ABS Coding (MK60EC1 after Engine Swap)
Germanzues
South Africa
C?ID=327780
Dear Friends,
Can you`ll please help me as I need the long code for ABS unit.
Also if you can please provide me the link for programming procedure.
Thank you.
Friday,27,May,2022,12:50:14:45632
VIN: WVWZZZ1KZBW334621   License Plate: ABS INCORRECT
Mileage: 158030km-98195mi   Repair Order:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72
VIN: WVWZZZ1KZBW334621   Mileage: 158030km-98195miles
56-Radio -- Status: Not registered 0001
Address 01: Engine (CAX)       Labels: 03C-906-016-CAX.clb
   Part No SW: 03C 906 016 AJ    HW: 03C 907 309 A
   Component: MED17.5.5       G   9971
   Revision: LCH12---    Serial number:
   Coding: 0000077
   Shop #: WSC 00010 824 103719
   VCID: 678A4CD25366F0336E5-8032
   VINID: 9E69EAAAA05BA929C30C41820466810868
049682 - Steering Column Control Module
               U0212 - 000 - No Communications
                    Mileage: 158019 km
                    Date: 2016.10.15
                    Time: 13:31:51
                    RPM: 716 /min
                    Load: 22.0 %
                    Temperature: 72.0°C
                    Temperature: 26.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.716 V
008852 - Fuel Pressure Regulator Valve (N276)
               P2294 - 000 - Open Circuit - MIL ON
                    Fault Status: 11100000
                    Mileage: 158019 km
                    Date: 2016.10.15
                    Time: 13:31:52
                    RPM: 716 /min
                    Load: 25.1 %
                    Temperature: 72.0°C
                    Temperature: 26.0°C
                    Voltage: 13.843 V
005241 - Brake Boost Vacuum System
               P1479 - 000 - Mechanical Failure
                    Mileage: 158035 km
                    Date: 2016.10.17
                    Time: 12:48:41
                    RPM: 800 /min
                    Load: 26.7 %
                    Temperature: 10.0°C
                    Temperature: 12.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 14.097 V
Readiness: 0010 0001
   Part No SW: 0AM 300 050 D    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 9033
   Revision: 00043014    Serial number: CU501608045490
   Shop #: WSC 64989 001 1048576
   VCID: 2A0CF5E680F40D5BB1B-807E
006247 - Powertrain Data Bus
               P1867 - 000 - Missing Message from Steering Wheel (J527)
                    Reset counter: 10
                    Mileage: 158019 km
                    Date: 2016.10.15
                    Time: 13:31:54
   Revision: 00H31001
   Shop #: WSC 00066 000 00000
   VCID: 7BA200A233EE44D39AD-802E
                    Reset counter: 38
                    Date: 2016.09.26
                    Time: 01:08:17
                    Count: 3
                    Count: 20992
                    Count: 195
                    Count: 51200
                    Fault Status: 01100101
                    Reset counter: 38
                    Mileage: 157917 km
                    Date: 2016.09.26
                    Time: 01:08:17
                    Count: 3
                    Count: 2
                    Count: 29184
                    Count: 279
                    Count: 50944
                    Count: 65280
                    Reset counter: 38
                    Mileage: 157917 km
                    Date: 2016.09.26
                    Time: 01:08:17
                    Count: 3
                    Count: 2
                    Count: 29184
                    Count: 295
                    Count: 50944
                    Count: 65280
                    Reset counter: 38
                    Mileage: 157917 km
                    Date: 2016.09.26
                    Time: 01:08:17
                    Count: 3
                    Count: 2
                    Count: 29184
                    Count: 270
                    Count: 50944
                    Count: 65280
   Part No SW: 5K0 907 044 DT    HW: 5K0 907 044 DT
   Component: Climatronic   H17 1010
   Revision: 00003001
   Coding: 0000001002
   Shop #: WSC 00066 000 00147
   VCID: 0058774E5A88270BCFF-8054
          B10AB F0 [009] - Too Low
                    Reset counter: 47
                    Mileage: 158019 km
                    Date: 2022.05.25
