Coding ABS Module (MK60EC1 & 2012 NMS modules in a T3 Chassis)
Audigon by ettagon
Magalia, CA, USA
C?ID=389081
hi guys
I need help finding a coding that will work. Its a 2012passat tdi ckra. Vin# 1VWBN7A35CC054020
Tuesday,26,April,2022,12:32:30:02325
VCDS Version: 22.3.1.1 (x64)  HEX-V2 CB: 0.4615.4
Data version: 20220401 DS337.0
VIN: 1VWBN7A35CC054020   License Plate:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 4F 52 56 62 72 77
VIN: 1VWBN7A35CC054020   Mileage: 303240km-188424miles
02-Auto Trans -- Status: Cannot be reached 1100
04-Steering Angle -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: Cannot be reached 1100
44-Steering Assist -- Status: Cannot be reached 1100
52-Door Elect, Pass. -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Cannot be reached 1100
   Component: R4 2.0l TDI   H21 9982
   Revision: 71H21---    Serial number:                CVN: D240C61F5C3E0D04
   Coding: 001D0012042400000000
   Shop #: WSC 26113 444 00000
   ROD: EV_ECM20TDI01103L997009J.rod
   VCID: 3B2339AAA3E53183DA8-806E
   VINID: 0669D27874431534C014400200BA87ABCA
4718 - No Communication with Transmission Control Module
          U0101 00 [039] - -
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:44:49
                    Engine RPM: 0.00 /min
                    Coolant temperature: 17 °C
                    Intake air temperature: 17 °C
                    Ambient air pressure: 920 mbar
                    Voltage terminal 30: 12.600 V
                    Requested transmission torque: 1000.0 Nm
                    Limitation: accelerator pedal: 220.0 Nm
                    Cruise Control System (CCS): status-Bits 0-7: 15
                    selected gear-Bits 0-7: 0
                    Transmission torque intervention status-Bits 0-7: 16
                    Transmission torque intervention status-Bits 0-7: 128
                    Calculated reducing transmission intervention torque: 1000.0 Nm
17262 - Terminal 30
          U140A 00 [039] - Open Circuit
          [Terminal 30Open circuit]
                    Vehicle speed: 255 km/h
                    Coolant temperature: -40 °C
                    Intake air temperature: -40 °C
                    Ambient air pressure: 0 mbar
                    Voltage terminal 30: 12.820 V
                    Limitation: torque: 0.0 Nm
                    Engine torque: -500.0 Nm
                    Generator: load signal: 0.00 %
Readiness: 0 0 0 1 1
Address 02: Auto Trans
   Revision: 00H31001
   Shop #: WSC 00066 000 00000
   VCID: 7DA7F7B2FDF1FFB3A4C-8028
7 Faults Found:
03839 - RPM Sensor Front Left: Incorrect Signal
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:45:30
                    Count: 16386
                    Count: 12
                    Count: 4096
                    Count: 39
                    Count: 44800
                    Count: 65024
                    Fault Status: 00101100
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:48:41
                    Count: 16386
                    Count: 12
                    Count: 4096
                    Count: 48
                    Count: 44800
                    Count: 62720
03306 - Coding Not Valid
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:10
                    Count: 16387
                    Count: 12
                    Count: 4096
                    Count: 4161
                    Count: 44800
                    Count: 64768
                    Reset counter: 114
                    Date: 2022.04.26
                    Time: 00:45:23
                    Count: 16387
                    Count: 12
                    Count: 20992
                    Count: 195
                    Count: 44800
                    Fault Status: 01100101
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:45:17
                    Count: 16387
                    Count: 12
                    Count: 4096
                    Count: 279
                    Count: 44800
                    Count: 65024
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:45:17
                    Count: 16387
                    Count: 12
                    Count: 4096
                    Count: 295
                    Count: 44800
                    Count: 65024
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:45:17
                    Count: 16387
                    Count: 12
                    Count: 4096
                    Count: 270
                    Count: 44800
                    Count: 65024
   Part No SW: 561 907 044 H    HW: 561 907 044 H
   Component: Climatronic   043 0202
   Revision: 00001001
   Coding: 0010001002
   Shop #: WSC 09003 957 00200
   VCID: 1C61DA36062B56BB332-8048
15 Faults Found:
9473137 - Motor for Left Temperature Flap
          B108C 71 [008] - Actuator Stuck
                    Reset counter: 154
                    Mileage: 303245 km
                    Date: 2022.04.27
                    Time: 00:05:56
9475093 - Position Sensor for Left Temperature Flap Motor
          B1094 15 [009] - Open or Short to Plus
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.27
                    Time: 00:03:33
9475349 - Position Sensor for Right Temperature Flap Motor
          B1095 15 [009] - Open or Short to Plus
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.27
                    Time: 00:03:43
9476117 - Position Sensor for Defrost Flap Motor
          B1098 15 [009] - Open or Short to Plus
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:00:07
9476373 - Position Sensor for Front Air Distribution Flap Motor
          B1099 15 [009] - Open or Short to Plus
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.27
                    Time: 00:00:07
9476885 - Position Sensor for Fresh/Recirculated Flap Motor
          B109B 15 [009] - Open or Short to Plus
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:00:07
