;SW:0CT-927-750-A HW:0CT-927-750-A --- Auto Trans
;Component:SQ100 H10 0013, Coding:000120
;EV_TCMSQ101011,004010,EV_TCMSQ101011_004.
;Monday,30,May,2022,11:53:52:12676
; Version: Release 22.3.1 (x64) Data version: 20220407 DS337.0
;VCID: 46D557E7D824F57BB53-8012
Group,Description,Actual
IDE00021-ENG98542,Engine RPM-Engine speed,0, /min
IDE00022-ENG121494,Transmission input speed-Inputshaft speed,0, /min
IDE00023,Transmission output speed,0, /min
IDE00025-ENG124656,Coolant temperature-Param to DOP_94674,15, °C
IDE00086-ENG121516,Accelerator pedal position-Accelerator pedal,0, %
IDE00090-ENG121515,selected gear-TEXT TABLE: GEAR,invalid,
IDE00100,Engine torque,-23, Nm
IDE00102-ENG121529,Control Module temperature-Temperature CPU,32.00, °C
IDE00144-ENG121500,Transmission status-CLEARANCE PHASE,not active,
IDE00144-ENG121502,Transmission status-DISENGAGE PHASE,not active,
IDE00144-ENG98540,Transmission status-engaged,not active,
IDE00144-ENG121507,Transmission status-ENGAGING PHASE,not active,
IDE00144-ENG112322,Transmission status-General Error,not active,
IDE00144-ENG121498,Transmission status-Initialisation of gearbox mode is active,active,
IDE00144-ENG121505,Transmission status-MAIN SYNCHRONIZE PHASE,not active,
IDE00144-ENG121510,Transmission status-MECANICAL BLOCKER,not active,
IDE00144-ENG121497,Transmission status-NO SHIFT MANAGER DISABLED,active,
IDE00144-ENG121504,Transmission status-PRE SYNCHRONIZE PHASE,not active,
IDE00144-ENG121501,Transmission status-PRELOAD PHASE,not active,
IDE00144-ENG121499,Transmission status-PREPARING PHASE,not active,
IDE00144-ENG121509,Transmission status-PUSHOUT PHASE,not active,
IDE00144-ENG121508,Transmission status-REBOUND PHASE,not active,
IDE00144-ENG121511,Transmission status-REQUEST DOUBLE CLUTCHING,not active,
IDE00144-ENG121503,Transmission status-SELECT PHASE,not active,
IDE00144-ENG121496,Transmission status-Shifting acitve,not active,
IDE00144-ENG121506,Transmission status-SYNCHRONIZE READY,not active,
IDE00145-ENG99141,Clutch status-Clutch State,closed,
IDE00920-ENG99010,Front left wheel speed-Vehicle speed,0, km/h
IDE00921-ENG99010,Wheel speed: right front-Vehicle speed,0, km/h
IDE00922-ENG99010,Left rear wheel speed-Vehicle speed,0, km/h
IDE00923-ENG99010,Right rear wheel speed-Vehicle speed,0, km/h
IDE01834,Battery voltage,13.45, V
IDE02298-ENG121493,Adaptation of clutch kiss points-Clutch position,616, INK
IDE02792-ENG121495,Specified position clutch 1-Param to DOP_44308,1000, INK
IDE02793-ENG121495,Actual position clutch 1-Param to DOP_44308,1010, INK
IDE02794-ENG121512,Actual position clutch 1 duty cycle factor 1-Duity cycle,0, %
IDE02823-ENG125574,Identification of selector lever-Identifikation Wahlhebel,1S0 7133 025 S11 SCHALTBETAET. VOLL.,
IDE03393-ENG121518,Selector lever position-Gear lever input signal,Malfunction,
IDE05228-ENG123377,Operating hour counter-Betriebstundenzähler,4197.28, H
IDE05402-ENG121492,Driving mode-Text Tabel: Drivng Situation,KEINE_SYSTEMFREIGABE,
IDE06087-ENG121514,Excess temperature counter-Param to DOP_64079,0,
IDE06448-ENG100569,Gear selector: gear 1: end position-Shift Position,728, INK
IDE06454-ENG100569,Gear selector: gear 2: end position-Shift Position,1263, INK
IDE06460-ENG100569,Gear selector: gear 3: end position-Shift Position,727, INK
IDE06466-ENG100569,Gear selector: gear 4: end position-Shift Position,1265, INK
IDE06472-ENG100569,Gear selector: gear 5: end position-Shift Position,727, INK
IDE06490-ENG100569,Gear selector: gear R: end position-Shift Position,1308, INK