                    Time: 13:32:03
9496597 - Sunlight Photo Sensor
          B10E8 15 [009] - Open or Short to Plus
                    Reset counter: 47
                    Mileage: 158019 km
                    Date: 2022.05.25
                    Time: 13:32:03
9496613 - Sunlight Photo Sensor
                    Reset counter: 47
                    Mileage: 158019 km
                    Date: 2022.05.25
                    Time: 13:32:03
   Part No SW: 5K0 937 087 P    HW: 5K0 937 087 P
   Component: BCM PQ35 H    011 0046
   Revision: BK011001
   Coding: 02180E3A883F02C0400000803400892443750088737D0960648000200040
   Shop #: WSC 00066 123 12345
   VCID: 42DCBD461484F51B99B-8016
   Subsystem 1 - Part No: 5K2 955 119
   Component: Wischer 21031  26  0512
   Coding: 009795
   Component: RLS 040311 05  54  0403
   Coding: 0B30AD
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 47
                    Mileage: 158019 km
                    Date: 2016.10.15
                    Time: 13:32:14
                    Voltage: 13.90 V
   Part No SW: 5K0 959 655 E    HW: 5K0 959 655 E
   Component: AirbagVW10G   037 0606
   Serial number: 003FLR00NLP6
   Coding: 00003138
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3C20C3BE76E083EBD37-8068
   Subsystem 1 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3572MSME55346155ZZZR
   Subsystem 2 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3582MSME1B74645BZZZ0
   Serial number: 3511HSME1B133526ZZZD
   Serial number: 3521HSME21535326ZZZ9
   Part No SW: 5K0 953 507 AC    HW: 5K0 953 549
   Revision: --------    Serial number:  90422KBB000NW
   Coding: 5880040000
   Shop #: WSC 00066 000 00197
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 71BE228A61223E83301-8024
   Part No SW: 5K0 920 871     HW: 5K0 920 871
   Coding: 170B00
   VCID: 6B8230E2430ED4530AD-803E
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 02041101210345
   Coding: 352003
   VCID: 3038E78EAA28778B7FF-8064
                    Fault Frequency: 33
                    Mileage: 158019 km
                    Date: 2016.10.15
                    Time: 13:32:16
   Component: IMMO          H20 0420
   VCID: 6A8C35E64CF4CD5B71B-803E
   Part No SW: 561 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0502
   Revision: 12110009    Serial number: 0002193577
   Coding: 0012B6
   Shop #: WSC 01383 790 50316
   VCID: 1C60233ED620E3EB337-8048
   Slave Driver:
   Subsystem 1 - Part No SW: 1K0 959 704 AG    HW: 1K0 959 794 R
   Component: J389__TSG-HR  006 1401
   Serial number: 00000005606528
   Coding: 000290
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 69     3201
   Revision: 00H20000
   Shop #: WSC 02069 000 90108
   VCID: 3430EB9E52304BAB1B7-8060
   Part No SW: 561 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0502
   Revision: 14110009    Serial number: 0002245751
   Coding: 0013B6
   VCID: 1D662E3ACD3AEAE3C49-8048
   Slave Passenger:
   Subsystem 1 - Part No SW: 1K0 959 703 AG    HW: 1K0 959 795 R
   Component: J388__TSG-HL  006 1401
   Serial number: 00000005592370
   Coding: 000290
67589 - Turn Signal in Exterior Mirror
          B11FD 01 [009] - Electrical Failure
                    Reset counter: 48
Address 55: Headlight Range        Labels: 5M0-907-357-V2.clb
   Coding: 1476444
   Shop #: WSC 07130 981 63406
   Coding: 00000022
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Coding: 00000022
   Part No SW: 6RD 035 187 B    HW: 6RD 035 187 B
   Component: Radio         534 5314
   Revision: --------    Serial number: VWZZZ4H6233379
   Coding: 16000440040005
   Shop #: WSC 00078 790 00236
   VCID: 46D4A15638ACC93BB53-8012
End----------(Elapsed Time: 01:15, VBatt start/end: 14.2V/14.3V)-----------
   Coding: 0000077
                    Mileage: 158019 km
                    Date: 2016.10.15
                    Time: 13:31:51
                    RPM: 716 /min
                    Load: 22.0 %
                    Temperature: 72.0°C
                    Temperature: 26.0°C
                    Voltage: 13.716 V
                    Mileage: 158019 km
                    Date: 2016.10.15
                    Time: 13:31:52
                    RPM: 716 /min
                    Load: 25.1 %
                    Temperature: 72.0°C
                    Temperature: 26.0°C
