Short version:
Why is the Compressor Current (actual) field empty? Is that normal? No error codes.
Long version:
Hi, on vacation, A/C is no longer cooling properly and it's 35C/95F outside with strong sunlight.
I don't have graphs (new to this, sorry) but short explanation of the values:
Refrigerant pressure: Started at 7.8 bar (off) and went to 10.2-11 bar when on. I think this is normal from what i read.
Evaporator Temperature: this is dropping only very very slowly. It should go down to 4C over 5-10 minutes but after 15 minutes it was only at 28C (down from 35C at start).
This was in a parking lot idling but i noticed the problem while driving. Don't have low pressure gauge at the moment (trying to get one). Don't speak the local language AT ALL and the locals don't like to speak english :|
Pic is from 30 minutes into testing.
Thank for any help!
Edit: Getting Auto Scan now.
Edit2: Auto Scan
Long version:
Thank for any help!
Edit2: Auto Scan
Monday,20,June,2022,12:51:55:48187
VCDS Version: 22.3.1.4 (x64) HEX-V2 CB: 0.4615.4
Chassis Type: 3C-VW46 (3C0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 3D 42 44 46 52 53 62 72
VIN: [not public] Mileage: [not public]
3D-Special Function -- Status: OK 0000
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 QD HW: 03L 907 309
Component: R4 2.0l TDI 0000AG 9982
Revision: 13H01--- Serial number: VWZCZ000000000
Coding: 0000078
Shop #: WSC 18688 807 404200
VCID: 77AA179E33C68703FE5-8022
VINID: 9E69EAAAA0D3A8954020704924CF48896D
005184 - EGR Valve (N18)
P1440 - 000 - Open Circuit
Mileage: 162502 km
Date: 2016.11.10
Time: 12:47:52
Load: 100.0 %
Lambda: 99.4 %
Mass Air / Rev.: 0.0 mg/str
Temperature: 23.4°C
Part No SW: 02E 300 052 HW: 02E 927 770 AJ
Component: GSG DSG AG6 440 1918
Revision: 04844002 Serial number: 00000901160193
Shop #: WSC 32441 133 51611
VCID: 51FE8906FDE2F933101-8004
Address 03: ABS Brakes Labels:. 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 T HW: 3C0 614 109 T
Component: J104 C4 440 V2 0013
Revision: --025--- Serial number: 00000786382621
Coding: 0004373
Shop #: WSC 05311 000 00000
VCID: 2F3AEFFE8B168FC3665-807A
Part No SW: 1K0 820 047 JD HW: 1K0 820 047 JD
Component: Climatic PQ35 143 1313
Revision: 00143033 Serial number: 00000000000000
VCID: 6FBA2FFE4B96CFC3265-803A
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Revision: 00H54000 Serial number: 00000009067441
Coding: 01880F0700041A00470A00000F00000000895DC35C000120000000000000
Shop #: WSC 05124 000 00000
VCID: 3332E38E673EAB2302D-8066
Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
Component: Wischer 240908 004 0206
Coding: 00046997
Shop #: WSC 05124
Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
Part No SW: 3C8 919 475 HW: 3C8 919 475
Component: PARKHILFE 8K H07 0007
Revision: -------- Serial number: 97540830906456
Coding: 100103
Shop #: WSC 05314 000 00000
VCID: 71BE298651A2D933301-8024
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__00P VW10 HI 1815
Revision: 19013000 Serial number: 0039DPN76909
Coding: 0012368
VCID: 3B22CBAE4F6E6363DAD-806E
Subsystem 1 - Serial number: 6333FTS641262968
Subsystem 2 - Serial number: 6343FTS612332918
Subsystem 3 - Serial number: 6353ETS6LET5VVNR
Subsystem 4 - Serial number: 6363ETS63K7LVVNR
Address 16: Steering wheel Labels: 3C0-953-549-SW25.lbl
Part No SW: 3C0 953 549 AT HW: 3C0 953 549 AT
Component: J0527 0025
Revision: 00033000 Serial number: 3C9953507CD
Coding: 0001002
VCID: 7EA402BA1CFCB64BBD3-802A
Part No SW: 3C0 920 860 R HW: 3C0 920 860 R
Component: KOMBI H04 0106
Coding: 160700
Shop #: WSC 05314 115 00000
VCID: 313EE98691A29933701-8064
Address 19: CAN Gateway Labels:. 3C0-907-530-V3.clb
Part No SW: 3C0 907 530 L HW: 3C0 907 951
Component: J533__Gateway H13 0152
Revision: H13 Serial number: 3300P08B100189
Coding: FDA07F06010002002002
VCID: 2A0CFEEAB0F4EAEBB1B-807E
Part No SW: 3C0 959 433 AR HW: 3C0 959 433 AR
Component: IMMO 043 0383
Revision: 00043000 Serial number: VWZCZ000000000
Shop #: WSC 32522 133 81168
VCID: 7AAC0EAA00D49A6B81B-802E
Component: ELV 027 0380
3C0905861G ELV 027 0380
Address 3D: Special Function Labels: Redir Fail!
Part No SW: 3C0 907 427 A HW: 3C0 907 427 A
Component: J608 MFG 011 0020
Revision: M0011000 Serial number: 00000000035649
Coding: 05000101000100000300000100
Shop #: WSC 09431 127 76521
VCID: 241010D2D2D03C9B8B7-8070
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1517
Revision: 72009005 Serial number: 00000571789006
Coding: 0000181
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 J HW: 5N1 909 148 F
Component: J500__APA-BS KL.082 0502
Revision: 1AH02240 Serial number: 00082000241902
Coding: 0000258
VCID: 392ED1A645525173C81-806C
01288 - Terminal 30; Steering Assist
Fault Status: 00101011
Fault Priority: 9
Reset counter: 97
RPM: 65 /min
(no units): 2.0
Voltage: 10.80 V
Component: KSG PQ46 ELV 043 0612
Coding: 0091020051030E7630049415702A4F0B6078A1
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1517
Revision: 72009005 Serial number: 00000773389012
Coding: 0000180
VCID: 70B82C8256A8D03B3FF-8024
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C8 907 801 A HW: 3C8 907 801 A
Component: J540 EPB3 VW-10498 0003
Revision: 009 Serial number: 00000000196362
Coding: 0000057
VCID: 280804E2AEF8D8FBA7F-807C
Part No SW: 1K0 959 703 AB HW: 1K0 959 795 L
Component: J388 TUER-SG HL 0307
Revision: 41004101 Serial number: 00000000697255
Coding: 0000144
Part No SW: 1K0 959 704 AB HW: 1K0 959 794 L
Component: J389 TUER-SG HR 0307
Revision: 41004101 Serial number: 00000000691078
Coding: 0000144
VCID: 71BE29865DA2D933301-8024
End----------(Elapsed Time: 01:27, VBatt start/end: 12.2V/12.2V)-----------
