Audi A3 8P (2009) ABS Control Module Coding (MK60EC1)
snakku
Plymouth, UK
C?ID=519620
Hi all,
thank you very much for the add. Just to give some brief background, we added an A3 to our collection which had it's speedometer stuck on 20mph. After some diagnostics, I concluded that the speedo motor / bearing is the offending party and proceeded to purchase a second hand replacement with the exact same part number.
I got a bit trigger happy and connected the new cluster, went to switch on the car, and of course, the immo kicked in and the car would not start. When I went back to the old cluster, a bunch of codes appeared relating to ABS / brakes, and the last one remaining relates to the uncoded control module. (Code 01042 - see below)
I am planning on trying to pull the login codes for the clusters from a locksmith and will then try to adapt. In the mean time, could anyone help with pinpointing the correct code?
Thanks!
Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: Release 22.3.1(x64) Data version: 20220407 DS337.0
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Friday,27,May,2022,18:31:58:55637
VIN: WAUZZZ8P69A094828 License Plate:
Mileage: 178110km-110672mi Repair Order:
Chassis Type: 8P-AU35 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WAUZZZ8P69A094828 Mileage: 178110km-110672miles
25-Immobilizer -- Status: Sporadic communication error 1000
------------------------------------------------------------------------------- Address 01: Engine Labels: 03G-906-021-BLS.clb
 Part No SW: 03G 906 056 S HW: 03G 906 021 AB
 Component: R4 1,9L EDC 000SG 2917
 Revision: --H09--- Serial number: AUX7Z0HDFN40TF
 Coding: 0000071
 Shop #: WSC 00145 210 96588
 VCID: 372B26D0634011E33E5-8062
 VINID: 9D196AAAA22018944024420220291BC716
Readiness: 0 0 0 0 0 -------------------------------------------------------------------------------
Self-Diagnosis Log
Page 2
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
 Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
 Component: ESP MK60EC1 H35 0106
 Revision: 00H35001
 Coding: 000000000000000000000000000000000000
 Shop #: WSC 06314 000 00000
 VCID: 74B1D1DC3EB6BAFBDB7-8020
 Reset counter: 179
 Mileage: 178115 km
 Date: 2022.05.26
 Time: 01:41:49
 Count: 16391
 Count: 2
 Count: 8192
 Count: 195
 Count: 47360
 Count: 65280
------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8P0-820-047.clb
 Part No: 8P0 820 047 B
 Component: J255 Klima Man H07 0030
 VCID: 2F3B1EB09B10D923665-807A
 004 - No Signal/Communication - Intermittent -------------------------------------------------------------------------------
Self-Diagnosis Log
Page 3
Address 09: Cent. Elect. Labels:. 8P0-907-279-30-H.lbl
 Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
 Component: Bordnetz-SG H54 2801
 Revision: 00H54000 Serial number: 00000009247573
 Coding: 10A82F81B0141380EF00001C0000000000084A1564010401002800000000
 Shop #: WSC 06314 000 08192
 VCID: 48C9552C1EBE6E1B47F-801C
 Subsystem 1 - Part No: 8P2 955 119 F Labels: 1KX-955-119.CLB
 Component: Wischer AU350 H10 0040
 Coding: 00056595
 Shop #: WSC 06314
 Fault Status: 01101100
 Reset counter: 179
 Mileage: 177969 km
 Date: 2022.04.21
 Time: 19:27:00
 Voltage: 11.90 V
 Reset counter: 179
 Mileage: 177969 km
 Date: 2022.04.21
 Time: 19:39:00
 Voltage: 11.95 V
Self-Diagnosis Log
Page 4
------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:* 8P0-959-655-10.clb
 Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
 Component: Airbag AU1042 H06 0090
 Revision: -------- Serial number: 003000000000
 Coding: 303142383038303030374A55305238503053
 ROD: EV_Airba10AURB4.rod
 VCID: 49CF502809349713581-801C
 Serial number: 3572DRB400008598793Z
 Serial number: 3582DRB400008594A2C.
