2012 A4 DSG basic settings and adaptations
MartinSlu TFMC
St. Lucia
C?ID=520011
Trying to get some assistance on this A4 AllRoad DSG Japanese domestic market. Want to do basic settings and then some adaptations after having replaced the dual mass flywheel for rattling sounds in the bell housing area. Keeps failing the basic settings although I am slowly and painfully learning not all settings are applicable or relevant to certain transmission codes. Nonetheless in the absence of a guided criteria for the test as well as the specific settings to perform I remain challenged. Your assistance will be greatly appreciated.
Saturday,28,May,2022,16:01:10:44814
VCDS Version: 22.3.1.4 (x64)
VIN: WAUZZZ8K7CA005621   License Plate:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 02 03 05 08 09 0E 10 15 16 17 19 42 46 52 53 55 56 57 5F
          62 72
VIN: WAUZZZ8K7CA005621   Mileage: 141440km-87886miles
Address 01: Engine (CL0MA-CDNC)       Labels:| 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 AJ    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H20 0002
   Revision: E1H20---    CVN: F7BDB4B4
   Coding: 0124000C240F0060
   Shop #: WSC 30129 002 1048576
   ASAM Dataset: EV_ECM20TFS0118K2907115AJ 001002
   ROD: EV_ECM20AVS.rod
   VCID: 77F6188ECE624A37FE-8022
   VINID: 9D196AAAA21B1D344000518204F314BD43
Readiness: 1110 0101
   Part No SW: 8K1 927 156 L    HW: 0B5 927 156 F
   Component: 0B5 20TFSIRdW H10 0009
   Revision: --H10---    Serial number: 0000000450 CVN: 000037F3
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_TCMDL501 A02087
   ROD: EV_TCMDL501.rod
   VCID: 3E78CDAAA1D8BB7FFD-806A
   Part No SW: 8K9 907 379 E    HW: 8K9 907 379 E
   Component: ESP8 quattro  H06 0030
   Coding: 024508
   Shop #: WSC 06334 000 00000
   VCID: 448CBF42C734D1AFAB-8010
   Part No SW: 8K0 907 064 CS    HW: 8K0 907 064 CS
   Component: BCM2 2.0      H05 0435
   Coding: 051200
   VCID: 030E7C5E82BA1697D2-8056
   Serial number: 2311000110914012
Address 08: Auto HVAC (J255)       Labels: 8Tx-820-043-3Z.clb
   Part No SW: 8T2 820 043 AG    HW: 8T2 820 043 AG
   Component: KLIMA 3 ZONEN H08 KLIMA 3 ZONEN H08 01800180
   Revision: D1000000    Serial number: 01250520111017
   Coding: 64146000
   VCID: 77F6188EC6624A37FE-8022
No Faults Found
   Component: BCM1 1.0      H30 0392
   Revision: 10030001    Serial number: 00000000924824
   Coding: 260010800030AF010001000300001D0D0F1D470802010141000000
   VCID: 3C7CC7A2BFC4A96FD3-8068
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 250511  H06 0070
   Serial number: SWF11050250136
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 11468762
   Coding: 025028
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002105111734
Address 0E: Media Player 1 (R41)       Labels: Redir Fail!
