How to search for a Channel (64)
jeffc
Illinois
C?ID=444936
I have done several modifications using Adaptation-10 and very few using Long Coding. I am attempting to do the following. How do I search for a Channel, 64 in this case, using either Adaptation or Long Coding?
Set Automatic Transmission Start Mode to D or S
[09 - Cent. Elect.] [Security Access - 10]
[Adaptation 10] -> Channel 64
Stored Value = 218 = Starting mode is always D
New Value = 00; Starting mode is determined by ADS selection at engine shutdown.
Westbury, UK
Depending on how your car (whatever it is) is equipped and configured it may not use numeric adaptation channels.
We need you to post an Auto-Scan to be able to advise.
jeffc
Illinois
C?ID=444936
Thanks. It's a 2021 Audi TTS. Here you go:
Address 01: Engine (J623-DLRA)       Labels: None
   Part No SW: 8S0 906 259 S    HW: 06K 907 425 J
   Component: R4 2.0l TFSI  H13 0002
   Revision: --H13---
   Coding: 0A2500122426010E3004
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0208S0906259S 001002
   ROD: EV_ECM20TFS0208S0906259S.rod
   VCID: 4DC7600CDD56C3F3345-8018
   Part No SW: 0GC 300 014 T    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2804
   Revision: 00H06V11
   ASAM Dataset: EV_TCMDQ381061 001001
   ROD: EV_TCMDQ381061_VW37.rod
   VCID: 36352FE048C0A02B65F-8062
   No subsystems:
   Part No SW: 8S0 907 379 P    HW: 8S0 907 379 F
   Component: ESC           H42 0570
   Revision: 00000000    Serial number: 60151000000536
   Coding: 34AAE08D0A9915AD4198086D82989306332C0750A8821041C960CC
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 060017
   ROD: EV_Brake1UDSContiMK100IPB_060.rod
   VCID: 4EC56700D050F8EB4DF-801A
16401 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 48
                    Mileage: 162 km
                    Date: 2021.05.16
                    Time: 12:43:46
   Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
   Component: VWKESSYMQB    037 1307
   Revision: 00037000    Serial number: 0569757547
   Coding: 030C0C1720
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 45D7582C05263BB3FC5-8010
   Part No SW: 8S0 820 043 A    HW: 8S0 820 043 A
   Component: AC Automat    H07 0100
   Revision: 20011000    Serial number: 21290000009000
   Coding: 400040100011041100
   ASAM Dataset: EV_AirCondiVAPrehAU33x 003011
   ROD: EV_AirCondiVAPrehAU33x.rod
   VCID: 2D07008CBD96E3F3145-8078
   Humidity sensor: exterior:
   Subsystem 1 - Part No SW: 4H0 907 658 D    HW: 4H0 907 658 D
   Component: G935 MuFu  H04 0010
   Serial number: A8E4883800PAG0MUFU05
   Rear A/C Control Head 1:
   Subsystem 2 - Part No SW: 8S0 820 373 F    HW: 8S0 820 373 F
   Component: E774 BuA_1  H02 0850
   Serial number: 00000000000000002815
   Rear A/C Control Head 2:
   Subsystem 3 - Part No SW: 8S0 820 359 D    HW: 8S0 820 359 D
   Component: E775 BuA_2  H02 0850
   Rear A/C Control Head 3:
   Subsystem 4 - Part No SW: 8S0 820 359 C    HW: 8S0 820 359 C
   Component: E776 BuA_3  H02 0850
   Rear A/C Control Head 4:
   Subsystem 5 - Part No SW: 8S0 820 359 E    HW: 8S0 820 359 E
   Component: E777 BuA_4  H02 0850
   Rear A/C Control Head 5:
   Subsystem 6 - Part No SW: 8S0 820 373 G    HW: 8S0 820 373 G
   Component: E778 BuA_5  H02 0850
   Part No SW: 5Q0 937 085 CG    HW: 5Q0 937 085 CG
   Component: BCM MQBAB HNA H42 0411
   Serial number: 01102104800300
   ASAM Dataset: EV_BCMMQB 021001
   ROD: EV_BCMBOSCH_021_VW26.rod
   VCID: 005989385A84DE9B8F3-8054
   Subsystem 1 - Part No SW: 8S1 955 119 B    HW: 8K1 955 119 B  Labels: 5QX-955-119-V1.CLB
   Component: 43x LL 210107  038 0371
   Serial number: 00000002101060300644
   Coding: 1BC7F7
   Subsystem 2 - Part No SW: 81A 955 547 B    HW: 81A 955 547
   Serial number: 40064085X81A955547B0
   Coding: 00005D
   Serial number: 11 11 2020  20001238
   Subsystem 4 - Part No SW: 4N0 907 410 C    HW: 4M0 907 410 A
   Component: USHL5     GX1  H12 0300
   Serial number: 0000009600373Z00D202
   Coding: 150000
   Garage door opener control head:
   Subsystem 5 - Part No SW: 8S0 959 719     HW: 8S0 959 719
   Component: GTO BF  H05 0010
   Serial number: 20190610135728 00751
   Subsystem 6 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY20340479R
   Subsystem 7 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000049184173
   Valve block 1 in front seat driver side:
   Subsystem 8 - Part No SW: 8S0 907 182     HW: 8S0 907 182
   Component: N475 VB1 FSv  H07 0022
   Serial number: 7008173235E204626636
   Coding: 810500
   Valve block 1 in front seat passenger side:
   Subsystem 9 - Part No SW: 8S0 907 182     HW: 8S0 907 182
   Component: N477 VB1 BFSv  H07 0022
   Serial number: 7008173235E204626718
   Coding: 810500
   Part No SW: 5Q0 919 294 M    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0545
   Revision: --------    Serial number: 39332104100458
   Coding: 0070150051
   ASAM Dataset: EV_EPHVA18AU3700000 003027
   ROD: EV_EPHVA18AU3700000_003.rod
Address 14: Susp. Elect. (J250)       Labels: 8V0-907-376.clb
   Part No SW: 8V0 907 376 H    HW: 8V0 907 376 F
   Component: DAEMPFUNGS-SG H11 0083
   Serial number:       200121053
   ASAM Dataset: EV_AudiMagneRide 003007
   ROD: EV_AudiMagneRide_003.rod
   VCID: 46D55F20382030ABF5F-8012
   Part No SW: 5Q0 959 655 R    HW: 5Q0 959 655 R
   Component: AirbagVW20    012 0830
   Serial number: 003M9R00VL0R
   Coding: BFCCF0C000800000A000001FC24800000065
   VCID: 4FFB7A04D75AF1E3469-801A
   Subsystem 1 - Part No SW: 4M0 959 339     HW: 4M0 959 339
   Component: BF-Gewichtss.  H12 0022
   Serial number: IBH00000000000F8K8HS
   Coding: 303338
   Subsystem 2 - Part No SW: -----------    HW: 480 001 902 21
   Serial number: 357000000007BB4C025O
   Subsystem 3 - Part No SW: -----------    HW: 480 001 902 21
   Serial number: 3580000000092B20D05F
   Subsystem 4 - Part No SW: -----------    HW: 480 011 412 20
   Component: SideSensor_Dr  005 0108
   Serial number: 351001A159CC01834FDH
   Subsystem 5 - Part No SW: -----------    HW: 480 401 002 21
   Component: FrontSensor_D  003 6149
   Serial number: 3550001A0C07C1D847FH
   Subsystem 6 - Part No SW: -----------    HW: 480 401 002 21
   Component: FrontSensor_P  003 6149
   Serial number: 3560001A0C07C1D9A92E
   Part No SW: 8S0 907 129 AJ    HW: 8S0 907 129 AJ
   Component: Lenks. Modul  H07 0150
   Revision: --------    Serial number: 91335TIK06046
   Coding: 2058
   ASAM Dataset: EV_SMLSKLOMQB 050001
   ROD: EV_SMLSKLOMQB_050.rod
   VCID: 025D83305488CC8B997-8056
   Part No SW: 8S0 920 890 F    HW: 8S0 920 890 F
   Component: FBenUSA       H45 0383
   Coding: 08EF0841398ACF050221ECC09800801000000000
   ASAM Dataset: EV_DashBoardBOSCHAU33X 001032
   ROD: EV_DashBoardBOSCHAU33X.rod
   VCID: 3D2730CC6DF67373A45-8068
   Part No SW: 8S0 907 468 L    HW: 8S0 907 468 E
   Component: GW MQB TT3    023 0423
   Serial number: 19022110520467
   Coding: 030100042F025A004B008068B80B00000000000000000000000000000001
   ASAM Dataset: EV_GatewContiAU33X 013026
   ROD: EV_GatewContiAU33X_013.rod
   VCID: 49CF541C293EDFD318D-801C
   Generator:
   Component: 4-01-0d-01-04
   Subsystem 2 - Part No SW: 8S0 951 523 C    HW: 8S0 951 523 C
   Component: J453 MFL  H07 0002
   Serial number: 20210210074448 00292
   Subsystem 3 - Part No SW: 8W0 915 181     HW: 8W0 915 181
   Serial number: 0369375805
   Part No SW: 0CQ 907 554 K    HW: 0CQ 525 130
   Component: Haldex4Motion H55 7762
   Serial number: HA1-00022.12.20
   Coding: 0101
   Part No SW: 8S0 907 566     HW: 4H0 907 566 F
   Component: SWA Master    H08 0060
   Serial number: 0565138039
   Coding: 030311
   ROD: EV_LaneChangAssis_VW51.rod
   VCID: 7CA1FDC8366CBA7BD3B-8028
   Subsystem 1 - Part No SW: 8S0 907 568     HW: 4H0 907 568 F
   Component: SWA Slave  H08 0060
   Serial number: 0565459299
   Coding: 030311
   Part No SW: 5Q0 959 593 K    HW: 5Q0 959 593 F
   Component: TSG FS003 0330
   Serial number: YE007UBF10578
   Coding: 001F53225000000100000402
          B1487 54 [008] - Missing Calibration / Basic Setting
                    Mileage: 21 km
                    Date: 2021.05.05
                    Time: 12:40:32
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
   Coding: 811F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3C213DC876EC7A7B93B-8068
   Part No SW: 8S0 035 466 A    HW: 8S0 035 466
   Component: MIB2_amp_P_TT H10 0440
   Revision: 00000001    Serial number: AUZ8ZAL5C00NE6.
   Coding: 0133040000AA2A2AAA0000010000
   ASAM Dataset: EV_AMPMst16C1Gen2ALPI 001012
   ROD: EV_AMPMst16C1Gen2ALPI_AU37.rod
   VCID: 343115E85EBCB23B5BB-8060
Address 52: Door Elect, Pass. (J387)       Labels:* Redir Fail!
   Part No SW: 5Q0 959 592 K    HW: 5Q0 959 592 F
   Component: TSG BFS002 0330
   Serial number: YE007UAM05451
   Coding: 001F53225C00000100000402
   VCID: 48C95118323426DB073-801C
   Part No SW: 4H4 907 357 G    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0115
   Coding: 03E2001123200400
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005012
   Coding: E01800
   Coding: E01800
   Subsystem 3 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 S002
   Coding: E01800
   Subsystem 4 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 S002
   Coding: E01800
   Part No SW: 8S0 035 046 C    HW: 8S0 035 025 B
   Component: MU-H-LNS-US   055 1480
   Serial number: A707L0LP001139
   Coding: 013354020000000011220002041A00332F0000E0007000047E
   VCID: 303919F8AAA48E1B3F3-8064
   Subsystem 1 - Part No SW: V03 959 803 AK    HW: -----------
   Component: NAR 2021  --- 0081
   Subsystem 2 - Part No SW: 8S0 919 614 M    HW: 8S0 919 614 M
   Component: ControlUnit_H  H30 0206
   Serial number: APVAK125112000010067
   Compact disc data bank:
   Component: Gracenote2  --- 3013
   Coding: 0233540102002001000040
   VCID: 392F24DC79DE4F5388D-806C
Address A9: Struct. Borne Sound (J869)       Labels: None
   Part No SW: 8S0 907 159 E    HW: 81A 907 159 A
   Component: SAS-GEN 2.5   H08 0004
   Serial number: 210205200857
   VCID: 3FDB4AC467FA6163B69-806A
jeffc
Illinois
C?ID=444936
Here is a map of Central Electric. In the first row of data, is the IDE00001 the
Channel number? If not, how to I find it?
;SW:5Q0-937-085-CG HW:5Q0-937-085-CG --- Cent. Elect.
;Component:BCM MQBAB HNA H42 0411Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BCMMQB
21001​
EV_BCMBOSCH_021_AU37.rod
;Monday
2​
May
;VCDS Version: Release 22.3.1 (x64) Data version: 20220407 DS337.0
;VCID: 005989385A84DE9BCFF-8054
IDE00001-ENG99061-Production mode-Access controlnot active
3​
IDE00001-ENG115730-Production mode-Exterior lightingnot active
3​
IDE00001-ENG112304-Production mode-Heckwischernot active
3​
IDE00001-ENG98647-Production mode-Interior lightsnot active
3​
IDE00001-ENG115729-Production mode-Scheinwerferreinigungnot active
3​
IDE00001-ENG115731-Production mode-Virtuel_pedalnot active
3​
IDE00002-Transport modeactive
1​
IDE00820-Activating and deactivating all development messagesnot active
1​
IDE01550-Service position163.999837 °
2​
IDE02152-Characteristics in production mode2000 ms
4​
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during lockingDELAY
10​
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegelnnot active
10​
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung globalactive
10​
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhornnot active
10​
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegelnactive
10​
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhornnormal
10​
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldungactive
10​
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchtenot active
10​
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessenactive
10​
IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehlnot active
10​
IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit200 ms
10​
IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit200 ms
10​
IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit200 ms
10​
IDE02332-Deactivate production mode
0​
3​
IDE02488-Anti-theft system interior monitoring
100%​
1​
IDE02711-ENG116690-Rear wiper-Automatisches Heckwischennot active
8​
IDE02711-ENG133397-Rear wiper-Einzelansteuerung Heckintervallwischennot active
8​
IDE02711-ENG133395-Rear wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 18 s
8​
IDE02711-ENG133396-Rear wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 216 s
8​
IDE02711-ENG112304-Rear wiper-Heckwischernot installed
8​
IDE02711-ENG114947-Rear wiper-Heckwischer Weiterlaufnot active
8​
IDE02711-ENG114946-Rear wiper-Komfortwischen Heckactive
8​
IDE02711-ENG116695-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 13 s
8​
IDE02711-ENG116696-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 21 s
8​
IDE02711-ENG116694-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik5 s
8​
IDE02711-ENG116693-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall5 s
8​
IDE02711-ENG116689-Rear wiper-Menuesteuerung Komfortwischen HWnot active
8​
IDE02711-ENG154784-Rear wiper-Spannungsanforderung_konfig_WischerKeine_Spannungsanforderung
8​
IDE02711-ENG116691-Rear wiper-Traenenwischen Hecknot active
8​
IDE02711-ENG154831-Rear wiper-Zeit_wasch_min_heck0 ms
8​
IDE03638-IDE04231-Stationary cornering lamp-Steering wheel angle: offset-0.3 °
16​
IDE03638-ENG116677-Stationary cornering lamp-Abdimmgeschwindigkeit50.0 %/s
16​
IDE03638-ENG116673-Stationary cornering lamp-bei RueckwaertsfahrtOFF
16​
IDE03638-ENG116675-Stationary cornering lamp-Lower speed threshold0.0 km/h
16​
IDE03638-ENG116682-Stationary cornering lamp-Maximaltemperatur100.0 °C
16​
IDE03638-ENG116679-Stationary cornering lamp-obere Grenztemperatur95.0 °C
16​
IDE03638-ENG116681-Stationary cornering lamp-Oberer Lenkradwinkel90 °
16​
IDE03638-ENG116680-Stationary cornering lamp-untere Grenztemperatur80.0 °C
16​
IDE03638-ENG116678-Stationary cornering lamp-Unterer Lenkradwinkel30 °
16​
IDE03638-ENG116676-Stationary cornering lamp-Upper speed threshold32.0 km/h
16​
IDE03638-ENG116674-Stationary cornering lamp-VorschriftOFF
16​
IDE03638-ENG115830-Stationary cornering lamp-Zeitwert Einschaltzeit Abbiegelicht15 min
16​
IDE03787-Activate left/right hand drive switch-overNo_Menue
1​
IDE04927-IDE01446-Window heater-Running time of heated front window600 s
11​
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung35.0 °C
11​
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung35.0 °C
11​
IDE04927-ENG142251-Window heater-Frontscheibenheizung _maximale_Dauer0 s
11​
IDE04927-ENG142035-Window heater-Frontscheibenheizung_LED_direktnot installed
11​
IDE04927-ENG142018-Window heater-Frontscheibenheizungsansteuerung direkt von externem Algorithmusnot installed
11​
IDE04927-ENG126845-Window heater-FSH Automatiknot active
11​
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert600 s
11​
IDE04927-ENG141955-Window heater-heizbare Heckscheibeinstalled
11​
IDE04927-ENG142021-Window heater-Heizbare_Frontscheibenot installed
11​
IDE04927-ENG246969-Window heater-HZG_Wischer_Ablagenot installed
11​
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSHnot active
11​
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSHactive
11​
IDE04927-ENG246996-Window heater-WAH_Temp_Wischer_aktiv-50.0 °C
11​
IDE04927-ENG141962-Window heater-Waschduesenheizunginstalled
11​
IDE04927-ENG154810-Window heater-window heating front activation time pause240 s
11​
IDE04928-MAS01577-Anti-theft protection-Parking heaternot installed
8​
IDE04928-ENG115867-Anti-theft protection-Akustischer Alarm Signalhornnot active
8​
IDE04928-ENG115864-Anti-theft protection-Alarmsignalfrequency modulated
8​
IDE04928-ENG141960-Anti-theft protection-Anti-theft alarm systemactive
8​
IDE04928-ENG154588-Anti-theft protection-Deaktivierung DWA-Sensoren via Doppelklicknot_active
8​
IDE04928-ENG154589-Anti-theft protection-Deaktivierung_DWA_Sensoren_HMInot_active
8​
IDE04928-ENG115865-Anti-theft protection-DWA Alarmverzoegerungnot active
8​
IDE04928-ENG115812-Anti-theft protection-DWA Camper Modusnot active
8​
IDE04928-ENG142007-Anti-theft protection-DWA_Einfachhorn_oder_SounderSounder_verbaut
8​
IDE04928-ENG141961-Anti-theft protection-Heckscheibenbruchsensorinstalled
8​
IDE04928-ENG142006-Anti-theft protection-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtetNo
8​
IDE04928-ENG142249-Anti-theft protection-OBD Alarmactiv
8​
IDE04928-ENG154722-Anti-theft protection-RHF_Panikalarmnot_active
8​
IDE04928-ENG142009-Anti-theft protection-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv)Yes
8​
IDE04928-ENG142010-Anti-theft protection-Sensor_fuer_InnenraumueberwachungYes
8​
IDE04928-ENG115866-Anti-theft protection-Sirenen Alarmzahl1 Alarm
8​
IDE04928-ENG142008-Anti-theft protection-tilt_sensorYes
8​
IDE04928-ENG126842-Anti-theft protection-Ueberwachung Innenentriegelungshebelactive
8​
IDE04928-ENG115868-Anti-theft protection-Verzoegerung Panikalarmkeine verzoegerung
8​
IDE05143-MAS02985-Writing parameter-Value
132​
5​
IDE05143-MAS04381-Writing parameter-Parameter addressFE 00 00
5​
IDE05144-Read parameter addressFE 00 00
3​
IDE05145-Light configuration21 34 00 14 02 00 7F 03 00 00 00 00 00 00 00 00 21 3E 00 15 04 00 7F 05 00 00 00 00 00 00 00 00 04 48 00 4A 14 00 64 06 00 80 08 09 1C 1E 00 1C 04 4C 00 4C 14 00 64 07 00 80 08 0A 1C 1E 00 1C 01 48 00 49 14 00 64 06 00 80 08 09 64 1E 00 64 01 4C 00 4B 14 00 64 07 00 80 08 0A 64 1E 00 64 05 36 00 1A 0B 00 7F 1E 00 7F 00 00 00 00 00 00 05 40 00 1B 0C 00 7F 1E 00 7F 00 00 00 00 00 00 05 36 00 5D 28 00 7F 1E 00 7F 00 00 00 00 00 00 05 40 00 5E 28 00 7F 1E 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 00 62 3F 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
224​
IDE05822-Anti-theft alarm system vehicle inclination sensor
100%​
1​
IDE05823-DWA Interior monitoring parameter set01 0A 08 00 43 63 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 CD 46 26 00 0F 1D 00 85 0F 39 F7 24 19 45 31 57 9B 25 44 3F 3A 69 35 95 18 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 29 0F E3 31 87 9B 05 34 3F 3A 69 58 03 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 29 19 45 31 77 9B 05 24 3F 3A 69 47 03 08 09 A3 04 23 15 4A 16 0A 16 1F 88 0B 28 51 32 0C 61 31 5A 94 05 24 8F FD 57 45 02 14 05 A2 05 64 26 26 15 0C 12 18 86 09 30 33 27 19 45 31 57 9B 25 24 0C FA 0A 34 95 18 09 A3 21 03 00 02 02 02 02 02 02 91 20 61 26 41
172​
IDE06089-ENG246993-Seat heater level current consumption allocation-SIH_PWM_Teiler
0​
30​
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CANHeizmatten am BCM
30​
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss1 s
30​
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss0.00 °C
30​
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle20.00 °C
30​
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle18.00 °C
30​
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle20.00 °C
30​
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle18.00 °C
30​
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle32.00 °C
30​
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle30.00 °C
30​
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle32.00 °C
30​
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle30.00 °C
30​
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle45.00 °C
30​
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle43.00 °C
30​
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle45.00 °C
30​
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle43.00 °C
30​
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HISollspannungsanforderung 14.7
30​
IDE06089-ENG154775-Seat heater level current consumption allocation-Sitzheizung.Regelbetrieb LOKeine_Spannungsanforderung
30​
IDE06089-ENG141977-Seat heater level current consumption allocation-Sitzheizungsfreigabenot installed
30​
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_7515.7 V
30​
IDE06425-Dynamometer mode: functionalnot active
1​
IDE06507-MAS13125-Button in center console-Function of button 1Start-stop
8​
IDE06507-MAS13129-Button in center console-Function of button 2not coded/not installed
8​
IDE06507-MAS13132-Button in center console-Function of button 3Driving program
8​
IDE06507-MAS13135-Button in center console-Function of button 4not coded/not installed
8​
IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LEDLED not installed
8​
IDE07007-ENG142253-Air conditioning/heating function via remote control-Abbruch_d_Warnblinker_moeglichactive
8​
IDE07007-ENG142252-Air conditioning/heating function via remote control-Abbruch_Hupen_RStnot active
8​
IDE07007-ENG142255-Air conditioning/heating function via remote control-Aktivierung_Drehzahlanzeigeactive
8​
IDE07007-ENG142254-Air conditioning/heating function via remote control-Kombi_Fahrerhinweis_m_Akustikactive
8​
IDE07007-ENG128461-Air conditioning/heating function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RStactive
8​
IDE07007-ENG249923-Air conditioning/heating function via remote control-pa_RSt_MOD_verbautnot installed
8​
IDE07007-ENG115720-Air conditioning/heating function via remote control-Remote Startnot installed
8​
IDE07007-ENG246992-Air conditioning/heating function via remote control-Remotestart_externe_FFB_verbautnot installed
8​
IDE07007-ENG128460-Air conditioning/heating function via remote control-Rueckmeldung_bei_Aktivierungactive
8​
IDE07356-Position during interval mode41.494464 °
2​
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufsabschalten nach der Nachlaufzeit
6​
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit30 min
6​
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Einnot active
6​
IDE08577-Garage door opener: use of GPS datanot active
1​
IDE08578-Garage door opener: bi-directional communic.Communication active
1​
IDE08579-Garage door opener: drift adapt.not active
1​
IDE08580-Garage door opener: increasing transm. powernot active
1​
IDE08583-Garage door opener: no. of channels3 channels
1​
IDE08585-Garage door opener: activation via remote keynot active
1​
IDE08778-Garage door opener: surround. target area30 m
1​
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regenactive
9​
IDE08786-ENG141956-Assistance light functions-Humidity sensorinstalled
9​
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeitnormal
9​
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabeactive
9​
IDE08786-ENG142228-Assistance light functions-Maskierung_Regenfunktionnot active
9​
IDE08786-ENG141985-Assistance light functions-Regen_LichtsensorLIN_REGEN_LICHT_SENSOR
9​
IDE08786-ENG124476-Assistance light functions-Sunlight photo sensornot installed
9​
IDE09377-IDE00761-Multi contour seat driver's side-Run-on time600 s
5​
IDE09377-IDE03006-Multi contour seat driver's side-Running time of massage function600 s
5​
IDE09377-IDE03007-Multi contour seat driver's side-Component locationDriver side
5​
IDE09377-IDE03099-Multi contour seat driver's side-Characteristics for manual seat adjustmentOpen circuit
5​
IDE09377-IDE03100-Multi contour seat driver's side-Characteristics for seat adjustment using memoryOpen circuit
5​
IDE09378-IDE00761-Multicontour seat passenger side-Run-on time600 s
5​
IDE09378-IDE03006-Multicontour seat passenger side-Running time of massage function600 s
5​
IDE09378-IDE03007-Multicontour seat passenger side-Component locationFront passenger side
5​
IDE09378-IDE03099-Multicontour seat passenger side-Characteristics for manual seat adjustmentOpen circuit
5​
IDE09378-IDE03100-Multicontour seat passenger side-Characteristics for seat adjustment using memoryOpen circuit
5​
IDE09546-Multicontour seat on driver's side: reset compressor counternot active
1​
IDE09547-Multicontour seat on frt. pass. side: reset compressor counternot active
1​
IDE09548-Multicontour seat on driver's side: reset adaptationnot active
1​
IDE09549-Multicontour seat on frt. pass. side: reset adaptationnot active
1​
IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual
2​
19​
IDE09731-ENG249826-Int. light: 2nd generation-Ambiente_Fahrprofil_Offroad_Individual
0​
19​
IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformationnot active
19​
IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplungnot active
19​
IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_defaultnot active
19​
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit0.00 s
19​
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1
0​
19​
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2
0​
19​
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3
0​
19​
