SRI reset doesnt remove service reminder on DIS.
   #21
Bruce
Near Philadelphia, PA, USA
To be a little more complete, a quiescent current is:
that amount of current consumed from a power source by a single component or group of components in a circuit when the circuit is in its powered but non-operating state.
   #22
Gone But Not Forgotten
Sweet Bruce......... never thought to do a search as quiescent current.
Now this was helpful and opened up some reading that is informative.
To have a high efficiency, drop out voltage and quiescent current must be minimized. In addition, the voltage difference between input and output must be minimized, since the power dissipation of LDO regulators accounts for the efficiency.
   #23
Bruce
When designing circuits, especially for standby modes, one would like the quiescent current to be 0. However, one can also understand that the circuit cannot be standing by and ready to do any work, if it is not powered. So, when we design, we do our best to minimize the current drawn so the power used is minimized.
But we lead this thread astray!
   #24
Sorry.......OP/Forum
Well maybe make a new one that explains this in a part of a BDM understandings thread sticky, since BDM will be being discussed much more I suspect as time goes on.
   #25
rich dj
C?ID=245358
I think your on to something.....
UWE yes there are channels 50 to 56 with figures
50 is 145
51 is 365
52 is 190
53 is 137
54 is 730
55 is 358
56 is 1962
logs below
Thursday,18,June,2015,22:09:23:42520
VCDS Version: 14.10.2.0
Data version: 20150311
Adaptation Channel 050:
Stored value 145
  Basic Value
  Oil in 1
  00 Miles
  N/A
Thursday,18,June,2015,22:08:49:42520
Adaptation Channel 051:
Stored value 365
  Basic Value
  Oil in 1
  Days
  N/A
Thursday,18,June,2015,22:08:27:42520
Adaptation Channel 052:
Stored value 190
  Basic Value
  Insp. in 1
  00 km
  N/A
Thursday,18,June,2015,22:07:49:42520
Adaptation Channel 053:
Stored value 137
  Actual Value
  Insp. in 1
  00 Miles
  N/A
Thursday,18,June,2015,22:07:08:42520
Adaptation Channel 054:
Stored value 730
  Basic Value
  Insp. in 1
  Days
  N/A
Thursday,18,June,2015,22:06:37:42520
Adaptation Channel 055:
Stored value 358
  Actual Value
  Insp. in 1
  Days
  N/A
56 said N/A
So not sure what figures to change them too.
50 is 145
51 is 365
52 is 190
53 is 137
54 is 730
55 is 358
56 is 1962
OK, I'm scratching my head why those are there in a MY 2006 car... I don't think those channels should even exist in that car...?
If it was a 2008 or newer, it would work like this:
50=Distance Value for Oil Change with fixed Service Interval
51=Time Value for Oil Change with fixed Service Interval
52=Distance Value for Inspection
53=Distance since Inspection (if this exceeds 52, the light will be on)
54=Time Value for Inspection
55=Time since Inspection (if this exceeds 53, the reminder will be on)
56=Day Counter (since the car was delivered or built or something like that)
The thing is, 53 doesn't exceed 52 and 55 doesn't exceed 54, so this doesn't explain why your reminder won't go away either.
In other words, I'm still confused. :banghead:
Part No SW: 4F0 920 983 P HW: 4F0 920 983 P <<<<<<<<<<<<<<<<<<<<<<<<<<<<<
Component: KOMBIINSTR. 0900
Revision: 00000000 Serial number: AYR00DL79
Coding: 2049443
Shop #: WSC 00519 210 91291
VCID: 397E8C3870FF8AE9691-806C
Don't know if this is helpful.
If I look up the application of this A6 cluster 4F0-920-983P supersedes to PX.........however, makes the specific requirement of software version 4F0-910-930A be used.
That's not in the scan.
Further examination shows that this part #'s firmware was updated quite a few times being a loser.
Maybe this cluster is altered or is updated with wrong data?
   #28
rich dj
C?ID=245358
so perhaps i should pop to audi parts and get the mmi update discs, will they load if software is of same version? and or will audi supply them to me?
