2013 Audi A4 work shop code?
Moxnix
C?ID=212386
Trying to enjoy all of the features of this software but come up against dialog box wanting "3" code, 0-9999. Is there some way to glean this from an autoscan? Car has been to the shop I can see that from the scan but there is nothing to indicate what the access code might be to "unlearn behaviours" etc. Thanks in advance for any input. I can post up whatever will help of course for anyone with knowledge of this. Best to all on the forum
Moxnix
C?ID=212386
My apologies, I did not fully read the online manual about the work shop codes. I will be more vigilant and let the software do its job and read more in depth before I post.
Moxnix
C?ID=212386
Update, when i went back to options in startup menu and selected save settings I was still asked for the 3 digit code when I try to tweak in module 44. If i go to "security" in the 44 module it asks for a 5 digit code? I did notice that the WSC starts with 5 digits so I will try that. Otherwise the program did not act in stealth mode as suggested and will not let me "unlearn steering behaviour". Any input would be welcome.
I'm having a hard time visualizing exactly where this is occurring. Can you post up some screen-shots please?
Moxnix
C?ID=212386
Hi Uwe,
Much obliged for responding to the post. Will post up some screen shots as soon as possible.
Best
Moxnix
C?ID=212386
Hi Uwe,
I just sent my autoscan off to RossTech and I am on a slight learning curve with the Toshiba laptop I went with to do this kind of work. Needless to say I have been a Mac person for the last 30 years so getting the screen shots up is going to take me a little longer. The screenshot issue I have down but posting them will require I do a little more reading. I don't want to waste your time until I can do this a little more efficiently. I will get them up as soon as possible.
Moxnix
C?ID=212386
Hi Uwe,
Any chance I can send you an autoscan along with the screenshots? I will give support another day but I haven't heard back from them after following their instructions. I have all the screen shots in photot bucket url form and cayn add them along with the autoscan. Let me know if this is something you would consider. Don't want to take advantage of your generosity.
GB
Is there some reason you don't want to post them here?
I believe he is referring to the UDS (reserved) box but I'm not entirely sure.
Internal Ref to E?ID=200940
Moxnix
C?ID=212386
2013 A4 Work Shop Code
Hi, here is the first scan I took, the latest scan and screen shots. Hopefully I did this right.
Sunday,13,April,2014,13:30:29:21746
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: WAUHFAFL2DA195461   License Plate: GFM1511
Mileage: 17440km-10836mi   Repair Order:
Chassis Type: FL (8R0)
Scan: 01 03 05 08 09 15 16 17 19 36 42 44 46 47 52 53 56 5F 62 6C
         72
VIN: WAUHFAFL2DA195461   Mileage: 17440km/10836miles
Address 01: Engine (0-----CAEB)       Labels: 06H-907-115-CDN.clb
  Part No SW: 8K5 907 115 C    HW: 8K2 907 115 L
  Component: 2.0l R4/4V TF H09 0005
  Revision: ECH09---
  Coding: 4A190013242600062000
  Shop #: WSC 38543 000 1048576
  ASAM Dataset: EV_ECM20TFS0118K5907115C 001006
  ROD: N/A
  VCID: 326B16B4657B938E5D3-8067
No ASAM data for: "EV_ECM20TFS0118K5907115C" (AU48)
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379.clb
  Part No SW: 8K0 907 379 CK    HW: 8K0 907 379 CK
  Component: ESP8 quattro  H09 0100
  Coding: 071D18
  Shop #: WSC 06325 000 00000
  VCID: 8407006C074F6D3E3FF-80D1
                   Fault Status: 00101101
                   Reset counter: 193
                   Mileage: 17443 km
                   Date: 2014.04.06
                   Time: 11:06:32
                   Hex Value: 0x0000
                   Hex Value: 0x0082
                   Hex Value: 0x001A
                   Hex Value: 0x0297
                   Hex Value: 0x0000
  Part No SW: 8K0 907 064 GM    HW: 8K0 907 064 FM
  Component: BCM2 2.0      H12 0633
  Coding: 0F814000000000000000
  VCID: 81090978185D7816149-80D4
  Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
  Revision: C1000000    Serial number: 01180120131569
  Coding: 6400208000
  VCID: 39792198B00D60D69C9-806C
  Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
  Revision: 08016001    Serial number: 00000539092902
