2008 Audi TT Roadster 3.2L Quatro - DTC P0491 P2197 P2181 etc Auto-Scan and the OBD-II modes 1 thru 9
Stuart C
Dallas, TX, USA
C?ID=519902
Hello, this is my first post for my 2008 Audi TT Roadster 3.2L Quatro using the Ross-Tech scanner.
Any of your comments will be much appreciated.
I had a check engine light, so I cleared the Fault codes and drove the car for a few days until the check engine light came back on.
Also, the dashboard engine coolant temp gauge is intermittent - sometimes it shows (full cold /or normal) when the engine is warmed up. The scan tool shows the engine cooling temp (ECT) always warming up and never staying on full cold (like the dashboard gauge sometimes does).
I did a quick thermostat test by starting the car with a cold engine and then ran it at 1800 rpm for 10 mins. The ECT warmed to 92C and the dashboard temp gauge showed normal temp this time!
Here are copies of the full Auto-Scan and the OBD-II modes 1 thru 9:
Thursday,16,June,2022,11:52:03:13474
VIN: TRURD38J781003564   License Plate:
Chassis Type: 8J (1K0)
Scan: 01 02 03 08 09 15 16 17 19 22 25 26 37 42 44 46 47 52 55 56
          65 77
VIN: TRURD38J781003564   Mileage: 168530km-104719miles
26-Auto Roof -- Status: Malfunction 0010
Address 01: Engine        Labels: 022-906-032-BDB.lbl
   Part No SW: 022 906 032 HG    HW: 022 906 032 GP
   Component: TT-3.2-DQ-LEV2  G   1166
   Revision: 1QH02---    Serial number: AUX7Z0G4FNA03D
   Coding: 0000178
   Shop #: WSC 01236 785 00200
   VCID: 57EB864A930E2E93DE5-8002
   VINID: 92296250321A1C8040003146100F4EAC7A
001169 - Secondary Air Injection System: Bank 1
               P0491 - 002 - Insufficient Flow
                    Fault Status: 01100010
                    Mileage: 168327 km
                    Date: 2022.06.07
                    Time: 18:13:17
                    RPM: 1259 /min
                    Load: 26.3 %
                    Speed: 30.0 km/h
                    Temperature: 37.0°C
                    Temperature: 36.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 13.335 V
008599 - Oxygen (Lambda) Sensor B2 S1
               P2197 - 001 - Signal too Low (Lean) - Intermittent
                    Fault Status: 00100001
                    Mileage: 168330 km
                    Date: 2022.06.07
                    Time: 18:18:15
                    RPM: 1625 /min
                    Load: 36.5 %
                    Speed: 64.0 km/h
                    Temperature: 67.0°C
                    Temperature: 38.0°C
                    Voltage: 13.589 V
008577 - Performance Malfunction in Cooling System
               P2181 - 008 -  - Intermittent - MIL ON
                    Fault Status: 10101000
                    Mileage: 168332 km
                    Date: 2022.06.07
                    Time: 18:22:04
                    RPM: 1508 /min
                    Load: 54.1 %
                    Speed: 60.0 km/h
                    Temperature: 72.0°C
                    Temperature: 39.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 13.462 V
Readiness: 0000 1100
   Part No SW: 02E 300 011 BL    HW: 02E 927 770 AD
   Component: GSG DSG         082 1396
   Revision: 05308020    Serial number: 00001001050882
   Shop #: WSC 04940 001 00001
   VCID: 5AED9F7EE01C33FBE1B-800E
Address 03: ABS Brakes        Labels: 8J0-614-517.clb
   Part No SW: 8J0 614 517     HW: 8J0 614 517
   Component: ESP MK60E1          0130
   Revision: 00H52001
   Coding: 0017985
   VCID: 6A8DCFBE307CA37B71B-803E
                    Reset counter: 91
                    Mileage: 167698 km
                    Date: 2022.05.09
                    Time: 00:26:22
                    Count: 128
                    Count: 13057
                    Count: 297
                    Count: 42496
