Hi all,
I working on a Crafter SY ACC retrofit. All are ok, 1 thing is missing.
The coding....
Can anybody sending the a full LOG from the Crafter SY with original ACC functions and automatic transmission?
I need info about the speed sensors too. I need a Crafter ( with original ACC ) rear and front speed sensors too.
Thank you very much!
The coding....
Wednesday,18,May,2022,11:15:41:01826
VCDS Version: 22.3.1.4 (x64) HEX-V2 CB: 0.4615.4
Workshop Code: 585 55555 018585
VIN: WV1ZZZSYZK License Plate: CRAFTER ACC
Mileage: 46521km-28906mi Repair Order:
Chassis Type: SY-VN54 (3Q0)
Scan: 01 02 03 08 09 10 15 17 19 42 44 52 5F 69 BB BC
VIN: WV1ZZZSYZK Mileage: 46521km-28906miles
BB-Door Rear Drv -- Status: Cannot be reached 0100
BC-Door Rear Pass -- Status: Cannot be reached 0100
Address 01: Engine (J623-DAUA) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 EP HW: 04L 907 445 C
Component: R4 2.0l TDI H01 6410
Revision: 23201001
Coding: 002A40346314010800000000000000000000000000000000
ASAM Dataset: EV_ECM20TDI03004L906056EP 005006
ROD: EV_ECM20TDI03004L906056EP_005.rod
VCID: 7F5AFD05F77D0ED3B65-802A
VINID: 9E606AAAA8E9A9B240149181005CD1B50B
23871 - EGR System
P0401 00 [096] - Insufficient Flow
Mileage: 45531 km
Date: 2022.03.30
Time: 14:42:29
Engine RPM: 1364.25 /min
Normed load value: 44.7 %
Vehicle speed: 56 km/h
Coolant temperature: 91 °C
Intake air temperature: 20 °C
Voltage terminal 30: 12.554 V
Unlearning counter according OBD: 8
EGR travel diagnosis: strongly increased NOx emission: 0.00 kg/h
Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: 23.15 %
EGR travel diagnosis: marginally increased NOx emission: -23.00 kg/h
Mass airflow sensor 1 bank 1 airflow: raw value: 478.2 mg/stroke
Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 74.71 %
Charge press. ctrl deviation after throttle valve bank 1-Pressure_16_signed_10_mbar: -5.0 mbar
O2 sens. 1 bank 1 upstrm oxi cat: raw value: 2.363 counts
Exhaust recirc.valve 1 bank 1: posit.feedback - Raw voltage: 2.786 V
Readiness: N/A
Address 02: Auto Trans (J217) Labels: 09G-927-749-V2.clb
Part No SW: 09G 927 158 CT HW: 09G 927 158
Component: AISIN AQ8 206 3508
CVN: 1EF87AF1
Coding: 0000000100000000010000000000000000000000
Shop #: WSC 00069 790 00016
ROD: EV_TCMAQ450031_VN54.rod
VCID: 074A65E5AFAD46138E5-8052
22984 - Gear Shift Lock Solenoid Control Circuit
P0929 00 [040] - Implausible Signal
Reset counter: 151
Mileage: 45550 km
Date: 2022.03.31
Time: 13:19:38
Engine RPM: 830.0 /min
Transmission input speed: 784 /min
Engine torque: -8 Nm
ATF temperature: 43 °C
Accelerator pedal position: 0.0 %
Clutch_C1: Open
Clutch_C2: Open
Clutch_C3: Open
Clutch_C4: Open
Clutch_B1: Open
Clutch_B2: Open
Lock Up Clutch: Open
Electrical Oil Pump target revolution: 65534 /min
Electrical Oil Pump actual revolution: 65279 /min
Engine Speed signal Current: 65279 /min
Electrical Oil Pump failure status with Electrical Oil Pump without HV 1: Motor normal stop
Electrical Oil Pump target current: 65278 mA
Part No SW: 2N0 907 379 C HW: 2N0 907 379 C
Component: ESC_base H02 0850
Serial number: 08502412190317
Coding: 25A824774842B68BA44D246112436D063A0000BA
ASAM Dataset: EV_Brake1ESP90iBOSCHVN54X 701028
ROD: EV_Brake1ESP90iBOSCHVN54X_701.rod
VCID: 3634D82198C70F9B253-8062
Address 08: Auto HVAC (J301) Labels:* None
Part No SW: 7C0 907 426 AD HW: 7C0 907 426 AD
Component: AC Manuell H01 0401
Coding: A03010000800000001000800500101000000000000000000000000000000
Shop #: WSC 00069 790 00035
ASAM Dataset: EV_AirCondiBHTCVN54X 003020
ROD: EV_AirCondiBHTCVN54X_003_VN54.rod
VCID: 6B823955930582730AD-803E
Part No SW: 5Q0 937 084 DA HW: 5Q0 937 084 CD
Component: BCM MQBAB B H38 0273
Serial number: 00001909200351
ROD: EV_BCMBOSCH_019_VW27.rod
VCID: 7AAC0C11EC5F2BFB81B-802E
Steering Column Switch:
Subsystem 1 - Part No SW: 5Q1 953 521 AK HW: 5Q1 953 569
