter,0, km
ENG168891-ENG169189,Strain_detection-OBD_FStatus_ATemp,kein Fehler/Init/nicht verbaut,
ENG168891-ENG102605,Strain_detection-outside_temperature,30.5, °C
ENG168891-ENG168990,Strain_detection-revolutions_per_minute_electric_motor,-1, /min
ENG168891-ENG157280,Strain_detection-Steering_angle,-4.2, °
ENG168891-ENG168991,Strain_detection-steering_moment,0.069, Nm
ENG168891-ENG168992,Strain_detection-Steering_Support_Engine_Commanded_Torque,0.007, Nm
ENG168891-ENG169223,Strain_detection-Strain_detection_per_cent,0.0000006824, %
Elapsed Time: 00:08,,,
blockmap-47-2G0-035-456_3VV2X7B28NM061887-20220618-1237.CSV
;SW:2G0-035-456   HW:2G0-035-456 ---  Sound System
;Component:AMPeth8C      H04 3131, Coding:22000000000000000000000000000000000000000000000000
;EV_AMPEthMQB,001005,EV_AMPEthMQB_VW27.rod
;Saturday,18,June,2022,12:37:38:14741
;VCID: E0924BCA2AC0BA5B332-80B4
IDE00019,Voltage terminal 30,12.50, V
IDE00020,Terminal 15 status,On,
IDE00021,Engine RPM,1394.50, /min
IDE00767,No. of unscheduled ECU resets,0,
IDE00916-ENG249445,Speaker status-loudspeaker_config_channel_1,Left rear speaker,
IDE00916-ENG249480,Speaker status-loudspeaker_config_channel_10,Not available,
IDE00916-ENG249518,Speaker status-loudspeaker_config_channel_11,Not available,
IDE00916-ENG249486,Speaker status-loudspeaker_config_channel_12,Not available,
IDE00916-ENG249341,Speaker status-loudspeaker_config_channel_13,Not available,
IDE00916-ENG249407,Speaker status-loudspeaker_config_channel_14,Not available,
IDE00916-ENG249456,Speaker status-loudspeaker_config_channel_15,Not available,
IDE00916-ENG249515,Speaker status-loudspeaker_config_channel_16,Not available,
IDE00916-ENG249507,Speaker status-loudspeaker_config_channel_17,Not available,
IDE00916-ENG249452,Speaker status-loudspeaker_config_channel_18,Not available,
IDE00916-ENG249466,Speaker status-loudspeaker_config_channel_19,Not available,
IDE00916-ENG249455,Speaker status-loudspeaker_config_channel_2,Right rear speaker,
IDE00916-ENG249434,Speaker status-loudspeaker_config_channel_20,Not available,
IDE00916-ENG249416,Speaker status-loudspeaker_config_channel_21,Not available,
IDE00916-ENG249527,Speaker status-loudspeaker_config_channel_22,Not available,
IDE00916-ENG249489,Speaker status-loudspeaker_config_channel_23,Not available,
IDE00916-ENG249520,Speaker status-loudspeaker_config_channel_24,Not available,
IDE00916-ENG249288,Speaker status-loudspeaker_config_channel_3,Double subwoofer speaker 1,
IDE00916-ENG249509,Speaker status-loudspeaker_config_channel_4,Double subwoofer speaker 2,
IDE00916-ENG249362,Speaker status-loudspeaker_config_channel_5,Left front bass speaker,
IDE00916-ENG249491,Speaker status-loudspeaker_config_channel_6,Right front bass speaker,
IDE00916-ENG249410,Speaker status-loudspeaker_config_channel_7,Left front treble speaker,
IDE00916-ENG249340,Speaker status-loudspeaker_config_channel_8,Right front treble speaker,
IDE00916-ENG249470,Speaker status-loudspeaker_config_channel_9,Not available,
IDE00916-ENG249411,Speaker status-loudspeaker_state_channel_1,Measuring value not available,
IDE00916-ENG249429,Speaker status-loudspeaker_state_channel_10,Measuring value not available,
IDE00916-ENG249464,Speaker status-loudspeaker_state_channel_11,Measuring value not available,
IDE00916-ENG249451,Speaker status-loudspeaker_state_channel_12,Measuring value not available,
IDE00916-ENG249436,Speaker status-loudspeaker_state_channel_13,Measuring value not available,
IDE00916-ENG249447,Speaker status-loudspeaker_state_channel_14,Measuring value not available,
IDE00916-ENG249426,Speaker status-loudspeaker_state_channel_15,Measuring value not available,
IDE00916-ENG249317,Speaker status-loudspeaker_state_channel_16,Measuring value not available,
IDE00916-ENG249528,Speaker status-loudspeaker_state_channel_17,Measuring value not available,
IDE00916-ENG249492,Speaker status-loudspeaker_state_channel_18,Measuring value not available,
IDE00916-ENG249409,Speaker status-loudspeaker_state_channel_19,Measuring value not available,
IDE00916-ENG249305,Speaker status-loudspeaker_state_channel_2,Measuring value not available,
IDE00916-ENG249435,Speaker status-loudspeaker_state_channel_20,Measuring value not available,
IDE00916-ENG249417,Speaker status-loudspeaker_state_channel_21,Measuring value not available,
IDE00916-ENG249404,Speaker status-loudspeaker_state_channel_22,Measuring value not available,
IDE00916-ENG249319,Speaker status-loudspeaker_state_channel_23,Measuring value not available,
IDE00916-ENG249408,Speaker status-loudspeaker_state_channel_24,Measuring value not available,
IDE00916-ENG249290,Speaker status-loudspeaker_state_channel_3,Measuring value not available,
IDE00916-ENG249312,Speaker status-loudspeaker_state_channel_4,Measuring value not available,
IDE00916-ENG249303,Speaker status-loudspeaker_state_channel_5,Measuring value not available,
IDE00916-ENG249399,Speaker status-loudspeaker_state_channel_6,Measuring value not available,
IDE00916-ENG249508,Speaker status-loudspeaker_state_channel_7,Measuring value not available,
IDE00916-ENG249335,Speaker status-loudspeaker_state_channel_8,Measuring value not available,
IDE00916-ENG249382,Speaker status-loudspeaker_state_channel_9,Measuring value not available,
IDE01285-ENG101364,Counter of component protection malfunctions-Theft Protection Error Counter,0,
IDE01351,Terminal 75 status,not detected,
IDE01716,Terminal 50 status,OFF,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,3F B2 FF 82,
IDE02475-MAS01167,Acoustic check of loudspeakers-Actuation time,0 seconds,
IDE02475-ENG170421,Acoustic check of loudspeakers-IoReached Status,Output diagnostic test not active,
IDE02476-MAS01167,Electrical test of speakers-Actuation time,0 seconds,
IDE02476-ENG170421,Electrical test of speakers-IoReached Status,Output diagnostic test not active,
IDE04640,Over-temperature protection for amplifier,0,
IDE05713-MAS01632,Network diagnosis-Status,Enabled,
IDE06517-MAS01424,Temperature: audio amplifier-max.value,36, °C
IDE06517-MAS01425,Temperature: audio amplifier-min.value,28, °C
IDE06517-MAS02238,Temperature: audio amplifier-Up-to-date,35, °C
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,05,
IDE07145-MAS06785,Component protection properties-GFA key,Not Used,
IDE08343,Immobilizer Challenge,B5 1A E1 E6,
IDE10300,OBD Driving Cycle detected,not active,
IDE10779,Ethernet signal quality,good: link available,
IDE10780,Ethernet counter connection interruptions,0,
IDE10781,Ethernet counter checksum malfunction,0,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 6F|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 2D|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 02|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 05|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|3|,
IDE11756,IP network: counter messages with inadmissible VLANs,0,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,0,
IDE11759,IP network: counter messages with inadmissible TCP ports,0,
IDE11760,IP network: counter messages with inadmissible UDP ports,0,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|00 13 43 D1 92 DA|,
IDE11869,IP network: NDP cache,|MAC address,IPv6 address
IDE12238,I network: discarded messages counter,0,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE12633,IP Network maximum correction of the synchronized clock,0, ns
IDE13344-MAS01167,Acoustic check of loudspeakers: sequential analysis-Actuation time,0 seconds,
IDE13344-ENG170421,Acoustic check of loudspeakers: sequential analysis-IoReached Status,Output diagnostic test not active,
ENG117872-ENG117778,Byte_Coding_Condition-byte_0_condition,dont care,
ENG117872-ENG117779,Byte_Coding_Condition-byte_1_condition,dont care,
ENG117872-ENG117788,Byte_Coding_Condition-byte_10_condition,dont care,
ENG117872-ENG117789,Byte_Coding_Condition-byte_11_condition,dont care,
ENG117872-ENG117790,Byte_Coding_Condition-byte_12_condition,dont care,
ENG117872-ENG117791,Byte_Coding_Condition-byte_13_condition,dont care,
ENG117872-ENG117792,Byte_Coding_Condition-byte_14_condition,dont care,
ENG117872-ENG117793,Byte_Coding_Condition-byte_15_condition,dont care,
ENG117872-ENG117794,Byte_Coding_Condition-byte_16_condition,dont care,
ENG117872-ENG117795,Byte_Coding_Condition-byte_17_condition,dont care,
ENG117872-ENG117796,Byte_Coding_Condition-byte_18_condition,dont care,
ENG117872-ENG117797,Byte_Coding_Condition-byte_19_condition,dont care,
ENG117872-ENG117780,Byte_Coding_Condition-byte_2_condition,dont care,
ENG117872-ENG117798,Byte_Coding_Condition-byte_20_condition,dont care,
ENG117872-ENG117799,Byte_Coding_Condition-byte_21_condition,dont care,
ENG117872-ENG117800,Byte_Coding_Condition-byte_22_condition,dont care,
ENG117872-ENG117801,Byte_Coding_Condition-byte_23_condition,dont care,
ENG117872-ENG117802,Byte_Coding_Condition-byte_24_condition,dont care,
ENG117872-ENG117803,Byte_Coding_Condition-byte_25_condition,dont care,
ENG117872-ENG117804,Byte_Coding_Condition-byte_26_condition,dont care,
ENG117872-ENG117805,Byte_Coding_Condition-byte_27_condition,dont care,
ENG117872-ENG117781,Byte_Coding_Condition-byte_3_condition,dont care,
ENG117872-ENG117782,Byte_Coding_Condition-byte_4_condition,dont care,
ENG117872-ENG117783,Byte_Coding_Condition-byte_5_condition,dont care,
ENG117872-ENG117784,Byte_Coding_Condition-byte_6_condition,dont care,
ENG117872-ENG117785,Byte_Coding_Condition-byte_7_condition,dont care,
ENG117872-ENG117786,Byte_Coding_Condition-byte_8_condition,dont care,
ENG117872-ENG117787,Byte_Coding_Condition-byte_9_condition,dont care,
ENG249154-MAS18871,Loudspeaker_Test_acoustic_extended_actual_loudspeaker-Current channel,OFF,
ENG249154-MAS18921,Loudspeaker_Test_acoustic_extended_actual_loudspeaker-Current loudspeaker,Not available,
blockmap-4B-3Q0-907-338-E_3VV2X7B28NM061887-20220618-1237.CSV
;SW:3Q0-907-338-E   HW:3Q0-907-338-E ---  Multifunc. Module
;Component:FCM MQB Low   003 0367, Coding:0000000709000B5202110301000000000000000000000000000000000000
;EV_MultiModulContiVW48X,003003,EV_MultiModulContiVW48X_003.rod
;Saturday,18,June,2022,12:37:50:14741
;VCID: B720C096DFCE9DE3A28-80E2
IDE00019,Voltage terminal 30,12.6, V
IDE00075,Vehicle speed,0.0, km/h
IDE00326,Steering wheel angle,-4.20, °
IDE00767-MAS03945,No. of unscheduled ECU resets-Watchdog Reset,0,
IDE01714,Status reverse gear,OFF,
IDE01717-ENG161283,Processor load-Software_component_AFS_MXB,9, %
IDE01717-ENG161295,Processor load-Total_system_FCM,25, %
IDE01943,Turn signal lamp,Not operated,
IDE01946,ESP intervention,not active,
IDE02389,Ambient brightness,6126, lx
IDE02515,Low beam,OFF,
IDE02743,High Beam,OFF,
IDE03214,Engine stop using start-stop function,OFF,
IDE03215,Engine start using start-stop function,OFF,
IDE03602,Left front level control system sensor,30.40, %
IDE03604,Left rear level control system sensor,50.00, %
IDE03616,Motor status,On,
IDE03620,Front jounce travel,-10.2, mm
IDE03621,Rear jounce travel,-19.3, mm
IDE03622,Left headlight beam adjusting motor: status,No malfunction,
IDE03623,Right headlight beam adjusting motor: status,No malfunction,
IDE03624,Left dynamic AFS light motor: specified value,0.000000, °
IDE03625,Right dynamic AFS light motor: specified value,0.000000, °
IDE03626,Left dynamic AFS light motor: status,No malfunction,
IDE03627,Right dynamic AFS light motor: status,No malfunction,
IDE03628,Adjusting motor for variable left front lighting: status,No malfunction,
IDE03629,Adjusting motor for variable right front lighting: status,No malfunction,
IDE03630,Left headlight beam adjusting motor: specified value,-34.0, mm
IDE03631,Right headlight beam adjusting motor: specified value,-34.0, mm
IDE03632,Left-/right hand driving switch-over,OFF,
IDE03638-IDE03717,Stationary cornering lamp-Dim static left AFS light,101.6, %
IDE03638-IDE03718,Stationary cornering lamp-Dim static right AFS light,101.6, %
IDE03640,Dynamic AFS light,On,
IDE03669,Status of light distribution,not activated,
IDE03727,Variable left front lighting specified position,204.70, %
IDE03728,Variable right front lighting specified position,204.70, %
IDE03788,Status of basic headlamp setting,no request,
IDE03850,Left front level ctrl sys sensor: adapt. value (zero pos),33.60, %
IDE03866,Left rear level ctrl sys sensor: adaptation value (zero pos),54.40, %
IDE04805-IDE02955,Driving profile selection-System status,Not available,
IDE04805-MAS01447,Driving profile selection-Act.val.,0,
IDE04805-MAS05058,Driving profile selection-Compatibility,No,
IDE07245-MAS01447,Left rear seat backrest fan 1: activation-Act.val.,not coded/not installed,
IDE07245-MAS01448,Left rear seat backrest fan 1: activation-Target value,not coded/not installed,
IDE07247-MAS01447,Left rear seat cushion fan 1: activation-Act.val.,not coded/not installed,
IDE07247-MAS01448,Left rear seat cushion fan 1: activation-Target value,not coded/not installed,
IDE07249-MAS01447,Right rear seat backrest fan 1: activation-Act.val.,not coded/not installed,
IDE07249-MAS01448,Right rear seat backrest fan 1: activation-Target value,not coded/not installed,
IDE07251-MAS01447,Right rear seat cushion fan 1: activation-Act.val.,not coded/not installed,
IDE07251-MAS01448,Right rear seat cushion fan 1: activation-Target value,not coded/not installed,
IDE07253-IDE11719,Installation info: rear seat ventilation-Fan 1 for left rear seat backrest,not installed,
IDE07253-IDE11720,Installation info: rear seat ventilation-Fan 1 for left rear seat cushion,not installed,
IDE07253-IDE11721,Installation info: rear seat ventilation-Fan 1 for right rear seat backrest,not installed,
IDE07253-IDE11722,Installation info: rear seat ventilation-Fan 1 for right rear seat cushion,not installed,
IDE08447,Driving axis angle,-120.0, '
IDE08516-IDE02743,LED headlights: light distribution requirement-High Beam,not requested,
IDE08516-IDE06864,LED headlights: light distribution requirement-Daytime running lamps,not requested,
IDE08516-MAS02922,LED headlights: light distribution requirement-City light,not requested,
IDE08516-MAS02923,LED headlights: light distribution requirement-Highway light,not requested,
IDE08516-MAS02931,LED headlights: light distribution requirement-Rural highway light,not requested,
IDE08516-MAS02946,LED headlights: light distribution requirement-static AFS light,not requested,
IDE08516-MAS07013,LED headlights: light distribution requirement-All-weather light,not requested,
IDE08516-MAS07014,LED headlights: light distribution requirement-Tourist light,not requested,
IDE08516-MAS07015,LED headlights: light distribution requirement-Running light,not requested,
IDE08516-MAS07234,LED headlights: light distribution requirement-Eco mode 1,both sides,
IDE08516-MAS07235,LED headlights: light distribution requirement-Eco mode 2,not requested,
IDE08706-MAS17323,Actual angle of ref. segments-Horizontal angle reference segment left: in angular minutes,-500.0, '
IDE08706-MAS17324,Actual angle of ref. segments-Horizontal angle reference segment left: in degrees,-10.00, °
IDE08706-MAS17325,Actual angle of ref. segments-Horizontal angle reference segment left: as a percentage,-15.00, %
IDE08706-MAS17326,Actual angle of ref. segments-Horizontal angle reference segment right: in angular minutes,-500.0, '
IDE08706-MAS17327,Actual angle of ref. segments-Horizontal angle reference segment right: in degrees,-10.00, °
IDE08706-MAS17328,Actual angle of ref. segments-Horizontal angle reference segment right: as a percentage,-15.00, %
IDE08706-MAS17329,Actual angle of ref. segments-Vertical angle reference segment left: in angular minutes,-120.0, '
IDE08706-MAS17330,Actual angle of ref. segments-Vertical angle reference segment left: in degrees,-10.00, °
IDE08706-MAS17331,Actual angle of ref. segments-Vertical angle reference segment left: as a percentage,-15.00, %
IDE08706-MAS17332,Actual angle of ref. segments-Vertical angle reference segment right: in angular minutes,-120.0, '
IDE08713-MAS17335,Matrix light: calculated offset values-Horizontal offset: left headlight in angular minutes,-300.0, '
IDE08713-MAS17336,Matrix light: calculated offset values-Horizontal offset: left headlight in degrees,-5.00, °
IDE08713-MAS17337,Matrix light: calculated offset values-Horizontal: left headlight as a percentage,-9.00, %
IDE08713-MAS17338,Matrix light: calculated offset values-Horizontal offset: right headlight in angular minutes,-300.0, '
IDE08713-MAS17339,Matrix light: calculated offset values-Horizontal offset: right headlight in degrees,-5.00, °
IDE08713-MAS17340,Matrix light: calculated offset values-Horizontal offset: right headlight as a percentage,-9.00, %
IDE08713-MAS17341,Matrix light: calculated offset values-Vertical offset: left headlight in angular minutes,-300.0, '
IDE08713-MAS17342,Matrix light: calculated offset values-Vertical offset: left headlight in degrees,-5.00, °
IDE08713-MAS17343,Matrix light: calculated offset values-Vertical offset: left headlight as a percentage,-9.00, %
IDE08713-MAS17344,Matrix light: calculated offset values-Vertical offset: right headlight in angular minutes,-300.0, '
IDE08713-MAS17345,Matrix light: calculated offset values-Vertical offset: right headlight in degrees,-5.00, °
IDE08713-MAS17346,Matrix light: calculated offset values-Vertical offset: right headlight as a percentage,-9.00, %
IDE08714-MAS06929,Axle offsets-Axle offset front,-400.0, mm
IDE08714-MAS06930,Axle offsets-Axle offset rear,-400.0, mm
IDE08715,Func. status matrix high beam,not active,
MAS16427-MAS17003,Online data acquisition configuration-Locking time for change of condition,1.0, s
MAS16427-MAS19090,Online data acquisition configuration-Configuration version,FF FF FF FE,
MAS16428-MAS00106,Online data acquisition and analysis-Year,2000,
MAS16428-MAS00107,Online data acquisition and analysis-Month,0,
MAS16428-MAS00108,Online data acquisition and analysis-Day,0,
MAS16428-MAS00109,Online data acquisition and analysis-Hours,0,
MAS16428-MAS00110,Online data acquisition and analysis-Minutes,0,
MAS16428-MAS00111,Online data acquisition and analysis-Seconds,0,
MAS16428-MAS16995,Online data acquisition and analysis-Downloads data set number,0,
MAS16428-MAS19089,Online data acquisition and analysis-Emergency Call Module recognition and communication unit or navigation,Navigation,
MAS16431-MAS16982,Online data acquisition warning overview-Type of 1st WARNING,24,
MAS16431-MAS16983,Online data acquisition warning overview-Type of 2nd WARNING,27,
MAS16431-MAS16984,Online data acquisition warning overview-Type of 3rd WARNING,31,
MAS16431-MAS16985,Online data acquisition warning overview-Type of fourth WARNING,15,
MAS16431-MAS16986,Online data acquisition warning overview-Type of fifth WARNING,0,
MAS16431-MAS16987,Online data acquisition warning overview-Type of sixth WARNING,0,
MAS16431-MAS16988,Online data acquisition warning overview-Type of seventh WARNING,0,
MAS16432-MAS00106,Online data acquisition: warning 1-Year,2000,
MAS16432-MAS00106,Online data acquisition: warning 1-Year,2022,
MAS16432-MAS00107,Online data acquisition: warning 1-Month,6,
MAS16432-MAS00107,Online data acquisition: warning 1-Month,0,
MAS16432-MAS00108,Online data acquisition: warning 1-Day,19,
MAS16432-MAS00108,Online data acquisition: warning 1-Day,0,
MAS16432-MAS00109,Online data acquisition: warning 1-Hours,0,
MAS16432-MAS00110,Online data acquisition: warning 1-Minutes,26,
MAS16432-MAS00110,Online data acquisition: warning 1-Minutes,0,
MAS16432-MAS00111,Online data acquisition: warning 1-Seconds,50,
MAS16432-MAS00111,Online data acquisition: warning 1-Seconds,0,
MAS16432-MAS16989,Online data acquisition: warning 1-Index of the warning,2,
MAS16432-MAS16990,Online data acquisition: warning 1-Number of warnings,124,
MAS16433-MAS00106,Online data acquisition: warning 2-Year,2000,
MAS16433-MAS00106,Online data acquisition: warning 2-Year,2022,
MAS16433-MAS00107,Online data acquisition: warning 2-Month,6,
MAS16433-MAS00107,Online data acquisition: warning 2-Month,0,
MAS16433-MAS00108,Online data acquisition: warning 2-Day,19,
MAS16433-MAS00108,Online data acquisition: warning 2-Day,0,
MAS16433-MAS00109,Online data acquisition: warning 2-Hours,0,
MAS16433-MAS00110,Online data acquisition: warning 2-Minutes,0,
MAS16433-MAS00110,Online data acquisition: warning 2-Minutes,26,
MAS16433-MAS00111,Online data acquisition: warning 2-Seconds,50,
MAS16433-MAS00111,Online data acquisition: warning 2-Seconds,0,
MAS16433-MAS16989,Online data acquisition: warning 2-Index of the warning,2,
MAS16433-MAS16990,Online data acquisition: warning 2-Number of warnings,124,
MAS16434-MAS00106,Online data acquisition: warning 3-Year,2000,
MAS16434-MAS00106,Online data acquisition: warning 3-Year,2022,
MAS16434-MAS00107,Online data acquisition: warning 3-Month,6,
MAS16434-MAS00107,Online data acquisition: warning 3-Month,0,
MAS16434-MAS00108,Online data acquisition: warning 3-Day,19,
MAS16434-MAS00108,Online data acquisition: warning 3-Day,0,
MAS16434-MAS00109,Online data acquisition: warning 3-Hours,0,
MAS16434-MAS00110,Online data acquisition: warning 3-Minutes,0,
MAS16434-MAS00110,Online data acquisition: warning 3-Minutes,26,
MAS16434-MAS00111,Online data acquisition: warning 3-Seconds,0,
MAS16434-MAS00111,Online data acquisition: warning 3-Seconds,50,
MAS16434-MAS16989,Online data acquisition: warning 3-Index of the warning,2,
MAS16434-MAS16990,Online data acquisition: warning 3-Number of warnings,124,
MAS16435-MAS00106,Online data acquisition: warning 4-Year,2011,
MAS16435-MAS00107,Online data acquisition: warning 4-Month,1,
MAS16435-MAS00108,Online data acquisition: warning 4-Day,1,
MAS16435-MAS00109,Online data acquisition: warning 4-Hours,0,
MAS16435-MAS00110,Online data acquisition: warning 4-Minutes,0,
MAS16435-MAS00111,Online data acquisition: warning 4-Seconds,4,
MAS16435-MAS00111,Online data acquisition: warning 4-Seconds,26,
MAS16435-MAS16989,Online data acquisition: warning 4-Index of the warning,3,
MAS16435-MAS16990,Online data acquisition: warning 4-Number of warnings,1,
MAS16436-MAS00106,Online data acquisition: warning 5-Year,2000,
MAS16436-MAS00107,Online data acquisition: warning 5-Month,0,
MAS16436-MAS00108,Online data acquisition: warning 5-Day,0,
MAS16436-MAS00109,Online data acquisition: warning 5-Hours,0,
MAS16436-MAS00110,Online data acquisition: warning 5-Minutes,0,
MAS16436-MAS00111,Online data acquisition: warning 5-Seconds,0,
MAS16436-MAS16989,Online data acquisition: warning 5-Index of the warning,0,
MAS16436-MAS16990,Online data acquisition: warning 5-Number of warnings,0,
MAS16437-MAS00106,Online data acquisition: warning 6-Year,2000,
MAS16437-MAS00107,Online data acquisition: warning 6-Month,0,
MAS16437-MAS00108,Online data acquisition: warning 6-Day,0,
MAS16437-MAS00109,Online data acquisition: warning 6-Hours,0,
MAS16437-MAS00110,Online data acquisition: warning 6-Minutes,0,
MAS16437-MAS00111,Online data acquisition: warning 6-Seconds,0,
MAS16437-MAS16989,Online data acquisition: warning 6-Index of the warning,0,
MAS16437-MAS16990,Online data acquisition: warning 6-Number of warnings,0,
MAS16438-MAS00106,Online data acquisition: warning 7-Year,2000,
MAS16438-MAS00107,Online data acquisition: warning 7-Month,0,
MAS16438-MAS00108,Online data acquisition: warning 7-Day,0,
MAS16438-MAS00109,Online data acquisition: warning 7-Hours,0,
MAS16438-MAS00110,Online data acquisition: warning 7-Minutes,0,
MAS16438-MAS00111,Online data acquisition: warning 7-Seconds,0,
MAS16438-MAS16989,Online data acquisition: warning 7-Index of the warning,0,
MAS16438-MAS16990,Online data acquisition: warning 7-Number of warnings,0,
ENG101323,Headlight leveling control state,static,
ENG107365,Left dynamic cornering light value,0.000000, °
ENG157518-ENG161284,Multifunction_Module_Application_Software_Version-Software_Version_AFS/MXB,0170,
ENG157518-ENG161297,Multifunction_Module_Application_Software_Version-Version_Routing_FCM,7200,
ENG124613,Predictive_Route_Data_Intown_Flag,Not available,
ENG124610,Predictive_Route_Data_Number_Of_Lanes,Not available,
ENG124612,Predictive_Route_Data_Placename_Sign,Not available,
ENG124611,Predictive_Route_Data_Speed_Limit,Not available,
ENG124609,Predictive_Route_Data_Street_Class,Not available,
ENG108468,Right dynamic cornering light value,0.000000, °
Elapsed Time: 00:11,,,
blockmap-52-5Q4-959-592-P_3VV2X7B28NM061887-20220618-1238.CSV
;SW:5Q4-959-592-P   HW:5Q4-959-592-P ---  Door Elect, Pass.
