VW TOUAREG 7P 2010 ACC disable CCS Enable
idanny50
Romania
C?ID=287208
Hello to all!
I have a problem with a VW TOUAREG 2010 7P 3.0 diesel, automatic transimision. I want to disable ACC system and activate CCS(GRA) system. I partialy done reonfigure car with 2 exceptions: 1. dashboard is not accepting my CCS coding, i allready coded with no ACC and 2. gearbox complains about comunication with ACC. Can someone help me?
Thank you!
Please post an Auto-Scan for context, so people can see how the vehicle is equipped and configured.
idanny50
Romania
C?ID=287208
Friday,17,June,2022,09:33:57:59252
VCDS Version: 22.3.1.4  HEX-NET2 CB: 0.4615.4
VIN: WVGZZZ7PZBD000760   License Plate: BUZDUGAN
Mileage: 309040km-192028mi   Repair Order:
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 08 09 0E 10 13 15 16 17 18 19 28 34 36 3C 42 46
          52 53 55 56 5F 62 69 6C 6D 72 85 8B 8E 8F 90
VIN: WVGZZZ7PZBD000760   Mileage: 309040km-192028miles
13-Auto Dist. Reg -- Status: Cannot be reached 0100
8F-Pretens. Frt Left -- Status: Malfunction 0010
90-Pretens. Frt Right -- Status: Malfunction 0010
Address 01: Engine (J623-CASA)       Labels:. 059-907-401-V2.clb
   Part No SW: 7P0 907 401     HW: 7P0 907 401
   Component: 3.0TDI EDC17  H13 0007
   Revision: 51H13---    CVN: 56A5C45E
   Coding: 292A4012A37E01020000
   Shop #: WSC 43168 133 83556
   ASAM Dataset: EV_ECM30TDI0117P0907401 002009
   ROD: EV_ECM30TDI0117P0907401.rod
   VCID: EC8A2C009605002B837-80B8
   VINID: 9E65EAAAA1E0A925000001C6008F436642
4807 - EGR System
          P0401 00 [096] - Insufficient Flow
                    Mileage: 308981 km
                    Date: 2022.06.12
                    Time: 19:07:30
                    Engine RPM: 1571.00 /min
                    Normed load value: 56.5 %
                    Vehicle speed: 54 km/h
                    Coolant temperature: 59 °C
                    Intake air temperature: 29 °C
                    Voltage terminal 30: 14.260 V
                    Mean injection quantity: 18.75 mg/stroke
                    Control Module temperature: 52.9 °C
                    EGR_governor_deviation: -175.0 mg/stroke
                    Inj Ctl q Curr: 18.78 mg/stroke
                    Mass_air_flow_sensor_drift: 1.2360
                    Air_Flow_Rate_from_Mass_Air_Flow_Sensor_kg_h: 141.9 kg/h
                    Actual charge pressure: 1220 hPa
5417 - Cylinder 5 Glow Plug Circuit (Q14)
          P0675 00 [109] - Electrical Fault
                    Mileage: 308807 km
                    Date: 2022.06.11
                    Time: 17:30:58
                    Engine RPM: 807.00 /min
                    Normed load value: 71.4 %
                    Coolant temperature: 25 °C
                    Intake air temperature: 26 °C
                    Voltage terminal 30: 12.940 V
                    Pre-glow time: 4100 ms
                    Glow status-Bits 0-7: 0
                    Time since ignition off: 84543 s
                    Outside temperature: 26.0 °C
4709 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [047] - -
          [Lost Communication WithCruise Control Front Distance Range Sensor]
                    Mileage: 308796 km
                    Date: 2022.06.10
                    Time: 14:47:41
                    Engine RPM: 0.00 /min
                    Coolant temperature: 48 °C
                    Intake air temperature: 38 °C
                    Voltage terminal 30: 12.200 V
                    Cruise Control System (CCS): status-Bits 0-7: 244
                    selected gear-Bits 0-7: 0
   Part No SW: 0C8 927 750 H    HW: 0C8 927 750 H
   Component: AL1000 AISIN  001 1811
   Serial number:                CVN: FE16D548
   Coding: 001568
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_TCMAL991031 001001
   ROD: EV_TCMAL991031_001_VW52.rod
   VCID: B134FD7471A7ADC3F01-80E4
12816 - No Communication with Cruise Control Module
          U0104 00 [009] - -
                    Reset counter: 201
                    Engine RPM: 0.0 /min
                    Transmission input speed: 0 /min
                    Engine torque: -44 Nm
                    ATF temperature: 34 °C
                    Accelerator pedal position: 0.0 %
