- Mar 21, 2022
- 5
- 3
- Magalia, CA, USA
- C?ID=389081
hi guys
I need help finding a coding that will work. Its a 2012passat tdi ckra. Vin# 1VWBN7A35CC054020
Tuesday,26,April,2022,12:32:30:02325
VCDS Version: 22.3.1.1 (x64) HEX-V2 CB: 0.4615.4
Data version: 20220401 DS337.0
VIN: 1VWBN7A35CC054020 License Plate:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 4F 52 56 62 72 77
VIN: 1VWBN7A35CC054020 Mileage: 303240km-188424miles
02-Auto Trans -- Status: Cannot be reached 1100
04-Steering Angle -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: Cannot be reached 1100
44-Steering Assist -- Status: Cannot be reached 1100
52-Door Elect, Pass. -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Cannot be reached 1100
Address 01: Engine (J623-CKRA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 997 009 J HW: 03L 907 309 S
Component: R4 2.0l TDI H21 9982
Revision: 71H21--- Serial number: CVN: D240C61F5C3E0D04
Coding: 001D0012042400000000
Shop #: WSC 26113 444 00000
ASAM Dataset: EV_ECM20TDI01103L997009J 004005
ROD: EV_ECM20TDI01103L997009J.rod
VCID: 3B2339AAA3E53183DA8-806E
VINID: 0669D27874431534C014400200BA87ABCA
4718 - No Communication with Transmission Control Module
U0101 00 [039] - -
Mileage: 303245 km
Date: 2022.04.26
Time: 00:44:49
Engine RPM: 0.00 /min
Coolant temperature: 17 °C
Intake air temperature: 17 °C
Ambient air pressure: 920 mbar
Voltage terminal 30: 12.600 V
Requested transmission torque: 1000.0 Nm
Limitation: accelerator pedal: 220.0 Nm
Cruise Control System (CCS): status-Bits 0-7: 15
selected gear-Bits 0-7: 0
Transmission torque intervention status-Bits 0-7: 16
Transmission torque intervention status-Bits 0-7: 128
Calculated reducing transmission intervention torque: 1000.0 Nm
17262 - Terminal 30
U140A 00 [039] - Open Circuit
[Terminal 30Open circuit]
Time: 00:00:00
Vehicle speed: 255 km/h
Coolant temperature: -40 °C
Intake air temperature: -40 °C
Ambient air pressure: 0 mbar
Voltage terminal 30: 12.820 V
Limitation: torque: 0.0 Nm
Cruise Control System (CCS): status-Bits 0-7: 0
Engine torque: -500.0 Nm
Generator: load signal: 0.00 %
Readiness: 0 0 0 1 1
Address 02: Auto Trans
Revision: 00H31001
Shop #: WSC 00066 000 00000
VCID: 7DA7F7B2FDF1FFB3A4C-8028
7 Faults Found:
03839 - RPM Sensor Front Left: Incorrect Signal
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:45:30
Count: 16386
Count: 12
Count: 4096
Count: 39
Count: 44800
Count: 65024
00285 - ABS Wheel Speed Sensor; Front Right (G45)
Fault Status: 00101100
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:48:41
Count: 16386
Count: 12
Count: 4096
Count: 48
Count: 44800
Count: 62720
03306 - Coding Not Valid
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:10
Count: 16387
Count: 12
Count: 4096
Count: 4161
Count: 44800
Count: 64768
Reset counter: 114
Date: 2022.04.26
Time: 00:45:23
Count: 16387
Count: 12
Count: 20992
Count: 195
Count: 44800
Fault Status: 01100101
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:45:17
Count: 16387
Count: 12
Count: 4096
Count: 279
Count: 44800
Count: 65024
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:45:17
Count: 16387
Count: 12
Count: 4096
Count: 295
Count: 44800
Count: 65024
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:45:17
Count: 16387
Count: 12
Count: 4096
Count: 270
Count: 44800
Count: 65024
Part No SW: 561 907 044 H HW: 561 907 044 H
Component: Climatronic 043 0202
Revision: 00001001
Coding: 0010001002
Shop #: WSC 09003 957 00200
VCID: 1C61DA36062B56BB332-8048
15 Faults Found:
9473137 - Motor for Left Temperature Flap
B108C 71 [008] - Actuator Stuck
Reset counter: 154
Mileage: 303245 km
Date: 2022.04.27
Time: 00:05:56
9475093 - Position Sensor for Left Temperature Flap Motor
B1094 15 [009] - Open or Short to Plus
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.27
Time: 00:03:33
9475349 - Position Sensor for Right Temperature Flap Motor
B1095 15 [009] - Open or Short to Plus
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.27
Time: 00:03:43
9476117 - Position Sensor for Defrost Flap Motor
B1098 15 [009] - Open or Short to Plus
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:00:07
9476373 - Position Sensor for Front Air Distribution Flap Motor
B1099 15 [009] - Open or Short to Plus
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.27
Time: 00:00:07
9476885 - Position Sensor for Fresh/Recirculated Flap Motor
B109B 15 [009] - Open or Short to Plus
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:00:07
9470741 - Temperature Sensor for Left Footwell Vent
B1083 15 [009] - Open or Short to Plus
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:00:00
9470997 - Temperature Sensor for Right Footwell Vent
B1084 15 [009] - Open or Short to Plus
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:00:00
9471765 - Temperature Sensor for Left Vent
B1087 15 [009] - Open or Short to Plus
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:00:00
9472021 - Temperature Sensor for Right Vent
B1088 15 [009] - Open or Short to Plus
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:00:00
9472533 - Temperature Sensor for Evaporator Vent
B108A 15 [009] - Open or Short to Plus
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:00:00