Address 08: Auto HVAC        Labels: 8J0-820-043.clb
   Part No SW: 8J0 820 043 AJ    HW: 8J0 820 043 AJ
   Component: J255  Klima 1 Zone  0080
   Revision: 00H07003    Serial number: 00000001035418
   Coding: 1048870
   VCID: 6E85C3AE0C944F5B2D3-803A
                    Fault Frequency: 62
                    Reset counter: 117
                    Mileage: 147276 km
                    Date: 2019.12.27
                    Time: 22:20:46
                    Reset counter: 90
                    Mileage: 167698 km
                    Date: 2022.05.09
                    Time: 00:26:23
Address 09: Cent. Elect.        Labels:. 8P0-907-279-23-H.lbl
   Part No SW: 8P0 907 279 H    HW: 8P0 907 279 H
   Component: Bordnetz-SG     H46 1802
   Revision: 00H46000    Serial number: 00000007051043
   Coding: F1041E83C0141C0003180000180000000028EE075A250802
   VCID: 42DD471E688C9B3B99B-8016
   Subsystem 1 - Part No: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer AU354   H07 0060
   Coding: 00064784
   Shop #: WSC 01236
   Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH13 0090
   Coding: 00149804
   Shop #: WSC 01236
02498 - Left Low Beam Reflector Motor (V294)
                    Fault Status: 01111100
                    Reset counter: 77
                    Mileage: 140192 km
                    Date: 2019.06.28
                    Time: 12:01:00
                    Voltage: 14.00 V
Address 15: Airbags        Labels: 8J0-959-655.lbl
   Part No SW: 8J0 959 655     HW: 8J0 959 655
   Component: -F Airbag 9.43  H02 0020
   Revision: 93H02002    Serial number: 0036K001CDNZ
   Coding: 0011590
   VCID: 79AFE0F245DA18E3881-802C
   Subsystem 1 - Part No: 8J0 910 339 A
   Component: BF-Gewichtsens. H02 0030
   Subsystem 2 - Serial number: 00HEQ
   Subsystem 3 - Serial number: 0001.01.0000H0200000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332DRB404F885A2Zÿ†63
   Subsystem 5 - Serial number: 885A2Zÿ†6342DRB40510490EHÿ†63
   Subsystem 6 - Serial number: 0490EHÿ†63747RB402338650Aÿ†63
   Subsystem 7 - Serial number: 38650Aÿ†63847RB402338722Bÿ
   Subsystem 8 - Serial number: 38722Bÿ
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Component: J0527           H36 0070
   Coding: 0013141
   VCID: 41DF48126D8A8023801-8014
   Component: E0221           H06 0030
Address 17: Instruments        Labels: 8J0-920-xxx-17-MY7.lbl
   Part No SW: 8J0 920 990 C    HW: 8J0 920 990 C
   Component: KOMBIINSTR. VDO H21 0070
   Revision: D0H21004    Serial number: 2244G004003096
   Coding: 0049268
   Shop #: WSC 07470 067 57207
   VCID: 323D17DED82C2BBB09B-8066
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H12 0170
   Revision:   H12       Serial number: 33001074270A8C
   Coding: FF8F23CA07005100
   VCID: 2F3B1EAACB1E0653665-807A
Address 22: AWD        Labels: 1K0-907-554.lbl
   Part No: 1K0 907 554 L
   Component: Haldex 4Motion      0116
   Coding: 0000001
   VCID: 36352BCE3444379B253-8062
   Revision: D0H21004    Serial number: AUX7Z0G4FNA03D
Address 26: Auto Roof        Labels: 8J7-959-255.lbl
   Part No: 8J7 959 255 B
   Component: 256 VSG TT      H13 0110
   VCID: 3E2533EE1C74FFDBFD3-806A
02000 - Switch Position
                    Fault Status: 01101000
                    Reset counter: 3
                    Mileage: 151801 km
                    Date: 2020.07.24
                    Time: 21:11:10
03247 - Sensor for Canopy Flap; Right (G597)
                    Reset counter: 3
                    Mileage: 151801 km
                    Date: 2020.07.24
                    Time: 21:11:10
Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
   Part No SW: 8J0 035 192 B    HW: 8J0 035 192 B
   Component: RNS-E US3       H10 0150
   Revision:      01S    Serial number: AUZBZ7G3801110
