Bank 2 all cylinder misfires, cam sensor faults
   #81
I found myself reflecting on the 1978 Wide World of Sports intro from my youth and feeling like skier Vinko Bogataj.
Ah yes, The Agony of Defeat; the reason my wife has adamantly refused to even consider skiing. :o
  • Haha
Reactions: JMR
   #82
JMR
Romania
C?ID=432218
I m no mechanic but what if you take out the oil pan ?? Would it help ?
   #83
EuroX
Northern NJ USA
C?ID=208579
No chance in order to remove upper pan engine needs to come out. I am not sure if lower pan is enough, but from my experience upper pan has a baffle in it. Either way if removing lower pan its only at the front of the engine, the back end of engine has upper pan only. I would assume upper pan would need to come off or at that point rear timing cover.
First (as noted in #78) , get a borescope and see if you can locate it ; there are many , many configurations : pc, i-phone, Milwaukee, articulating and a wide price range as well ! You can always sell it once you have finished the project. Its time for a surgical technique! (fingers crossed).
Then, you are going to need one of these (or similar).
Flexible-Pick-Up-Tool-Magnet-4-Claw-LED-Light-Magnetic-Long-Spring-Grip-Home-Toilet-Gadget.jpg
ebay. This one has a 4mm head !
Or, this one from Stahlwille # 12600
alvocado
Cincinnati, OH, USA
C?ID=520115
I'm traveling this week but have ordered up a few magnetic pickups and located a borescope in the Autozone loaner tool inventory. Next Sunday is the day. Will keep everyone posted.
   #87
alvocado
Cincinnati, OH, USA
C?ID=520115
Success! Located the bolt with a borescope sitting on top of the lower chain just in front of the sprocket. Snagged it with a long magnetic pickup on the first try using the scope to guide the magnet in. Need to get new cam adjuster bolts so I should have everything buttoned up on Tuesday to fire up and test. It's getting close.
   #88
EuroX
Northern NJ USA
C?ID=208579
Looking forward to the update.
   #89
Many decades ago (when the only time you came across an Endoscope was when it was covered in KY Jelly :eek:) I was changing the plugs on a Daimler Sovereign Double 6 and as I was opening up the packets a ferrule shot out of the box about 15 feet across the room and I watched in horror as it went into the V of the engine and disappeared... I could not have done that if I had tried. Thankfully the Snap Off man turned up and he had a magnet on a stick with a light and I found it down in one of the cylinders.
   #90
alvocado
Cincinnati, OH, USA
C?ID=520115
Just fired up the car and it is running well. I don't feel any misfires, idle is smooth and it ran fine on a test drive.
The only issue is a persistent CEL on the dash. I've cleared the DTCs but the scan continues to show the engine misfires that were presenting when the cam adjusters were reversed. Here's the most recent scan after clearing the DTCs twice.