9481748 - High Pressure Sensor
B10AE 14 [009] - Open or Short to Ground
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.27
Time: 00:00:08
9480469 - Control Circuit for A/C Compressor
B10A9 15 [008] - Open or Short to Plus
Reset counter: 154
Mileage: 303245 km
Date: 2022.04.27
Time: 00:00:07
9496597 - Sunlight Photo Sensor
B10E8 15 [008] - Open or Short to Plus
Reset counter: 154
Mileage: 303245 km
Date: 2022.04.26
Time: 00:03:02
9478421 - Diagnostic Line for Front Air Blower
B10A1 15 [009] - Open or Short to Plus
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.27
Time: 00:02:24
Part No SW: 5K0 937 085 S HW: 5K0 937 085 S
Component: BCM PQ35 B+ 021 0064
Revision: BH021001
Coding: 6F200E1B902B08D408880001160004480171008640A00560E48060000C70
VCID: 43D3414ADB954943928-8016
29 Faults Found:
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:23
Term 15 On
Voltage: 12.60 V
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:27
Term 15 On
Voltage: 12.60 V
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:27
Term 15 On
Voltage: 12.60 V
00984 - Left Tail Light (M4)
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:27
Term 15 On
Voltage: 12.60 V
00985 - Right Tail Light (M2)
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:27
Term 15 On
Voltage: 12.55 V
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:26
Term 15 On
Voltage: 12.55 V
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:24
Term 15 On
Voltage: 12.55 V
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:24
Term 15 On
Voltage: 12.55 V
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:24
Term 15 On
Voltage: 12.55 V
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:24
Term 15 On
Voltage: 12.55 V
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:24
Term 15 On
Voltage: 12.55 V
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:26
Term 15 On
Voltage: 12.55 V
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:28
Term 15 On
Voltage: 12.55 V
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:26
Term 15 On
Voltage: 12.55 V
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:28
Term 15 On
Voltage: 12.55 V
01503 - Bulb for 3rd Brake Light (M25)
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:28
Term 15 On
Voltage: 12.55 V
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:28
Term 15 On
Voltage: 12.55 V
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:14:24
Term 15 On
Voltage: 12.05 V
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:14:24
Term 15 On
Voltage: 12.20 V
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:28
Term 15 On
Voltage: 12.55 V
01800 - Light Switch (E1)
008 - Implausible Signal
Fault Status: 01101000
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:22
Term 15 On
Voltage: 12.55 V
02092 - Enabling Heated Seat
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:24
Term 15 On
Voltage: 12.60 V
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:14:25
Term 15 On
Voltage: 12.15 V
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:14:25
Term 15 On
Voltage: 12.15 V
02742 - Bulb for Brake/Turn Signal Light; Left
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:24
Term 15 On
Voltage: 12.60 V
02743 - Bulb for Brake/Turn Signal Light; Right
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:24
Term 15 On
Voltage: 12.60 V
03188 - Bulb for Side Marker Light; Front Left
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:27
Term 15 On
Voltage: 12.55 V
03189 - Bulb for Side Marker Light; Front Right
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:27
Term 15 On
Voltage: 12.55 V
01339 - Door Warning Light
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:14:25
Term 15 On
Voltage: 12.30 V
Part No SW: 5C0 959 655 HW: 5C0 959 655
Component: AirbagVW10G 013 0809
Serial number: 003ENM01C4TM
Coding: 00003548
ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 6FBBDDFAA71D9D23260-803A
24 Faults Found:
9440027 - Driver's side; side-airbag igniter
B100B 1B [137] - Resistance Too High
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:03
9439771 - Front Passenger's Side Airbag Igniter
B100A 1B [137] - Resistance Too High
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:03
9438491 - Igniter for Driver head airbag
B1005 1B [137] - Resistance Too High
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:03
9438235 - Igniter for Front passenger's Head Curtain Airbag
B1004 1B [137] - Resistance Too High
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:03
9437211 - Igniter for Driver's Airbag
B1000 1B [137] - Resistance Too High
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:03
9437723 - Igniter for Passenger's Airbag
B1002 1B [137] - Resistance Too High
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:03
9438747 - Igniter for Seat Belt Tensioner; Driver's Side
B1006 1B [137] - Resistance Too High
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:03
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
B1007 1B [137] - Resistance Too High
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:03
9442075 - Driver's Belt Force Limiter Igniter
B1013 1B [137] - Resistance Too High
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:03
