Sticky How to create VCDS-Cloud account (IOS)
Sticky
   #41
Yes I tried that, I tried several times, also cleared rods and even the option for cache. Autoscan again update found for asam data, seems to complete but the LED still flashing red and green and the screen is locked with only back button showing.
OK, I'm gonna wait for Shaun's input here.
Shaun
HexNet interface has a red LED flashing to the right of the USB connector and seems to be locked.
After the update, it sometimes has a lot of old or temporary files that it needs to delete, which sounds like what it is doing. Most of the time, this process is quick, but if you have done a bunch of dataset/rod updates and manually rebooted it after so it can't complete the cleanup process, it may have compounded all of these files. I would try doing the update, and when it gets to this state, leave it plugged in and just let it run for at least ten minutes. It should eventually finish and come back to a normal state.
Hawkeye9723
C?ID=389466
I seem to be having a similar issue. I have set up my cloud account, but when trying to do cloud functions I get the server error. I wait the 10 seconds and try again. Then it directs me to the VCDS Cloud Index Page and prompts me to login. I enter my username and password and then all I can see is “View saved files” and “Account management”
I’m working with a VW Tiguan SEL-P module 5F I have the HEX-Net tethered to my Android phone and I’m using the app on that same phone.
   #44
Shaun
What module are you having this issue with, can you post an autoscan? Have you tried some of the other modules in the car, to see if they work?
   #45
Hawkeye9723
C?ID=389466
Shaun, here are the Autoscan I did. One is over the USB, and the other is over WiFi. I was attempting to use module 09 (Central Elect.). I did not try a different module. I ended up grabbing an old laptop. I can attempt again with my phone on a different module.
EDIT: Tried again tonight, and cloud functions were working as expected on multiple modules. Must has been a glitch in the matrix. :)
USB:
Thursday,12,December,2019,15:59:41:31648
VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4513.4
VIN: 3VV4B7AX2KM######   License Plate:
Mileage: 2788km-1732mi   Repair Order:
Chassis Type: AX-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 22 29 2B 36 39 3C 42 44 47
          4B 52 5F 6C 6D 75 A5 CA D6 D7
VIN: 3VV4B7AX2KM######   Mileage: 2788km-1732miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DGUA)       Labels:. 06L-907-115-V1.clb
   Part No SW: 83A 907 115     HW: 06L 907 309 B
   Component: R4 2.0l TFSI  H31 0004
   Revision: 1DH31000
   Coding: 012A00122466012FB4000000000000000000000000000000
   Shop #: WSC 00066 790 00451
   ASAM Dataset: EV_ECM20TFS01183A907115 001006
   ROD: EV_ECM20TFS01183A907115.rod
   VCID: 63868DD16A2E1857DA-8036
   Part No SW: 09G 927 158 DT    HW: 09G 927 158
   Component: AISIN AQ8     206 3549
   Coding: 0002000100000000000000000000000000000000
   Shop #: WSC 00066 790 00446
   ROD: EV_TCMAQ450031_VW37.rod
   VCID: 085CBA7DB3489B0FEF-805C
   Part No SW: 5Q0 614 517 DT    HW: 5Q0 614 517 BP
   Component: ESC           H35 0108
   Revision: 00000000    Serial number: 51479000001482
   Coding: 0BFA6BA450281B6CC5770303A2C749D0D60AD8A3C045927438415058D2AA4A0B00402864121A1C230935351919323200
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 0640B445B95C8D7F9D-8052
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0514420935
   Coding: 132C2C0723
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_KessyHellaMQBAB 004046
   VCID: 43C66D51CAEE7857FA-8016