   #29
Not sure what Audi will do in UK but it doesn't hurt to inquire.
   #30
rich dj
C?ID=245358
Apparently the MMI update discs won't update the instrument cluster only via audi kit or vcds pro so I wonder what the garage have done ?
A friend has looked at his figures on his updated A6 for 50 to 55 and will stick them in when I get home as ready to try anything at the moment
Well, if you're ready to try anything, try zeroing out channels 53 and 55.
rich dj
C?ID=245358
Yes its sorted....... No More Service Reminder
I put in the values a friend on the Audi forum who has the updated version on his car the figures he gave me are as follows.
50 = 144
51 = 365
52 = 305
53 = 79
54 = 730
55 = 151
56 = 1704
56 didnt test or save so i didnt bother with that.
so thanks to every one for all your help, no more "ping" "service due".....
I should have bought this product before hand its really worth the money.
   #33
Happy to hear it's "fixed", but that still doesn't explain why the reminder was on, or why a cluster in a 2006 car has (or cares about) these channels at all.
rich dj
C?ID=245358
Thanks for your help Uwe, cant explain why either but worked out someone has has a fiddle before i got the car as the set clock by radio was on, in a uk car? and having wrong firmware maybe before I got the car or the garage (specialist loaded it by accident / lake of knowledge on particular car? who knows. So I await next service :-) which will be done according to my millage on the garage invoice and not the in car one :-)
   #35
rich dj
C?ID=245358
So what should the figures be set to on all the channels after a service ie if I want a 10000 mile service and not variable as I easily do more than 10000 a year.
And also the correct order of changing them. I assume this would be for a later model with the 50-55 numbers as well.
Thanks in advance. Rich
   #36
Try:
45:1
50:160
51:365
49:365
44:365
42:100
43:100
Jef
HQ
ST?ID=64328
2006 A6 with same type of problem. SRI reset, cluster was happy, but MMI was stating maybe 22 days until next service.
Tuesday,15,December,2015,14:56:31:46857
VCDS Version: 15.7.2.0 (x64)
Data version: 20151124
VIN: WAUDL74F56N070070   License Plate:
Mileage: 89710km-55743mi   Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 34 36 37 42 46 47 4F
          52 53 55 56 61 62 65 67 72 76 77
VIN: WAUDL74F56N070070   Mileage: 89710km-55743miles
   Part No SW: 4F0 910 560 E    HW: 4F0 907 559
   Component: 4.2L V8/5V      G   0010
   Revision: --H01---    Serial number:
   Coding: 0007772
   Shop #: WSC 02325 785 00200
   VCID: 244C2B66E76CF61E2F-8070
18010 - Power Supply Terminal 30
                    Temperature: -40.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
18061 - Please check DTC Memory of ABS Controller
            P1653 - 008 -  - Intermittent
                    Mileage: 89716 km