;Component:TSG BFS       011 0912, Coding:003E13200000028000000000
;EV_DCU2PasseSideMAXHCONT,001005,EV_DCU2PasseSideMAXHCONT_VW37.rod
;Saturday,18,June,2022,12:38:06:14741
;VCDS Version: Beta 22.4.0 (x64)  Data version: 20220407 DS338.0
Group,Description,Actual,
IDE01993-MAS12276,Control module reference number-Front door control module,Front passenger door control module,
IDE01993-MAS12277,Control module reference number-Rear door control module,Rear Passenger Door Control Module,
IDE02261-IDE00773,Supply voltage for door control module: rear: frt.pass. side-Terminal 15 status via CAN,active,
IDE02261-IDE01715,Supply voltage for door control module: rear: frt.pass. side-Status terminal S,active,
IDE02261-IDE05835,Supply voltage for door control module: rear: frt.pass. side-Supply voltage for central locking,12.10, V
IDE02266,Passenger side rear power window button,Not operated,
IDE02268-IDE00773,Supply voltage for door control module: front: frt.pass. side-Terminal 15 status via CAN,active,
IDE02268-IDE01715,Supply voltage for door control module: front: frt.pass. side-Status terminal S,active,
IDE02268-IDE05835,Supply voltage for door control module: front: frt.pass. side-Supply voltage for central locking,12.60, V
IDE04216-MAS04247,Mirror heater-Button,not installed,
IDE04540,Mirror adjustment (X/Y direction),not installed,
IDE05727-IDE04213,Front passenger side door status-Central locking button,Not operated,
IDE05727-IDE04214,Front passenger side door status-Key switch in door lock,not installed,
IDE05727-MAS06256,Front passenger side door status-Status door lock,Signal from door lock: engaged,
IDE06207-MAS01453,Front window regulator status: frt.pass. side-Blocking detection,not active,
IDE06207-MAS02039,Front window regulator status: frt.pass. side-Force limitation,not active,
IDE06207-MAS02097,Front window regulator status: frt.pass. side-Window position,0.00, %
IDE06207-MAS02098,Front window regulator status: frt.pass. side-Window regulator standardized,Yes,
IDE06207-MAS03548,Front window regulator status: frt.pass. side-Motor current,0, A
IDE06207-MAS04642,Front window regulator status: frt.pass. side-Before upper stop,active,
IDE06207-MAS05370,Front window regulator status: frt.pass. side-Direction of movement,Position top,
IDE06209-MAS01453,Rear window regulator status: frt.pass. side-Blocking detection,active,
IDE06209-MAS02039,Rear window regulator status: frt.pass. side-Force limitation,not active,
IDE06209-MAS02097,Rear window regulator status: frt.pass. side-Window position,0.00, %
IDE06209-MAS02098,Rear window regulator status: frt.pass. side-Window regulator standardized,Yes,
IDE06209-MAS03548,Rear window regulator status: frt.pass. side-Motor current,Not available,
IDE06209-MAS04642,Rear window regulator status: frt.pass. side-Before upper stop,active,
IDE06209-MAS05370,Rear window regulator status: frt.pass. side-Direction of movement,Position top,
IDE06872,Front passenger power window button,Not operated,
IDE06932-MAS01159,Ident. of rear window regulator programming: frt.pass. side-Version number,4Q01,
IDE06934,Front window regulator relay: frt.pass. side,Open,
IDE06936,Rear window regulator relay: frt.pass. side,Open,
IDE06938-MAS02545,Front window regulator reversing position: frt. pass. side-Last,127.50, %
IDE06938-MAS02546,Front window regulator reversing position: frt. pass. side-Second to last,127.50, %
IDE06938-MAS02547,Front window regulator reversing position: frt. pass. side-Third to last,127.50, %
IDE06938-MAS02548,Front window regulator reversing position: frt. pass. side-Fourth to last,127.50, %
IDE06938-MAS05380,Front window regulator reversing position: frt. pass. side-fifth to last,127.50, %
IDE06941,Rear window regulator child lock: frt.pass. side,not active,
IDE07223,Window regulator child lock: frt.pass. side,Not available,
IDE07406-IDE03114,Enable front passenger window regulator relay-Comfort function,No,
IDE07406-MAS02447,Enable front passenger window regulator relay-Release,Yes,
IDE07408-IDE03114,Enable frt.pass.-side rear window regulator-Comfort function,No,
IDE07408-MAS02447,Enable frt.pass.-side rear window regulator-Release,Yes,
IDE07410-MAS01632,Excess.temp. disconnect: front window regulator: frt.pass. side-Status,not active,
IDE07410-MAS02955,Excess.temp. disconnect: front window regulator: frt.pass. side-Engine temperature,42, °C
IDE07412-MAS01632,Excess.temp.disconnect for rear window regulator: frt.pass.side-Status,not active,
IDE07412-MAS02955,Excess.temp.disconnect for rear window regulator: frt.pass.side-Engine temperature,47, °C
IDE07414,Comfort function for front window regulator: frt.pass. side,not active,
IDE07416,Comfort function for rear window regulator: frt.pass. side,not active,
IDE07417-MAS02545,Rear window regulator reversing position: frt.pass. side-Last,71.00, %
IDE07417-MAS02546,Rear window regulator reversing position: frt.pass. side-Second to last,14.00, %
IDE07417-MAS02547,Rear window regulator reversing position: frt.pass. side-Third to last,127.50, %
IDE07417-MAS02548,Rear window regulator reversing position: frt.pass. side-Fourth to last,127.50, %
IDE07417-MAS05380,Rear window regulator reversing position: frt.pass. side-fifth to last,127.50, %
IDE15340,Light output 1 pin D8 target brightness on front passenger side,0, %
IDE15341,Light output 2 pin D3 target brightness on front passenger side,0, %
IDE15342,Light output 3 pin C1/B3 target brightness on front passenger side,Not available,
IDE15343,Light output 4 pin D16 target brightness on front passenger side,0, %
ENG117316-ENG163906,Window_Regulator_Passenger_Side_Rear_VW_Workshop_System_Name-System_short_sign,J927 ,
blockmap-5F-3G5-035-842-D_3VV2X7B28NM061887-20220618-1238.CSV
;SW:3G5-035-842-D   HW:3G5-035-842 ---  Information Electr.
;Component:MU-O-NS-US    H56 0813, Coding:23165000002000000000000000000000000000000000000000
;EV_MUOIMQB,001002,EV_MUOIMQB_VW27.rod
;Saturday,18,June,2022,12:38:19:14741
;VCID: A90416EE197A3B1324C-80FC
IDE00019,Voltage terminal 30,12.60, V
IDE00021,Engine RPM,1421.50, /min
IDE00655-MAS01424,Temperature of processor circuit board-max.value,69, °C
IDE00655-MAS01425,Temperature of processor circuit board-min.value,0, °C
IDE00655-MAS02238,Temperature of processor circuit board-Up-to-date,62, °C
IDE00916-ENG249445,Speaker status-loudspeaker_config_channel_1,Not available,
IDE00916-ENG249455,Speaker status-loudspeaker_config_channel_2,Not available,
IDE00916-ENG249288,Speaker status-loudspeaker_config_channel_3,Not available,
IDE00916-ENG249509,Speaker status-loudspeaker_config_channel_4,Not available,
IDE00916-ENG249362,Speaker status-loudspeaker_config_channel_5,Not available,
IDE00916-ENG249491,Speaker status-loudspeaker_config_channel_6,Not available,
IDE00916-ENG249410,Speaker status-loudspeaker_config_channel_7,Not available,
IDE00916-ENG249340,Speaker status-loudspeaker_config_channel_8,Not available,
IDE01351,Terminal 75 status,On,
IDE01627-MAS01167,Search for Bluetooth devices-Actuation time,0 s,
IDE01627-ENG170421,Search for Bluetooth devices-IoReached Status,Output diagnostic test not active,
IDE01628-MAS01167,Establish connection to last Bluetooth device-Actuation time,0 s,
IDE01628-ENG170421,Establish connection to last Bluetooth device-IoReached Status,Output diagnostic test not active,
IDE01700-MAS01763,Status of tuner for digital radio (DAB)-Signal Strength,0,
IDE01700-MAS02572,Status of tuner for digital radio (DAB)-Mute,not active,
IDE01700-MAS02949,Status of tuner for digital radio (DAB)-Frequency,0,
IDE01700-MAS03786,Status of tuner for digital radio (DAB)-Audio Codec,MPEG Audio Layer 2,
IDE01700-MAS06242,Status of tuner for digital radio (DAB)-Signal quality,0,
IDE01700-MAS19004,Status of tuner for digital radio (DAB)-DAB fault bit rate FIC,0.00,
IDE01700-MAS19005,Status of tuner for digital radio (DAB)-DAB fault bit rate NET,0.00,
IDE01700-MAS19006,Status of tuner for digital radio (DAB)-DAB fault bit rate MSC,0.00,
IDE01700-MAS19007,Status of tuner for digital radio (DAB)-TP traffic data,Not available,
IDE01700-MAS19010,Status of tuner for digital radio (DAB)-TPEG,Not available,
IDE01700-MAS19011,Status of tuner for digital radio (DAB)-Ensemble ID,0,
IDE01700-MAS19012,Status of tuner for digital radio (DAB)-Ensemble Label,,
IDE01700-MAS19013,Status of tuner for digital radio (DAB)-Ensemble label mask,0,
IDE01700-MAS19014,Status of tuner for digital radio (DAB)-Ensemble country code,0,
IDE01700-MAS19018,Status of tuner for digital radio (DAB)-Bit rate,0,
IDE01700-MAS19019,Status of tuner for digital radio (DAB)-Sample Rate,0,
IDE01700-MAS19020,Status of tuner for digital radio (DAB)-Audio mode,00,
IDE01700-MAS19022,Status of tuner for digital radio (DAB)-DAB transfer mode,0,
IDE01700-MAS19023,Status of tuner for digital radio (DAB)-SYNC / OFDM Lock,not active,
IDE01700-MAS19024,Status of tuner for digital radio (DAB)-Audio quality,0,
IDE01700-MAS19041,Status of tuner for digital radio (DAB)-Protection level,1_A_equal_protection_level,
IDE01700-ENG117346,Status of tuner for digital radio (DAB)-Charset,00,
IDE01700-ENG249430,Status of tuner for digital radio (DAB)-Count_Audio_Services,0,
IDE01700-ENG249296,Status of tuner for digital radio (DAB)-Count_Services,0,
IDE01700-ENG117340,Status of tuner for digital radio (DAB)-Data_Service_Identifier,00 00 00 00,
IDE01700-ENG117341,Status of tuner for digital radio (DAB)-Data_Service_Label,,
IDE01700-ENG117345,Status of tuner for digital radio (DAB)-Data_Service_Label_Mask,00 00,
IDE01700-ENG117335,Status of tuner for digital radio (DAB)-Program_Service_Identifier,Service deactivated,
IDE01700-ENG117336,Status of tuner for digital radio (DAB)-Service_Component_Identifier,0,
IDE01700-ENG117338,Status of tuner for digital radio (DAB)-Service_Label,,
IDE01700-ENG117343,Status of tuner for digital radio (DAB)-Service_Label_Mask,00 00,
IDE01700-ENG117337,Status of tuner for digital radio (DAB)-Sub_Channel_Identifier,0,
IDE01700-ENG117339,Status of tuner for digital radio (DAB)-Sub_Service_Label,,
IDE01700-ENG117344,Status of tuner for digital radio (DAB)-Sub_Service_Label_Mask,00 00,
IDE01712-MAS01779,GPS Position-Length,Redacted by Ross-Tech for User Privacy,
IDE01712-MAS01780,GPS Position-Width,Redacted by Ross-Tech for User Privacy,
IDE01713-MAS01632,Status GPS reception-Status,GPS data is being received: position completely determined,
IDE01713-MAS01785,Status GPS reception-Number of visible satellites,15,
IDE01713-MAS01786,Status GPS reception-Number of tracked satellites,12,
IDE01767-MAS00940,Status of telephone-Antenna diagnostic,OK,
IDE01768-MAS01808,Status of antenna 1 for radio-Antenna current,67, mA
IDE01768-MAS03938,Status of antenna 1 for radio-Connection between radio and antenna amplifier,electrically OK,
IDE01768-MAS03939,Status of antenna 1 for radio-Connection between antenna amplifier and antenna,electrically OK,
IDE01769-MAS01808,Status of antenna 2 for radio-Antenna current,46, mA
IDE01769-MAS03938,Status of antenna 2 for radio-Connection between radio and antenna amplifier,electrically OK,
IDE01769-MAS03939,Status of antenna 2 for radio-Connection between antenna amplifier and antenna,electrically OK,
IDE01770-MAS01632,Status of GPS antenna-Status,Not available,
IDE01770-MAS01808,Status of GPS antenna-Antenna current,Not available,
IDE01771-MAS01808,Status of digital radio antenna 1-Antenna current,0, mA
IDE01771-MAS03938,Status of digital radio antenna 1-Connection between radio and antenna amplifier,electrically OK,
IDE01771-MAS03939,Status of digital radio antenna 1-Connection between antenna amplifier and antenna,electrically OK,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,94 9A 0A 22,
IDE02178-MAS01167,Status remote control-Actuation time,0 s,
IDE02178-ENG170421,Status remote control-IoReached Status,Output diagnostic test not active,
IDE02179-MAS01167,Remote control for selecting the audio source-Actuation time,0 s,
IDE02179-ENG170421,Remote control for selecting the audio source-IoReached Status,Output diagnostic test not active,
IDE02180-MAS01167,Remote control for FM frequency selection-Actuation time,0 s,
IDE02180-ENG170421,Remote control for FM frequency selection-IoReached Status,Output diagnostic test not active,
IDE02181-MAS01167,Remote control for AM frequency selection-Actuation time,0 s,
IDE02181-ENG170421,Remote control for AM frequency selection-IoReached Status,Output diagnostic test not active,
IDE02326-MAS17347,GPS signal strength-Satellite 1: identification,0,
IDE02326-MAS17348,GPS signal strength-Satellite 1: signal strength,63, dBµV
IDE02326-MAS17349,GPS signal strength-Satellite 2: signal strength,63, dBµV
IDE02326-MAS17350,GPS signal strength-Satellite 3: signal strength,63, dBµV
IDE02326-MAS17351,GPS signal strength-Satellite 4: signal strength,51, dBµV
IDE02326-MAS17352,GPS signal strength-Satellite 2: identification,0,
IDE02326-MAS17353,GPS signal strength-Satellite 3: identification,0,
IDE02326-MAS17354,GPS signal strength-Satellite 4: identification,6,
IDE02449-MAS01167,Remote control for satellite radio station selection-Actuation time,0 s,
IDE02449-ENG170421,Remote control for satellite radio station selection-IoReached Status,Output diagnostic test not active,
IDE02452-IDE02451,Satellite radio tuner status-Satellite radio antenna status,electrically OK,
IDE02452-IDE02453,Satellite radio tuner status-Channel selection for satellite radio,1,
IDE02452-MAS01765,Satellite radio tuner status-Audio Signal,available.,
IDE02452-MAS01808,Satellite radio tuner status-Antenna current,113, mA
IDE02452-MAS02573,Satellite radio tuner status-Reception quality,Good signal,
IDE02452-MAS13343,Satellite radio tuner status-Satellite radio tuner: pre-activation status,factory_activation_successful,
IDE02452-MAS13344,Satellite radio tuner status-Satellite radio tuner: pre-activation value,05,
IDE02454-MAS01167,Remote control for digital radio service selection (DSB)-Actuation time,0 s,
IDE02454-ENG170421,Remote control for digital radio service selection (DSB)-IoReached Status,Output diagnostic test not active,
IDE02470-MAS01167,Remote control frequency selection digital radio (band III)-Actuation time,0 s,
IDE02470-ENG170421,Remote control frequency selection digital radio (band III)-IoReached Status,Output diagnostic test not active,
IDE02475-MAS01167,Acoustic check of loudspeakers-Actuation time,0 s,
IDE02476-MAS01167,Electrical test of speakers-Actuation time,0 s,
IDE02501-MAS01167,Remote control for voice operation-Actuation time,0 s,
IDE02501-ENG170421,Remote control for voice operation-IoReached Status,Output diagnostic test not active,
IDE02505-MAS01763,Status of tuner 2 for digital radio (DAB)-Signal Strength,0,
IDE02505-MAS02949,Status of tuner 2 for digital radio (DAB)-Frequency,0,
IDE02505-MAS06242,Status of tuner 2 for digital radio (DAB)-Signal quality,0,
IDE02505-MAS19004,Status of tuner 2 for digital radio (DAB)-DAB fault bit rate FIC,0.00,
IDE02505-MAS19005,Status of tuner 2 for digital radio (DAB)-DAB fault bit rate NET,0.00,
IDE02505-MAS19006,Status of tuner 2 for digital radio (DAB)-DAB fault bit rate MSC,0.00,
IDE02505-MAS19011,Status of tuner 2 for digital radio (DAB)-Ensemble ID,00 00 00 00,
IDE02505-MAS19012,Status of tuner 2 for digital radio (DAB)-Ensemble Label,,
IDE02505-MAS19023,Status of tuner 2 for digital radio (DAB)-SYNC / OFDM Lock,not active,
IDE02508-MAS00951,Bluetooth: Visibility-Bluetooth,On,
IDE02508-MAS03001,Bluetooth: Visibility-Mode,Bluetooth available,
IDE02766,Malfunction status,00 00,
IDE02766-ENG249300,Malfunction status-amount_communication_errors,0,
IDE03477-MAS00106,GPS time-Year,2022,
IDE03477-MAS00107,GPS time-Month,6,
IDE03477-MAS00108,GPS time-Day,18,
IDE03477-MAS00109,GPS time-Hours,16,
IDE03477-MAS00110,GPS time-Minutes,38,
IDE03477-MAS00111,GPS time-Seconds,21,
IDE03477-MAS01632,GPS time-Status,valid,
IDE03610-MAS02573,Voice operation: last detected command-Reception quality,0, %
IDE03610-MAS03874,Voice operation: last detected command-last detected command,0,
IDE03610-MAS03875,Voice operation: last detected command-Reliability,0, %
IDE04312-MAS00109,System run time-Hours,0, H
IDE04312-MAS00110,System run time-Minutes,11, min