  Coding: 26000091863CAFC00000480300003D0D0F1C1208A2090221000008000000030100000030000000
  VCID: 78FFE49CCB87B9DEA37-802D
  Component: WWS 210113  H07 0080
  Coding: 00FD11
  Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B
  Coding: 02005D
  Component: E1 - LDS  H03 0031
  Component: USHL4.2  H30 0030
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
  Part No SW: 8K0 959 655 P    HW: 8K0 959 655 P
  Serial number: 003KJD91AGHM
  Coding: 303842354730303030304A55304C384B3053
  ROD: EV_AirbaECUVWAUDI010_AU48.rod
  VCID: 4A9B6E54EDEBFB4E053-801F
  Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
  Serial number: 5810000R120000AZ8Z
  Serial number: 6334MSME76116C44E
  Serial number: 6344MSME761108647
  Serial number: 6352QSME6826365AN
  Serial number: 6362QSME3E2D486C/
  Serial number: 63732SME6D262544+
  Crash sensor for front airbag; passenger side:
  Serial number: 63832SME4527336E1
  Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
  Component: Lenks.Modul   H02 0171
  Revision: 00000000    Serial number: 20130121000643
  Coding: 000016
  VCID: 4FAD7F401E89DE6652D-801A
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
  Part No SW: 8K0 920 982 D    HW: 8K0 920 982 D
  Component: KOMBIINSTR.   H35 0556
  Revision: 00300000    Serial number: UVN79AJ1E
  Coding: 8BB409000301D705020000
  VCID: 35612DA89C1584B6781-8060
  Part No SW: 8R0 907 468 N    HW: 8R0 907 468 C
  Component: GW-BEM 4CAN-M H11 0055
  Revision: 1Y060027    Serial number: 2741Y131150658
  Coding: 80C303FF00
  VCID: 4A9B6E54E5EBFB4E053-801F
Address 36: Seat Mem. Drvr (J136)       Labels: 8T0-959-760.clb
  Component: MEM-FS        H06 0076
  Revision: AA000000    Serial number: 00000048546902
  Coding: 00581B00000000000000
  VCID: 3B753B90BA3152C68E5-806E
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
  Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
  Component: TSG FA        H09 0304
  Coding: 011C13204E00410001
  VCID: 56A38A242153AFAE91B-8003
Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
  Component: RCEPS         H37 0507
  Revision: 00001000    Serial number: 0007166157
  Coding: 100000000001
  Shop #: WSC 06324 000 00000
  ROD: EV_RCEPSAU48X.rod
  VCID: 346710AC9F6F9DBE4FF-8061
  Revision: 00002001    Serial number: 0300234317
  Coding: 0106023A00FA404580B0013200000000
  Component: GTO BF  H01 0080
  Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
  Component: J245 PS050  H08 0043
Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
  Revision: 00005001    Serial number: 94813009669202
  VCID: 2D5105C87445CC76001-8078
  Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
  Component: TSG BF        H09 0304
  VCID: 55A18D283C55A4B6981-8000
  Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
  Component: EPB-4         H01 0003
  Revision: --------    Serial number: 00000001232281
  ROD: EV_ParkiBrake_AU48.rod
  VCID: 387F249C830779DE637-806D
721152 - Brake pad replacement mode active
         C1011 00 [000] - -
                   Fault Status: 00000000
                   Fault Frequency: 0
                   Reset counter: 0
  Part No SW: 4G0 035 082 E    HW: 4G0 035 082
  Component: Radio U SIRIU H60 0121
  Revision: AB001007    Serial number: 156AV0D7682402
  Coding: 020007010000000001
  VCID: 224BE6F43D9B030EAD3-8077
  Part No SW: 8R1 035 746 C    HW: 8R1 035 746 B
  Component: H-BNT-NA      H44 0624
  Revision: --------    Serial number: 204AO0D7555132
  Coding: 0F0200000006A1EF41028B4E00000403140000000000000000
  VCID: 377D27A0861976A66AD-8062
  Subsystem 1 - Part No: 8R0 060 884 BA
  Component: NAR 2013  0703
  Component: DU7 High  H42 0104
  Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
  Component: CD-Database  4949
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
  Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
  Component: TSG HL        H07 0304
  Coding: 010C13204000210001
  VCID: 59B98118504D80D6BC9-800C
  Revision: --H07---    Serial number: 525PA8-J2X935D
  Coding: 1000006
  VCID: 387F249C4B0779DE637-806D
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-794.clb
  Component: TSG HR        H07 0304
Sunday,13,April,2014,15:20:51:21746
         72
  Revision: ECH09---
  ROD: N/A
  Coding: 071D18
