2015 Passat - 13: Auto Dist. Reg ACC - 1229 - Control Module Incorrectly Coded
golfather
London, UK
C?ID=104745
Hey chaps
VW Passat 2015
We are having problems with his factory ACC not working
Customer has messed about a bit with the car previously, with an Ali Express dash etc.
However original dash now reinserted and ACC still not working
Have used ODIS online to reinstate the original Coding for ACC, and Instruments. So i know they are now factory spec.
What else do you chaps think that may be affecting the coding to be out for the ACC?
Engine? Can? Radio?
Wednesday,11,May,2022,19:30:57:51070
VCDS Version: 22.3.1.1 (x64)  HEX-V2 CB: 0.4615.4
Data version: 20220401 DS337.0
VIN: WVWZZZ3CZGE086869   License Plate:
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 5F 69
VIN: WVWZZZ3CZGE086869   Mileage: 254968km-158429miles
Address 01: Engine (J623-CRLB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 ES    HW: 04L 907 309 R
   Component: R4 2,0L EDC   H22 1342
   Revision: B5H22---    CVN: 9D8A4204
   Coding: 0119001203551D083000
   Shop #: WSC 05311 115 00304
   ASAM Dataset: EV_ECM20TDI01104L906026ES 002001
   ROD: EV_ECM20TDI01104L906026FK.rod
   VCID: 7F5AF3D257710B13B60-802A
   VINID: 9E69EAAAA0D3A97540206206248B290E04
17156 - Databus
          U1123 00 [047] - Received Error Message
                    Fault Frequency: 47
                    Mileage: 253862 km
                    Date: 2022.05.03
                    Time: 16:40:23
                    Engine RPM: 0.00 /min
                    Coolant temperature: 39 °C
                    Intake air temperature: 37 °C
                    Voltage terminal 30: 13.160 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 0
                    Acceleration: 0.000 m/s²
   Part No SW: 3Q0 907 379 AF    HW: 3Q0 907 379 F
   Component: ESC           H42 0625
   Revision: 00000000    Serial number: 92565000000021
   Coding: 0FEC928F34280B72077F060641CC49F0492CD0E0608292F11460F078C002
   ROD: EV_Brake1UDSContiMK100IPB_034_VW48.rod
   VCID: 7EA40ED6507B021BBD6-802A
   Part No SW: 3Q0 959 435 B    HW: 3Q0 959 435 B
   Component: VWKESSYMQB    026 0710
   Revision: 00026000    Serial number: 0381381882
   Coding: 000F1F0603
   Shop #: WSC 12345 123 61029
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 392EDDCA09D5E523C84-806C
65794 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [Function restriction due to temp low voltage]
                    Reset counter: 160
                    Mileage: 253911 km
                    Date: 2022.05.04
                    Time: 14:27:24
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: 5TD 907 044 E    HW: 5TD 907 044 E
   Component: Climatronic   H04 1603
   Revision: 00001K01
   Coding: 00020004200010010004004000101000
   ASAM Dataset: EV_ACClimaBHBVW37X 006140
   VCID: 4ACC92065C337EBB51E-801E
13 Faults Found:
65543 - No Basic Setting
          B2010 00 [009] - -
          [Grundeinstellung - nicht durchgeführt]
                    Reset counter: 102
                    Mileage: 253862 km
                    Date: 2022.05.03
                    Time: 16:40:24
328199 - Position Sensor for Right Temperature Flap Motor
          B1095 15 [009] - Open or Short to Plus
                    Fault Frequency: 192
                    Reset counter: 121
                    Mileage: 253862 km
                    Date: 2022.05.03
                    Time: 16:40:25
                    Voltage terminal 30: 12.9 V
                    Outside temperature: 15.0 °C
                    Inside temperature: 25.0 °C
                    Right temperature flap: actual value: 0.0 %
                    Right temperature flap: actual value: 15
                    Temperature door right - Specified value: 15
328455 - Position Sensor for Rear Temperature Flap Motor
          B1096 15 [009] - Open or Short to Plus
                    Reset counter: 102
                    Mileage: 253862 km
                    Date: 2022.05.03
                    Time: 16:40:24
                    Rear temperature flap: actual value: 15
                    Rear temperature flap: actual value: 0.0 %
                    Rear temperature flap: specified value: 15
329991 - Position Sensor for Defrost Flap Motor
          B1098 15 [009] - Open or Short to Plus
                    Reset counter: 121
                    Mileage: 253862 km
                    Date: 2022.05.03
                    Time: 16:40:24
                    Defroster flap: actual value: 138
                    Defroster flap: actual value: 65.5 %