IDE04317-MAS00108,Total system run time-Day,0, d
IDE04317-MAS00109,Total system run time-Hours,12, H
IDE04317-MAS00110,Total system run time-Minutes,12, min
IDE04329-ENG118721,Status of all SWaP functions-SWaP_function_state array,|ID number,Release code for a SWaP function
IDE04332-ENG117770,Release code for a SWaP function-fsc,Not available,
IDE04546-IDE00301,Calibration of navigation-Mileage,437.85, mm
IDE04546-MAS03647,Calibration of navigation-Calibration condition,complete,
IDE04548-MAS00106,Electronic toll collection-Year,2000,
IDE04548-MAS00107,Electronic toll collection-Month,0,
IDE04548-MAS00108,Electronic toll collection-Day,OFF,
IDE04548-MAS00109,Electronic toll collection-Hours,0,
IDE04548-MAS00110,Electronic toll collection-Minutes,0,
IDE04548-MAS00111,Electronic toll collection-Seconds,0,
IDE04548-MAS01156,Electronic toll collection-Communication status,not OK,
IDE04548-MAS01161,Electronic toll collection-Communication malfunction,0,
IDE04548-MAS01758,Electronic toll collection-Date / time,invalid,
IDE04548-MAS04385,Electronic toll collection-Authorization,not OK,
IDE04548-MAS04386,Electronic toll collection-Write card,not OK,
IDE04548-MAS04387,Electronic toll collection-Read card,not OK,
IDE04548-MAS04388,Electronic toll collection-Card type,no card available,
IDE04548-MAS04389,Electronic toll collection-Number of repeat attempts,0,
IDE04548-MAS04394,Electronic toll collection-Connection status,not connected,
IDE04548-MAS04460,Electronic toll collection-Validity,not OK,
IDE04649-MAS01968,Activation for housing fan-Fan,Stage 1,
IDE04649-MAS06857,Activation for housing fan-Speed,2100, /min
IDE04767-MAS01240,Update software via medium-Programming status,not active,
IDE04767-MAS02111,Update software via medium-Data consistency,invalid,
IDE04767-MAS02112,Update software via medium-Programmability,Waiting for data transmission,
IDE04768,Bluetooth: device address,9C 50 D1 80 CE 7A,
IDE05040-MAS01632,Video input status-Status,Not available,
IDE05040-MAS04390,Video input status-Active source,Not available,
IDE05107-MAS01167,Test image display unit 1 for multimedia system-Actuation time,0 s,
IDE05107-ENG170421,Test image display unit 1 for multimedia system-IoReached Status,Output diagnostic test not active,
IDE05535-MAS01632,Traffic data antenna-Status,not OK,
IDE05570-MAS01632,DSRC antenna-Status,Unknown (0),
IDE05595-MAS00106,Last time GPS without satellite reception-Year,2000,
IDE05595-MAS00107,Last time GPS without satellite reception-Month,0,
IDE05595-MAS00108,Last time GPS without satellite reception-Day,OFF,
IDE05595-MAS00109,Last time GPS without satellite reception-Hours,0,
IDE05595-MAS00110,Last time GPS without satellite reception-Minutes,0,
IDE05595-MAS00111,Last time GPS without satellite reception-Seconds,0,
IDE05596-MAS00106,Last time GPS position outside map-Year,2022,
IDE05596-MAS00107,Last time GPS position outside map-Month,6,
IDE05596-MAS00108,Last time GPS position outside map-Day,18,
IDE05596-MAS00109,Last time GPS position outside map-Hours,16,
IDE05596-MAS00110,Last time GPS position outside map-Minutes,38,
IDE05596-MAS00111,Last time GPS position outside map-Seconds,20,
IDE05602-IDE03615,Bluetooth: connected device 1-Variant,,
IDE05602-IDE04768,Bluetooth: connected device 1-Bluetooth: device address,00 00 00 00 00 00,
IDE05602-MAS01483,Bluetooth: connected device 1-Software version,,
IDE05602-MAS02159,Bluetooth: connected device 1-Remote SIM Access Profile (rSAP),0,
IDE05602-MAS02160,Bluetooth: connected device 1-Hands free profile (HFP),0,
IDE05602-MAS03159,Bluetooth: connected device 1-Manufacturer,,
IDE05602-MAS04326,Bluetooth: connected device 1-Device name,,
IDE05602-MAS17538,Bluetooth: connected device 1-Received Signal Strength Indicator (RSSI),0,
IDE05602-MAS17539,Bluetooth: connected device 1-Determining the existing profile (SDP),0,
IDE05602-MAS17540,Bluetooth: connected device 1-Serial data transfer (SPP),0,
IDE05602-MAS17541,Bluetooth: connected device 1-Streaming audio data (A2DP),0,
IDE05602-MAS17542,Bluetooth: connected device 1-Remote control for audio/video (AVRCP),0,
IDE05602-MAS17543,Bluetooth: connected device 1-Network connections (PAN),0,
IDE05602-MAS17544,Bluetooth: connected device 1-Message exchange between devices (MAP),0,
IDE05602-MAS17545,Bluetooth: connected device 1-Generic data transfer between two devices (OBEX),0,
IDE05602-MAS17546,Bluetooth: connected device 1-Sending individual files (OPP),0,
IDE05602-MAS17547,Bluetooth: connected device 1-File transfer (FTP),0,
IDE05602-MAS17548,Bluetooth: connected device 1-Read-only access to telephone directory (PBAP),0,
IDE05602-MAS17549,Bluetooth: connected device 1-Telephone directory download (AT),0,
IDE05602-MAS17550,Bluetooth: connected device 1-Sharing calendars or notes between two devices (CTN),0,
IDE05602-MAS17551,Bluetooth: connected device 1-iAP protocol (iAP),0,
IDE05603-IDE03615,Bluetooth: connected device 2-Variant,,
IDE05603-IDE04768,Bluetooth: connected device 2-Bluetooth: device address,00 00 00 00 00 00,
IDE05603-MAS01483,Bluetooth: connected device 2-Software version,,
IDE05603-MAS02159,Bluetooth: connected device 2-Remote SIM Access Profile (rSAP),0,
IDE05603-MAS02160,Bluetooth: connected device 2-Hands free profile (HFP),0,
IDE05603-MAS03159,Bluetooth: connected device 2-Manufacturer,,
IDE05603-MAS04326,Bluetooth: connected device 2-Device name,,
IDE05603-MAS17538,Bluetooth: connected device 2-Received Signal Strength Indicator (RSSI),0,
IDE05603-MAS17539,Bluetooth: connected device 2-Determining the existing profile (SDP),0,
IDE05603-MAS17540,Bluetooth: connected device 2-Serial data transfer (SPP),0,
IDE05603-MAS17541,Bluetooth: connected device 2-Streaming audio data (A2DP),0,
IDE05603-MAS17542,Bluetooth: connected device 2-Remote control for audio/video (AVRCP),0,
IDE05603-MAS17543,Bluetooth: connected device 2-Network connections (PAN),0,
IDE05603-MAS17544,Bluetooth: connected device 2-Message exchange between devices (MAP),0,
IDE05603-MAS17545,Bluetooth: connected device 2-Generic data transfer between two devices (OBEX),0,
IDE05603-MAS17546,Bluetooth: connected device 2-Sending individual files (OPP),0,
IDE05603-MAS17547,Bluetooth: connected device 2-File transfer (FTP),0,
IDE05603-MAS17548,Bluetooth: connected device 2-Read-only access to telephone directory (PBAP),0,
IDE05603-MAS17549,Bluetooth: connected device 2-Telephone directory download (AT),0,
IDE05603-MAS17550,Bluetooth: connected device 2-Sharing calendars or notes between two devices (CTN),0,
IDE05603-MAS17551,Bluetooth: connected device 2-iAP protocol (iAP),0,
IDE05604-IDE03615,Bluetooth: connected device 3-Variant,,
IDE05604-IDE04768,Bluetooth: connected device 3-Bluetooth: device address,00 00 00 00 00 00,
IDE05604-MAS01483,Bluetooth: connected device 3-Software version,,
IDE05604-MAS02159,Bluetooth: connected device 3-Remote SIM Access Profile (rSAP),0,
IDE05604-MAS02160,Bluetooth: connected device 3-Hands free profile (HFP),0,
IDE05604-MAS03159,Bluetooth: connected device 3-Manufacturer,,
IDE05604-MAS04326,Bluetooth: connected device 3-Device name,,
IDE05604-MAS17538,Bluetooth: connected device 3-Received Signal Strength Indicator (RSSI),0,
IDE05604-MAS17539,Bluetooth: connected device 3-Determining the existing profile (SDP),0,
IDE05604-MAS17540,Bluetooth: connected device 3-Serial data transfer (SPP),0,
IDE05604-MAS17541,Bluetooth: connected device 3-Streaming audio data (A2DP),0,
IDE05604-MAS17542,Bluetooth: connected device 3-Remote control for audio/video (AVRCP),0,
IDE05604-MAS17543,Bluetooth: connected device 3-Network connections (PAN),0,
IDE05604-MAS17544,Bluetooth: connected device 3-Message exchange between devices (MAP),0,
IDE05604-MAS17545,Bluetooth: connected device 3-Generic data transfer between two devices (OBEX),0,
IDE05604-MAS17546,Bluetooth: connected device 3-Sending individual files (OPP),0,
IDE05604-MAS17547,Bluetooth: connected device 3-File transfer (FTP),0,
IDE05604-MAS17548,Bluetooth: connected device 3-Read-only access to telephone directory (PBAP),0,
IDE05604-MAS17549,Bluetooth: connected device 3-Telephone directory download (AT),0,
IDE05604-MAS17550,Bluetooth: connected device 3-Sharing calendars or notes between two devices (CTN),0,
IDE05604-MAS17551,Bluetooth: connected device 3-iAP protocol (iAP),0,
IDE05605-IDE03615,Bluetooth: connected device 4-Variant,,
IDE05605-IDE04768,Bluetooth: connected device 4-Bluetooth: device address,00 00 00 00 00 00,
IDE05605-MAS01483,Bluetooth: connected device 4-Software version,,
IDE05605-MAS02159,Bluetooth: connected device 4-Remote SIM Access Profile (rSAP),0,
IDE05605-MAS02160,Bluetooth: connected device 4-Hands free profile (HFP),0,
IDE05605-MAS03159,Bluetooth: connected device 4-Manufacturer,,
IDE05605-MAS04326,Bluetooth: connected device 4-Device name,,
IDE05605-MAS17538,Bluetooth: connected device 4-Received Signal Strength Indicator (RSSI),0,
IDE05605-MAS17539,Bluetooth: connected device 4-Determining the existing profile (SDP),0,
IDE05605-MAS17540,Bluetooth: connected device 4-Serial data transfer (SPP),0,
IDE05605-MAS17541,Bluetooth: connected device 4-Streaming audio data (A2DP),0,
IDE05605-MAS17542,Bluetooth: connected device 4-Remote control for audio/video (AVRCP),0,
IDE05605-MAS17543,Bluetooth: connected device 4-Network connections (PAN),0,
IDE05605-MAS17544,Bluetooth: connected device 4-Message exchange between devices (MAP),0,
IDE05605-MAS17545,Bluetooth: connected device 4-Generic data transfer between two devices (OBEX),0,
IDE05605-MAS17546,Bluetooth: connected device 4-Sending individual files (OPP),0,
IDE05605-MAS17547,Bluetooth: connected device 4-File transfer (FTP),0,
IDE05605-MAS17548,Bluetooth: connected device 4-Read-only access to telephone directory (PBAP),0,
IDE05605-MAS17549,Bluetooth: connected device 4-Telephone directory download (AT),0,
IDE05605-MAS17550,Bluetooth: connected device 4-Sharing calendars or notes between two devices (CTN),0,
IDE05605-MAS17551,Bluetooth: connected device 4-iAP protocol (iAP),0,
IDE05606-IDE03615,Bluetooth: connected device 5-Variant,,
IDE05606-IDE04768,Bluetooth: connected device 5-Bluetooth: device address,00 00 00 00 00 00,
IDE05606-MAS01483,Bluetooth: connected device 5-Software version,,
IDE05606-MAS02159,Bluetooth: connected device 5-Remote SIM Access Profile (rSAP),0,
IDE05606-MAS02160,Bluetooth: connected device 5-Hands free profile (HFP),0,
IDE05606-MAS03159,Bluetooth: connected device 5-Manufacturer,,
IDE05606-MAS04326,Bluetooth: connected device 5-Device name,,
IDE05606-MAS17538,Bluetooth: connected device 5-Received Signal Strength Indicator (RSSI),0,
IDE05606-MAS17539,Bluetooth: connected device 5-Determining the existing profile (SDP),0,
IDE05606-MAS17540,Bluetooth: connected device 5-Serial data transfer (SPP),0,
IDE05606-MAS17541,Bluetooth: connected device 5-Streaming audio data (A2DP),0,
IDE05606-MAS17542,Bluetooth: connected device 5-Remote control for audio/video (AVRCP),0,
IDE05606-MAS17543,Bluetooth: connected device 5-Network connections (PAN),0,
IDE05606-MAS17544,Bluetooth: connected device 5-Message exchange between devices (MAP),0,
IDE05606-MAS17545,Bluetooth: connected device 5-Generic data transfer between two devices (OBEX),0,
IDE05606-MAS17546,Bluetooth: connected device 5-Sending individual files (OPP),0,
IDE05606-MAS17547,Bluetooth: connected device 5-File transfer (FTP),0,
IDE05606-MAS17548,Bluetooth: connected device 5-Read-only access to telephone directory (PBAP),0,
IDE05606-MAS17549,Bluetooth: connected device 5-Telephone directory download (AT),0,
IDE05606-MAS17550,Bluetooth: connected device 5-Sharing calendars or notes between two devices (CTN),0,
IDE05606-MAS17551,Bluetooth: connected device 5-iAP protocol (iAP),0,
IDE05700-MAS01456,USB connection-Speed,Low speed,
IDE05700-MAS01632,USB connection-Status,not OK.,
IDE05700-MAS03159,USB connection-Manufacturer,0,
IDE05700-MAS04393,USB connection-USB device class,0,
IDE05700-MAS04394,USB connection-Connection status,not connected,
IDE05700-MAS04436,USB connection-USB device sub-class,0,
IDE05700-MAS06173,USB connection-Protocol,0,
IDE05700-MAS06174,USB connection-Product ID,0,
IDE05725,Dimmer terminal 58xs,0, %
IDE05726,Dimmer terminal 58xd,99.94, %
IDE05814,Individualization characteristic,6C 49 26 0A A5,
IDE06028-MAS02317,Control head button operation-Button code 1,0,
IDE06028-MAS02318,Control head button operation-Button code 2,0,
IDE06028-MAS04151,Control head button operation-Joystick,0,
IDE06028-MAS04413,Control head button operation-Push-and rotary knob for selection,-127,
IDE06028-MAS04414,Control head button operation-Volume control,-127,
IDE06516-MAS01424,Temperature: optical drive-max.value,Not available,
IDE06516-MAS01425,Temperature: optical drive-min.value,Not available,
IDE06516-MAS02238,Temperature: optical drive-Up-to-date,Not available,
IDE06517-MAS01424,Temperature: audio amplifier-max.value,73, °C
IDE06517-MAS01425,Temperature: audio amplifier-min.value,0, °C
IDE06517-MAS02238,Temperature: audio amplifier-Up-to-date,63, °C
IDE06519-MAS01424,Temperature of MOST transceiver-max.value,Not available,
IDE06519-MAS01425,Temperature of MOST transceiver-min.value,Not available,
IDE06519-MAS02238,Temperature of MOST transceiver-Up-to-date,Not available,
IDE06521-MAS01424,Temperature of MMX PC boards-max.value,72, °C
IDE06521-MAS01425,Temperature of MMX PC boards-min.value,0, °C
IDE06521-MAS02238,Temperature of MMX PC boards-Up-to-date,69, °C
IDE06522-MAS01424,Temperature of phone unit-max.value,72, °C
IDE06522-MAS01425,Temperature of phone unit-min.value,0, °C
IDE06522-MAS02238,Temperature of phone unit-Up-to-date,69, °C
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,06,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,03,
IDE07174,Connection for extern. audio sources (USB): overcurrent detect.,OK,
IDE07364,GPS reception status,GPS data available,
IDE07543,Vehicle speed,0.00, km/h
IDE07589-IDE07590,Update programming: status-Currently processed module,0,
IDE07589-IDE07591,Update programming: status-Number of modules to be programmed,0,
IDE07589-MAS01632,Update programming: status-Status,not active,
IDE07589-MAS10948,Update programming: status-control,Diagnosis,
IDE08531-MAS07133,Connection status online license services-No. of license serv.,0,
IDE08531-ENG98502,Connection status online license services-Data,|ID services,Activation status
IDE09544-MAS01167,Locking information electronic 1 operation-Actuation time,0 s,
IDE09544-ENG170421,Locking information electronic 1 operation-IoReached Status,Output diagnostic test not active,
IDE09563-MAS09154,Proximity detection for touchscreen 1-Proximity sensor 1,No object in sector,
IDE10300,OBD Driving Cycle detected,active,
IDE10478-MAS01632,Interface for external media: status-Status,OK,
IDE10481-MAS01167,Interface for external media: diagnosis-Actuation time,0 s,
IDE10481-ENG170421,Interface for external media: diagnosis-IoReached Status,Output diagnostic test not active,
IDE10600-MAS01632,Status of the navigation database-Status,valid,
IDE10600-ENG98502,Status of the navigation database-Data,|Country Code,Region Code
IDE10843-ENG98502,Function module: identification-Data,|Device name,Module Name
IDE10857-MAS02476,Touchless loading of mobile phone: status-installed,available.,
IDE10857-MAS11500,Touchless loading of mobile phone: status-Foreign object,No,
IDE10857-MAS11501,Touchless loading of mobile phone: status-Charging,No,
IDE11034-MAS01482,Satellite radio: module information-Hardware version,1.0.1,
IDE11034-MAS11961,Satellite radio: module information-Serial number,36EVWDH1,
IDE11034-MAS11962,Satellite radio: module information-Pre-activation key,8E D0 A8 00 33 36 45 56 57 44 48 31 00 02 98 05 8A 38 64 68 F5 31 71 89 CD BF 18 05 78 60 E8 37 6E F1 6F 62 E4 E4 03 41 00 66 03 41 00 07 00 66 00 07,
IDE11034-MAS11963,Satellite radio: module information-Firmware version,11.46.1,
IDE11034-MAS11964,Satellite radio: module information-Satellite Module Services Version,,
IDE11034-MAS11965,Satellite radio: module information-SiriusXM Interconnect Version,4.1.0,
IDE11034-MAS11966,Satellite radio: module information-Database Version,492,