                    Clutch_C1: Open
                    Clutch_C2: Open
                    Clutch_C3: Open
                    Clutch_C4: Open
                    Clutch_B1: Open
                    Clutch_B2: Open
                    Lock Up Clutch: Open
                    EOP failure status 2: Normalcy
                    EOP target revolution: 0 /min
                    EOP actual revolution: 65279 /min
                    Engine Speed signal Current: 65279 /min
                    EOP failure status with EOP without HV 1: Motor normal stop
                    EOP target current: 65278 mA
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 G    HW: 7P0 907 379 A
   Component: MK25A         H33 0421
   Revision: --------    Serial number: 423990010EC010
   Coding: 5B6B13C30B242F53DAFBC899D0D2F4507700
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_MK25AXT 007001
   ROD: EV_ESPMK25A00700.rod
   VCID: C1D4ADB4C1073D43001-8094
5B6B13C30B242F53DAFBC899D0D2F4507700  oe
818436 - Databus
          [AWV CAN-Überwachung kein Signal / Kommunikation]
                    Reset counter: 3
                    Mileage: 303312 km
                    Date: 2021.11.25
                    Time: 11:30:00
                    Standard Freeze  Frame Dynamic: 00 49 00 00 00 00 00 07 01 00 01 20 34
337668 - Databus
          [Steuergerät für ADR kein Signal/Kommunikation]
                    Reset counter: 3
                    Mileage: 303312 km
                    Date: 2021.11.25
                    Time: 11:30:00
                    Standard Freeze  Frame Dynamic: 00 49 00 00 00 00 00 07 01 00 01 20 0E
   Part No SW: 4H0 907 064 AM    HW: 4H0 907 064 J
   Component: BCM2 2.0      H12 0208
   Coding: 01A60000000000000000
   VCID: F4BA3460CEB5D8EB5B7-80A0
   Subsystem 1 - Part No SW: 7P6 959 754 L    HW: 7P6 959 754 L
   Component: FBSTOUAREGIDG  H05 0051
   Serial number: 0510000007710013
   Subsystem 2 - Part No SW: 4H0 905 852 A    HW: 4H0 905 852 A
   Serial number: 0209000100125012
                    Fault Status: 00101101
                    Reset counter: 157
                    Mileage: 303314 km
                    Date: 2021.11.25
                    Time: 12:46:03
Address 08: Auto HVAC (J255)       Labels:| 7P6-907-040.clb
   Part No SW: 7P6 907 040 H    HW: 7P6 907 040 H
   Component: Klima 4 Zonen H18 0511
   Coding: 36C6007A70
   ASAM Dataset: EV_AirCondiFront 001012
   VCID: B924C554A9D76583481-80EC
   Part No SW: 4H0 907 063 C    HW: 4H0 907 063 C
   Component: BCM1 2.0      H09 0083
   Revision: 14009001    Serial number: 00000000472790
   Coding: 26001011D1345D010021000000005D0C431C670806010245000000020000
   VCID: A802101042FDEC0B27F-80FC
   Subsystem 1 - Part No SW: 7P0 955 119     HW: 7P0 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    091203  31  0020
   Serial number: 90243400091210160605
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 D    HW: 7P0 955 559 D  Labels: 8K0-955-559.CLB
   Component: RLFS  H09 0011
   Serial number: 10001463
   Coding: 004B25
   Subsystem 3 - Part No SW: 7P6 941 431 D    HW: 7P6 941 431 D
   Component: E1 - LDS  H04 0031
   Serial number: 00000000000902100059
   Subsystem 4 - Part No SW: 8K0 959 772 B    HW: 8K0 959 772
   Component: SLR-B8  H05 0004
   Serial number:           1100070461
   Coding: 853000
Address 0E: Media Player 1 (R161)       Labels: None
   Part No SW: 4H0 035 108 B    HW: 4H0 035 108
   Component: DVDCAlpine    H42 0140
   Revision: AA001001
   VCID: 9F100BCC17B32BB3565-80CA
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475     HW: 7P6 919 475
   Component: PARKHILFE 8K  H03 0016
   Revision: --------    Serial number: 38931004501025
   Coding: 318501
   ASAM Dataset: EV_VW526ParkiAssis2 001008
   ROD: EV_VW526ParkiAssis2.rod
   VCID: D5FC69E4258FA1E34C9-8080
Address 13: Auto Dist. Reg
Address 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Part No SW: 7P0 959 655     HW: 7P0 959 655
   Component: VW10Airbag009 H05 0019
   Revision: --------    Serial number: 003DN0002DU+
   ROD: EV_AirbaVW10BPAVW526_001.rod
   VCID: FEAE1648F07982BB3D3-80AA
   Serial number: 3575LRB405B6CMJM3OQI
   Serial number: 3585LRB40536O2OU31BL
