I have a 2001 VW New Beetle. Recently it threw an EPC light and MIL with error codes for the Throttle Position Sensor so I replaced the accelerator pedal assembly with a Hella unit. (It's drive by wire rather than cable if that matters.)
Since then I have this unclearable error:
It seems to want a throttle body adaptation, but I can't do it without clearing this code. Every time I clear codes, it comes back. I even tried disconnecting the battery for 30 minutes, to no avail.
Driving the car for a bit results in Throttle Position Sensor error codes, and eventually it goes into "limp" mode under which it has next to no power.
Car was in a collision at the beginning of March, but I got it back from the body shop about a month ago and I'd been driving it around with no signs that anything was amiss.
Any suggestions here before I throw in the towel and take it to a repair shop? Thanks.
Auto Scan:
17987 - Throttle Actuator (J338)
P1579 - 35-00 - Adaptation Not Started
Auto Scan:
Monday,16,May,2022,18:01:07:10877
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VirtualBox)
VCDS Version 22.3.1.4 (x64) HEX-V2 CB: 0.4615.4
Mileage: 231050km-143567mi Repair Order:
Chassis Type: 1C - VW New Beetle (1998 > 2010)
Scan: 01 02 03 08 15 17 19 25 29 35 37 39 46 54 56 65 75
Mileage: 231050km-143567miles
Address 01: Engine Labels: 06A-906-032-AVH.lbl
Part No: 06A 906 032 BS
Component: 2.0l R4/2V G *3655
Coding: 00003
Shop #: WSC 00066
VCID: 70B92E7093B1B45B3FF-5161
Readiness: 0110 1101
Address 02: Auto Trans Labels: 01M-927-733.lbl
Part No: 01M 927 733 JF
Component: AG4 Getriebe 01M 4719
Coding: 00000
VCID: 7DA70744D4E3C933A49-0963
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.clb
Part No: 1J0 907 379 P
Component: ABS 20 IE CAN 0001
Coding: 03504
Shop #: WSC 00066
VCID: 3E25C0489965122BFD3-4B1F
Part No: 6Q0 909 605 A
Component: 16 AIRBAG VW5 0D 0004
Coding: 12598
Shop #: WSC 00066
VCID: 3537DF64AC53D1732C9-4B3D
01221 - Crash Sensor Side Airbag; Driver Side (G179)
37-00 - Faulty
Address 17: Instruments Labels: 1C0-920-xx0.lbl
Part No: 1C0 920 901 X
Component: KOMBI+WEGFAHRS. M73 V07
Coding: 03202
Shop #: WSC 09141
VCID: 313FEB74583BFD53701-4B1F
Subsystem 1 - Part No: Ident
Component: Nr. Wegfahrs.:VWZ5Z0B2142050
Ident.-Nr. Wegfahrs.:VWZ5Z0B2142050
Address 19: CAN Gateway Labels: 6N0-909-901-19.clb
Part No: 6N0 909 901
Component: Gateway K<->CAN V072
Coding: 00007
Shop #: WSC 09141
VCID: 70B92E7093B1B45B3FF-4B1F
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AJ
Component: 5X Zentral-SG Komf. 0001
Coding: 00257
Shop #: WSC 00066
VCID: 065568A881358AEBF53-4B1F
Subsystem 1 - Part No: 1J2959802C
Component: 5X Tõrsteuerger. FS0002r
Subsystem 2 - Part No: 1J2959801D
Component: 5X Tõrsteuerger. BF0002r
00953 - Interior Light Time limit
25-10 - Unknown Switch Condition - Intermittent
End----------(Elapsed Time: 03:39, VBatt start/end: 12.1V/12.1V)-----------