IDE11034-ENG249454,Satellite radio: module information-apogee_traffic,,
IDE11034-ENG249326,Satellite radio: module information-canadian_fuel,,
IDE11034-ENG249344,Satellite radio: module information-channel_arts,,
IDE11034-ENG249291,Satellite radio: module information-ev_stations,,
IDE11034-ENG249490,Satellite radio: module information-fuel_stations,,
IDE11034-ENG249493,Satellite radio: module information-internal_sxm,1.6.6.10.1,
IDE11034-ENG249368,Satellite radio: module information-movies,,
IDE11034-ENG249268,Satellite radio: module information-Parking,,
IDE11034-ENG249458,Satellite radio: module information-phonetics,,
IDE11034-ENG249496,Satellite radio: module information-safety_alerts,,
IDE11034-ENG176820,Satellite radio: module information-States,,
IDE11034-ENG249463,Satellite radio: module information-stocks,,
IDE11034-ENG249431,Satellite radio: module information-sxm_pics,,
IDE11034-ENG249499,Satellite radio: module information-tabular_weather,,
IDE11034-ENG249467,Satellite radio: module information-weather_alerts,,
IDE11127-IDE04332,Error-causing FS ID with status-Release code for a SWaP function,Not available,
IDE11127-IDE05814,Error-causing FS ID with status-Individualization characteristic,invalid,
IDE11127-IDE06260,Error-causing FS ID with status-ID number,0,
IDE11127-MAS01340,Error-causing FS ID with status-Functions,Not available,
IDE11127-MAS01903,Error-causing FS ID with status-Configuration,not OK,
IDE11127-MAS02934,Error-causing FS ID with status-Preconditions met,Condition not met,
IDE11127-MAS05616,Error-causing FS ID with status-Cancellation,Yes,
IDE11127-MAS05617,Error-causing FS ID with status-Authentication,Condition not met,
IDE11504,Satellite radio tuner: pre-activated subscription,Yes,
IDE11728,Ethernet signal quality: branch 1,good: link available,
IDE11729,Ethernet signal quality: branch 2,no link,
IDE11730,Ethernet signal quality: branch 3,good: link available,
IDE11731,Ethernet signal quality: branch 4,good: link available,
IDE11736,Ethernet counter connection interruptions: branch 1,0,
IDE11737,Ethernet counter connection interruptions: branch 2,0,
IDE11738,Ethernet counter connection interruptions: branch 3,0,
IDE11739,Ethernet counter connection interruptions: branch 4,0,
IDE11744,Ethernet counter checksum error: branch 1,0,
IDE11745,Ethernet counter checksum error: branch 2,0,
IDE11746,Ethernet counter checksum error: branch 3,0,
IDE11747,Ethernet counter checksum error: branch 4,0,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FE 80 00 00 00 00 00 00 32 B4 B8 FF FE B9 F2 A8|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 73|FE 80 00 00 00 00 00 00 32 B4 B8 FF FE B9 F2 A8|FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 00 73|FE 80 00 00 00 00 00 00 32 B4 B8 FF FE B9 F2 A8|FD 53 7C B8 03 83 00 05 00 00 00 00 00 00 00 73|FE 80 00 00 00 00 00 00 32 B4 B8 FF FE B9 F2 A8|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 2D|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 09|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 50|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 46|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 32|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 31|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 29|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 28|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|3|4|5|0|0|0|0|0|0|0|,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,54,
IDE11988-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 1-MAC address,|MAC address|00 54 AF 86 02 F9|00 54 AF 86 02 F9|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|,
IDE11989-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 2-MAC address,|MAC address|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|,
IDE11990-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 3-MAC address,|MAC address|00 13 43 D1 92 DA|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|,
IDE11991-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 4-MAC address,|MAC address|30 B4 B8 C9 9F 14|30 B4 B8 C9 9F 14|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|,
IDE12230-MAS14856,IP network: VLANs of Ethernet switch ports branch 1-VLAN,|VLAN|5|5|5|5|5|5|5|5|5|5|,
IDE12231-MAS14856,IP network: VLANs of Ethernet switch ports branch 2-VLAN,|VLAN|0|0|0|0|0|0|0|0|0|0|,
IDE12232-MAS14856,IP network: VLANs of Ethernet switch ports branch 3-VLAN,|VLAN|3|3|3|3|0|0|0|0|0|0|,
IDE12233-MAS14856,IP network: VLANs of Ethernet switch ports branch 4-VLAN,|VLAN|4|4|4|4|0|0|0|0|0|0|,
IDE12238,I network: discarded messages counter,54,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 00 67
IDE12267-MAS03231,Microphone current draw-Microphone 1,6.50, mA
IDE12267-MAS03232,Microphone current draw-Microphone 2,Not available,
IDE12267-MAS03233,Microphone current draw-Microphone 3,Not available,
IDE12267-MAS14201,Microphone current draw-Microphone 4,Not available,
IDE12625,IP network: current link deceleration: branch 1,4864, ns
IDE12626,IP network: current link deceleration: branch 2,0, ns
IDE12627,IP network: current link deceleration: branch 3,4864, ns
IDE12628,IP network: current link deceleration: branch 4,4864, ns
IDE12939-MAS02643,Public key for SWaP function (3072)-Key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
IDE13344-MAS01167,Acoustic check of loudspeakers: sequential analysis-Actuation time,0 s,
IDE13344-ENG170421,Acoustic check of loudspeakers: sequential analysis-IoReached Status,Output diagnostic test not active,
IDE13737-MAS01763,Status of tuner for digital radio 1b (DAB)-Signal Strength,0,
IDE13737-MAS19004,Status of tuner for digital radio 1b (DAB)-DAB fault bit rate FIC,0.00,
IDE13737-MAS19005,Status of tuner for digital radio 1b (DAB)-DAB fault bit rate NET,0.00,
IDE13737-MAS19006,Status of tuner for digital radio 1b (DAB)-DAB fault bit rate MSC,0.00,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,3VV2X7B28NM061887,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 01,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,7,
IDE14128-MAS01167,Activation for blower housing status-Actuation time,0 s,
IDE14128-ENG170421,Activation for blower housing status-IoReached Status,Output diagnostic test not active,
IDE14715-MAS18871,Acoustic test of loudspeakers: status-Current channel,OFF,
IDE14715-MAS18921,Acoustic test of loudspeakers: status-Current loudspeaker,Not available,
IDE14733-MAS00106,SDARS subscription status-Year,2000,
IDE14733-MAS00107,SDARS subscription status-Month,0, Months
IDE14733-MAS00108,SDARS subscription status-Day,Not available,
IDE14733-MAS00109,SDARS subscription status-Hours,0, H
IDE14733-MAS00110,SDARS subscription status-Minutes,3, min
IDE14733-MAS00111,SDARS subscription status-Seconds,Not available,
IDE14733-MAS10690,SDARS subscription status-Activation condition,active,
IDE14733-MAS19035,SDARS subscription status-Procedure status,not expired,
IDE14733-MAS19036,SDARS subscription status-Expiration warning,Not available,
IDE14734-MAS01766,SDARS Service Status-Traffic data,not active,
IDE14734-MAS19037,SDARS Service Status-Audio Service,active,
IDE14734-MAS19040,SDARS Service Status-Travel link,not active,
MAS00778-IDE03619,Multimedia System 1-System condition,On,
MAS00778-IDE05228,Multimedia System 1-Operating hour counter,9, H
MAS00778-MAS00110,Multimedia System 1-Minutes,15, min
MAS00778-MAS01634,Multimedia System 1-Supply voltage,12.70, V
MAS00778-MAS02200,Multimedia System 1-Highest measured temperature,74, °C
MAS00778-MAS02201,Multimedia System 1-Temperature,60, °C
MAS00778-MAS03691,Multimedia System 1-Dimming,100, %
MAS00951-MAS04325,Bluetooth-Bluetooth: Paired devices,0,
MAS01760-MAS01765,Radio Tuner 1-Audio Signal,Analog,
MAS01760-MAS02949,Radio Tuner 1-Frequency,0.00, MHz
MAS01760-MAS03991,Radio Tuner 1-Reception level antenna 1,0,
MAS01760-MAS04344,Radio Tuner 1-Reception level antenna 2,0,
MAS01760-MAS04345,Radio Tuner 1-Frequency (AM),0,
MAS01760-MAS19025,Radio Tuner 1-IBOC fault rate,0, %
MAS01760-MAS19026,Radio Tuner 1-IBOC audio signal:,Not available,
MAS01760-MAS19028,Radio Tuner 1-IBOC DRM Service,0,
MAS01760-MAS19030,Radio Tuner 1-IBOC DRM counter,OFF,
MAS01761-MAS01763,Radio Tuner 2-Signal Strength,23,
MAS03782-MAS17355,WLAN-MAC address 2: tethering,00 00 00 00 00 00,
MAS03782-MAS17356,WLAN-MAC address 1,00 00 00 00 00 00,
MAS03782-MAS17357,WLAN-MAC address 2,00 00 00 00 00 00,
MAS03782-MAS17559,WLAN-MAC address 1: tethering,00 00 00 00 00 00,
MAS17523-MAS17968,Unlockable functions: date of last activation-Date of last function activation,62 31 FD 80,
MAS17523-MAS17969,Unlockable functions: date of last activation-Date of last key exchange,00 00 00 00,
MAS17523-MAS17970,Unlockable functions: date of last activation-Date of last reset,00 00 00 00,
MAS17524-MAS17977,Unlockable functions: version info-Supported activation version,Support from FSC version 0x12,
MAS17524-MAS17978,Unlockable functions: version info-Supported encryption procedure,RSA3072 Exp. 17,
MAS17524-MAS18453,Unlockable functions: version info-FoD metadata version,No version of FoD metadata is supported,
MAS17524-MAS18456,Unlockable functions: version info-KeyIdent (Key project identification),1690,
MAS17524-MAS18457,Unlockable functions: version info-Generation of function activation,Activation via FoD,
MAS17524-MAS18460,Unlockable functions: version info-FoD partner diagnostic address,00 75,
MAS17833,Remaining period of test activation,4294967295, s
ENG117872-ENG117778,Byte_Coding_Condition-byte_0_condition,OK,
ENG117872-ENG117779,Byte_Coding_Condition-byte_1_condition,dont care,
ENG117872-ENG117788,Byte_Coding_Condition-byte_10_condition,dont care,
ENG117872-ENG117789,Byte_Coding_Condition-byte_11_condition,dont care,
ENG117872-ENG117790,Byte_Coding_Condition-byte_12_condition,dont care,
ENG117872-ENG117791,Byte_Coding_Condition-byte_13_condition,dont care,
ENG117872-ENG117792,Byte_Coding_Condition-byte_14_condition,dont care,
ENG117872-ENG117793,Byte_Coding_Condition-byte_15_condition,dont care,
ENG117872-ENG117794,Byte_Coding_Condition-byte_16_condition,dont care,
ENG117872-ENG117795,Byte_Coding_Condition-byte_17_condition,dont care,
ENG117872-ENG117796,Byte_Coding_Condition-byte_18_condition,dont care,
ENG117872-ENG117797,Byte_Coding_Condition-byte_19_condition,dont care,
ENG117872-ENG117780,Byte_Coding_Condition-byte_2_condition,dont care,
ENG117872-ENG117798,Byte_Coding_Condition-byte_20_condition,dont care,
ENG117872-ENG117799,Byte_Coding_Condition-byte_21_condition,dont care,
ENG117872-ENG117800,Byte_Coding_Condition-byte_22_condition,dont care,
ENG117872-ENG117801,Byte_Coding_Condition-byte_23_condition,dont care,
ENG117872-ENG117802,Byte_Coding_Condition-byte_24_condition,dont care,
ENG117872-ENG117803,Byte_Coding_Condition-byte_25_condition,dont care,
ENG117872-ENG117804,Byte_Coding_Condition-byte_26_condition,dont care,
ENG117872-ENG117805,Byte_Coding_Condition-byte_27_condition,dont care,
ENG117872-ENG117781,Byte_Coding_Condition-byte_3_condition,dont care,
ENG117872-ENG117782,Byte_Coding_Condition-byte_4_condition,OK,
ENG117872-ENG117783,Byte_Coding_Condition-byte_5_condition,dont care,
ENG117872-ENG117784,Byte_Coding_Condition-byte_6_condition,dont care,
ENG117872-ENG117785,Byte_Coding_Condition-byte_7_condition,dont care,
ENG117872-ENG117786,Byte_Coding_Condition-byte_8_condition,dont care,
ENG117872-ENG117787,Byte_Coding_Condition-byte_9_condition,dont care,
ENG117866-ENG117457,DAB_FM_linking-dab_mute_status,No,
ENG117866-ENG117456,DAB_FM_linking-DAB_quality,0, %
ENG117866-ENG117455,DAB_FM_linking-fm_quality,0, %
ENG117866-ENG117458,DAB_FM_linking-service_linking_status,no_link,
ENG249161-MAS01167,Operating_Unit_Simulation_Keys_status-Actuation time,0 s,
ENG249161-ENG170421,Operating_Unit_Simulation_Keys_status-IoReached Status,Output diagnostic test not active,
ENG249164-MAS09154,Proximity_Sensor_slider_1-Proximity sensor 1,No object in sector,
ENG249168-MAS01167,Remote_Seek_Activation_status-Actuation time,0 s,
ENG249168-ENG170421,Remote_Seek_Activation_status-IoReached Status,Output diagnostic test not active,
ENG249169-MAS01167,Remote_Set_AF_status-Actuation time,0 s,
ENG249169-ENG170421,Remote_Set_AF_status-IoReached Status,Output diagnostic test not active,
ENG249170-MAS01167,Remote_Set_Concealment_Level_status-Actuation time,0 s,
ENG249170-ENG170421,Remote_Set_Concealment_Level_status-IoReached Status,Output diagnostic test not active,
ENG249171-MAS01167,Remote_Set_DAB_Announcement_status-Actuation time,0 s,
ENG249171-ENG170421,Remote_Set_DAB_Announcement_status-IoReached Status,Output diagnostic test not active,
ENG249172-MAS01167,Remote_Set_DAB_Default_status-Actuation time,0 s,
ENG249172-ENG170421,Remote_Set_DAB_Default_status-IoReached Status,Output diagnostic test not active,
ENG249173-MAS01167,Remote_Set_DAB_Linking_status-Actuation time,0 s,
ENG249173-ENG170421,Remote_Set_DAB_Linking_status-IoReached Status,Output diagnostic test not active,
ENG249174-MAS01167,Remote_Set_DAB_Mute_status-Actuation time,0 s,
ENG249174-ENG170421,Remote_Set_DAB_Mute_status-IoReached Status,Output diagnostic test not active,
ENG249175-MAS01167,Remote_Set_Hidden_Tune_status-Actuation time,0 s,
ENG249175-ENG170421,Remote_Set_Hidden_Tune_status-IoReached Status,Output diagnostic test not active,
ENG249176-MAS01167,Remote_Set_IBOC_Service_status-Actuation time,0 s,
ENG249176-ENG170421,Remote_Set_IBOC_Service_status-IoReached Status,Output diagnostic test not active,
ENG249177-MAS01167,Remote_Set_TP_status-Actuation time,0 s,
ENG249177-ENG170421,Remote_Set_TP_status-IoReached Status,Output diagnostic test not active,
ENG249178-MAS01167,Remote_Shift_Frequency_AM_Activation_status-Actuation time,0 s,
ENG249178-ENG170421,Remote_Shift_Frequency_AM_Activation_status-IoReached Status,Output diagnostic test not active,
ENG249179-MAS01167,Remote_Shift_Frequency_DAB_Activation_status-Actuation time,0 s,
ENG249179-ENG170421,Remote_Shift_Frequency_DAB_Activation_status-IoReached Status,Output diagnostic test not active,
ENG249180-MAS01167,Remote_Shift_Frequency_FM_Activation_status-Actuation time,0 s,
ENG249180-ENG170421,Remote_Shift_Frequency_FM_Activation_status-IoReached Status,Output diagnostic test not active,
ENG249197-MAS01167,set_amfm_measurement_mode_status-Actuation time,0 s,
ENG249197-ENG170421,set_amfm_measurement_mode_status-IoReached Status,Output diagnostic test not active,
ENG249198-MAS01167,set_tuner_mode_status-Actuation time,0 s,
ENG249198-ENG170421,set_tuner_mode_status-IoReached Status,Output diagnostic test not active,
ENG117864-MAS01632,Status_Position_Touchscreen_1-Status,Not operated,
ENG117864-ENG117402,Status_Position_Touchscreen_1-calibrate_delta_x,0,
ENG117864-ENG117403,Status_Position_Touchscreen_1-calibrate_delta_y,0,
ENG117864-ENG117396,Status_Position_Touchscreen_1-position_x1,0,
ENG117864-ENG117397,Status_Position_Touchscreen_1-position_x2,0,
ENG117864-ENG117398,Status_Position_Touchscreen_1-position_x3,0,
ENG117864-ENG117399,Status_Position_Touchscreen_1-position_y1,0,
ENG117864-ENG117400,Status_Position_Touchscreen_1-position_y2,0,
ENG117864-ENG117401,Status_Position_Touchscreen_1-position_y3,0,
ENG117870-MAS00106,VICS_Infrared_Beacon_State-Year,2000,
ENG117870-MAS00107,VICS_Infrared_Beacon_State-Month,0,
ENG117870-MAS00108,VICS_Infrared_Beacon_State-Day,OFF,
ENG117870-MAS00109,VICS_Infrared_Beacon_State-Hours,0,
ENG117870-MAS00110,VICS_Infrared_Beacon_State-Minutes,0,
ENG117870-MAS00111,VICS_Infrared_Beacon_State-Seconds,0,
ENG117870-MAS01632,VICS_Infrared_Beacon_State-Status,Not available,
ENG117870-ENG117771,VICS_Infrared_Beacon_State-vics_id,0,
ENG117871-MAS00106,VICS_Radio_Beacon_State-Year,2000,
ENG117871-MAS00107,VICS_Radio_Beacon_State-Month,0,
ENG117871-MAS00108,VICS_Radio_Beacon_State-Day,0,
ENG117871-MAS00109,VICS_Radio_Beacon_State-Hours,0,
ENG117871-MAS00110,VICS_Radio_Beacon_State-Minutes,0,
ENG117871-MAS00111,VICS_Radio_Beacon_State-Seconds,0,
ENG117871-MAS01632,VICS_Radio_Beacon_State-Status,Not available,
ENG117871-ENG117771,VICS_Radio_Beacon_State-vics_id,0,
Elapsed Time: 00:44,,,
blockmap-6C-5Q0-980-556-B_3VV2X7B28NM061887-20220618-1239.CSV
;SW:5Q0-980-556-B   HW:5Q0-980-556-B ---  Back-up Cam.