                    Date: 2009.01.28
                    Time: 00:01:25
                    Temperature: 75.0°C
                    Temperature: 43.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 11.938 V
   Part No SW: 4F1 910 156 Q    HW: 09L 927 156 A
   Component: AG6 09L 4,2 MPI USA 0040
   Revision: --H01---    Serial number:        4074590
   Coding: 0000002
   Shop #: WSC 02327 785 00200
   VCID: 3260DD3EAD9868AEAD-8066
Address 03: ABS Brakes        Labels: 4F0-910-517.lbl
   Part No SW: 4F0 910 517 L    HW: 4F0 614 517 L
   Component: ESP 8.0 quattro H04 0090
   Coding: 0017256
   VCID: 2D5ACE42B4A63756F0-8078
Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H31 0180
   Revision: 30070501    Serial number: 10600600237864
   Coding: 0000015
   Shop #: WSC 26153 444 57392
   VCID: 63CE687AA2E2B12616-8036
   Subsystem 1 - Part No: 4F0 910 131 L
   Component: FBSAUDIC6 EZS   H45 0070
   Component: FBSAUDIC6 KSG   H26 0080
   Component: FBSAUDIC6 IDG   H01 0040
Address 07: Control Head        Labels: 4F0-910-7xx-07-H.lbl
   Part No SW: 4F0 910 731 B    HW: 4E0 035 729
   Component: Interfacebox    H43 1190
   Revision: 00000000    Serial number: 303HU057505994
   Coding: 0000003
   Shop #: WSC 02335 785 00200
   VCID: 21422272F87EE33644-8074
   Component: Bedienteil MMIC6H07 0050
   Subsystem 2 - Serial number: 00000000215602
   Subsystem 3 - Serial number: 0117.08.050000000100010180ÿ
   Subsystem 4 - Serial number: 010180ÿ
Address 08: Auto HVAC        Labels: 4F0-910-043.lbl
   Part No SW: 4F0 910 043     HW: 4F1 820 043 S
   Component: KLIMABETAETIGUNGH12 0160
   Revision: 00000027    Serial number: 00000030047374
   Coding: 0008232
   VCID: 5BBE509A9A9289E65E-800E
   Part No SW: 4F0 910 279 C    HW: 4F0 907 279 A
   Component: ILM Fahrer      H15 0190
   Coding: 0114123
   VCID: 29523A52804E2B761C-807C
   Subsystem 1 - Part No: 4F1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H05 0150
   Coding: 00062736
   Shop #: WSC 02335
   Subsystem 2 - Part No: 4E0 910 557   Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH10 0050
   Coding: 00141886
   Shop #: WSC 02335
   Part No SW: 4E0 910 111 E    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0430
   Revision: 00000000    Serial number: AUZ5ZBE7227239
   VCID: 1B3E109ADA12C9E69E-804E
Address 0F: Digital Radio        Labels: 4E0-910-593-XM.lbl
   Part No SW: 4E0 910 593 E    HW: 4E0 035 593 A
   Component: SDAR
   Serial number: AUZ4Z7E3032769
            000 -  -
                    Reset counter: 154
                    Mileage: 89716 km
                    Raw, Form. N/A: 000 000 075
                    Raw, Form. N/A: 000 000 000
Address 15: Airbags        Labels: 4F0-910-655-8R.lbl
   Part No SW: 4F0 910 655 F    HW: 4F0 959 655 A
   Component: 66 AIRBAG AUDI8RH29 0300
   Revision: 12H29000    Serial number: 00359D0A28MT
   Coding: 0013878
