ABS long Coding needed for Frankencar (MK60EC1)
Vees Auto
South Africa
C?ID=493967
Tuesday,14,June,2022,11:07:49:10524
VIN: WVWZZZ13ZDV026684   License Plate:
Chassis Type: 13-VW36 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ13ZDV026684   Mileage: 140390km-87234miles
Address 01: Engine (J623-CAXA)       Labels:. 03C-906-016-CAX2.clb
   Part No SW: 03C 906 016 BS    HW: 03C 907 309 F
   Component: MED17.5.5     H13 4772
   Revision: LCH13---    Serial number:                CVN: 526BC66E
   Coding: 00190012000400000000
   Shop #: WSC 00020 999 00000
   ASAM Dataset: EV_ECM14TFS01103C906016BS 001010
   ROD: EV_ECM14TFS01103C906016BS_VW36.rod
   VCID: 71BED6FA012B8B43301-8024
   VINID: 9E69EAAAA043A9498008618810350C593B
5523 - Engine Start Blocked by Immobilizer
          P1570 00 [046] - -
                    Fault Frequency: 20
                    Mileage: 140386 km
                    Date: 2022.06.08
                    Time: 02:20:49
                    Engine RPM: 722.00 /min
                    Normed load value: 17.3 %
                    Coolant temperature: 90 °C
                    Intake air temperature: 53 °C
                    Ambient air pressure: 950 mbar
                    Voltage terminal 30: 13.829 V
                    Mass flow through throttle valve: 7.8 kg/h
                    Mean injection time: 0.820 ms
                    Engine operating condition-Channel 87: Idle
                    Relative load value: 20.39 %
                    Torque request: sum of auxiliary aggregate: 6.2 Nm
                    Engine torque: 25.8 Nm
Readiness: 0010 0101
   Revision: 00H31001
   Shop #: WSC 00066 000 00000
   VCID: 7DA6FACA4DF3FF23A49-8028
03306 - Coding Not Valid
                    Reset counter: 208
                    Mileage: 140395 km
                    Date: 2016.10.30
                    Time: 06:27:14
                    Count: 3
                    Count: 2
                    Count: 28672
                    Count: 4161
                    Count: 43008
                    Count: 65280
                    Count: 512
                    Reset counter: 208
                    Count: 16391
                    Count: 12
                    Count: 8448
                    Count: 195
                    Count: 43264
                    Count: 512
                    Fault Status: 01100101
                    Reset counter: 208
                    Mileage: 140395 km
                    Date: 2016.10.30
                    Time: 06:22:05
                    Count: 3
                    Count: 2
                    Count: 28672
                    Count: 295
                    Count: 43008
                    Count: 65280
                    Count: 512
                    Reset counter: 208
                    Mileage: 140395 km
                    Date: 2016.10.30
                    Time: 06:22:05
                    Count: 3
                    Count: 2
                    Count: 28672
                    Count: 270
                    Count: 43008
                    Count: 65280
                    Count: 512
   Part No SW: 7N0 907 426 AM    HW: 7N0 907 426 AM
   Component: AC Manuell    H19 0404
   Revision: 00001018
   Coding: 0000001002
   Shop #: WSC 00066 000 00119
   VCID: 7F5A00C2477FED33B65-802A
   Part No SW: 5K0 937 086 M    HW: 5K0 937 086 M
   Component: BCM PQ35 M    021 0064
   Revision: BC021001
   Coding: 04000A3A802DE1C040080080040001E40170008850A089605C8000000040
   VCID: 3E243DC60075243BFD3-806A
   Component: RLS 160212 05  54  0403
   Coding: 02300A
   Subsystem 2 - Part No: 1K8 951 171
12 Faults Found:
                    Reset counter: 247
                        Term 15 Off
                    Voltage: 5.35 V
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 203
                    Mileage: 140377 km
                    Date: 2016.10.29
                    Time: 08:02:54
                    Voltage: 14.25 V
00984 - Left Tail Light (M4)
                    Fault Status: 00101010
                    Reset counter: 248
                    Mileage: 140377 km
                    Date: 2016.10.29
                    Time: 08:02:54
                    Voltage: 14.25 V
00985 - Right Tail Light (M2)
                    Reset counter: 248
                    Mileage: 140377 km
                    Date: 2016.10.29
                    Time: 08:02:54
                    Voltage: 14.20 V
                    Reset counter: 247
                    Mileage: 140395 km
                    Date: 2016.10.29
                    Time: 00:00:01
                        Term 15 Off
                    Voltage: 12.25 V
                    Reset counter: 207
                    Mileage: 140377 km
                    Date: 2016.10.29