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbignot active
19​
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbignot active
19​
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach
0%​
19​
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe
0​
19​
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum
0%​
19​
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole
0%​
19​
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer
0%​
19​
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn
0%​
19​
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnenactive
19​
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnenactive
19​
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnenactive
19​
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnenactive
19​
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnenactive
19​
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnenactive
19​
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnenactive
19​
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnennot active
19​
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnenactive
19​
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnenactive
19​
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnennot active
19​
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnenactive
19​
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnenactive
19​
IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnennot active
19​
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschaltennot active
19​
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbignot active
19​
IDE09731-ENG98648-Int. light: 2nd generation-Interior lightingKeine_Spannungsanforderung
19​
IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWMnot active
19​
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbignot active
19​
IDE09731-ENG142031-Int. light: 2nd generation-LIN-Dachkonsole mit Flaechenlichtnot installed
19​
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbignot active
19​
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivierennot active
19​
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbignot active
19​
IDE09731-ENG116687-Int. light: 2nd generation-Tuerinnengriff mit Tuertafelnot installed
19​
IDE09731-ENG116686-Int. light: 2nd generation-Tuerinnengriffbeleuchtung mit I-Tafelnot installed
19​
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbignot active
19​
IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30Gnot installed
19​
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechselnot active
19​
IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default
0​
5​
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMInot active
5​
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafelnot installed
5​
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafelinstalled
5​
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecherinstalled
5​
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonenactive
5​
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem ausnot active
5​
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtunginstalled
5​
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtungnot installed
5​
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofilnot installed
5​
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMInot installed
5​
IDE09732-ENG114629-Interior light: light configuration-Footwell lightinginstalled
5​
IDE09732-ENG133385-Interior light: light configuration-Frei_Farbwahl_ueber_HMInot active
5​
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbarnot active
5​
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtungnot installed
5​
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtungnot installed
5​
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne
30%​
17​
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz
25%​
17​
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne
30%​
17​
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz
25%​
17​
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne
58%​
17​
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz
53%​
17​
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne
58%​
17​
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz
53%​
17​
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne
85%​
17​
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz
80%​
17​
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne
85%​
17​
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz
80%​
17​
IDE09761-ENG142024-Seat fan charac. curve-Sitzlueftungnot installed
17​
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbarnot installed
17​
IDE09761-ENG142025-Seat fan charac. curve-Sitzpneumatikinstalled
17​
IDE10298-Alternating park position 129.999970 °
2​
IDE10299-Alternating park position 233.494472 °
2​
IDE10308-Garage door opener: support door namenot active
1​
IDE10349-MAS10436-Garage door opener: Default/Fix kit mode-Default modenot active
1​
IDE10349-MAS10437-Garage door opener: Default/Fix kit mode-Fixkit mode: button 1not active
1​
IDE10349-MAS10438-Garage door opener: Default/Fix kit mode-Fixkit mode: button 2not active
1​
IDE10349-MAS10439-Garage door opener: Default/Fix kit mode-Fixkit mode: button 3not active
1​
IDE10350-Garage door opener: programming antennaInternal antenna
1​
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit
1​
256​
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach
1​
256​
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum
1​
256​
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel
1​
256​
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher
1​
256​
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko
1​
256​
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd
1​
256​
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer
1​
256​
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI
0​
256​
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2
0​
256​
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3
0​
256​
IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4
0​
256​
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI
0​
256​
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2
0​
256​
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3
0​
256​
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4
0​
256​
IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab
1​
256​
IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf
1​
256​
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI
0​
256​
IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay
0​
256​
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit
100%​
256​
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach
100%​
256​
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum
100%​
256​
IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht
100%​
256​
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel
100%​
256​
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher
100%​
256​
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko
100%​
256​
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd
100%​
256​
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren
100%​
256​
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit
100%​
256​
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach
100%​
256​
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum
100%​
256​
IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht
100%​
256​
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel
100%​
256​
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher
100%​
256​
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko
100%​
256​
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd
100%​
256​
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren
100%​
256​
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit
100%​
256​
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach
100%​
256​
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum
100%​
256​
IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht
100%​
256​
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel
100%​
256​
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher
100%​
256​
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko
100%​
256​
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd
100%​
256​
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren
100%​
256​
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit
100%​
256​
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach
100%​
256​
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum
100%​
256​
IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht
100%​
256​
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel
100%​
256​
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher
100%​
256​
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko
100%​
256​
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd
100%​
256​
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren
100%​
256​
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit
100%​
256​
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach
100%​
256​
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum
100%​
256​
IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht
100%​
256​
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel
100%​
256​
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher
100%​
256​
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko
100%​
256​
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd
100%​
256​
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren
100%​
256​
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit
100%​
256​
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach
100%​
256​
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum
100%​
256​
IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht
100%​
256​
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel
100%​
256​
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher
100%​
256​
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko
100%​
256​
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd
100%​
256​
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren
100%​
256​
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit
100%​
256​
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach
100%​
256​
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum
100%​
256​
IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht
100%​
256​
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel
100%​
256​
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher
100%​
256​
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko
100%​
256​
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd
100%​
256​
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren
100%​
256​
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit
100%​
256​
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach
100%​
256​
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum
100%​
256​
IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht
100%​
256​
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel
100%​
256​
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher
100%​
256​
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko
100%​
256​
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd
100%​
256​
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren
100%​
256​
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit
126%​
256​
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach
126%​
256​
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum
126%​
256​
IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht
0%​
256​
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel
126%​
256​
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher
126%​
256​
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko
126%​
256​
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd
126%​
256​
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren
126%​
256​
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit
100%​
256​
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach
100%​
256​
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum
100%​
256​
IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht
100%​
256​
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel
100%​
256​
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher
100%​
256​
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko
100%​
256​
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd
100%​
256​
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren
100%​
256​
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit
100%​
256​
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach
100%​
256​
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum
100%​
256​
IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht
100%​
256​
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel
100%​
256​
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher
100%​
256​
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko
100%​
256​
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd
100%​
256​
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren
100%​
256​
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit
100%​
256​
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach
100%​
256​
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum
100%​
256​
IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht
100%​
256​
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel
100%​
256​
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher
100%​
256​
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko
100%​
256​
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd
100%​
256​
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren
100%​
256​
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit
100%​
256​
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach
100%​
256​
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum
100%​
256​
IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht
100%​
256​
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel
100%​
256​
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher
100%​
256​
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko
100%​
256​
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd
100%​
256​
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren
100%​
256​
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit
100%​
256​
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach
100%​
256​
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum
100%​
256​
IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht
100%​
256​
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel
100%​
256​
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher
100%​
256​
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko
100%​
256​
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd
100%​
256​
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren
100%​
256​
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit
100%​
256​
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach
100%​
256​
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum
100%​
256​
IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht
100%​
256​
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel
100%​
256​
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher
100%​
256​
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko
100%​
256​
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd
100%​
256​
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren
100%​
256​
IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte200 ms
256​
IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit0.0 s
256​
IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach0.0 s
256​
IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum0.0 s
256​
IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht0.0 s
256​
IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko0.0 s
256​
IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren0.0 s
256​
IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit0.0 s
256​
IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach0.0 s
256​
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum0.0 s
256​
IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht0.0 s
256​
IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko0.0 s
256​
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren0.0 s
256​
IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit0.0 s
256​
IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach0.0 s
256​
IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum0.0 s
256​
IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht0.0 s
256​
IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko0.0 s
256​
IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren0.0 s
256​
IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit0.0 s
256​
IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach0.0 s
256​
IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum0.0 s
256​
IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht0.0 s
256​
IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko0.0 s
256​
IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren0.0 s
256​
IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit0.0 s
256​
IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach0.0 s
256​
IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum0.0 s
256​
IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht0.0 s
256​
IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko0.0 s
256​
IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren0.0 s
256​
IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit0.0 s
256​
IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach0.0 s
256​
IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum0.0 s
256​
IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht0.0 s
256​
IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko0.0 s
256​
IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren0.0 s
256​
IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit0.0 s
256​
IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach0.0 s
256​
IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum0.0 s
256​
IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht0.0 s
256​
IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko0.0 s
256​
IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren0.0 s
256​
IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen
0​
256​
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1
0​
30​
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10
0​
30​
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2
0​
30​
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3
0​
30​
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4
0​
30​
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5
0​
30​
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6
0​
30​
IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7
0​
30​
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8
0​
30​
IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9
0​
30​
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1
0​
30​
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10
0​
30​
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2
0​
30​
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3
0​
30​
IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4
0​
30​
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5
0​
30​
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6
0​
30​
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7
0​
30​
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8
0​
30​
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9
0​
30​
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1
0​
30​
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10
0​
30​
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2
0​
30​
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3
0​
30​
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4
0​
30​
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5
0​
30​
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6
0​
30​
IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7
0​
30​
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8
0​
30​
IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9
0​
30​
IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelungnot installed
3​
IDE11944-ENG141948-Keyless access and start authorization-Kessyinstalled
3​
IDE11944-ENG179141-Keyless access and start authorization-Kessy Bewegungsüberwachung IDGeberactive
3​
IDE11944-ENG116653-Keyless access and start authorization-Kessy Komfort oeffnennot active
3​
IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessenactive
3​
IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzungactive
3​
IDE11944-ENG179142-Keyless access and start authorization-Kessy Protokollvariante EntryExitactive
3​
IDE11944-ENG179143-Keyless access and start authorization-Kessy Ruhephase EntryExitnot active
3​
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelungactive
3​
IDE12120-Garage door opener: piloted parkingnot active
1​
IDE12302-SFT271873-Identification of sub-bus participant-Wiper motor control moduleNot available
6​
IDE12302-SFT271874-Identification of sub-bus participant-Rain/Light Recognition SensorNot available
6​
IDE12302-SFT271875-Identification of sub-bus participant-Light switchNot available
6​
IDE12302-SFT271876-Identification of sub-bus participant-Garage door opener control moduleNot available
6​
IDE12302-SFT271877-Identification of sub-bus participant-Garage door opener control headNot available
6​
IDE12302-SFT271894-Identification of sub-bus participant-Anti-theft alarm system sensorNot available
6​
IDE12302-SFT271896-Identification of sub-bus participant-Alarm hornNot available
6​
IDE12302-SFT271904-Identification of sub-bus participant-Sunroof control moduleNot available
6​
IDE12302-SFT271910-Identification of sub-bus participant-Roof electronics control moduleNot available
6​
IDE12302-SFT271928-Identification of sub-bus participant-Roof shade control moduleNot available
6​
IDE12302-SFT271947-Identification of sub-bus participant-Humidity sensor: interiorNot available
6​
IDE12302-SFT271966-Identification of sub-bus participant-Left head area heaterNot available
6​
IDE12302-SFT271967-Identification of sub-bus participant-Right head area heaterNot available
6​
IDE12302-SFT272065-Identification of sub-bus participant-Blower 1 for left front backrestNot available
6​
IDE12302-SFT272067-Identification of sub-bus participant-Blower 1 for left front seat cushionNot available
6​
IDE12302-SFT272069-Identification of sub-bus participant-Blower 1 for right front backrestNot available
6​
IDE12302-SFT272071-Identification of sub-bus participant-Blower 1 for right front seat cushionNot available
6​
IDE12302-ENG246961-Identification of sub-bus participant-Remote_ControlNot available
6​
IDE12302-ENG246960-Identification of sub-bus participant-steering_column_switchNot available
6​
IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin
0​
30​
IDE12412-ENG154527-LIN Ambient light color list-Blauwert_Farbe_10_lin
0​
30​
IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin
0​
30​
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin
0​
30​
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin
0​
30​
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin
0​
30​
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin
0​
30​
IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin
0​
30​
IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin
0​
30​
IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin
0​
30​
IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin
0​
30​
IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin
0​
30​
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin
0​
30​
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin
0​
30​
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin
0​
30​
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin
0​
30​
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin
0​
30​
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin
0​
30​
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin
0​
30​
IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin
0​
30​
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin
0​
30​
IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin
0​
30​
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin
0​
30​
IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin
0​
30​
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin
0​
30​
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin
0​
30​
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin
0​
30​
IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin
0​
30​
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin
0​
30​
IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin
0​
30​
IDE80001-ENG125667-Analysis 1-EE_pMax_LM_MSG_Px_Iy110 hPa
15​
IDE80001-ENG125666-Analysis 1-EE_pMax_LO_MSG_Px_Iy110 hPa
15​
IDE80001-ENG125668-Analysis 1-EE_pMax_LU_MSG_Px_Iy110 hPa
15​
IDE80001-ENG125673-Analysis 1-EE_tEnt_LM_MSG_Px_Iy5000 ms
15​
IDE80001-ENG125672-Analysis 1-EE_tEnt_LO_MSG_Px_Iy5000 ms
15​
IDE80001-ENG125674-Analysis 1-EE_tEnt_LU_MSG_Px_Iy5000 ms
15​
IDE80001-ENG125670-Analysis 1-EE_tHalte_LM_MSG_Px_Iy0 ms
15​
IDE80001-ENG125669-Analysis 1-EE_tHalte_LO_MSG_Px_Iy0 ms
15​
IDE80001-ENG125671-Analysis 1-EE_tHalte_LU_MSG_Px_Iy0 ms
15​
IDE80001-ENG125676-Analysis 1-EE_tWarte_LM_MSG_Px_Iy0 ms
15​
IDE80001-ENG125675-Analysis 1-EE_tWarte_LO_MSG_Px_Iy0 ms
15​
IDE80001-ENG125677-Analysis 1-EE_tWarte_LU_MSG_Px_Iy0 ms
15​
IDE80001-ENG125664-Analysis 1-EE_Upumpe_LM_MSG_Px_Iy80 ms
15​
IDE80001-ENG125663-Analysis 1-EE_Upumpe_LO_MSG_Px_Iy80 ms
15​
IDE80001-ENG125665-Analysis 1-EE_Upumpe_LU_MSG_Px_Iy80 ms
15​
IDE80002-ENG125667-Analysis 2-EE_pMax_LM_MSG_Px_Iy160 hPa
15​
IDE80002-ENG125666-Analysis 2-EE_pMax_LO_MSG_Px_Iy160 hPa
15​
IDE80002-ENG125668-Analysis 2-EE_pMax_LU_MSG_Px_Iy160 hPa
15​
IDE80002-ENG125673-Analysis 2-EE_tEnt_LM_MSG_Px_Iy6000 ms
15​
IDE80002-ENG125672-Analysis 2-EE_tEnt_LO_MSG_Px_Iy6000 ms
15​
IDE80002-ENG125674-Analysis 2-EE_tEnt_LU_MSG_Px_Iy6000 ms
15​
IDE80002-ENG125670-Analysis 2-EE_tHalte_LM_MSG_Px_Iy0 ms
15​
IDE80002-ENG125669-Analysis 2-EE_tHalte_LO_MSG_Px_Iy0 ms
15​
IDE80002-ENG125671-Analysis 2-EE_tHalte_LU_MSG_Px_Iy0 ms
15​
IDE80002-ENG125676-Analysis 2-EE_tWarte_LM_MSG_Px_Iy0 ms
15​
IDE80002-ENG125675-Analysis 2-EE_tWarte_LO_MSG_Px_Iy0 ms
15​
IDE80002-ENG125677-Analysis 2-EE_tWarte_LU_MSG_Px_Iy0 ms
15​
IDE80002-ENG125664-Analysis 2-EE_Upumpe_LM_MSG_Px_Iy80 ms
15​
IDE80002-ENG125663-Analysis 2-EE_Upumpe_LO_MSG_Px_Iy80 ms
15​
IDE80002-ENG125665-Analysis 2-EE_Upumpe_LU_MSG_Px_Iy80 ms
15​
IDE80003-ENG125667-Analysis 3-EE_pMax_LM_MSG_Px_Iy210 hPa
15​
IDE80003-ENG125666-Analysis 3-EE_pMax_LO_MSG_Px_Iy210 hPa
15​
IDE80003-ENG125668-Analysis 3-EE_pMax_LU_MSG_Px_Iy210 hPa
15​
IDE80003-ENG125673-Analysis 3-EE_tEnt_LM_MSG_Px_Iy7000 ms
15​
IDE80003-ENG125672-Analysis 3-EE_tEnt_LO_MSG_Px_Iy7000 ms
15​
IDE80003-ENG125674-Analysis 3-EE_tEnt_LU_MSG_Px_Iy7000 ms
15​
IDE80003-ENG125670-Analysis 3-EE_tHalte_LM_MSG_Px_Iy0 ms
15​
IDE80003-ENG125669-Analysis 3-EE_tHalte_LO_MSG_Px_Iy0 ms
15​
IDE80003-ENG125671-Analysis 3-EE_tHalte_LU_MSG_Px_Iy0 ms
15​
IDE80003-ENG125676-Analysis 3-EE_tWarte_LM_MSG_Px_Iy0 ms
15​
IDE80003-ENG125675-Analysis 3-EE_tWarte_LO_MSG_Px_Iy0 ms
15​
IDE80003-ENG125677-Analysis 3-EE_tWarte_LU_MSG_Px_Iy0 ms
15​
IDE80003-ENG125664-Analysis 3-EE_Upumpe_LM_MSG_Px_Iy80 ms
15​
IDE80003-ENG125663-Analysis 3-EE_Upumpe_LO_MSG_Px_Iy80 ms
15​
IDE80003-ENG125665-Analysis 3-EE_Upumpe_LU_MSG_Px_Iy80 ms
15​
IDE80004-ENG125667-Analysis 4-EE_pMax_LM_MSG_Px_Iy140 hPa
15​
IDE80004-ENG125666-Analysis 4-EE_pMax_LO_MSG_Px_Iy140 hPa
15​
IDE80004-ENG125668-Analysis 4-EE_pMax_LU_MSG_Px_Iy140 hPa
15​
IDE80004-ENG125673-Analysis 4-EE_tEnt_LM_MSG_Px_Iy5000 ms
15​
IDE80004-ENG125672-Analysis 4-EE_tEnt_LO_MSG_Px_Iy5000 ms
15​
IDE80004-ENG125674-Analysis 4-EE_tEnt_LU_MSG_Px_Iy5000 ms
15​
IDE80004-ENG125670-Analysis 4-EE_tHalte_LM_MSG_Px_Iy2000 ms
15​
IDE80004-ENG125669-Analysis 4-EE_tHalte_LO_MSG_Px_Iy2000 ms
15​
IDE80004-ENG125671-Analysis 4-EE_tHalte_LU_MSG_Px_Iy2000 ms
15​
IDE80004-ENG125676-Analysis 4-EE_tWarte_LM_MSG_Px_Iy6000 ms
15​
IDE80004-ENG125675-Analysis 4-EE_tWarte_LO_MSG_Px_Iy6000 ms
15​
IDE80004-ENG125677-Analysis 4-EE_tWarte_LU_MSG_Px_Iy6000 ms
15​
IDE80004-ENG125664-Analysis 4-EE_Upumpe_LM_MSG_Px_Iy80 ms
15​
IDE80004-ENG125663-Analysis 4-EE_Upumpe_LO_MSG_Px_Iy80 ms
15​
IDE80004-ENG125665-Analysis 4-EE_Upumpe_LU_MSG_Px_Iy80 ms
15​
IDE80005-ENG125667-Analysis 5-EE_pMax_LM_MSG_Px_Iy190 hPa
15​
IDE80005-ENG125666-Analysis 5-EE_pMax_LO_MSG_Px_Iy190 hPa
15​
IDE80005-ENG125668-Analysis 5-EE_pMax_LU_MSG_Px_Iy190 hPa
15​
IDE80005-ENG125673-Analysis 5-EE_tEnt_LM_MSG_Px_Iy6000 ms
15​
IDE80005-ENG125672-Analysis 5-EE_tEnt_LO_MSG_Px_Iy6000 ms
15​
IDE80005-ENG125674-Analysis 5-EE_tEnt_LU_MSG_Px_Iy6000 ms
15​
IDE80005-ENG125670-Analysis 5-EE_tHalte_LM_MSG_Px_Iy2000 ms
15​
IDE80005-ENG125669-Analysis 5-EE_tHalte_LO_MSG_Px_Iy2000 ms
15​
IDE80005-ENG125671-Analysis 5-EE_tHalte_LU_MSG_Px_Iy2000 ms
15​
IDE80005-ENG125676-Analysis 5-EE_tWarte_LM_MSG_Px_Iy7000 ms
15​
IDE80005-ENG125675-Analysis 5-EE_tWarte_LO_MSG_Px_Iy7000 ms
15​
IDE80005-ENG125677-Analysis 5-EE_tWarte_LU_MSG_Px_Iy7000 ms
15​
IDE80005-ENG125664-Analysis 5-EE_Upumpe_LM_MSG_Px_Iy80 ms
15​
IDE80005-ENG125663-Analysis 5-EE_Upumpe_LO_MSG_Px_Iy80 ms
15​
IDE80005-ENG125665-Analysis 5-EE_Upumpe_LU_MSG_Px_Iy80 ms
15​
IDE80006-ENG125667-Analysis 6-EE_pMax_LM_MSG_Px_Iy240 hPa
15​
IDE80006-ENG125666-Analysis 6-EE_pMax_LO_MSG_Px_Iy240 hPa
15​
IDE80006-ENG125668-Analysis 6-EE_pMax_LU_MSG_Px_Iy240 hPa
15​
IDE80006-ENG125673-Analysis 6-EE_tEnt_LM_MSG_Px_Iy7000 ms
15​
IDE80006-ENG125672-Analysis 6-EE_tEnt_LO_MSG_Px_Iy7000 ms
15​
IDE80006-ENG125674-Analysis 6-EE_tEnt_LU_MSG_Px_Iy7000 ms
15​
IDE80006-ENG125670-Analysis 6-EE_tHalte_LM_MSG_Px_Iy2000 ms
15​
IDE80006-ENG125669-Analysis 6-EE_tHalte_LO_MSG_Px_Iy2000 ms
15​
IDE80006-ENG125671-Analysis 6-EE_tHalte_LU_MSG_Px_Iy2000 ms
15​
IDE80006-ENG125676-Analysis 6-EE_tWarte_LM_MSG_Px_Iy8000 ms
15​
IDE80006-ENG125675-Analysis 6-EE_tWarte_LO_MSG_Px_Iy8000 ms
15​
IDE80006-ENG125677-Analysis 6-EE_tWarte_LU_MSG_Px_Iy8000 ms
15​
IDE80006-ENG125664-Analysis 6-EE_Upumpe_LM_MSG_Px_Iy80 ms
15​
IDE80006-ENG125663-Analysis 6-EE_Upumpe_LO_MSG_Px_Iy80 ms
15​
IDE80006-ENG125665-Analysis 6-EE_Upumpe_LU_MSG_Px_Iy80 ms
15​
IDE80007-ENG125682-Analysis 7-s_GrobleckerkennungDauer30 s
5​
IDE80007-ENG125680-Analysis 7-s_LatenzzeitHaengenderTaster60 s
5​
IDE80007-ENG125681-Analysis 7-s_Leckageerkennung
3​
5​
IDE80007-ENG125678-Analysis 7-s_UeberspannungsSschwelle16 V
5​
IDE80007-ENG125679-Analysis 7-s_UnterspannungsSchwelle9 V
5​
IDE80008-ENG125684-Analysis 8-s_DruckschwelleNachlauf50 hPa
30​
IDE80008-ENG126855-Analysis 8-s_Maximaldruck_LRD_m0 hPa
30​
IDE80008-ENG126854-Analysis 8-s_Maximaldruck_LRD_o280 hPa
30​
IDE80008-ENG126856-Analysis 8-s_Maximaldruck_LRD_u260 hPa
30​
IDE80008-ENG126857-Analysis 8-s_Maximaldruck_Sitzlehnenwangen350 hPa
30​
IDE80008-ENG126863-Analysis 8-s_Maximaldruck_Ueberlastschutz500 hPa
30​
IDE80008-ENG126862-Analysis 8-s_Maximaler_Differenzdruck_LRD_Vor_Zurueck5 hPa
30​
IDE80008-ENG126859-Analysis 8-s_Minimaldruck_LRD_m0 hPa
30​
IDE80008-ENG126858-Analysis 8-s_Minimaldruck_LRD_o15 hPa
30​
IDE80008-ENG126860-Analysis 8-s_Minimaldruck_LRD_u15 hPa
30​
IDE80008-ENG126864-Analysis 8-s_Minimaldruck_Massage22 hPa
30​
IDE80008-ENG126861-Analysis 8-s_MinimaldruckSitzlehnenwangen15 hPa
30​
IDE80008-ENG125683-Analysis 8-s_ZieldruckDerSitzlehnenwangenBeiPreCrash330 hPa
30​
IDE80009-ENG125687-Analysis 9-s_AnzahlDruckmessungenIntervallerhoehung2 counts
5​
IDE80009-ENG125689-Analysis 9-s_AussendruckschwelleNachregelung100 hPa
5​
IDE80009-ENG125685-Analysis 9-s_BasismessintervallNachregelung2 min
5​
IDE80009-ENG125688-Analysis 9-s_BlasendruckschwelleNachregelung10 hPa
5​
IDE80009-ENG125686-Analysis 9-s_ErhoehungsintervallNachregelung5 min
5​
IDE80011-ENG125667-Analysis 11-EE_pMax_LM_MSG_Px_Iy240 hPa
15​
IDE80011-ENG125666-Analysis 11-EE_pMax_LO_MSG_Px_Iy240 hPa
15​
IDE80011-ENG125668-Analysis 11-EE_pMax_LU_MSG_Px_Iy240 hPa
15​
IDE80011-ENG125673-Analysis 11-EE_tEnt_LM_MSG_Px_Iy7000 ms
15​
IDE80011-ENG125672-Analysis 11-EE_tEnt_LO_MSG_Px_Iy7000 ms
15​
IDE80011-ENG125674-Analysis 11-EE_tEnt_LU_MSG_Px_Iy7000 ms
15​
IDE80011-ENG125670-Analysis 11-EE_tHalte_LM_MSG_Px_Iy2000 ms
15​
IDE80011-ENG125669-Analysis 11-EE_tHalte_LO_MSG_Px_Iy2000 ms
15​
IDE80011-ENG125671-Analysis 11-EE_tHalte_LU_MSG_Px_Iy2000 ms
15​
IDE80011-ENG125676-Analysis 11-EE_tWarte_LM_MSG_Px_Iy8000 ms
15​
IDE80011-ENG125675-Analysis 11-EE_tWarte_LO_MSG_Px_Iy8000 ms
15​
IDE80011-ENG125677-Analysis 11-EE_tWarte_LU_MSG_Px_Iy8000 ms
15​
IDE80011-ENG125664-Analysis 11-EE_Upumpe_LM_MSG_Px_Iy80 ms
15​
IDE80011-ENG125663-Analysis 11-EE_Upumpe_LO_MSG_Px_Iy80 ms
15​
IDE80011-ENG125665-Analysis 11-EE_Upumpe_LU_MSG_Px_Iy80 ms
15​
IDE80012-ENG125693-Analysis 12-s_DauerFuerGrobleckerkennung30 s
5​
IDE80012-ENG125680-Analysis 12-s_LatenzzeitHaengenderTaster60 s
5​
IDE80012-ENG125681-Analysis 12-s_Leckageerkennung
3​
5​
IDE80012-ENG125678-Analysis 12-s_UeberspannungsSschwelle16 V
5​
IDE80012-ENG125679-Analysis 12-s_UnterspannungsSchwelle9 V
5​
IDE80013-ENG126871-Analysis 13-s_Druckschwelle_Nachlauf50 hPa
30​
IDE80013-ENG126855-Analysis 13-s_Maximaldruck_LRD_m0 hPa
30​
IDE80013-ENG126854-Analysis 13-s_Maximaldruck_LRD_o280 hPa
30​
IDE80013-ENG126856-Analysis 13-s_Maximaldruck_LRD_u260 hPa
30​
IDE80013-ENG126857-Analysis 13-s_Maximaldruck_Sitzlehnenwangen350 hPa
30​
IDE80013-ENG126863-Analysis 13-s_Maximaldruck_Ueberlastschutz500 hPa
30​
IDE80013-ENG126870-Analysis 13-s_Maximaler_Differenzdruck_LRD_VorZurueck5 hPa
30​
IDE80013-ENG126859-Analysis 13-s_Minimaldruck_LRD_m0 hPa
30​
IDE80013-ENG126858-Analysis 13-s_Minimaldruck_LRD_o15 hPa
30​
IDE80013-ENG126860-Analysis 13-s_Minimaldruck_LRD_u15 hPa
30​
IDE80013-ENG126864-Analysis 13-s_Minimaldruck_Massage22 hPa
30​
IDE80013-ENG126869-Analysis 13-s_Minimaldruck_Sitzlehnenwangen15 hPa
30​
IDE80013-ENG125683-Analysis 13-s_ZieldruckDerSitzlehnenwangenBeiPreCrash330 hPa
30​
IDE80014-ENG125687-Analysis 14-s_AnzahlDruckmessungenIntervallerhoehung2 counts
5​
IDE80014-ENG125689-Analysis 14-s_AussendruckschwelleNachregelung100 hPa
5​
IDE80014-ENG125685-Analysis 14-s_BasismessintervallNachregelung2 min
5​
IDE80014-ENG125688-Analysis 14-s_BlasendruckschwelleNachregelung10 hPa
5​
IDE80014-ENG125686-Analysis 14-s_ErhoehungsintervallNachregelung5 min
5​
IDE80015-ENG126865-Analysis 15-s_Kompressorleistung_Manuelle_Befuellung_LRD
100%​
6​
IDE80015-ENG126867-Analysis 15-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen
100%​
6​
IDE80015-ENG126866-Analysis 15-s_Kompressorleistung_Memorisierte_Befuellung_LRD
100%​
6​
IDE80015-ENG126868-Analysis 15-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen
100%​
6​
IDE80015-ENG125690-Analysis 15-s_VerzoegerungszeitKompressoranlauf120 ms
6​
IDE80016-Analysis 1610 s
1​
IDE80017-ENG133471-Analysis 17-Offset_PB1_LM0 hPa
50​
IDE80017-ENG133470-Analysis 17-Offset_PB1_LO0 hPa
50​
IDE80017-ENG133472-Analysis 17-Offset_PB1_LU0 hPa
50​
IDE80017-ENG133473-Analysis 17-Offset_PB1_SH0 hPa
50​
IDE80017-ENG133475-Analysis 17-Offset_PB2_LM0 hPa
50​
IDE80017-ENG133474-Analysis 17-Offset_PB2_LO0 hPa
50​
IDE80017-ENG133476-Analysis 17-Offset_PB2_LU0 hPa
50​
IDE80017-ENG133477-Analysis 17-Offset_PB2_SH0 hPa
50​
IDE80017-ENG133483-Analysis 17-Offset_PV1_LM0 ms
50​
IDE80017-ENG133482-Analysis 17-Offset_PV1_LO0 ms
50​
IDE80017-ENG133484-Analysis 17-Offset_PV1_LU0 ms
50​
IDE80017-ENG133485-Analysis 17-Offset_PV1_SH0 ms
50​
IDE80017-ENG133486-Analysis 17-Offset_PV2_LO0 ms
50​
IDE80017-ENG133488-Analysis 17-Offset_PV2_LU0 ms
50​
IDE80017-ENG133489-Analysis 17-Offset_PV2_SH0 ms
50​
IDE80017-ENG133480-Analysis 17-OffsetPP1
0%​
50​
IDE80017-ENG133481-Analysis 17-OffsetPP2
0%​
50​
IDE80017-ENG133487-Analysis 17-OffsetPV2_LMy0 ms
50​
IDE80017-ENG133478-Analysis 17-OffsetT10 °C
50​
IDE80017-ENG133479-Analysis 17-OffsetT20 °C
50​
IDE80017-ENG133490-Analysis 17-p_function_feedback_timeout200 ms
50​
IDE80017-ENG133491-Analysis 17-p_longpush_time500 ms
50​
IDE80017-ENG133497-Analysis 17-p_stoesselSchaltschwelle_eins
11%​
50​
IDE80017-ENG133498-Analysis 17-p_stoesselSchaltschwelle_zwei
22%​
50​
IDE80017-ENG133494-Analysis 17-p_tasterSchaltschwelle_drei
42%​
50​
IDE80017-ENG133492-Analysis 17-p_tasterSchaltschwelle_eins
10%​
50​
IDE80017-ENG133496-Analysis 17-p_tasterSchaltschwelle_fuenf
62%​
50​
IDE80017-ENG133495-Analysis 17-p_tasterSchaltschwelle_vier
46%​
50​
IDE80017-ENG133493-Analysis 17-p_tasterSchaltschwelle_zwei
32%​
50​
IDE80017-ENG133458-Analysis 17-s_Beruhigungszeit_Befuellen250 ms
50​
IDE80017-ENG133460-Analysis 17-s_Beruhigungszeit_Druckmessung250 ms
50​
IDE80017-ENG133459-Analysis 17-s_Beruhigungszeit_Entlueften250 ms
50​
IDE80017-ENG133469-Analysis 17-s_Faktor_Druck_Entlueftung_Seitenhalt
100​
50​
IDE80017-ENG133464-Analysis 17-s_IntervallUmgebungsbedingungen10 min
50​
IDE80017-ENG133465-Analysis 17-s_MaxIntervall30 min
50​
IDE80017-ENG133461-Analysis 17-s_Messdauer_Initialisierung5 ms
50​
IDE80017-ENG133462-Analysis 17-s_Messdauer_Kurzzeitmessung30 min
50​
IDE80017-ENG133463-Analysis 17-s_Messdauer_Langzeitmessung30 min
50​
IDE80017-ENG133468-Analysis 17-s_Sitzvariantevariant_2
50​
IDE80017-ENG133467-Analysis 17-s_Timeout_Befuell_Linearbereich10 s
50​
IDE80017-ENG133466-Analysis 17-s_Timeout_Befuell_Startbereich10 s
50​
IDE80017-ENG133457-Analysis 17-s_Uebernahmedruck_P_u
75%​
50​
IDE80017-ENG133456-Analysis 17-s_Uebernahmedruck_PUe_o
20%​
50​
IDE80018-ENG133471-Analysis 18-Offset_PB1_LM0 hPa
50​
IDE80018-ENG133472-Analysis 18-Offset_PB1_LU0 hPa
50​
IDE80018-ENG133473-Analysis 18-Offset_PB1_SH0 hPa
50​
IDE80018-ENG133475-Analysis 18-Offset_PB2_LM0 hPa
50​
IDE80018-ENG133474-Analysis 18-Offset_PB2_LO0 hPa
50​
IDE80018-ENG133476-Analysis 18-Offset_PB2_LU0 hPa
50​
IDE80018-ENG133477-Analysis 18-Offset_PB2_SH0 hPa
50​
IDE80018-ENG133483-Analysis 18-Offset_PV1_LM0 ms
50​
IDE80018-ENG133482-Analysis 18-Offset_PV1_LO0 ms
50​
IDE80018-ENG133484-Analysis 18-Offset_PV1_LU0 ms
50​
IDE80018-ENG133485-Analysis 18-Offset_PV1_SH0 ms
50​
IDE80018-ENG133486-Analysis 18-Offset_PV2_LO0 ms
50​
IDE80018-ENG133488-Analysis 18-Offset_PV2_LU0 ms
50​
IDE80018-ENG133489-Analysis 18-Offset_PV2_SH0 ms
50​
IDE80018-ENG133534-Analysis 18-OffsetPB1_LO0 hPa
50​
IDE80018-ENG133480-Analysis 18-OffsetPP1
0%​
50​
IDE80018-ENG133481-Analysis 18-OffsetPP2
0%​
50​
IDE80018-ENG133487-Analysis 18-OffsetPV2_LMy0 ms
50​
IDE80018-ENG133478-Analysis 18-OffsetT10 °C
50​
IDE80018-ENG133479-Analysis 18-OffsetT20 °C
50​
IDE80018-ENG133490-Analysis 18-p_function_feedback_timeout200 ms
50​
IDE80018-ENG133491-Analysis 18-p_longpush_time500 ms
50​
IDE80018-ENG133497-Analysis 18-p_stoesselSchaltschwelle_eins
11%​
50​
IDE80018-ENG133498-Analysis 18-p_stoesselSchaltschwelle_zwei
22%​
50​
IDE80018-ENG133494-Analysis 18-p_tasterSchaltschwelle_drei
42%​
50​
IDE80018-ENG133492-Analysis 18-p_tasterSchaltschwelle_eins
10%​
50​
IDE80018-ENG133496-Analysis 18-p_tasterSchaltschwelle_fuenf
62%​
50​
IDE80018-ENG133495-Analysis 18-p_tasterSchaltschwelle_vier
46%​
50​
IDE80018-ENG133493-Analysis 18-p_tasterSchaltschwelle_zwei
32%​
50​
IDE80018-ENG133458-Analysis 18-s_Beruhigungszeit_Befuellen250 ms
50​
IDE80018-ENG133460-Analysis 18-s_Beruhigungszeit_Druckmessung250 ms
50​
IDE80018-ENG133459-Analysis 18-s_Beruhigungszeit_Entlueften250 ms
50​
IDE80018-ENG133469-Analysis 18-s_Faktor_Druck_Entlueftung_Seitenhalt
100​
50​
IDE80018-ENG133464-Analysis 18-s_IntervallUmgebungsbedingungen10 min
50​
IDE80018-ENG133465-Analysis 18-s_MaxIntervall30 min
50​
IDE80018-ENG133461-Analysis 18-s_Messdauer_Initialisierung5 ms
50​
IDE80018-ENG133462-Analysis 18-s_Messdauer_Kurzzeitmessung30 min
50​
IDE80018-ENG133463-Analysis 18-s_Messdauer_Langzeitmessung30 min
50​
IDE80018-ENG133468-Analysis 18-s_Sitzvariantevariant_2
50​
IDE80018-ENG133467-Analysis 18-s_Timeout_Befuell_Linearbereich10 s
50​
IDE80018-ENG133466-Analysis 18-s_Timeout_Befuell_Startbereich10 s
50​
IDE80018-ENG133532-Analysis 18-s_Uebernahmedruck_PUe_u
20%​
50​
IDE80018-ENG133533-Analysis 18-s_UebernahmedruckP_u
75%​
50​
MAS01490-ENG142027-Energy management-Energiemanagement Abschaltungactive
5​
MAS01490-ENG116830-Energy management-Energy_Management_AdaptationEnergy management active
5​
MAS01490-ENG142256-Energy management-Hochvoltfahrzeugnot installed
5​
MAS01490-ENG141950-Energy management-Hybrid vehicleNo
5​
MAS01490-ENG133400-Energy management-Praediktives_Energiemanagementnot active
5​
MAS01490-ENG141978-Energy management-Recuperationactive
5​
MAS01490-ENG142037-Energy management-Zweitbatterienot installed
5​
MAS05055-lower turn position42.494463 °
2​
MAS05056-upper turn position171.494335 °
2​
MAS08228-ENG133434-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze1200 lx
24​
MAS08228-ENG133435-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze2200 lx
24​
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle1000 lx
24​
MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO600 lx
24​
MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten1200 lx
24​
MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten2200 lx
24​
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red00 50
24​
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell4000 lx
24​
MAS08228-ENG142230-Light sensor-HMI_Exterior_light_on_highwaynot active
24​
MAS08228-ENG142231-Light sensor-HMI_Exterior_light_on_rainnot active
24​
MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivityfrueh
24​
MAS08228-ENG142229-Light sensor-HMI_Wiper_Comfort_Rain_Sensor_OFFnot active
24​
MAS08228-ENG126628-Light sensor-LS_Error_Ausgabenot active
24​
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung4500 mV
24​
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke6000 lx
24​
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung2000 mV
24​
MAS08228-ENG133439-Light sensor-Minimale_Beleuchtungsstaerke0 lx
24​
MAS08228-ENG133443-Light sensor-Tunnel_einschalt_verzoegerung
2​
24​
ENG153709-ENG154696-Aktivierung_Entwicklungsdiagnose-log_dtc_statusnot active
9​
ENG153709-ENG154697-Aktivierung_Entwicklungsdiagnose-log-dtc_DFCC00 00 00
9​
ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTCFirst_dtc
9​
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahrennot active
4​
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FTnot active
4​
ENG141683-ENG141975-Allwetterlicht_Spoiler-tt_spoilerelektrischer Spoiler
4​
ENG153710-ENG154516-Ambience_lightning_color_list_2-Blauwert Farbe 11
0​
60​
ENG153710-ENG154517-Ambience_lightning_color_list_2-Blauwert Farbe 12
0​
60​
ENG153710-ENG154518-Ambience_lightning_color_list_2-Blauwert Farbe 13
0​
60​
ENG153710-ENG154519-Ambience_lightning_color_list_2-Blauwert Farbe 14
0​
60​
ENG153710-ENG154520-Ambience_lightning_color_list_2-Blauwert Farbe 15
0​
60​
ENG153710-ENG154521-Ambience_lightning_color_list_2-Blauwert Farbe 16
0​
60​
ENG153710-ENG154522-Ambience_lightning_color_list_2-Blauwert Farbe 17
0​
60​
ENG153710-ENG154523-Ambience_lightning_color_list_2-Blauwert Farbe 18
0​
60​
ENG153710-ENG154524-Ambience_lightning_color_list_2-Blauwert Farbe 19
0​
60​
ENG153710-ENG154525-Ambience_lightning_color_list_2-Blauwert Farbe 20
0​
60​
ENG153710-ENG154539-Ambience_lightning_color_list_2-Blauwert_Farbe_21
0​
60​
ENG153710-ENG154541-Ambience_lightning_color_list_2-Blauwert_Farbe_22
0​
60​
ENG153710-ENG154543-Ambience_lightning_color_list_2-Blauwert_Farbe_23
0​
60​
ENG153710-ENG154545-Ambience_lightning_color_list_2-Blauwert_Farbe_24
0​
60​
ENG153710-ENG154547-Ambience_lightning_color_list_2-Blauwert_Farbe_25
0​
60​
ENG153710-ENG154549-Ambience_lightning_color_list_2-Blauwert_Farbe_26
0​
60​
ENG153710-ENG154551-Ambience_lightning_color_list_2-Blauwert_Farbe_27
0​
60​
ENG153710-ENG154553-Ambience_lightning_color_list_2-Blauwert_Farbe_28
0​
60​
ENG153710-ENG154555-Ambience_lightning_color_list_2-Blauwert_Farbe_29
0​
60​
ENG153710-ENG154558-Ambience_lightning_color_list_2-Blauwert_Farbe_30
0​
60​
ENG153710-ENG154635-Ambience_lightning_color_list_2-Gruenwert Farbe 11
0​
60​
ENG153710-ENG154636-Ambience_lightning_color_list_2-Gruenwert Farbe 12
0​
60​
ENG153710-ENG154637-Ambience_lightning_color_list_2-Gruenwert Farbe 13
0​
60​
ENG153710-ENG154638-Ambience_lightning_color_list_2-Gruenwert Farbe 14
0​
60​
ENG153710-ENG154639-Ambience_lightning_color_list_2-Gruenwert Farbe 15
0​
60​
ENG153710-ENG154640-Ambience_lightning_color_list_2-Gruenwert Farbe 16
0​
60​
ENG153710-ENG154641-Ambience_lightning_color_list_2-Gruenwert Farbe 17
0​
60​
ENG153710-ENG154642-Ambience_lightning_color_list_2-Gruenwert Farbe 18
0​
60​
ENG153710-ENG154643-Ambience_lightning_color_list_2-Gruenwert Farbe 19
0​
60​
ENG153710-ENG154644-Ambience_lightning_color_list_2-Gruenwert Farbe 20
0​
60​
ENG153710-ENG154658-Ambience_lightning_color_list_2-Gruenwert_Farbe_21
0​
60​
ENG153710-ENG154660-Ambience_lightning_color_list_2-Gruenwert_Farbe_22
0​
60​
ENG153710-ENG154662-Ambience_lightning_color_list_2-Gruenwert_Farbe_23
0​
60​
ENG153710-ENG154664-Ambience_lightning_color_list_2-Gruenwert_Farbe_24
0​
60​
ENG153710-ENG154666-Ambience_lightning_color_list_2-Gruenwert_Farbe_25
0​
60​
ENG153710-ENG154668-Ambience_lightning_color_list_2-Gruenwert_Farbe_26
0​
60​
ENG153710-ENG154670-Ambience_lightning_color_list_2-Gruenwert_Farbe_27
0​
60​
ENG153710-ENG154672-Ambience_lightning_color_list_2-Gruenwert_Farbe_28
0​
60​
ENG153710-ENG154674-Ambience_lightning_color_list_2-Gruenwert_Farbe_29
0​
60​
ENG153710-ENG154677-Ambience_lightning_color_list_2-Gruenwert_Farbe_30
0​
60​
ENG153710-ENG154723-Ambience_lightning_color_list_2-Rotwert Farbe 11
0​
60​
ENG153710-ENG154724-Ambience_lightning_color_list_2-Rotwert Farbe 12
0​
60​
ENG153710-ENG154725-Ambience_lightning_color_list_2-Rotwert Farbe 13
0​
60​
ENG153710-ENG154726-Ambience_lightning_color_list_2-Rotwert Farbe 14
0​
60​
ENG153710-ENG154727-Ambience_lightning_color_list_2-Rotwert Farbe 15
0​
60​
ENG153710-ENG154728-Ambience_lightning_color_list_2-Rotwert Farbe 16
0​
60​
ENG153710-ENG154729-Ambience_lightning_color_list_2-Rotwert Farbe 17
0​
60​
ENG153710-ENG154730-Ambience_lightning_color_list_2-Rotwert Farbe 18
0​
60​
ENG153710-ENG154731-Ambience_lightning_color_list_2-Rotwert Farbe 19
0​
60​
ENG153710-ENG154732-Ambience_lightning_color_list_2-Rotwert Farbe 20
0​
60​
ENG153710-ENG154746-Ambience_lightning_color_list_2-Rotwert_Farbe_21
0​
60​
ENG153710-ENG154748-Ambience_lightning_color_list_2-Rotwert_Farbe_22
0​
60​
ENG153710-ENG154750-Ambience_lightning_color_list_2-Rotwert_Farbe_23
0​
60​
ENG153710-ENG154752-Ambience_lightning_color_list_2-Rotwert_Farbe_24
0​
60​
ENG153710-ENG154754-Ambience_lightning_color_list_2-Rotwert_Farbe_25
0​
60​
ENG153710-ENG154756-Ambience_lightning_color_list_2-Rotwert_Farbe_26
0​
60​
ENG153710-ENG154758-Ambience_lightning_color_list_2-Rotwert_Farbe_27
0​
60​
ENG153710-ENG154760-Ambience_lightning_color_list_2-Rotwert_Farbe_28
0​
60​
ENG153710-ENG154762-Ambience_lightning_color_list_2-Rotwert_Farbe_29
0​
60​
ENG153710-ENG154765-Ambience_lightning_color_list_2-Rotwert_Farbe_30
0​
60​
ENG153711-ENG154528-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_11_lin
0​
60​
ENG153711-ENG154529-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_12_lin
0​
60​
ENG153711-ENG154530-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_13_lin
0​
60​
ENG153711-ENG154531-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_14_lin
0​
60​
ENG153711-ENG154532-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_15_lin
0​
60​
ENG153711-ENG154533-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_16_lin
0​
60​
ENG153711-ENG154534-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_17_lin
0​
60​
ENG153711-ENG154535-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_18_lin
0​
60​
ENG153711-ENG154536-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_19_lin
0​
60​
ENG153711-ENG154538-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_20_lin
0​
60​
ENG153711-ENG154540-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_21_lin
0​
60​
ENG153711-ENG154542-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_22_lin
0​
60​
ENG153711-ENG154544-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_23_lin
0​
60​
ENG153711-ENG154546-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_24_lin
0​
60​
ENG153711-ENG154548-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_25_lin
0​
60​
ENG153711-ENG154550-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_26_lin
