ABS, Steering Wheel, and Steering Angle Sensor Issues
DJM1450
Florida, USA
C?ID=430089
I just changed a broken Clock Spring. Hopefully, it was done correctly. I did obtain the code from the one and input the code after installing the new one. There is not no air bag light. The horn and steering wheel controls work. There are lights for the ABS Brakes, Steering Angle Sensor, and CEL. I tried the steering wheel procedure of turning the steering wheel left, right, left, right, center and driving slow straight, but it still stays on. Any help would be greatly appreciated. Here are the complete codes:
Tuesday,17,May,2022,10:48:47:10168
VIN: WVGBV7AXXFW563184   License Plate:
Chassis Type: AX-VW36 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 1C 22 25 2B 2E 42 44 46 4C 4F
          52 53 56 62 72 75 77
VIN: WVGBV7AXXFW563184   Mileage: 188820km-117327miles
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 06J 906 027 HE    HW: 06J 907 309 A
   Component: MED17.5.2 TFSI 2 07 8226
   Revision: P3H07---    Serial number:
   Coding: 0423010A190F0160
   VCID: 75B7EA1969C34D23EC9-8020
   VINID: 9E65D2987468A169C5183048105B64D78C
               P0300 - 000 -  - Intermittent - MIL ON
                    Fault Status: 10100000
                    Fault Frequency: 54
                    Mileage: 178183 km
                    Date: 2016.03.30
                    Time: 12:49:22
                    RPM: 711 /min
                    Load: 27.0 %
                    Temperature: 48.0°C
                    Temperature: 24.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 14.097 V
000769 - Cylinder 1
               P0301 - 000 - Misfire Detected - Intermittent - MIL ON
                    Fault Frequency: 52
                    Mileage: 178183 km
                    Date: 2016.03.30
                    Time: 12:49:22
                    RPM: 711 /min
                    Load: 27.0 %
                    Temperature: 48.0°C
                    Temperature: 24.0°C
                    Voltage: 14.097 V
000771 - Cylinder 3
               P0303 - 000 - Misfire Detected - Intermittent
                    Mileage: 187769 km
                    Date: 2016.09.20
                    Time: 08:34:01
                    RPM: 675 /min
                    Load: 27.0 %
                    Temperature: 58.0°C
                    Temperature: 27.0°C
                    Voltage: 14.097 V
000770 - Cylinder 2
               P0302 - 000 - Misfire Detected - Intermittent
                    Mileage: 188556 km
                    Date: 2016.10.03
                    Time: 09:08:50
                    RPM: 749 /min
                    Load: 33.3 %
                    Temperature: 42.0°C
                    Temperature: 25.0°C
                    Voltage: 14.097 V
005703 - Check Coding of ECUs on Powertrain Data Bus
               P1647 - 000 -  - Intermittent
                    Mileage: 188791 km
                    Date: 2016.10.06
                    Time: 00:06:09
                    RPM: 1177 /min
                    Load: 31.4 %
                    Temperature: 66.0°C
                    Temperature: 40.0°C
                    Voltage: 13.843 V
050217 - Implausible Data Received from Steering Column Control Module
               U0429 - 000 -  - Intermittent
                    Mileage: 188791 km
                    Date: 2016.10.06
                    Time: 00:10:34
                    RPM: 715 /min
                    Load: 18.0 %
                    Temperature: 90.0°C
                    Temperature: 39.0°C
                    Voltage: 13.970 V
   Part No SW: 09G 927 750 NK    HW: 09G 927 750 NK
   Component: AQ 250 6F           2627
   Revision: 00H97000    Serial number:
   Coding: 0000840
   Shop #: WSC 00736 003 1048576
   VCID: 074B90D1032F4FB38E5-8052
   Part No SW: 5N0 614 109 BN    HW: 5N0 614 109 BN
   Component: J104   C6 450M VD3A 0021
   Revision: --H07---    Serial number: 00000008617133
   Coding: 0005161
   VCID: 78A9E32D7ED1304BF7F-802C
02214 - Tire Pressure Warning