   Coding: 0610617
   VCID: 2809F5B6EEF0516BA7F-807C
02446 - Disk Drive Mechanical Malfunction
                    Fault Status: 00100011
                    Reset counter: 223
                    Mileage: 152782 km
                    Date: 2020.09.11
                    Time: 21:02:22
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MAX1.lbl
   Part No: 8J7 959 801 C
   Component: Tuer-SG         H02 0060
   Coding: 0001077
   VCID: 3C2139E60A68EDCBD37-8068
   Part No: 8J1 909 143 B
   Component: EPS_ZFLS Kl.155 H07 1807
Address 46: Central Conv.        Labels:. 8J0-959-433.lbl
   Part No: 8J0 959 433 A
   Component:    KSG          H06 0070
   Coding: 1B9032824138093F0F0FC88A0433
   Shop #: WSC 25167 444 84593
   VCID: 343111C62238258B1B7-8060
00956 - Key 2
Address 47: Sound System        Labels: 8J0-035-223.lbl
   Part No SW: 8J0 035 223 B    HW: 8J0 035 223 B
   Component: J525 Amp Std    H03 0120
   Revision: 00H03001    Serial number: 93802002219906
   Coding: 0206136
   VCID: 2313E29A97D6B233F2D-8076
Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MAX1.lbl
   Part No: 8J7 959 802 C
   Coding: 0001077
   VCID: 3D2734E21172E4C3E49-8068
   Part No SW: 4F0 910 357 F    HW: 4F0 907 357 F
   Coding: 0000024
   VCID: 290FF0B2F5FA6863B81-807C
   Subsystem 1 - Part No: 8E0 941 329 A
   Component: AFS-Modul links H04 0020
   Subsystem 2 - Part No: 8E0 941 329 A
   Component: AFS-Modul rechtsH04 0020
Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
   Coding: 0610617
                    Reset counter: 223
                    Mileage: 152782 km
                    Date: 2020.09.11
                    Time: 21:02:22
Address 65: Tire Pressure        Labels: 8J0-907-273.lbl
   Part No SW: 8J0 907 273 A    HW: 8J0 907 273 A
   Component: J502_RDK        H02 0300
   Revision: --H02-D0    Serial number: 12679770503286
   Coding: 0840019
   Part No SW: 8P0 862 335 J    HW: 8P0 862 335 J
   Component: FSE_255x BT     H26 0290
   Revision: 00000000    Serial number: 00000005026658
   Coding: 0011407
End----(Elapsed Time: 01:28, VBatt start/end: 12.0V/12.0V. VIgn 0.0V)------
Thursday,16,June,2022,15:35:26:13474
VCDS Release 22.3.1 (x64):  Generic OBD2
Mode 01 - PID 01 : Readiness  --  Address 7E8
Number of DTCs stored: 1  --  MIL Status: MIL ON
Misfire monitoring:  Passed
Fuel System:  Passed
Comprehensive Components:  Passed
Catalyst monitoring:  Passed
Heated catalyst monitoring: Not installed.
Evaporative system monitoring:  Failed or Incomplete
Secondary air system monitoring:  Failed or Incomplete
A/C system refrigerant monitoring: Not installed.
Oxygen sensor monitoring:  Passed
Oxygen sensor heater monitoring:  Passed
Exhaust Gas Recirculation: Not installed.
Thursday,16,June,2022,15:34:46:13474
Freeze Frame Data for address 7E8
    PID02 DTC that caused freeze frame data storage: P2181
    PID03 Fuel system 1/2 status: Closed loop, using O2 sensors
              ... Open loop, due to system fault detected
    PID04 Calculated load value: 54.1 %
    PID05 Engine coolant temperature: 72 °C
    PID06 Short Term Trim - Bank 1: 1.6 %
    PID07 Long Term Trim - Bank 1: -2.3 %
    PID08 Short Term Trim - Bank 2: 0.0 %
    PID09 Long Term Trim - Bank 2: 0.0 %
    PID0C Engine RPM: 1508 /min
    PID0D Vehicle speed: 60 km/h
    PID0E Ignition timing advance for cyl #1: 24.5 Degrees
    PID0F Intake air temperature: 39 °C
    PID10 Mass Air Flow: 20.47 g/s
    PID11 Absolute Throttle Position: 18.4 %
    PID12 Secondary Air Status: Atmosphere/off
    PID1F Time since engine start: 576 s
Thursday,16,June,2022,15:34:10:13474
Mode 03: Emission related fault codes
Address 7E8: 1 Fault Found:
P2181 - Performance Malfunction in Cooling System
Address 7E9: No fault code found.