0​
60​
ENG153711-ENG154552-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_27_lin
0​
60​
ENG153711-ENG154554-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_28_lin
0​
60​
ENG153711-ENG154556-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_29_lin
0​
60​
ENG153711-ENG154559-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_30_lin
0​
60​
ENG153711-ENG154647-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_11_lin
0​
60​
ENG153711-ENG154648-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_12_lin
0​
60​
ENG153711-ENG154649-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_13_lin
0​
60​
ENG153711-ENG154650-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_14_lin
0​
60​
ENG153711-ENG154651-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_15_lin
0​
60​
ENG153711-ENG154652-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_16_lin
0​
60​
ENG153711-ENG154653-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_17_lin
0​
60​
ENG153711-ENG154654-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_18_lin
0​
60​
ENG153711-ENG154655-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_19_lin
0​
60​
ENG153711-ENG154657-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_20_lin
0​
60​
ENG153711-ENG154659-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_21_lin
0​
60​
ENG153711-ENG154661-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_22_lin
0​
60​
ENG153711-ENG154663-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_23_lin
0​
60​
ENG153711-ENG154665-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_24_lin
0​
60​
ENG153711-ENG154667-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_25_lin
0​
60​
ENG153711-ENG154669-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_26_lin
0​
60​
ENG153711-ENG154671-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_27_lin
0​
60​
ENG153711-ENG154673-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_28_lin
0​
60​
ENG153711-ENG154675-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_29_lin
0​
60​
ENG153711-ENG154678-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_30_lin
0​
60​
ENG153711-ENG154735-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_11_lin
0​
60​
ENG153711-ENG154736-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_12_lin
0​
60​
ENG153711-ENG154737-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_13_lin
0​
60​
ENG153711-ENG154738-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_14_lin
0​
60​
ENG153711-ENG154739-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_15_lin
0​
60​
ENG153711-ENG154740-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_16_lin
0​
60​
ENG153711-ENG154741-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_17_lin
0​
60​
ENG153711-ENG154742-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_18_lin
0​
60​
ENG153711-ENG154743-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_19_lin
0​
60​
ENG153711-ENG154745-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_20_lin
0​
60​
ENG153711-ENG154747-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_21_lin
0​
60​
ENG153711-ENG154749-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_22_lin
0​
60​
ENG153711-ENG154751-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_23_lin
0​
60​
ENG153711-ENG154753-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_24_lin
0​
60​
ENG153711-ENG154755-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_25_lin
0​
60​
ENG153711-ENG154757-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_26_lin
0​
60​
ENG153711-ENG154759-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_27_lin
0​
60​
ENG153711-ENG154761-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_28_lin
0​
60​
ENG153711-ENG154763-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_29_lin
0​
60​
ENG153711-ENG154766-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_30_lin
0​
60​
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1
0​
30​
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10
0​
30​
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11
0​
30​
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12
0​
30​
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13
0​
30​
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14
0​
30​
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15
0​
30​
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2
0​
30​
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3
0​
30​
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4
0​
30​
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5
0​
30​
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6
0​
30​
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7
0​
30​
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8
0​
30​
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9
0​
30​
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1NOT-DEFINED
30​
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10NOT-DEFINED
30​
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11NOT-DEFINED
30​
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12NOT-DEFINED
30​
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13NOT-DEFINED
30​
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14NOT-DEFINED
30​
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15NOT-DEFINED
30​
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2NOT-DEFINED
30​
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3NOT-DEFINED
30​
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4NOT-DEFINED
30​
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5NOT-DEFINED
30​
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6NOT-DEFINED
30​
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7NOT-DEFINED
30​
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8NOT-DEFINED
30​
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9NOT-DEFINED
30​
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1not installed
30​
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10not installed
30​
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11not installed
30​
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12not installed
30​
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13not installed
30​
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14not installed
30​
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15not installed
30​
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2not installed
30​
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3not installed
30​
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4not installed
30​
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5not installed
30​
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6not installed
30​
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7not installed
30​
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8not installed
30​
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9not installed
30​
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12
0​
60​
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1
0​
60​
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10
0​
60​
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11
0​
60​
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13
0​
60​
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14
0​
60​
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15
0​
60​
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16
0​
60​
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17
0​
60​
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18
0​
60​
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19
0​
60​
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2
0​
60​
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20
0​
60​
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3
0​
60​
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4
0​
60​
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5
0​
60​
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6
0​
60​
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7
0​
60​
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8
0​
60​
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9
0​
60​
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1
0​
60​
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10
0​
60​
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11
0​
60​
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12
0​
60​
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13
0​
60​
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14
0​
60​
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15
0​
60​
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16
0​
60​
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17
0​
60​
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18
0​
60​
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19
0​
60​
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2
0​
60​
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20
0​
60​
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3
0​
60​
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4
0​
60​
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5
0​
60​
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6
0​
60​
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7
0​
60​
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9
0​
60​
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8
0​
60​
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1not installed
60​
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10not installed
60​
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11not installed
60​
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12not installed
60​
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13not installed
60​
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14not installed
60​
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15not installed
60​
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16not installed
60​
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17not installed
60​
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18not installed
60​
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19not installed
60​
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2not installed
60​
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20not installed
60​
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3not installed
60​
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4not installed
60​
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5not installed
60​
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6not installed
60​
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7not installed
60​
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9not installed
60​
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8not installed
60​
ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-AmbienteSollspannungsanforderung 13.5
23​
ENG153712-ENG154602-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_0
1​
23​
ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1
1​
23​
ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10
1​
23​
ENG153712-ENG154605-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_11
1​
23​
ENG153712-ENG154606-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_12
1​
23​
ENG153712-ENG154607-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_13
1​
23​
ENG153712-ENG154608-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_14
1​
23​
ENG153712-ENG154609-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_15
1​
23​
ENG153712-ENG154610-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_2
1​
23​
ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3
1​
23​
ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4
1​
23​
ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5
1​
23​
ENG153712-ENG154614-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_6
1​
23​
ENG153712-ENG154615-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_7
1​
23​
ENG153712-ENG154616-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_8
1​
23​
ENG153712-ENG154617-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_9
1​
23​
ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinkenactive
10​
ENG141649-ENG133379-Außenlicht_Blinker-Abbruch Komfortblinkennot active
10​
ENG141649-ENG116590-Außenlicht_Blinker-Blinkkontrolleuchte fuer Anhaengerseparte
10​
ENG141649-ENG121966-Außenlicht_Blinker-Crash flashingnot active
10​
ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinkenactive
10​
ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittungactive
10​
ENG141649-ENG142195-Außenlicht_Blinker-Dynamische_Blink_Delay50 ms
10​
ENG141649-ENG126819-Außenlicht_Blinker-Emergency_alert_blinkennot active
10​
ENG141649-ENG154601-Außenlicht_Blinker-Fahrerassistenz_BlinkenfunktionenWarnblinke_zulaessig
10​
ENG141649-ENG115774-Außenlicht_Blinker-Komfortblinkenactive
10​
ENG141649-ENG116587-Außenlicht_Blinker-Komfortblinken Blinkzyklen
3​
10​
ENG141649-ENG122208-Außenlicht_Blinker-Multi_kollisions_Blinkennot active
10​
ENG141649-ENG122209-Außenlicht_Blinker-Notwarn_blinken_NBA_Phase_2not active
10​
ENG141649-ENG121967-Außenlicht_Blinker-Panic flashingactive
10​
ENG141649-ENG154711-Außenlicht_Blinker-PreCrash_RECASPreCrash_passiv
10​
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_linksactive
10​
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechtsactive
10​
ENG141649-ENG249932-Außenlicht_Blinker-Rollenmodusblinkennot active
10​
ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinkenactive
10​
ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashingactive
10​
ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinkenactive
10​
ENG141649-ENG251922-Außenlicht_Blinker-Travel_Assist_Blinkennot active
10​
ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinkenactive
10​
ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenznot active
10​
ENG141649-ENG246997-Außenlicht_Blinker-Warnblinken_TP_max120 min
10​
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUSactive
10​
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EINactive
10​
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_aufactive
10​
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zuactive
10​
ENG141647-ENG141986-Außenlicht_Front-Abblendlicht_LeuchtentypH7
9​
ENG141647-ENG246962-Außenlicht_Front-ABL Redundanz Check sperrenactive
9​
ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze350 km/h
9​
ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze350 km/h
9​
ENG141647-ENG115833-Außenlicht_Front-Fahrlicht bei TagDaytime running lamps
9​
ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL4 km/h
9​
ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglichnot active
9​
ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlichtactive
9​
ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrumentnot active
9​
ENG141647-ENG142190-Außenlicht_Front-Signaturlicht_verbautnot installed
9​
ENG141647-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlichtnot active
9​
ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglichactive
9​
ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschaltennot active
9​
ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTOnot active
9​
ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlichtnot active
9​
ENG141647-ENG115733-Außenlicht_Front-Tagfahrlichtkontrollleuchtenot active
9​
ENG141647-ENG142192-Außenlicht_Front-TFL_Abschaltung_ueber_Geschwindigkeitactive
9​
ENG141647-ENG116591-Außenlicht_Front-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolgeactive
9​
ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitierenlimitieren
9​
ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_BlinklichtNo
5​
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit0 km/h
5​
ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBAnot active
5​
ENG141648-ENG115831-Aussenlicht_Heck-Schlusslicht mit Bremslichtfunktionactive
5​
ENG141648-ENG142004-Aussenlicht_Heck-Umgreifende_Heckklappenot installed
5​
ENG141656-ENG249813-Außenlicht_uebergreifend-ABL_Abschaltung_nach_ECE48_Rev6No
18​
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lightinstalled
18​
ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzungabschaltbar über Energiemanagement
18​
ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzungabschaltbar über Energiemanagement
18​
ENG141656-ENG142188-Außenlicht_uebergreifend-bewusstes StandlichtAktive Begrenzung
18​
ENG141656-ENG246968-Außenlicht_uebergreifend-CHo_LHo_Nachlauf0 ms
18​
ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home LeuchtenLow beam
18​
ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatusautomatic
18​
ENG141656-ENG116604-Außenlicht_uebergreifend-Coming-home EinschaltereignisDriver door
18​
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfachnot active
18​
ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_KonfigHinweis_in_LDS-Stellung_Null_und_SL
18​
ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer VerfuegbarkeitstimerFaktor fuer x1 Stunden
18​
ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LHKeine_Spannungsanforderung
18​
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog lampKeine_Spannungsanforderung
18​
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung96 lx
18​
ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung800 lx
18​
ENG141656-ENG142189-Außenlicht_uebergreifend-HVLM_LadezustandsanzeigeNo
18​
ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslichtseparate
18​
ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinkerfalse
18​
ENG141656-ENG141992-Außenlicht_uebergreifend-LDS_mit_AFLYes
18​
ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_SchlusslichtYes
18​
ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_NebellichtYes
18​
ENG141656-ENG141993-Außenlicht_uebergreifend-LDS_mit_StandlichtstellungYes
18​
ENG141656-ENG115657-Außenlicht_uebergreifend-Leaving-Home VerbausstatusEnabled
18​
ENG141656-ENG249901-Außenlicht_uebergreifend-Licht_Schaltung_nach_ECE48_Rev6not active
18​
ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS)LIN
18​
ENG141656-ENG115862-Außenlicht_uebergreifend-Lichtwarnungsverhaltenklemmenabhaengig
18​
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Modulenot installed
18​
ENG141656-ENG98354-Außenlicht_uebergreifend-Low beamKeine_Spannungsanforderung
18​
ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHOMenuesteuerung aktivieren
18​
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome20 seconds
18​
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP60 seconds
18​
ENG141656-ENG116602-Außenlicht_uebergreifend-Menuesteuerung Coming Home Werkseinstellungactive
18​
ENG141656-ENG116606-Außenlicht_uebergreifend-Menuesteuerung Leaving-home Freischaltung per BAPactive
18​
ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviertnot active
18​
ENG141656-ENG126816-Außenlicht_uebergreifend-Standlicht ausactive
18​
ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklichtactive
18​
ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit8 s
18​
ENG141656-ENG249943-Außenlicht_uebergreifend-TFL_Abschaltung_nach_ECE48_Rev6No
18​
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal lampKeine_Spannungsanforderung
18​
ENG141656-ENG126817-Außenlicht_uebergreifend-Umfeldleuchte als Manoevrierleuchtenot active
18​
ENG126647-ENG98399-debug_light_function-Activation
0​
11​
ENG126647-ENG101417-debug_light_function-Adresse
0​
11​
ENG126647-ENG126820-debug_light_function-Bitmask
0​
11​
ENG126647-ENG126821-debug_light_function-Divisor
0​
11​
ENG126647-ENG98827-debug_light_function-Offset
0​
11​
ENG126647-ENG126822-debug_light_function-Polaritaet
0​
11​
ENG246955-ENG246967-digital_key-central_locking_digital_key_generalnot installed
3​
ENG246955-ENG246972-digital_key-komfortbedienung_fh_oeffnen_ueber_btlenot active
3​
ENG246955-ENG246973-digital_key-komfortbedienung_fh_oeffnen_ueber_btle_sonderfunktionnot active
3​
ENG246955-ENG246974-digital_key-komfortbedienung_fh_oeffnen_ueber_nfc_fahrertuernot active
3​
ENG246955-ENG246975-digital_key-komfortbedienung_fh_schliessen_ueber_btlenot active
3​
ENG246955-ENG246976-digital_key-komfortbedienung_fh_schliessen_ueber_btle_sonderfunktionnot active
3​
ENG246955-ENG246977-digital_key-komfortbedienung_fh_schliessen_ueber_nfc_fahrertuernot active
3​
ENG246955-ENG246991-digital_key-pa_Two_Keysnot active
3​
ENG141675-ENG115658-Dimmunt_KL_58xs_PWM-x0
0.00%​
6​
ENG141675-ENG101574-Dimmunt_KL_58xs_PWM-X1
50.00%​
6​
ENG141675-ENG99557-Dimmunt_KL_58xs_PWM-X2
100.00%​
6​
ENG141675-ENG115659-Dimmunt_KL_58xs_PWM-y0
0.00%​
6​
ENG141675-ENG99777-Dimmunt_KL_58xs_PWM-Y1
50.00%​
6​
ENG141675-ENG100480-Dimmunt_KL_58xs_PWM-Y2
100.00%​
6​
ENG125597-ENG126865-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manuelle_Befuellung_LRD
100%​
6​
ENG125597-ENG126867-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen
100%​
6​
ENG125597-ENG126866-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_LRD
100%​
6​
ENG125597-ENG126868-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen
100%​
6​
ENG125597-ENG125690-Driver_compressor_parameter_multi-contour_seat-s_VerzoegerungszeitKompressoranlauf120 ms
6​
ENG133364-ENG133507-Driver_multi-contour_seat_Error_Mask-ERROR_CODE_PIN0 bit
66​
ENG133364-ENG133526-Driver_multi-contour_seat_Error_Mask-ERROR_EEPROM31743 bit
66​
ENG133364-ENG133528-Driver_multi-contour_seat_Error_Mask-ERROR_HW_VERSION31743 bit
66​
ENG133364-ENG133500-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB1_CTRL_LEAK0 bit
66​
ENG133364-ENG133499-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB1_LEAK0 bit
66​
ENG133364-ENG133502-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB2_CTRL_LEAK0 bit
66​
ENG133364-ENG133501-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB2_LEAK0 bit
66​
ENG133364-ENG133504-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB3_CTRL_LEAK0 bit
66​
ENG133364-ENG133503-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB3_LEAK0 bit
66​
ENG133364-ENG133511-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_BLOCK31743 bit
66​
ENG133364-ENG133508-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_OPEN31743 bit
66​
ENG133364-ENG133509-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_GND31743 bit
66​
ENG133364-ENG133510-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_UB31743 bit
66​
ENG133364-ENG133524-Driver_multi-contour_seat_Error_Mask-ERROR_RAM31743 bit
66​
ENG133364-ENG133525-Driver_multi-contour_seat_Error_Mask-ERROR_ROM31743 bit
66​
ENG133364-ENG133506-Driver_multi-contour_seat_Error_Mask-ERROR_SIDE_CTRL_LEAK0 bit
66​
ENG133364-ENG133505-Driver_multi-contour_seat_Error_Mask-ERROR_SIDE_LEAK0 bit
66​
ENG133364-ENG133531-Driver_multi-contour_seat_Error_Mask-ERROR_SIG_RESPONSE0 bit
66​
ENG133364-ENG133512-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_10 bit
66​
ENG133364-ENG133515-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_20 bit
66​
ENG133364-ENG133518-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_30 bit
66​
ENG133364-ENG133521-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_40 bit
66​
ENG133364-ENG133513-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_10 bit
66​
ENG133364-ENG133516-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_20 bit
66​
ENG133364-ENG133519-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_30 bit
66​
ENG133364-ENG133522-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_40 bit
66​
ENG133364-ENG133514-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_10 bit
66​
ENG133364-ENG133517-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_20 bit
66​
ENG133364-ENG133520-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_30 bit
66​
ENG133364-ENG133523-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_40 bit
66​
ENG133364-ENG133529-Driver_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_HIGH0 bit
66​
ENG133364-ENG133530-Driver_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_LOW0 bit
66​
ENG133364-ENG133527-Driver_multi-contour_seat_Error_Mask-ERROR_WDT31743 bit
66​
ENG122925-DWA_Interior_Monitoring_Data_Set_DevelopmentFF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
150​
ENG122934-erase_error_table00 00 00
3​
ENG141650-MAS13782-Fernlicht_assistent-Will Beam assistant: responsivity adjustable via BAPpresent
6​
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_FernlichtsteuerungAFS: Fernlicht ueber AFS