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Fault Frequency: 21
                    Reset counter: 58
                    Mileage: 188791 km
                    Date: 2016.10.06
                    Time: 00:09:22
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 14.00 V
                    Bin. Bits: 00011111
                    Count: 185
                    Hex Value: 0x0000
                    Fault Frequency: 21
                    Reset counter: 58
                    Mileage: 188791 km
                    Date: 2016.10.06
                    Time: 00:09:33
                    Hex Value: 0x0000
                    Voltage: 14.00 V
                    Bin. Bits: 00011110
                    Count: 191
                    Hex Value: 0x0000
                    Fault Frequency: 21
                    Reset counter: 58
                    Mileage: 188791 km
                    Date: 2016.10.06
                    Time: 00:09:33
   Part No SW: 5K0 959 434 E    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1202
   Revision: 00092000    Serial number: 0353897853
   Coding: 030C0C
   ROD: EV_KESSYPQ35G_A02_VW32.rod
   VCID: 372B20113FCFFF333E5-8062
   Part No SW: 561 907 426 J    HW: 561 907 426 J
   Component: AC Manuell    H02 0404
   Revision: 00001K01
   Coding: 0010001002
   ROD: EV_ACManuaElectGen2BHTC_VW36.rod
   VCID: 221DE145844D8A9BF9B-8076
   Part No SW: 5K0 937 086 R    HW: 5K0 937 086 R
   Component: BCM PQ35 M    122 0174
   Revision: BJ122001
   Coding: EF1A0A0B84232EC4018800C11000854448010086564D8DF064804000A040
   Shop #: WSC 33361 790 00999
   VCID: 43D344C17B97A39392D-8016
   Subsystem 1 - Part No SW: 5N1 955 119 B    HW: 5N1 955 119 B  Labels: 1KX-955-119.CLB
   Component: WWS316 041114  24  0664
   Coding: 009795
   Part No SW: 5N0 959 655 AD    HW: 5N0 959 655 AD
   Component: J234__207 VW10 HI   2418
   Revision: 29020000    Serial number: 003N4PQBX7Y.
   Coding: 0012343
   VCID: 7F5B08315BFF0773B65-802A
   Subsystem 1 - Part No: 5N0 959 339 B
   Subsystem 2 - Serial number: 0000000000M82K
   Subsystem 3 - Serial number: 0011.09.140000300000660065ÿ†63
   Subsystem 4 - Serial number: 660065ÿ†6332MTS6532830742ÿ†63
   Subsystem 5 - Serial number: 830742ÿ†6342MTS6517430742ÿ†63
   Subsystem 6 - Serial number: 430742ÿ†6351HTS6N3PH9DKRHÿ†63
   Subsystem 7 - Serial number: H9DKRHÿ†6361HTS6UDC4BDKRBÿ†63
   Subsystem 8 - Serial number: 4BDKRBÿ†63727TS62UVSDDKJTÿ†63
   Subsystem 9 - Serial number: SDDKJTÿ†63827TS6A9JNCDKR7ÿ
   Subsystem 10 - Serial number: NCDKR7ÿ
   Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
   Revision: --X01---    Serial number: 20210407100132
   Coding: 110A140000
   Shop #: WSC 01286 386 08256
   VCID: 025D81C5248D6A9BD9B-8056
   Serial number: 0690262
   Coding: 820000
147464 - Terminal 15
          B1148 29 [009] - Signal Implausible
                    Reset counter: 54
                    Mileage: 188791 km
                    Date: 2022.05.16
                    Time: 00:09:23
          B1149 13 [008] - Open Circuit
                    Reset counter: 95
                    Mileage: 188791 km
                    Date: 2022.05.16
                    Time: 00:09:23
1140738 - Steering angle sensor
                    Reset counter: 54
                    Mileage: 188791 km
                    Date: 2022.05.16
                    Time: 00:09:23
                    UBat: 14.10 V
                    MC1 interner Fehlercode: 0
                    MC2 interner Fehlercode: 0
   Part No SW: 5N0 920 973 H    HW: 5N0 920 973 H
   Component: KOMBI         H03 0905
   Coding: 211F01
   VCID: 392F262909DBE943C81-806C
   Part No SW: 7N0 907 530 AR    HW: 7N0 907 530 AM
   Component: J533  Gateway H55 1653
   Revision:   H55       Serial number: 241114F1001231
   Coding: 356002
   VCID: 00598BCD2A01788BCFF-8054
Address 1C: Position Sensing
   Part No SW: 0AY 907 554 J    HW: 0AY 907 554 J
   Component: Haldex4Motion H52 7522
   Serial number: HA1-00004.11.14
   Coding: 0001
