Hello to everyone. I am about to do a little project, swapping half MFD to full MFD in VW Golf MK5 2005. I know this cannot be done with VCDS, but I have other tools for that. The only donor tacho I can get now (and I did not buy it yet, because I am not sure if it will work) is from the car with DSG transmission, but my car is equipped with manual transmission. In the lower part of the donor tacho (picture 2.jpg from the web) is the DSG gear shift indicator. Is there any way to get rid of it to look like in picture 1.jpg? I attached VCDS log from the car with current (half MFD).
Thanks for your help!
Primoz
Primoz
Tuesday,22,March,2022,09:01:23:38999
VCDS Version: 22.3.0.1 (x64) HEX-V2 CB: 0.4613.4
Data version: 20220225 DS336.1
VIN: WVWZZZ1KZ5W064982 License Plate:
Mileage: 197080km-122459mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 7D
VIN: WVWZZZ1KZ5W064982 Mileage: 197080km-122459miles
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-016-BKC.clb
Part No SW: 03G 906 016 FS HW: 028 101 195 5
Component: R4 1,9L EDC G000SG 6124
Revision: 12345678 Serial number: VWZ7Z0D0394606
Coding: 0000071
Shop #: WSC 01279 785 00200
VCID: 79AFEBCDF5D0D7B388C-802C
VINID: 9E69EAAAA05BA859C018424808A0078936
17057 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 - 000 - Electrical Fault
Torque: 144.0 Nm
Voltage: 11.70 V
Bin. Bits: 00001111
Temperature: 7.2°C
Bin. Bits: 00110000
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 N
Component: ASR FRONT MK70 0103
Coding: 0017025
VCID: 3D273FDDA1782B93E44-8068
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 AT
Component: ClimatronicPQ35 066 0606
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 T HW: 1K0 937 049 T*
Component: Bordnetz-SG 1.0 H30 0704
Revision: 00030000 Serial number: 00000000896116
Coding: 01890B0600041800001400001400000000
Shop #: WSC 07149 690 10000
VCID: 40D94629D68A467B8F2-8014
Subsystem 1 - Part No: 1K1 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0401
Coding: 00065493
Shop #: WSC 07149
01064 - Terminal 58d; Interior Dimming
02404 - Vehicle Exterior Illumination
010 - Open or Short to Plus
Part No SW: 1K0 909 605 H HW: 1K0 909 605 H
Component: 01 AIRBAG VW8 023 0700
Revision: 06023000 Serial number: 00385D0HRCZY
Coding: 0012337
Shop #: WSC 01268 785 00200
VCID: 313F13ED6D20DFF370C-8064
Subsystem 1 - Serial number: 6332MSME28354604
Subsystem 2 - Serial number: 6342MSME134C7D03
Subsystem 3 - Serial number: 6351HSME12194A03
Subsystem 4 - Serial number: 6361HSME31445803
Part No SW: 1K0 953 549 B HW: 1K0 953 549 B
Component: Lenksäulenmodul 013 0010
Coding: 0002042
Component: Lenkradmodul 002 0010
Part No: 1K0 920 851 B
Component: KOMBIINSTRUMENT VDD 0814
Coding: 0003103
Shop #: WSC 11111 111 11111
VCID: 270BFDB553E49143AE8-8072
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H09 0110
Revision: 09 Serial number: 270010481304CD
Coding: 3D0F0B40070000
VCID: 290FFB8D45F0A733B8C-807C
01304 - Radio
Reset counter: 20
Mileage: 193220 km
Time: 00:20:43
Reset counter: 60
Mileage: 193220 km
Time: 00:20:51
Component: IMMO VDD 0814
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
Part No: 1K0 959 701 E
Component: Tuersteuergeraet 09 0149
Coding: 0000052
VCID: 303916E9662AD6FB7F2-8064
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 G
Component: EPS_ZFLS Kl.6 1401
VCID: 2F3B15957B14C903668-807A
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 BK
Component: 01 KSG 0301
Coding: 80C802087F2D8404084A01E010
Shop #: WSC 00000 785 00200
VCID: 7AADF4C1F0D6DCAB816-802E
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX1.lbl
Part No: 1K0 959 702 G
Component: Tuersteuergeraet 09 0153
Coding: 0000052
Shop #: WSC 07149 298 06375
VCID: 333319E5973CEDE3020-8066
Address 56: Radio
Component: PTC-Element 0404
VCID: 2D070F9D7118BB13544-8078
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
End----------(Elapsed Time: 00:55, VBatt start/end: 12.5V/12.4V)-----------