6​
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Resetactive
6​
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistentnot installed
6​
ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellungnot installed
6​
ENG141685-Front_wash_function
10​
2​
ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRAactive
6​
ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung500 ms
6​
ENG141682-ENG115836-Front_wiper-Frontwischer Notlaufprogrammactive
6​
ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlaufnot active
6​
ENG141682-ENG154620-Front_wiper-Frontwischer Spannungsanforderung_konfigKeine_Spannungsanforderung
6​
ENG141682-ENG133394-Front_wiper-Frontwischer_Abtaupositionnot active
6​
ENG141682-ENG141966-Front_wiper-FrontwischertypLIN
6​
ENG141682-ENG116617-Front_wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltungactive
6​
ENG141682-ENG116615-Front_wiper-Menuesteuerung Frontwischernot active
6​
ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer2000 ms
6​
ENG141682-ENG115771-Front_wiper-Regensensor aktivierenDeactivating
6​
ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay300 ms
6​
ENG141682-ENG116616-Front_wiper-Tippwischen mit erhoehter Wischfrequenzactive
6​
ENG141682-ENG116618-Front_wiper-Traenenwischen Front Statusactive
6​
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierungnot active
6​
ENG141682-ENG126844-Front_wiper-Washer_Tipwiping_Variantnot active
6​
ENG141682-ENG116613-Front_wiper-Wischer abparken bei Oeffnen der Motorhaubenot active
6​
ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 ausnot active
6​
ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaubeactive
6​
ENG99457-ENG117394-Head area heater-blower_speed
0​
2​
ENG99457-ENG98971-Head area heater-Temperature
-3​
2​
ENG141645-MAS00211-HW_Verbau-Insufficient brake fluidinstalled
8​
ENG141645-MAS00212-HW_Verbau-Insufficient washer fluidinstalled
8​
ENG141645-MAS00213-HW_Verbau-Insufficient coolantinstalled
8​
ENG141645-MAS00214-HW_Verbau-Brake pad wearinstalled
8​
ENG141645-ENG142026-HW_Verbau-Druckklappenot installed
8​
ENG141645-ENG141963-HW_Verbau-Elektrische Laderaumabdeckung aktivnot active
8​
ENG141645-ENG142012-HW_Verbau-Elektrische_Laderaumabdeckungnot installed
8​
ENG141645-ENG141952-HW_Verbau-Exterior temp. sensorinstalled
8​
ENG141645-ENG142005-HW_Verbau-Kontaktschalter_fuer_Motorhaubeinstalled
8​
ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelungnot installed
8​
ENG141645-ENG142036-HW_Verbau-PTC Zuheizernot installed
8​
ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15not active
8​
ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelungnot active
8​
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0
0.00%​
30​
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1
-0.50%​
30​
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2
-1.00%​
30​
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3
-1.50%​
30​
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4
-2.00%​
30​
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5
-2.50%​
30​
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6
-3.00%​
30​
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7
-3.5​
30​
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8
-4.00%​
30​
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9
-4.50%​
30​
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0
100.00%​
30​
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1
90.00%​
30​
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2
80.00%​
30​
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3
70.00%​
30​
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4
60.00%​
30​
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5
50.00%​
30​
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6
40.00%​
30​
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7
30.00%​
30​
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8
15.00%​
30​
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9
0.00%​
30​
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0maximize
16​
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0maximize
16​
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0maximize
16​
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0
127​
16​
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0
0​
16​
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0
0​
16​
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0
0​
16​
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0
14​
16​
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0
34​
16​
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 033 - LED-Modul Blinkleuchten
16​
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0Always
16​
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0Blinken links Hellphase
16​
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0not active
16​
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0Blinken links Dunkelphase
16​
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0not active
16​
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0not active
16​
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0not active
16​
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0not active
16​
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0not active
16​
ENG141657-ENG116167-Leuchte 35 LED Warnblinktaster C48-Dimming Direction CD 15maximize
16​
ENG141657-ENG116171-Leuchte 35 LED Warnblinktaster C48-Dimming Direction EF 15maximize
16​
ENG141657-ENG116175-Leuchte 35 LED Warnblinktaster C48-Dimming Direction GH 15maximize
16​
ENG141657-ENG116162-Leuchte 35 LED Warnblinktaster C48-Dimmwert AB 15
100​
16​
ENG141657-ENG116166-Leuchte 35 LED Warnblinktaster C48-Dimmwert CD 15
0​
16​
ENG141657-ENG116170-Leuchte 35 LED Warnblinktaster C48-Dimmwert EF 15
0​
16​
ENG141657-ENG116174-Leuchte 35 LED Warnblinktaster C48-Dimmwert GH 15
0​
16​
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15
63​
16​
ENG141657-ENG116566-Leuchte 35 LED Warnblinktaster C48-Lampendefektbitposition 15
0​
16​
ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 1541 - LED Kleinleistung
16​
ENG141657-ENG116163-Leuchte 35 LED Warnblinktaster C48-Lichtansteuerung HD AB 15Always
16​
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15Warnblinktaster_Suchbeleuchtung
16​
ENG141657-ENG116161-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion B 15not active
16​
ENG141657-ENG116164-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion C 15not active
16​
ENG141657-ENG116165-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion D 15not active
16​
ENG141657-ENG116168-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion E 15not active
16​
ENG141657-ENG116169-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion F 15not active
16​
ENG141657-ENG116172-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion G 15not active
16​
ENG141657-ENG116173-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion H 15not active
16​
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10maximize
16​
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10maximize
16​
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10maximize
16​
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10
0​
16​
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10
0​
16​
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10
0​
16​
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10
0​
16​
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10
0​
16​
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10
0​
16​
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10not active
16​
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10Always
16​
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10not active
16​
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10not active
16​
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10not active
16​
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10not active
16​
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10not active
16​
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10not active
16​
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10not active
16​
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10not active
16​
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11maximize
16​
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11maximize
16​
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11maximize
16​
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11
127​
16​
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11
0​
16​
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11
0​
16​
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11
0​
16​
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11
62​
16​
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11
0​
16​
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 112 - Shutter: Diagnosesensierung für 'LED low'
16​
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11Always
16​
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11Aktive Blinkfunktion hat ein auf 1 gesetztes zugeordnetes Bit in pa_dynamisch_blinken
16​
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11not active
16​
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11not active
16​
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11not active
16​
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11not active
16​
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11not active
16​
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11not active
16​
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11not active
16​
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12maximize
16​
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12maximize
16​
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12maximize
16​
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12
0​
16​
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12
0​
16​
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12
0​
16​
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12
0​
16​
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12
0​
16​
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12
0​
16​
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12not active
16​
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12Always
16​
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12not active
16​
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12not active
16​
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12not active
16​
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12not active
16​
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12not active
16​
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12not active
16​
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12not active
16​
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12not active
16​
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13maximize
16​
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13maximize
16​
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13maximize
16​
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13
0​
16​
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13
0​
16​
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13
0​
16​
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13
0​
16​
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13
0​
16​
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13
0​
16​
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13not active
16​
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13Always
16​
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13not active
16​
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13not active
16​
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13not active
16​
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13not active
16​
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13not active
16​
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13not active
16​
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13not active
16​
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13not active
16​
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16minimize
16​
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16maximize
16​
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16maximize
16​
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16
127​
16​
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16
0​
16​
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16
0​
16​
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16
127​
16​
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 160B
16​
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16
0​
16​
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 1636 - LED Kleinleistung
16​
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16Always
16​
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16Klemme 30G
16​
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16not active
16​
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16Heckdeckel geschlossen
16​
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16Klemme 15 mit Nachlauf bis Fahrzeugstillstand
16​
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16not active
16​
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16not active
16​
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16Luggage compartment light
16​
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16not active
16​
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17maximize
16​
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17maximize
16​
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17maximize
16​
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17
100​
16​
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17
0​
16​
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17
0​
16​
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17
0​
16​
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17
4​
16​
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17
0​
16​
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 1746 - LED Kleinleistung
16​
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17Always
16​
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17Ambientelicht 2
16​
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17not active
16​
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17not active
16​
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17not active
16​
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17not active
16​
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17not active
16​
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17not active
16​
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17not active
16​
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18maximize
16​
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18maximize
16​
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18maximize
16​
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18
127​
16​
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18
0​
16​
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18
0​
16​
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18
0​
16​
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18
16​
16​
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18
8​
16​
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 1833 - LED-Modul Blinkleuchten
16​
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18Always
16​
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18Blinken links Hellphase
16​
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18not active
16​
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18Blinken links Dunkelphase
16​
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18not active
16​
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18not active
16​
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18not active
16​
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18not active
16​
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18not active
16​
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19maximize
16​
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19maximize
16​
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19maximize
16​
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19
127​
16​
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19
0​
16​
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19
0​
16​
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19
0​
16​
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19
18​
16​
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19
18​
16​
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 1933 - LED-Modul Blinkleuchten
16​
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19Always
16​
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19Blinken rechts Hellphase
16​
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19not active
16​
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19Blinken rechts Dunkelphase
16​
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19not active
16​
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19not active
16​
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19not active
16​
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19not active
16​
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19not active
16​
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1maximize
16​
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1maximize
16​
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1maximize
16​
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1
127​
16​
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1
0​
16​
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1
0​
16​
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1
0​
16​
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1
15​
16​
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 13E
16​
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 133 - LED-Modul Blinkleuchten
16​
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1Always
16​
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1Blinken rechts Hellphase
16​
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1not active
16​
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1Blinken rechts Dunkelphase
16​
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1not active
16​
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1not active
16​
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1not active
16​
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1not active
16​
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1not active
16​
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20minimize
16​
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20maximize
16​
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20maximize
16​
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20
127​
16​
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20
0​
16​
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20
0​
16​
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20
0​
16​
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 203F
16​
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20
13​
16​
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 2035 - kombinierte LED Blink-Bremsleuchten
16​
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20Always
16​
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20Brake lamp
16​
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20Blinken links Hellphase
16​
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20Blinken links Dunkelphase
16​
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20not active
16​
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20not active
16​
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20not active
16​
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20not active
16​
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20not active
16​
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21minimize
16​
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21maximize
16​
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21maximize
16​
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21
127​
16​
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21
0​
16​
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21
0​
16​
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21
0​
16​
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21
40​
16​
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21
23​
16​
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 2135 - kombinierte LED Blink-Bremsleuchten
16​
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21Always
16​
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21Brake lamp
16​
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21Blinken rechts Hellphase
16​
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21Blinken rechts Dunkelphase
16​
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21not active
16​
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21not active
16​
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21not active
16​
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21not active
16​
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21not active
16​
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22maximize
16​
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22maximize
16​
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22maximize
16​
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22
100​
16​
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22
0​
16​
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22
0​
16​
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22
0​
16​
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 222C
16​
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22
29​
16​
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 2242 - LED dritte Bremsleuchte
16​
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22Always
16​
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22Brake lamp
16​
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22not active
16​
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22not active
16​
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22not active
16​
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22not active
16​
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22not active
16​
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22not active
16​
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22not active
16​
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23maximize
16​
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23maximize
16​
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23maximize
16​
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23
100​
16​
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23
100​
16​
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23
0​
16​
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23
0​
16​
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23
29​
16​
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 230A
16​
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 2340 - allgemeine LED
16​
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23Always
16​
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
16​
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23Coming Home oder Leaving Home aktiv
16​
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23Parklicht links (beidseitiges Parklicht aktiviert li & re)
16​
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23not active
16​
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23not active
16​
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23not active
16​
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23not active
16​
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23not active
16​
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24maximize
16​
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24maximize
16​
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24maximize
16​
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24
