I have a strange problem with my Fabia: I replaced the reverse lights with high-power LEDs and now I get a check light warning. I have learned that I should be able to set the load for each bulb individually, and also that the reverse lights should be Leuchte28. It is in fact the only one with a mention of "Rueckfahrlicht" in the entire module, but I do not have a channel "(1) Load type" for the Leuchte28 ?? In the latest beta, this channel shows up, but it is "Not activated" or something similar (I can't remember the exact wording), and I am not able to change the value.
Is it possible to somehow change the load type for the Leuchte28, or to disable the light check altogether for this bulb, or do I just have to live with the error or switch back to traditional bulbs for the reversing lights. Based on advice I have tried changing the load type for Leuchte29, but that did not do any good.
Wednesday,27,May,2015,22:04:21:63777
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
VIN: TMBEN6NJ3FZ0xxxxx License Plate: xxx-xxx
Mileage: 3386 Repair Order:
Chassis Type: NJ (6C0)
Scan: 01 03 05 08 09 10 13 15 17 19 2B 44 5F 69
VIN: TMBEN6NJ3FZ025636
Address 01: Engine (J623-CJZD) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 027 BC HW: 04E 907 309 AF
Component: 1.2l R4 TSI H21 8229
Revision: R4H21---
Coding: 01190032243415080000
Shop #: WSC 73430 031 00045
ASAM Dataset: EV_ECM12TFS01104E906027BC 001006
ROD: EV_ECM12TFS_VW26.rod
VCID: 66C8BB60999EEC11F43-8033
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 6C0 907 379 G HW: 6R0 907 379 BA
Component: ESP9.0i H03 0003
Serial number: 08508261150116
Coding: 41F5487D492533C5091A106C0057821292CC9008000DCBF98F00
Shop #: WSC 13765 031 00045
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100018
ROD: EV_Brake1ESP90iBOSCHPQ26_SE26.rod
VCID: 336E12349ACC49B9A3D-8066
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Revision: 00021000 Serial number: 0358182678
Coding: 030C0C
Shop #: WSC 13765 790 00045
ROD: EV_KessyHellaMQBAB_SK26.rod
VCID: 3A703F10BDA6B8F160B-806F
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 6V0 907 044 HW: 6V0 907 044
Component: Climatronic H01 0105
Serial number: 1501201A-0253
Coding: 100000001011100001
ASAM Dataset: EV_ACClimaValeoPQ26 003001
ROD: EV_ACClimaValeoPQ26.rod
VCID: 74ECD128DF420E817A7-8021
329476 - Motor for Fresh Air / Recirculated Air Flap
B108B 71 [012] - Actuator stuck
Reset counter: 33
Mileage: 11 km
Date: 2015.03.03
Time: 09:13:44
1179905 - ROD - Unknown Error Code
- 00 [008]
Reset counter: 8
Mileage: 3032 km
Date: 2015.05.13
Time: 20:14:50
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 6C0 937 090 B HW: 6C0 937 090
Component: BCM PQ26 HiKR H07 0065
Serial number: 001108006926
