Coming / leaving home
khaledabdulaziz
Israel
C?ID=394371
i have VW golf 2008, need to do coming/leaving home tweak but it doesnt work when doing it with vcds and activate it on 09 control module
anyone can help me figure out why? always having customers who wants this tweak but never work but on a passat 2006?
and could someone tell me if it can be done with wires ?
autoscan
Saturday,11,June,2022,14:19:51:04619
VCDS Version: 22.3.0.1 (x64)  HEX-V2 CB: 0.4615.4
Data version: 20220225 DS336.1
VIN: WVWZZZ1KZ7W214286   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 56 76 77
VIN: WVWZZZ1KZ7W214286   Mileage: 118620km-73707miles
37-Navigation -- Status: Cannot be reached 1100
Address 01: Engine        Labels: 06A-906-033-BGU.lbl
   Part No: 06A 906 033 EN
   Component: SIMOS71 1.6l 2VG    9443
   Revision: --H03---    Serial number: VWZBZ0G0577496
   Coding: 0000075
   Shop #: WSC 47953 133 82731
   VCID: 6FBBD587CB9C2CC3268-803A
   VINID: 9E69EAAAA05BA879C20440881821C676C2
16825 - EVAP Emission Control Sys
            P0441 - 008 - Incorrect Flow - Intermittent
                    Load: 9.4 %
                    (no units): 0.13
                    Lambda: 0.0 %
                    T.B. Angle: 2.4�
                    Load: 2.4 %
                    (no units): 0.06
                    Lambda: 0.0 %
                    T.B. Angle: 2.4�
Readiness: 0000 1000
   Part No: 09G 927 750 ET
   Component: AQ 250 6F           0842
   Coding: 0008264
   Shop #: WSC 01392 785 00200
   VCID: 074B9D27C32C14838E8-8052
Address 03: ABS Brakes        Labels:. 1K0-614-517-MK60AT.clb
   Part No SW: 1K0 614 517 AC    HW: 1K0 614 517 AC
   Component: ESP FRONT MK60-AT   0102
   Revision: 00H14001
   Coding: 0021121
   VCID: 6889BE9BEE72FBFB672-803C
   Part No SW: 1K0 907 044 BM    HW: 1K0 907 044 BM
   Component: ClimatronicPQ35 110 1010
   Revision: 00110021    Serial number: 00000000000000
   VCID: 73B3D9F7A7B40823C20-8026
   Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000006778514
   Coding: 018D0F2700041500471400001400000000097F075C0001
   Shop #: WSC 00000 785 00200
   VCID: 6C81C28BFA8AD7DB03A-8038
   Component: Wischer 200207 020  0501
   Coding: 00038805
01800 - Light Switch (E1)
                    Reset counter: 3
                    Mileage: 118150 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.30 V
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Frequency: 83
                    Reset counter: 218
                    Mileage: 118150 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.15 V
                    Fault Status: 00101010
                    Fault Frequency: 123
                    Reset counter: 3
                    Mileage: 118150 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.30 V
   Component: 37 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD12943P
   Coding: 0013111
   Shop #: WSC 01373 785 00200
   VCID: 3D273FCFD1708E53E44-8068
   Subsystem 1 - Serial number: 6332MSME10315B01-
   Subsystem 2 - Serial number: 6342MSME1764150D9
   Subsystem 3 - Serial number: 6352QSME2328105DB
   Subsystem 4 - Serial number: 6362QSME2332055DB
   Part No SW: 1K0 953 549 AP    HW: 1K0 953 549 AP
   Component: Lenks�ulenmodul 036 0070
   Coding: 0010042
   VCID: 0059863BE60223BBCF2-8054
   Part No SW: 1K0 920 863 A    HW: 1K0 920 863 A
   Component: KOMBIINSTRUMENT VN4 8212
   Revision: V0007000    Serial number: VWZBZ0G0577496
   Coding: 0003103
   Shop #: WSC 80093 222 69422
   VCID: 290FFB9F35F802F3B8C-807C
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0021
   Revision:   H04 02    Serial number: 260207F1000910
   Coding: 3F0F07C807000002
   VCID: 2F3B15870B1C6CC3668-807A
                    Reset counter: 145
                    Mileage: 97847 km
                    Time: 13:42:39