Friday,08,July,2022,15:05:54:00625
VCDS Version: 22.3.1.4 (x64)
VIN: WAUDH74FX8N009883   License Plate:
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 1E 36 37 42 46 47 4F
          52 53 55 56 61 62 65 67 6C 72 76 77
VIN: WAUDH74FX8N009883   Mileage: 242660km-150781miles
Address 01: Engine (AUK)       Labels:. 06E-910-559-BKH.clb
   Part No SW: 4F2 910 559 H    HW: 4F1 907 559 E
   Component: 3.2l V6 FSI         0040
   Revision: --H20---    Serial number:
   Coding: 01050109190F0120
   Shop #: WSC 03131 444 84059
   VCID: 3162FB7FA82B2B0770-8064
   VINID: 9D1954607116A087800092080C119E0B88
8 Faults Found:
               P1653 - 008 -  - Intermittent
                    Fault Frequency: 23
                    Mileage: 242656 km
                    Date: 2007.03.02
                    Time: 22:56:33
                    RPM: 832 /min
                    Mass Air / Rev.: 125.4 mg/str
                    Temperature: 81.0°C
                        Idle
                    Load: 15.7 %
000838 - Camshaft Position Sensor (G163)
               P0346 - 006 - Implausible Signal - Intermittent
                    Fault Status: 00100001
                    Mileage: 242656 km
                    Date: 2007.03.02
                    Time: 22:56:35
                    RPM: 800 /min
                    Mass Air / Rev.: 457.8 mg/str
                    Temperature: 43.5°C
                        Part Throttle
                    Bin. Bits: 00010000
000913 - Camshaft Position Sensor (G301)
               P0391 - 006 - Implausible Signal - Intermittent
                    Fault Frequency: 11
                    Mileage: 242656 km
                    Date: 2007.03.02
                    Time: 22:56:35
                    RPM: 1792 /min
                    Mass Air / Rev.: 212.6 mg/str
                    Temperature: 27.0°C
                        Idle
                    Bin. Bits: 00010000
000772 - Cylinder 4
               P0304 - 006 - Misfire Detected - Intermittent - MIL ON
                    Fault Status: 10100001
                    Fault Frequency: 18
                    Mileage: 242656 km
                    Date: 2007.03.02
                    Time: 22:56:42
                    RPM: 1376 /min
                    Mass Air / Rev.: 256.2 mg/str
                    Temperature: 42.0°C
                        Part Throttle
                    Time: 0.0 s
000773 - Cylinder 5
               P0305 - 006 - Misfire Detected - Intermittent - MIL ON
                    Fault Frequency: 16
                    Mileage: 242656 km
                    Date: 2007.03.02
                    Time: 22:56:51
                    RPM: 1120 /min
                    Mass Air / Rev.: 305.2 mg/str
                    Temperature: 43.5°C
                        Part Throttle
                    Time: 0.0 s
000774 - Cylinder 6
               P0306 - 006 - Misfire Detected - Intermittent - MIL ON
                    Fault Frequency: 11
                    Mileage: 242656 km
                    Date: 2007.03.02
                    Time: 22:56:51
                    RPM: 1344 /min
                    Temperature: 42.0°C
                        Part Throttle
                    Time: 0.0 s
004874 - Cylinder Disabling
               P130A - 006 -  - Intermittent
                    Fault Frequency: 9
                    Mileage: 242656 km
                    Date: 2007.03.02
                    Time: 22:56:51
                    RPM: 1248 /min
                    Mass Air / Rev.: 294.3 mg/str
                    Temperature: 43.5°C
                    Time: 0.00 s
               P0300 - 006 -  - Intermittent
                    Mileage: 242656 km
                    Date: 2007.03.03
                    Time: 06:22:02
                    RPM: 800 /min
                    Mass Air / Rev.: 261.6 mg/str
                    Temperature: 33.0°C
                        Idle
                    Time: 76.8 s
   Part No SW: 4F5 910 156     HW: 09L 927 156 C
   Component: AG6 09L 3.2 FSI USA 0010
   Revision: --H03---    Serial number:        4334069
   Coding: 0000002
   Shop #: WSC 02325 758 00200
   VCID: 65CA5F2FAC63B7A75C-8030
Address 03: ABS Brakes        Labels: 4F0-910-517.clb
   Part No SW: 4F0 910 517 AD    HW: 4F0 614 517 AA
   Component: ESP8 quattro    H01 0070
   Coding: 0020895
   Shop #: WSC 03131 444 103313
   VCID: 66C858235165BCBF55-8032