Coding: 0C03085042150AFB43804000402F07080800D900D30A3500000000000000
Shop #: WSC 73430 790 00045
ASAM Dataset: EV_BCMA0 004008
ROD: EV_BCMA0_SK26.rod
VCID: 2756F6645E1435190F5-8072
Slave 2:
Subsystem 1 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A
Component: RLHS 037 0059
Serial number: S5Y15M01D28H17M24S34
Coding: 00185E
Subsystem 2 - Part No SW: 6V1 959 801 B HW: 6V1 959 801 B
Component: FHSG DRV 007 0001
Serial number: 00000000000000733403
Coding: 011200
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-283.clb
Part No SW: 5Q0 919 283 D HW: 5Q0 919 283
Component: PARKHILFE 3K H10 0048
Revision: -------- Serial number: 39231502402235
Coding: 0001050101
ASAM Dataset: EV_EPHVA14AU3700000 002022
ROD: EV_EPHVA14AU3700000_AU37.rod
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-572.clb
Part No SW: 5Q0 907 572 D HW: 5Q0 907 572 D
Serial number: 18121403212312
Coding: 00000800FE0739
ROD: EV_ACCMRRBoschVW372_AU37.rod
VCID: 3874251883AAAAE196F-806D
Address 15: Airbags (J234) Labels: 6C0-959-655.clb
Part No SW: 6C0 959 655 F HW: 6C0 959 655 F
Component: VW20Airbag023 001 0340
Revision: -------- Serial number: 003RJ000L0E+
Coding: 88CCC000000000005C5400CF000800000000
ROD: EV_AirbaVW20BPAVW26X_SK26.rod
VCID: 36682B2089BE5C91843-8063
Subsystem 1 - Part No SW: ----------- HW: 410 822 101 15
Component: SideSensor_Df 151 0800
Serial number: 3575H00C116DB7D0D0C/
Subsystem 2 - Part No SW: ----------- HW: 410 822 101 15
Component: SideSensor_Pf 151 0800
Serial number: 3585H00AF18F34B0C2B1
Subsystem 3 - Part No SW: ----------- HW: 442 152 501 15
Component: SideSensor_Dr 1CA 0148
Serial number: 3517A00A7183BFD540DU
Subsystem 4 - Part No SW: ----------- HW: 442 152 501 15
Component: SideSensor_Pr 1CA 0148
Serial number: 3527A00A7183BFD4543P
Address 17: Instruments (J285) Labels: None
Part No SW: 6V0 920 740 HW: 6V0 920 740
Component: KOMBI 214 0290
Coding: 072401102180000801882A011000000000000000
ROD: EV_DashBoardVDDMQBAB_SE25.rod
VCID: 72E0D730A55600B168B-8027
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 6C0 909 901 HW: 6C0 937 090
Component: GW MQB A0 H07 0065
Revision: -------- Serial number: 001108006926
Coding: 030100342F0A640000000000000000010001050000000000000000000000
ASAM Dataset: EV_GatewA0Lear 001001
ROD: EV_GatewA0Lear_SK26.rod
VCID: 65CABC6C6498E709FD9-8030
Subsystem 1 - Part No SW: 5E0 919 719 A HW: 5E0 919 719 A
Component: E221__MFL-PR6 H05 0130
Serial number: 000000000C0332230115
Subsystem 2 - Part No SW: 6C0 915 181 A HW: 6C0 915 181 A
Component: J367-BDM H08 0223
Serial number: 62016I56432821347447
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000004170002
Coding: 5500000000000000
ROD: EV_ELVMarquMQB_SE25.rod
VCID: 346C11289FC24E81BA7-8061
Address 44: Steering Assist (J792) Labels: Redir Fail!