Component: Lenks.Modul H03 0170
Serial number: 0100250220190C301399
12307 - License Plate Light
B12CA 01 [009] - Electrical Failure
Fault Frequency: 23
Reset counter: 115
Mileage: 43603 km
Date: 2022.01.16
Time: 17:37:49
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
OFF: Not operated
Position lamps: Not operated
Low beam: operated
last_wakeup: gültiges Funktelegramm
Voltage: 11.9 V
Outside temperature: 1.5 °C
Part No SW: 5QA 919 294 E HW: 5QA 919 294
Component: PDC 8 KanalH07 0443
Serial number: 000308418019080
Coding: 0431151151
ROD: EV_EPHVA18AU3700000.rod
VCID: 4EC490C10057575B0D3-801A
Part No SW: 3Q0 959 655 CL HW: 3Q0 959 655 CL
Component: Airbag VW21 006 0720
Revision: -------- Serial number: 003Z1P6H4J3R
Coding: 800080000000000040000000000800000065
ROD: EV_AirbaVW21TS6VW48X_VN54.rod
VCID: 0A4C5CD1BCBF3B7B91B-805E
Subsystem 1 - Part No SW: ----------- HW: 454 801 802 19
Component: FrontSensor_D 305 0109
Serial number: 3550051E0E917000000L
Subsystem 2 - Part No SW: ----------- HW: 454 801 802 19
Component: FrontSensor_P 305 0109
Serial number: 35600A2F7E917000000-
Part No SW: 7C0 920 741 B HW: 7C0 920 741 B
Component: KOMBI 211 2700
Coding: 07A411082080000800086A001400000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009068
ROD: EV_DashBoardVDDMQBAB_VW27.rod
VCID: 231211753B558A33F2D-8076
Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Component: GW MQB High 442 4368
Revision: -------- Serial number: 0008736338
Coding: 030000344F05730000000000000F00010001070000000000000000000000
GVL: 01443C0000000000C00C00000000C80000000000000000000000000000000000
ROD: EV_GatewNF_VW27.rod
VCID: 6E843041A017775B2D3-803A
Generator:
Component: 0-00-00-00-00
Subsystem 2 - Part No SW: 2N0 915 181 HW: 2N0 915 181
Component: J367-BDMConti H03 1051
Serial number: 758849020019032905F6
8531970 - Quiescent Current
U1406 00 [008] - Too High
[Ruhestrom oberer Grenzwert überschritten]
Fault Frequency: 13
Reset counter: 190
Terminal 30 power supply: 12.2 V
Terminal 15: OFF
Part No SW: 5Q4 959 393 F HW: 5Q4 959 393 F
Component: TSG FS 006 0246
Serial number: 0000370529493
Coding: 00300B208000020100001000
VCID: 46D4A8E1E8279F1BB53-8012
196665 - Switch for Central Locking
B122D 29 [009] - Signal Implausible
Reset counter: 175
Mileage: 46163 km
Date: 2022.05.06
Time: 08:59:36
Address 44: Steering Assist (J500) Labels:| 2N0-909-143.clb
Part No SW: 2N0 909 143 G HW: 2N0 909 143 C
Component: EPS_MQB_ZFLS 701 7031
Coding: 0107
ASAM Dataset: EV_SteerAssisMNB 002009
ROD: EV_SteerAssisMNB.rod
VCID: 313EEB3D71A928A3701-8064
Part No SW: 5Q4 959 392 F HW: 5Q4 959 392 F
Component: TSG BFS 006 0246
Serial number: 0000370368809
VCID: 45D6AFEDD5219403BC9-8010
Part No SW: 3Q0 035 846 B HW: 3Q0 035 846 B
Component: MU-S-N-ER H41 0475
Serial number: VWZAZ2W0336588
Coding: 064500013C00000051110001000808001F0500D401200500CE
ROD: EV_MUStd4CTSAT_VN47.rod
VCID: 3038EE397AA321AB7FF-8064
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H64 0032
Serial number: VWZ8Z9V4P00JEL
Subsystem 2 - Part No SW: V03 825 254 AC HW: -----------
Component: ECE DL1 22/23 --- 1810
5688 - Control Head for Mulimedia System
B13C9 F2 [008] - On/Off Switch
Reset counter: 208
Mileage: 45919 km
Date: 2022.04.22
Time: 13:34:13
Voltage terminal 30: 12.7 V
6179 - Display Module 1 for Multimedia System
B1297 F6 [008] - Cable for Video Signal; Open Circuit
Reset counter: 215
Mileage: 46152 km
Date: 2022.05.05
Time: 16:45:45
Voltage terminal 30: 14.1 V
Part No SW: 6C0 907 383 G HW: 6C0 907 383 G
Component: Anhaenger H27 0260
Revision: 8D001004 Serial number: 0511644860
Coding: 0100000202000000
ROD: EV_TrailFunctGener2Hella_VW27.rod
VCID: 2E04F0416097375B6D3-807A
Address BB: Door Rear Drv
Address BC: Door Rear Pass
End----------(Elapsed Time: 00:58, VBatt start/end: 12.1V/12.1V)-----------