IDE06882-ENG121495,Trans. fluid temp. model value-Param to DOP_44308,16.0, °C
IDE08291-ENG121493,Clutch position in opened up state-Clutch position,448, INK
IDE08292-ENG121493,Clutch position in engaged state-Clutch position,1025, INK
IDE08293-ENG121512,Maximum allowed value-Duity cycle,100, %
IDE08294-ENG121513,Counter engage procedures-Param to DOP_19153,732775,
IDE08295-ENG123375,Duration overtemperature state clutch-Param to DOP_08916,0.0, min
IDE08296-ENG121515,Target gear-TEXT TABLE: GEAR,invalid,
IDE08297-ENG99010,Vehicle speed unpowered axle-Vehicle speed,0, km/h
IDE08298-ENG121517,Reset Status-Param to DOP_74796,0,
IDE08299-ENG121519,Clutch excess temperature class-Clutch protection,---,
IDE08300-ENG121512,Current duty cycle engine 2-Duity cycle,0, %
IDE08301-ENG121512,Current duty cycle engine 1-Duity cycle,0, %
IDE08302-ENG121520,Maximum value energy input through clutch friction-Param to DOP_34971,0,
IDE08303-ENG125567,Currently closed gear-Gang_1_gesperrt,not active,
IDE08303-ENG125568,Currently closed gear-Gang_2_gesperrt,not active,
IDE08303-ENG125569,Currently closed gear-Gang_3_gesperrt,not active,
IDE08303-ENG125570,Currently closed gear-Gang_4_gesperrt,not active,
IDE08303-ENG125571,Currently closed gear-Gang_5_gesperrt,not active,
IDE08303-ENG125566,Currently closed gear-Neutral_gesperrt,not active,
IDE08303-ENG125565,Currently closed gear-R_Gang_gesperrt,not active,
IDE08304-ENG123376,Adaptation state of transmission module-Einlernstatus Getriebe,nicht eingelernt,
IDE08314-ENG121521,Counter for all gear engage procedures-Param to DOP_56608,1026602,
IDE08315-ENG121521,Counter for all gear disengage procedures-Param to DOP_56608,80429,
IDE08316-ENG121528,Adaptation state of clutch abrasion point-Param to DOP_99400,2735,
IDE08317-ENG98542,Differential speed between engine and transmission-Engine speed,0, /min
IDE08324-ENG100569,Actual position of engine 2-Shift Position,0, INK
IDE08325-ENG100569,Actual position of engine 1-Shift Position,0, INK
IDE08326-ENG98749,Instantaneous current of clutch actuator-Motor current,0.00, A
IDE08327-ENG98749,Current current engine 2-Motor current,0.00, A
IDE08328-ENG98749,Current current engine 1-Motor current,0.00, A
IDE08329-ENG121530,Expanded status information on production functions-Status_Einlernroutinen,Routine not active,
IDE08336-ENG125573,Replacement measures group 1-All Gears are blocked,not active,
IDE08336-ENG123403,Replacement measures group 1-Clutch Adaption Values Are Set To Default,not active,
IDE08336-ENG112437,Replacement measures group 1-Clutch open,not active,
IDE08336-ENG123395,Replacement measures group 1-Cranking is allowed 1,not active,
IDE08336-ENG123396,Replacement measures group 1-Cranking is allowed 2,not active,
IDE08336-ENG123405,Replacement measures group 1-Disconnect CAN,not active,
IDE08336-ENG123406,Replacement measures group 1-Gearbox And Clutch Adaption Not Allowed,not active,
IDE08336-ENG123402,Replacement measures group 1-Gearboxpositons Are Set To Default Postions,not active,
IDE08336-ENG123398,Replacement measures group 1-Gears are set undef,not active,
IDE08336-ENG123397,Replacement measures group 1-LongInit is not allowed,not active,
IDE08336-ENG123400,Replacement measures group 1-NO Double Shifts Allowed,not active,
IDE08336-ENG123404,Replacement measures group 1-Only Gears 1: 2: R and Neutral Are Allowed,not active,
IDE08336-ENG123407,Replacement measures group 1-Run Neutral Gutter Check,not active,
IDE08336-ENG123399,Replacement measures group 1-Run Shortinit,not active,