   Shop #: WSC 26105 444 68460
   VCID: 2A50C55E8548206E15-807E
   Subsystem 1 - Part No: 4F0 910 339 A
   Component: BF-Gewichtsens. H02 0050
   Subsystem 2 - Serial number: 6332CSME0B3F2501+
   Subsystem 3 - Serial number: 6342CSME0B6279524
   Subsystem 4 - Serial number: 6352QSME05622D1FL
   Subsystem 5 - Serial number: 6362QSME064413613
   Subsystem 6 - Serial number: 63734SME04522275S
   Subsystem 7 - Serial number: 63834SME03691A45/
   Part No SW: 4F0 910 549     HW: 4F0 953 549 A
   Component: Lenksäulenmodul H07 0230
   Revision: 00H07000    Serial number: 90026052300447
   Coding: 0012041
   Shop #: WSC 02331 785 00200
   VCID: 66C8716E51D0C40EF1-8032
   Component: Lenkradmodul    H07 0080
   Part No SW: 4F0 920 983 R    HW: 4F0 920 983 R
   Revision: 00300000    Serial number: AYS41TN2A
   Coding: 2161283
   Shop #: WSC 26153 444 84168
   VCID: 3B7EF01A7AD2A9E67E-806E
00003 - Control Module
                    Fault Status: 01100101
                    Reset counter: 154
                    Mileage: 89716 km
                    Date: 2015.12.15
                    Time: 13:38:40
Address 19: CAN Gateway        Labels: 4F0-910-468.lbl
   Part No SW: 4F0 910 468 A    HW: 4F0 907 468 D
   Component: Gateway         H11 0070
   Revision: 11          Serial number: 13008058228143
   Coding: ECFE7BCD1B7904
   VCID: 27563C6A965A1D060A-8072
Address 34: Level Control        Labels: None
   Part No SW: 4F0 910 553     HW: 4F0 907 553
   Component: J197 LUFTFEDER  H15 0040
   Serial number: 006280014543
   Coding: 0000010
   Shop #: WSC 26105 444 59306
   VCID: 61C26272B8FEA33604-8034
   Part No SW: 4F0 910 760     HW: 4F0 959 760
   Component: Sitzmemory FS   H04 0050
   Revision: 00000000    Serial number: 00000000896400
   Coding: 0082954
   Part No SW: 4E0 910 887 N    HW: 4E0 919 887 C
   Component: MNS US          H45 0740
   Revision: 00000000    Serial number: 355GY057552990
   VCID: 3874EF164BE482FE93-806C
Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
   Part No SW: 4F0 910 793 E    HW: 4F0 959 793 E
   Component: TSG FA          H12 0080
   Revision: 00000000    Serial number: ‡G�
   Coding: 0051947
   Shop #: WSC 98765 666 36129
   VCID: 2C5CC3468FBC3E5EE7-8078
Address 46: Central Conv.        Labels: 4F0-910-289.lbl
   Part No SW: 4F0 910 289 G    HW: 4F0 907 289 G
   Component: Komfortgeraet   H19 0140
   Revision: 01400019    Serial number: 01006576030000
   Coding: 4619325
   VCID: 2E58C94EB9A04C4EC9-807A
Address 47: Sound System        Labels: 4F0-910-223-BO.lbl
   Part No SW: 4F0 910 223 A    HW: 4F0 035 223 A
   Component: DSP-High C6     H09 0140
   Revision: PROD_01     Serial number: 00000000801137
   Coding: 0000026
   VCID: 1C3C1386DF1CCEDE97-8048
02753 - Inside Microphone (R74)
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 154
                    Mileage: 89716 km