9442331 - Passenger's Belt Force Limiter Igniter
B1014 1B [137] - Resistance Too High
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:03
9437979 - Igniter 2 for Passenger's Airbag
B1003 1B [137] - Resistance Too High
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:03
9440539 - Driver's Safety Belt Tensioner Igniter 2
B100D 1B [137] - Resistance Too High
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:03
9441051 - Front passenger's safety belt tensioner igniter 2
B100F 1B [137] - Resistance Too High
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:03
9443093 - Driver's Side Airbag Crash Sensor
B1017 15 [137] - Open or Short to Plus
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:03
9451029 - Crash sensor side airbag; passenger side
B1036 15 [137] - Open or Short to Plus
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:03
9443349 - Rear Side Airbag Crash Sensor (on driver's side)
B1018 15 [137] - Open or Short to Plus
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:03
9443605 - Rear Side Airbag Crash Sensor (on front passenger's side)
B1019 15 [137] - Open or Short to Plus
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:03
9443861 - Driver's Front Airbag Crash Sensor
B101A 15 [137] - Open or Short to Plus
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:03
9444117 - Front Passenger's Front Airbag Crash Sensor
B101B 15 [137] - Open or Short to Plus
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:03
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
B1016 14 [137] - Open or Short to Ground
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:03
9445937 - Seat occupied recognition control module
B1022 31 [137] - No Signal
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:05
9444885 - Driver's seat position sensor
B101E 15 [137] - Open or Short to Plus
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:03
9445141 - Passenger's seat position sensor
B101F 15 [137] - Open or Short to Plus
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:03
9482752 - Seat Occupied Recognition
B10B2 00 [008] - Function Restriction due to Missing Message(s)
Reset counter: 154
Mileage: 303245 km
Date: 2022.04.26
Time: 00:47:44
Part No SW: 1K5 953 521 AK HW: 5K0 953 569 B
Revision: FF010040 Serial number: 20110727301092
Coding: 088A140000
ROD: EV_SMLSNGVOLWS.rod
VCID: 76B5E89ED847ACEBE56-8022
Component: E221__MFL-YVJ H06 0022
Coding: E20000
0516 - Databus
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:02:08
147462 - Terminal 15
B1148 12 [009] - Short to Plus
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:02:08
226819 - Turn Signal Switch
B1144 07 [009] - Mechanical Failure
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:04:59
226827 - Turn Signal Switch
B1144 13 [009] - Open Circuit
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:02:08
227339 - Windshield Wiper Switch
B1145 13 [009] - Open Circuit
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:02:08
227355 - Windshield Wiper/Washer Switch
B1149 13 [009] - Open Circuit
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:02:08
Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
Part No SW: 561 920 970 C HW: 561 920 970 C
Component: KOMBI H07 0507
Coding: 231E01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04093
VCID: 1A6DDC2E0C1F288B21E-804E
12648704 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Steuergerät für Getriebe: keine Kommunikation]
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:00:34
12656896 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuergerät für Bremse: keine Kommunikation]
Reset counter: 154
Mileage: 303245 km
Date: 2022.04.26
Time: 00:47:29
13638912 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Steuergerät für Lenkhilfe: keine Kommunikation]
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:00:34
Part No SW: 7N0 907 530 P HW: 1K0 907 951
Component: J533 Gateway H40 1623
Revision: H40 Serial number: 30011201290475
Coding: 461000
VCID: 3D2737B2BD713FB3E4C-8068
8 Faults Found:
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:14:24
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:14:24
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:14:24
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:14:24
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:14:24
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:14:24
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:14:24
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:14:25
Address 1C: Position Sensing
Component: IMMO H07 0507
VCID: 6A8DCCEE9CFF780B71E-803E
9456433 - Key
B104B 31 [009] - No Signal
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:09:59
Address 44: Steering Assist
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H40 1623
Coding: 01030108
VCID: 6FBBDDFAA79D9D23260-803A
01512 - Control Module for Sliding Roof
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:36
02174 - Analog/Digital clock
Reset counter: 114
Mileage: 303245 km
Date: 2022.04.26
Time: 00:01:36
Address 52: Door Elect, Pass.
Address 56: Radio
Address 62: Door, Rear Left
Address 72: Door, Rear Right
Address 77: Telephone
End----------(Elapsed Time: 01:12, VBatt start/end: 12.4V/12.3V)-----------