9470741 - Temperature Sensor for Left Footwell Vent
          B1083 15 [009] - Open or Short to Plus
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
9470997 - Temperature Sensor for Right Footwell Vent
          B1084 15 [009] - Open or Short to Plus
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
9471765 - Temperature Sensor for Left Vent
          B1087 15 [009] - Open or Short to Plus
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
9472021 - Temperature Sensor for Right Vent
          B1088 15 [009] - Open or Short to Plus
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
9472533 - Temperature Sensor for Evaporator Vent
          B108A 15 [009] - Open or Short to Plus
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
9481748 - High Pressure Sensor
          B10AE 14 [009] - Open or Short to Ground
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.27
                    Time: 00:00:08
9480469 - Control Circuit for A/C Compressor
          B10A9 15 [008] - Open or Short to Plus
                    Reset counter: 154
                    Mileage: 303245 km
                    Date: 2022.04.27
                    Time: 00:00:07
9496597 - Sunlight Photo Sensor
          B10E8 15 [008] - Open or Short to Plus
                    Reset counter: 154
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:03:02
9478421 - Diagnostic Line for Front Air Blower
          B10A1 15 [009] - Open or Short to Plus
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.27
                    Time: 00:02:24
   Part No SW: 5K0 937 085 S    HW: 5K0 937 085 S
   Component: BCM PQ35 B+   021 0064
   Revision: BH021001
   Coding: 6F200E1B902B08D408880001160004480171008640A00560E48060000C70
   VCID: 43D3414ADB954943928-8016
29 Faults Found:
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:23
                    Voltage: 12.60 V
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:27
                    Voltage: 12.60 V
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:27
                    Voltage: 12.60 V
00984 - Left Tail Light (M4)
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:27
                    Voltage: 12.60 V
00985 - Right Tail Light (M2)
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:27
                    Voltage: 12.55 V
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:26
                    Voltage: 12.55 V
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:24
                    Voltage: 12.55 V
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:24
                    Voltage: 12.55 V
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:24
                    Voltage: 12.55 V
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:24
                    Voltage: 12.55 V
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:24
                    Voltage: 12.55 V
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:26
                    Voltage: 12.55 V
01495 - Bulb for High-Beams; Left (M30)
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:28
                    Voltage: 12.55 V
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:26
                    Voltage: 12.55 V
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:28
                    Voltage: 12.55 V
01503 - Bulb for 3rd Brake Light (M25)
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:28
                    Voltage: 12.55 V
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:28
                    Voltage: 12.55 V
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:14:24
                    Voltage: 12.05 V
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:14:24
                    Voltage: 12.20 V
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:28
                    Voltage: 12.55 V
01800 - Light Switch (E1)
                    Fault Status: 01101000
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:22
                    Voltage: 12.55 V
02092 - Enabling Heated Seat
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:24
                    Voltage: 12.60 V
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:14:25
                    Voltage: 12.15 V
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:14:25
                    Voltage: 12.15 V
02742 - Bulb for Brake/Turn Signal Light; Left
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:24
                    Voltage: 12.60 V
02743 - Bulb for Brake/Turn Signal Light; Right
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:24
                    Voltage: 12.60 V
03188 - Bulb for Side Marker Light; Front Left
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:27
                    Voltage: 12.55 V
03189 - Bulb for Side Marker Light; Front Right
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:27
                    Voltage: 12.55 V
01339 - Door Warning Light
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:14:25
                    Voltage: 12.30 V
   Part No SW: 5C0 959 655     HW: 5C0 959 655
   Component: AirbagVW10G   013 0809
   Serial number: 003ENM01C4TM
   Coding: 00003548
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 6FBBDDFAA71D9D23260-803A
24 Faults Found:
9440027 - Driver's side; side-airbag igniter
          B100B 1B [137] - Resistance Too High
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:03
9439771 - Front Passenger's Side Airbag Igniter
          B100A 1B [137] - Resistance Too High
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:03
9438491 - Igniter for Driver head airbag
          B1005 1B [137] - Resistance Too High
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:03
9438235 - Igniter for Front passenger's Head Curtain Airbag
          B1004 1B [137] - Resistance Too High
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:03
          B1000 1B [137] - Resistance Too High
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:03