   Serial number: 3515RRB405V6CSQ8C8TX
   Serial number: 3525RRB405V6CSQ8K0FK
   Serial number: 3555NRB404Q70PNCKP3D
   Serial number: 3565NRB404S70PNCIGMO
   Part No SW: 4H0 953 568 B    HW: 7P6 953 507 G
   Component: Lenks.Modul   H07 0007
   Revision: --------    Serial number: 90815JBM0001F
   Coding: 000C9D
   VCID: B236F278742196DB89B-80E6
   Subsystem 1 - Part No SW: 7P6 959 542     HW: 7P6 959 542
   Component: E221__MFL-TAS  H03 0027
   Serial number: 0002433
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   Part No SW: 7P6 920 880 D    HW: 7P6 920 880 D
   Component: Kombi         H09 0114
   Revision: 06499041    Serial number: 658260210593743
   Coding: 071733007E080008000000
   ASAM Dataset: EV_KombiUDSRBVW526 001011
   ROD: EV_KombiUDSRBVW526.rod
   VCID: BC2ADC40A6E550AB537-80E8
16776960 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ACC_02_FR keine Kommunikation]
                    Reset counter: 3
                    Mileage: 303312 km
                    Date: 2021.11.25
                    Time: 12:39:28
16776961 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ACC_04_FR keine Kommunikation]
                    Reset counter: 3
                    Mileage: 303312 km
                    Date: 2021.11.25
                    Time: 12:39:28
Address 18: Aux. Heat (J364)       Labels:. 8R0-265-105.clb
   Part No SW: 7P0 963 272 A    HW: 7P0 963 272 A
   Component: Standheizung  H21 0230
   Revision: 45004005    Serial number: 20091209180340
   Coding: 114200
   VCID: B53CC964854F81E3AC9-80E0
01410 - Heater Over-Temp
                    Fault Status: 00100001
                    Fault Frequency: 72
                    Reset counter: 70
                    Mileage: 303312 km
                    Date: 2021.11.25
                    Time: 12:41:22
                    Temperature: 65.0°C
                    Temperature: 82.0°C
                    Voltage: 14.10 V
                        Full Throt
                    Error Code: 182
                    Temperature: 0.0°C
                    RPM: 1344 /min
                        Yes
                    Reset counter: 4
                    Mileage: 303437 km
                    Date: 2021.12.02
                    Time: 07:27:49
                    Temperature: 51.0°C
                    Temperature: 65.0°C
                    Voltage: 14.10 V
                        Ctrl. Pause
                    Error Code: 200
                    Temperature: 5.0°C
                    RPM: 1193 /min
                        Yes
03176 - Temperature Sensor 2 for Aux. Heating
                    Fault Frequency: 23
                    Reset counter: 70
                    Mileage: 303459 km
                    Date: 2021.12.03
                    Time: 15:57:13
                    Temperature: 36.0°C
                    Temperature: 66.0°C
                    Voltage: 11.90 V
                        Start
                    Error Code: 144
                    Temperature: 2.0°C
                    RPM: 1151 /min
                        Yes
01444 - Under-Voltage Shut-Off (Automatic)
                    Reset counter: 62
                    Mileage: 304050 km
                    Date: 2021.12.23
                    Time: 11:39:05
                    Temperature: 6.0°C
                    Temperature: 40.0°C
                    Voltage: 12.20 V
                    Error Code: 0
                    Temperature: 1.0°C
                        Yes
            007 - Short to Ground
                    Fault Status: 01100111
                    Fault Frequency: 51
                    Reset counter: 65
                    Mileage: 304147 km
                    Date: 2021.12.29
                    Time: 16:30:28
                    Temperature: 51.0°C
                    Temperature: 63.0°C
                    Voltage: 13.70 V
                        Start
                    Error Code: 145
                    Temperature: -3.0°C
                    RPM: 1754 /min
                        Yes
02251 - Heater Unit Locked
                    Mileage: 304147 km
                    Date: 2021.12.29
                    Time: 16:30:30
                    Temperature: 51.0°C
