RNS510 - steering wheel buttons don't work
wfdTamar
Tasmania, Australia
C?ID=150916
I have a 2008 Skoda Octavia. In the past I’ve installed the following:
A 2012 VW RNS510 (all worked fine) with an updated canbus gateway (for the battery issue).
Bluetooth unit.
Factory parking sensors front & rear.
Tow bar wiring.
MDI unit ( I have a little coding issue with that too. I think I need to code to disable the Accessory audio socket in the armrest pocket).
Q1. The issue I have now is I have arranged to swap my VW RNS510 with another person that has the reverse - a Skoda Columbus unit in a VW. This is so we get the correct colour buttons, startup screen and graphics for our cars.
The problem I’m having is the steering wheel buttons aren’t working with the Skoda radio in my car - a Skoda! (they did work when I had the VW unit in).
You may note in the log - Radio/Navigation errors for speakers. I’m also putting in an aftermarket amp and speakers, which aren’t connected yet - so there are no speakers connected to the RNS510. I can still ‘pretend’ to play the radio and turning the volume knob on the unit shows the volume being adjusted, but not the steering wheel buttons.
This is the type of steering wheel I have (it has cruise control on the left stalk):
(can't work out the format of the link for photo's)
https://www.flickr.com/photos/8753947@N06/13857679734/in/set-72157629221672317
Any ideas? Log below:
Sunday,13,April,2014,23:19:15:46507
VCDS Version: 14.2.3.0
Data version: 20140320
VIN: TMBKE61Z482108213   License Plate:
Mileage: 94590km-58775mi   Repair Order:
Chassis Type: 1Z (7N0)
Scan: 01 03 08 09 10 15 16 17 19 22 25 2E 37 42 44 46 52 56 62 69
          72 77
VIN: TMBKE61Z482108213   Mileage: 94590km-58775miles
Address 01: Engine        Labels: 03G-906-021-BMM.clb
   Part No SW: 03G 906 021 SS    HW: 03G 906 021 AB
   Component: R4 2,0L EDC G000SG  1302
   Revision: --H07---    Serial number: SKZ7Z0G4674602
   Coding: 0050172
   Shop #: WSC 66565 257 00032
   VCID: 820122E4DDBA3A2403-80D7
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-A.lbl
   Part No SW: 1K0 907 379 AB    HW: 1K0 907 379 AB
   Component: ESP 4MOTION MK60    0102
   Revision: 00H13001
   Coding: 0023170
   Shop #: WSC 73430 790 00000
   VCID: 72E1F2246D1A8AA493-8027
   Part No SW: 1Z0 907 044 AB    HW: 1Z0 907 044 AB
   Component: ClimatronicPQ35 120 0600
   Revision: 00120022    Serial number: 00000000000000
   VCID: 76E9CE3401729684BF-8023
   Revision: 00H54000    Serial number: 00000005403549
   Coding: E1880F011004140040110D000000000000087F075C00000C000000000000
   Shop #: WSC 73430 790 12345
   VCID: 71E3FD28681CB1BC6A-8024
   Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 111207 022  0601
   Coding: 00055223
   Shop #: WSC 73430
   Component: RLS     271207 046  0204
   Coding: 00471077
   Shop #: WSC 73430
Address 10: Park/Steer Assist (J446)       Labels: 1Z0-919-475-V2.clb
   Part No SW: 1Z0 919 475 E    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0005
   Revision: --H06---    Serial number: 28261216303427
   Coding: 110001
   ASAM Dataset: EV_EPHVA18SKxxx0000 001001
   ROD: EV_EPHVA18SKxxx0000.rod
   VCID: 438F67E0CA20732CC8-8016
   Part No SW: 1K0 909 605 AA    HW: 1K0 909 605 AA
   Component: Q3 AIRBAG VW8   027 0900
   Revision: 11027000    Serial number: 003B5D13SLJI
   Coding: 0020787
   VCID: 6BDFEF404A305B6C50-803E
   Subsystem 1 - Serial number: 6332MSME2D42254BE
   Subsystem 2 - Serial number: 6342MSME37136549A
   Subsystem 3 - Serial number: 6351HSME1204096B0
   Subsystem 4 - Serial number: 6361HSME1204237E1
   Part No SW: 1K0 953 549 BG    HW: 1K0 953 549 BG
   Component: J0527           051 0100
   Coding: 0002042
   VCID: 78F5C00C0B66E0F4AD-802D
   Part No SW: 1Z0 920 842 D    HW: 1Z0 920 842 D
   Component: KOMBIINSTRUMENT VD1 1612
   Revision: V1612036    Serial number: SKZ7Z0G4674602
   Coding: 0002101
   Shop #: WSC 23050 822 88145
   VCID: 3875000C4BE620F46D-806D
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 250511F1000940
   Coding: 352303
   VCID: 3065382C6396F8B425-8065
Address 22: AWD        Labels: 1K0-907-554.lbl
   Part No: 1K0 907 554 L
   Component: Haldex 4Motion      0116
   Coding: 0000001
   VCID: 36690E3441F2D6847F-8063
   Component: IMMO            VD1 1612
   Shop #: WSC 73129 959 96102