;Component:RVC Compact   H18 0231, Coding:01135602A2002017300040
;EV_CamSysRVRVCPANAMQBAB,006009,EV_CamSysRVRVCPANAMQBAB_006_VW37.rod
;Saturday,18,June,2022,12:39:06:14741
;VCID: B924C6AEE9DA8B9354C-80EC
IDE00019,Voltage terminal 30,12.53, V
IDE00303-MAS00222,Status: doors/lids 1-Rear lid,closed,
IDE00303-MAS00223,Status: doors/lids 1-Hood,Measuring value not available,
IDE00303-MAS01374,Status: doors/lids 1-Trailer,detected,
IDE00924-IDE08941,Steering angle-Rack position,0.000, mm
IDE00924-MAS02471,Steering angle-Sign,Negative,
IDE00924-MAS02983,Steering angle-Steering wheel angle,4.200, °
IDE00924,Steering angle,0.200, °
IDE00924-MAS10998,Steering angle-Rear-wheel drive: steering angle,0.000, °
IDE00924-MAS10999,Steering angle-Rear-wheel drive: sign,Positive,
IDE00924-MAS11000,Steering angle-Rack: sign,Positive,
IDE01714,Status reverse gear,not selected,
IDE03619,System condition,passive,
IDE07402,External activation,Not available,
MAS00037-MAS05746,Calibration status-Rearview camera calibration status,Calibration ended,
MAS00037-MAS05748,Calibration status-Rearview camera calibration progress,100, %
MAS00037-MAS05750,Calibration status-Rearview camera calibration repeat attempts,0,
MAS00037-MAS05753,Calibration status-Cause of rearview camera calibration error,No malfunction,
MAS00037-MAS05803,Calibration status-Rearview camera calibration resumption,No resumption,
MAS00464-MAS00106,Standard - ambient data 1-Year,2022,
MAS00464-MAS00107,Standard - ambient data 1-Month,6,
MAS00464-MAS00108,Standard - ambient data 1-Day,18,
MAS00464-MAS00109,Standard - ambient data 1-Hours,10,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,38,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,45,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,20, counts
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,156, km
ENG119197-ENG128717,camera_calibration_parameters-Cam0 Calibration binary threshold,00,
ENG119197-ENG119070,camera_calibration_parameters-Cam0 Calibration Result judgment,00 00 A0 40 00 00 A0 40 00 00 A0 40 00 00 A0 40 00 00 A0 40 00 00 A0 40 00 00 20 41,
ENG119197-ENG119060,camera_calibration_parameters-Cam0 Changing default data - Ground to Camera Z,0.00, mm
ENG119197-ENG119061,camera_calibration_parameters-Cam0 Changing default data - Ground to wheel arch Z,0.00, mm
ENG119197-ENG119068,camera_calibration_parameters-Cam0 division counts horizontal,1,
ENG119197-ENG119069,camera_calibration_parameters-Cam0 division counts vertical,0,
ENG119197-ENG119062,camera_calibration_parameters-Cam0 Fixed value input - Ground to Camera Z,0.00, mm
ENG119197-ENG119063,camera_calibration_parameters-Cam0 Fixed value input - Ground to wheel arch Z,759.75, mm
ENG119197-ENG119067,camera_calibration_parameters-Cam0 height of marker,20.00, mm
ENG119197-ENG119064,camera_calibration_parameters-Cam0 Marker size Full-size or Half-size,half size,
ENG119197-ENG119058,camera_calibration_parameters-Cam0 Transversal position front axle,0.00, mm
ENG119197-ENG119059,camera_calibration_parameters-Cam0 Transversal position rear axle,0.10, mm
ENG119197-ENG119065,camera_calibration_parameters-Cam0 X direction of marker red ribbon,4330.00, mm
ENG119197-ENG119066,camera_calibration_parameters-Cam0 Y direction of marker,0.00, mm
ENG119196-ENG119090,camera_calibration_tolerance-RV_Calibration_Result,0.94, px
ENG119196-ENG119084,camera_calibration_tolerance-RV_Calibration_Tolerance_alpha,-1.45, °
ENG119196-ENG119085,camera_calibration_tolerance-RV_Calibration_Tolerance_beta,0.64, °
ENG119196-ENG119086,camera_calibration_tolerance-RV_Calibration_Tolerance_gamma,0.75, °
ENG119196-ENG119087,camera_calibration_tolerance-RV_Calibration_Tolerance_x,0.00, mm
ENG119196-ENG119088,camera_calibration_tolerance-RV_Calibration_Tolerance_y,0.00, mm
ENG119196-ENG119089,camera_calibration_tolerance-RV_Calibration_Tolerance_z,7.62, mm
Elapsed Time: 00:05,,,
blockmap-75-5WA-035-285_3VV2X7B28NM061887-20220618-1239.CSV
;SW:5WA-035-285   HW:5WA-035-285 ---  Telematics
;Component:OCUGen3High   H12 0316, Coding:023160201968AC209005460160102607
;EV_OCUGen3High,003005,EV_OCUGen3High_003_VW37.rod
;Saturday,18,June,2022,12:39:15:14741
;VCID: 845A675ADE98067B77A-80D0
IDE00019,Voltage terminal 30,12.6, V
IDE00020,Terminal 15 status,On,
IDE00102,Control Module temperature,50, °C
IDE00608,Fuel type,Gas,
IDE00667-MAS03231,Microphone status-Microphone 1,electrically OK,
IDE00667-MAS03232,Microphone status-Microphone 2,Not available,
IDE00668-MAS03231,Microphone voltage consumption-Microphone 1,6.2, mA
IDE00668-MAS03232,Microphone voltage consumption-Microphone 2,0.0, mA
IDE00672,Roadside Assistance Button,Not operated,
IDE00673,Information Service Button -E450-,Not operated,
IDE00767,No. of unscheduled ECU resets,0,
IDE01215,Dimmer terminal 58d,Measuring value not available,
IDE01216,Dimmer terminal 58s,100, %
IDE01588,Driving direction,128, °
IDE01588-MAS01632,Driving direction-Status,available.,
IDE01625,Muting of radio/radio navigation system via control wire,not active,
IDE01630-MAS01167,Key illumination in telephone operating unit-Actuation time,0 s,
IDE01630-ENG170421,Key illumination in telephone operating unit-IoReached Status,Output diagnostic test not active,
IDE01631-MAS01167,Output of variable test tones via radio/radio navigation system-Actuation time,0 s,
IDE01631-ENG170421,Output of variable test tones via radio/radio navigation system-IoReached Status,Output diagnostic test not active,
IDE01712-IDE06673,GPS Position-Initialization status,initialized,
IDE01712-MAS02230,GPS Position-Height,290, m
IDE01718,Crash signal,No crash recognized,
IDE01770-MAS01632,Status of GPS antenna-Status,OK,
IDE01770-MAS01808,Status of GPS antenna-Antenna current,25, mA
IDE01971,Lowest recorded control module temperature,10, °C
IDE01972,Highest recorded control module temperature,63, °C
IDE02067-IDE00690,Antenna for telephone status-Connection to antenna,electrically OK,
IDE02067-MAS01808,Antenna for telephone status-Antenna current,38, µA
IDE02067-MAS03991,Antenna for telephone status-Reception level antenna 1,66, %
IDE02326-ENG117459,GPS signal strength-ID_GPS_satellite_no_1,2,
IDE02326-ENG117461,GPS signal strength-ID_GPS_satellite_no_2,3,
IDE02326-ENG117463,GPS signal strength-ID_GPS_satellite_no_3,6,
IDE02326-ENG117465,GPS signal strength-ID_GPS_satellite_no_4,11,
IDE02326-ENG117460,GPS signal strength-S/N_GPS_satellite_no_1,50, dBµV
IDE02326-ENG117462,GPS signal strength-S/N_GPS_satellite_no_2,47, dBµV
IDE02326-ENG117464,GPS signal strength-S/N_GPS_satellite_no_3,51, dBµV
IDE02326-ENG117466,GPS signal strength-S/N_GPS_satellite_no_4,50, dBµV
IDE03477-MAS00110,GPS time-Minutes,39,
IDE03477-MAS00111,GPS time-Seconds,15,
IDE04293,Operating state for emer call module,registerstate_registered,
IDE04750-MAS03876,SIM card-active SIM card,internal,
IDE04750-MAS03878,SIM card-SIM IMSI,311480779606303,
IDE04750-MAS04226,SIM card-Telephone number,               ,
IDE04750-MAS08401,SIM card-SIM intern,operational,
IDE04750-MAS08402,SIM card-SIM extern,Unknown,
IDE04750-MAS11003,SIM card-ICCID,89148000008169850660,
IDE04750-MAS11004,SIM card-UICCID,89033023312150000000006371859879,
IDE04790,Call for help button,Not operated,
IDE05430,Telephone serial number,015279003912188,
IDE05431-MAS01167,Lock for high-voltage charging connector-Actuation time,0 s,
IDE05431-ENG170421,Lock for high-voltage charging connector-IoReached Status,Output diagnostic test not active,
IDE07007-MAS01167,Air conditioning/heating function via remote control-Actuation time,0 s,
IDE07007-ENG170421,Air conditioning/heating function via remote control-IoReached Status,Output diagnostic test not active,
IDE07589-IDE07590,Update programming: status-Currently processed module,24,
IDE07589-IDE07591,Update programming: status-Number of modules to be programmed,28,
IDE07589-MAS00106,Update programming: status-Year,2000,
IDE07589-MAS00107,Update programming: status-Month,0,
IDE07589-MAS00108,Update programming: status-Day,0,
IDE07589-MAS00109,Update programming: status-Hours,0,
IDE07589-MAS00110,Update programming: status-Minutes,0,
IDE07589-MAS00111,Update programming: status-Seconds,0,
IDE07911-MAS01167,Microphone signal via audio output-Actuation time,0 s,
IDE07911-ENG170421,Microphone signal via audio output-IoReached Status,Output diagnostic test not active,
IDE07975-MAS01167,Remote control for charging function of high-voltage battery-Actuation time,0 s,
IDE07975-ENG170421,Remote control for charging function of high-voltage battery-IoReached Status,Output diagnostic test not active,
IDE08156-MAS01167,Transmission of configuration for online services-Actuation time,0 s,
IDE08156-ENG170421,Transmission of configuration for online services-IoReached Status,Output diagnostic test not active,
IDE08235-MAS06798,Status of immobilizer participant-Key / terminal status,04,
IDE08235-MAS06799,Status of immobilizer participant-Immobiliser status,00,
IDE08235-MAS06800,Status of immobilizer participant-Status MSG 1,00,
IDE08235-MAS06801,Status of immobilizer participant-Status MSG 2,00,
IDE08235-MAS06802,Status of immobilizer participant-Status MSG 3,00,
IDE08235-MAS06803,Status of immobilizer participant-Status MSG 4,00,
IDE08235-MAS06804,Status of immobilizer participant-Status TCM,00,
IDE08235-MAS06805,Status of immobilizer participant-Status ESCL,00,
IDE08235-MAS06806,Status of immobilizer participant-Status OCU,00,
IDE08235-MAS06807,Status of immobilizer participant-Status VTS,00,
IDE08236-MAS06808,Status locking periods immobilizer-Lock time download,00,
IDE08236-MAS06809,Status locking periods immobilizer-Reset lock time passwords,00,
IDE08236-MAS06810,Status locking periods immobilizer-Lock time login terminal 15 on,00,
IDE08236-MAS06811,Status locking periods immobilizer-Lock time login learn keys,00,
IDE08236-MAS06812,Status locking periods immobilizer-Lock time login leave learn keys,00,
IDE08236-MAS06813,Status locking periods immobilizer-Lock time login special functions,00,
IDE08237-MAS06814,Status Secure Hardware Extension-SHE counter,00 00 01 01,
IDE08237-MAS06815,Status Secure Hardware Extension-SHE key number,6, s
IDE08251-MAS06847,Configuration immobilizer-Snapshot,53 00 00 00 00 00 00 00 05 63 00 00 00 00 00 0C 03 00 3C,
IDE08343,Immobilizer Challenge,B9 CD CF 7D,
IDE09293-IDE00690,Status of antenna 2 for phone-Connection to antenna,electrically OK,
IDE09293-MAS01808,Status of antenna 2 for phone-Antenna current,39, µA
IDE09293-MAS03991,Status of antenna 2 for phone-Reception level antenna 1,66, %
IDE11307-IDE01839,eCall battery status-Battery charge level,99, %
IDE11307-MAS08415,eCall battery status-Battery status,normal,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FE 80 00 00 00 00 00 00 32 B4 B8 FF FE C9 9F 14|FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 00 67|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 02 00 00 00 00 00 00 00 00 00 01 FF 00 00 00|FF 02 00 00 00 00 00 00 00 00 00 01 FF C9 9F 14|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 02|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 01 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 09|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 50|FF 02 00 00 00 00 00 00 00 00 00 01 FF 00 00 67|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|4|,
IDE11756,IP network: counter messages with inadmissible VLANs,0,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,355,
IDE11759,IP network: counter messages with inadmissible TCP ports,0,
IDE11760,IP network: counter messages with inadmissible UDP ports,355,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|30 B4 B8 C9 9F 14|,
IDE11869,IP network: NDP cache,|MAC address,IPv6 address
IDE11988-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 1-MAC address,|MAC address|30 B4 B8 B9 F2 A8|,
IDE12231-MAS14856,IP network: VLANs of Ethernet switch ports branch 2-VLAN,|VLAN|4|,
IDE12238,I network: discarded messages counter,40,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 00 73
IDE12732,Button for ERA/Glonass test,Not available,
IDE13159-MAS01167,Loudspeaker test for emergency call module-Actuation time,0 s,
IDE13159-ENG170421,Loudspeaker test for emergency call module-IoReached Status,Output diagnostic test not active,
IDE13593-MAS07135,Emergency call SIM profile-Activation status,not activated,
IDE13593-MAS07967,Emergency call SIM profile-profile,Not available,
IDE13593-MAS11003,Emergency call SIM profile-ICCID,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,12,
IDE13957-MAS00106,Mobile Online Service: connection status-Year,2022, yr
IDE13957-MAS00107,Mobile Online Service: connection status-Month,5, Months
IDE13957-MAS00108,Mobile Online Service: connection status-Day,31, d
IDE13957-MAS00109,Mobile Online Service: connection status-Hours,8, H
IDE13957-MAS00110,Mobile Online Service: connection status-Minutes,12, min
IDE13957-MAS00111,Mobile Online Service: connection status-Seconds,57, s
IDE13957-MAS00976,Mobile Online Service: connection status-Counter,0,
IDE13957-MAS07131,Mobile Online Service: connection status-ID steps,0,
IDE13957-MAS07132,Mobile Online Service: connection status-Code status,30,
IDE13957-MAS16770,Mobile Online Service: connection status-Year (UTC: universal time coordinated),2022, yr
IDE13957-MAS16772,Mobile Online Service: connection status-Month (UTC: universal time coordinated),5, Months
IDE13957-MAS16773,Mobile Online Service: connection status-Day (UTC: universal time coordinated),31, d
IDE13957-MAS16774,Mobile Online Service: connection status-Hour (UTC: universal time coordinated),14, H
IDE13957-MAS16775,Mobile Online Service: connection status-Minute (UTC: universal time coordinated),13, min
IDE13957-MAS16776,Mobile Online Service: connection status-Seconds (UTC: universal time coordinated),12, s
IDE13957-ENG151979,Mobile Online Service: connection status-Server_HTTP_Status_Code_Textual,Data connection established,
IDE13958-MAS00106,Mobile Online Service: service status-Year,2255, yr
IDE13958-MAS00107,Mobile Online Service: service status-Month,255, Months
IDE13958-MAS00108,Mobile Online Service: service status-Day,255, d
IDE13958-MAS00109,Mobile Online Service: service status-Hours,255, H
IDE13958-MAS00110,Mobile Online Service: service status-Minutes,255, min
IDE13958-MAS00111,Mobile Online Service: service status-Seconds,255, s
IDE13958-MAS07134,Mobile Online Service: service status-ID services,cc_breakdown_v2,
IDE13958-MAS07135,Mobile Online Service: service status-Activation status,Not available,
IDE13958-MAS07136,Mobile Online Service: service status-Exp. year,2000, yr
IDE13958-MAS07137,Mobile Online Service: service status-Exp. month,1, Months
IDE13958-MAS07138,Mobile Online Service: service status-Exp. day,1, d
IDE13958-MAS16770,Mobile Online Service: service status-Year (UTC: universal time coordinated),2255, yr
IDE13958-MAS16772,Mobile Online Service: service status-Month (UTC: universal time coordinated),255, Months
IDE13958-MAS16773,Mobile Online Service: service status-Day (UTC: universal time coordinated),255, d
IDE13958-MAS16774,Mobile Online Service: service status-Hour (UTC: universal time coordinated),255, H
IDE13958-MAS16775,Mobile Online Service: service status-Minute (UTC: universal time coordinated),255, min
IDE13958-MAS16776,Mobile Online Service: service status-Seconds (UTC: universal time coordinated),255, s
IDE13958-ENG246084,Mobile Online Service: service status-status_last_fail,65535,
IDE13958-ENG246255,Mobile Online Service: service status-status_last_ok,65535,
IDE13958-ENG246120,Mobile Online Service: service status-status_second_last_fail,65535,
IDE13958-ENG246279,Mobile Online Service: service status-status_second_last_ok,65535,
MAS00077-MAS02345,Immobilizer-Current condition,02,
MAS00077-MAS06790,Immobilizer-Identity counter,01,
MAS00077-MAS06791,Immobilizer-Mark detection,03,
MAS00077-MAS06792,Immobilizer-P class,63,
MAS00077-MAS06793,Immobilizer-Number of adapted keys,00,
MAS00077-MAS06794,Immobilizer-Number of keys to be adapted via service download,00,
MAS00077-MAS06795,Immobilizer-Number of keys to be adapted adapt service keys,00,
MAS00077-MAS06796,Immobilizer-Remaining time to switch on terminal 15,00,
MAS00077-MAS06797,Immobilizer-Status configuration,04,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,39,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,19,
MAS01490-MAS08403,Energy management-Remaining short term energy budget,827, mAh
MAS01490-MAS08404,Energy management-Remaining long term energy budget,3600, mAh
MAS01490-MAS08405,Energy management-Wake up cycles counter,156,
MAS03615-MAS01167,Connection setup-Actuation time,0 s,
MAS03615-ENG170421,Connection setup-IoReached Status,Output diagnostic test not active,
MAS04394-IDE03580,Connection status-Country recognition for mobile network,311,
MAS04394-IDE07699,Connection status-Mobile network operator,480,
MAS04394-MAS03991,Connection status-Reception level antenna 1,66, %
MAS04394-MAS04460,Connection status-Validity,valid,
MAS04394-MAS08406,Connection status-Network type,LTE,
MAS04394-MAS08407,Connection status-Data connection,active,
MAS04394-ENG123307,Connection status-Radio_Cell_Number,118528790,
MAS04394-ENG123308,Connection status-TCP_Connection_State,active,
MAS06413,Audio signal output,electrically OK,
MAS08178-IDE05253,Crash information-Front crash,No,
MAS08178-IDE05254,Crash information-Side crash on driver side,No,
MAS08178-IDE05255,Crash information-Side crash on frt.pass.side,No,
MAS08178-IDE05256,Crash information-Rear crash,No,
MAS08178-IDE05257,Crash information-Rollover crash,No,
MAS08178-MAS08636,Crash information-Automatic emergency call activated:Accident sensor,No,
MAS08200,Emergency call speaker status,electrically OK,
MAS08374-MAS01167,Remote control for lights and horn-Actuation time,0 s,
MAS08374-ENG170421,Remote control for lights and horn-IoReached Status,Output diagnostic test not active,
MAS13076-MAS12732,Error valid: error path traversed-Dataset download,full working order,
MAS13076,Error valid: error path traversed,Active diagnosis,
MAS16678-MAS01167,Test mode for emergency call-Actuation time,0 s,
MAS16678-ENG170421,Test mode for emergency call-IoReached Status,Output diagnostic test not active,
MAS18799-MAS01167,Radio / radio navigation system muting test-Actuation time,0 s,
MAS18799-ENG170421,Radio / radio navigation system muting test-IoReached Status,Output diagnostic test not active,
MAS18800,Version of audio dataset used,M3P0,
MAS19234,Status of user-related refresh tokens,invalid,