                    Temperature: 63.0°C
                    Voltage: 13.70 V
                        Start
                    Error Code: 145
                    Temperature: -3.0°C
                    RPM: 1754 /min
                        Yes
   Part No SW: 7P6 907 530     HW: 7P6 907 530
   Component: GW-CAN-L-FR-M H08 5179
   Revision: --------    Serial number: 00000000006173
   Coding: 000D077500
   GVL: FBDFC4E51D6F6E0000
   ASAM Dataset: EV_GatewVW526UDS 001005
   ROD: EV_GatewUDS_VW52.rod
   VCID: F5BC0964C54FC1E36C9-80A0
   Subsystem 1 - Part No SW: 7P0 915 181 A    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0140
   Serial number: 00000000005650094920
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 7PP 959 663 B    HW: 7PP 959 663 B
   Component: J532_DCDCStab  H16 0039
   Serial number: 10025001152011200180
4365 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [009] - -
                    Reset counter: 3
                    Mileage: 303312 km
                    Date: 2021.11.25
                    Time: 12:39:29
                    Voltage terminal 30: 14.5 V
                    Voltage terminal 15: 14.5 V
                    Control Module temperature: 56 °C
                    System status: Terminal 15 on
                    Engine running: On
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
4224 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [008] - -
                    Reset counter: 156
                    Mileage: 303431 km
                    Date: 2021.12.01
                    Time: 13:08:35
                    Voltage terminal 30: 11.7 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 6 °C
                    System status: Awake_Timer_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status via CAN: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
Address 28: HVAC, Rear (E265)       Labels:* None
   Part No SW: 7P6 907 049     HW: 7P6 907 049
   Component: Klima Fond    H13 0511
   Coding: 0000000000
   ASAM Dataset: EV_AirCondiHeck 001007
   ROD: EV_AirCondiHeck.rod
   VCID: FAA61A58EC51AE9B01B-80AE
Address 34: Level Control (J197)       Labels:. 7P0-907-553.clb
   Part No SW: 7P0 907 553 J    HW: 7P0 907 553 J
   Component: PASM          H01 1030
   Revision: 00000000    Serial number: 00000100150097
   Coding: 14210001
   ASAM Dataset: EV_PASMConti 001004
   ROD: EV_PASMConti.rod
   VCID: BE2ED648B0F942BB7D3-80EA
12656679 - Databus
          [CAN-Timeoutfehler ACC]
                    Fault Frequency: 117
                    Reset counter: 4
                    Mileage: 524032 km
                    Date: 2011.03.19
                    Time: 17:17:05
                    Default: 00
                    Default: 85
                    Default: 00
0840 - Comfort limitation
          C10D7 00 [137] - -
          [Dämpferregelung - eingeschränkter Normalbetrieb - Notlauf 1]
                    Reset counter: 4
                    Mileage: 524032 km
                    Date: 2011.03.19
                    Time: 17:25:06
                    Default: 00
                    Default: 85
                    Default: 00
   Part No SW: 4H0 959 760 A    HW: 4H0 959 760 A
   Component: MEM-FS        H07 0114
   Revision: AA000000    Serial number: 00001001386849
   Coding: C058130015004001000001010101202020202121202020
   VCID: B134FD747127ADC3F01-80E4
03777 - Sensor for Lumbar Support Adjustment
                    Fault Status: 01100101
                    Reset counter: 3
                    Mileage: 303312 km
                    Date: 2021.11.25
                    Time: 12:39:26
03329 - Seat Bottom Heating
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 50
                    Mileage: 303436 km
                    Date: 2021.12.02
                    Time: 07:08:28
   Part No SW: 7P6 907 566     HW: 4H0 907 566
   Component: J769  SWA MasterH03 0090
   Revision: 00H03000    Serial number: 6PZ 010 316-01
   Coding: 0010151
   VCID: FEAE1648FCF982BB3D3-80AA
   Subsystem 1 - Part No: 7P6 907 568
   Component: J770  SWA Slave H01 0090
   Subsystem 2 - Serial number: 6PZ 010 316-21
   Subsystem 3 - Serial number: 5F25.01.1000H010003C520456ÿ