                    Fault Status: 00101101
                    Fault Frequency: 13
                    Reset counter: 146
                    Mileage: 242405 km
                    Date: 2022.03.09
                    Time: 15:11:12
                    Hex Value: 0x00C0
                    Hex Value: 0x40A2
                    Hex Value: 0x0025
                    Hex Value: 0x01A7
                    Hex Value: 0x00FF
                    Fault Frequency: 29
                    Reset counter: 147
                    Mileage: 242656 km
                    Date: 2007.03.02
                    Time: 22:56:30
                    Hex Value: 0x00C0
                    Hex Value: 0x42A2
                    Hex Value: 0x0024
                    Hex Value: 0x018F
                    Hex Value: 0x00FF
                    Fault Status: 00100011
                    Reset counter: 146
                    Mileage: 242656 km
                    Date: 2007.03.03
                    Time: 06:22:51
                    Hex Value: 0x0100
                    Hex Value: 0x62A2
                    Hex Value: 0x0007
                    Hex Value: 0xA8A7
                    Hex Value: 0x00FF
   Part No SW: 4F0 910 852 A    HW: 4F0 905 852 C
   Component: FBSAUDIC6 ELVSG H01 0050
   Revision: 07020801    Serial number: 10601200776510
   Coding: 0000007
   VCID: 244C022BE7D98EAF8B-8070
   Subsystem 1 - Part No: 4F0 910 132 L
   Component: FBSAUDIC6 EZS   H03 0020
   Component: FBSAUDIC6 KSG   H27 0080
   Component: FBSAUDIC6 IDG   H01 0060
00190 - Driver's Door Handle Touch Sensor (G415)
            007 - Short to Ground
                    Fault Status: 01110111
                    Reset counter: 107
                    Mileage: 242656 km
                    Date: 2007.03.02
                    Time: 15:41:20
00955 - Key 1
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 107
Address 07: Control Head        Labels: 4F0-910-7xx-07-H.clb
   Part No SW: 4F0 910 732 D    HW: 4E0 035 729 A
   Component: Interfacebox    H43 4140
   Revision: 00000000    Serial number: 361EW077515893
   Coding: 0000003
   Shop #: WSC 02335 758 00200
   Component: Bedienteil MMIC6H01 0060
   Subsystem 2 - Serial number: 00000001514464
   Subsystem 3 - Serial number: 0122.02.100000000100011230ÿ
   Subsystem 4 - Serial number: 011230ÿ
Address 08: Auto HVAC        Labels: 4F0-910-043.clb
   Part No SW: 4F0 910 043 A    HW: 4F1 820 043 AG
   Component: KLIMABETAETIGUNGH30 0020
   Revision: 00000052    Serial number: 00000000405883
   Coding: 0524326
   VCID: 1C3C3ACBDFA9B66F33-8048
01232 - A/C Compressor Regulator Valve (N280)
                    Fault Status: 00101010
                    Reset counter: 147
                    Mileage: 242656 km
                    Date: 2007.03.02
                    Time: 15:42:45
                    Load: 90.0 %
                    Current: 0.000 A
   Part No SW: 4F0 910 279 J    HW: 4F0 907 279 A
   Component: ILM Fahrer      H17 0240
   Coding: 0113123
   VCID: 3064FE7BA321220F7F-8064
   Subsystem 1 - Part No: 4F1 910 113 C  Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H05 0210
   Coding: 00064784
   Shop #: WSC 02335
   Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH13 0090
   Coding: 00146221
   Shop #: WSC 02335
   Part No SW: 4E0 910 110 C    HW: 4E0 035 110 A
   Component: MP3-Changer     H46 0350
   Revision: 00046004    Serial number: AUZ5ZBG3412010
   VCID: 183426DB2B91DA4F17-804C
Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
   Part No SW: 4E0 910 593 K    HW: 4E0 035 593 F
   Component: SDAR SIRIUS     H07 0140
   Revision: 00000000    Serial number: AUZ4Z7G0091617
   Coding: 0000100
   VCID: 2F66FD07BE1F3DF766-807A
                    Reset counter: 107
                    Mileage: 242656 km
                    Date: 2007.03.02
                    Time: 15:22:59
Address 15: Airbags        Labels: 4F0-910-655-8R.clb
   Part No SW: 4F0 910 655 F    HW: 4F0 959 655 A
   Component: 6N AIRBAG AUDI8RH30 0320
   Revision: 16H30000    Serial number: 00359D0J45V3
   Coding: 0013902
   VCID: 2A50EC1385FD58DFB1-807E
   Subsystem 1 - Part No: 4F0 910 339 B
   Component: BF-Gewichtsens. H03 0060
   Subsystem 2 - Serial number: 6332CSME18423964+
   Subsystem 3 - Serial number: 6342CSME186E3F48L
   Subsystem 4 - Serial number: 6352QSME2F4D0A0BW
   Subsystem 5 - Serial number: 6362QSME2D77780F.