   Part No SW: 8X0 035 110 B    HW: 8X0 035 110
   Component: CDC-MP3-Pana  H41 0480
   Revision: 00000007
   VCID: 2C5CF7E24FA439EF43-8078
   Part No SW: 8K0 919 475 AA    HW: 8P0 919 475 N
   Component: PARKHILFE 8K  H01 0081
   Revision: 11001001    Serial number: 12501114602481
   Coding: 100104
   VCID: 78F41BB2CB7C454FF7-802C
01625 - Front Parking Aid Warning Chime (H22)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 118
                    Mileage: 141442 km
                    Date: 2010.01.27
                    Time: 22:26:52
                    Temperature: 29.0°C
   Part No SW: 8K0 959 655 L    HW: 8K0 959 655 L
   Component: AirbagVW-AU10 H44 0610
   Serial number: 003JMD0C4CYX
   Coding: 30543435363030303030554A3052384B3053
   VCID: 4688A54AF908E3BFB5-8012
   Serial number: 6334MSME600415773
   Serial number: 6344MSME60116A176
   Serial number: 6352QSME421E4B7CW
   Serial number: 6362QSME0B2F5256O
   Serial number: 63732SME540C0154U
   Serial number: 63832SME540C025A
   Part No SW: 8R0 953 568 K    HW: 8R0 953 568 K
   Component: Lenks.Modul   H07 0156
   Revision: 00000000    Serial number: 20110601000341
   Coding: 000033
   VCID: 4992AE76E0160CC758-801C
   Component: E221 - MFL  H02 0010
   Part No SW: 8K0 920 930 M    HW: 8K0 920 930 M
   Component: KOMBIINSTR.   H28 0258
   Revision: 00000000    Serial number: EJ820AU5C
   Coding: 2F0629020200000C010000
   VCID: 3776D88E86E28A373E-8062
   Part No SW: 8T0 907 468 AD    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0117
   Revision: EC000056    Serial number: 5600E1151100B4
   Coding: 00C303
   Component: J367-BDM  H07 0170
   Serial number: 1101F434180511
   Part No SW: 8K0 959 793 M    HW: 8K0 959 793 M
   Component: TSG FA        H12 0357
   Revision:             Serial number: 0000006282966
   Coding: 011C12205001410001
   VCID: 4A90917AE51007DF51-801E
   Revision: 00002001    Serial number: 0151329664
   Coding: 01000E2220B904818130023280000000
   Part No SW: 8K0 959 792 M    HW: 8K0 959 792 M
   Component: TSG BF        H12 0357
   Revision:             Serial number: 0000006308828
   Revision: 00000003    Serial number: 20000000026298
   VCID: 346CEF829794612F1B-8060
   Part No: 8K5 907 357 B
   Coding: 0000004
   VCID: 3972DEB670F69C47C8-806C
   Part No SW: 4G0 035 083     HW: 4G0 035 083
   Component: Radio U JP    H50 0055
   Revision: AB001007    Serial number: 448E$0B7512755
   Coding: 030005020100000001
   VCID: 5EB86D2A49989B7F9D-800A
02981 - Connection between Radio and Impedance Converter 1
                    Reset counter: 118
                    Mileage: 141442 km
                    Date: 2010.01.27
                    Time: 22:27:12
                    Voltage: 13.90 V
02982 - Connection between Radio and Impedance Converter 2
                    Reset counter: 118
                    Mileage: 141442 km
                    Date: 2010.01.27
                    Time: 22:27:12
                    Voltage: 13.90 V
Address 57: TV Tuner (R78)       Labels: None
   Part No SW: 8F0 919 129 C    HW: 8F0 919 129
   Component: DTV-JP        H07 0600
   Revision: R0070000    Serial number: 79300701869701
   Coding: 100300
   VCID: 3064E392638C5D0F7F-8064
   Subsystem 1 - Part No SW: 4F0 919 805     HW: 4F0 919 805
   Component: R204 TVKLeser  H07 0010
   Serial number: 2172800600637406
   Part No SW: 8T2 035 678 C    HW: 8T2 035 678
   Component: H-BN-JP       H17 0263
   Revision: --------    Serial number: K5FAN11JA7WLQ
   Coding: 01060101000681ED01000B0E00000003
   VCID: 3E78CDAAA9D8BB7FFD-806A
   Subsystem 1 - Part No: 8R0 060 884 L
   Component: JPN-17.06.10.  7323
   Subsystem 2 - Part No SW: 4F0 035 503 C    HW: 4F0 035 503 C
   Component: ETC-VICS-Ant.  H02 0020
   Subsystem 3 - Part No SW: 4F0 919 813 C    HW: 4F0 919 813 C
   Component: Card reader  H02 0100
   Serial number: 358010282921
   Subsystem 4 - Part No SW: 8F0 919 604     HW: 8F0 919 604
   Component: DU7 High  H43 0084
   Serial number: 9466E$0B0592727
   Subsystem 5 - Part No SW: 8T0 919 609 G    HW: 8T0 919 609 G
   Serial number: 00000000841960
   Part No SW: 8K0 959 795 F    HW: 8K0 959 795 F
   Component: TSG HL        H11 0357
   Revision:             Serial number: 0000006267596
   Coding: 010C12204001210001
   VCID: 458AA246CC0EE8A7BC-8010
   Component: TSG HR        H11 0357
   Revision:             Serial number: 0000006267700
End-------------------------(Elapsed Time: 03:53)--------------------------
