Seat Leon FR (1P) 1K0907379AD ABS Module Coding (MK60EC1)
littlemamon
Argentina
C?ID=163140
I'm having issues coding the ABS module on a Seat Leon FR (1P). It's a 1K0 907 379 AD ESP MK60EC1 H35 0104.
That car has recently had a front and rear brakes swap using the OEM units from a 8P Audi S3 (345mm & 310mm).
Since then, the ABS is not working properly and it recods the code 16352 as intermitent.
The first thing that I've tried to do was to code the ABS module for the new brakes but it didn't accept the new coding.
The OEM code on byte 2 is 60 and 06 on byte 10 which are the correct values for the OEM brakes (312mm Front & 253mm Rear).
According to what I was able to find 80 on byte 2 and 01 on byte 10 would be the correct values for the S3 brakes but it doesn't accept that new coding.
I don't know if the coding that I'm using is wrong or if there's another problem so I would definetely need your help with this.
Thanks in advance for your help!
Regards,
Pablo.
Auto-scan from that vehicle:
Wednesday,27,April,2022,18:47:18:35146
VCDS Version: 22.3.1.1 (x64)
Data version: 20220401 DS337.0
VIN: VSSCE61P99R029582   License Plate:
Chassis Type: 1P (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72 75 77
VIN: VSSCE61P99R029582   Mileage: 96360km-59875miles
   Part No SW: 1P0 907 115 H    HW: 8P0 907 115 B
   Revision: 5BH16---    Serial number: SEZ7Z0H3999977
   Coding: 030300431C070160
   Shop #: WSC 00006 000 00000
   VCID: 306FA987A3AA190F7A-8064
   VINID: 9A38D354606024988008914808C68441B1
   Part No SW: 02E 300 051 C    HW: 02E 927 770 AJ
   Component: GSG DSG AG6     431 1817
   Revision: 04843012    Serial number: 00000808200160
   Coding: 0000024
   Shop #: WSC 44551 111 44551
   VCID: 1325060B32FCC21767-8046
   Part No SW: 1K0 907 379 AD    HW: 1K0 907 379 AD
   Component: ESP MK60EC1   H35 0104
   Revision: 00H35001
   Coding: 143B601209240003281006EC901B0041B400
   Shop #: WSC 04941 000 00000
   VCID: 74E76597D732652FDE-8020
16352 - Control Module - Electrical Error
                    Fault Status: 00101110
                    Reset counter: 101
                    Mileage: 96360 km
                    Count: 17984
                    Count: 12800
                    Count: 96
                    Count: 48401
                    Count: 2
                    Count: 9984
   Part No: 1P0 907 044 D
   Component: ClimatronicPQ35 011 0702
   VCID: 2D51B0F3B49874E751-8078
   Revision: 00H54000    Serial number: 00000005891348
   Coding: 838E0F2F00041000431D0000000000800001FF055C400000000000000000
   Shop #: WSC 02334 007 00004
   VCID: 3365A68B52BC221707-8066
   Subsystem 1 - Part No: 1P0 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 040808 022  0601
   Coding: 00056208
   Shop #: WSC 02334
   Part No SW: 5N0 959 655 J    HW: 5N0 959 655 J
   Component: J234__A0A VW10 HI   1916
   Revision: 20013000    Serial number: 003E2P5UFP2Z
   Coding: 0012353
   Shop #: WSC 05002 985 88716
   VCID: 4487F557071295AFAE-8010
   Subsystem 1 - Serial number: 6332MTS647731858
   Subsystem 2 - Serial number: 6342MTS652121788
   Subsystem 3 - Serial number: 6351HTS6HE14B6KR
   Subsystem 4 - Serial number: 6361HTS6897JUVNH
   Part No SW: 1K0 953 549 BG    HW: 1K0 953 549 BG
   Component: J0527           752 0101
   Coding: 0012142
   Shop #: WSC 06403 785 00200
   VCID: 78FF51A70B5A014FF2-802C
   Part No: 1P0 920 841 B
   Component: KOMBIINSTRUMENT VO3 0750
   Coding: 0006101
   VCID: 2B55BEEB8A8C7AD74F-807E
   Component: J533__Gateway   H16 0202
   Revision:   H16       Serial number: 2700K089090428
   Coding: ED817F062006020202
   VCID: 356198935CC83C2729-8060
   Component: IMMO            VO3 0750
   Part No SW: 1T0 959 701 L    HW: 1K0 959 793 P
   Component: J386  TUER-SG FT    1517
   Revision: 71009005    Serial number: 00000035788604
   Coding: 0004272
   VCID: 408FF947130A898F8A-8014
                    Fault Status: 00101100
                    Reset counter: 101
                    Mileage: 96354 km
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.142 H08 1901
   Coding: 998000005283CC7F7F0685056008CF86307800
   VCID: 0305364B429C5297D7-8056
   Subsystem 5 - Part No: 1P0 951 171 A
   Component: Innenraumueberw.010 4974
   Coding: 00000000
   Shop #: WSC 06403
   Subsystem 6 - Part No: 1K0 951 605 C
   Subsystem 7 - Component:       NGS n.mounted
                    Reset counter: 61