   Subsystem 1 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 11741140
Address 08: Auto HVAC (E87)       Labels:| 3V0-907-044.clb
   Part No SW: 5NN 907 044 N    HW: 5NN 907 044 N
   Component: AC Automat    H35 4601
   Revision: 20K03000    Serial number: 00000D00387459
   Coding: 00020024200118001105010C1211140E
   ASAM Dataset: EV_ACClimaPrehVW37X 002025
   ROD: EV_ACClimaPrehVW37X.rod
   VCID: 57FEA9012E76C4F7B6-8002
   Air quality sensor:
   Subsystem 1 - Part No SW: 5Q0 907 659 C    HW: 5Q0 907 659 C
   Component: G238 _AQS  H30 0119
   Serial number: 94600257
   Part No SW: 5Q0 937 087 BA    HW: 5Q0 937 087 BA
   Component: BCM PQ37BOSCH 036 0265
   Revision: --------    Serial number: C86421061902J1
   Shop #: WSC 00066 790 00267
   ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 7BB6D5B1F29EC097F2-802E
   Subsystem 1 - Part No SW: 5NN 955 119     HW: 5NN 955 119   Labels: 1KX-955-119.CLB
   Component: 326 LL 190405  034 0373
   Serial number: 19040421004440
   Component: RLHS  052 0107
   Serial number: S6Y19M05D23H17M05S29
   Coding: 00A8DD
   Steering Column Switch:
   Subsystem 4 - Part No SW: 5Q1 953 521 R    HW: 5Q1 953 569 B
   Component: Lenks.Modul  H23 0170
   Serial number: 0300260620190C200173
   Part No SW: 5QA 919 294 C    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0050
   Serial number: 000137088R19175
   Coding: 0471255811
   ASAM Dataset: EV_EPHVA18AU3700000 009039
   VCID: 4CD4466DE7B0B72F0B-8018
   Part No SW: 2Q0 907 572 Q    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0342
   Coding: 320000C258FF8728749C810530409700000000000000000000
   ASAM Dataset: EV_ACCMRRCONTIVW376 003015
   ROD: EV_ACCMRRCONTIVW376_003_VW37.rod
   VCID: 42C86855D5F4715FF1-8016
   Part No SW: 5Q0 959 655 BM    HW: 5Q0 959 655 BM
   Component: AirbagVW21    005 0403
   Serial number: 003FGM03PKW7
   Coding: 8CCCFC00000000005000001AC20800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 0C54866DA730F72FCB-8058
   Occupant Detection:
   Serial number: IBH00000000000BPA80E
   Coding: 303352
   Subsystem 2 - Part No SW: -----------    HW: 480 001 005 19
   Serial number: 3570000000085BF82C3-
   Subsystem 3 - Part No SW: -----------    HW: 480 001 705 19
   Serial number: 358000000009A465FB3-
   Subsystem 4 - Part No SW: -----------    HW: 480 401 105 19
   Component: SideSensor_Dr  005 6149
   Serial number: 3510001BAF029AA7F85Q
   Subsystem 5 - Part No SW: -----------    HW: 480 401 705 19
   Component: SideSensor_Pr  005 6149
   Serial number: 3520001C8EFE7865C34X
   Subsystem 6 - Part No SW: -----------    HW: 480 403 105 19
   Component: FrontSensor_D  005 6149
   Serial number: 3550001BCF051DB3FA1P
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 403 105 19
   Component: FrontSensor_P  005 6149
   Serial number: 3560001BCF051DB3841D
   Part No SW: 5NA 920 890 D    HW: 5NA 920 890 D
   Component: KOMBI         509 1701
   Coding: 08A4041AEF88CF050288634B50010000A0000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001026
   ROD: EV_DashBoardVDDMQBA0_VW37.rod
   VCID: 44C46E4DCFE07F6FC3-8010
   Serial number: 21061900840047
   Coding: 030500347F085900FB03225A1E0F00010001070000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 6E90ECE5B1ECA53F45-803A
   Component: 0-00-0d-00-04
   Subsystem 2 - Part No SW: 5NA 959 442 B    HW: 5NA 959 442 B
   Component: E221__MFL-TAT  H06 0025
   Serial number: 0981902550700324FG2B
   Coding: 2E0000
   Serial number: 8840436600
   Component: Haldex4Motion H55 7084
   Serial number: HA1-00002.04.19
   Coding: 0101
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
   Component: LCM_MLBevoH08 0014
   VCID: 45C27349C4DA4667D4-8010
