Hi folks.
I've helped a friend retrofit hadlex awd into a 2010 Skoda octavia vrs 2.0tsi dsg. The awd all functions correctly! We're having issues getting the abs to play ball!
At first the original abs unit was throwing codes for incorrect unit fitted and G251 sensor no basic setting. I realised that the 2wd abs unit doesn't have the G251 built into it, so my friend sourced an awd unit. We've fitted the unit and all the basic settings have worked, but obviously the coding is now the issue! I copied the original abs unit coding before removal as I knew we'd need it, but the new abs unit will not take any coding, it just throws the error 31 coding out of range code. I did realise the coding was a byte shorter on the new abs unit coding so I tried to drop 00 off the end of the original coding, this still didn't work.
This is the coding off the original 2wd abs unit :- 163B601C09290001681206E690210081340800
This is coding I got off a generator for the new unit (which i believe is incorrect!) :- 863D8016092800FB610C01E7901D00823004
Here is a full scan off the car now, all awd functioning and coded correctly bar the abs..
All help greatly appreciated!!
Chassis Type: 1Z-SK35 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 22 25 42 44 46 52 56 62 72
VIN: TMBEF61Z1A2077728 Mileage: 235930km-146600miles
Address 01: Engine (CCZ) Labels:. 06J-907-115-CCZ.clb
Part No SW: 1Z0 907 115 AF HW: 1Z0 907 115 F
Component: 2.0l R4/4V TFSI 0010
Revision: AAH11--- Serial number:
Coding: 0203000C1C070160
Shop #: WSC 66565 257 00032
VCID: 79BACA2E30105A4788-802C
VINID: 91D49558606A0510801C71C220524A8179
Readiness: 0010 0000
Part No SW: 02E 300 013 K HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2602
Revision: 05351112 Serial number: 00001011130502
Shop #: WSC 01236 785 00200
VCID: 197AEAAED050BA4728-804C
28907 - No Communications with Cruise Control (Front) Distance Sensor
U0235 - 000 -
Fault Frequency: 255
Mileage: 235933 km
Date: 2016.09.22
Time: 16:16:46
18261 - Powertrain Data Bus
P1853 - 000 - Implausible Message from ABS Controller
Mileage: 235933 km
Date: 2016.09.22
Time: 16:16:46
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 3T0 907 379 C HW: 3T0 907 379 C
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
Coding: 000000000000000000000000000000000000
Shop #: WSC 33361 790 00999
VCID: 3D321E3EA4B8A667E4-8068
Reset counter: 13
Date: 2016.09.22
Time: 16:16:46
Count: 12
Count: 4608
Count: 195
Count: 42240
Count: 65280
Part No SW: 3T0 907 044 AR HW: 3T0 907 044 AR
Component: Climatronic H15 0401
Revision: 00005001
Coding: 0000000002
Shop #: WSC 73430 790 00999
ROD: EV_ClimaAutoBasis_SK35.rod
VCID: 0248ADC295C6199FD9-8056
Part No SW: 1K0 937 087 D HW: 1K0 937 087 D
Component: BCM PQ35 H 103 0575
Revision: 00103 AG
Coding: 48180AB8B05BB1C040080080110001E4430000AE424D8960800440040000
VCID: 32283D026DE6691F09-8066
Subsystem 1 - Part No: 1Z2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 16120 22 0601
Coding: 00D7B7
Subsystem 2 - Part No: 1Z0 951 171
Component: Innenraumuebe 008 5101
Reset counter: 13
Mileage: 235933 km
Date: 2016.09.22
Time: 16:16:46
Voltage: 11.60 V
Term 50 Off
Component: Q8 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD2HPRVM
Coding: 0020792
VCID: 3D321E3E64B8A667E4-8068
Subsystem 1 - Serial number: 6332MSME4E10666FN
Subsystem 2 - Serial number: 6342MSME407046272
Subsystem 3 - Serial number: 6351HSME1F44136DE
Subsystem 4 - Serial number: 6361HSME1F4420385
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
Component: J0527 056 0111
Coding: 0001632
VCID: 76A0C112010E353FE5-8022
Subsystem 1 - Part No: 3T0 959 537 A Labels: 3C8-959-537.CLB
Component: E221__MFL-URO H07 0012
Coding: 00000131
Part No SW: 1Z0 920 943 H HW: 1Z0 920 943 H
Component: KOMBI H05 0305
Coding: 410900
Shop #: WSC 73430 031 00999
ROD: EV_Kombi_UDS_VDD_RM09_004_SK35.rod
VCID: 3E301932A1BEBD7FFD-806A
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H16 0233
Revision: H16 Serial number: 4520K09C1807F7
Coding: ED827F06000202001303
VCID: 699A9A6E40B0EAC778-803C
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 0BR 907 554 C HW: 0BR 907 554 C
Component: Haldex 4Motion 3018
Coding: 0000005
VCID: 45C276DE0C68EEA7BC-8010
Component: IMMO H05 0305
VCID: 6A98E5628DB6E1DF71-803E
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2114
Coding: 0000756
VCID: 48DC7FEA3B7AF3CF47-801C
00120 - Outside Warning Light/Door exit Light Driver Side
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 74 3001
Revision: 00H17000
VCID: 312A320EA8E0520770-8064
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0000756
VCID: 47DE7CD63664FCB74E-8012
Part No SW: 1Z0 035 156 F HW: 1Z0 035 156 F
Component: BOLERO 008 0053
Revision: 0A001001 Serial number: SKZ1Z3I8183343
Coding: 010004000001
VCID: 3522061E9C887E272C-8060
Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 73430 790 1012551
VCID: 32283D02ADE6691F09-8066
Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
Coding: 0000144
VCID: 3326380652FC601702-8066
End----(Elapsed Time: 01:06, VBatt start/end: 11.7V/11.6V. VIgn 11.7V)-----