   Revision: A1001003    Serial number: 7662009629
   VCID: 2953D548404C897CE2-807C
03138 - Input AUX IN
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 194
                    Mileage: 94594 km
                    Time: 23:16:28
   Part No SW: 3T0 035 680 B    HW: 3T0 035 680 B
   Component: RNS-MID       H60 4120
   Revision: AB001001    Serial number: SKZ6Z7L5341119
   Coding: 00000400040000A00000
   Shop #: WSC 73430 790 00098
   VCID: 2F673B507EA8E74C3C-807A
   Subsystem 1 - Part No: 3T0 051 859 P
   Component: AUNZ V6  7920
8 Faults Found:
00871 - Bass Speaker Front Right (R23)
                    Reset counter: 194
                    Mileage: 94592 km
                    Time: 23:14:03
00875 - Treble Speaker Front Right (R22)
                    Reset counter: 194
                    Mileage: 94592 km
                    Time: 23:14:04
                    Reset counter: 194
                    Mileage: 94592 km
                    Time: 23:14:04
                    Reset counter: 194
                    Mileage: 94592 km
                    Time: 23:14:04
                    Reset counter: 194
                    Mileage: 94592 km
                    Time: 23:14:04
00877 - Treble Speaker Rear Right (R16)
                    Reset counter: 194
                    Mileage: 94592 km
                    Time: 23:14:04
                    Reset counter: 194
                    Mileage: 94592 km
                    Time: 23:14:04
                    Reset counter: 194
                    Mileage: 94592 km
                    Time: 23:14:04
   Part No SW: 1T0 959 701 D    HW: 1T0 959 701 D
   Component: Tuer-SG         006 1204
   Coding: 0000758
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.070 H08 1901
   Shop #: WSC 73430 000 90108
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Coding: 88801A085283007F3F02850500085F01807C00
   VCID: 830F27E0C2A0332C08-80D6
   Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
   Coding: 0000758
   VCID: 3973050870EC39FC92-806C
8 Faults Found:
                    Reset counter: 194
                    Mileage: 94592 km
                    Time: 23:14:03
                    Reset counter: 194
                    Mileage: 94592 km
                    Time: 23:14:04
                    Reset counter: 194
                    Mileage: 94592 km
                    Time: 23:14:04
                    Reset counter: 194
                    Mileage: 94592 km
                    Time: 23:14:04
                    Reset counter: 194
                    Mileage: 94592 km
                    Time: 23:14:04
                    Reset counter: 194
                    Mileage: 94592 km
                    Time: 23:14:04
                    Reset counter: 194
                    Mileage: 94592 km
                    Time: 23:14:04
                    Reset counter: 194
                    Mileage: 94592 km
                    Time: 23:14:04
   Part No SW: 1K0 959 703 J    HW: 1K0 959 703 J
   Component: Tuer-SG         006 1201
   Coding: 0000144
   Shop #: WSC 73430 790 1012544
   VCID: 3777033046F82F8C64-8062
   Part No SW: 1K0 959 704 J    HW: 1K0 959 704 J
   Coding: 0000144
   Part No SW: 7P6 035 730 F    HW: 7P6 035 730 F
   Component: TELEFON       H13 2730
   Revision: 1B001001    Serial number: 00007661882609
   Coding: 0200000000010110
   Shop #: WSC 06402 785 00200
   ASAM Dataset: EV_UHVNA A01015
   ROD: EV_UHVNA.rod
   VCID: 356B093894F4DD9C76-8060
United States
BAP is enabled in the 37/56 module coding but that 16 module and MFSW is the older Lin 1.3/DDP Protocol. What happens when you uncheck BAP in Byte 7 followed by a reboot?
-Dana
wfdTamar
Tasmania, Australia
C?ID=150916
I did try that and it's the same.
It appears the firmware I used for the RNS510 is designed for VW units. Here's the fix for Skoda units (though interestingly the VW unit worked in my Skoda):
Note! Skoda owners
Extract files PQTABLE and SKTABLE from image (use magiciso or ultraiso). Files can be found from path: \VUCI\B101\RNSMIDEC\PROG
Switch the filenames by just renaming SKTABLE to PQTABLE and vice versa
Overwrite the renamed files back to image and save the image. Burn this image to DVD or CD.
Load or reload the Firmware to your RNS-510 using the steps below.
Voilá… buttons are back!
United States
Thanks for the update!
