RNS 510 English Language reverted to German
Dinosaur Doug
Mount Riverview, Australia
C?ID=495269
2010 Tiguan (5N) in Australia
Normal Day - going for a drive and when starting up I noticed the display was in German. Went through Setup and selected English but received message "The desired language could not be selected" since Cancel was the only option offered, I cancelled and was duly informed: "Ausgewahlte Sprache wurde nicht geladen."
Tried to find a solution in VCDS but wasnt able to identify one.
Have attached an Autoscan - there are other issues evident - rear camera has been on the blink for years after a rear-ender was repaired (it only works in the rain). The CEL comes on whenever the EGR system needs a clean out.
Any suggestions (apart from learning German :))
Thursday,16,June,2022,14:16:57:41453
VIN: WVGZZZ5NZAW086734   License Plate: BND000
Mileage: 334620km-207923mi   Repair Order:
Chassis Type: 5N-VW36 (1K0)
Scan: 01 03 08 09 10 15 16 17 19 22 25 2E 37 42 44 46 52 53 55 56
          62 69 6C 72 77
VIN: WVGZZZ5NZAW086734   Mileage: 334620km-207923miles
Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 RN    HW: 03L 906 022 RP
   Component: R4 2.0l TDI G000SG  9979
   Revision: 13H03---    Serial number:
   Coding: 0000172
   Shop #: WSC 13758 002 1048576
   VCID: 025D828588050FCBD9B-8056
   VINID: 9E65EAAAA15EA919C02061C310795CAEA4
008213 - Intake Manifold Flap Position Sensor (Bank 1)
               P2015 - 000 - Implausible Signal - MIL ON
                    Fault Status: 11100000
                    Mileage: 326812 km
                    Date: 2016.11.06
                    Time: 21:49:08
                    Lambda: 11.0 %
                    Lambda: 7.1 %
                    Voltage: 0.304 V
                    Bin. Bits: 00000000
Readiness: 1 1 0 0 0
Address 03: ABS Brakes        Labels: 5N0-614-109-C4.clb
   Part No SW: 5N0 614 109 L    HW: 5N0 614 109 L
   Component: J104    C4 450 V11D 0003
   Revision: --H28---    Serial number: 00000002572358
   Coding: 0006444
   Shop #: WSC 01324 020 00200
   VCID: 3431145D8231717B1B7-8060
   Part No SW: 5K0 907 044 BT    HW: 5K0 907 044 BT
   Component: Climatronic   H15 0709
   Revision: 00003001
   Coding: 0000001002
   VCID: 7EA5F675F07D6B2BBD3-802A
9481988 - Air Quality Sensor
          B10AF 04 [009] - Internal System Fault
                    Reset counter: 29
                    Mileage: 326878 km
                    Date: 2022.06.16
                    Time: 16:04:13
   Part No SW: 5K0 937 087 D    HW: 5K0 937 087 D
   Component: BCM PQ35 H    011 0028
   Revision: BE011001
   Coding: 48180A3B9025F1C0400800803400092441553088736D85605C8000000000
   VCID: 36352E55984D636B253-8062
   Subsystem 1 - Part No SW: 5N2 955 119     HW:              Labels: 1KX-955-119.CLB
   Component: Wischer 22021  012 0203
   Serial number:   N2955119   °203!
   Coding: 009795
   Component: RLS 230210 05  54  0403
   Coding: 03304D
Address 10: Park/Steer Assist (J791)       Labels:. 1T0-919-475.clb
   Part No SW: 1T0 919 475 H    HW: 1T0 919 475
   Component: PARKHILFE PLA H07 0110
   Revision: --------    Serial number: 88591004939396
   Coding: 301003
   VCID: 40D9488DCA89DDDB8FF-8014
01626 - Sensor for Parking-Aid; Front Right (G252)
            014 - Defective
                    Fault Status: 01101110
                    Fault Frequency: 150
                    Reset counter: 9
                    Mileage: 326812 km
                    Date: 2016.11.06
                    Time: 21:58:19
                    Temperature: 20.0°C
01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
                    Fault Status: 00101110
                    Fault Frequency: 186
                    Reset counter: 68
                    Mileage: 326812 km
                    Date: 2016.11.06
                    Time: 23:46:40
                    Temperature: 28.0°C
   Part No SW: 5N0 959 655 J    HW: 5N0 959 655 J
   Component: J234__202 VW10 HI   1916
   Revision: 20013000    Serial number: 003E2P3HKTRB
   Coding: 0012338
   VCID: 44D1449DD291C1FBAB7-8010
   Subsystem 1 - Serial number: 6332MTS634160420
   Subsystem 2 - Serial number: 6342MTS618260420
   Subsystem 3 - Serial number: 6351HTS64PV186KJ
   Subsystem 4 - Serial number: 6361HTS6TPS186KR
   Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
   Coding: 0000332
   VCID: 78A9E06DDED9551BF7F-802C
   Component: E0221           002 0030
   Part No SW: 5N0 920 871 C    HW: 5N0 920 871 C
   Component: KOMBI         H05 0305