   Subsystem 6 - Serial number: 63734SME2D5B0E1BF
   Subsystem 7 - Serial number: 63834SME31163365U
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 D
   Component: J0527               0410
   Revision: 00H02000    Serial number: 90054071430307
   Coding: 0012141
   Shop #: WSC 02323 758 00200
   VCID: 2756152796EF65B7AE-8072
   Component: E0221           H02 0030
Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
   Part No SW: 4F0 910 930 C    HW: 4F0 920 983
   Component: KOMBIINSTR. M73 H21 0220
   Revision: 00600000    Serial number: 6IK56UX57
   Coding: 2129288
   Shop #: WSC 03131 444 100646
   VCID: 234E0137E2D78997F2-8076
Address 19: CAN Gateway        Labels:. 4L0-910-468.clb
   Part No SW: 4L0 910 468     HW: 4L0 907 468
   Component: J533__Gateway   H06 0040
   Revision: 00H06000    Serial number: 0900B075138178
   Coding: F5D5DE77707A06
   VCID: 6CDC2A0B4F8986EF03-8038
Address 1E: Media Player 2 (R192)       Labels:. 4E0-035-785.lbl
   Part No SW: 4E0 035 785 B    HW: 4E0 035 785 B
   Component: SG ext.Player H09 0700
   Revision: 00000000
   VCID: 2756152756EF65B7AE-8072
   Part No SW: 4F0 910 760     HW: 4F0 959 760
   Component: Sitzmemory FS   H04 0050
   Revision: 00000000    Serial number: 00000000896400
   Coding: 0082954
   VCID: 61C24B3FB84BDB87A0-8034
01446 - Sensor for Driver Seat; Seatback Adjust (G230)
                    Fault Status: 01100101
                    Reset counter: 107
                    Mileage: 242656 km
                    Date: 2007.03.02
                    Time: 15:22:47
00003 - Control Module
                    Reset counter: 107
                    Mileage: 242656 km
                    Date: 2007.03.02
                    Time: 15:22:47
   Part No SW: 4E0 910 888 F    HW: 4E0 919 887 M
   Component: MNS US          H49 0990
   Revision: 00000000    Serial number: 395EU077500728
Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
   Part No SW: 4F0 910 793 E    HW: 4F0 959 793 E
   Component: TSG FA          H12 0210
   Revision: 00-00000
   Coding: 0051947
   Shop #: WSC 02327 758 00200
   VCID: 2C5CEA0B8F0946EF43-8078
Address 46: Central Conv.        Labels:. 4F0-910-289.lbl
   Part No SW: 4F0 910 289 J    HW: 4F0 907 289 J
   Component: Komfortgeraet   H25 0200
   Revision: 02000025    Serial number: 01047625890000
   Coding: 4618269
Address 47: Sound System        Labels: 4F0-910-223-BO.lbl
   Part No SW: 4F0 910 223 J    HW: 4F0 035 223 G
   Component: DSP-High C6     H10 0240
   Revision: PROD_01     Serial number: 00000000030007
   Coding: 0000026
   VCID: 254A1F2FECE377A79C-8070
   Part No SW: 4F0 910 280     HW: 4F0 907 280 C
   Component: ILM Beifahrer   H12 0100
   Revision:             Serial number: 00000000019955
   Coding: 0002014
   VCID: 5EB870C38935E47F9D-800A
Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
   Part No SW: 4F0 910 793 E    HW: 4F0 959 792 E
   Component: TSG BF          H12 0210
   Revision: 00-00000
   Coding: 0051947
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801 C    HW: 4F0 907 801 A
   Component: EPB  CDEC0080   H04 0080
   Revision: --H04---
   Coding: 0005022
   Shop #: WSC 02145 758 00200