   Subsystem 4 - Serial number: 520456ÿ
   Part No SW: 4H0 959 793 E    HW: 4H0 959 793 E
   Component: TSG FA        H02 0158
   Revision: --------    Serial number: 0000102904388
   Coding: 011D0620DE00459005080003
   VCID: BB28DF5CA36B57935AD-80EE
   Revision: 00002001    Serial number: 0126748738
   Coding: 011A162028B91080832006242D0000000000000000000000000000000000
   Shop #: WSC 43168 133 82954
   Subsystem 1 - Part No: 7P6 951 171
   Component: DWA-Sensor  002 0204
01319 - Control Module for Distance Control (J428)
                    Reset counter: 3
                    Mileage: 303312 km
                    Date: 2021.11.25
                    Time: 12:39:41
                    Reset counter: 157
                    Mileage: 303314 km
                    Date: 2021.11.25
                    Time: 12:46:03
02738 - Bulb for Tail/Brake Light; Left
                    Fault Status: 00101100
                    Fault Frequency: 16
                    Reset counter: 122
                    Mileage: 303661 km
                    Date: 2021.12.07
                    Time: 17:23:11
   Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
   Component: TSG BF        H07 0158
   Revision: --------    Serial number: 0000102911680
   Coding: 011D0620DE00459005080000
Address 53: Parking Brake (J540-)       Labels:| 7P0-907-801.clb
   Part No SW: 7P0 907 801 D    HW: 7P0 907 801 C
   Component: EPB           H51 1000
   Revision: 00000000    Serial number: A101280002B
   Coding: 01040000
   Shop #: WSC 02118 002 1048576
   ROD: EV_ParkbA7.rod
   VCID: B43AF4608EB598EB9B7-80E0
   Slave 3:
0048 - Control Module for Electronic Parking Brake
          C10E2 22 [008] - Signal Amplitude Too High
                    Reset counter: 19
                    Mileage: 303814 km
                    Date: 2021.12.17
                    Time: 15:03:36
                    Voltage: 6.6 V
12656679 - Databus
          [CAN-Timeout ACC]
                    Reset counter: 3
                    Mileage: 303312 km
                    Date: 2021.11.25
                    Time: 12:39:29
                    Voltage: 14.8 V
Address 55: Headlight Range (J745)       Labels:. 7P6-907-357.clb
   Part No SW: 7P6 907 357     HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0100
   Coding: 01AA00000F000200
   ASAM Dataset: EV_HeadlRegulVWAFS 005006
   ROD: EV_HeadlRegulVWAFS_VW52.rod
   VCID: FCAA1C40E66590AB137-80A8
   Subsystem 1 - Part No SW: 4H0 941 329     HW: 4H0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 0003
   Coding: 130000
   Subsystem 2 - Part No SW: 4H0 941 329     HW: 4H0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 0003
   Coding: 130000
   Part No SW: 4F0 035 061 H    HW: 4F0 035 061
   Component: Radio U DAB   H46 0048
   Revision: AB001007    Serial number: 006BH0A7504205
   Coding: 010105020100000001
   VCID: A1140D3421C71D43601-80F4
   Part No SW: 7P6 035 670     HW: 7P6 035 670
   Component: H-BNT-EU      H43 0203
   Revision: --------    Serial number: 478B%0A7507719
   Coding: 010100060040C9EF39102B0E00000003F0040101
   VCID: F2B63278B4A1D6DB49B-80A6
   Subsystem 1 - Part No: 8R0 060 884 R
   Component: EUR 2010  1106
   Subsystem 2 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Component: DU8 SV Touch  H10 0042
   Serial number: VWZ8Z9K18000XK
   Subsystem 3 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Component: CD-Database  1886
                    Reset counter: 3
                    Mileage: 303314 km
                    Date: 2021.11.25
                    Time: 13:15:07
                    Bin. Bits: 00000000 00100000
                    Bin. Bits: 00001000 00000000
                    Bin. Bits: 00000000 00000000
                    Fault Status: 00101011
                    Reset counter: 157
                    Mileage: 305683 km
                    Date: 2022.02.03
                    Time: 10:02:36
                    Voltage: 14.50 V
   Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
   Component: TSG HL        H09 0158
   Revision: --------    Serial number: 0000102668544
   Coding: 011C06200000259005080000
   VCID: BA26DA58AC516E9B41B-80EE
Address 69: Trailer (J345)       Labels: Redir Fail!
