Transporter T5 wipers not stopping (sort of)
somlioy
Norway
C?ID=210881
Hello
Got a slight issue on a 2005 Transporter T5, and since M.O.T is coming up I need this sorted.
The problem is that the wipers starts at stage 1 speed as soon as I turn the ignition on. The interval function dose not work, stage 2 however does (wiper speeds up). Putting the wiper stalk in "off-position" does absolutely nothing.
I've noticed that if I'm turning the right blinker on everything works as normal except that if I turn the wiper stalk to stage 1 while the blinker is still blinking it'll stop. While the right blinker is on the interval works as it should with different interval lengths etc. This tells me that the "home-feedback" from the wiper motor is functioning(?). Vag-Com confirms this aswell, see pictures later. However there's a fault code on this which is odd.
I removed the T18a connector from the BCM and Wiper stage 1 is still active in both vag-com and "live". T18a contains the wires from the wiper-stalk.
I also removed the BCM from the car, opened it up to check the wiper relay, turns out it's fine. Then I powered the BCM from my bench supply and as soon as I applied power the wiper relay clicks. I tried jumping both the home-position pin and stage 1 pin without any changes. Stage 2 pin however powered the other part of the relay. (It's a relay with two coils)
Does anyone know what the heck is wrong? Am I wrong to conclude a defective BCM? (Based on the fact that it's energizing stage 1 immediately when only power is applied to the BCM?)
I took some images from measurements blocks to show you.
This image shows the state with the wiper-stalk in off-position:
Interval position:
Stage 1 is no different from off-position with only "Wiper-switch stage 1" activated
Stage 2:
Here you can see the wiper stage 1 is deactivated while the right blinker is activated. Wiper-stalk in off-position:
And last two images with the wiper "outside" and "inside" the park position:
Outside:
Home:
Auto-scan:
Sunday,14,June,2015,13:52:12:59807
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
VIN: WV1ZZZ7HZ6H032669   License Plate:
Mileage: 99480km-61814mi   Repair Order: 13042005
          57 6E 76 77 78 7D
VIN: WV1ZZZ7HZ6H032669   Mileage: 99480km-61814miles
   Part No SW: 038 906 016 N    HW: 028 101 185 5
   Component: R4 1,9L EDC 0000SG  6209
   Revision: 12345678    Serial number: VWZ7Z0E2697723
   Coding: 0000031
   Shop #: WSC 02756 785 00200
   VCID: 1F4DED53CD5443D9775-5124
Readiness: 0 0 X X X
Address 03: ABS Brakes        Labels: 7H0-907-37x-ASR-F.lbl
   Part No: 7H0 907 379 G
   Component: ASR FRONT MK25      0103
   Coding: 0007205
   VCID: 397923CB73B00DE9691-5106
Address 09: Cent. Elect.        Labels: 7H0-937-049.lbl
   Part No: 7H0 937 049 N
   Component: BORDNETZ SGVER 1.0  1001
   Coding: 0000037
   Shop #: WSC 02737 785 00200
   VCID: 3D7137DB679831C9459-5106
00909 - Windshield Wiper Motor (V) Stage 1/2
00077 - Windshield Wiper Stop Switch (F229)
00888 - Wiper Switch for Intermittent Operation (E22)
   Part No: 1C0 909 605 A
   Component: 3C AIRBAG VW51      0008
   Coding: 13123
   Shop #: WSC 02756
   VCID: 224BE4A7AE266E3158B-5106
Address 17: Instruments        Labels: 7Hx-920-xxx-17.lbl
   Part No: 7H0 920 851 D
   Component: KOMBI+WEGFAHRSP VDO V03
   Coding: 01111
   Shop #: WSC 00082
   VCID: 2C570A9FDCE2A841E27-5106
   WV1ZZZ7HZ6H032669     VWZ7Z0E2697723
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 02737
   VCID: 70EFDEEF304A8CA19EF-5106
Address 56: Radio        Labels: 1J0-035-15x-56.lbl
   Part No: 6X0 035 153 A
   Component:  Radio BNO         0007
   Coding: 00001
   Shop #: WSC 02737
   VCID: 306F1EEFF0CACCA1DEF-4AE8
00852 - Loudspeaker(s); Front
            36-10 - Open Circuit - Intermittent
somlioy
Norway
C?ID=210881
BCM replaced, problem solved. :)
Bit odd tho. I mean such an odd fault to just appear on the BCM.