                   Reset counter: 193
                   Mileage: 17443 km
                   Date: 2014.04.06
                   Time: 11:06:32
                   Hex Value: 0x0000
                   Hex Value: 0x0082
                   Hex Value: 0x001A
                   Hex Value: 0x0297
                   Hex Value: 0x0000
  Coding: 6400208000
  Coding: 00FD11
  Coding: 02005D
  Coding: 000016
  Coding: 80C303FF00
         C1011 00 [000] - -
                   Fault Frequency: 0
                   Reset counter: 0
  Coding: 1000006
Sunday,13,April,2014,15:24:49:21746
Address 44: Steering Assist (8K0 909 144 F)
15:24:33
[IMG]http://s1191.photobucket.com/user/garnetlake/media/dsrbox.png[/IMG]
[IMG]http://s1191.photobucket.com/user/garnetlake/media/44pane.png[/IMG]
[IMG]http://s1191.photobucket.com/user/garnetlake/media/adaptset.png[/IMG]
[IMG]http://s1191.photobucket.com/user/garnetlake/media/error2.png[/IMG]
[IMG]http://s1191.photobucket.com/user/garnetlake/media/VCDS9.png[/IMG]
[IMG]http://s1191.photobucket.com/user/garnetlake/media/IDscreen.png[/IMG]
[IMG]http://s1191.photobucket.com/user/garnetlake/media/adaptscreen.png[/IMG]
[IMG]http://s1191.photobucket.com/user/garnetlake/media/steerassist.png[/IMG]
Latest Scan
 Thursday,17,April,2014,15:17:43:21746
Mileage: 17460km-10849mi   Repair Order:
          72
VIN: WAUHFAFL2DA195461   Mileage: 17460km/10849miles
   Revision: ECH09---
   ROD: N/A
   Coding: 071D18
                    Reset counter: 193
                    Mileage: 17443 km
                    Date: 2014.04.06
                    Time: 11:06:32
                    Hex Value: 0x0000
                    Hex Value: 0x0082
                    Hex Value: 0x001A
                    Hex Value: 0x0297
                    Hex Value: 0x0000
                    Reset counter: 156
                    Mileage: 17445 km
                    Date: 2014.04.13
                    Time: 18:18:16
                    Hex Value: 0x0000
                    Hex Value: 0x0082
                    Hex Value: 0x0015
                    Hex Value: 0x1098
                    Hex Value: 0x0000
   Coding: 6400208000
   Coding:
000
1KX-955-119.CLB
   Coding: 00FD11
   Coding: 02005D
   Coding: 000016
   Coding: 80C303FF00
   Coding: 000000000001
          C1011 00 [000] - -
                    Fault Frequency: 0
                    Reset counter: 0
   Coding: 1000006
OK, I think these are the pics you intended to post:
CODE tags need square brackets [Code] and [/Code], not parenthesis, but I fixed those for you. ;)
Moxnix
C?ID=212386
Try scans again?
dsrbox.png.html
44pane.png.html
adaptset.png.html
error2.png.html
VCDS9.png.html
IDscreen.png.html
adaptscreen.png.html
steerassist.png.html
error.png.html
Sorry!
Moxnix
C?ID=212386
Yep, must be the Photobucket, I am doing it right. I will go with your suggestion. I had photobucket set up already.
Dang it, Photobucket is a huge PITA. :mad:
Moxnix
C?ID=212386
Thanks for fixing the brackets Uwe. I am making an account with the photo posting you have the link to. Sorry for the snafu. Yep, that's one of my scans.
Moxnix
C?ID=212386
UWE, I don't want to take up your time until I 86 the bucket and put them up for real. I will try to do it tonight but I have to find the originals and upload them. Don't trust photobucket anymore. I will have them up by tomorrow, the dog is giving me that look.
Well, I got your screen-shots to show. :)
Why Photobucket wants to make it difficult to do this, I do not understand.
Moxnix
C?ID=212386
Well I don't know how you did it but those are indeed my shots. Spezialist
Moxnix
C?ID=212386
Uwe,
Thanks for all of you help last night straightening out my scans and images so my issues are more easily identified.
G
I'll address one:
You have no values there because you haven't entered any. The reason you haven't entered any is probably because you haven't been assigned any by the VAG mothership. That's OK; when those fields are all zeros, VCDS will attempt to operate in Stealth Mode. That means it will try to put back whatever values it finds in a particular module already. Of course, there are some cases where that won't work and you'll have to make up some random, non-zero values to use, but hey..
See also:
http://www.ross-tech.com/vcds/tour/option_screen.html#UII