Part No SW: 6C1 909 144 M HW: 6C1 909 144 D
Component: EPS_TRW_ALow 311 3211
Serial number: CF1Q0865
Coding: 0007
ASAM Dataset: EV_SteerAssisUDSTRW 011021
ROD: EV_SteerAssisUDSTRW_SK26.rod
VCID: 3260173065D640B1A8B-8067
Part No SW: 5Q0 035 819 HW: 5Q0 035 819
Component: MU-S--ER H11 0135
Serial number: SKZAZ2R0010231
Coding: 03620000BE00000011110004000808002F0100C40120010000
ASAM Dataset: EV_MUStd4CTSAT 001018
ROD: EV_MUStd4CTSAT_SK26.rod
VCID: 70E4DD38AB5A32A19EF-8025
Media Player Position 1:
Subsystem 1 - Part No SW: 6V0 919 604 HW: 6V0 919 604
Component: ABTm_Std2 H40 1022
Serial number: SKZ8Z9RH30067B
1637 - Interface for External Media
U11B8 00 [008] - No Communications
Fault Frequency: 91
Reset counter: 30
Mileage: 123 km
Date: 2015.03.11
Time: 19:53:14
Address 69: Trailer (J345) Labels: 5Q0-907-383.clb
Part No SW: 5Q0 907 383 E HW: 5Q0 907 383 B
Component: Anhaenger H14 0137
Revision: 8C001001 Serial number: 0358097400
Coding: 0100000202000000
ROD: EV_TrailFunctGener2Hella.rod
VCID: 3972201CB8A0B3E9691-806C
End-------------------------(Elapsed Time: 02:58)--------------------------
(19)-Leuchte27 KL58XS C67-Dimming_Direction_GH_27,maximize
(2)-Leuchte28RFL C3-Lampendefektbit_Position_28,2B
(3)-Leuchte28RFL C3-Fehlerort_mittleres_Byte_DTC-DFCC_28,34
(4)-Leuchte28RFL C3-Light_Function_A_28,Rueckfahrlicht
(5)-Leuchte28RFL C3-Light_Function_B_28,not active
(6)-Leuchte28RFL C3-Dimming_AB_28,100
(7)-Leuchte28RFL C3-Light_Control_HD_AB_28,Always
(8)-Leuchte28RFL C3-Light_Function_C_28,not active
(9)-Leuchte28RFL C3-Light_Function_D_28,not active
(10)-Leuchte28RFL C3-Dimming_CD_28,0
(11)-Leuchte28RFL C3-Dimming_Direction_CD_28,maximize
(12)-Leuchte28RFL C3-Light_Function_E_28,not active
(13)-Leuchte28RFL C3-Light_Function_F_28,not active
(14)-Leuchte28RFL C3-Dimming_EF_28,0
(15)-Leuchte28RFL C3-Dimming_Direction_EF_28,maximize
(16)-Leuchte28RFL C3-Light_Function_G_28,not active
(17)-Leuchte28RFL C3-Light_Function_H_28,not active
(18)-Leuchte28RFL C3-Dimming_GH_28,0
(19)-Leuchte28RFL C3-Dimming_Direction_GH_28,maximize
(1)-Leuchte29 KL30G A69-Type_Of_Load_29,allgemeineGluehlampe12W
(2)-Leuchte29 KL30G A69-Lampendefektbit_Position_29,00
(3)-Leuchte29 KL30G A69-Fehlerort_mittleres_Byte_DTC-DFCC_29,01
(4)-Leuchte29 KL30G A69-Light_Function_A_29,Klemme 30G
(5)-Leuchte29 KL30G A69-Light_Function_B_29,not active
(6)-Leuchte29 KL30G A69-Dimming_AB_29,100
(7)-Leuchte29 KL30G A69-Light_Control_HD_AB_29,Always
(8)-Leuchte29 KL30G A69-Light_Function_C_29,not active
(9)-Leuchte29 KL30G A69-Light_Function_D_29,not active
(10)-Leuchte29 KL30G A69-Dimming_CD_29,0
(11)-Leuchte29 KL30G A69-Dimming_Direction_CD_29,maximize
(12)-Leuchte29 KL30G A69-Light_Function_E_29,not active
(13)-Leuchte29 KL30G A69-Light_Function_F_29,not active
(14)-Leuchte29 KL30G A69-Dimming_EF_29,0
(15)-Leuchte29 KL30G A69-Dimming_Direction_EF_29,maximize
(16)-Leuchte29 KL30G A69-Light_Function_G_29,not active
(17)-Leuchte29 KL30G A69-Light_Function_H_29,not active
(18)-Leuchte29 KL30G A69-Dimming_GH_29,0
(19)-Leuchte29 KL30G A69-Dimming_Direction_GH_29,maximize
(1)-Leuchte2SL VLB22-Type_Of_Load_2,LED Tagfahrlichtmodul Signal
(2)-Leuchte2SL VLB22-Lampendefektbit_Position_2,48