9437723 - Igniter for Passenger's Airbag
          B1002 1B [137] - Resistance Too High
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:03
          B1006 1B [137] - Resistance Too High
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:03
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
          B1007 1B [137] - Resistance Too High
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:03
9442075 - Driver's Belt Force Limiter Igniter
          B1013 1B [137] - Resistance Too High
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:03
9442331 - Passenger's Belt Force Limiter Igniter
          B1014 1B [137] - Resistance Too High
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:03
9437979 - Igniter 2  for Passenger's Airbag
          B1003 1B [137] - Resistance Too High
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:03
9440539 - Driver's Safety Belt Tensioner Igniter 2
          B100D 1B [137] - Resistance Too High
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:03
9441051 - Front passenger's safety belt tensioner igniter 2
          B100F 1B [137] - Resistance Too High
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:03
9443093 - Driver's Side Airbag Crash Sensor
          B1017 15 [137] - Open or Short to Plus
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:03
9451029 - Crash sensor side airbag; passenger side
          B1036 15 [137] - Open or Short to Plus
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:03
9443349 - Rear Side Airbag Crash Sensor (on driver's side)
          B1018 15 [137] - Open or Short to Plus
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:03
9443605 - Rear Side Airbag Crash Sensor (on front passenger's side)
          B1019 15 [137] - Open or Short to Plus
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:03
9443861 - Driver's Front Airbag Crash Sensor
          B101A 15 [137] - Open or Short to Plus
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:03
9444117 - Front Passenger's Front Airbag Crash Sensor
          B101B 15 [137] - Open or Short to Plus
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:03
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
          B1016 14 [137] - Open or Short to Ground
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:03
9445937 - Seat occupied recognition control module
          B1022 31 [137] - No Signal
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:05
9444885 - Driver's seat position sensor
          B101E 15 [137] - Open or Short to Plus
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:03
9445141 - Passenger's seat position sensor
          B101F 15 [137] - Open or Short to Plus
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:03
9482752 - Seat Occupied Recognition
          B10B2 00 [008] - Function Restriction due to Missing Message(s)
                    Reset counter: 154
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:47:44
   Part No SW: 1K5 953 521 AK    HW: 5K0 953 569 B
   Revision: FF010040    Serial number: 20110727301092
   Coding: 088A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 76B5E89ED847ACEBE56-8022
   Component: E221__MFL-YVJ  H06 0022
   Coding: E20000
0516 - Databus
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:02:08
147462 - Terminal 15
          B1148 12 [009] - Short to Plus
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:02:08
226819 - Turn Signal Switch
          B1144 07 [009] - Mechanical Failure
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:04:59
226827 - Turn Signal Switch
          B1144 13 [009] - Open Circuit
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:02:08
227339 - Windshield Wiper Switch
          B1145 13 [009] - Open Circuit
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:02:08
          B1149 13 [009] - Open Circuit
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:02:08
   Part No SW: 561 920 970 C    HW: 561 920 970 C
   Component: KOMBI         H07 0507
   Coding: 231E01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04093
   VCID: 1A6DDC2E0C1F288B21E-804E
12648704 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerät für Getriebe: keine Kommunikation]
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:00:34
12656896 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Bremse: keine Kommunikation]
                    Reset counter: 154
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:47:29
13638912 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerät für Lenkhilfe: keine Kommunikation]
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:00:34
   Part No SW: 7N0 907 530 P    HW: 1K0 907 951
   Component: J533  Gateway H40 1623
   Revision:   H40       Serial number: 30011201290475
   Coding: 461000
   VCID: 3D2737B2BD713FB3E4C-8068
8 Faults Found:
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:14:24
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:14:24
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:14:24
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:14:24
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:14:24
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:14:24
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:14:24
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:14:25
Address 1C: Position Sensing
   Component: IMMO          H07 0507
   VCID: 6A8DCCEE9CFF780B71E-803E
9456433 - Key
          B104B 31 [009] - No Signal
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:09:59
Address 44: Steering Assist
   Component: EZE_2         H40 1623
   Coding: 01030108
   VCID: 6FBBDDFAA79D9D23260-803A
01512 - Control Module for Sliding Roof
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:36
02174 - Analog/Digital clock
                    Reset counter: 114
                    Mileage: 303245 km
                    Date: 2022.04.26
                    Time: 00:01:36
Address 52: Door Elect, Pass.