 Serial number: 35128RB4000048D77F7-
 Serial number: 35228RB4000048AFA98/
 Serial number: 35547RB400004A3A02AJ
 Serial number: 35647RB400004A3A075K
No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
 Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
 Component: J0527 036 0070
 Coding: 0000002
 VCID: 78A9E5EC2EDEDE9BF7F-802C
Self-Diagnosis Log
Page 5
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
 Part No SW: 8P0 920 982 C HW: 8P0 920 982 C
 Component: KOMBIINSTR. VDO H19 0860
 Revision: D0H19007 Serial number: 224DH007012093
 Coding: 0006428
 VCID: 392F20E855540793C81-806C
No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
 Part No SW: 1K0 907 530 S HW: 1K0 907 951
 Component: J533__Gateway H16 0210
 Revision: H16 Serial number: 3400K08C110BDE
 Coding: E9807F06000202002103
 Reset counter: 219
------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
 Revision: D0H19007 Serial number: AUX7Z0HDFN40TF
Self-Diagnosis Log
Page 6
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
 Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
 Component: Tuer-SG H03 0060
 Coding: 0000692
 VCID: 43D3420027984D4392D-8016
 008 - Implausible Signal - Intermittent ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
 Part No: 1K0 909 144 E
 Component: EPS_ZFLS Kl. 232 2501
 Revision: 00H15000
 Shop #: WSC 02069 000 90108
 VCID: 2C0109BCAA06A23B437-8078
No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8P0-959-433.lbl
 Part No: 8P0 959 433 J
 Component: KSG H11 0080
 Coding: 1980202002186D0985054C9FC637
 Subsystem 2 - Part No: 1K0 907 719 C
 Component: Neigungssensor 005 0003
 Subsystem 3 - Part No: 8P0 951 177
 Component: Innenraumueberw.H04 0020
00332 - Control Circuit for Tank Flap
 007 - Short to Ground - Intermittent -------------------------------------------------------------------------------
Self-Diagnosis Log
Page 7
 Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
 Coding: 0000692
 VCID: 44D1411C22964A7BAB7-8010
No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 8J0-035-1xx-56.clb
 Part No SW: 8P0 035 152 C HW: 8P0 035 152 C
 Component: R Chorus2+ H20 0270
 Revision: 00H20000 Serial number: AUZ1Z2H2544618
 Coding: 0000221
 VCID: 2B030AA0AF08A5034AD-807E
No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
 Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
 Component: Tuer-SG H04 0040
 Coding: 0000144
 Shop #: WSC 06314 000 1012544
 VCID: 41DF48083D845F53801-8014
 012 - Electrical Fault in Circuit - Intermittent ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
 Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
 Coding: 0000144
 VCID: 42DD47043882444B99B-8016
End----------(Elapsed Time: 01:10, VBatt start/end: 12.3V/12.3V)----------
Greetings from the US , I think you will need to post another Auto-Scan as your format is a bit difficult to follow.
IIRC from other similar posts, you don't want to use the "print" tab ; use the copy tab and go to logs file on your PC or copy and paste to your notepad. I believe that is what is usually recommended.
Do check your Scans sub-folder to see if perhaps you've done a scan before you swapped clusters?
snakku
Plymouth, UK
C?ID=519620
Hi both, thank you for your reply. I will try to pull a new auto scan tomorrow when I am near the car.
Unfortunately I did this before I purchased the kit so I do not have any back up.
The VIN triangle seems to agree though which gives me hope that this is recoverable!
Oh, I'm confident that it is, but I also know I'm not the person to do it. Stand by. I expect someone will come up with some coding(s) for you to try.
snakku
Plymouth, UK
C?ID=519620
Hi all,
apologies for the delay. Please find attached new scan
Friday,10,June,2022,18:56:33:55637
   Coding: 0000071
   Revision: 00H35001
                    Reset counter: 179
                    Mileage: 178115 km
                    Date: 2022.05.26
                    Time: 01:41:49
                    Count: 16391
                    Count: 2
                    Count: 8192
                    Count: 195
                    Count: 47360
                    Count: 65280
   Coding: 00056595
   Shop #: WSC 06314
                    Reset counter: 179
                    Mileage: 177969 km
                    Date: 2022.04.21
                    Time: 19:27:00
                    Voltage: 11.90 V
                    Reset counter: 179
                    Mileage: 177969 km
                    Date: 2022.04.21
                    Time: 19:39:00
                    Voltage: 11.95 V
   Coding: 0000002
   Coding: 0006428
                    Reset counter: 219
Address 56: Radio
End----(Elapsed Time: 00:45, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
etz2k
C?ID=69430
This coding only fits if RHD, front brake disk=D280 and TMC=D22,2
w/ iTPMS: 13422012092B00FEC81304E6902100813C00
w/o iTPMS: 13422012092B00FEC81304E6902100813800
snakku
Plymouth, UK
C?ID=519620
Thank you very much both. Haven’t had a chance to try yet but will keep you updated!
Wishing you all a great weekend.
JMR
Romania
C?ID=432218
What do you mean you haven t had a chance to try it ? People worked hard to provide you with a solution and we re waiting for you to let us know if the solution works....
snakku
Plymouth, UK
C?ID=519620
Thank you very much Etz2k & Dana for the coding. I can confirm that the code without iTPMS has worked and the coding has been accepted!
Once again thanks for the time to look into it.