MAS19235,Back end (MBB) active user ID,#anonymousGuest#              ,
MAS19236-MAS00106,Expiration date of user-related refresh tokens-Year,2000,
MAS19236-MAS00107,Expiration date of user-related refresh tokens-Month,0,
MAS19236-MAS00108,Expiration date of user-related refresh tokens-Day,0,
MAS19237,Status of user-related safety pin in vehicle,locked,
MAS19245-MAS19246,Safety mode-Safety mode status,OFF,
MAS19247-MAS19256,Authentication stage-User-related instantaneous authentication stage,0,
MAS19248-MAS19257,User role-User role for active user,Main user,
MAS19255-MAS19238,Status of user image for current user-Image reference value,00 00,
MAS19270,Parameter list,|Parameter ID,Data description
MAS19273,Shadow drive metadata,|User ID,Year
MAS19295,Historical memory for synchronization,Write only channel,
MAS19313,BAP historical memory,|Year,Month
MAS19326,CAN signals for OCU customization,|Year,Month
ENG123206,Antenna_Switch,LTE antenna 1,
ENG254564-ENG255490,Backup_Battery_SoH-BUB_ci,79.550,
ENG254564-ENG256057,Backup_Battery_SoH-mcharge_time,0, s
ENG254564-ENG256085,Backup_Battery_SoH-mSoH,100,
ENG254564-ENG256302,Backup_Battery_SoH-rSoH,99,
ENG125913,Hybrid_Type,no_Hybrid_Car,
ENG123205,Incoming_call_line_state,Idle,
ENG117422,IP_Address,100.105.230.61,
ENG123203-ENG123321,Network_Statistics-CRC_Errors,120,
ENG123203-ENG123320,Network_Statistics-DNS_Resolution,1040,
ENG123203-ENG123324,Network_Statistics-DNS_Resolution_Error,No malfunction,
ENG123203-ENG124655,Network_Statistics-Duration_Of_Voice_Calls,123932676, min
ENG123203-ENG123319,Network_Statistics-Established_TCP_Connections,16,
ENG123203-ENG123326,Network_Statistics-HTTP_Transmission_Error,No malfunction,
ENG123203-ENG123317,Network_Statistics-Interrupted_TCP_Connections,120,
ENG123203-ENG123323,Network_Statistics-Network_Timeout_Error,No malfunction,
ENG123203-ENG123315,Network_Statistics-Number_Of_Events,13873,
ENG123203-ENG123330,Network_Statistics-Number_Of_Failed_DNS_Requests,4096,
ENG123203-ENG123332,Network_Statistics-Number_Of_Failed_HTTP_Requests,1860,
ENG123203-ENG123331,Network_Statistics-Number_Of_Failed_PDP_Connections,53667,
ENG123203-ENG123333,Network_Statistics-Number_Of_Failed_Secure_Connections,4100,
ENG123203-ENG123328,Network_Statistics-Number_Of_Failed_Transport_Protocol_Connections,0,
ENG123203-ENG123314,Network_Statistics-Number_Of_Jobs,12334,
ENG123203-ENG123329,Network_Statistics-Number_Of_Network_Timeouts,4100,
ENG123203-ENG123316,Network_Statistics-Number_Of_Packet_Data_Connection_Failures,16,
ENG123203-ENG123311,Network_Statistics-Number_Of_Voice_Calls,12592,
ENG123203-ENG123325,Network_Statistics-PDP_Connection_Error,No malfunction,
ENG123203-ENG123318,Network_Statistics-Rejected_TCP_Connections,0,
ENG123203-ENG123334,Network_Statistics-Round_Trip_Time,4096, ms
ENG123203-ENG123327,Network_Statistics-Secure_Connection_Error,No malfunction,
ENG123203-ENG123313,Network_Statistics-Service_Data_Volume,892219955, B
ENG123203-ENG123335,Network_Statistics-SMS_Counter,53667,
ENG123203-ENG123312,Network_Statistics-Total_Data_Volume,808333616, B
ENG123203-ENG123322,Network_Statistics-Transport_Protocol_Connection_Error,No malfunction,
ENG245690,OCU_Internal_Status_Field,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG123204,Outgoing_call_line_state,Idle,
ENG247809,Position_Confidence,36, m
ENG157421-MAS04460,Scan_Network_List-Validity,valid,
ENG157421-MAS08406,Scan_Network_List-Network type,LTE,
ENG157421-MAS08406,Scan_Network_List-Network type,GSM,
ENG157421-MAS08406,Scan_Network_List-Network type,UMTS,
ENG157421-ENG159652,Scan_Network_List-Mobile_Country_Code,311,
ENG157421-ENG159652,Scan_Network_List-Mobile_Country_Code,313,
ENG157421-ENG159652,Scan_Network_List-Mobile_Country_Code,310,
ENG157421-ENG159760,Scan_Network_List-Mobile_Network_Code,589,
ENG157421-ENG159760,Scan_Network_List-Mobile_Network_Code,480,
ENG157421-ENG159760,Scan_Network_List-Mobile_Network_Code,490,
ENG157421-ENG159760,Scan_Network_List-Mobile_Network_Code,260,
ENG157421-ENG159760,Scan_Network_List-Mobile_Network_Code,100,
ENG157421-ENG159760,Scan_Network_List-Mobile_Network_Code,588,
ENG157421-ENG159760,Scan_Network_List-Mobile_Network_Code,580,
ENG157421-ENG159760,Scan_Network_List-Mobile_Network_Code,410,
ENG247812-ENG159329,Second_Last_Position-Latitude, 35°54'21.2"N,
ENG247812-ENG159328,Second_Last_Position-Longitude, 84° 6'40.8"W ,
ENG247822-ENG159329,Third_Last_Position-Latitude, 35°54'22.8"N,
ENG247822-ENG159328,Third_Last_Position-Longitude, 84° 6'41.3"W ,
ENG254851-MAS01779,VTT_First_GPS_fix-Length,---           ,
ENG254851-MAS01780,VTT_First_GPS_fix-Width,---           ,
ENG254851-MAS02230,VTT_First_GPS_fix-Height,65034, m
ENG254852,VTT_Last_SMS_Content,56 31 2E 30 3B 33 56 56 32 58 37 42 32 38 4E 4D 30 36 31 38 38 37 3B 30 30 30 37 3B 31 36 35 34 30 30 36 32 37 32 3B 67 6E 73 73 3A 28 2D 30 38 34 31 31 31 37 35 32 3B 30 33 35 39 30 35 39 37 38 29 3B 30 30 30 30 30 31 35 3B 64 65 61 6C 65 72 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
Elapsed Time: 01:02,,,
blockmap-A5-2Q0-980-653-C_3VV2X7B28NM061887-20220618-1240.CSV
;SW:2Q0-980-653-C   HW:2Q0-980-653 ---  Frt Sens. Drv. Assist
;Component:MQB MFK 3.0   H16 1302, Coding:00000A9011CE4020089F10001030002000418000000000000000000000000000
;EV_MFK3ValeoMQB,007042,EV_MFK3ValeoMQB_007_VW27.rod
;Saturday,18,June,2022,12:40:21:14741
;VCDS Version: Beta 22.4.0 (x64)  Data version: 20220407 DS338.0
;VCID: B53CCA9EC5C26FF3B04-80E0
Group,Description,Actual,
IDE00018,Voltage terminal 15,12.5, V
IDE00973,Outside temperature,30.5, °C
IDE01968,Dynamic calibration: yaw angle offset,-0.315, °
IDE01969,Dynamic calibration: pitch angle offset,0.000, °
IDE01970,Dynamic calibration: roll angle offset,-0.039, °
IDE01971,Lowest recorded control module temperature,13, °C
IDE01972,Highest recorded control module temperature,84, °C
IDE01974-MAS01167,Steering wheel vibration-Actuation time,0 s,
IDE01974-MAS08863,Steering wheel vibration-Status of actuator test,Actuator test terminated due to client request,
IDE02007-MAS01167,Yellow indicator light for directional stabilization assistance-Actuation time,0 s,
IDE02007-MAS08863,Yellow indicator light for directional stabilization assistance-Status of actuator test,Actuator test terminated due to client request,
IDE02008-MAS01167,Green indicator light for directional stabilization assistance-Actuation time,0 s,
IDE02008-MAS08863,Green indicator light for directional stabilization assistance-Status of actuator test,Actuator test terminated due to client request,
IDE02009-MAS01167,Directional stabilization assistance display-Actuation time,0 s,
IDE02009-MAS08863,Directional stabilization assistance display-Status of actuator test,Actuator test terminated due to client request,
IDE02057,Dynamic calibration: status,Passive values stored,
IDE02486,Data logger triggering,not initialized,
IDE02608-MAS01167,Window defogger for front sensor system-Actuation time,0 s,
IDE02608-MAS08863,Window defogger for front sensor system-Status of actuator test,Actuator test terminated due to client request,
IDE03222-MAS02534,Blindness detection-Clear view,Yes,
IDE03222-MAS03365,Blindness detection-Blind vehicle detection during darkness,No,
IDE03222-MAS03366,Blindness detection-Blind traffic sign detection,No,
IDE03222-MAS03399,Blindness detection-Blindness automatic distance control,No,
IDE03222-MAS09886,Blindness detection-Blind during pedestrian recognition,No,
IDE03222-MAS09887,Blindness detection-Blind during object recognition,No,
IDE03222-MAS09888,Blindness detection-Blind during lane recognition,No,
IDE03222-MAS10690,Blindness detection-Activation condition,activated,
IDE03222-MAS11902,Blindness detection-Blind DTC memory entry,No,
IDE03222-MAS17450,Blindness detection-Blindness: space detection,No,
IDE03222-MAS17452,Blindness detection-Windshield heater blindness request,No,
IDE03222-MAS17453,Blindness detection-Clear view currently detected,Yes,
IDE03354-MAS01632,Dynamic calibration: details-Status,No calibration relevant malfunction,
IDE03354-MAS02552,Dynamic calibration: details-Distance traveled with active dynamic calibration,54, km
IDE03948-MAS01167,High beam recommendation-Actuation time,0 s,
IDE03948-MAS08863,High beam recommendation-Status of actuator test,Actuator test terminated due to client request,
IDE04036-MAS01632,High beam assistant: status-Status,not active,
IDE04036-MAS17492,High beam assistant: status-Switching state,OFF,
IDE04036-MAS17493,High beam assistant: status-Sensor view,Not assigned,
IDE04036-MAS17494,High beam assistant: status-Higher sensitivity active,No,
IDE04123-MAS01480,High beam: reason for shut-off-excessive temperature,No,
IDE04123-MAS06833,High beam: reason for shut-off-Ambient brightness too high,No,
IDE04123-MAS06846,High beam: reason for shut-off-Location detected,No,
IDE04123-MAS14875,High beam: reason for shut-off-Fog detected,No,
IDE04123-MAS17489,High beam: reason for shut-off-Oncoming vehicle detected,No,
IDE04123-MAS17490,High beam: reason for shut-off-Vehicle ahead detected,No,
IDE04123-MAS17491,High beam: reason for shut-off-Speed not achieved,Yes,
IDE04123,High beam: reason for shut-off,0,
IDE04123,High beam: reason for shut-off,4,
IDE04227,Directional stab. asst w/ pwr steering asst: steering status,active,
IDE04229,Directional stab. asst w/ pwr steering asst: steering torque,-0.00, Nm
IDE04329-ENG118721,Status of all SWaP functions-SWaP_function_state array,|ID number,Release code for a SWaP function
IDE04332-ENG117770,Release code for a SWaP function-fsc,Not available,
IDE04904-MAS01167,Traffic sign display in instrument cluster-Actuation time,0 s,
IDE04904-MAS08863,Traffic sign display in instrument cluster-Status of actuator test,Actuator test terminated due to client request,
IDE05814,Individualization characteristic,A1 E0 C8 78 14,
IDE06592-MAS00478,Status: special functions-Reserved,00,
IDE06592-MAS18012,Status: special functions-Vehicle locking and unlocking via mobile online service,lock,
IDE06592-MAS18013,Status: special functions-Deactivation of extended start authentication,OFF,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,05,
IDE07145-MAS06776,Component protection properties-Komponent protection role,WFS Master,
IDE07145-MAS06786,Component protection properties-SSW RND Generation,used,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 01,
IDE07214,Dynamic calibration: camera height offset,-29, mm
IDE09433-MAS01632,Perception module for light assistant-Status,Deactivated,
IDE09433-MAS08885,Perception module for light assistant-Object 1 removal,1023, m
IDE09433-MAS08886,Perception module for light assistant-Object 2 removal,1023, m
IDE09433-MAS08887,Perception module for light assistant-Object 1 horizontal position,25.650001, °
IDE09433-MAS08888,Perception module for light assistant-Object 2 horizontal position,25.650001, °
IDE09433-MAS08889,Perception module for light assistant-Object 1 vertical position,35.150001, °
IDE09433-MAS08890,Perception module for light assistant-Object 2 vertical position,35.150001, °
IDE09433-MAS08891,Perception module for light assistant-Object 1 horizontal expansion,51.15, °
IDE09433-MAS08892,Perception module for light assistant-Object 2 horizontal expansion,51.15, °
IDE09433-MAS08893,Perception module for light assistant-Object 1 ID,Not available,
IDE09433-MAS08894,Perception module for light assistant-Object 2 ID,Not available,
IDE09433-MAS08895,Perception module for light assistant-Object 1 replacement value,Not available,
IDE09433-MAS08896,Perception module for light assistant-Object 2 replacement value,Not available,
IDE09433-MAS08903,Perception module for light assistant-Object 1 Object type,Not available,
IDE09433-MAS08904,Perception module for light assistant-Object 2 Object type,Not available,
IDE09433-MAS08905,Perception module for light assistant-Object 1 Object quality,<= 50%,
IDE09433-MAS08906,Perception module for light assistant-Object 2 Object quality,<= 50%,
IDE09433-MAS08907,Perception module for light assistant-Cause for passive switching,active,
IDE09436,Recognized street illumination,no streetlight,
IDE09438,Drive sequence,Right hand driv.,
IDE09492-MAS11790,Temperatures-Control Module temperature,72, °C
IDE09492-MAS17447,Temperatures-Temperature of the EyeQ chip,77, °C
IDE09492-MAS17448,Temperatures-Temperature of the memory in the EyeQ chip,75, °C
IDE09492-MAS17449,Temperatures-High temperature shutdown,OFF,
IDE10220,Initial online calibration active,not active,
IDE10403,Current initial calibration: status,Initial static calibration EOL OK.,
IDE10404-MAS10704,Dynamic calibration: quality-Dynamic calibration: yaw angle offset quality,0.0000,
IDE10404-MAS10705,Dynamic calibration: quality-Dynamic calibration: pitch angle offset quality,0.0000,
IDE10404-MAS10706,Dynamic calibration: quality-Dynamic calibration: roll angle offset quality,0.0000,
IDE10404-MAS10707,Dynamic calibration: quality-Dynamic calibration: camera height offset quality,0.0000,
IDE10405-MAS10708,Initial dynamic calibration: details-Initial dynamic calibration: roll angle,0.000, °
IDE10405-MAS10709,Initial dynamic calibration: details-Initial dynamic calibration: roll angle quality,0.0000,
IDE10405-MAS10710,Initial dynamic calibration: details-Initial dynamic calibration: pitch angle,0.000, °
IDE10405-MAS10711,Initial dynamic calibration: details-Initial dynamic calibration: pitch angle quality,0.0000,
IDE10405-MAS10712,Initial dynamic calibration: details-Initial dynamic calibration: yaw angle,0.000, °
IDE10405-MAS10713,Initial dynamic calibration: details-Initial dynamic calibration: yaw angle quality,0.0000,
IDE10405-MAS10714,Initial dynamic calibration: details-Initial dynamic calibration: Camera height,1200, mm
IDE10405-MAS10715,Initial dynamic calibration: details-Initial dynamic calibration: Camera height quality,0.0000,
IDE10405-MAS10716,Initial dynamic calibration: details-Distance traveled with active initial calibration,0,
IDE10406-MAS00106,Last initial calibrations: details-Year,2022,
IDE10406-MAS00107,Last initial calibrations: details-Month,3,
IDE10406-MAS00108,Last initial calibrations: details-Day,16,
IDE10406-MAS00109,Last initial calibrations: details-Hours,20,
IDE10406-MAS00110,Last initial calibrations: details-Minutes,30,
IDE10406-MAS00111,Last initial calibrations: details-Seconds,7,
IDE10406-MAS10994,Last initial calibrations: details-Last initial calibration: error code,No calibration relevant malfunction,
IDE10547,Status of camera,Camera operating,
IDE10664-MAS00106,Current initial calibration: details-Year,2022,
IDE10664-MAS00107,Current initial calibration: details-Month,3,
IDE10664-MAS00108,Current initial calibration: details-Day,16,
IDE10664-MAS00109,Current initial calibration: details-Hours,20,
IDE10664-MAS00110,Current initial calibration: details-Minutes,30,
IDE10664-MAS00111,Current initial calibration: details-Seconds,7,
IDE10664-MAS00711,Current initial calibration: details-Odometer reading,0,
IDE10664-MAS01632,Current initial calibration: details-Status,No calibration relevant malfunction,
IDE10664-MAS02541,Current initial calibration: details-Rear projection fault,0,
IDE10664-MAS02542,Current initial calibration: details-Calibration marks,00111111 ,
IDE10664-MAS02543,Current initial calibration: details-VIN determined during calibration,3VV2X7B28NM061887,
IDE10664,Current initial calibration: details,00111111 ,
IDE10664,Current initial calibration: details,00110011 ,
IDE10924-MAS02479,Initial calibration: result-Yaw angle,1.233, °
IDE10924-MAS05286,Initial calibration: result-Roll angle,0.526, °
IDE10924-MAS05287,Initial calibration: result-Pitch angle,-0.405, °
IDE10924-MAS10678,Initial calibration: result-Camera height,1465, mm
IDE12939-MAS02643,Public key for SWaP function (3072)-Key,A1 3C 3F 3E DB 3B C7 26 46 C8 A4 60 86 76 E2 B2 7C 49 E0 E1 7A 1D 94 D7 C5 3B C1 67 2D A4 14 CC CE 63 6F 13 57 0D FE 90 D7 72 D3 56 2B 8C 68 43 6E 73 E2 EE 50 F7 11 EE 51 46 49 F7 16 0E CB 5B 98 D2 66 93 17 79 C4 43 92 9A A9 A5 57 8A EC F1 CD FC 78 C7 97 B0 84 0E A8 B0 B0 FF 3C 28 8C 12 45 E1 7D 0E 3B 73 4E DD DF 49 90 9E 8E 8C 19 6A A7 F7 AC D9 2C 26 5D B5 E4 B2 68 17 B3 C3 76 73 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE13994-MAS17458,Intrinsic calibration: result-Main point x,645.51, px
IDE13994-MAS17463,Intrinsic calibration: result-Main point y,543.72, px
IDE13994-MAS17464,Intrinsic calibration: result-Focal length x,1457.86, px
IDE13994-MAS17465,Intrinsic calibration: result-Focal length y,1457.86, px
IDE13994-MAS17466,Intrinsic calibration: result-Distortion in k1,-0.000468891,
IDE13994-MAS17467,Intrinsic calibration: result-Distortion in k2,-0.000363679,
IDE13994-MAS17468,Intrinsic calibration: result-Distortion in k3,-0.000638848,
IDE13994-MAS17469,Intrinsic calibration: result-Distortion in t1,-0.000000000,
IDE13994-MAS17470,Intrinsic calibration: result-Distortion in t2,-0.000000000,
IDE13994-MAS17471,Intrinsic calibration: result-Gamma,1.00,
IDE13994-MAS17472,Intrinsic calibration: result-Incline,0.00, px
IDE13995-MAS08824,Calibration target position: stored values-Target 1: calibration mark 1: x-coordinate,2460.00, mm
IDE13995-MAS08825,Calibration target position: stored values-Target 1: calibration mark 1: y-coordinate,733.00, mm
IDE13995-MAS08826,Calibration target position: stored values-Target 1: calibration mark 1: z-coordinate,1693.00, mm
IDE13995-MAS08827,Calibration target position: stored values-Target 1: calibration mark 2: x-coordinate,2460.00, mm
IDE13995-MAS08828,Calibration target position: stored values-Target 1: calibration mark 2: y-coordinate,-733.00, mm
IDE13995-MAS08829,Calibration target position: stored values-Target 1: calibration mark 2: z-coordinate,1693.00, mm
IDE13995-MAS08830,Calibration target position: stored values-Target 1: calibration mark 3: x-coordinate,2460.00, mm
IDE13995-MAS08831,Calibration target position: stored values-Target 1: calibration mark 3: y-coordinate,733.00, mm
IDE13995-MAS08832,Calibration target position: stored values-Target 1: calibration mark 3: z-coordinate,1107.00, mm
IDE13995-MAS08833,Calibration target position: stored values-Target 1: calibration mark 4: x-coordinate,2460.00, mm
IDE13995-MAS08834,Calibration target position: stored values-Target 1: calibration mark 4: y-coordinate,-733.00, mm
IDE13995-MAS08835,Calibration target position: stored values-Target 1: calibration mark 4: z-coordinate,1107.00, mm
IDE13996-IDE05717,Axle offset: stored values-Front axle transverse position,-0.2, mm
IDE13996-IDE05718,Axle offset: stored values-Rear axle transverse position,-0.8, mm