   Part No SW: 7P0 907 383 C    HW: 7P0 907 383 C
   Component: Anhaenger     H07 0100
   Revision: 5H001003    Serial number: 00000126333730
   Coding: 0106040000000000
   VCID: B822C050925D7C8BB7F-80EC
Address 6C: Back-up Cam. (J928)       Labels:| 7P6-907-441-V1.clb
   Part No SW: 7P6 907 441 C    HW: 7P6 907 441 C
   Component: TopView       --- 0093
   Coding: 0100000001010000010102000000
   ASAM Dataset: EV_CamerSysteTopViewVW 001013
   ROD: EV_CamerSysteTopViewVW.rod
13701388 - Databus
          [Funktionseinschraenkung wegen fehlender Botschaft (LWI_01_alt)]
                    Fault Frequency: 48
                    Reset counter: 157
                    Mileage: 303314 km
                    Date: 2021.11.25
                    Time: 13:18:21
                    Voltage terminal 30: 11.8 V
                    Terminal 15 status: Terminal 15 on
10489856 - No Basic Setting
          B2010 00 [009] - -
          [TopView system not calibrated]
                    Reset counter: 3
                    Mileage: 303312 km
                    Date: 2021.11.25
                    Time: 12:39:29
                    Voltage terminal 30: 14.2 V
   Part No SW: 7P6 959 107     HW: 7P6 959 107
   Component: HDSG-Modul    H10 0612
   Revision: 09145444    Serial number: 026000062
   Coding: 0533310003
   ASAM Dataset: EV_HeckkTouar 202135
   ROD: EV_HeckkTouar.rod
   Component: TSG HR        H09 0158
   Revision: --------    Serial number: 0000102582969
   Part No SW: 7P6 907 217     HW: 7P6 907 217
   Component: DPC-SG        H19 0012
   Coding: E1070000
   ASAM Dataset: EV_OnBoardCamerDTR 001001
   ROD: EV_OnBoardCamerDTR.rod
   VCID: F7A0036CDF43B3F37E5-80A2
   Slave 1:
   Subsystem 1 - Part No: 7P6 907 658
   Component: NICKRATENSENS  H02 0001
   Serial number: 000000003018344_1366
   Part No SW: 7P6 907 541     HW: 7P6 907 541
   Component: ACC3          H13 0160
   Coding: 3F04010101
   ASAM Dataset: EV_AdaptCruisContr2VW526 001004
   ROD: EV_AdaptCruisContr2VW526_001.rod
10 Faults Found:
94720 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [FAULT_CIS_QDCACC_FAIL]
                    Reset counter: 117
                    Mileage: 309040 km
                    Date: 2022.06.17
                    Time: 09:29:49
                    Control Module temperature: 24 °C
                    Voltage terminal 15: 14.156 V
94976 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [FAULT_CIS_QDCPSS_FAIL]
                    Reset counter: 157
                    Mileage: 309040 km
                    Date: 2022.06.17
                    Time: 09:29:48
                    Voltage terminal 15: 14.158 V
95232 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [FAULT_CIS_QEPBACC_FAIL]
                    Reset counter: 117
                    Mileage: 309040 km
                    Date: 2022.06.17
                    Time: 09:31:08
                    Control Module temperature: 25 °C
38912 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [FAULT_CIM_TIMEOUT_APS1]
                    Reset counter: 157
                    Mileage: 308995 km
                    Date: 2022.06.13
                    Time: 09:07:35
                    Control Module temperature: 19 °C
                    Voltage terminal 15: 10.971 V
38656 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [FAULT_CIM_TIMEOUT_APS2]
                    Reset counter: 157
                    Mileage: 308259 km
                    Date: 2022.05.03
                    Time: 07:07:05
                    Voltage terminal 15: 9.519 V
21760 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [FAULT_CIM_TIMEOUT_APSM]
                    Reset counter: 157
                    Mileage: 304525 km
                    Date: 2022.01.22
                    Time: 18:39:47
                    Control Module temperature: -1 °C
                    Voltage terminal 15: 11.792 V
77568 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [FAULT_CIM_TIMEOUT_LRRM_DEJU]
                    Reset counter: 117
                    Mileage: 309040 km
                    Date: 2022.06.17
                    Time: 09:26:37
                    Control Module temperature: 20 °C
                    Voltage terminal 15: 12.039 V
98304 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 157
                    Mileage: 308796 km
                    Date: 2022.06.10
                    Time: 14:30:22