                    Date: 2015.12.15
                    Time: 13:04:24
                    Reset counter: 154
                    Mileage: 89716 km
                    Date: 2015.12.15
                    Time: 13:04:24
   Part No SW: 4F0 910 280     HW: 4F0 907 280 B
   Component: ILM Beifahrer   H10 0080
   Revision:             Serial number: 00000000006166
   Coding: 0012114
   VCID: 5EB8598E89809CCE39-800A
Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
   Part No SW: 4F0 910 793 E    HW: 4F0 959 792 E
   Component: TSG BF          H12 0080
   Revision: 00000000    Serial number: pwˆ
   Coding: 0051947
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801     HW: 4F0 907 801
   Component: EPB  C63C0030   H03 0030
   Revision: C63C0030
   Coding: 0006022
   Shop #: WSC 02334 785 00200
   VCID: 5DBA5E82848687D620-8008
   Part No SW: 4F0 910 357 F    HW: 4F0 907 357 F
   Coding: 0000017
   Shop #: WSC 26149 444 85834
   Subsystem 1 - Part No: 4F0 941 329 B
   Component: AFS-Modul links H02 0020
   Subsystem 2 - Part No: 4F0 941 329 B
   Component: AFS-Modul rechtsH02 0020
   Part No SW: 4E0 910 541 F    HW: 4F0 035 541 B
   Component: TUNER EU/US/RDW H42 0480
   Revision: 00000000    Serial number: 394HY057605618
   Coding: 0000002
   VCID: 234E287AE262F12656-8076
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4F0 910 181 E    HW: 4F0 915 181 A
   Component: ENERGIEMANAGER  H12 0490
   Revision: 00000000    Serial number: 00000000099504
   Shop #: WSC 26027 444 67044
   Subsystem 1 - Part No: 000 915 105 DL
   Component: von VA0  0340807717
   Coding: 303030393135313035444C56413030333430383037373137
   Shop #: WSC 00000 384 00291
02273 - Quiescent Current Stage 2
            000 -  -  - Intermittent
                    Date: 2015.12.15
                    Time: 14:15:04
Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 E    HW: 4F0 959 795 E
   Component: TSG HL          H21 0050
   Coding: 0051754
Address 65: Tire Pressure        Labels: 4F0-910-273-BA.lbl
   Part No SW: 4F0 910 273     HW: 4F0 907 273
   Component: Reifendruck 3   H04 0080
   Revision: 00040080    Serial number: 00000900009243
   Coding: 0062422
   VCID: 60C46776B3F4AA3E0B-8034
   Part No SW: 4E0 910 754 J    HW: 4E0 035 753 A
   Component: SDS 3501 US     H45 0600
   Revision: 00000000    Serial number: 00000508230354
   Shop #: WSC 12336 024 394758
Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
   Component: TSG HR          H21 0050
   Coding: 0051754
   Part No SW: 4F0 910 283 B    HW: 4F0 919 283 B
   Component: Parkhilfe 4-Kan H09 0020
   Revision: 00H09000    Serial number: 11720524401207
   Coding: 0001206
   Part No SW: 4F0 910 336 B    HW: 4E0 862 335
   Component: Handyvorb2      H11 0440
   Revision: 00000000    Serial number: 00000007516271
   Coding: 0010900
   VCID: 22402D7EFD78F82E5D-8076