   VCID: 52FD7185B46D3A1B29B-8006
   Component: IMMO          H03 0905
   Coding: 000007
   VCID: 6A8DC9653CFD92DB71B-803E
   Revision: 00000000    Serial number: 14000323798003
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 30391B0DDAA1280B7FF-8064
Address 2E: Media Player 3
   Part No SW: 5N0 959 701 F    HW: 3C0 959 793 B
   Component: TUER-SG FT    002 0503
   Revision: 13110009    Serial number: 0009286728
   Coding: 0004B4
   VCID: 3829232D32D1F04B37F-806C
   Slave Driver:
   Subsystem 1 - Part No SW: 5N0 959 703 G    HW: 3C0 959 794 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  009 1504
   Serial number: 00000009087911
   Coding: 000490
   Part No SW: 5N1 909 144 R    HW: 5N1 909 148 J
   Component: J500__APA-BS KL.286 1401
   Revision: 1BH04841    Serial number: 00143210046201
   Coding: 0000258
   VCID: 41DF4EC96D8BB183801-8014
02546 - Steering Limit Stop
                    Fault Status: 11100101
                    Reset counter: 58
                    (no units): 4.0
                    Voltage: 12.40 V
00566 - Steering Assistance Operation
            008 - Implausible Signal - MIL ON
                    Fault Status: 11101000
                    Reset counter: 54
                    Mileage: 188791 km
                    Date: 2016.10.06
                    Time: 00:09:21
                    Hex Value: 0x7301
                    Hex Value: 0x7601
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Reset counter: 58
                    Mileage: 188824 km
                    Date: 2016.10.07
                    Time: 10:45:47
                    (no units): 4.0
                    Steering Angle: 0.00°
                        Not OK
                    (no units): 1
   Component: EZE_2         H55 1653
   Coding: 050B0500
   VCID: 6FBBD871079F77F3265-803A
   Subsystem 1 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H03 0090
   Subsystem 2 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H03 0090
   Part No SW: 5N0 959 702 F    HW: 3C0 959 792 B
   Component: TUER-SG BT    002 0503
   Revision: 15110009    Serial number: 0009298136
   Coding: 0004B4
   Slave Passenger:
   Subsystem 1 - Part No SW: 5N0 959 704 G    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  009 1504
   Serial number: 00000009074409
   Coding: 000490
   Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
   Component: J540 EPB4  VW-63206 0012
   Revision:   H19       Serial number: 00000000417599
   Coding: 0026156
   VCID: 3829232D3E51F04B37F-806C
                    Fault Status: 01101100
                    Reset counter: 58
                    Voltage: 12.80 V
                    Count: 9
                    Hex Value: 0x0160
                    Hex Value: 0x0082
                    Hex Value: 0x0101
16353 - Control Module - Internal Malfunction
                    Fault Status: 00101110
                    Fault Frequency: 24
                    Reset counter: 97
                    Mileage: 188791 km
                    Date: 2016.10.06
                    Time: 00:13:56
                    Voltage: 14.00 V
                    Count: 111
                    Hex Value: 0x1270
                    Hex Value: 0x0001
                    Hex Value: 0x0101
16352 - Control Module - Electrical Error
                    Fault Frequency: 27
                    Reset counter: 97
                    Mileage: 188791 km
                    Date: 2016.10.06
                    Time: 00:26:60
                    Voltage: 12.20 V
                    Count: 40
                    Hex Value: 0x12F0
                    Hex Value: 0x0001
                    Hex Value: 0x0101
   Part No SW: 1K0 035 188 F    HW: 1K0 035 188 F
   Component: Radio Prem-8  H07 0009
   Revision: -----12S    Serial number: VWZ4Z7P3637869
   Coding: 0100044004000C
   VCID: 2B030C61F3074BD34AD-807E
                    Reset counter: 54
                    Mileage: 188791 km
                    Date: 2016.10.06
                    Time: 00:09:22
   Part No SW: 561 035 285 A    HW: 561 035 285 A