                    Mileage: 96347 km
                    Time: 13:10:00
                    Reset counter: 101
                    Mileage: 96360 km
                    Time: 18:46:20
   Part No SW: 1T0 959 702 L    HW: 1K0 959 792 P
   Component: J387  TUER-SG BT    1517
   Revision: 71009005    Serial number: 00000619688602
   Coding: 0004272
   VCID: 4189FC431800808785-8014
Address 55: Headlight Range        Labels: 5M0-907-357-V2.clb
   Component: AFS-Steuergeraet    0133
   Coding: 2556933
   Shop #: WSC 00000 785 00200
   VCID: 3467A59757B2252F1E-8060
   Subsystem 1 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
   Coding: 00000039
   Subsystem 2 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
   Coding: 00000039
   Part No SW: 6RD 035 187 B    HW: 6RD 035 187 B
   Component: Radio         534 5314
   Revision: --------    Serial number: VWZZZ4R6211659
   Coding: 16000400040005
   Shop #: WSC 00078 790 00217
   VCID: 4683EF5FF12EA7BFB0-8012
                    Reset counter: 61
                    Mileage: 96347 km
                    Time: 13:10:06
                    Fault Status: 00110100
                    Reset counter: 61
                    Mileage: 96347 km
                    Time: 13:12:25
                    Reset counter: 61
                    Mileage: 96349 km
                    Time: 15:32:34
   Part No SW: 1K0 959 703 AF    HW: 1K0 959 795 S
   Component: J388   TUER-SG HL   1401
   Revision: 11006001    Serial number: 00000003323513
   Coding: 0000144
   VCID: 74E765971732652FDE-8020
   Part No SW: 1K0 959 704 AF    HW: 1K0 959 794 S
   Component: J389   TUER-SG HR   1401
   Revision: 11006001    Serial number: 00000003327813
   Coding: 0000144
   VCID: 75E158931C487C27E9-8020
Address 75: Telematics
Address 77: Telephone        Labels: 5P0-862-335.lbl
   Part No SW: 5P0 862 335 B    HW: 5P0 862 335 B
   Component: FSE_2P5x        H30 0110
   Revision: 00000001    Serial number: 00000005052529
   Coding: 0000555
   VCID: 326BA38FADA62B1F0C-8066
End-------------------------(Elapsed Time: 02:20)--------------------------
Screen shot of the error that I get when I tried to code the ABS module:
Then this is a retrofit, not a repair. Moving.
JMR
Romania
C?ID=432218
It seems that you have an electrical problem not a coding problem per se...:confused:
etz2k
C?ID=69430
The first MK60EC1 with HW:35 (like yours) are prone to fail.
You can try to to set in Byte 16 Bit 2 = 0 (disable RKA) if this works, to test if coding is possible.(because your new coding is OK)
There was since 2017 a Recall for your ABS (FW Update), why your ABS don't have it? You should buy a ABS with HW:31 and throw your old away.
littlemamon
Argentina
C?ID=163140
Thank you guys so much for all the replies, they're much appreciated!
The ABS module from this car was supposed to be firmware updated by VW under the recall so I didn't pay much attention to the error code or to the software version that the scan showed.
Once I'd took a second look at that I realized that the issue was not coding related rather than the ABS modue itself. Either the firmware update wasn't performed correctly or it wasn't performed at all.
We're trying to get a response from VW about this and I'll let you know what they have to say once they reply.
Thanks again for your help! :thumbs:
Reactions: JMR
etz2k
C?ID=69430
Your ABS didn't have SW:120 = no 45F2 recall made. The recall started mid 2017, than you get 24 month warrenty (so it was in germany). But now, i think it's to late and you must pay and not Seat. That's life.
littlemamon
Argentina
C?ID=163140
The FW update was handled differently here and, since they supposedly upgraded the firmware, we're hoping that they take care of this . If not, we'll have to find another way. Thanks again for your replies!
littlemamon
Argentina
C?ID=163140
Hello guys, I'd need your help again because the dealership won't take care of the software update.
So I decided to change the ABS module and I would need to know what modules should I be looking for that won't have the same issue as the 1K0907379AD H35 0104?
JMR
Romania
C?ID=432218
Perhaps @Jef would be kind and take a second of his time ?
littlemamon
Argentina
C?ID=163140
Please @Jef, would you be so kind to take a look at this?
etz2k
C?ID=69430
I'm not Jef, but i recommend to use a -BL or better a -CC ABS. If you have the "new" ABS i can help you with the coding.