   Serial number: 19000110819008
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 33263D919A4EC8D76A-8066
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 C    HW: 5Q0 959 760 C
   Component: Sitzmemory    H09 0024
   Serial number: Y0006SDE37620
   Coding: 0010000000000500018280808080000000008101000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   VCID: 3D321BA9AC0A0EA78C-8068
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   Serial number: 0515380406
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0081
   Serial number: 0519089033
   Coding: 020111
   Part No SW: 5Q4 959 593 M    HW: 5Q4 959 593 F
   Component: TSG FS        006 0247
   Serial number: 42038913301668
   Coding: 003F1B205200048000000000
   VCID: 4FEE516116A68C376E-801A
   Subsystem 1 - Part No SW: 5Q4 959 811 G    HW: 5Q4 959 811 G
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000003397190
   Coding: 011000
   Part No SW: 5QM 909 144 B    HW: 5QM 909 144 B
   Component: EPS_MQB_ZFLS  173 1081
   Coding: 911F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 50EC521D0B9893CF77-8004
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1KMD04XU6C
   Coding: 2200000000AAAAAA000000000000
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: 2E102CE5716CE53F05-807A
   Component: FCM MQB Low   002 0345
   Serial number: 16061900840037
   Coding: 0000000509001D5200210F01090000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW37.rod
   VCID: 35220389943AD6E744-8060
   Part No SW: 5Q4 959 592 M    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0247
   Serial number: 46038915800683
   Coding: 003F13205E00048000000000
   VCID: 4ED04C6511AC853F65-801A
   Subsystem 1 - Part No SW: 5Q4 959 812 G    HW: 5Q4 959 812 G
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000003431911
   Coding: 091000
   Part No SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
   Component: MU-S-NS-US    853 0890
   Coding: 027306020000000051220002001808001F0500E401200405C6
   ROD: EV_MUStd4CDELP_VW37.rod
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  254 8130
   Serial number: VWZ6ZMW1755086
   Subsystem 2 - Part No SW: 5NA 919 866 E    HW: -----------
   Component: NAR 2018/19  --- 0810
   Part No SW: 5Q0 907 556 C    HW: 5Q0 907 556
   Component: Areaview 2    H13 0608
   Serial number: C854707JG052686
   Coding: 01230601A20F20003000400C
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
   ROD: EV_CamSysRVAV2ARCE2MQBAB.rod
   VCID: 393A0FB9B8223287A0-806C
   Part No SW: 5Q0 959 107 Q    HW: 5Q0 959 107 C
   Component: HDSG-Modul    H12 0266
   Revision: --------    Serial number: A2-C758-8700-2
   Coding: 0A28
   VCID: 46C07445F9DC4D7FDD-8012
   Component: OCULowMQBUS   009 0570
   Coding: 02230602C2823A037F1E06020000
   Shop #: WSC 14217 002 1048576
   ROD: EV_OCULowMQB.rod
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H09 0610
   Serial number: 16121815P20374
   Coding: 0003070601020201002213548150490084000E20012000
   ROD: EV_MFKBoschMQBB_002_VW37.rod
   VCID: 40CC625DDBF8634FE7-8014
   Coding: 00804073260C
   ROD: EV_SunRoofCONTIAU736_009_VW37.rod
   VCID: 75A2C389D4BA96E784-8020
   Part No SW: 7P5 941 572 AG    HW: 7P5 941 572 A
   Component: LED1L         H07 0008
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 004CA25D9B78A34FA7-8054
   Component: LED1R         H07 0008
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxRKEBODVW481.rod
End----------(Elapsed Time: 02:12, VBatt start/end: 14.8V/14.8V)-----------
Mobile:
VCDS Mobile 0.4513.0.4
Address 01: Engine  (DGUA J623)	Labels: None
	Revision: 1DH31000
	VCID: E389BC8F2D4BB0C4EBF065-80B6
No fault codes found.