100​
16​
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24
100​
16​
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24
0​
16​
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24
0​
16​
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 242A
16​
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 241A
16​
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 2440 - allgemeine LED
16​
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24Always
16​
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
16​
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24Coming Home oder Leaving Home aktiv
16​
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24Parking light right
16​
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24not active
16​
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24not active
16​
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24not active
16​
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24not active
16​
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24not active
16​
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25maximize
16​
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25maximize
16​
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25maximize
16​
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25
100​
16​
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25
0​
16​
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25
100​
16​
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25
0​
16​
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25
30​
16​
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25
28​
16​
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 2543 - allgemeine LED
16​
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25Always
16​
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
16​
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25Coming Home oder Leaving Home aktiv
16​
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25not active
16​
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25not active
16​
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25beidseitiges Dauerparklicht
16​
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25not active
16​
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25not active
16​
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25not active
16​
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26minimize
16​
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26maximize
16​
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26maximize
16​
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26
60​
16​
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26
0​
16​
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26
100​
16​
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26
0​
16​
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 262E
16​
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 260C
16​
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 2643 - allgemeine LED
16​
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26Always
16​
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26Brake lamp
16​
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26Blinken links Hellphase
16​
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26Blinken links Dunkelphase
16​
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26not active
16​
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26Nebelschlusslicht wenn kein Anhaenger gesteckt
16​
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26not active
16​
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26not active
16​
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26not active
16​
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27minimize
16​
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27maximize
16​
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27maximize
16​
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27
60​
16​
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27
0​
16​
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27
100​
16​
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27
0​
16​
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 272F
16​
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 271C
16​
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 2743 - allgemeine LED
16​
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27Always
16​
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27Brake lamp
16​
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27Blinken rechts Hellphase
16​
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27Blinken rechts Dunkelphase
16​
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27not active
16​
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27Nebelschlusslicht wenn kein Anhaenger gesteckt
16​
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27not active
16​
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27not active
16​
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27not active
16​
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28maximize
16​
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28maximize
16​
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28maximize
16​
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28
100​
16​
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28
0​
16​
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28
0​
16​
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28
0​
16​
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28
31​
16​
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 280B
16​
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 2840 - allgemeine LED
16​
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28Always
16​
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28Rueckfahrlicht
16​
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28not active
16​
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28not active
16​
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28not active
16​
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28not active
16​
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28not active
16​
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28not active
16​
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28not active
16​
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29maximize
16​
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29maximize
16​
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29maximize
16​
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29
100​
16​
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29
0​
16​
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29
0​
16​
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29
0​
16​
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29
32​
16​
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 291B
16​
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 2940 - allgemeine LED
16​
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29Always
16​
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29Rueckfahrlicht
16​
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29not active
16​
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29not active
16​
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29not active
16​
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29not active
16​
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29not active
16​
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29not active
16​
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29not active
16​
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2minimize
16​
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2maximize
16​
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2maximize
16​
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2
100​
16​
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2
0​
16​
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2
28​
16​
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2
28​
16​
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 24A
16​
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2
48​
16​
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 24 - LED Tagfahrlichtmodul Signal
16​
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2Always
16​
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2Daytime running lamps
16​
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2not active
16​
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2Blinken links aktiv (beide Phasen)
16​
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2not active
16​
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
16​
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2Parklicht links (beidseitiges Parklicht aktiviert li & re)
16​
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2Coming Home oder Leaving Home aktiv
16​
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2not active
16​
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30maximize
16​
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30maximize
16​
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30maximize
16​
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30
100​
16​
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30
0​
16​
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30
0​
16​
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30
0​
16​
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30
2​
16​
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30
0​
16​
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 3046 - LED Kleinleistung
16​
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30Always
16​
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30Footwell lamp
16​
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30not active
16​
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30not active
16​
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30not active
16​
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30not active
16​
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30not active
16​
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30not active
16​
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30not active
16​
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31maximize
16​
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31maximize
16​
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31maximize
16​
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31
100​
16​
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31
0​
16​
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31
0​
16​
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31
0​
16​
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31
3​
16​
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31
0​
16​
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31not active
16​
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31Always
16​
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31Ambientelicht 1
16​
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31not active
16​
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31not active
16​
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31not active
16​
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31not active
16​
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31not active
16​
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31not active
16​
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31not active
16​
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32maximize
16​
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32maximize
16​
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32maximize
16​
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32
100​
16​
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32
0​
16​
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32
0​
16​
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32
0​
16​
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32
4​
16​
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32
0​
16​
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32not active
16​
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32Always
16​
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32Ambientelicht 2
16​
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32not active
16​
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32not active
16​
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32not active
16​
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32not active
16​
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32not active
16​
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32not active
16​
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32not active
16​
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33maximize
16​
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33maximize
16​
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33maximize
16​
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33
100​
16​
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33
0​
16​
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33
0​
16​
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33
0​
16​
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33
5​
16​
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33
0​
16​
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33not active
16​
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33Always
16​
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33Ambientelicht 3
16​
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33not active
16​
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33not active
16​
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33not active
16​
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33not active
16​
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33not active
16​
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33not active
16​
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33not active
16​
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34maximize
16​
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34maximize
16​
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34maximize
16​
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34
100​
16​
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34
0​
16​
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34
0​
16​
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34
0​
16​
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34
6​
16​
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34
0​
16​
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34not active
16​
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34Always
16​
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34Ambientelicht 4
16​
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34not active
16​
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34not active
16​
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34not active
16​
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34not active
16​
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34not active
16​
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34not active
16​
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34not active
16​
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3minimize
16​
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3maximize
16​
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3maximize
16​
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3
100​
16​
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3
0​
16​
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3
28​
16​
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3
28​
16​
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 34C
16​
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 34C
16​
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 34 - LED Tagfahrlichtmodul Signal
16​
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3Always
16​
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3Daytime running lamps
16​
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3not active
16​
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3Blinken rechts aktiv (beide Phasen)
16​
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3not active
16​
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
16​
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3Parking light right
16​
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3Coming Home oder Leaving Home aktiv
16​
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3not active
16​
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4minimize
16​
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4maximize
16​
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4maximize
16​
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4
100​
16​
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4
0​
16​
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4
100​
16​
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4
100​
16​
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4
49​
16​
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4
48​
16​
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 41 - LED Tagfahrlichtmodul Versorgung
16​
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4Always
16​
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4Daytime running lamps
16​
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4not active
16​
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4Blinken links aktiv (beide Phasen)
16​
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4not active
16​
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
16​
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4Parklicht links (beidseitiges Parklicht aktiviert li & re)
16​
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4Coming Home oder Leaving Home aktiv
16​
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4not active
16​
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5minimize
16​
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5maximize
16​
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5maximize
16​
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5
100​
16​
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5
0​
16​
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5
100​
16​
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5
100​
16​
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 54B
16​
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 54C
16​
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 51 - LED Tagfahrlichtmodul Versorgung
16​
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5Always
16​
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5Daytime running lamps
16​
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5not active
16​
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5Blinken rechts aktiv (beide Phasen)
16​
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5not active
16​
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
16​
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5Parking light right
16​
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5Coming Home oder Leaving Home aktiv
16​
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5not active
16​
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6maximize
16​
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6maximize
16​
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6maximize
16​
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6
127​
16​
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6
127​
16​
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6
0​
16​
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6
0​
16​
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 61A
16​
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6
36​
16​
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 65 - LED Abblendlicht
16​
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6Always
16​
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6Abblendlicht links
16​
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6not active
16​
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6Coming Home oder Leaving Home aktiv
16​
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6not active
16​
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6not active
16​
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6not active
16​
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6not active
16​
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6not active
16​
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7maximize
16​
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7maximize
16​
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7maximize
16​
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7
127​
16​
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7
127​
16​
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7
0​
16​
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7
0​
16​
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 71B
16​
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7
40​
16​
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 75 - LED Abblendlicht
16​
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7Always
16​
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7Abblendlicht rechts
16​
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7not active
16​
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7Coming Home oder Leaving Home aktiv
16​
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7not active
16​
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7not active
16​
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7not active
16​
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7not active
16​
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7not active
16​
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8maximize
16​
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8maximize
16​
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8maximize
16​
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8
127​
16​
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8
127​
16​
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8
0​
16​
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8
0​
16​
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 85D
16​
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8
36​
16​
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 85 - LED Abblendlicht
16​
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8Always
16​
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8Klemme 15 mit Nachlauf bis Fahrzeugstillstand
16​
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8not active
16​
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8Coming Home oder Leaving Home aktiv
16​
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8not active
16​
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8not active
16​
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8not active
16​
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8not active
16​
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8not active
16​
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9maximize
16​
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9maximize
16​
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9maximize
16​
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9
127​
16​
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9
127​
16​
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9
0​
16​
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9
0​
16​
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 95E
16​
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9
40​
16​
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 95 - LED Abblendlicht
16​
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9Always
16​
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9Klemme 15 mit Nachlauf bis Fahrzeugstillstand
16​