01304 - Radio
                    Fault Status: 00110100
                    Reset counter: 2
                    Mileage: 97847 km
                    Time: 13:42:39
   Part No: 1K0 920 863 A
   Component: IMMO VN4            8212
01176 - Key
Address 37: Navigation
   Part No SW: 1K0 959 701 N    HW: 1K0 959 701 N
   Component: Tuer-SG         005 0985
   Coding: 0000180
   VCID: 392F2BDFC558B273C8C-806C
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.069 H07 1806
   Shop #: WSC 00000 028 00001
   VCID: 34311AEBE23A4F1B1BA-8060
   Part No: 1K0 959 433 CP
   Coding: 80C802087F2D840548CB03E010CC
   Part No SW: 1K0 959 702 N    HW: 1K0 959 702 N
   Coding: 0000436
   VCID: 3A2D34D3C05EB96BC16-806E
00106 - Signal Central Locking SAVE/LOCK Passenger Side
Address 56: Radio
Address 76: Park Assist        Labels: 1K0-919-283.lbl
   Part No: 1K0 919 283 A
   Component: 22 Einparkhilfe     0101
   VCID: 2D070F8F01101ED3544-8078
Address 77: Telephone        Labels: 3C0-035-729.lbl
   Part No SW: 3C0 035 729 F    HW: 3C0 035 729 F
   Component: Telefon             7009
   Revision: 00012000    Serial number: 0000000859276
   Coding: 0016041
   Shop #: WSC 47953 133 97049
   VCID: 2615F0A324E62D8B95E-8072
00385 - Positive Output Audio Channel for Speech/Telephone
                    Reset counter: 174
                    Mileage: 98265 km
                    Time: 19:59:58
00386 - Negative Output Audio Channel for Speech/Telephone
                    Reset counter: 174
                    Mileage: 98265 km
                    Time: 19:59:58
01304 - Radio
                    Reset counter: 2
                    Mileage: 97847 km
                    Time: 13:42:38
End----------(Elapsed Time: 01:04, VBatt start/end: 12.6V/12.6V)-----------
Westbury, UK
Do you have auto lights? To work properly coming/leaving home needs auto lights.
TBAx
C?ID=287144
Looking at the auto scan it seems he doesn’t have a RLS so it might be impossible with the current spec.
khaledabdulaziz
Israel
C?ID=394371
I was wondering if there is a way with wires ?
also while I was searching the 09 control module for the coming/leaving home i saw an option saying 0:coming home personalization/1:RLS coming home
does anyone knows what that means?
@khaledabdulaziz Hi: With the caveat that I know very little about your 1K chassis vehicle, there has been some dialogue about this very matter on MQB platform posts. In the case of these more modern cars- simulating CH/LH when a RLS isn't installed is possible via coding mods - but in your car, perhaps not?
Anyhow, extrapolating the MQB solution - maybe a wiring based alternative is to use the internal cabin-light ciruit as a trigger for a relay that connects power to whichever lights you want to operate for CH/LH function. Depending on which lights you select and conditional on the car's circuit wiring, you may need to install blocking-diodes to stop back-feeding into the native wiring - but even with this safe-guard, it's a very easy set-up IMO.
In its simplest form (i.e. sans diodes), the circuit is like this (for each chosen CH/LH lamp, of course):
Note:
  • this circuit assumes that the "chosen lamp" is not monitored for errors (if the lamp is switched-ON at the same time that the cabin light is illuminated, the electrical current in the "native wire" drops to zero)
  • this is not a real CH/LH solution - it simply simulates the facility because it operates whenever the cabin lighting is active
The suggestion is yours to consider and if you market the solution, I require 10% of ALL sales - only kidding!:)
EDIT: changes made to diagram following remedial DIN72552 training!!:banghead:
Zenerdiode
Newcastle, England
C?ID=24330
Ahem, Don, T31 is actually chassis ground; did you mean T30 in your little drawing? :o