IDE08336-ENG123401,Replacement measures group 1-Shortinit Is Not Allowed,not active,
IDE08337-ENG123382,Replacement measures group 2-CAN interruption,not active,
IDE08337-ENG123381,Replacement measures group 2-Clutch Limp Home,not active,
IDE08337-ENG123383,Replacement measures group 2-Keep Current Gear,not active,
IDE08337-ENG125572,Replacement measures group 2-Launching is possible in all gears,not active,
IDE08337-ENG123386,Replacement measures group 2-Limp Home Mode Clutch Motor,not active,
IDE08337-ENG123384,Replacement measures group 2-Limp Home Mode Motor 1,not active,
IDE08337-ENG123385,Replacement measures group 2-Limp Home Mode Motor 2,not active,
IDE08337-ENG123379,Replacement measures group 2-No Position D,not active,
IDE08337-ENG123380,Replacement measures group 2-No Position R,not active,
IDE08337-ENG98878,Replacement measures group 2-Red warning lamp,active,
IDE08337-ENG123390,Replacement measures group 2-Shift To Neutral 1,not active,
IDE08337-ENG123391,Replacement measures group 2-Shift To Neutral 2,not active,
IDE08337-ENG123392,Replacement measures group 2-Shift To Neutral 3,not active,
IDE08337-ENG123393,Replacement measures group 2-Shift To Neutral 4,not active,
IDE08337-ENG123394,Replacement measures group 2-Shift To Neutral 5,not active,
IDE08337-ENG123387,Replacement measures group 2-Substitute Engine Speed,not active,
IDE08337-ENG123388,Replacement measures group 2-Substitute Transmission Input Speed,not active,
IDE08337-ENG123389,Replacement measures group 2-Substitute Vehicle Speed,not active,
IDE08337-ENG99064,Replacement measures group 2-Yellow warning lamp,not active,
IDE08409-IDE08305,Gear selector neutral-Gear selector passage 1-2 neutral,994, INK
IDE08409-IDE08306,Gear selector neutral-Gear selector passage 3-4 neutral,994, INK
IDE08409-IDE08307,Gear selector neutral-Gear selector passage 5-R neutral,994, INK
IDE08410-IDE08308,Counter engage procedures-Counter for engage procedures 1st gear,149700,
IDE08410-IDE08309,Counter engage procedures-Counter for engage procedures 2nd gear,258653,
IDE08410-IDE08310,Counter engage procedures-Counter for engage procedures 3rd gear,242760,
IDE08410-IDE08311,Counter engage procedures-Counter for engage procedures 4th gear,184201,
IDE08410-IDE08312,Counter engage procedures-Counter for engage procedures 5th gear,85424,
IDE08410-IDE08313,Counter engage procedures-Counter for engage procedures reverse gear,25435,
IDE08411-IDE08318,Point of synchronization-Point of synchronization of 1st gear,930, INK
IDE08411-IDE08319,Point of synchronization-Point of synchronization of 2nd gear,1070, INK
IDE08411-IDE08320,Point of synchronization-Point of synchronization of 3rd gear,930, INK
IDE08411-IDE08321,Point of synchronization-Point of synchronization of 4th gear,1070, INK
IDE08411-IDE08322,Point of synchronization-Point of synchronization of 5th gear,930, INK
IDE08411-IDE08323,Point of synchronization-Point of synchronization of reverse gear,1070, INK
IDE08412-IDE08330,Number of engage blockers-Number of engage blockers for 1st gear,430,
IDE08412-IDE08331,Number of engage blockers-Number of engage blockers for 2nd gear,0,
IDE08412-IDE08332,Number of engage blockers-Number of engage blockers for 3rd gear,0,
IDE08412-IDE08333,Number of engage blockers-Number of engage blockers for 4th gear,6,
IDE08412-IDE08334,Number of engage blockers-Number of engage blockers for 5th gear,0,
IDE08412-IDE08335,Number of engage blockers-Number of engage blockers for reverse gear,212,
MAS04894,Operating mode,GET_INIT_KURZ,
Elapsed Time: 00:06