Thursday,16,June,2022,15:33:32:13474
Mode 07: Pending emission related fault codes
P0491 - Secondary Air Injection System: Bank 1: Insufficient Flow
Thursday,16,June,2022,15:32:09:13474
Type 02 - VIN : TRURD38J781003564 (Address E8)
Type 04 - Calibration ID : 022906032HG 1166 (Address E8)
Type 06 - Calibration Verification Number : C14146EF (Address E8)
Type 06 - Calibration Verification Number : 00001FF4 (Address E9)
Type 08 - In-use performance tracking :
    OBD Monitoring Conditions Encountered count : 5509
    Ignition cycle count : 20537
         Catalyst monitor bank 1 : 5270 / 5238
         Catalyst monitor bank 2 : 4838 / 5060
         O2 Sensor monitor bank 1 : 4377 / 5509
         O2 Sensor monitor bank 2 : 4321 / 5493
         EGR-VVT monitor : 14375 / 5509
         AIR monitor : 2484 / 1310
         EVAP monitor : 1634 / 808
Type 0A - Controller Name : ECM-Engine Control (Address E8)
Jef
HQ
I would suggest to get the latest and greatest coolant temp sensor from the dealer first.
Live data for coolant temp will be found in 01-08-001.2
Instrument cluster will have coolant data as well in 17-08-003.1
There looks to be a firmware update for the ECM. You currently have 022 906 032 HG @ 1166 (firmware version). The firmware update should be at 1317. I do not find info on what the firmware update is for. Any firmware updates will be done via the dealer.
For the P0491 fault code, first verify the SAI pump is running. Start the engine and let idle for +5 seconds. Then key on / engine off. Connected to ECM and go to function 03 for Output Test. One of those test will operate the J299 relay for SAI pump... verify the pump does pulse on/off when this is running.
EuroX
Northern NJ USA
C?ID=208579
Cooling system performance has always always been a faulty thermostat in these cars. I would recommend replacing thermostat. Then I would look why its running lean. Most likely vacuum leak.
SwissJetPilot
Switzerland
C?ID=317276
For your convertible top Roof Flap Servos (RFS) Fault under Address 26 (03247 - Sensor for Canopy Flap; Right (G597) I would recommend you follow this link to our forum and then use the VCDS to perform the roof flap Adaptation.
Audi will encourage you to replace one or both of the RFS which may or may not solve the problem. The problem is usually caused by excess grease that migrates from the internal gears onto the circuit board thus triggering an implausible signal fault. It's a pretty easy DIY and many Roadster owners have done it with good success.
Any time you run your very first fault diagnostic, always run a full scan then clear all the faults. Many of these might be old faults that were never cleared in the past and are no longer relevant. Take the car out for a spin (10 minutes is enough to get it warmed up) and run another fault scan. Any faults that come up this time need to be addressed.
save-jpg.390081
SwissJetPilot
Switzerland
C?ID=317276
For the 3.2 VR6 BUB engine, if you have a vacuum leak originating from the back of the valve cover, on the back of the "hump" behind the oil cap, you may hear a tea kettle whistle from the little hole back there. If that's the case your PCV diaphragm has failed as is leaking.
Unfortunately, Audi doesn't have a repair kit. Instead, they will happily sell you a brand new valve cover for around $500. Now there are after market diaphragms available, but you will have to pull the valve cover to get to it which is a major PITA.
An alternative method is to remove the OEM breather tube, replace it with a breather tube from a VW Touareg and then block the vent hole in the valve cover with an M4 screw. When the time comes to remove the valve cover; (e.g. timing chain, tensioner replacement, etc.) then you can replace the OEM diaphragm if you want to.
You can read more about it here -
pcv-venthole-jpg.444893