                    Voltage: 13.843 V
                    Mileage: 158035 km
                    Date: 2016.10.17
                    Time: 12:48:41
                    RPM: 800 /min
                    Load: 26.7 %
                    Temperature: 10.0°C
                    Temperature: 12.0°C
                    Voltage: 14.097 V
                    Reset counter: 10
                    Mileage: 158019 km
                    Date: 2016.10.15
                    Time: 13:31:54
   Revision: 00H31001
                    Reset counter: 38
                    Date: 2016.09.26
                    Time: 01:08:17
                    Count: 3
                    Count: 20992
                    Count: 195
                    Count: 51200
                    Reset counter: 38
                    Mileage: 157917 km
                    Date: 2016.09.26
                    Time: 01:08:17
                    Count: 3
                    Count: 2
                    Count: 29184
                    Count: 279
                    Count: 50944
                    Count: 65280
                    Reset counter: 38
                    Mileage: 157917 km
                    Date: 2016.09.26
                    Time: 01:08:17
                    Count: 3
                    Count: 2
                    Count: 29184
                    Count: 295
                    Count: 50944
                    Count: 65280
                    Reset counter: 38
                    Mileage: 157917 km
                    Date: 2016.09.26
                    Time: 01:08:17
                    Count: 3
                    Count: 2
                    Count: 29184
                    Count: 270
                    Count: 50944
                    Count: 65280
                    Fault Status: 01101000
                    Reset counter: 48
                    Mileage: 158035 km
                    Date: 2016.10.17
                    Time: 12:51:04
                    Count: 3
                    Count: 2
                    Count: 29184
                    Count: 266
                    Count: 51968
                    Count: 65280
                    Count: 13824
   Revision: 00003001
   Coding: 0000001002
                    Reset counter: 47
                    Mileage: 158019 km
                    Date: 2022.05.25
                    Time: 13:32:03
                    Reset counter: 47
                    Mileage: 158019 km
                    Date: 2022.05.25
                    Time: 13:32:03
                    Reset counter: 47
                    Mileage: 158019 km
                    Date: 2022.05.25
                    Time: 13:32:03
   Revision: BK011001
   Coding: 009795
   Coding: 0B30AD
                    Reset counter: 47
                    Mileage: 158019 km
                    Date: 2016.10.15
                    Time: 13:32:14
                    Voltage: 13.90 V
   Coding: 00003138
   Coding: 5880040000
   Coding: 170B00
   Coding: 352003
                    Fault Frequency: 33
                    Mileage: 158019 km
                    Date: 2016.10.15
                    Time: 13:32:16
   Coding: 0012B6
   Slave Driver:
   Coding: 000290
   Revision: 00H20000
   Coding: 0013B6
   Slave Passenger:
   Coding: 000290
                    Reset counter: 48
   Coding: 1476444
   Coding: 00000022
   Coding: 00000022
End----------(Elapsed Time: 01:15, VBatt start/end: 14.3V/14.2V)-----------
It would be helpful to know how the ABS lost its coding.
- What (if any) parts have been replaced?
- Do the VINs stored in the ECU, the Instrument Cluster, and the Immobilizer all match each other and the physical VIN of the car?
etz2k
C?ID=69430
I have nothing to get the pr-codes, so if your car is rhd and has front brake disk 288mm
with iTPMS button: 163B400D112500FE681102E6881A0080B70000
w/o iTMPS button: 163B400D112500FE681102E6881A0080310000
Germanzues
South Africa
C?ID=327780
Thank you for getting back to me. Did chat with the workshop and the truth is now unveiled. Taken a engine, cluster, and wiring from a 1.4 tsfi ,turbo only and fitted into a 1.4 twin turbo/supercharger.
Is it possible to code out Vacuum sensor for brakes or is there a procedure for the sensor to be code and also take a look at the Gateway module.