IDE13997-IDE02001,Body height to wheel house edge: stored values-Body height left front wheel house edge,758.25, mm
IDE13997-IDE02002,Body height to wheel house edge: stored values-Body height right front wheel house edge,762.00, mm
IDE13997-IDE02003,Body height to wheel house edge: stored values-Body height left rear wheel house edge,758.50, mm
IDE13997-IDE02004,Body height to wheel house edge: stored values-Body height right rear wheel house edge,761.00, mm
IDE13998,Distance to calibration field: stored values,1500.00, mm
IDE14000,Windshield defogger camera: activation status,OFF,
MAS01634-MAS09193,Supply voltage-PLA,12.5, V
MAS01634-MAS17440,Supply voltage-Supply voltage 1V0,1.0, V
MAS01634-MAS17441,Supply voltage-Supply voltage 1V1,1.0, V
MAS01634-MAS17442,Supply voltage-Supply voltage 1V2,0.0, V
MAS01634-MAS17443,Supply voltage-Supply voltage 1V25,1.2, V
MAS01634-MAS17444,Supply voltage-Supply voltage 1V8,1.7, V
MAS01634-MAS17445,Supply voltage-Supply voltage 3V3,3.3, V
MAS01634-MAS17446,Supply voltage-Supply voltage 5V0,5.0, V
MAS11502-MAS10691,Self-glare recognition-Self-glare quality,0, %
MAS11502-MAS11503,Self-glare recognition-Self-glare status,active,
MAS11502-MAS15965,Self-glare recognition-Glare detected,No,
MAS17473,Functional state and lane boundary information,1,
MAS19593-MAS01167,Upload for expanded static navigation data activation-Actuation time,0 s,
MAS19593-MAS08863,Upload for expanded static navigation data activation-Status of actuator test,Actuator test terminated due to client request,
MAS19594-MAS01167,Upload for expanded dynamic navigation data activation-Actuation time,0 s,
MAS19594-MAS08863,Upload for expanded dynamic navigation data activation-Status of actuator test,Actuator test terminated due to client request,
ENG152732-MAS06854,CRC32 Checksum of FAZIT Identification String-Version,81,
ENG152732-MAS06855,CRC32 Checksum of FAZIT Identification String-Test sum,CA 18 AC CF,
ENG106922,Immobilizer - Challenge,9B E7 60 48,
ENG185847-MAS01167,Light_assist_blockage_detection-Actuation time,0 s,
ENG185847-MAS08863,Light_assist_blockage_detection-Status of actuator test,Actuator test terminated due to client request,
ENG185858-MAS01167,Light_assist_self_glare_detection-Actuation time,0 s,
ENG185858-MAS08863,Light_assist_self_glare_detection-Status of actuator test,Actuator test terminated due to client request,
ENG185848-MAS01167,Main_beam_defect_message-Actuation time,0 s,
ENG185848-MAS08863,Main_beam_defect_message-Status of actuator test,Actuator test terminated due to client request,
ENG251654-MAS01167,REM_Dynamic_EyeQ_Data_Test_Trigger_status-Actuation time,0 s,
ENG251654-MAS08863,REM_Dynamic_EyeQ_Data_Test_Trigger_status-Status of actuator test,Actuator test terminated due to client request,
ENG251655-MAS01167,REM_Static_EyeQ_Data_Test_Trigger_status-Actuation time,0 s,
ENG251655-MAS08863,REM_Static_EyeQ_Data_Test_Trigger_status-Status of actuator test,Actuator test terminated due to client request,
ENG185865-MAS01167,SAE_mode_activation-Actuation time,0 s,
ENG185865-MAS08863,SAE_mode_activation-Status of actuator test,Actuator test terminated due to client request,
Elapsed Time: 00:41,,,
blockmap-CA-4K0-907-594-AC_3VV2X7B28NM061887-20220618-1241.CSV
;SW:4K0-907-594-AC   HW:4K0-907-594 ---  Sunroof
;Component:SAD_STG_1     006 0002, Coding:00804073163C
;EV_SunRoofCONTIAU736,009011,EV_SunRoofCONTIAU736_009_VW37.rod
;Saturday,18,June,2022,12:41:08:14741
;VCID: F5BC0A9E85422FF3704-80A0
IDE03114-MAS02447,Comfort function-Release,not installed,
IDE03114-MAS08867,Comfort function-Request open sliding sunroof,not active,
IDE03114-MAS08868,Comfort function-Request close sliding sunroof,not active,
IDE03114-MAS08869,Comfort function-Request open sunroof shade,not active,
IDE03114-MAS08870,Comfort function-Request close sunroof shade,not active,
IDE03421-MAS09452,Hall sensors for position detection-Hall sensor for sunroof motor,Not operated,
IDE03421-MAS09453,Hall sensors for position detection-Sunroof motor Hall sensor 2,Not operated,
IDE03421-MAS09454,Hall sensors for position detection-Hall sensor for roof blind motor,Not operated,
IDE03421-MAS09455,Hall sensors for position detection-Hall sensor 2 for roof blind motor,Not operated,
IDE09422-MAS02282,Roof shade-Position,0, %
IDE09422-MAS05370,Roof shade-Direction of movement,Not moving,
IDE09422-MAS05563,Roof shade-Norming,standardized,
IDE09422-MAS08536,Roof shade-Excessive temperature protection,not active,
IDE09422-MAS08862,Roof shade-Reversing,not active,
IDE09422-MAS08866,Roof shade-Adaption depth,not installed,
IDE09423-MAS02282,Sunroof-Position,0, %
IDE09423-MAS05370,Sunroof-Direction of movement,Not moving,
IDE09423-MAS05563,Sunroof-Norming,standardized,
IDE09423-MAS05737,Sunroof-Position,Tilt out posi.,
IDE09423-MAS08536,Sunroof-Excessive temperature protection,not active,
IDE09423-MAS08862,Sunroof-Reversing,not active,
IDE09423-MAS08866,Sunroof-Adaption depth,not installed,
IDE09427-MAS08536,Control module counter readings-Excessive temperature protection,0,
IDE09427-MAS08872,Control module counter readings-Resets due to interruption of supply voltage,12,
IDE09427-MAS08873,Control module counter readings-Resets to hardware watchdog,5,
IDE09427-MAS08874,Control module counter readings-Resets due to software watchdog,0,
IDE09428-MAS05563,Sunroof counter readings-Norming,4,
IDE09428-MAS08536,Sunroof counter readings-Excessive temperature protection,0,
IDE09428-MAS08862,Sunroof counter readings-Reversing,2,
IDE09428-MAS10406,Sunroof counter readings-Opening runs: sliding pos.,10,
IDE09428-MAS10407,Sunroof counter readings-Opening runs: tilted pos.,3,
IDE09428-MAS10408,Sunroof counter readings-Closing runs,12,
IDE09429-MAS05563,Sunroof shade counter readings-Norming,2,
IDE09429-MAS08536,Sunroof shade counter readings-Excessive temperature protection,0,
IDE09429-MAS08862,Sunroof shade counter readings-Reversing,1,
IDE09429-MAS08871,Sunroof shade counter readings-Opening cycles,12,
IDE09430,History data sunroof reversing,|Year,Month
IDE09431,History data sunroof shade reversing,|Year,Month
IDE09492-MAS01155,Temperatures-Control module,46.00, °C
IDE09492-MAS06997,Temperatures-Outside temperature: filtered,30.50, °C
IDE09492-MAS09033,Temperatures-Motor for sunroof,47.00, °C
IDE09492-MAS09047,Temperatures-Roof shade motor,47.00, °C
IDE09515-MAS08884,Controls-Sunroof button,Not operated,
IDE09515-MAS08932,Controls-Sunroof shade button,Not operated,
IDE09515-MAS08992,Controls-Button for sliding roof,Not operated,
IDE09515-MAS12701,Controls-Background lighting,Current cannot be measured,
IDE09516-MAS04194,Status of child safety-Driver side,not active,
IDE09516-MAS04195,Status of child safety-Front passenger side,not active,
IDE09517-IDE00075,Control module-Vehicle speed,0.00, km/h
IDE09517-MAS02447,Control module-Release,present,
IDE09517-MAS07376,Control module-Terminal 58xd,Not available,
IDE09517-MAS07720,Control module-Terminal 15 via CAN,On,
IDE09517-MAS08536,Control module-Excessive temperature protection,not active,
IDE09517-MAS09820,Control module-Terminal 58xt,100, %
IDE09517-MAS11498,Control module-Search illumination for control elements,0, %
IDE09517-MAS11499,Control module-Indicator lamp for rear sunroof,not installed,
IDE09518-MAS01634,Voltages and currents-Supply voltage,12.60, V
IDE09518-MAS09048,Voltages and currents-Motor current consumption for sun roof,0.00, A
IDE09518-MAS09049,Voltages and currents-Motor current consumption for roof blind,0.00, A
IDE09844,History data sunroof standardization,|Year,Month
IDE09845,History data roof blind standardization,|Year,Month
IDE09846,History data sunroof control point,|Year,Month
IDE11840-MAS13333,Operating signals for sunroof/tilt roof and roof blind-Operating signals of roof shade,Unknown (255),
IDE11840-MAS13334,Operating signals for sunroof/tilt roof and roof blind-Front operating signals: rear roof shade,Unknown (255),
IDE11840-MAS13335,Operating signals for sunroof/tilt roof and roof blind-Rear operating signals: rear roof shade,Unknown (255),
IDE11840-MAS13364,Operating signals for sunroof/tilt roof and roof blind-Operating signal sliding/tilting roof,Unknown (255),
IDE12985-MAS15419,Operating signals: rear door control modules-Operating signal: rear: driver side sliding/tilting sunroof,Not operated,
IDE12985-MAS15420,Operating signals: rear door control modules-Operating signal: rear: passenger side sliding/tilting sunroof,Not operated,
IDE12985-MAS15421,Operating signals: rear door control modules-Operating signal: rear: driver side roof shade,Not operated,
IDE12985-MAS15422,Operating signals: rear door control modules-Operating signal: rear: passenger side roof shade,Not operated,
IDE14139-MAS01161,Wind deflector control module: status-Communication malfunction,not installed,
IDE14139-MAS02282,Wind deflector control module: status-Position,not installed,
IDE14139-MAS04183,Wind deflector control module: status-Position error,not installed,
IDE14139-MAS08536,Wind deflector control module: status-Excessive temperature protection,not installed,
IDE14139-MAS17855,Wind deflector control module: status-Wagon message,Not available,
IDE14139-MAS17856,Wind deflector control module: status-Forced connection requirement,Not available,
IDE14139-MAS17857,Wind deflector control module: status-Position,not installed,
IDE14139-MAS17858,Wind deflector control module: status-Drive initializing,not installed,
IDE14139-MAS17859,Wind deflector control module: status-Adaptation run successful,not installed,
IDE14139-MAS17860,Wind deflector control module: status-Function canceled,not installed,
IDE14140-IDE02021,Wind deflector control module: reception signal-Comfort closing,Not available,
IDE14140-IDE02022,Wind deflector control module: reception signal-Comfort opening,Not available,
IDE14140-IDE14099,Wind deflector control module: reception signal-Wind deflector: denormalization,Not available,
IDE14140-MAS00370,Wind deflector control module: reception signal-Vehicle speed,Not available,
IDE14140-MAS01468,Wind deflector control module: reception signal-Terminal 15,Not available,
IDE14140-MAS02447,Wind deflector control module: reception signal-Release,Not available,
IDE14140-MAS05563,Wind deflector control module: reception signal-Norming,Not available,
IDE14140-MAS05737,Wind deflector control module: reception signal-Position,Not available,
IDE14140-MAS17871,Wind deflector control module: reception signal-Teaching-in run,Not available,
IDE14231-IDE09422,Power sunroof control module: absolute position values-Roof shade,70,
IDE14231-IDE09423,Power sunroof control module: absolute position values-Sunroof,82,
Elapsed Time: 00:04,,,
blockmap-D6-992-941-572-AE_3VV2X7B28NM061887-20220618-1241.CSV
;SW:992-941-572-AE   HW:992-941-572-A ---  Light Ctrl Left 2
;Component:LED1L         H08 9202, Coding:
;EV_LLPGen3LKEBODPO68X,001003,EV_LLPGen3LKEBODPO68X_VW27.rod
;Saturday,18,June,2022,12:41:18:14741
;VCID: E69E5DD2C8E4D46BC9E-80B2
IDE09774-MAS02923,Number of activations-Highway light,0,
IDE09774-MAS14159,Number of activations-Coming Home,1,
IDE09774-MAS14160,Number of activations-Leaving Home,0,
IDE09774-MAS18763,Number of activations-Headlight contour light,0,
IDE09774-ENG187780,Number of activations-additional highbeam,10,
IDE09774-ENG186684,Number of activations-All weather light,0,
IDE09774-ENG108961,Number of activations-Camera lock,0,
IDE09774-ENG186410,Number of activations-City light,0,
IDE09774-ENG186757,Number of activations-daytimerunning light,123,
IDE09774-ENG255608,Number of activations-design light 2,0,
IDE09774-ENG274344,Number of activations-design light 3,0,
IDE09774-ENG186554,Number of activations-Eco mode 1,365,
IDE09774-ENG186555,Number of activations-Eco mode 2,0,
IDE09774-ENG247934,Number of activations-Express light,0,
IDE09774-ENG187761,Number of activations-higbeam,10,
IDE09774-ENG186491,Number of activations-Low beam,28,
IDE09774-ENG186411,Number of activations-Parking light,0,
IDE09774-ENG186853,Number of activations-position light,36,
IDE09774-ENG186603,Number of activations-race mode,0,
IDE09774-ENG166761,Number of activations-Sidemarker,0,
IDE09774-ENG186659,Number of activations-Static cornering light,0,
IDE09774-ENG186553,Number of activations-Tourist light,0,
IDE09774-ENG187378,Number of activations-turn indicator,333,
IDE10165-MAS02201,LED channel 1: Master 1-Temperature,35, °C
IDE10165-MAS04121,LED channel 1: Master 1-Voltage,0.00, V
IDE10165-MAS04136,LED channel 1: Master 1-Current,0, mA
IDE10165-MAS04625,LED channel 1: Master 1-Power: actual value,0, W
IDE10165-MAS09022,LED channel 1: Master 1-PWM value,0.0, %
IDE10165-MAS09326,LED channel 1: Master 1-Function,Highbeam,
IDE10165-MAS09327,LED channel 1: Master 1-LED brightness class,LK1,
IDE10165-ENG186571,LED channel 1: Master 1-Output,LED,
IDE10167-MAS02201,LED channel 1: Slave-Temperature,200, °C
IDE10167-MAS04121,LED channel 1: Slave-Voltage,0.00, V
IDE10167-MAS04136,LED channel 1: Slave-Current,0, mA
IDE10167-MAS04625,LED channel 1: Slave-Power: actual value,0, W
IDE10167-MAS09022,LED channel 1: Slave-PWM value,0.0, %
IDE10167-MAS09326,LED channel 1: Slave-Function,no function,
IDE10167-MAS09327,LED channel 1: Slave-LED brightness class,Not Used,
IDE10167-ENG186571,LED channel 1: Slave-Output,ERROR,
IDE10168-FSS01570,LED channel 2: Master-Temperature,34, °C
IDE10168-MAS02201,LED channel 2: Master-Temperature,0, mA
IDE10168-MAS04136,LED channel 2: Master-Current,0.00, V
IDE10168-MAS09022,LED channel 2: Master-PWM value,0.0, %
IDE10168-MAS09326,LED channel 2: Master-Function,lowbeam,
IDE10168-MAS09327,LED channel 2: Master-LED brightness class,LK1,
IDE10168-ENG186571,LED channel 2: Master-Output,LED,
IDE10168-ENG186891,LED channel 2: Master-output power,0, W
IDE10169-MAS02201,LED channel 2: Slave-Temperature,200, °C
IDE10169-MAS04121,LED channel 2: Slave-Voltage,0.00, V
IDE10169-MAS04136,LED channel 2: Slave-Current,0, mA
IDE10169-MAS04625,LED channel 2: Slave-Power: actual value,0, W
IDE10169-MAS09022,LED channel 2: Slave-PWM value,0.0, %
IDE10169-MAS09326,LED channel 2: Slave-Function,no function,
IDE10169-MAS09327,LED channel 2: Slave-LED brightness class,Not Used,
IDE10169-ENG186571,LED channel 2: Slave-Output,ERROR,
IDE10170-MAS02201,LED channel 3: Master-Temperature,36, °C
IDE10170-MAS04121,LED channel 3: Master-Voltage,1.67, V
IDE10170-MAS04136,LED channel 3: Master-Current,0, mA
IDE10170-MAS04625,LED channel 3: Master-Power: actual value,0, W
IDE10170-MAS09022,LED channel 3: Master-PWM value,0.0, %
IDE10170-MAS09326,LED channel 3: Master-Function,DRL & PO,
IDE10170-MAS09327,LED channel 3: Master-LED brightness class,LK1,
IDE10170-ENG186571,LED channel 3: Master-Output,LED,
IDE10171-FSS01570,LED channel 3: Slave-Temperature,200, °C
IDE10171-MAS02201,LED channel 3: Slave-Temperature,0, mA
IDE10171-MAS04136,LED channel 3: Slave-Current,0.00, V
IDE10171-MAS09022,LED channel 3: Slave-PWM value,0.0, %
IDE10171-MAS09326,LED channel 3: Slave-Function,no function,
IDE10171-MAS09327,LED channel 3: Slave-LED brightness class,Not Used,
IDE10171-ENG186571,LED channel 3: Slave-Output,ERROR,
IDE10171-ENG186891,LED channel 3: Slave-output power,0, W
IDE10205,Control module version,MAX_MQB,
IDE13678-MAS02201,LED channel 4: Master-Temperature,34, °C
IDE13678-MAS04121,LED channel 4: Master-Voltage,2.00, V
IDE13678-MAS04136,LED channel 4: Master-Current,0, mA
IDE13678-MAS04625,LED channel 4: Master-Power: actual value,0, W
IDE13678-MAS09022,LED channel 4: Master-PWM value,0.0, %
IDE13678-MAS09326,LED channel 4: Master-Function,lowbeam,
IDE13678-MAS09327,LED channel 4: Master-LED brightness class,LK1,
IDE13678-ENG186571,LED channel 4: Master-Output,LED,
IDE13898-MAS02201,LED channel 5: Master-Temperature,34, °C
IDE13898-MAS04121,LED channel 5: Master-Voltage,2.00, V
IDE13898-MAS04136,LED channel 5: Master-Current,0, mA
IDE13898-MAS04625,LED channel 5: Master-Power: actual value,0, W
IDE13898-MAS09022,LED channel 5: Master-PWM value,0.0, %
IDE13898-MAS09326,LED channel 5: Master-Function,Highbeam,
IDE13898-MAS09327,LED channel 5: Master-LED brightness class,LK2,
IDE13898-ENG186571,LED channel 5: Master-Output,LED,
IDE13899-FSS01570,LED channel 6: Master-Temperature,36, °C
IDE13899-MAS02201,LED channel 6: Master-Temperature,0, mA
IDE13899-MAS04136,LED channel 6: Master-Current,2.00, V
IDE13899-MAS09022,LED channel 6: Master-PWM value,0.0, %
IDE13899-MAS09326,LED channel 6: Master-Function,DRL & PO,
IDE13899-MAS09327,LED channel 6: Master-LED brightness class,LK1,
IDE13899-ENG186571,LED channel 6: Master-Output,LED,
IDE13899-ENG186891,LED channel 6: Master-output power,0, W
IDE13900-FSS01570,LED channel 7: Master-Temperature,36, °C
IDE13900-MAS02201,LED channel 7: Master-Temperature,0, mA
IDE13900-MAS04136,LED channel 7: Master-Current,2.00, V
IDE13900-MAS09022,LED channel 7: Master-PWM value,0.0, %
IDE13900-MAS09326,LED channel 7: Master-Function,turn indicator,
IDE13900-MAS09327,LED channel 7: Master-LED brightness class,LK1,
IDE13900-ENG186571,LED channel 7: Master-Output,LED,
IDE13900-ENG186891,LED channel 7: Master-output power,0, W
IDE13901-FSS01570,LED channel 8: Master-Temperature,200, °C
IDE13901-MAS02201,LED channel 8: Master-Temperature,0, mA
IDE13901-MAS04136,LED channel 8: Master-Current,2.00, V
IDE13901-MAS09022,LED channel 8: Master-PWM value,0.0, %
IDE13901-MAS09326,LED channel 8: Master-Function,Sidemarker,
IDE13901-MAS09327,LED channel 8: Master-LED brightness class,LK1,
IDE13901-ENG186571,LED channel 8: Master-Output,LED,
IDE13901-ENG186891,LED channel 8: Master-output power,0, W
IDE13902-MAS02201,LED channel 9: Master-Temperature,200, °C
IDE13902-MAS04121,LED channel 9: Master-Voltage,0.00, V
IDE13902-MAS04136,LED channel 9: Master-Current,0, mA
IDE13902-MAS04625,LED channel 9: Master-Power: actual value,0, W
IDE13902-MAS09022,LED channel 9: Master-PWM value,0.0, %
IDE13902-MAS09326,LED channel 9: Master-Function,no function,
IDE13902-MAS09327,LED channel 9: Master-LED brightness class,Not Used,
IDE13902-ENG186571,LED channel 9: Master-Output,ERROR,
IDE13903-MAS02201,LED channel 10: Master-Temperature,200, °C
IDE13903-MAS04121,LED channel 10: Master-Voltage,0.00, V
IDE13903-MAS04136,LED channel 10: Master-Current,0, mA
IDE13903-MAS04625,LED channel 10: Master-Power: actual value,0, W
IDE13903-MAS09022,LED channel 10: Master-PWM value,0.0, %
IDE13903-MAS09326,LED channel 10: Master-Function,no function,
IDE13903-MAS09327,LED channel 10: Master-LED brightness class,Not Used,
IDE13903-ENG186571,LED channel 10: Master-Output,ERROR,