End-------------------------(Elapsed Time: 03:09)--------------------------
;SW:4F0-920-983-R   HW:4F0-920-983-R ---  Instruments
;Component:KOMBIINSTR.         0900, Coding:2161283
;Tuesday,15,December,2015,14:42:27:46857
;VCDS Version: Release 15.7.2 (x64)  Data version: 20151124
;VCID: 3B7EF01A7AD2A9E67E-806E
;01 N/A
A02,0,
;0
A02,1,
;ServRemInd
A02,2,
;Closed
A02,3,
;Reset
A02,4,
A03,0,
;100
A03,1,
;N/A
A03,2,
;N/A
A03,3,
;N/A
A03,4,
;N/A
;04 N/A
;05 N/A
;06 N/A
;07 N/A
;08 N/A
A09,0,
A09,1,
;ERROR:
A09,2,
;Security
A09,3,
;access
A09,4,
;required
;10 N/A
;11 N/A
;12 N/A
;13 N/A
;14 N/A
;15 N/A
;16 N/A
;17 N/A
;18 N/A
A19,0,
;0
A19,1,
;N/A
A19,2,
;N/A
A19,3,
;N/A
A19,4,
;N/A
;20 N/A
A21,0,
;14
A21,1,
;Hour
A21,2,
;N/A
A21,3,
;N/A
A21,4,
;N/A
A22,0,
;38
A22,1,
;Minute
A22,2,
;N/A
A22,3,
;N/A
A22,4,
;N/A
A23,0,
;15
A23,1,
;Year
A23,2,
;N/A
A23,3,
;N/A
A23,4,
;N/A
A24,0,
;12
A24,1,
;Month
A24,2,
;N/A
A24,3,
;N/A
A24,4,
;N/A
A25,0,
;15
A25,1,
;Day
A25,2,
;N/A
A25,3,
;N/A
A25,4,
;N/A
;26 N/A
;27 N/A
;28 N/A
A29,0,
;136
A29,1,
A29,2,
;N/A
A29,3,
;N/A
A29,4,
;N/A
A30,0,
;129
A30,1,
A30,2,
;N/A
A30,3,
;N/A
A30,4,
;N/A
A31,0,
;0
A31,1,
A31,2,
;N/A
A31,3,
;N/A
A31,4,
;N/A
A32,0,
;0
A32,1,
A32,2,
;N/A
A32,3,
;N/A
A32,4,
;N/A
A33,0,
;128
A33,1,
;Wait
A33,2,
;N/A
A33,3,
;N/A
A33,4,
;N/A
A34,0,
;0
A34,1,
A34,2,
;N/A
A34,3,
;N/A
A34,4,
;N/A
A35,0,
A35,1,
;ERROR:
A35,2,
;Security
A35,3,
;access
A35,4,
;required
A36,0,
;0
A36,1,
;N/A
A36,2,
;N/A
A36,3,
;N/A
A36,4,
;N/A
;37 N/A
A38,0,
A38,1,
;ERROR:
A38,2,
;Security
A38,3,
;access
A38,4,
;required
A39,0,
;1
A39,1,
;Oil
A39,2,
;Reading
A39,3,
;evaluation
A39,4,
;N/A
A40,0,
;0
A40,1,
;Actual Value
A40,2,
;Insp. in 1
A40,3,
;00 Miles
A40,4,
;N/A
A41,0,
;0
A41,1,
;Actual Value
A41,2,
;Insp. in 1
A41,3,
;Days
A41,4,
;N/A
A42,0,
;100
A42,1,
;Min. Value
A42,2,
;Oil in 1
A42,3,
;00 Miles
A42,4,
;N/A
A43,0,
;100
A43,1,
;Max. Value
A43,2,
;Oil in 1
A43,3,
;00 Miles
A43,4,
;N/A
A44,0,
;365
A44,1,
;Max. Value
A44,2,
;Insp. in 1
A44,3,
;Days
A44,4,
;N/A
A45,0,
;1
A45,1,
;Oil
A45,2,
;Quality
A45,3,
A45,4,
;N/A
;46 N/A
A47,0,
;0
A47,1,
;Soot
A47,2,
;Qty. in 1
A47,3,
;00 km
A47,4,
;N/A
A48,0,
;0
A48,1,
;Thermal Load
A48,2,
;in 1
A48,3,
;00 km
A48,4,
;N/A
A49,0,
;365
A49,1,
;Min. Value
A49,2,
;Insp. in 1
A49,3,
;Days
A49,4,
;N/A
A50,0,
;160
A50,1,
;Basic Value
A50,2,
;Oil in 1
A50,3,
;00 Miles
A50,4,
;N/A
A51,0,
;365
A51,1,
;Basic Value
A51,2,
;Oil in 1
A51,3,
;Days
A51,4,
;N/A
A52,0,
;160
A52,1,
;Basic Value
A52,2,
;Insp. in 1
A52,3,
;00 km
A52,4,
;N/A
A53,0,
;33
A53,1,
;Actual Value
A53,2,
;Insp. in 1
A53,3,
;00 Miles
A53,4,
;N/A
A54,0,
;365
A54,1,
;Basic Value
A54,2,
;Insp. in 1
A54,3,
;Days
A54,4,
;N/A
A55,0,
;343
A55,1,
;Actual Value
A55,2,
;Insp. in 1
A55,3,
;Days
A55,4,
;N/A
A56,0,
;2090
A56,1,
;N/A
A56,2,
;N/A
A56,3,
;N/A
A56,4,
;N/A
;57 N/A
;58 N/A
;59 N/A
;60 N/A
;61 N/A
;62 N/A
;63 N/A
