- May 27, 2022
- 12
- 9
- Plymouth, UK
- C?ID=519620
Hi all,
thank you very much for the add. Just to give some brief background, we added an A3 to our collection which had it's speedometer stuck on 20mph. After some diagnostics, I concluded that the speedo motor / bearing is the offending party and proceeded to purchase a second hand replacement with the exact same part number.
I got a bit trigger happy and connected the new cluster, went to switch on the car, and of course, the immo kicked in and the car would not start. When I went back to the old cluster, a bunch of codes appeared relating to ABS / brakes, and the last one remaining relates to the uncoded control module. (Code 01042 - see below)
I am planning on trying to pull the login codes for the clusters from a locksmith and will then try to adapt. In the mean time, could anyone help with pinpointing the correct code?
Thanks!
Thanks!
Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: Release 22.3.1(x64) Data version: 20220407 DS337.0
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Friday,27,May,2022,18:31:58:55637
VIN: WAUZZZ8P69A094828 License Plate:
Mileage: 178110km-110672mi Repair Order:
Chassis Type: 8P-AU35 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WAUZZZ8P69A094828 Mileage: 178110km-110672miles
25-Immobilizer -- Status: Sporadic communication error 1000
------------------------------------------------------------------------------- Address 01: Engine Labels: 03G-906-021-BLS.clb
Part No SW: 03G 906 056 S HW: 03G 906 021 AB
Component: R4 1,9L EDC 000SG 2917
Revision: --H09--- Serial number: AUX7Z0HDFN40TF
Coding: 0000071
Shop #: WSC 00145 210 96588
VCID: 372B26D0634011E33E5-8062
VINID: 9D196AAAA22018944024420220291BC716
Readiness: 0 0 0 0 0 -------------------------------------------------------------------------------
Self-Diagnosis Log
Page 2
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
Coding: 000000000000000000000000000000000000
Shop #: WSC 06314 000 00000
VCID: 74B1D1DC3EB6BAFBDB7-8020
Reset counter: 179
Mileage: 178115 km
Date: 2022.05.26
Time: 01:41:49
Count: 16391
Count: 2
Count: 8192
Count: 195
Count: 47360
Count: 65280
------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8P0-820-047.clb
Part No: 8P0 820 047 B
Component: J255 Klima Man H07 0030
VCID: 2F3B1EB09B10D923665-807A
004 - No Signal/Communication - Intermittent -------------------------------------------------------------------------------
Self-Diagnosis Log
Page 3
Address 09: Cent. Elect. Labels:. 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000009247573
Coding: 10A82F81B0141380EF00001C0000000000084A1564010401002800000000
Shop #: WSC 06314 000 08192
VCID: 48C9552C1EBE6E1B47F-801C
Subsystem 1 - Part No: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00056595
Shop #: WSC 06314
Fault Status: 01101100
Reset counter: 179
Mileage: 177969 km
Date: 2022.04.21
Time: 19:27:00
Voltage: 11.90 V
Reset counter: 179
Mileage: 177969 km
Date: 2022.04.21
Time: 19:39:00
Voltage: 11.95 V
Self-Diagnosis Log
Page 4
------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:* 8P0-959-655-10.clb
Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003000000000
Coding: 303142383038303030374A55305238503053
ROD: EV_Airba10AURB4.rod
VCID: 49CF502809349713581-801C
Serial number: 3572DRB400008598793Z
Serial number: 3582DRB400008594A2C.
Serial number: 35128RB4000048D77F7-
Serial number: 35228RB4000048AFA98/
Serial number: 35547RB400004A3A02AJ
Serial number: 35647RB400004A3A075K
No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
Component: J0527 036 0070
Coding: 0000002
VCID: 78A9E5EC2EDEDE9BF7F-802C
Self-Diagnosis Log
Page 5
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 C HW: 8P0 920 982 C
Component: KOMBIINSTR. VDO H19 0860
Revision: D0H19007 Serial number: 224DH007012093
Coding: 0006428
VCID: 392F20E855540793C81-806C
No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533__Gateway H16 0210
Revision: H16 Serial number: 3400K08C110BDE
Coding: E9807F06000202002103
Reset counter: 219
------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H19007 Serial number: AUX7Z0HDFN40TF
Self-Diagnosis Log
Page 6
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H03 0060
Coding: 0000692
VCID: 43D3420027984D4392D-8016
008 - Implausible Signal - Intermittent ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 E
Component: EPS_ZFLS Kl. 232 2501
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2C0109BCAA06A23B437-8078
No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 J
Component: KSG H11 0080
Coding: 1980202002186D0985054C9FC637
Subsystem 2 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
00332 - Control Circuit for Tank Flap
007 - Short to Ground - Intermittent -------------------------------------------------------------------------------
Self-Diagnosis Log
Page 7
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0000692
VCID: 44D1411C22964A7BAB7-8010
No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 152 C HW: 8P0 035 152 C
Component: R Chorus2+ H20 0270
Revision: 00H20000 Serial number: AUZ1Z2H2544618
Coding: 0000221
VCID: 2B030AA0AF08A5034AD-807E
No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
Component: Tuer-SG H04 0040
Coding: 0000144
Shop #: WSC 06314 000 1012544
VCID: 41DF48083D845F53801-8014
012 - Electrical Fault in Circuit - Intermittent ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
Coding: 0000144
VCID: 42DD47043882444B99B-8016
End----------(Elapsed Time: 01:10, VBatt start/end: 12.3V/12.3V)----------