                    Control Module temperature: 21 °C
                    Voltage terminal 15: 13.064 V
147456 - Internal Fault
          B200F F0 [009] - Unknown Error Elaboration
          [FAULT_SCON_WD3_EXPIRED]
                    Mileage: 214428 km
                    Date: 2017.04.15
                    Time: 08:07:17
                    Control Module temperature: 10 °C
                    Voltage terminal 15: 14.468 V
                    Velocity_vehicle_reference: 5.77 m/s
                    Longitudinal_acceleration_vehicle_reference: 1.73 m/s²
147712 - Internal Control Module Memory Check Sum Error
          B2000 00 [009] - -
          [FAULT_SCON_BIST]
                    Mileage: 214428 km
                    Date: 2017.04.15
                    Time: 08:07:17
                    Voltage terminal 15: 14.488 V
                    Velocity_vehicle_reference: 5.72 m/s
                    Longitudinal_acceleration_vehicle_reference: 1.68 m/s²
Address 8E: Image Processing (J851)       Labels:| 7P6-907-107.clb
   Part No SW: 7P6 907 107     HW: 7P6 907 107
   Component: BV-SG         H25 0003
   Serial number: 000040080202107
   Coding: 0A20BE04
   ASAM Dataset: EV_BTR 001001
   ROD: EV_BTR_001.rod
0080 - Video Cable for Image Processing
          C1107 02 [024] - Signal Failure
          [No_connection_to_camera]
                    Fault Frequency: 11
                    Reset counter: 157
                    Mileage: 309040 km
                    Date: 2022.06.17
                    Time: 09:24:11
0161 - Video Cable for Image Processing
          C1107 02 [009] - Signal Failure
          [No_camera_found_on_startup]
                    Reset counter: 157
                    Mileage: 309040 km
                    Date: 2022.06.17
                    Time: 09:26:46
   Part No SW: 4H0 980 945     HW: 4H0 980 945
   Component: RGS-VL        H04 0070
   Coding: 006606000317037F00033811594097000000
   Shop #: WSC 00001 790 00001
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: EFB03B0CA713FB33A65-80BA
12583680 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 3
                    Mileage: 303312 km
                    Date: 2021.11.25
                    Time: 12:39:28
12583693 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 3
                    Mileage: 303312 km
                    Date: 2021.11.25
                    Time: 12:39:28
12589824 - Data Set Implausible
          B2012 00 [009] - -
          [Implausible Datase]
   Part No SW: 4H0 980 946     HW: 4H0 980 946
   Component: RGS-VR        H04 0070
   Coding: 00660600031F037F00033811594097000000
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: F0B23870BA2DE4CBBFF-80A4
          U1111 00 [009] - -
                    Reset counter: 3
                    Mileage: 303312 km
                    Date: 2021.11.25
                    Time: 12:39:28
          U1111 00 [009] - -
                    Reset counter: 3
                    Mileage: 303312 km
                    Date: 2021.11.25
                    Time: 12:39:28
          B2012 00 [009] - -
End----------(Elapsed Time: 02:30, VBatt start/end: 14.0V/13.9V)-----------
Try 001168 in the Trans -- but I'm not certain that's correct.
idanny50
Romania
C?ID=287208
Transmision accept any coding and error is still the same! I think is something related to dataset. I will try tomorrow! Thx for info!
Spacewalker
Poland
C?ID=159607
Remove 13 and 8B first - they are both ACC
Disable from:
01,02,03,19 perhaps also from 3C,
idanny50
Romania
C?ID=287208
i removed, 13 and 8b, coded 01,03,19, the only thing i cannot code is 02. 02 accept every coding i give(00000,12356......everyting) but still the same error that no comm with acc. i found scans of my module on internet with the same coding and no ACC. i think the problem is not in 02.
Spacewalker
Poland
C?ID=159607
well... if VW never made car like that w/o ACC, some module might be ONLY made to talk with ACC
and this is basic equipment
so you will propably never remove completly ACC
They definitely made 7P T'regs w/o ACC. Here in NAR, ACC was not available at all until the 7P facelift in MY 2015, and even after that, it was only in the top trim models.
dieseltje
The Netherlands
C?ID=148044
instruments need also recoding should be
073731007A080008000002
byte 01 bit 5 is for CCS
byte 04 bit 2 is for deactivating ACC in cluster