Address 56: Radio
Address 62: Door, Rear Left
Address 72: Door, Rear Right
Address 77: Telephone
End----------(Elapsed Time: 01:12, VBatt start/end: 12.4V/12.3V)-----------
Hi and welcome.
How did it lose its coding? What was done, what parts have been replaced?
Why do you have so many modules that are off-line ("Cannot be reached")? The transmission and the steering assist being off-line are particularly troubling.
Audigon by ettagon
Magalia, CA, USA
C?ID=389081
Hi and welcome.
Yeah sorry I should have stated that this is a junk yard engine that I’m putting in an 88 vanagon. So I wasn’t able to get everything out of the donor car. But I was able to get the abs module but it was damaged and will not read I was able to get a different one same part number. And i wasn’t able to get the dsg transmission it will be manual transmission in the Vanagon but haven’t gotten that far yet. At this point in the build the engine is running.
  • Wow
dieseldub
Gresham, OR
C?ID=28764
You're going to have a real hard time coding it if you also don't have a brake pressure sensor in the master cylinder or steering angle sensor.
Whenever you swap in a Mk60 ABS that needs to be recoded, the coding will NOT save unless you also do the basic settings calibrations of the various acceleration sensors, brake pressure sensor and steering angle sensor in the same session.
And if any one of those sensors is not installed... well... all I can say is "good luck".
Audigon by ettagon
Magalia, CA, USA
C?ID=389081
Ok I have an idea. I have a 2012 Passat 2.5 gas car that I can probably connect my project to its steering assist module. Brake pressure sensor I’ll have to think about 🤔
iichel
Eindhoven, NB, NL
C?ID=284912
perhaps a MK60EC1 compatible master cylinder swap?
I absolutely agree with the advice here. If the ABS module doesn't see data from G85, G201 and all of his factory installed buddies it won't cooperate. When you get to the point where those issues are resolved this is probably the closest factory-like scan we have that includes what you want to accomplish:
That car was born as a Manual trans (rather than the 02E/DSG your VIN decrypts to) but you can use that as a starting point.
Good reads include:
and
If you use the Long Coding Helper (off the car) and load @etz2k 's label file you can tweak things as needed to accommodate the alternative VIN and any brake, suspension and similar modifications that may be involved in your conversion. I'll break-down the MT NMS TDI coding from that reference scan below:
C54BC0F5492300FEA31403E692220042A70000 (Factory string complete)
C500C00049000000A300030092000042A70000 (Factory string with 00's in VIN positions)
C5__C0__49__00__A3__03__92__0042A70000 (Factory string with __'s in VIN positions. You cannot use that in a coding helper but it works as a visual aid)
At this point you could start by inserting the correct VIN Bytes from your donor parts. That results in:
C54BC0F5492700FEA30B03E692190042A70000
That may not be the final coding you run with but it should be accepted as a starting point.
On an entirely different note (to building MK60EC1 form scratch) there were MK60EC1 cars without Electromechanical steering rack that used G85 via the clock spring/address 16. This may be the entirely wrong direction for your project but the long-winded thread here may he helpful:
You might be able to get away with a tweak to the coding in address 16 (Byte 0, Bit 1) resulting in a virtual G85 on the PT databus resolving this problem:
If so, and you haven't already installed the factory-like 44/rack, then 03 would need to be coded for 1N1 in Bytes 6 and 14.
P.S. I just noticed the 2012 Donor is a 2.5L. That may have the 1N1 rack in it already. If there aren't any wire connectors hanging off of it and is uses an old-school pump with hoses you may want to try my address 16 tweak.
Audigon by ettagon
Magalia, CA, USA
C?ID=389081
Ok well turn out my gas Passat 2.5 uses a mechanical power steering unit this will not work for me. So I’ve come up with a different plan I still have the original ABS module for this project although it is damaged from the wrecking breaking some resistors on the circuit board therefore it will not turn on but if I pull the memory chip and put it into the new replaced module I think it will just work. It’s only 8 pins. I’ll post my results. Update!!!!!!! I did not do this!!!!!!!!!!!!
Audigon by ettagon
Magalia, CA, USA
C?ID=389081
Good reads include:
and
Thank you so much Dana!!! It excepted that coding!!!wow. Now I can move forward. Thank you again!!
etz2k
C?ID=69430
@Audigon by ettagon you should use your 379bl ABS-MODUL, there is no relevant difference (except G251 sensor), the difference is only the coding.
What axis are you use, because of the WSS? Do you make the Passat fit?
And before you go on with ESP in the T3, please read this about MK20 in the T3 (use a translator):
The conclusion is don't do it it won't work properly!