   Component: OCULowUSA     020 0156
   Serial number: 000003554140533
   Coding: 02130602C21632107F1606C20000
   ASAM Dataset: EV_OCULow 002009
   ROD: EV_OCULow_002_VW32.rod
   VCID: 1471B79D4EF9F42B7B7-8040
   Part No SW: 5N0 035 729 E    HW: 5N0 035 729 E
   Component: TELEFON       H07 0593
   Revision: 1B001001    Serial number: 00007666922647
   Coding: 0A10030080010110
   ROD: EV_UHVUMI.rod
   VCID: 323D1105D4AD1A1B09B-8066
End----------(Elapsed Time: 01:37, VBatt start/end: 13.8V/13.8V)-----------
EuroX
Northern NJ USA
C?ID=208579
Turn the wheel full lock to the left and check if youll hear a audible beep, if so then right it full lock to the right and if it beeps should be good to go.
Reactions: JMR
DJM1450
Florida, USA
C?ID=430089
Jeff Recommendati0n - Tried the procedure recommended 3 time, but light stayed on. The battery was 12.54 with car turned off.
Ziddy Recommendation - Tried the procedure 2 times, but light stayed on. Never heard a beep on the left or right side.
The steering wheel and wheels appear to be straight. What is the risk with the steering angle light being on? Is there a serious safety issue?
DJM1450
Florida, USA
C?ID=430089
I did another scan
Wednesday,18,May,2022,15:52:43:10168
                    Fault Frequency: 56
                    Mileage: 178183 km
                    Date: 2016.03.30
                    Time: 12:49:22
                    RPM: 711 /min
                    Load: 27.0 %
                    Temperature: 48.0°C
                    Temperature: 24.0°C
                    Voltage: 14.097 V
000769 - Cylinder 1
                    Fault Frequency: 54
                    Mileage: 178183 km
                    Date: 2016.03.30
                    Time: 12:49:22
                    RPM: 711 /min
                    Load: 27.0 %
                    Temperature: 48.0°C
                    Temperature: 24.0°C
                    Voltage: 14.097 V
000771 - Cylinder 3
                    Mileage: 187769 km
                    Date: 2016.09.20
                    Time: 08:34:01
                    RPM: 675 /min
                    Load: 27.0 %
                    Temperature: 58.0°C
                    Temperature: 27.0°C
                    Voltage: 14.097 V
000770 - Cylinder 2
                    Mileage: 188556 km
                    Date: 2016.10.03
                    Time: 09:08:50
                    RPM: 749 /min
                    Load: 33.3 %
                    Temperature: 42.0°C
                    Temperature: 25.0°C
                    Voltage: 14.097 V
                    Mileage: 188791 km
                    Date: 2016.10.06
                    Time: 00:06:09
                    RPM: 1177 /min
                    Load: 31.4 %
                    Temperature: 66.0°C
                    Temperature: 40.0°C
                    Voltage: 13.843 V
                    Mileage: 188791 km
                    Date: 2016.10.06
                    Time: 00:10:34
                    RPM: 715 /min
                    Load: 18.0 %
                    Temperature: 90.0°C
                    Temperature: 39.0°C
                    Voltage: 13.970 V
   Coding: 0000840
   Component: J104   C6 450M VD3C 0021
   Coding: 0005161
                    Fault Frequency: 41
                    Reset counter: 60
                    Mileage: 188791 km
                    Date: 2016.10.06
                    Time: 00:09:22
                    Hex Value: 0x0000
                    Voltage: 14.00 V
                    Bin. Bits: 00011111
                    Count: 185
                    Hex Value: 0x0000
                    Fault Frequency: 41
                    Reset counter: 60
                    Mileage: 188791 km
                    Date: 2016.10.06
                    Time: 00:09:33
                    Hex Value: 0x0000
                    Voltage: 14.00 V
                    Bin. Bits: 00011110
                    Count: 191
                    Hex Value: 0x0000
                    Fault Frequency: 41
