Audi RS5 and S5 B9 VAG rocker arm Update (premature failure)
Itsmys4
Fullerton, CA, USA
C?ID=523098
That's correct.
However, just to be fully transparent: There are a few members here who are allowed to offer/advertise their services on the Ross-Tech forum. They are all people who fix cars and/or do diagnostics for a living. They all have the status of "Professional User", and they have earned that status by repeatedly helping others with various diagnostic-related issues.
You’re absolutely Correct I’m very new to forums in general and will now look up your rules to your ross tech forums, again I do apologize!
   #22
.................."I’m very new to forums"......................
Hi Josh, For what you seem to be focusing on I would recommend the other Audi forums such as Audizine and A5OC ; they have "marketplace" categories and "classified" areas that are more suited to your offering/services.
Also, I think you will find a more geographical targeted audience there (ie. West Coast USA) after all, I think your customer would need to be within a reasonable proximity. I'm not sure what the rules are with those two, but there are many vendors and sponsors , so it is a very broad audience. IMO, The primary focus here, is VCDS support with some "wrenching" to complete the process and not the other way around.
I look forward to your future write-ups and pictures and how VCDS applies on the (unverified , but developing rocker arm issue) B9 2.9L engine.
Welcome, and keep the forum here posted on your future findings.
   #23
Itsmys4
Fullerton, CA, USA
C?ID=523098
You’re awesome buddy thanks for all the support you guys are truly great I think I do have an account with Audizine.
   #25
Here is a new B9 video for PREVENTATIVE rocker arm replacement ; however, at the end of the video, the white B9 has a CEL showing and a loud ticking noise (especially with the oil fill cap removed ; I'll post [that] video once it is released, stay tuned!
   #26
RS5 , rockers caught in time ; water to air intercooler fail . S4 noise to be announced.
I'm starting to wonder if the coolant leaks (heat exchanger problem) is causing the rocker arm fail ??? ie xs coolant in oil :confused:
Regarding the poor compression test on the "white car" S4 above. It looks like some metal debris was holding open the valve slightly ; originally I thought the valve keepers came off, but for a split second in the video, he shows them removed in his hand. (56:00)....... (59:00)....
Original rocker arms appeared to be "ok" , but were updated anyway.
Helpful inspection video, rather than prod. date . Verify with Inspection. !
   #29
JMR
Romania
C?ID=432218
it s that you above @Itsmys4 ?
Huh, after that guys comment there will be lots of inspection cameras bought and returned :))
   #30
Itsmys4
Fullerton, CA, USA
C?ID=523098
No this isn’t me but it’s true you can see the rocker just by opening the oil filler cap, but won’t be able to see the roller bearing without the inspection camera haha
   #31
Another Rocker Arm failure (MY 2017, 2.9L V6 ) ; displaced and roller bearing fail.
   #32
Ziddywerks
Northern NJ USA
C?ID=208579
IIRC audi did make the design changes on later engines. I recently had one apart, the rockers and bearing do look bigger and beefier. That being said engine was apart because some other shop decided no to tighten water pump pulley after replacement of pump. Needless to say vehicle arrived for tear down and diagnosis of engine as per customers extended warranty. Customer was on the hook for tear down. Long story short, needs a long block. Also fun fact it seems as certain engines now are only available in long block form. Needed an engine for a 2018 a4 2.0t I purchased that decided to window the block, audi said no soup for you long block only. So then no soup for them i'll buy a decent one from LKQ instead.
   #33
Two more RS5's RS4's (but same engine) with very different mileage ; one needs a engine and the other can be repaired! One seems to be a intermix problem (coolant in intake system, from faulty intercooler) and the other was the rocker arm beginning to fail. (no roller bearing present!)
  • Informative
Another B9 (rocker arm caused) failure!
   #35
And now I've decided to go for a 2023 or 24 RS5 (coupe) and hopefully that issue will be sorted. But, just taking my time. :cool:
   #36
sportmotor
Czech Republic
C?ID=14747
Second video is up:
As a former owner of RS5 B9 2017, I dismantle rocker arms after 72000 km, all were like new.
Ticking and then hammering noise were from wearing out connecting rod bearing shells on cylinder 5.
But I use 0W-40 oil and changed it every 7500 km.
   #37
S4, B9, at 94K miles