;64 N/A
;65 N/A
;66 N/A
;67 N/A
;68 N/A
;69 N/A
A70,0,
;1487
A70,1,
;N/A
A70,2,
;N/A
A70,3,
;N/A
A70,4,
;N/A
A71,0,
;65535
A71,1,
;N/A
A71,2,
;N/A
A71,3,
;N/A
A71,4,
;N/A
A72,0,
;0
A72,1,
;N/A
A72,2,
;N/A
A72,3,
;N/A
A72,4,
;N/A
A73,0,
;2
A73,1,
;N/A
A73,2,
;N/A
A73,3,
;N/A
A73,4,
;N/A
A74,0,
;123
A74,1,
;N/A
A74,2,
;N/A
A74,3,
;N/A
A74,4,
;N/A
A75,0,
;2
A75,1,
;N/A
A75,2,
;N/A
A75,3,
;N/A
A75,4,
;N/A
A76,0,
;255
A76,1,
;N/A
A76,2,
;N/A
A76,3,
;N/A
A76,4,
;N/A
;77 N/A
;78 N/A
;79 N/A
;80 N/A
;81 N/A
;82 N/A
;83 N/A
;84 N/A
;85 N/A
;86 N/A
;87 N/A
;88 N/A
;89 N/A
;90 N/A
;91 N/A
;92 N/A
;93 N/A
;94 N/A
;95 N/A
;96 N/A
;97 N/A
;98 N/A
;99 N/A
;100 N/A
;101 N/A
;102 N/A
;103 N/A
;104 N/A
;105 N/A
;106 N/A
;107 N/A
;108 N/A
;109 N/A
;110 N/A
;111 N/A
;112 N/A
;113 N/A
;114 N/A
;115 N/A
;116 N/A
;117 N/A
;118 N/A
;119 N/A
;120 N/A
;121 N/A
;122 N/A
;123 N/A
;124 N/A
;125 N/A
;126 N/A
;127 N/A
;128 N/A
;129 N/A
;130 N/A
;131 N/A
;132 N/A
;133 N/A
;134 N/A
;135 N/A
;136 N/A
;137 N/A
;138 N/A
;139 N/A
;140 N/A
;141 N/A
;142 N/A
;143 N/A
;144 N/A
;145 N/A
;146 N/A
;147 N/A
;148 N/A
;149 N/A
A150,0,
;0
A150,1,
;N/A
A150,2,
;N/A
A150,3,
;N/A
A150,4,
;N/A
A151,0,
;0
A151,1,
;N/A
A151,2,
;N/A
A151,3,
;N/A
A151,4,
;N/A
;152 N/A
;153 N/A
;154 N/A
;155 N/A
;156 N/A
;157 N/A
;158 N/A
;159 N/A
;160 N/A
;161 N/A
;162 N/A
;163 N/A
;164 N/A
;165 N/A
;166 N/A
;167 N/A
;168 N/A
;169 N/A
;170 N/A
;171 N/A
;172 N/A
;173 N/A
;174 N/A
;175 N/A
;176 N/A
;177 N/A
;178 N/A
;179 N/A
;180 N/A
;181 N/A
;182 N/A
;183 N/A
;184 N/A
;185 N/A
;186 N/A
;187 N/A
;188 N/A
;189 N/A
;190 N/A
;191 N/A
;192 N/A
;193 N/A
;194 N/A
;195 N/A
;196 N/A
;197 N/A
;198 N/A
;199 N/A
;200 N/A
;201 N/A
;202 N/A
;203 N/A
;204 N/A
;205 N/A
;206 N/A
;207 N/A
;208 N/A
;209 N/A
;210 N/A
;211 N/A
;212 N/A
;213 N/A
;214 N/A
;215 N/A
;216 N/A
;217 N/A
;218 N/A
;219 N/A
;220 N/A
;221 N/A
;222 N/A
;223 N/A
;224 N/A
;225 N/A
;226 N/A
;227 N/A
;228 N/A
;229 N/A
;230 N/A
;231 N/A
;232 N/A
;233 N/A
;234 N/A
;235 N/A
;236 N/A
;237 N/A
;238 N/A
;239 N/A
;240 N/A
;241 N/A
;242 N/A
;243 N/A
;244 N/A
;245 N/A
;246 N/A
;247 N/A
;248 N/A
;249 N/A
;250 N/A
;251 N/A
;252 N/A
;253 N/A
;254 N/A
;255 N/A
  • I was assured that only "Service Reset" selected under the SRI Reset function.
  • Tried "Change to Fixed Intervals (Miles)" and then Service Reset, no change.
  • Channel map showed 17-10-55 with a stored value of "343". Following day, it was "344".
  • Set Adaptation 55 to new value of 1.
  • Now the MMI display says 16000 km (10,000 miles) or 365 days. :)
   #38
Well, either the 4F A6 got clusters with "Inspection" channels up in the 50s a whole lot earlier than other Audis (which typically got them starting at MY 2008) or some of these cars have newer clusters in them than they should.
This almost sounds like we are going back to the old inspections ...............in early to mid 90's