Address 02: Auto Trans  (J217)	Labels: 09-02.lbl
	VCID: 88538B23F42D339CDE427A-80DD
Address 03: ABS Brakes  (J104)	Labels: 5Q-03.clb
	Revision: 00000000
	ROD: EV_Brake1UDSContiMK100IPB_038_VW37.rod
	VCID: 864F851BFE3925ECAC2E64-80D3
Address 05: Acc/Start Auth.  (J518)	Labels: 5Q0-959-435.clb
	Revision: 00037000
	Coding: 132C2C0723
	VCID: 43C9DC0F0D8B50C44BB045-8016
Address 08: Auto HVAC  (E87)	Labels: 5N-08.lbl
	Revision: 20K03000
	VCID: 57F1185FE913EC64077861-8002
	Subsystem 1 - 	Part No SW: 5Q0-907-659-C
	Serial Number: 94600257
	Subsystem 2 -
Address 09: Cent. Elect.  (J519)	Labels: 5Q-09.clb
	Revision: --------
	ROD: EV_BodyContrModul1UDSBosc_019_VW37.rod
	VCID: 7BB964EF35FBE80443C0ED-802E
	Subsystem 1 - 	Part No SW: 5NN-955-119	Labels: 1Kx-955-119.clb
	Component: 326 LL 190405034 0373
	Serial Number: 19040421004440
	Subsystem 2 - 	Part No SW: 5Q0-955-547-B	Labels: 5Q0-955-547.clb
	Serial Number: S6Y19M05D23H17M05S29
	Coding: 00A8DD
	Subsystem 3 -
	Subsystem 4 - 	Part No SW: 5Q1-953-521-R
	Serial Number: 0300260620190C200173
Address 10: Park/Steer Assist  (J446)	Labels: 5Q-10.lbl
	Coding: 0471255811
	VCID: 4CDBF73320D59FBCBAEAE6-8019
Address 13: Auto Dist. Reg  (J428)	Labels: 2Q0-907-572.clb
	ROD: EV_ACCMRRCONTIVW376_003.rod
	VCID: 42C7D90B129159CC408678-8017
Address 15: Airbags  (J234)	Labels: 5Q0-959-655.clb
	VCID: 8C5BB733E0555FBCFA6AA6-80D9
	Subsystem 1 - 	Part No SW: 4M0-959-339-B
	Component: BF-Gewichtss.H13 0022
	Serial Number: IBH00000000000BPA80E
	Coding: 303352
	Subsystem 2 - 	Part No SW: --------------
	Component: SideSensor_Df001 0887
	Serial Number: 3570000000085BF82C3-
	Subsystem 3 - 	Part No SW: --------------
	Component: SideSensor_Pf001 0887
	Serial Number: 358000000009A465FB3-
	Subsystem 4 - 	Part No SW: --------------
	Component: SideSensor_Dr005 6149
	Serial Number: 3510001BAF029AA7F85Q
	Subsystem 5 - 	Part No SW: --------------
	Component: SideSensor_Pr005 6149
	Serial Number: 3520001C8EFE7865C34X
	Subsystem 6 - 	Part No SW: --------------
	Component: FrontSensor_D005 6149
	Serial Number: 3550001BCF051DB3FA1P
Address 17: Instruments  (J285)	Labels: 5N-17.lbl
	VCID: 44CBDF13088557FC72BA4E-8011
Address 19: CAN Gateway  (J533)	Labels: 3Q0-907-530-V1.clb
	ROD: EV_GatewNF_VW37.rod
	VCID: 6E9F5DBB76898DACF45E1C-803B
	Subsystem 1 - 	Component: 0-00-0d-00-04
	Subsystem 2 - 	Part No SW: 5NA-959-442-B
	Component: E221__MFL-TATH06 0025
	Serial Number: 0981902550700324FG2B
	Coding: 2E0000
	Subsystem 3 - 	Part No SW: 5QA-915-181-D
	Component: J367-BDMHellaH10 9070
	Serial Number: 8840436600
Address 22: AWD  (J492)	Labels: 0CQ-907-554.clb
	Coding: 0101
	Shop #: WSC 00000 000
	VCID: 45CDC21703BF6EF465A45B-8010
Address 2B: Steer. Col. Lock  (J764)	Labels: 5Q0-905-861.clb
	VCID: 33298CCF5D2BE044DB1095-8066
Address 36: Seat Mem. Drvr  (J810)	Labels: None
	ROD: EV_SeatMemorDriveSide_002.rod
	VCID: 3D3DAAF76B6F26343D7403-8068
	ROD: EV_LCMRightHELLAAU736_VW37.rod
Address 3C: Lane Change  (J1086)	Labels: 5Q0-907-686.clb
	Coding: 02011103
	ROD: EV_HREntryHella.rod
Address 42: Door Elect, Driver  (J386)	Labels: 5Q-42.clb
	Coding: 001F1B205200048000000000
	VCID: 4FE1E03FD1C3A4A4DF08C9-801A
Address 44: Steering Assist  (J500)	Labels: 5Q0-909-144.clb
	Coding: 911F0000
	VCID: 50E3E343CCFDBB5CC632D2-8005
Address 47: Sound System  (J525)	Labels: 5Q0-035-456.clb
	Revision: 00000001
	VCID: 2E1F9DBBB609CDACB4DE5C-807B
Address 4B: Multifunc. Module  (J745)	Labels: None
	VCID: 352DB2D7535FFE74F504EB-8060
Address 52: Door Elect, Pass.  (J387)	Labels: 5Q-52.clb
	Coding: 001F13205E00048000000000
	VCID: 4EDFFD3BD6C9ADACD41EFC-801B
Address 5F: Information Electr.  (J794)	Labels: 5G0-035-MIB-STD2.clb
	Subsystem 1 - 	Part No SW: 5G6-919-605-D
	Component: ABT_Std-2_Nav254 8130
	Serial Number: VWZ6ZMW1755086
	Subsystem 2 - 	Part No SW: 5NA-919-866-E
	Serial Number: --------------------
Address 6C: Back-up Cam.  (J928)	Labels: 5Q-6c.lbl