IDE13904-FSS01570,LED channel 11: Master-Temperature,200, °C
IDE13904-MAS02201,LED channel 11: Master-Temperature,0, mA
IDE13904-MAS04136,LED channel 11: Master-Current,0.00, V
IDE13904-MAS09022,LED channel 11: Master-PWM value,0.0, %
IDE13904-MAS09326,LED channel 11: Master-Function,no function,
IDE13904-MAS09327,LED channel 11: Master-LED brightness class,Not Used,
IDE13904-ENG186571,LED channel 11: Master-Output,ERROR,
IDE13904-ENG186891,LED channel 11: Master-output power,0, W
IDE13905-MAS02201,LED channel 12: Master-Temperature,200, °C
IDE13905-MAS04121,LED channel 12: Master-Voltage,0.00, V
IDE13905-MAS04136,LED channel 12: Master-Current,0, mA
IDE13905-MAS04625,LED channel 12: Master-Power: actual value,0, W
IDE13905-MAS09022,LED channel 12: Master-PWM value,0.0, %
IDE13905-MAS09326,LED channel 12: Master-Function,no function,
IDE13905-MAS09327,LED channel 12: Master-LED brightness class,Not Used,
IDE13905-ENG186571,LED channel 12: Master-Output,ERROR,
ENG105152,AktiveDiagnoseSession,Extended Session,
ENG186146-ENG188375,DKL stepper motor-DKL_fault_position,not active,
ENG186146-ENG248062,DKL stepper motor-DKL_motor_position_in_degree,0, °
ENG186146-ENG187407,DKL stepper motor-DKL_motor_position_in_percent,36.5, %
ENG186146-ENG188280,DKL stepper motor-DKL_reference_run,erfolgt,
ENG186146-ENG188233,DKL stepper motor-DKL_speed_adjustment,warm,
ENG186082-MAS02201,ECU Temperature-Temperature,38, °C
ENG186166-ENG188338,GLW stepper motor-GLW_fault_position,not active,
ENG186166-ENG187719,GLW stepper motor-GLW_motor_position_in_percent,0.0, %
ENG186166-ENG188477,GLW stepper motor-GLW_reference_run,nicht erfolgt,
ENG186166-ENG248013,GLW stepper motor-GLW_shutter_position_in_percent,200, %
ENG186166-ENG188478,GLW stepper motor-GLW_speed_adjustment,warm,
ENG186197,headlamp variant,E0,
ENG186197,headlamp variant,F0,
ENG186197-ENG186889,headlamp variant-dataset country variant,SAE,
ENG186197-ENG247966,headlamp variant-SOA Checking Status,Finished and OK,
ENG186197-ENG186964,headlamp variant-via CAN country variant,SAE,
ENG186197-ENG187223,headlamp variant-via CAN SOA variant,E0,
ENG186197-ENG187100,headlamp variant-via CAN SOA variant 2,F0,
ENG186198-MAS02201,highside channel 1-Temperature,0, mA
ENG186198-MAS09022,highside channel 1-PWM value,0.0, %
ENG186198-MAS09326,highside channel 1-Function,no function,
ENG186198-ENG186571,highside channel 1-Output,FAN 1,
ENG186199-MAS02201,highside channel 2-Temperature,0, mA
ENG186199-MAS09022,highside channel 2-PWM value,0.0, %
ENG186199-MAS09326,highside channel 2-Function,no function,
ENG186199-ENG186571,highside channel 2-Output,Not Used,
ENG186200-MAS02201,highside channel 3-Temperature,0, mA
ENG186200-MAS09022,highside channel 3-PWM value,0.0, %
ENG186200-MAS09326,highside channel 3-Function,no function,
ENG186200-ENG186571,highside channel 3-Output,Not Used,
ENG186201-MAS02201,highside channel 4-Temperature,0, mA
ENG186201-MAS09022,highside channel 4-PWM value,0.0, %
ENG186201-MAS09326,highside channel 4-Function,no function,
ENG186201-ENG186571,highside channel 4-Output,Not Used,
ENG186202-MAS18765,identification headlamp-Identification,Not Used,
ENG186215-ENG188404,LWR stepper motor-LWR__speed_adjustment,warm,
ENG186215-ENG188356,LWR stepper motor-LWR_fault_position,not active,
ENG186215-ENG187101,LWR stepper motor-LWR_motor_position_in_mm,-34.00, mm
ENG186215-ENG187107,LWR stepper motor-LWR_motor_position_in_percent,53.0, %
ENG186215-ENG188443,LWR stepper motor-LWR_reference_run,erfolgt,
ENG157274-MAS14159,Operating time-Coming Home,0.00, H
ENG157274-MAS14160,Operating time-Leaving Home,0.00, H
ENG157274,Operating time,0.02, H
ENG157274,Operating time,0.00, H
ENG157274,Operating time,0.19, H
ENG157274,Operating time,14.15, H
ENG157274,Operating time,6.68, H
ENG157274,Operating time,2.05, H
ENG157274-ENG187780,Operating time-additional highbeam,0.00, H
ENG157274-ENG187666,Operating time-cornerlight,0.00, H
ENG157274-ENG187323,Operating time-Designlight,0.00, H
ENG157274-ENG255609,Operating time-designlight 2,0.00, H
ENG157274-ENG274345,Operating time-designlight 3,0.00, H
ENG157274-ENG186554,Operating time-Eco mode 1,6.16, H
ENG157274-ENG186555,Operating time-Eco mode 2,0.00, H
ENG157274-ENG186523,Operating time-Highbeam,0.00, H
ENG157274-ENG186491,Operating time-Low beam,1.31, H
ENG157274-ENG186603,Operating time-race mode,0.00, H
ENG157274-ENG166761,Operating time-Sidemarker,0.00, H
ENG157274-ENG166116,Operating time-Turn_indicator,1.70, H
ENG186104,Operating times in temperature ranges,0.00, H
ENG186104,Operating times in temperature ranges,14.15, H
ENG186228-MAS03378,production data headlamp-Supplier,              ,
ENG186228-ENG187298,production data headlamp-partnumber headlamp,              ,
ENG186228-ENG186473,production data headlamp-production date,              ,
ENG186228-ENG98897,production data headlamp-Serial number,              ,
ENG186229-MAS09833,PWM value CH 1-LED 1,0.0, %
ENG186229-MAS09834,PWM value CH 1-LED 2,0.0, %
ENG186229-MAS09835,PWM value CH 1-LED 3,0.0, %
ENG186229-MAS09836,PWM value CH 1-LED 4,0.0, %
ENG186229-MAS09837,PWM value CH 1-LED 5,0.0, %
ENG186229-MAS09838,PWM value CH 1-LED 6,0.0, %
ENG186229-MAS09839,PWM value CH 1-LED 7,0.0, %
ENG186229-MAS09840,PWM value CH 1-LED 8,0.0, %
ENG186229-MAS09841,PWM value CH 1-LED 9,0.0, %
ENG186229-MAS09842,PWM value CH 1-LED 10,0.0, %
ENG186229-MAS09843,PWM value CH 1-LED 11,0.0, %
ENG186229-MAS09844,PWM value CH 1-LED 12,0.0, %
ENG186230-MAS09833,PWM value CH 10-LED 1,0.0, %
ENG186230-MAS09834,PWM value CH 10-LED 2,0.0, %
ENG186230-MAS09835,PWM value CH 10-LED 3,0.0, %
ENG186230-MAS09836,PWM value CH 10-LED 4,0.0, %
ENG186230-MAS09837,PWM value CH 10-LED 5,0.0, %
ENG186230-MAS09838,PWM value CH 10-LED 6,0.0, %
ENG186230-MAS09839,PWM value CH 10-LED 7,0.0, %
ENG186230-MAS09840,PWM value CH 10-LED 8,0.0, %
ENG186230-MAS09841,PWM value CH 10-LED 9,0.0, %
ENG186230-MAS09842,PWM value CH 10-LED 10,0.0, %
ENG186230-MAS09843,PWM value CH 10-LED 11,0.0, %
ENG186230-MAS09844,PWM value CH 10-LED 12,0.0, %
ENG186231-MAS09833,PWM value CH 11-LED 1,0.0, %
ENG186231-MAS09834,PWM value CH 11-LED 2,0.0, %
ENG186231-MAS09835,PWM value CH 11-LED 3,0.0, %
ENG186231-MAS09836,PWM value CH 11-LED 4,0.0, %
ENG186231-MAS09837,PWM value CH 11-LED 5,0.0, %
ENG186231-MAS09838,PWM value CH 11-LED 6,0.0, %
ENG186231-MAS09839,PWM value CH 11-LED 7,0.0, %
ENG186231-MAS09840,PWM value CH 11-LED 8,0.0, %
ENG186231-MAS09841,PWM value CH 11-LED 9,0.0, %
ENG186231-MAS09842,PWM value CH 11-LED 10,0.0, %
ENG186231-MAS09843,PWM value CH 11-LED 11,0.0, %
ENG186231-MAS09844,PWM value CH 11-LED 12,0.0, %
ENG186232-MAS09833,PWM value CH 12-LED 1,0.0, %
ENG186232-MAS09834,PWM value CH 12-LED 2,0.0, %
ENG186232-MAS09835,PWM value CH 12-LED 3,0.0, %
ENG186232-MAS09836,PWM value CH 12-LED 4,0.0, %
ENG186232-MAS09837,PWM value CH 12-LED 5,0.0, %
ENG186232-MAS09838,PWM value CH 12-LED 6,0.0, %
ENG186232-MAS09839,PWM value CH 12-LED 7,0.0, %
ENG186232-MAS09840,PWM value CH 12-LED 8,0.0, %
ENG186232-MAS09841,PWM value CH 12-LED 9,0.0, %
ENG186232-MAS09842,PWM value CH 12-LED 10,0.0, %
ENG186232-MAS09843,PWM value CH 12-LED 11,0.0, %
ENG186232-MAS09844,PWM value CH 12-LED 12,0.0, %
ENG186233-MAS09833,PWM value CH 2-LED 1,0.0, %
ENG186233-MAS09834,PWM value CH 2-LED 2,0.0, %
ENG186233-MAS09835,PWM value CH 2-LED 3,0.0, %
ENG186233-MAS09836,PWM value CH 2-LED 4,0.0, %
ENG186233-MAS09837,PWM value CH 2-LED 5,0.0, %
ENG186233-MAS09838,PWM value CH 2-LED 6,0.0, %
ENG186233-MAS09839,PWM value CH 2-LED 7,0.0, %
ENG186233-MAS09840,PWM value CH 2-LED 8,0.0, %
ENG186233-MAS09841,PWM value CH 2-LED 9,0.0, %
ENG186233-MAS09842,PWM value CH 2-LED 10,0.0, %
ENG186233-MAS09843,PWM value CH 2-LED 11,0.0, %
ENG186233-MAS09844,PWM value CH 2-LED 12,0.0, %
ENG186234-MAS09833,PWM value CH 3-LED 1,0.0, %
ENG186234-MAS09834,PWM value CH 3-LED 2,0.0, %
ENG186234-MAS09835,PWM value CH 3-LED 3,0.0, %
ENG186234-MAS09836,PWM value CH 3-LED 4,0.0, %
ENG186234-MAS09837,PWM value CH 3-LED 5,0.0, %
ENG186234-MAS09838,PWM value CH 3-LED 6,0.0, %
ENG186234-MAS09839,PWM value CH 3-LED 7,0.0, %
ENG186234-MAS09840,PWM value CH 3-LED 8,0.0, %
ENG186234-MAS09841,PWM value CH 3-LED 9,0.0, %
ENG186234-MAS09842,PWM value CH 3-LED 10,0.0, %
ENG186234-MAS09843,PWM value CH 3-LED 11,0.0, %
ENG186234-MAS09844,PWM value CH 3-LED 12,0.0, %
ENG186235-MAS09833,PWM value CH 4-LED 1,0.0, %
ENG186235-MAS09834,PWM value CH 4-LED 2,0.0, %
ENG186235-MAS09835,PWM value CH 4-LED 3,0.0, %
ENG186235-MAS09836,PWM value CH 4-LED 4,0.0, %
ENG186235-MAS09837,PWM value CH 4-LED 5,0.0, %
ENG186235-MAS09838,PWM value CH 4-LED 6,0.0, %
ENG186235-MAS09839,PWM value CH 4-LED 7,0.0, %
ENG186235-MAS09840,PWM value CH 4-LED 8,0.0, %
ENG186235-MAS09841,PWM value CH 4-LED 9,0.0, %
ENG186235-MAS09842,PWM value CH 4-LED 10,0.0, %
ENG186235-MAS09843,PWM value CH 4-LED 11,0.0, %
ENG186235-MAS09844,PWM value CH 4-LED 12,0.0, %
ENG186236-MAS09833,PWM value CH 5-LED 1,0.0, %
ENG186236-MAS09834,PWM value CH 5-LED 2,0.0, %
ENG186236-MAS09835,PWM value CH 5-LED 3,0.0, %
ENG186236-MAS09836,PWM value CH 5-LED 4,0.0, %
ENG186236-MAS09837,PWM value CH 5-LED 5,0.0, %
ENG186236-MAS09838,PWM value CH 5-LED 6,0.0, %
ENG186236-MAS09839,PWM value CH 5-LED 7,0.0, %
ENG186236-MAS09840,PWM value CH 5-LED 8,0.0, %
ENG186236-MAS09841,PWM value CH 5-LED 9,0.0, %
ENG186236-MAS09842,PWM value CH 5-LED 10,0.0, %
ENG186236-MAS09843,PWM value CH 5-LED 11,0.0, %
ENG186236-MAS09844,PWM value CH 5-LED 12,0.0, %
ENG186237-MAS09833,PWM value CH 6-LED 1,0.0, %
ENG186237-MAS09834,PWM value CH 6-LED 2,0.0, %
ENG186237-MAS09835,PWM value CH 6-LED 3,0.0, %
ENG186237-MAS09836,PWM value CH 6-LED 4,0.0, %
ENG186237-MAS09837,PWM value CH 6-LED 5,0.0, %
ENG186237-MAS09838,PWM value CH 6-LED 6,0.0, %
ENG186237-MAS09839,PWM value CH 6-LED 7,0.0, %
ENG186237-MAS09840,PWM value CH 6-LED 8,0.0, %
ENG186237-MAS09841,PWM value CH 6-LED 9,0.0, %
ENG186237-MAS09842,PWM value CH 6-LED 10,0.0, %
ENG186237-MAS09843,PWM value CH 6-LED 11,0.0, %
ENG186237-MAS09844,PWM value CH 6-LED 12,0.0, %
ENG186238-MAS09833,PWM value CH 7-LED 1,0.0, %
ENG186238-MAS09834,PWM value CH 7-LED 2,0.0, %
ENG186238-MAS09835,PWM value CH 7-LED 3,0.0, %
ENG186238-MAS09836,PWM value CH 7-LED 4,0.0, %
ENG186238-MAS09837,PWM value CH 7-LED 5,0.0, %
ENG186238-MAS09838,PWM value CH 7-LED 6,0.0, %
ENG186238-MAS09839,PWM value CH 7-LED 7,0.0, %
ENG186238-MAS09840,PWM value CH 7-LED 8,0.0, %
ENG186238-MAS09841,PWM value CH 7-LED 9,0.0, %
ENG186238-MAS09842,PWM value CH 7-LED 10,0.0, %
ENG186238-MAS09843,PWM value CH 7-LED 11,0.0, %
ENG186238-MAS09844,PWM value CH 7-LED 12,0.0, %
ENG186239-MAS09833,PWM value CH 8-LED 1,0.0, %
ENG186239-MAS09834,PWM value CH 8-LED 2,0.0, %
ENG186239-MAS09835,PWM value CH 8-LED 3,0.0, %
ENG186239-MAS09836,PWM value CH 8-LED 4,0.0, %
ENG186239-MAS09837,PWM value CH 8-LED 5,0.0, %
ENG186239-MAS09838,PWM value CH 8-LED 6,0.0, %
ENG186239-MAS09839,PWM value CH 8-LED 7,0.0, %
ENG186239-MAS09840,PWM value CH 8-LED 8,0.0, %
ENG186239-MAS09841,PWM value CH 8-LED 9,0.0, %
ENG186239-MAS09842,PWM value CH 8-LED 10,0.0, %
ENG186239-MAS09843,PWM value CH 8-LED 11,0.0, %
ENG186239-MAS09844,PWM value CH 8-LED 12,0.0, %
ENG186240-MAS09833,PWM value CH 9-LED 1,0.0, %
ENG186240-MAS09834,PWM value CH 9-LED 2,0.0, %
ENG186240-MAS09835,PWM value CH 9-LED 3,0.0, %
ENG186240-MAS09836,PWM value CH 9-LED 4,0.0, %
ENG186240-MAS09837,PWM value CH 9-LED 5,0.0, %
ENG186240-MAS09838,PWM value CH 9-LED 6,0.0, %
ENG186240-MAS09839,PWM value CH 9-LED 7,0.0, %
ENG186240-MAS09840,PWM value CH 9-LED 8,0.0, %
ENG186240-MAS09841,PWM value CH 9-LED 9,0.0, %
ENG186240-MAS09842,PWM value CH 9-LED 10,0.0, %
ENG186240-MAS09843,PWM value CH 9-LED 11,0.0, %
ENG186240-MAS09844,PWM value CH 9-LED 12,0.0, %
ENG138939-MAS01632,Status InputOutputControl-Status,not active,
ENG186117-IDE00019,Supply_informations-Voltage terminal 30,12.5, V
ENG186117-ENG187145,Supply_informations-Voltage terminal 30G,12.5, V
ENG99026,Unlearning counter,20,
Elapsed Time: 00:10,,,
blockmap-D7-992-941-572-AE_3VV2X7B28NM061887-20220618-1241.CSV
;SW:992-941-572-AE   HW:992-941-572-A ---  Light Ctrl Right 2
;Component:LED1R         H08 9202, Coding:
;EV_LLPGen3RKEBODPO68X,001003,EV_LLPGen3LKEBODPO68X_VW27.rod
;Saturday,18,June,2022,12:41:32:14741
IDE09774-MAS14159,Number of activations-Coming Home,0,
IDE09774-ENG187780,Number of activations-additional highbeam,0,
IDE09774-ENG186757,Number of activations-daytimerunning light,31,
IDE09774-ENG186554,Number of activations-Eco mode 1,138,
IDE09774-ENG187761,Number of activations-higbeam,0,
IDE09774-ENG186491,Number of activations-Low beam,0,
IDE09774-ENG186853,Number of activations-position light,9,
IDE09774-ENG187378,Number of activations-turn indicator,256,
IDE10165-MAS02201,LED channel 1: Master 1-Temperature,34, °C
IDE10168-FSS01570,LED channel 2: Master-Temperature,32, °C
IDE10170-MAS02201,LED channel 3: Master-Temperature,34, °C
IDE13678-MAS02201,LED channel 4: Master-Temperature,32, °C
IDE13898-MAS02201,LED channel 5: Master-Temperature,32, °C
IDE13898-MAS09327,LED channel 5: Master-LED brightness class,LK1,
IDE13899-FSS01570,LED channel 6: Master-Temperature,34, °C
IDE13900-FSS01570,LED channel 7: Master-Temperature,34, °C
ENG186146-ENG187407,DKL stepper motor-DKL_motor_position_in_percent,62.5, %
ENG186082-MAS02201,ECU Temperature-Temperature,39, °C
ENG157274,Operating time,0.07, H
ENG157274,Operating time,6.60, H
ENG157274,Operating time,4.12, H
ENG157274,Operating time,0.73, H
ENG157274-ENG186554,Operating time-Eco mode 1,2.04, H
ENG157274-ENG186491,Operating time-Low beam,0.00, H
ENG157274-ENG166116,Operating time-Turn_indicator,0.22, H
ENG186104,Operating times in temperature ranges,0.04, H
ENG186104,Operating times in temperature ranges,6.56, H
ENG186117-IDE00019,Supply_informations-Voltage terminal 30,12.6, V
ENG186117-ENG187145,Supply_informations-Voltage terminal 30G,12.6, V
blockmap-OBD_3VV2X7B28NM061887-20220618-1241.CSV
;33-OBD2
;Saturday,18,June,2022,12:41:48:14741
03,Fuel system 1/2 status,Closed loop,
04,Calculated load value,21.6 %,22.0 %
05,Engine coolant temperature,86 °C,87 °C
06,Short Term Trim - Bank 1,1.6 %,
07,Long Term Trim - Bank 1,0.0 %,
0B,Intake Manifold Absolute Pressure,25 kPa abs,
0C,Engine RPM,837 /min,837 /min
0D,Vehicle speed,0 km/h,0 km/h
0E,Ignition timing advance for cyl #1,-1.0 Degrees,
11,Absolute Throttle Position,11.0 %,
12,Secondary Air Status,Atmosphere/off,
13,Location of O2 sensors,B1S1 B1S2 ,
15,Bank 1 Sensor 2 Status,0.835 V,
1C,OBD Requirements Met,OBD + OBD II,
1F,Time since engine start,771 s,
21,Distance travelled with MIL on,0 km,
2E,Commanded Evaporative Purge,12.9 %,
2F,Fuel Level Input,65.9 %,
30,Warm-ups since DTC cleared,1,
31,Distance since DTC cleared,0 km,
33,Barometric pressure,98 kPa abs,
34,Bank 1 Sensor 1 Status,0.999 Lambda,-0.020 mA
3C,B1S1 Cat. Temp.,429.6 °C,
42,Control module voltage,12.640 V,12.800 V
43,Absolute Load Value,,
44,Commanded Equivalence Ratio,1.000 Lambda,
45,Relative Throttle Position,0.8 %,
46,Ambient Air Temp,30 °C,
47,Absolute Throttle Position B,11 %,
49,Accelerator Pedal Position D,14.1 %,14.1 %
4A,Accelerator Pedal Position E,14.1 %,
4C,Commanded Throttle Actuator Control,1.6 %,
51,Fuel type,Gasoline,
53,Abs. evap. vapour press.,96825 kPa abs,
54,Evap. vapour. press.,2878 Pa,
56,Long term sec. O2 trim bank 1/3,0.0 %,
62,Torque actual,6.0 %,
63,Torque Reference,280 Nm,
65,Auxiliary Input/Output,GEAR_RCMD: N,
67,Engine Coolant Temp,ECT 1:86 °C,ECT 2:91 °C
68,Intake Air Temp,IAT 11:39 °C,IAT 12:38 °C
6D,Fuel Press. Control A/B,FRP CMD:---/--- kPa,FRP ACT:16860/--- kPa
70,Boost Press Ctrl A/B,BP_A act:99.1 kPa,
71,Var. Geom. Turb. Ctrl A/B,VGT_A cmd/act:80.0/79.6 %,VGT_B cmd/act:---/--- %
73,Exhaust Press 1/2,EP1:100.03 kPa,
Mode 9 : Calibration Identification,,,
Type 02 - VIN : 3VV2X7B28NM061887 (Address E8),,,
Type 04 - Calibration ID : 05E013C 1936EXAK (Address E8),,,
Type 04 - Calibration ID : 0GC300018E++2803 (Address E9),,,
Type 06 - Calibration Verification Number : 8C880010 (Address E8),,,
Type 06 - Calibration Verification Number : 3DD0C142 (Address E9),,,
Type 08 - In-use performance tracking :,,,
    OBD Monitoring Conditions Encountered count : 7,,,
    Ignition cycle count : 92,,,
    Conditions completion count / Specified conditions encountered count,,,
         Catalyst monitor bank 1 : 5 / 7,,,
         Catalyst monitor bank 2 : 0 / 0,,,
         O2 Sensor monitor bank 1 : 4 / 7,,,
         O2 Sensor monitor bank 2 : 0 / 0,,,
         EGR-VVT monitor : 8 / 7,,,
         AIR monitor : 22 / 3,,,
         EVAP monitor : 1 / 1,,,
         Secondary O2 Sensor monitor bank 1 : 2 / 7,,,
         Secondary O2 Sensor monitor bank 2 : 0 / 0,,,
         Air Fuel Ratio Imbalance Monitor bank 1 : 4 / 7,,,
         Air Fuel Ratio Imbalance Monitor bank 2 : 0 / 0,,,
         Particulate Filter Monitor bank 1 : 0 / 0,,,
         Particulate Filter Monitor bank 2 : 0 / 0,,,
Type 0A - Controller Name : ECM-EngineControl (Address E8),,,
Type 0A - Controller Name : TCM-TransmisCtrl (Address E9),,,
Unknown NVGAV01.5V3Q (Address E8),,,
Type 14 - Distance Traveled Since Evap Monitoring Decision:,,,
         65535 km,,,
Type 16 - Vehicle Operation Data - Engine Run-Idle Time, Recent/Lifetime:,,
         Ignition counter : 1 / 92,,,
         Fueled Engine Operation Ignition Cycle Counter : 1 / 92,,,
         Total Engine Run Time : 785 s / 29774 s,,,
         Total Idle Engine Run Time : 465 s / 16278 s,,,
Type 17 - Vehicle Operation Data - Distance-Fuel Used, Recent/Lifetime:,,
         Total Distance Traveled : 0.0 km / 156.1 km,,,
         Total Fuel Consumed : 0.23 L / 23.73 L,,,
Type 18 - Vehicle Operation Data - PKE-EOE, Recent/Lifetime:,,
         Positive Kinetic Energy : 0 km/h2 / 5401 km/h2,,,
         Engine Output Energy : 0.1 kWh / 41.8 kWh,,,
Type 19 - Vehicle Operation Data - PSA, Recent/Lifetime:,,
         Total Propulsion System Active Time : 788 s / 30167 s,,,
         Total Idle Propulsion System Active Time : 468 s / 16683 s,,,
         Total City Propulsion System Active Time : 0 s / 8897 s,,,
Type 22 - Run Time for Stop-Start and Coasting Off-cycle Credit, Recent/Lifetime:,,
         Idle Stop-Start Timer : 0 s / 363 s,,,
         Engine Running Coasting Timer : -1 s / -1 s,,,
         Engine Off Coasting Timer : -1 s / -1 s,,,
Type 24 - Active Powertrain Warm-up Features Off-cycle Credit, Recent/Lifetime:,,
         Active Engine Warm-up Timer : 791 s / 12299 s,,,
         Active Transmission Warm-up Timer : -1 s / -1 s,,,