                    Reset counter: 60
                    Mileage: 188791 km
                    Date: 2016.10.06
                    Time: 00:09:33
   Coding: 030C0C
   Revision: 00001K01
   Coding: 0010001002
   Revision: BJ122001
   Coding: 009795
   Coding: 0012343
   Coding: 110A140000
   Coding: 820000
                    Reset counter: 54
                    Mileage: 188791 km
                    Date: 2022.05.16
                    Time: 00:09:23
                    Reset counter: 95
                    Mileage: 188791 km
                    Date: 2022.05.16
                    Time: 00:09:23
                    Reset counter: 54
                    Mileage: 188791 km
                    Date: 2022.05.16
                    Time: 00:09:23
                    UBat: 14.10 V
   Coding: 211F01
   Coding: 356002
   Coding: 0001
   Coding: 000007
   Coding: 0004B4
   Slave Driver:
   Coding: 000490
   Coding: 0000258
                    Reset counter: 60
                    (no units): 4.0
                    Voltage: 12.40 V
                    Reset counter: 54
                    Mileage: 188791 km
                    Date: 2016.10.06
                    Time: 00:09:21
                    Hex Value: 0x7301
                    Hex Value: 0x7601
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Reset counter: 60
                    Mileage: 188828 km
                    Date: 2016.10.08
                    Time: 15:50:12
                    (no units): 4.0
                        Not OK
                    (no units): 14
   Coding: 050B0500
   Coding: 0004B4
   Slave Passenger:
   Coding: 000490
   Coding: 0026156
                    Reset counter: 60
                    Voltage: 12.80 V
                    Count: 9
                    Hex Value: 0x0160
                    Hex Value: 0x0082
                    Hex Value: 0x0101
                    Fault Frequency: 24
                    Reset counter: 97
                    Mileage: 188791 km
                    Date: 2016.10.06
                    Time: 00:13:56
                    Voltage: 14.00 V
                    Count: 111
                    Hex Value: 0x1270
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Fault Frequency: 27
                    Reset counter: 97
                    Mileage: 188791 km
                    Date: 2016.10.06
                    Time: 00:26:60
                    Voltage: 12.20 V
                    Count: 40
                    Hex Value: 0x12F0
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Reset counter: 59
                    Mileage: 188791 km
                    Date: 2016.10.06
                    Time: 00:09:22
   ROD: EV_UHVUMI.rod
End----------(Elapsed Time: 01:36, VBatt start/end: 13.9V/13.8V)-----------
JMR
Romania
C?ID=432218
try and drive straight for few meters and then redo the BS on G85. Also , to wake up the G85 , ( i did this once on a Skoda ) turned the steering to the right and then to the left about 90 degrees , put it straight , drove about 20 meters and then recalibrate g85.
I did another scan
Have you looked at the values from the steering angle sensor? Is it close to 0 degrees with the front wheels pointed straight ahead and the steering wheel centered? Do the values change when you turn the wheel? The should increase when the wheel is turned one direction and dcrease (go negative) when it's turned the other direction.
DJM1450
Florida, USA
C?ID=430089
No Uwe, I have not checked the steering angle sensor values. Is there a procedure to check the values? This is the first vehicle that I am using the Ross-Tech scan tool.
DJM1450
Florida, USA
C?ID=430089
Thanks JMR for the recommendation. Unfortunately I am not able to try it now because my daughter came and picked up her car. She will bring it back in a couple of weeks for me to change out the parking brake switch.
Do you have a scan from before you changed the control unit?
MVB 004 field 1 in the ABS module should have the real-time value from the steering angle sensor.