                    Defrost door - Specified value: 156
329479 - Position Sensor for Fresh/Recirculated Flap Motor
          B109B 15 [009] - Open or Short to Plus
                    Reset counter: 102
                    Mileage: 253862 km
                    Date: 2022.05.03
                    Time: 16:40:25
                    Actual value for fresh air/recirculation air flow flap: 0.0 %
                    Actual value for fresh air/recirculation air flow flap: 78
                    Fresh air/recirculating air/back pressure door specified value: 78
197122 - Temperature Sensor for Left Vent
          B1087 15 [009] - Open or Short to Plus
                    Reset counter: 102
                    Mileage: 253862 km
                    Date: 2022.05.03
                    Time: 16:40:24
197378 - Temperature Sensor for Right Vent
          B1088 15 [009] - Open or Short to Plus
                    Reset counter: 102
                    Mileage: 253862 km
                    Date: 2022.05.03
                    Time: 16:40:24
197634 - Temperature Sensor for Rear Vent
          B1089 15 [009] - Open or Short to Plus
                    Reset counter: 102
                    Mileage: 253862 km
                    Date: 2022.05.03
                    Time: 16:40:24
196866 - Temperature Sensor for Footwell Vent
          B1085 15 [009] - Open or Short to Plus
                    Reset counter: 102
                    Mileage: 253862 km
                    Date: 2022.05.03
                    Time: 16:40:24
459015 - Databus
          [Feuchtesensor innen - kein Signal/Kommunikation]
                    Reset counter: 102
                    Mileage: 253862 km
                    Date: 2022.05.03
                    Time: 16:40:24
262402 - Sunlight Photo Sensor
          B10E8 15 [009] - Open or Short to Plus
                    Reset counter: 121
                    Mileage: 253862 km
                    Date: 2022.05.03
                    Time: 16:40:24
262404 - Sunlight Photo Sensor
                    Reset counter: 121
                    Mileage: 253862 km
                    Date: 2022.05.03
                    Time: 16:40:24
524545 - AC Compressor First Run-In
          B109E F0 [009] - Not Performed
                    Reset counter: 102
                    Mileage: 253862 km
                    Date: 2022.05.03
                    Time: 16:40:24
   Part No SW: 5Q0 937 086 AH    HW: 5Q0 937 086 AH
   Revision: --------    Serial number: 86580509152171
   Coding: 03030842C2C1027F0FA44094B10407281880000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 0058702E2A8F74EBCFA-8054
   Subsystem 1 - Part No SW: 3G2 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    150728  043 0607
   Serial number:         150901184247
   Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
   Component: RLS  037 0059
   Serial number: S3Y15M09D17H12M34S45
   Coding: 96A8DD
   Subsystem 3 - Part No SW: 3G0 941 633     HW: 3G0 941 633
   Serial number: 06 06 2015  10000192
   Subsystem 4 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  006 0326
   Serial number: 000000000ZY1521604M1
   Serial number: 00000000000063661958
   Part No SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0056
   Revision: --------    Serial number: 39391526005544
   Coding: 0071051901
   VCID: 44D0BC3E7E17A8CBAB2-8010
   Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
   Coding: 2A00608251FFC428949C804D
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 3430ECFE2EB7184B1B2-8060
          U1014 00 [009] - -
          [FAULT_CODING_AAG]
                    Reset counter: 102
                    Mileage: 253862 km
                    Date: 2022.05.03
                    Time: 16:40:24
                    Control Module temperature: 36 °C
                    Voltage terminal 15: 12.9 V
0836 - Databus
          [FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
                    Reset counter: 157
                    Mileage: 253862 km
                    Date: 2022.05.03
                    Time: 17:06:18
                    Control Module temperature: 26 °C
                    Voltage terminal 15: 11.9 V
   Part No SW: 3Q0 959 655 BA    HW: 3Q0 959 655 BA
   Component: Airbag VW20   013 0195
   Revision: --------    Serial number: 003SSPJYZV8$
   Coding: 98FCC0C0000000005C5400CC008800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X.rod
   Left seat belt tensioner:
   Serial number: 3G2857705E0271P00044
   Coding: 80000D
   Right seat belt tensioner:
