- Nov 23, 2019
- 38
- 12
- Cincinnati, OH, USA
- C?ID=520115
I completed the cam girdle gasket replacement on my '08 A6 and replaced the upper timing chain tensioners as preventative maintenance since they were removed for the procedure. All four cams were removed from the car as part of the gasket replacement but were removed and installed using cam locks to ensure correct timing and positioning at TDC. The engine was turned over two full rotations manually after reinstallation and all cams returned to correct position before closing everything up.
Upon startup, I'm getting cam position sensor faults and cylinder misfires on bank 1. I replaced both cam position sensors and verified the ground wire on the back of the engine was secured to the block. The vehicle ran fine before the repair which was done to address oil leaking into the spark plug wells. Any direction on troubleshooting would be greatly appreciated.
Here's the VAG scan including the fault details.
Tuesday,24,May,2022,10:09:48:00625
VCDS Version: 22.3.1.4 (x64)
VIN: WAUDH74FX8N009883 License Plate:
Mileage: 242650km-150775mi Repair Order:
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 1E 36 37 42 46 47 4F
52 53 55 56 61 62 65 67 6C 72 76 77
VIN: WAUDH74FX8N009883 Mileage: 242650km-150775miles
Address 01: Engine (AUK) Labels:. 06E-910-559-BKH.clb
Part No SW: 4F2 910 559 H HW: 4F1 907 559 E
Component: 3.2l V6 FSI 0040
Revision: --H20--- Serial number:
Coding: 01050109190F0120
Shop #: WSC 03131 444 84059
VCID: 3162FB7FA82B2B0770-8064
VINID: 9D1954607116A087800092080C119E0B88
7 Faults Found:
P1653 - 008 -
Fault Status: 01101000
Mileage: 242656 km
Date: 2007.03.02
Time: 22:56:33
RPM: 1024 /min
Mass Air / Rev.: 288.9 mg/str
Temperature: 36.0°C
Idle
Load: 42.7 %
000838 - Camshaft Position Sensor (G163)
P0346 - 006 - Implausible Signal - MIL ON
Fault Status: 10100001
Mileage: 242656 km
Date: 2007.03.02
Time: 22:56:35
RPM: 704 /min
Mass Air / Rev.: 348.8 mg/str
Temperature: 30.0°C
Idle
Bin. Bits: 00010000
000913 - Camshaft Position Sensor (G301)
P0391 - 006 - Implausible Signal - MIL ON
Mileage: 242656 km
Date: 2007.03.02
Time: 22:56:35
RPM: 704 /min
Temperature: 30.0°C
Idle
Bin. Bits: 00010000
000772 - Cylinder 4
P0304 - 006 - Misfire Detected - MIL ON
Mileage: 242656 km
Date: 2007.03.02
Time: 22:56:42
RPM: 864 /min
Mass Air / Rev.: 337.9 mg/str
Temperature: 30.0°C
Idle
Time: 0.0 s
000773 - Cylinder 5
P0305 - 006 - Misfire Detected - MIL ON
Mileage: 242656 km
Date: 2007.03.02
Time: 22:56:51
RPM: 800 /min
Mass Air / Rev.: 256.2 mg/str
Temperature: 34.5°C
Idle
Time: 51.2 s
000774 - Cylinder 6
P0306 - 006 - Misfire Detected - MIL ON
Mileage: 242656 km
Date: 2007.03.02
Time: 22:56:51
RPM: 800 /min
Mass Air / Rev.: 327.0 mg/str
Temperature: 30.0°C
Idle
Time: 0.0 s
004874 - Cylinder Disabling
P130A - 006 - - Intermittent
Fault Status: 00100001
Mileage: 242656 km
Date: 2007.03.02
Time: 22:56:51
RPM: 64 /min
Mass Air / Rev.: 0.0 mg/str
Temperature: 30.0°C
Time: 0.00 s
