Another Interface Not Found (HEX-V2)
texpoops
NY, USA
C?ID=435054
I've read through about 10 or so interface not found threads and none of the solutions I have tried have yielded any results. VCDS worked perfectly fine 30 minutes ago and now when I plug it in is says status OK interface not found. When clicking ok to go to the updater there are no updates found. I'm running the 22.3.1 which is now a fresh download because I tried to uninstall and reinstall. Very confused because everything worked perfectly fine before I went on a parts run.
You have a HEX-V2.
Please describe the behavior of the LEDs when you
- Plug it into your computer only.
- Plug it into a car only
- Have it connected to both your computer and a car.
texpoops
NY, USA
C?ID=435054
You have a HEX-V2.
Just went out to check the LEDs and now it works perfectly fine, false alarm I suppose.
Well, if you have this problem again, you'll know what/how to observe and report. :)