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9not active
16​
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9Coming Home oder Leaving Home aktiv
16​
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9not active
16​
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9not active
16​
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9not active
16​
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9not active
16​
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9not active
16​
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck21 08 00 16 02 00 7F 03 00 00 00 00 00 00 00 00 21 18 00 18 04 00 7F 05 00 00 00 00 00 00 00 00 23 13 00 3F 18 02 7F 03 00 80 00 00 00 00 00 00 23 23 00 40 18 04 7F 05 00 80 00 00 00 00 00 00 2A 29 00 2C 18 00 64 00 00 00 00 00 00 00 00 00 28 0A 00 29 08 1E 64 09 00 64 00 00 00 00 00 00 28 1A 00 2A 08 1E 64 0A 00 64 00 00 00 00 00 00 2B 28 00 30 08 1E 64 00 00 00 3A 00 64 00 00 00 2B 0C 00 2E 18 02 3C 03 00 80 1A 00 64 00 00 00 2B 1C 00 2F 18 04 3C 05 00 80 1A 00 64 00 00 00 28 0B 00 31 19 00 64 00 00 00 00 00 00 00 00 00 28 1B 00 32 19 00 64 00 00 00 00 00 00 00 00 00
192​
ENG141662-Leuchtenkonfiguration_Sonstiges24 00 00 0B 25 00 7F 22 28 80 00 00 00 2A 00 7F 2E 00 00 04 2E 00 64 00 00 00 00 00 00 00 00 00 2E 00 00 02 2B 00 64 00 00 00 00 00 00 00 00 00 00 00 00 03 2D 00 64 00 00 00 00 00 00 00 00 00 00 00 00 04 2E 00 64 00 00 00 00 00 00 00 00 00 00 00 00 05 2F 00 64 00 00 00 00 00 00 00 00 00 00 00 00 06 30 00 64 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00
128​
ENG141658-ENG142197-Leuchtweitenregulierung-1_Sensor_LWR1-Sensor_LWR
62​
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges2700 mm
62​
ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampenot active
62​
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze
90.00%​
62​
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze
10.00%​
62​
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung-127.0 ms
62​
ENG141658-ENG142209-Leuchtweitenregulierung-diagnose_soll_toleranz
15%​
62​
ENG141658-ENG142203-Leuchtweitenregulierung-Entprellung_Fehlerlampe10.0 s
62​
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_15.00 mm/%
62​
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_25.00 mm/%
62​
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_35.00 mm/%
62​
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_13.00 mm/%
62​
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_23.00 mm/%
62​
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_33.00 mm/%
62​
ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_VarianteVariante_1
62​
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR
100.00%​
62​
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf0.03 Hz
62​
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildungnormal
62​
ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_SignalNegative
62​
ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_10 mm
62​
ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_20 mm
62​
ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_30 mm
62​
ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_40 mm
62​
ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand550 mm
62​
ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe680 mm
62​
ENG141658-ENG142226-Leuchtweitenregulierung-lwr_pwm_obere_schwelle
47.50%​
62​
ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle
12.50%​
62​
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr0 km/h
62​
ENG141658-ENG142222-Leuchtweitenregulierung-pa_fDynFiltStatLwr100 Hz
62​
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung0.03 Hz
62​
ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_HoehenwerteBCM
62​
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installednot installed
62​
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlichtnot active
62​
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese
20.00%​
62​
ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstartnot active
62​
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad5.0 %/s
62​
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht
-100.00%​
62​
ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbautnot installed
62​
ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR10.00 s
62​
ENG246957-ENG246963-Lichttaster-Anzeigezeit_LTM_PopUp12.0 s
7​
ENG246957-ENG246964-Lichttaster-Anzeigezeit_LTM_PopUp1_lang10 s
7​
ENG246957-ENG246965-Lichttaster-Beleuchtung_Auto_LED_bei_Nebelfunktionactive
7​
ENG246957-ENG246966-Lichttaster-Beleuchtung_LTM_Auto_LED_58xt_logikactive
7​
ENG246957-ENG246978-Lichttaster-Licht_anforderung_FASNicht_verbaut
7​
ENG246957-ENG246979-Lichttaster-Licht_anforderung_Piloparknot active
7​
ENG246957-ENG246980-Lichttaster-Licht_Reaktivierungs_grenze100 m
7​
ENG246957-ENG246981-Lichttaster-Lichttastermodullds
7​
ENG246957-ENG246982-Lichttaster-LTM_Anzeige_Config
10​
7​
ENG246957-ENG246983-Lichttaster-LTM_Beleuchtung_Geschwindigkeits_Schwelle32 km/h
7​
ENG246957-ENG246984-Lichttaster-LTM_BGL_Geschwindigkeitsabhängigactive
7​
ENG246957-ENG246985-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig_Parameteractive
7​
ENG246957-ENG246986-Lichttaster-LTM_BGL_Wegabhängignot active
7​
ENG246957-ENG246987-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängigactive
7​
ENG246957-ENG246988-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig_Parameteractive
7​
ENG246957-ENG246989-Lichttaster-LTM_GlobalOFF_Wegabhängignot active
7​
ENG246957-ENG246990-Lichttaster-LTM_GlobalOFF_Zündungsabhängigactive
7​
ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1not active
1​
ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2not active
1​
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3not active
1​
ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4not active
1​
ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5not active
1​
ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6not active
1​
ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typnot active
1​
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0
0.00%​
12​
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1
5.00%​
12​
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2
50.00%​
12​
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3
75.00%​
12​
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4
110​
12​
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5
126.5​
12​
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0
0.00%​
12​
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1
6.00%​
12​
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2
16.00%​
12​
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3
30.00%​
12​
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4
60.00%​
12​
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5
100.00%​
12​
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0
-3.71%​
20​
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1
-2.96%​
20​
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2
-2.04%​
20​
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3
-1.48%​
20​
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4
-0.37%​
20​
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0
-0.2​
20​
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1
-0.1​
20​
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2
-0.05​
20​
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3
-0.01​
20​
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4
0​
20​
ENG133365-ENG133451-Multikontursitz_BFS_Wildmoser-Differenzdruck_Toleranzband60 hPa
12​
ENG133365-ENG133447-Multikontursitz_BFS_Wildmoser-Leckage_Fehlerschwelle_Druck110 hPa
12​
ENG133365-ENG133453-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_mitte0 s
12​
ENG133365-ENG133452-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_oben7 s
12​
ENG133365-ENG133454-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_unten7 s
12​
ENG133365-ENG133455-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_Seitenwangen7 s
12​
ENG133365-ENG133448-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_1
60%​
12​
ENG133365-ENG133449-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_2
60%​
12​
ENG133365-ENG133450-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_3
0%​
12​
ENG133365-ENG133446-Multikontursitz_BFS_Wildmoser-Schwellwert_Temperaturkompensation10 °C
12​
ENG133362-ENG133451-Multikontursitz_FS_Wildmoser-Differenzdruck_Toleranzband60 hPa
12​
ENG133362-ENG133447-Multikontursitz_FS_Wildmoser-Leckage_Fehlerschwelle_Druck110 hPa
12​
ENG133362-ENG133453-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_mitte0 s
12​
ENG133362-ENG133452-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_oben7 s
12​
ENG133362-ENG133454-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_unten7 s
12​
ENG133362-ENG133455-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_Seitenwangen7 s
12​
ENG133362-ENG133448-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_1
60%​
12​
ENG133362-ENG133449-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_2
60%​
12​
ENG133362-ENG133450-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_3
0%​
12​
ENG133362-ENG133446-Multikontursitz_FS_Wildmoser-Schwellwert_Temperaturkompensation10 °C
12​
ENG122979-ENG141954-Networking-A/C electronicsinstalled
8​
ENG122979-ENG141968-Networking-Anhaengeranschlussgeraetnot installed
8​
ENG122979-ENG141974-Networking-Bremsen_Steuergeraetinstalled
8​
ENG122979-ENG141953-Networking-Getriebesteuergeraetinstalled
8​
ENG122979-ENG99457-Networking-Head area heaternot installed
8​
ENG122979-ENG142040-Networking-Kunden_spezifisches_Funktions_SGnot installed
8​
ENG124714-ENG142044-OCU-DWA_pushnot active
8​
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfarenot active
8​
ENG124714-ENG246970-OCU-IAA -Nutzer_managementnot installed
8​
ENG124714-OCU-not installed
8​
ENG124714-ENG142261-OCU-Remote HuF Abbruch0 km/h
8​
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz0 Hz
8​
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s10 s
8​
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s30 ms
8​
ENG124714-ENG125657-OCU-Remote_Unlock_Locknot_active
8​
ENG125598-ENG125667-Passenger_massage_program_1_Intensity_1-EE_pMax_LM_MSG_Px_Iy110 hPa
15​
ENG125598-ENG125691-Passenger_massage_program_1_Intensity_1-EE_pMax_LO_MSG_Px_I110 hPa
15​
ENG125598-ENG125668-Passenger_massage_program_1_Intensity_1-EE_pMax_LU_MSG_Px_Iy110 hPa
15​
ENG125598-ENG125673-Passenger_massage_program_1_Intensity_1-EE_tEnt_LM_MSG_Px_Iy5000 ms
15​
ENG125598-ENG125672-Passenger_massage_program_1_Intensity_1-EE_tEnt_LO_MSG_Px_Iy5000 ms
15​
ENG125598-ENG125674-Passenger_massage_program_1_Intensity_1-EE_tEnt_LU_MSG_Px_Iy5000 ms
15​
ENG125598-ENG125670-Passenger_massage_program_1_Intensity_1-EE_tHalte_LM_MSG_Px_Iy0 ms
15​
ENG125598-ENG125669-Passenger_massage_program_1_Intensity_1-EE_tHalte_LO_MSG_Px_Iy0 ms
15​
ENG125598-ENG125671-Passenger_massage_program_1_Intensity_1-EE_tHalte_LU_MSG_Px_Iy0 ms
15​
ENG125598-ENG125676-Passenger_massage_program_1_Intensity_1-EE_tWarte_LM_MSG_Px_Iy0 ms
15​
ENG125598-ENG125675-Passenger_massage_program_1_Intensity_1-EE_tWarte_LO_MSG_Px_Iy0 ms
15​
ENG125598-ENG125677-Passenger_massage_program_1_Intensity_1-EE_tWarte_LU_MSG_Px_Iy0 ms
15​
ENG125598-ENG125664-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy80 ms
15​
ENG125598-ENG125663-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy80 ms
15​
ENG125598-ENG125665-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy80 ms
15​
ENG125599-ENG125667-Passenger_massage_program_1_Intensity_2-EE_pMax_LM_MSG_Px_Iy160 hPa
15​
ENG125599-ENG125666-Passenger_massage_program_1_Intensity_2-EE_pMax_LO_MSG_Px_Iy160 hPa
15​
ENG125599-ENG125668-Passenger_massage_program_1_Intensity_2-EE_pMax_LU_MSG_Px_Iy160 hPa
15​
ENG125599-ENG125673-Passenger_massage_program_1_Intensity_2-EE_tEnt_LM_MSG_Px_Iy6000 ms
15​
ENG125599-ENG125672-Passenger_massage_program_1_Intensity_2-EE_tEnt_LO_MSG_Px_Iy6000 ms
15​
ENG125599-ENG125674-Passenger_massage_program_1_Intensity_2-EE_tEnt_LU_MSG_Px_Iy6000 ms
15​
ENG125599-ENG125670-Passenger_massage_program_1_Intensity_2-EE_tHalte_LM_MSG_Px_Iy0 ms
15​
ENG125599-ENG125669-Passenger_massage_program_1_Intensity_2-EE_tHalte_LO_MSG_Px_Iy0 ms
15​
ENG125599-ENG125671-Passenger_massage_program_1_Intensity_2-EE_tHalte_LU_MSG_Px_Iy0 ms
15​
ENG125599-ENG125676-Passenger_massage_program_1_Intensity_2-EE_tWarte_LM_MSG_Px_Iy0 ms
15​
ENG125599-ENG125675-Passenger_massage_program_1_Intensity_2-EE_tWarte_LO_MSG_Px_Iy0 ms
15​
ENG125599-ENG125677-Passenger_massage_program_1_Intensity_2-EE_tWarte_LU_MSG_Px_Iy0 ms
15​
ENG125599-ENG125664-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy80 ms
15​
ENG125599-ENG125663-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy80 ms
15​
ENG125599-ENG125665-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy80 ms
15​
ENG125600-ENG125667-Passenger_massage_program_1_Intensity_3-EE_pMax_LM_MSG_Px_Iy210 hPa
15​
ENG125600-ENG125666-Passenger_massage_program_1_Intensity_3-EE_pMax_LO_MSG_Px_Iy210 hPa
15​
ENG125600-ENG125668-Passenger_massage_program_1_Intensity_3-EE_pMax_LU_MSG_Px_Iy210 hPa
15​
ENG125600-ENG125673-Passenger_massage_program_1_Intensity_3-EE_tEnt_LM_MSG_Px_Iy7000 ms
15​
ENG125600-ENG125672-Passenger_massage_program_1_Intensity_3-EE_tEnt_LO_MSG_Px_Iy7000 ms
15​
ENG125600-ENG125674-Passenger_massage_program_1_Intensity_3-EE_tEnt_LU_MSG_Px_Iy7000 ms
15​
ENG125600-ENG125670-Passenger_massage_program_1_Intensity_3-EE_tHalte_LM_MSG_Px_Iy0 ms
15​
ENG125600-ENG125669-Passenger_massage_program_1_Intensity_3-EE_tHalte_LO_MSG_Px_Iy0 ms
15​
ENG125600-ENG125671-Passenger_massage_program_1_Intensity_3-EE_tHalte_LU_MSG_Px_Iy0 ms
15​
ENG125600-ENG125676-Passenger_massage_program_1_Intensity_3-EE_tWarte_LM_MSG_Px_Iy0 ms
15​
ENG125600-ENG125675-Passenger_massage_program_1_Intensity_3-EE_tWarte_LO_MSG_Px_Iy0 ms
15​
ENG125600-ENG125677-Passenger_massage_program_1_Intensity_3-EE_tWarte_LU_MSG_Px_Iy0 ms
15​
ENG125600-ENG125692-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LM_MSG_Px_I80 ms
15​
ENG125600-ENG125663-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy80 ms
15​
ENG125600-ENG125665-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy80 ms
15​
ENG125601-ENG125667-Passenger_massage_program_2_Intensity_1-EE_pMax_LM_MSG_Px_Iy140 hPa
15​
ENG125601-ENG125666-Passenger_massage_program_2_Intensity_1-EE_pMax_LO_MSG_Px_Iy140 hPa
15​
ENG125601-ENG125668-Passenger_massage_program_2_Intensity_1-EE_pMax_LU_MSG_Px_Iy140 hPa
15​
ENG125601-ENG125673-Passenger_massage_program_2_Intensity_1-EE_tEnt_LM_MSG_Px_Iy5000 ms
15​
ENG125601-ENG125672-Passenger_massage_program_2_Intensity_1-EE_tEnt_LO_MSG_Px_Iy5000 ms
15​
ENG125601-ENG125674-Passenger_massage_program_2_Intensity_1-EE_tEnt_LU_MSG_Px_Iy5000 ms
15​
ENG125601-ENG125670-Passenger_massage_program_2_Intensity_1-EE_tHalte_LM_MSG_Px_Iy2000 ms
15​
ENG125601-ENG125669-Passenger_massage_program_2_Intensity_1-EE_tHalte_LO_MSG_Px_Iy2000 ms
15​
ENG125601-ENG125671-Passenger_massage_program_2_Intensity_1-EE_tHalte_LU_MSG_Px_Iy2000 ms
15​
ENG125601-ENG125676-Passenger_massage_program_2_Intensity_1-EE_tWarte_LM_MSG_Px_Iy6000 ms
15​
ENG125601-ENG125675-Passenger_massage_program_2_Intensity_1-EE_tWarte_LO_MSG_Px_Iy6000 ms
15​
ENG125601-ENG125677-Passenger_massage_program_2_Intensity_1-EE_tWarte_LU_MSG_Px_Iy6000 ms
15​
ENG125601-ENG125664-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy80 ms
15​
ENG125601-ENG125663-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy80 ms
15​
ENG125601-ENG125665-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy80 ms
15​
ENG125602-ENG125667-Passenger_massage_program_2_Intensity_2-EE_pMax_LM_MSG_Px_Iy190 hPa
15​
ENG125602-ENG125666-Passenger_massage_program_2_Intensity_2-EE_pMax_LO_MSG_Px_Iy190 hPa
15​
ENG125602-ENG125668-Passenger_massage_program_2_Intensity_2-EE_pMax_LU_MSG_Px_Iy190 hPa
15​
ENG125602-ENG125673-Passenger_massage_program_2_Intensity_2-EE_tEnt_LM_MSG_Px_Iy6000 ms
15​
ENG125602-ENG125672-Passenger_massage_program_2_Intensity_2-EE_tEnt_LO_MSG_Px_Iy6000 ms
15​
ENG125602-ENG125674-Passenger_massage_program_2_Intensity_2-EE_tEnt_LU_MSG_Px_Iy6000 ms
15​
ENG125602-ENG125670-Passenger_massage_program_2_Intensity_2-EE_tHalte_LM_MSG_Px_Iy2000 ms
15​
ENG125602-ENG125669-Passenger_massage_program_2_Intensity_2-EE_tHalte_LO_MSG_Px_Iy2000 ms
15​
ENG125602-ENG125671-Passenger_massage_program_2_Intensity_2-EE_tHalte_LU_MSG_Px_Iy2000 ms
15​
ENG125602-ENG125676-Passenger_massage_program_2_Intensity_2-EE_tWarte_LM_MSG_Px_Iy7000 ms
15​
ENG125602-ENG125675-Passenger_massage_program_2_Intensity_2-EE_tWarte_LO_MSG_Px_Iy7000 ms
15​
ENG125602-ENG125677-Passenger_massage_program_2_Intensity_2-EE_tWarte_LU_MSG_Px_Iy7000 ms
15​
ENG125602-ENG125664-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy80 ms
15​
ENG125602-ENG125663-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy80 ms
15​
ENG125602-ENG125665-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy80 ms
15​
ENG133367-ENG133507-Passenger_multi-contour_seat_Error_Mask-ERROR_CODE_PIN0 bit
66​
ENG133367-ENG133526-Passenger_multi-contour_seat_Error_Mask-ERROR_EEPROM31743 bit
66​
ENG133367-ENG133528-Passenger_multi-contour_seat_Error_Mask-ERROR_HW_VERSION31743 bit
66​
ENG133367-ENG133500-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB1_CTRL_LEAK0 bit
66​
ENG133367-ENG133499-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB1_LEAK0 bit
66​
ENG133367-ENG133502-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB2_CTRL_LEAK0 bit
66​
ENG133367-ENG133501-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB2_LEAK0 bit
66​
ENG133367-ENG133504-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB3_CTRL_LEAK0 bit
66​
ENG133367-ENG133503-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB3_LEAK0 bit
66​
ENG133367-ENG133511-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_BLOCK31743 bit
66​
ENG133367-ENG133508-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_OPEN31743 bit
66​
ENG133367-ENG133509-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_GND31743 bit
66​
ENG133367-ENG133510-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_UB31743 bit
66​
ENG133367-ENG133524-Passenger_multi-contour_seat_Error_Mask-ERROR_RAM31743 bit
66​
ENG133367-ENG133525-Passenger_multi-contour_seat_Error_Mask-ERROR_ROM31743 bit
66​
ENG133367-ENG133506-Passenger_multi-contour_seat_Error_Mask-ERROR_SIDE_CTRL_LEAK0 bit
66​
ENG133367-ENG133505-Passenger_multi-contour_seat_Error_Mask-ERROR_SIDE_LEAK0 bit
66​
ENG133367-ENG133531-Passenger_multi-contour_seat_Error_Mask-ERROR_SIG_RESPONSE0 bit
66​
ENG133367-ENG133512-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_10 bit
66​
ENG133367-ENG133515-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_20 bit
66​
ENG133367-ENG133518-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_30 bit
66​
ENG133367-ENG133521-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_40 bit
66​
ENG133367-ENG133513-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_10 bit
66​
ENG133367-ENG133516-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_20 bit
66​
ENG133367-ENG133519-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_30 bit
66​
ENG133367-ENG133522-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_40 bit
66​
ENG133367-ENG133514-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_10 bit
66​
ENG133367-ENG133517-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_20 bit
66​
ENG133367-ENG133520-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_30 bit
66​
ENG133367-ENG133523-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_40 bit
66​
ENG133367-ENG133529-Passenger_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_HIGH0 bit
66​
ENG133367-ENG133530-Passenger_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_LOW0 bit
66​
ENG133367-ENG133527-Passenger_multi-contour_seat_Error_Mask-ERROR_WDT31743 bit
66​
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbarnot active
16​
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten
0​
16​
ENG98831-ENG133402-Personalization-Automatische_ Schluesselzuordnungnot active
16​
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbarnot active
16​
ENG98831-ENG126848-Personalization-Personalisierung_aktivnot active
16​
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkionprofiles_inactive
16​
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbarnot active
16​
ENG98831-ENG142030-Personalization-Profil_VarianteSchluessel
16​
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1not active
16​
ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2not active
16​
ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3not active
16​
ENG98831-ENG133407-Personalization-PSO_FSG_Setup2_Bit_4not active
16​
ENG249801-ENG249833-PKW-Schiebetueren-CAN_TSG_HBFS_verbautNo
4​
ENG249801-ENG249834-PKW-Schiebetueren-CAN_TSG_HFS_verbautNo
4​
ENG249801-ENG249925-PKW-Schiebetueren-PKW_Schiebetuer_HBFS_nachverriegelnNo
4​
ENG249801-ENG249926-PKW-Schiebetueren-PKW_Schiebetuer_HBFS_verbautNo
4​
ENG249801-ENG249927-PKW-Schiebetueren-PKW_Schiebetuer_HFS_nachverriegelnNo
4​
ENG249801-ENG249928-PKW-Schiebetueren-PKW_Schiebetuer_HFS_verbautNo
4​
ENG249801-ENG251921-PKW-Schiebetueren-SBT_Entr_im_Zustand_entriegeltNo
4​
ENG249801-ENG249939-PKW-Schiebetueren-STSG_HBFS_verbautNo
4​
ENG249801-ENG249940-PKW-Schiebetueren-STSG_HFS_verbautNo
4​
ENG141646-MAS01065-Querschnitts_funktionen-BrandAudi
5​
ENG141646-ENG141980-Querschnitts_funktionen-Bedien_und_Anzeigeprotokollactive
5​
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigungnot active
5​
ENG141646-ENG141967-Querschnitts_funktionen-Codierungsabsicherungnot active
5​
ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21active
5​
ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_DrucktankklappenstatusPin A31
5​
ENG141646-ENG154685-Querschnitts_funktionen-HupeSollspannungsanforderung 13.5
5​
ENG141646-ENG115810-Querschnitts_funktionen-Klemmenfehler auf CAN ausgebenactive
5​
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahmeinstalled
5​
ENG141646-ENG141983-Querschnitts_funktionen-Schnittstelle_TrackingSystemnot active
5​
ENG141646-ENG141964-Querschnitts_funktionen-Steering alignmentLeft
5​
ENG141646-ENG141965-Querschnitts_funktionen-Traffic sideRight
5​
ENG249802-ENG249933-Rear_view_camera_wash-RVC_Speed_Hysteresis5 km/h
8​
ENG249802-ENG249934-Rear_view_camera_wash-RVC_Speed_max50 km/h
8​
ENG249802-ENG249935-Rear_view_camera_wash-RVC_Time_cleaning_Pumpe_active_BCM1.5 s
8​
ENG249802-ENG249936-Rear_view_camera_wash-RVC_Waschen_HMInot active
8​
ENG249802-ENG249937-Rear_view_camera_wash-RVC_Washnot installed
8​
ENG122927-RLS_close_glazing2.5 s
1​
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off120 s
3​
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on10 s
3​
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off65 km/h
3​
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on140 km/h
3​
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle6000 lx
2​
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high
12​
2​
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low
6​
2​
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht30 s
2​
ENG122929-RLS_LIN_Communication4 s
1​
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn100 lx
1​
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day200 lx
1​
ENG122930-RLS_tunel_gateway_recognize5 s
1​
ENG122935-RLS_Washer_Front15 s
1​
ENG122926-RLS_wiper_position_parking15 s
1​
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung
8​
10​
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer systemnot installed
10​
ENG115729-ENG249900-Scheinwerferreinigung-Init Versatz Betaetigungen Frontwaschanlage pro SRA Aktivierung
0​
10​
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangelactive
10​
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit1000 ms
10​
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit1200 ms
10​
ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit1000 ms
10​
ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit1000 ms
10​
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit1200 ms
10​
ENG115729-ENG154424-Scheinwerferreinigung-WaschenSollspannungsanforderung 13.5
10​
ENG116588-ENG248517-Sonderfunktionen-Blinkerueberwachug Sonderfunktions-SGnot installed
4​
ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer BlinkerSMLS
4​
ENG116588-Sonderfunktionen-not enabled
4​
ENG116588-ENG141979-Sonderfunktionen-Sonderfunktionen 1not installed
4​
ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappennot active
5​
ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modusby look command via remote control key
5​
ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappenactive
5​
ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkungactive
5​
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellungnot active
5​
ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegelnot active
5​
ENG141635-ENG126610-Spiegelverstellung-Signalisierung_Spiegelanklappungactive
5​
ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrtactive
5​
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelungnot active
5​
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchronnot active
5​
ENG153700-ENG154515-Steering Column Switch-Anzahl_fehler_P-verriegelt
250​
10​
ENG153700-ENG154621-Steering Column Switch-Geschwindigkeitesschwele_erkennung_fahrt_P_plausibel10 km/h
10​
ENG153700-ENG154803-Steering Column Switch-Verbauort_LenkstockschalterCAN
10​
ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel2000 ms
10​
ENG153700-ENG154829-Steering Column Switch-Zeit_t_P-verriegelt_entprellen100 ms
10​
ENG141678-ENG115658-Suchbeleuchtung_58_xs_Bus_Kennlinie-x00.0 lx
10​
ENG141678-ENG101574-Suchbeleuchtung_58_xs_Bus_Kennlinie-X18.0 lx
10​
ENG141678-ENG99557-Suchbeleuchtung_58_xs_Bus_Kennlinie-X250.0 lx
10​
ENG141678-ENG102140-Suchbeleuchtung_58_xs_Bus_Kennlinie-X380.0 lx
10​
ENG141678-ENG102936-Suchbeleuchtung_58_xs_Bus_Kennlinie-X4100.0 lx
10​
ENG141678-ENG115659-Suchbeleuchtung_58_xs_Bus_Kennlinie-y0
6​
10​
ENG141678-ENG99777-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y1
6​
10​
ENG141678-ENG100480-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y2
20​
10​
ENG141678-ENG100773-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y3
50​
10​
ENG141678-ENG100631-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y4
100​
10​
ENG141679-ENG115658-Suchbeleuchtung_58xt_Bus_Kennlinie-x00.0 lx
10​
ENG141679-ENG101574-Suchbeleuchtung_58xt_Bus_Kennlinie-X18.0 lx
10​
ENG141679-ENG99557-Suchbeleuchtung_58xt_Bus_Kennlinie-X250.0 lx
10​
ENG141679-ENG102140-Suchbeleuchtung_58xt_Bus_Kennlinie-X380.0 lx
10​
ENG141679-ENG102936-Suchbeleuchtung_58xt_Bus_Kennlinie-X4100.0 lx
10​
ENG141679-ENG115659-Suchbeleuchtung_58xt_Bus_Kennlinie-y0
6​
10​
ENG141679-ENG99777-Suchbeleuchtung_58xt_Bus_Kennlinie-Y1
6​
10​
ENG141679-ENG100480-Suchbeleuchtung_58xt_Bus_Kennlinie-Y2
20​
10​
ENG141679-ENG100773-Suchbeleuchtung_58xt_Bus_Kennlinie-Y3
50​
10​
ENG141679-ENG100631-Suchbeleuchtung_58xt_Bus_Kennlinie-Y4
100​
10​
ENG141666-ENG115658-Suchbeleuchtung_Abdimmen-x00 ms
22​
ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1200 ms
22​
ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x102000 ms
22​
ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2400 ms
22​
ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3600 ms
22​
ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4800 ms
22​
ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X51000 ms
22​
ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X61200 ms
22​
ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x71400 ms
22​
ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x81600 ms
22​
ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x91800 ms
22​
ENG141666-ENG115659-Suchbeleuchtung_Abdimmen-y0
100.00%​
22​
ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1
100.00%​
22​
ENG141666-ENG115668-Suchbeleuchtung_Abdimmen-y10
0.00%​
22​
ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2
95.00%​
22​
ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3
80.00%​
22​
ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4
40.00%​
22​
ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5
20.00%​
22​
ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6
10.00%​
22​
ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7
5.00%​
22​
ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8
3.00%​
22​
ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9
1.00%​
22​
ENG141663-ENG142240-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xd PWM0.00 s
21​
ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM0.00 s
21​
ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM0.00 s
21​
ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM0.00 s
21​
ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM0.00 s
21​
ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_SuchbeleuchtungPotentiometer
21​
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen0.0 s
21​
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen0.0 s
21​
ENG141663-ENG116598-Suchbeleuchtung_allgemein-KL58 Einschalten mit Rampenot active
21​
ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschaltenactive
21​
ENG141663-ENG116600-Suchbeleuchtung_allgemein-Lichtsensor wirkt auf Suchbeleuchtungactive
21​
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS
5​
21​
ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM0.00 s
21​
ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert
50%​
21​
ENG141663-ENG142234-Suchbeleuchtung_allgemein-Umgebungs_helligkeit_auswahlFotosensor_Kombi
21​
ENG141663-ENG115819-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung AktivierungAlways active
21​
ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor
0.248​
21​
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert
1.00%​
21​
ENG141667-ENG115658-Suchbeleuchtung_Fotosensor-x0
0​
22​
ENG141667-ENG101574-Suchbeleuchtung_Fotosensor-X1
50​
22​
ENG141667-ENG115664-Suchbeleuchtung_Fotosensor-x10
0​
22​
ENG141667-ENG99557-Suchbeleuchtung_Fotosensor-X2
100​
22​
ENG141667-ENG102140-Suchbeleuchtung_Fotosensor-X3
200​
22​
ENG141667-ENG102936-Suchbeleuchtung_Fotosensor-X4
253​
22​
ENG141667-ENG103548-Suchbeleuchtung_Fotosensor-X5
0​
22​
ENG141667-ENG113992-Suchbeleuchtung_Fotosensor-X6
0​
22​
ENG141667-ENG115661-Suchbeleuchtung_Fotosensor-x7
0​
22​
ENG141667-ENG115662-Suchbeleuchtung_Fotosensor-x8
0​
22​
ENG141667-ENG115663-Suchbeleuchtung_Fotosensor-x9
0​
22​
ENG141667-ENG115659-Suchbeleuchtung_Fotosensor-y00 lx
22​
ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y150 lx
22​
ENG141667-ENG115668-Suchbeleuchtung_Fotosensor-y100 lx
22​
ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2100 lx
22​
ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3
200​
22​
ENG141667-ENG100631-Suchbeleuchtung_Fotosensor-Y4
500​
22​
ENG141667-ENG102174-Suchbeleuchtung_Fotosensor-Y5
0​
22​
ENG141667-ENG113993-Suchbeleuchtung_Fotosensor-Y60 lx
22​
ENG141667-ENG115665-Suchbeleuchtung_Fotosensor-y70 lx
22​
ENG141667-ENG115666-Suchbeleuchtung_Fotosensor-y80 lx
22​
ENG141667-ENG115667-Suchbeleuchtung_Fotosensor-y90 lx
22​
ENG141665-ENG115658-Suchbeleuchtung_Hochdimmen-x00 ms
22​
ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1200 ms
22​
ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x102000 ms
22​
ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2400 ms
22​
ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3600 ms
22​
ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4800 ms
22​
ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X51000 ms
22​
ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X61200 ms
22​
ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x71400 ms
22​
ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x81600 ms
22​
ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x91800 ms
22​
ENG141665-ENG115659-Suchbeleuchtung_Hochdimmen-y0
0.00%​
22​
ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1
1.00%​
22​
ENG141665-ENG115668-Suchbeleuchtung_Hochdimmen-y10
100.00%​
22​
ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2
3.00%​
22​
ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3
5.00%​
22​
ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4
11.00%​
22​
ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5
22.00%​
22​
ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6
40.00%​
22​
ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7
80.00%​
22​
ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8
95.00%​
22​
ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9
100.00%​
22​
ENG141669-ENG115658-Suchbeleuchtung_KL 58xs max-x00 lx
8​
ENG141669-ENG101574-Suchbeleuchtung_KL 58xs max-X18 lx
8​
ENG141669-ENG99557-Suchbeleuchtung_KL 58xs max-X250 lx
8​
ENG141669-ENG102140-Suchbeleuchtung_KL 58xs max-X3500 lx
8​
ENG141669-ENG115659-Suchbeleuchtung_KL 58xs max-y0
100​
8​
ENG141669-ENG99777-Suchbeleuchtung_KL 58xs max-Y1
100​
8​
ENG141669-ENG100480-Suchbeleuchtung_KL 58xs max-Y2
100​
8​
ENG141669-ENG100773-Suchbeleuchtung_KL 58xs max-Y3
100​
8​
ENG141668-ENG115658-Suchbeleuchtung_KL 58xs min-x00 lx
8​
ENG141668-ENG101574-Suchbeleuchtung_KL 58xs min-X18 lx
8​
ENG141668-ENG99557-Suchbeleuchtung_KL 58xs min-X250 lx
8​
ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3500 lx
8​
ENG141668-ENG115659-Suchbeleuchtung_KL 58xs min-y0
6​
8​
ENG141668-ENG99777-Suchbeleuchtung_KL 58xs min-Y1
6​
8​
ENG141668-ENG100480-Suchbeleuchtung_KL 58xs min-Y2
100​
8​
ENG141668-ENG100773-Suchbeleuchtung_KL 58xs min-Y3
100​
8​
ENG141674-ENG115658-Suchbeleuchtung_KL_58xd_log_Bus-x0
0.00%​
12​
ENG141674-ENG101574-Suchbeleuchtung_KL_58xd_log_Bus-X1
6.00%​
12​
ENG141674-ENG99557-Suchbeleuchtung_KL_58xd_log_Bus-X2
16.00%​
12​
ENG141674-ENG102140-Suchbeleuchtung_KL_58xd_log_Bus-X3
30.00%​
12​
ENG141674-ENG102936-Suchbeleuchtung_KL_58xd_log_Bus-X4
60.00%​
12​
ENG141674-ENG103548-Suchbeleuchtung_KL_58xd_log_Bus-X5
100.00%​
12​
ENG141674-ENG115659-Suchbeleuchtung_KL_58xd_log_Bus-y0
10​
12​
ENG141674-ENG99777-Suchbeleuchtung_KL_58xd_log_Bus-Y1
10​
12​
ENG141674-ENG100480-Suchbeleuchtung_KL_58xd_log_Bus-Y2
100​
12​
ENG141674-ENG100773-Suchbeleuchtung_KL_58xd_log_Bus-Y3
150​
12​
ENG141674-ENG100631-Suchbeleuchtung_KL_58xd_log_Bus-Y4
220​
12​
ENG141674-ENG102174-Suchbeleuchtung_KL_58xd_log_Bus-Y5
253​
12​
ENG141673-ENG115658-Suchbeleuchtung_KL_58xd_max-x00 lx
10​
ENG141673-ENG101574-Suchbeleuchtung_KL_58xd_max-X18 lx
10​
ENG141673-ENG99557-Suchbeleuchtung_KL_58xd_max-X2200 lx
10​
ENG141673-ENG102140-Suchbeleuchtung_KL_58xd_max-X3300 lx
10​
ENG141673-ENG102936-Suchbeleuchtung_KL_58xd_max-X4500 lx
10​
ENG141673-ENG115659-Suchbeleuchtung_KL_58xd_max-y0
16​
10​
ENG141673-ENG99777-Suchbeleuchtung_KL_58xd_max-Y1
16​
10​
ENG141673-ENG100480-Suchbeleuchtung_KL_58xd_max-Y2
100​
10​
ENG141673-ENG100773-Suchbeleuchtung_KL_58xd_max-Y3
100​
10​
ENG141673-ENG100631-Suchbeleuchtung_KL_58xd_max-Y4
100​
10​
ENG141672-ENG115658-Suchbeleuchtung_KL_58xd_min-x00 lx
10​
ENG141672-ENG101574-Suchbeleuchtung_KL_58xd_min-X18 lx
10​
ENG141672-ENG99557-Suchbeleuchtung_KL_58xd_min-X2220 lx
10​
ENG141672-ENG102140-Suchbeleuchtung_KL_58xd_min-X3300 lx
10​
ENG141672-ENG102936-Suchbeleuchtung_KL_58xd_min-X4500 lx
10​
ENG141672-ENG115659-Suchbeleuchtung_KL_58xd_min-y0
6​
10​
ENG141672-ENG99777-Suchbeleuchtung_KL_58xd_min-Y1
6​
10​
ENG141672-ENG100480-Suchbeleuchtung_KL_58xd_min-Y2
100​
10​
ENG141672-ENG100773-Suchbeleuchtung_KL_58xd_min-Y3
100​
10​
ENG141672-ENG100631-Suchbeleuchtung_KL_58xd_min-Y4
100​
10​
ENG141677-ENG115658-Suchbeleuchtung_KL_58xd_PWM-x0
0​
12​
ENG141677-ENG101574-Suchbeleuchtung_KL_58xd_PWM-X1
10​
12​
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2
100​
12​
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3
150​
12​
ENG141677-ENG102936-Suchbeleuchtung_KL_58xd_PWM-X4
220​
12​
ENG141677-ENG103548-Suchbeleuchtung_KL_58xd_PWM-X5
253​
12​
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0
6.00%​
12​
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1
6.00%​
12​
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2
16.00%​
12​
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3
30.00%​
12​
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4
60.00%​
12​
ENG141677-ENG102174-Suchbeleuchtung_KL_58xd_PWM-Y5
100.00%​
12​
ENG141670-ENG115658-Suchbeleuchtung_KL_58xt min-x00 lx
8​
ENG141670-ENG101574-Suchbeleuchtung_KL_58xt min-X18 lx
8​
ENG141670-ENG99557-Suchbeleuchtung_KL_58xt min-X250 lx
8​
ENG141670-ENG102140-Suchbeleuchtung_KL_58xt min-X3500 lx
8​
ENG141670-ENG115659-Suchbeleuchtung_KL_58xt min-y0
6​
8​
ENG141670-ENG99777-Suchbeleuchtung_KL_58xt min-Y1
6​
8​
ENG141670-ENG100480-Suchbeleuchtung_KL_58xt min-Y2
100​
8​
ENG141670-ENG100773-Suchbeleuchtung_KL_58xt min-Y3
100​
8​
ENG141671-ENG115658-Suchbeleuchtung_KL_58xt_max-x00 lx
8​
ENG141671-ENG101574-Suchbeleuchtung_KL_58xt_max-X18 lx
8​
ENG141671-ENG99557-Suchbeleuchtung_KL_58xt_max-X250 lx
8​
ENG141671-ENG102140-Suchbeleuchtung_KL_58xt_max-X3500 lx
8​
ENG141671-ENG115659-Suchbeleuchtung_KL_58xt_max-y0
100​
8​
ENG141671-ENG99777-Suchbeleuchtung_KL_58xt_max-Y1
100​
8​
ENG141671-ENG100480-Suchbeleuchtung_KL_58xt_max-Y2
100​
8​
ENG141671-ENG100773-Suchbeleuchtung_KL_58xt_max-Y3
100​
8​
ENG141676-ENG115658-Suchbeleuchtung_KL_58xt_PWM-x0
0.00%​
6​
ENG141676-ENG101574-Suchbeleuchtung_KL_58xt_PWM-X1
50.00%​
6​
ENG141676-ENG99557-Suchbeleuchtung_KL_58xt_PWM-X2
100.00%​
6​
ENG141676-ENG115659-Suchbeleuchtung_KL_58xt_PWM-y0
0.00%​
6​
ENG141676-ENG99777-Suchbeleuchtung_KL_58xt_PWM-Y1
50.00%​
6​
ENG141676-ENG100480-Suchbeleuchtung_KL_58xt_PWM-Y2
100.00%​
6​
ENG141680-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x00 lx
12​
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1200 lx
12​
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2400 lx
12​
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3600 lx
12​
ENG141680-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4800 lx
12​
ENG141680-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X51020 lx
12​
ENG141680-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0
0​
12​
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1
84​
12​
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2
166​
12​
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3
250​
12​
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4
370​
12​
ENG141680-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5
500​
12​
ENG141664-ENG115633-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x00 ms
10​
ENG141664-ENG115634-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x12000 ms
10​
ENG141664-ENG115635-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x23000 ms
10​
ENG141664-ENG115636-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x34000 ms
10​
ENG141664-ENG115637-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x45100 ms
10​
ENG141664-ENG115638-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y0
1.00%​
10​
ENG141664-ENG115639-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y1
5​
10​
ENG141664-ENG115640-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y2
15​
10​
ENG141664-ENG115641-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y3
40​
10​
ENG141664-ENG115642-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y4
100​
10​
ENG141632-ENG116647-Sunroof-SAD Komfort oeffnenactive
4​
ENG141632-ENG116646-Sunroof-SAD Komfort schliessenactive
4​
ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnentilting
4​
ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1not installed
4​
ENG141632-ENG141971-Sunroof-Schiebedachmodul_MD_3not installed
4​
ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollonot installed
4​
ENG141632-ENG142022-Sunroof-Verortung SchiebedachmoduleLIN
4​
ENG141969-ENG249827-UGDO-Anlernblinkenactive
3​
ENG141969-ENG249832-UGDO-Bedienfeldinstalled
3​
ENG141969-ENG172987-UGDO-ugdo_transmitterinstalled
3​
ENG141969-ENG172966-UGDO-ugdo_via_mmi_configurablenot active
3​
ENG141634-ENG142013-Verdecksteuergeraet-Cabrio_Verdecknot_installed
9​
ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdecknot active
9​
ENG141634-ENG128459-Verdecksteuergeraet-easycloselight_aktivnot active
9​
ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetriebnot active
9​
ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_closenot installed
9​
ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck globalactive
9​
ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnenactive
9​
ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließenactive
9​
ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklaufactive
9​
ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessennot active
9​
ENG141634-ENG125652-Verdecksteuergeraet-Servoheck SchlossansteuerungAlways
9​
ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung sendennur wenn freigegeben
9​
ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unitnot installed
9​
ENG141634-ENG116717-Verdecksteuergeraet-Verdeck mit Schiebedachnot active
9​
ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienungnot active
9​
ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessynot active
9​
ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinderactive
9​
ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienungnot active
9​
ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessyactive
9​
ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinderactive
9​
ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedalnot active
9​
ENG141634-ENG126611-Verdecksteuergeraet-virtuelles_pedal_HMI_einstellbarnot active
9​
ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbaunot installed
9​
ENG141634-ENG246994-Verdecksteuergeraet-Virtuelles_Pedal_VersionVersion_1_2
9​
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 100 00
20​
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 200 00
20​
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 300 00
20​
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 400 00
20​
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 100 00
20​
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 200 00
20​
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 300 00
20​
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 400 00
20​
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 500 00
20​
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 600 00
20​
ENG249803-ENG249921-Waschen_Parameter-N_RVC_Activation
5​
8​
ENG249803-ENG249941-Waschen_Parameter-T1_RVC_Treshold30 s
8​
ENG249803-ENG249942-Waschen_Parameter-T2_RVC_Deactivation180 s
8​
ENG124901-Wischer_Fehlermaske_Mitsuba_Entw0 bit
4​
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute
42​
3​
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute
62​
3​
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute
30​
3​
ENG141651-ENG116632-ZV allgemein-Bewusstes Safe mit 2. Betaetigung der FFBnot active
7​
ENG141651-ENG133387-ZV allgemein-Deaktivierung_Laderaumschliessung_externnot active
7​
ENG141651-ENG125653-ZV allgemein-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstasteractive
7​
ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Einactive
7​
ENG141651-ENG115754-ZV allgemein-Funk bei Klemme 15 einnot active
7​
ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direktnot installed
7​
ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Tasternot installed
7​
ENG141651-ENG133388-ZV allgemein-LS_Taster_Togglefunktionnot active
7​
ENG141651-ENG116633-ZV allgemein-Menuesteuerung Tuerentriegelungactive
7​
ENG141651-ENG115755-ZV allgemein-Notschließfunktionnot active
7​
ENG141651-ENG133389-ZV allgemein-Nutzfahrzeug_Schliessungnot active
7​
ENG141651-ENG141957-ZV allgemein-Radio freq.315MHz
7​
ENG141651-ENG141958-ZV allgemein-TankschlossBidirectional
7​
ENG141651-ENG133390-ZV allgemein-Wiederverriegelung_LaderaumFreigabe_Softtouch
7​
ENG141651-ENG116623-ZV allgemein-ZV TuerentriegelungEinzeltuerentriegelung
7​
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktioninstalled
7​
ENG141654-ENG116628-ZV Autolock-Autolock Autounlock wirkt auf Heckactive
3​
ENG141654-ENG116621-ZV Autolock-automatisches Entriegelnactive
3​
ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeitactive
3​
ENG141654-ENG116706-ZV Autolock-Autounlock NARactive
3​
ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelungnot active
3​
ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlockadjustable
3​
ENG141655-ENG116627-ZV Crash-Heckdeckel-Bedienstellen nachCrash temporaer sperrenactive
4​
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessenactive
4​
ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrashactive
4​
ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckelsactive
7​
ENG141653-ENG126839-ZV Heck-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgangnot active
7​
ENG141653-ENG116707-ZV Heck-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktasternot active
7​
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentastervia_CAN
7​
ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerungnot active
7​
ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungenactive
7​
ENG141653-ENG141998-ZV Heck-Heckschloss_mit_VorrasteYes
7​
ENG141653-ENG141995-ZV Heck-Heckschloss_SteuerungPulse control
7​
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster0.0 s
7​
ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegeltnot active
7​
ENG141653-ENG141982-ZV Heck-Tausch_Tank_HecktreiberausgangNo
7​
ENG141653-ENG115760-ZV Heck-ZV entriegelt auch Heckdeckelactive
7​
ENG141653-ENG116629-ZV Heck-ZV Heck nur direkt auswerfennot active
7​
ENG141653-ENG141997-ZV Heck-ZV_Heck_Schlosstyp1 or 2 notch rear actuator
7​
ENG141681-IDE02021-ZV Komfort-Comfort closingactive
8​
ENG141681-IDE02022-ZV Komfort-Comfort openingnot active
8​
ENG141681-ENG141984-ZV Komfort-elektrischer_Fensterheber_hintenNo
8​
ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnennot active
8​
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessennot active
8​
ENG141681-ENG116662-ZV Komfort-FH SAD Kl15Aus Freigabezeit600 s
8​
ENG141681-ENG116648-ZV Komfort-Freigabenachlauf FH bei Kl 15 ausactive
8​
ENG141681-ENG122993-ZV Komfort-Freigabenachlauf FH bei Tueroeffnen abbrechenactive
8​
ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnenactive
8​
ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessennot active
8​
ENG141681-ENG115670-ZV Komfort-Komfortbedienung globalactive
8​
ENG141681-ENG116642-ZV Komfort-Komfortoeffnen nur FH Fahrertuernot active
8​
ENG141681-ENG122994-ZV Komfort-Menuesteuerung Komfortbedienung einstellbaradjustable
8​
ENG141681-ENG122186-ZV Komfort-Menuesteuerung Regenschliessennot active
8​
ENG141681-ENG125656-ZV Komfort-Regenschliessen_artonce
8​
ENG141681-ENG125655-ZV Komfort-Regenschliessen_ein_ausnot active
8​
ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnenactive
8​
ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessenactive
8​
ENG141652-ENG141999-ZV Türkonfiguration-Fond_SchlossTuersteuergeraet im Fond verbaut oder keine Fondtuer
5​
ENG141652-ENG142043-ZV Türkonfiguration-HFT_Invertierung_Drehfallensignalnicht invertiert
5​
ENG141652-ENG142039-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Beifahrerseitenot installed
5​
ENG141652-ENG142038-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Fahrerseitenot installed
5​
ENG141652-ENG142001-ZV Türkonfiguration-Schiebetuer_linksNo
5​
ENG141652-ENG142002-ZV Türkonfiguration-Schiebetuer_rechtsNo
5​
ENG141652-ENG142041-ZV Türkonfiguration-Schiebetueren_Crafternot installed
5​
ENG141652-ENG142244-ZV Türkonfiguration-Schiebetuerschloss_direkt_BCMDriver side
5​
ENG141652-ENG116631-ZV Türkonfiguration-Schliessung der Schiebetuer bei geoeffneter Tankklappenot active
5​
ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NARYes
5​
ENG141652-ENG141959-ZV Türkonfiguration-ViertuererNo
5​
Set Automatic Transmission Start Mode to D or S
[09 - Cent. Elect.] [Security Access - 10]
[Adaptation 10] -> Channel 64
Stored Value = 218 = Starting mode is always D
These instructions are clearly for an older, pre-UDS control module. You have a newer control module that uses the UDS protocol, which uses named rather than numbered channels, and those instructions are not applicable.
jeffc
Illinois
C?ID=444936
Thanks. I'm glad it was clear to someone.... I'll see if I can find similar instructions for the UDS protocol.
AINils
Germany (AIB)
C?ID=56975
this coding isnt possible anymore on MQB Vehicle. Your coding instructions are related to old MLB cars, but never was uses in PQ or MQB cars. You only can reach your goal by editing Dataset of Gateway at offset 0xB80. But this can't be done with VCDS! So no Details in here
  • Informative
jeffc
Illinois
C?ID=444936
Thanks for clearing that up for me.
vinadre
France
C?ID=519944
Hi jeffc,
I'm trying to do the retrofit of the alarm horn, i saw that you posted all the adaptations of module 9.
Can you tell me if your alarm horn comes from the factory or a retrofit ?