   VCID: 20440E3BF3C1928FEF-8074
   Part No SW: 4F0 910 357 F    HW: 4F0 907 357 F
   Coding: 0000016
   VCID: 2952131F80FB53C7B8-807C
   Subsystem 1 - Part No: 4F0 941 329 D
   Component: AFS-Modul links H01 0010
   Subsystem 2 - Part No: 4F0 941 329 D
   Component: AFS-Modul rechtsH01 0010
   Part No SW: 4E0 910 541 Q    HW: 4F0 035 541 L
   Component: TUNER EU/US/RDW H42 0620
   Revision: 00000000    Serial number: 394F8077777598
   Coding: 0000002
   VCID: 2E58E003B91534FF6D-807A
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4F0 910 181 E    HW: 4F0 915 181 A
   Component: J0644 BEM       H12 0590
   Revision: 00000000    Serial number: 00000000082895
   Shop #: WSC 25101 444 52946
   Subsystem 1 - Part No: 000 915 105 DL
   Component: von VA0  350520K26F
   Coding: 303030393135313035444C5641303335303532304B323646
Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 E    HW: 4F0 959 795 E
   Component: TSG HL          H21 0210
   Coding: 0051754
Address 65: Tire Pressure        Labels: 4F0-910-273-BA.lbl
   Part No SW: 4F0 910 273 B    HW: 4F0 907 273 A
   Component: Reifendruck 3   H05 0100
   Revision: 00050100    Serial number: 00000700046737
   Coding: 0062221
   VCID: 22400433FDCD809FF9-8076
   Part No SW: 4E0 910 754 Q    HW: 4E0 035 753 A
   Component: SDS 3501 US     H46 0630
   Revision: 00000000    Serial number: 00000907090169
   Shop #: WSC 12336 024 394758
   VCID: 346CF26B57391E2F1B-8060
   Part No SW: 4F0 910 441     HW: 4L0 907 441 A
   Component: J772__Rearview      0050
   Revision: --H12---    Serial number: 525PA8-J74205X
   Coding: 1000404
   VCID: 5DBA77CF8433FF6784-8008
Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
   Component: TSG HR          H21 0210
   Coding: 0051754
   Part No SW: 4F0 910 283 F    HW: 4F0 919 283 F
   Component: Parkhilfe 4-Kan H09 0060
   Revision: 00H09000    Serial number: 06220715501300
   Coding: 0021206
   Part No SW: 4F0 910 336 H    HW: 4E0 862 335
   Component: Handyvorb2      H16 1130
   Revision: 00000000    Serial number: 00000007572134
   Coding: 0010900
   VCID: 2854161B9BF16ACFA7-807C
End-------------------------(Elapsed Time: 03:16)--------------------------
   #91
EuroX
Northern NJ USA
C?ID=208579
Please set date in vehicle possibly. Those time stamps look old lol. Clear and retest. Somtimes clearing a few times of doing a clear through the gateway does a much better job clearing dtcs.
alvocado
Cincinnati, OH, USA
C?ID=520115
Good news - clearing through the gateway worked and no new engine faults.
I dare say it but I think the A6 is back on the road. Much gratitude and appreciation to all of you who helped along the way, @EuroX and @stefdds in particular. I nearly flat bedded the car on more than one occasion while chasing down my error and likely would have given up if not for this forum.
   #93
EuroX
Northern NJ USA
C?ID=208579
Not a problem, I do this for a living, the key is to be thorough and retrace your steps. Sometimes the most minute details are missed. Silly but true. In any case glad you were able to get it sorted out and that you were able to fish that bolt out. In that alone I think you were very lucky.