   Serial number: 3G2857706E0271P00697
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 454 000 609 15
   Serial number: 3576U000000A01596613
   Subsystem 4 - Part No SW: -----------    HW: 454 000 609 15
   Serial number: 3586U00000005159661%
   Subsystem 5 - Part No SW: -----------    HW: 454 801 309 15
   Serial number: 3516R4D6F4808000000E
   Subsystem 6 - Part No SW: -----------    HW: 454 800 909 15
   Serial number: 3526R781D61080000001
   Subsystem 7 - Part No SW: -----------    HW: 454 800 109 15
   Serial number: 3556V20D33D080000006
   Part No SW: 3Q0 953 521 P    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0195
   Revision: FF033033    Serial number: 20150923501341
   Coding: 0400
   Shop #: WSC 00015 115 00001
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3D26C9DA1DFDD903E4C-8068
   Part No SW: 3G0 920 941 A    HW: 3G0 920 941 A
   Component: KOMBI         201 6421
   Coding: 27A409102780260001886B011000000000000000
   VCID: 24101CBE9E5788CB8B2-8070
10485828 - Internal Control Module Memory Check Sum Error
          B2000 41 [009] - General Checksum Failure
          [Steuergerät defekt (Fehler durch Selbsttest entdeckt)]
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2227
   Revision: --------    Serial number: 23091510800088
   Coding: 030300045F087300FB00005C080F00010001070000000000000000000000
   GVL: 01543C0000000600C00C80000000480000000000000000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 75B611FA654D4143ECC-8020
   Generator:
   Component: E221__MFL-DC1  H16 0040
   Serial number: 29150001902580095392
   Coding: 2CFFFF
   Serial number: 6280177503
   Analog clock:
   Subsystem 4 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  209 2002
66052 - Infotainment CAN Bus (SAE Bus E)
          U0065 00 [008] - Performance
          [Globaler Timeout CAN-Infotainment]
                    Reset counter: 159
                    Mileage: 254839 km
                    Date: 2022.05.10
                    Time: 18:49:56
                    Terminal 30 power supply: 12.2 V
                    Terminal 15: OFF
65796 - Infotainment CAN in One-Wire Mode
          U0072 00 [009] - -
          [Eindrahtfehler CAN-Infotainment]
                    Fault Frequency: 46
                    Reset counter: 121
                    Mileage: 253862 km
                    Date: 2022.05.03
                    Time: 16:40:24
                    Terminal 30 power supply: 13.1 V
                    Terminal 15: On
   Serial number: 15000082012012
   Coding: 0000000000000000
   Shop #: WSC 00015 115 08193
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BE25EA11256D63304-8024
   Serial number: 150915BIE12966
   Coding: 00350A20D001028000001000
   VCID: 43D2BF227B19AFF3928-8016
   Subsystem 1 - Part No SW: 5Q4 959 811 E    HW: 5Q4 959 811 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000002247619
   Coding: 0D0000
   Part No SW: 5Q0 909 144 S    HW: 5Q0 909 144 R
   Component: EPS_MQB_ZFLS  125 1063
   Coding: 8103
   Shop #: WSC 00015 115 00304
   Serial number: 110915BIA06899
   Coding: 00350020DC01028000001000
   VCID: 42DCBA266403A6FB99E-8016
   Subsystem 1 - Part No SW: 5Q4 959 812 E    HW: 5Q4 959 812 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000002263071
   Coding: 050000
   Part No SW: 3Q0 035 874 A    HW: 3Q0 035 874 A
   Component: MU-S-ND-ER    820 0633
   Coding: 02840201FF00000051111101008808001F0204C601200100CF
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 3038E0EEDAAF246B7FA-8064
   Subsystem 1 - Part No SW: 3G0 919 605 D    HW: 3G0 919 605 D
   Component: ABT_Std-2_Nav  H52 1031
   Serial number: VWZ8Z9REN00MVT
   Subsystem 2 - Part No SW: 3G0 919 866 H    HW: -----------
   Component: ECE 2015/16  --- 0430
   Part No SW: 5Q0 907 383 E    HW: 5Q0 907 383 B
   Component: ConWysTrailer H14 0137
   Serial number: 00000181563668
   Coding: 0100000200000000
End----(Elapsed Time: 01:37, VBatt start/end: 11.9V/11.8V. VIgn 11.8V)-----
I think the ACC radar isn't coded for the trailer module that this car has, and was presumably a retrofit that VW's servers don't know about. Byte 3, Bit 3.
partsaut
Poland
C?ID=513023
why dont you restore all modules using Odis ?
golfather
London, UK
C?ID=104745
Great info! Yes indeed the tow hitch was retrofitted by the previous owner. VW coding wasnt working, change byte as advised and now ACC fault codes gone!
Thanks all!
I think he did that, but it will not work correctly if the car has modules that the VAG server doesn't think it "should" have.