   Coding: 110F00
   VCID: 313F1D4971A34453701-8064
   Part No SW: 1K0 907 530 AF    HW: 1K0 907 951
   Component: J533  Gateway   H20 0592
   Revision:   H20       Serial number: 190210F2000440
   Coding: F9A37F46404612006003
   Shop #: WSC 20093 959 93518
   VCID: 6B83CF219F8FEE830AD-803E
   Part No SW: 0AY 907 554 C    HW: 0AY 907 554 C
   Component: Haldex 4Motion      0041
   Coding: 0000005
   VCID: 4BC36FA1FFCF0E836AD-801E
   Component: IMMO          H05 0305
   VCID: 6A8DCA259CF5F78B71B-803E
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Revision: A1001003    Serial number: 7667831321
   VCID: 2615FE1548ED13EB953-8072
   Part No SW: 1T0 035 680 C    HW: 1T0 035 680 C
   Component: RNS-MID       H06 2680
   Revision: AB001001    Serial number: VWZ6Z7K5058044
   Coding: 040004020400008000
   VCID: 2E050635601D5BAB6D3-807A
                    Fault Frequency: 76
                    Reset counter: 67
                    Mileage: 326872 km
01523 - Microphone for Telephone (R38)
                    Reset counter: 29
                    Mileage: 326812 km
                    Date: 2016.11.06
                    Time: 21:48:19
   Part No SW: 5N0 959 701 D    HW: 5N0 959 701 D
   Component: Tuer-SG         009 2102
   Coding: 0000700
   VCID: 36352E55944D636B253-8062
   Part No: 5N0 909 144 J
   Component: EPS_ZFLS Kl. 202    3001
   Revision: 00H17000
   Shop #: WSC 01324 785 00200
   VCID: 3829206D9E59951B37F-806C
   Part No SW: 5N0 959 702 D    HW: 5N0 959 702 D
   Coding: 0000700
   VCID: 372B235193479A633E5-8062
   Part No SW: 3AA 907 801 B    HW: 3AA 907 801 B
   Component: J540 EPB4  VW-49878 0004
   Revision:   H17       Serial number: 00000000003709
   Coding: 0023057
   VCID: 3039184D76294D5B7FF-8064
Address 55: Headlight Range        Labels: 5M0-907-357-V2.clb
   Component: AFS-Steuergeraet    0142
   Coding: 1361350
   Component: AFS-Lst.-Modul l    0005
   Coding: 00000020
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    0005
   Coding: 00000020
                    Fault Frequency: 76
                    Reset counter: 67
                    Mileage: 326872 km
                    Reset counter: 29
                    Mileage: 326812 km
                    Date: 2016.11.06
                    Time: 21:48:19
   Part No SW: 5N0 959 703 D    HW: 5N0 959 703 D
   Component: Tuer-SG         007 2102
   Coding: 0000144
   Shop #: WSC 01324 020 1012552
   Part No SW: 1K0 907 383 E    HW: 1K0 907 383 E
   Component: Anhaenger     H08 0080
   Revision: 3A002002    Serial number: 00000121204148
   Coding: 0100000100000000
   VCID: 2F3B1B31671752A3665-807A
16355 - Control Module - Watchdog Timer
            014 - Defective
                    Reset counter: 119
                    Mileage: 307634 km
                    Date: 2016.01.17
                    Time: 15:27:19
   Part No SW: 5N0 907 441 A    HW: 5N0 907 441 A
   Component: J772__Rearview      0020
   Revision: 00H07000    Serial number: 525PA8-J021661
   Coding: 0020010
   VCID: 2D070139611B20B3549-8078
   Part No SW: 5N0 959 704 D    HW: 5N0 959 704 D
   Coding: 0000144
   VCID: 392F2569A5538C13C81-806C
Address 77: Telephone (J738)       Labels:. 1K8-035-730.clb
   Part No SW: 1K8 051 730 B    HW: 1K8 051 730 B
   Component: Telefon       H02 5400
   Revision: 00002000    Serial number: 20389520249140
   Coding: 412120
End----------(Elapsed Time: 01:51, VBatt start/end: 12.2V/12.2V)-----------
iichel
Eindhoven, NB, NL
C?ID=284912
You could go into the adaptation channels of your RNS and look for language (or Sprache, if you insist on German terminology). Or give it a hard reset by holding the power button for about 30 seconds and/or disconnecting the fuse/quadlock to make sure it's not just off but super-off.
langers2k
C?ID=224085
I think German language is common with corrupt firmware?
AFAIK, the most mentioned solution seems to be reinstalling the RNS firmware assuming you can find the correct version for your unit.
Dinosaur Doug
C?ID=495269
Thanks iichel, I will give the hard reset a try first, if that doesn't correct the problem I will follow langers2k advice and look up reinstalling firmware procedure.
Any advice about how the firmware becomes corrupted?
iichel
Eindhoven, NB, NL
C?ID=284912
Sometimes a bit just falls over, NAND memory goes a bit bad, electromagnetic interference, cosmic radiation... it just happens :)
Dinosaur Doug
C?ID=495269
Ahhh! And I thought maybe Miss Tiggy was becoming demented and reverting to her childhood language!