                    Time: 08:02:53
                    Voltage: 14.05 V
                    Reset counter: 203
                    Mileage: 140377 km
                    Date: 2016.10.29
                    Time: 08:03:06
                    Voltage: 13.00 V
                    Reset counter: 203
                    Mileage: 140377 km
                    Date: 2016.10.29
                    Time: 08:03:06
                    Voltage: 13.00 V
                    Reset counter: 207
                    Mileage: 140377 km
                    Date: 2016.10.29
                    Time: 08:02:53
                    Voltage: 14.05 V
                    Reset counter: 203
                    Mileage: 140377 km
                    Date: 2016.10.29
                    Time: 08:02:53
                    Voltage: 14.10 V
                    Reset counter: 203
                    Mileage: 140377 km
                    Date: 2016.10.29
                    Time: 08:02:59
                    Voltage: 14.20 V
                    Reset counter: 203
                    Mileage: 140377 km
                    Date: 2016.10.29
                    Time: 08:02:59
                    Voltage: 14.20 V
   Part No SW: 5C0 959 655 C    HW: 5C0 959 655 C
   Component: AirbagVW10    013 0613
   Serial number: 003G6M02T4WS
   Coding: 00003241
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 323C19F6C4ADF05B09B-8066
   Serial number: 3572MSME3F35146BZZZ+
   Serial number: 3582MSME3735146BZZZY
   Serial number: 3516KSME01000C18ZZZB
   Serial number: 3526KSME02107717ZZZF
9440027 - Driver's side; side-airbag igniter
          B100B 1B [137] - Resistance Too High
                    Mileage: 140377 km
                    Date: 2022.06.08
                    Time: 08:01:51
9438491 - Igniter for Driver head airbag
          B1005 1B [137] - Resistance Too High
                    Mileage: 140377 km
                    Date: 2022.06.08
                    Time: 08:01:51
          B1006 1B [137] - Resistance Too High
                    Mileage: 140377 km
                    Date: 2022.06.08
                    Time: 08:01:51
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
          B1007 1B [137] - Resistance Too High
                    Mileage: 140377 km
                    Date: 2022.06.08
                    Time: 08:01:51
   Part No SW: 1K5 953 521 AK    HW: 5K0 953 569 B
   Revision: FF010040    Serial number: 20120208301542
   Coding: 0082140000
   Shop #: WSC 00066 000 00187
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 76B4E5E66845AC7BE53-8022
   Component: E221__MFL-TAS  H09 0013
   Coding: 820000
   Part No SW: 5C6 920 871     HW: 5C6 920 871
   Component: KOMBI         H04 0617
   Coding: 171A01
   VCID: 698EBE9A29FB7383781-803C
   Part No SW: 7N0 907 530 M    HW: 1K0 907 951
   Component: J533  Gateway H42 1623
   Revision:   H42       Serial number: 14031201270685
   Coding: 351003
   VCID: 3A2C31D61C5D081BC1B-806E
   Component: IMMO          H04 0617
   VCID: 6A8CC1962CFD789B71B-803E
   Component: TUER-SG FT    002 0515
   Revision: 13110009    Serial number: 0004293956
   Coding: 0002B5
   Shop #: WSC 01383 790 50316
   VCID: 5BE29452F3A71113FAD-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 704 B    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  007 1508
   Serial number: 00000006472651
   Coding: 000290
          B11EC 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 204
67330 - Switch for Central Locking
          B122D 29 [008] - Signal Implausible
                    Reset counter: 248
                    Mileage: 140395 km
                    Date: 2022.06.10
                    Time: 03:04:58
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 68     3305
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 372A28E2234F15733E5-8062
   Component: TUER-SG BT    002 0515
   Revision: 15110009    Serial number: 0004333479
   Coding: 0002B4
   VCID: 5CE0974EF6A9162BF37-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 703 B    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  008 1508
   Serial number: 00000006532187
   Coding: 000290
          B11EC 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 248
   Part No SW: 1K0 035 186 AN    HW: 1K0 035 186 AN
   Component: Radio RCD310  042 0082
   Revision: 01000001    Serial number: VWZ1Z2M4235371
   Coding: 05000400040006
   VCID: 72BCD9F604ADB05BC9B-8026
End----(Elapsed Time: 01:11, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
etz2k
C?ID=69430
Your VIN is from a Scirocco, please check this.
iichel
Eindhoven, NB, NL
C?ID=284912
Yes but all other parts are from a Jetta. Probably Scirocco clocks + ECU in a Jetta.
2kaa52
C?ID=319193
Match your immobilizer system first,then its time for abs coding