I connect abs pump for this turbo vehicle(one set) and now got this scan as follows-
Saturday,28,May,2022,12:45:23:45632
Mileage:
   Coding: 0000077
                    Mileage: 158035 km
                    Date: 2016.10.18
                    Time: 12:41:47
                    RPM: 700 /min
                    Load: 17.2 %
                    Temperature: 63.0°C
                    Temperature: 24.0°C
                    Voltage: 13.970 V
                    Mileage: 158035 km
                    Date: 2016.10.18
                    Time: 12:41:48
                    RPM: 702 /min
                    Load: 18.0 %
                    Temperature: 63.0°C
                    Temperature: 24.0°C
                    Voltage: 14.097 V
Readiness: 1110 0001
                    Reset counter: 10
                    Mileage: 158035 km
                    Date: 2016.10.18
                    Time: 12:42:33
   Revision: 00H31001
   Coding: 163B400D112500FE681102E6881A0080310000
   VCID: 76B4119608CC19BBE53-8022
03366 - Vacuum Sensor
                    Fault Status: 01101100
                    Reset counter: 48
                    Mileage: 158035 km
                    Date: 2016.10.18
                    Time: 12:42:17
                    Count: 3
                    Count: 14
                    Count: 12800
                    Count: 213
                    Count: 51456
                    Count: 65535
                    Count: 120
   Revision: 00003001
   Coding: 0000001002
                    Reset counter: 48
                    Mileage: 158035 km
                    Date: 2022.05.28
                    Time: 12:42:34
                    Reset counter: 48
                    Mileage: 158035 km
                    Date: 2022.05.28
                    Time: 12:42:34
                    Reset counter: 48
                    Mileage: 158035 km
                    Date: 2022.05.28
                    Time: 12:42:34
   Revision: BK011001
   Coding: 009795
   Coding: 0B30AD
   Coding: 00003138
   Coding: 5880040000
   Coding: 170B00
   Coding: 352003
                    Mileage: 158035 km
                    Date: 2016.10.18
                    Time: 12:42:35
   Coding: 0012B6
   Slave Driver:
   Coding: 000290
   Revision: 00H20000
   Coding: 0013B6
   Slave Passenger:
   Coding: 000290
   Coding: 1476444
   Coding: 00000022
   Coding: 00000022
End----------(Elapsed Time: 01:13, VBatt start/end: 14.2V/14.2V)-----------
etz2k
C?ID=69430
Your car has a 1.4tsi with DSG (PR-1AS) so the vacuum sensor is required, the coding is still correct for the new engine (CAX).
You can dissable the sensor in the ABS coding, but it's better to fix the problem.
But what's wrong with your Vacuum Sensor? It should be between the brake servo and engine. Where is it? Have you checked the wiring?
coding with iTPMS button: 163B400D112500FE681102E6881A0080B70000
coding w/o iTMPS button: 163B400D112500FE681102E6881A0080310000
Germanzues
South Africa
C?ID=327780
Hi,
Thank you for your reply and the detailed information.
You have mention is can be disable. Can you please explain the process on how to disable the sensor.
Will really appreciate your help.
Germanzues
South Africa
C?ID=327780
Mileage:
   Coding: 0000077
                    Mileage: 158035 km
                    Date: 2016.10.18
                    Time: 12:41:47
                    RPM: 700 /min
                    Load: 17.2 %
                    Temperature: 63.0°C
                    Temperature: 24.0°C
                    Voltage: 13.970 V
                    Mileage: 158035 km
                    Date: 2016.10.18
                    Time: 12:41:48
                    RPM: 702 /min
                    Load: 18.0 %
                    Temperature: 63.0°C
                    Temperature: 24.0°C
                    Voltage: 14.097 V
                    Reset counter: 10
                    Mileage: 158035 km
                    Date: 2016.10.18
                    Time: 12:42:33
   Revision: 00H31001
                    Reset counter: 48
                    Mileage: 158035 km
                    Date: 2016.10.18
                    Time: 12:42:17
                    Count: 3
                    Count: 14
                    Count: 12800
                    Count: 213
                    Count: 51456
                    Count: 65535
                    Count: 120
   Revision: 00003001
   Coding: 0000001002
                    Reset counter: 48
                    Mileage: 158035 km
                    Date: 2022.05.28
                    Time: 12:42:34
                    Reset counter: 48
                    Mileage: 158035 km
                    Date: 2022.05.28
                    Time: 12:42:34
                    Reset counter: 48
                    Mileage: 158035 km
                    Date: 2022.05.28
                    Time: 12:42:34
   Revision: BK011001
   Coding: 009795
   Coding: 0B30AD
   Coding: 00003138
   Coding: 5880040000
   Coding: 170B00
   Coding: 352003
                    Mileage: 158035 km
                    Date: 2016.10.18
                    Time: 12:42:35
   Coding: 0012B6
   Slave Driver:
   Coding: 000290
   Revision: 00H20000
   Coding: 0013B6
   Slave Passenger:
   Coding: 000290
   Coding: 1476444
   Coding: 00000022
   Coding: 00000022
Quote Reply
Report Edit
Another thread of yours moving to Retrofits.
etz2k
C?ID=69430
The sensor is wired to the ABS unit (pin 5,40,41), what's wrong with it? Why want you code out a necessary part of the car brakes, the vw engineers did this not just for fun:confused:. Do a dsg2mt swap and you can code it out;).
  • Informative
Germanzues
South Africa
C?ID=327780
Hi,
What do you mean by dsg2mt.
Regards
kamold
Australia
C?ID=241363
DSG (change) 2 (to) Manual Transmission