	ROD: EV_CamSysRVAV2ARCE2MQBAB_006.rod
	VCID: 3935BEE77F471A14112CD7-806C
Address 6D: Trunk Elect.  (J605)	Labels: 5Q0-959-107.clb
	Revision: --------
	Coding: 0A28
	VCID: 46CFC51B3EB965EC6CAEA4-8013
Address 75: Telematics  (J949)	Labels: 5QE-035-285.clb
Address A5: Frt Sens. Drv. Assist  (R242)	Labels: 3Q0-980-65X-A5.clb
	Coding: 0003070601020201002213548150890084000E20012000
	ROD: EV_MFKBoschMQBB_002.rod
	VCID: 40C3D3031C9D4BDC569262-8015
Address CA: Sunroof  (J245)	Labels: None
	VCID: 75AD72D713DFBE743584AB-8020
Address D6: Light Ctrl Left 2  (A31)	Labels: None
	VCID: 80439303DC1D0BDC961222-80D5
Address D7: Light Ctrl Right 2  (A27)	Labels: None
	ROD: EV_LEDMinMaxR_KEBODAVW481.rod
End--(Elapsed Time: 03:04, VBatt start/end: 12.3/12.3 Vign: 0.0)-
footwork
C?ID=243417
Uwe, I have hex net and am able to put it in infrastructure mode and connect to the cloud. There is no screen to register or login YET, when I go to basic settings to use a measuring block, it takes me to a screen that say I must register for a cloud account but there is no button to actually register. I went to ross-tech and there's a video to show how to register with VCDS but not VCDS mobile. Serial HN1-004701
   #47
Shaun
That interface is already registered for the cloud. The first thing I would recommend is to make sure that your interface is up to date, and then I would try this again. If you still have issues, please post what module you are talking to and what specific procedure you are trying to perform.
footwork
C?ID=243417
Hi Shaun I am trying to perform the E brake opening and closing. Maybe I do not know my login for the cloud? I have not updated firmware or anything in a long time but It does not seem like this is a problem. I am really deperate to get this going I am leaving on a trip tomorrow and I have car on jack stands trying to get rear brakes done. This is very frusterating Can you help?
   #49
footwork
C?ID=243417
The app on my mac is called hex net config_legacy - I am unable to find any other mac download att his time. I try and update the
hex net itself in this app and the dialog box says "the update must be done through the web interface, the USB update has changed behind the scenes."
   #50
footwork
C?ID=243417
when I hit the update button in the vcds mac app it just crashes out.... is there a workaround here to get access to the cloud? I do not have access to a PC and the mac compatability is why I got this back in the day. Thanks for any guidance.
   #51
Shaun
You can open VCDS-Mobile from any web browser by entering it's IP address displayed by the config utility while the interface is connected in infrastructure mode. Then you can go to [Options] -> [Check for Updates].
However, if you need this done by tomorrow I suggest the fastest way might be to borrow a windows computer from a friend.
   #52
Shaun
If you forget your password, you can go to VCDS-Cloud.com and enter your username and click the password reset. It will email you with followup steps.
drdanbah
Sweden
C?ID=124310
In order for the HEX-NET to connect to the internet, it needs to be in Infrastructure mode -- a client on some other network rather than creating its own network.
How can I put into Infrastructure mode without a computer?
   #54
Shaun
You can put it into AP mode by pushing the button so the middle led is amber, then connect to the network it broadcasts and open VCDS-Mobile. Under Options you can enter network settings for your Infrastructure network then push the button to switch to infrastructure mode. If it is set correctly middle LED turns green when it connects to your network, and now you can switch your phone back to your main infrastructure network if it didn't do so automatically. But really this kind of network setup is much easier from the PC utility, I would recommend that you borrow a PC from somewhere.