The 16-Steeing wheel module (UDS protocol) should have it under Advanced Measuring Values as:
MAS00815-IDE00326 -- Steering angle sensor - Steering wheel angle
And lastly, the 44-Steering Assist module should have it in MVB 006 field 2.
The behavior in all of them should match what I described.
DJM1450
Florida, USA
C?ID=430089
Crasher - I did scan before the clock spring was changed. However, I did not save it. I was only concerned about getting the clock spring code.
Uwe - Thanks for the info. I'm going to spend some time educating myself on the features of the VCDS scanner. It came with no manual.
Check your computers C drive , it is Saved automatically !
DJM1450
Florida, USA
C?ID=430089
Here is the scan prior to removing the clock spring.
VIN: WVGBV7AXXFW563184   Mileage: 188790km-117308miles
                    Fault Frequency: 53
                    Mileage: 178183 km
                    Date: 2016.03.30
                    Time: 12:49:22
                    RPM: 711 /min
                    Load: 27.0 %
                    Temperature: 48.0°C
                    Temperature: 24.0°C
                    Voltage: 14.097 V
000769 - Cylinder 1
                    Fault Frequency: 51
                    Mileage: 178183 km
                    Date: 2016.03.30
                    Time: 12:49:22
                    RPM: 711 /min
                    Load: 27.0 %
                    Temperature: 48.0°C
                    Temperature: 24.0°C
                    Voltage: 14.097 V
               U1017 - 000 -  - Intermittent
                    Mileage: 187336 km
                    Date: 2016.09.12
                    Time: 15:26:51
                    RPM: 681 /min
                    Load: 28.2 %
                    Temperature: 47.0°C
                    Temperature: 30.0°C
                    Voltage: 13.970 V
000771 - Cylinder 3
               P0303 - 000 - Misfire Detected - Intermittent - MIL ON
                    Mileage: 187769 km
                    Date: 2016.09.20
                    Time: 08:34:01
                    RPM: 675 /min
                    Load: 27.0 %
                    Temperature: 58.0°C
                    Temperature: 27.0°C
                    Voltage: 14.097 V
000770 - Cylinder 2
                    Mileage: 188556 km
                    Date: 2016.10.03
                    Time: 09:08:50
                    RPM: 749 /min
                    Load: 33.3 %
                    Temperature: 42.0°C
                    Temperature: 25.0°C
                    Voltage: 14.097 V
   Coding: 0000840
   Component: J104   C6 450M VD34 0021
   Coding: 0005161
                    Reset counter: 52
                    Mileage: 137941 km
                    Date: 2020.08.04
                    Time: 21:34:43
                    Speed: 85.0 km/h
                    Hex Value: 0x0000
                    Voltage: 13.75 V
                    Bin. Bits: 00011111
                    Count: 185
                    Hex Value: 0x0000
                    Fault Status: 00101100
                    Reset counter: 55
                    Mileage: 187336 km
                    Date: 2016.09.12
                    Time: 15:26:51
                    Hex Value: 0x0000
                    Voltage: 14.00 V
                    Bin. Bits: 00011111
                    Count: 15
                    Hex Value: 0x0000
                    Reset counter: 55
                    Mileage: 187336 km
                    Date: 2016.09.12
                    Time: 15:27:01
                    Speed: 8.0 km/h
                    Hex Value: 0x0000
                    Voltage: 14.00 V
                    Bin. Bits: 00011111
                    Count: 191
                    Hex Value: 0x0000
   Coding: 030C0C
   Revision: 00001K01
   Coding: 0010001002
   Revision: BJ122001
   Coding: 009795
   Coding: 0012343
03551 - Functional Restriction of Seat Occupied Recognition
            000 - - - Intermittent - MIL ON
                    Fault Frequency: 45
                    Mileage: 169196 km
                    Date: 2015.11.25
                    Time: 13:33:03
                    Fault Status: 11100001
                    Mileage: 131981 km
                    Date: 2020.05.23
                    Time: 09:44:03
   Part No SW: 5K0 953 501 DM    HW: 5K0 953 569 AP
   Component: LENKS.MODUL   016 0162
   Revision: FF010042    Serial number: 20141201300337
   Coding: 110A140000
   VCID: 78A9E32D7251304BF7F-802C
365080 - Controls in Steering Wheel
          U108E 00 [009] - No Communications
                    Reset counter: 93
                    Mileage: 131981 km
                    Date: 2020.05.23
                    Time: 09:57:04
   Coding: 211F01
   Coding: 356002
   Coding: 0001
16656 - Databus
          [Bremsensteuergerät - no speed signal]
                    Reset counter: 55
                    Mileage: 187336 km
                    Date: 2022.04.22
                    Time: 15:26:49
   Coding: 000007
   Coding: 0004B4
   Slave Driver:
   Coding: 000490
66304 - Switch for Drivers Side Window Regulator
          B11F0 29 [008] - Signal Implausible
                    Reset counter: 59
                    Mileage: 187681 km
                    Date: 2022.04.28
                    Time: 16:50:49
   Coding: 0000258
                    Fault Status: 00101101
                    Reset counter: 55
                    Mileage: 187336 km
                    Date: 2016.09.12
                    Time: 15:26:51
                    RPM: 1153 /min
                    (no units): 7.0
                    Voltage: 14.10 V
   Coding: 050B0500
   Coding: 0004B4
   Slave Passenger:
   Coding: 000490
   Coding: 0026156
                    Reset counter: 52
                    Voltage: 12.80 V
                    Count: 9
                    Hex Value: 0x0160
                    Hex Value: 0x0082
                    Hex Value: 0x0101
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 52
                    Voltage: 12.80 V
                    Count: 40
                    Hex Value: 0x0870
                    Hex Value: 0x0088
                    Hex Value: 0x0101
            014 - Defective
                    Reset counter: 52
                    Voltage: 12.80 V
                    Count: 111
                    Hex Value: 0x0870
                    Hex Value: 0x0088
                    Hex Value: 0x0101
                    Reset counter: 65
                    Mileage: 182671 km
                    Date: 2016.06.10
                    Time: 15:10:06
                    Voltage: 8.10 V
                    Count: 48
                    Hex Value: 0x1270
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Reset counter: 55
                    Mileage: 187336 km
                    Date: 2016.09.12
                    Time: 15:26:51
                    Voltage: 14.10 V
                    Count: 105
                    Hex Value: 0x12F0
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Fault Frequency: 67
                    Reset counter: 6
                    Mileage: 129859 km
                    Date: 2020.04.18
                    Time: 18:24:23
   ROD: EV_UHVUMI.rod
End----------(Elapsed Time: 01:42, VBatt start/end: 14.0V/14.0V)-----[\code]
Thanks for the old scan. I'm late to this thread but I have some comments.
The 16 module coding of 110A140000 appears to be correct and the 5K0-953-569-AP to 5K0-953-569-AL replacement appears to be installed.
What does not appear to be normal are the following (new) codes:
I doubt fuse SB11 could be blown but those under-hood panels are noted for having melt-downs that cause voltage drops. I would check that panel and nearby wiring to make sure there isn't an unrelated (pre-existing) problem brewing under the hood on the power distribution level.
Excellent, that is what I was probing for but as Dana says, the initial read you added showed 5K0 953 501 DM and the post work read 5K0 953 569 AL, the parts systems I have access to don’t tell me if this is correct, it seems to be only the main dealer who can see what to use based on what is fitted so how did you come about using 5K0 953 569 AL as according to the only system I have at home, Partslink 24, 5K0 953 569 AL is for cars up to 18.06.12 and your car was built 10.12.14, unhelpfully PL24 and ETKA gives zero information on the later numbers which is just about unique in my experience.
  • Informative
DJM1450
Florida, USA
C?ID=430089
I got the part number and part from the VW dealer based on my VIN. The part removed is 5K0-953-569-AP. I have been the 2nd owner for about 4 years. Maybe, the original clock spring was 501-DM and was changed to 569-AP.
If I get time I will run it past our parts people tomorrow using the info you posted in #16.
